  4. [How-to] Node.js für ioBroker richtig updaten
installationlinuxnodenode.jsnodejswindows
1.1k Beiträge 106 Kommentatoren 885.4k Aufrufe 112 Beobachtet
  • W Offline
    W Offline
    watcherkb
    #194
    Ich hab nur Fehlermeldungen. Habe schon alles mögliche versucht. Fixer, alle Punkte von oben in der Beschreibung...
    $ ./iobroker add shuttercontrol  --host iobrokertest
    NPM version: 6.9.0
    npm install iobroker.shuttercontrol@0.3.1 --production --save --prefix "/opt/iobroker" (System call)
    In file included from ../node_modules/nan/nan.h:190:0,                 from ../src/unix_dgram.cc:5:
    ../node_modules/nan/nan_maybe_43_inl.h: In function ‘Nan::Maybe<bool> Nan::ForceSet(v8::Local<v8::Object>, v8::Local<v8::Value>, v8::Local<v8::Value>, v8::PropertyAttribute)’:
    ../node_modules/nan/nan_maybe_43_inl.h:88:15: error: ‘class v8::Object’ has no member named ‘ForceSet’
       return obj->ForceSet(GetCurrentContext(), key, value, attribs);
    In file included from ../src/unix_dgram.cc:5:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’:
    ../node_modules/nan/nan.h:817:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
             v8::Isolate::GetCurrent(), target, func, argc, argv);
    In file included from ../node_modules/nan/nan.h:47:0,
    /home/iobroker/.node-gyp/10.16.0/include/node/node.h:177:50: note: declared here
                     NODE_EXTERN v8::Local<v8::Value> MakeCallback(
    /home/iobroker/.node-gyp/10.16.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’
         __attribute__((deprecated(message))) declarator
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’:
    ../node_modules/nan/nan.h:831:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
             v8::Isolate::GetCurrent(), target, symbol, argc, argv);
    /home/iobroker/.node-gyp/10.16.0/include/node/node.h:170:50: note: declared here
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’:
    ../node_modules/nan/nan.h:845:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
             v8::Isolate::GetCurrent(), target, method, argc, argv);
    /home/iobroker/.node-gyp/10.16.0/include/node/node.h:163:50: note: declared here
    In file included from ../src/unix_dgram.cc:5:0:../node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::Callback::Call_(v8::Isolate*, v8::Local<v8::Object>, int, v8::Local<v8::Value>*) const’:
    ../node_modules/nan/nan.h:1463:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Socket(Nan::NAN_METHOD_ARGS_TYPE)’:../src/unix_dgram.cc:189:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       domain      = info[0]->Int32Value();
    In file included from /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:26:0,
                     from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63,
                     from ../node_modules/nan/nan.h:47,
    /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2478:46: note: declared here
       V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
    /home/iobroker/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
       declarator __attribute__((deprecated(message)))
    ../src/unix_dgram.cc:190:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       type        = info[1]->Int32Value();
    ../src/unix_dgram.cc:191:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       protocol    = info[2]->Int32Value();
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Bind(Nan::NAN_METHOD_ARGS_TYPE)’:../src/unix_dgram.cc:230:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       fd = info[0]->Int32Value();
    ../src/unix_dgram.cc:231:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
       String::Utf8Value path(info[1]);
    /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2892:28: note: declared here
                       explicit Utf8Value(Local<v8::Value> obj));
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::SendTo(Nan::NAN_METHOD_ARGS_TYPE)’:../src/unix_dgram.cc:258:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/unix_dgram.cc:259:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       buf = info[1]->ToObject();
    In file included from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63:0,
    /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:10046:15: note: declared here
     Local<Object> Value::ToObject() const {
    ../src/unix_dgram.cc:260:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       offset = info[2]->Uint32Value();
    /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2477:47: note: declared here
       V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);
    ../src/unix_dgram.cc:261:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       length = info[3]->Uint32Value();
    ../src/unix_dgram.cc:262:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
       String::Utf8Value path(info[4]);
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Send(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/unix_dgram.cc:302:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/unix_dgram.cc:303:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Connect(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/unix_dgram.cc:340:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/unix_dgram.cc:341:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Close(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/unix_dgram.cc:361:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    make: *** [Release/obj.target/unix_dgram/src/unix_dgram.o] Fehler 1
    gyp
     ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
    gyp ERR! System Linux 4.9.0-9-amd64
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
    gyp ERR! node -v v10.16.0
    gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
    npm
    WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules/unix-dgram):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install: `node-gyp rebuild`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    host.iobrokertest install adapter shuttercontrol
    npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.shuttercontrol"
    npm notice
     created a lockfile as package-lock.json. You should commit this file.
    npm WARN tslint@5.18.0 requires a peer of typescript@>=2.3.0-dev || >=2.4.0-dev || >=2.5.0-dev || >=2.6.0-dev || >=2.7.0-dev || >=2.8.0-dev || >=2.9.0-dev || >=3.0.0-dev || >= 3.1.0-dev || >= 3.2.0-dev but none is installed. You must install peer dependencies yourself.npm WARN tsutils@2.29.0 requires a peer of typescript@>=2.1.0 || >=2.1.0-dev || >=2.2.0-dev || >=2.3.0-dev || >=2.4.0-dev || >=2.5.0-dev || >=2.6.0-dev || >=2.7.0-dev || >=2.8.0-dev || >=2.9.0-dev || >= 3.0.0-dev || >= 3.1.0-dev but none is installed. You must install peer dependencies yourself.
    got /opt/iobroker/node_modules/iobroker.shuttercontrol/admin
    upload [4] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/words.js words.js application/javascript
    upload [3] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/tsconfig.json tsconfig.json application/json
    upload [2] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/style.css style.css text/css
    upload [1] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/shuttercontrol.png shuttercontrol.png image/png
    upload [0] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/index_m.html index_m.html text/html
    host.iobrokertest object system.adapter.shuttercontrol created
    host.iobrokertest create instance shuttercontrol
    host.iobrokertest object shuttercontrol.0.info.Azimut created
    host.iobrokertest object shuttercontrol.0.info.Elevation created
    host.iobrokertest object shuttercontrol.0.info.GoldenHourEnd created
    host.iobrokertest object shuttercontrol.0.info.GoldenHour created
    host.iobrokertest object shuttercontrol.0.info.Sunset created
    host.iobrokertest object shuttercontrol.0.info.Sunrise created
    host.iobrokertest object shuttercontrol.0.info.downTimeLiving created
    host.iobrokertest object shuttercontrol.0.info.downTimeSleep created
    host.iobrokertest object shuttercontrol.0.info.upTimeLiving created
    host.iobrokertest object shuttercontrol.0.info.upTimeSleep created
    host.iobrokertest object shuttercontrol.0.control.autoSleep created
    host.iobrokertest object shuttercontrol.0.control.autoLiving created
    host.iobrokertest object shuttercontrol.0.control.Holiday created
    host.iobrokertest object shuttercontrol.0.control created
    host.iobrokertest object shuttercontrol.0.info created
    host.iobrokertest object shuttercontrol.0.shutters.autoSun created
    host.iobrokertest object shuttercontrol.0.shutters.autoDown created
    host.iobrokertest object shuttercontrol.0.shutters.autoUp created
    host.iobrokertest object shuttercontrol.0.shutters created
    host.iobrokertest object system.adapter.shuttercontrol.0.outputCount created
    host.iobrokertest object system.adapter.shuttercontrol.0.inputCount created
    host.iobrokertest object system.adapter.shuttercontrol.0.uptime created
    host.iobrokertest object system.adapter.shuttercontrol.0.memRss created
    host.iobrokertest object system.adapter.shuttercontrol.0.memHeapTotal created
    host.iobrokertest object system.adapter.shuttercontrol.0.memHeapUsed created
    host.iobrokertest object system.adapter.shuttercontrol.0.cputime created
    host.iobrokertest object system.adapter.shuttercontrol.0.cpu created
    host.iobrokertest object system.adapter.shuttercontrol.0.connected created
    host.iobrokertest object system.adapter.shuttercontrol.0.alive created
    host.iobrokertest object system.adapter.shuttercontrol.0 created
    process exited with code 0
    CC2538+CC2592 PA-Zigbee-Funkmodul
    • apollon77A Offline
      #195
      Auch hier unix_dgram:
      Bitte in diesem Thread Post #2 (die FAQ) Punkt #3 lesen ...
      Oder ignorieren wenn Du kein Syslog nutzt. Eine 1.5.13 vom controller wo die Meldung weg ist wird gerade vorbereitet
      • Z Offline
        Z Offline
        zgadgeter
        schrieb am zuletzt editiert von zgadgeter
        #196
        ich habe bei meinem node.js ein update gemacht auf v10.16.0. Das hat auch funktioniert.
        Danach sollte ich auch ein npm rebuild machen, aber da kamen Fehler auf, die ich nicht versteh. Ich habe auch danach den Anweisungen gefolgt und die weiteren Methoden probiert....aber mein zigbee funktioniert nicht mehr. Kann mir da jemand helfen? danke.
        Edit: ich habe jetzt die letzte Version von npm installiert...denke das Problem ist nicht mit npm? Alle Adapter funktionieren, nur Zigbee nicht mehr. Ich habe auch probiert eine extra Instanz von dem Zigbee Adapter zu installieren, das hat aber auch nicht funktioniert.
        Node.js
        v10.16.0
        NPM
        v6.10.1-next.1
        > iobroker@2.0.2 install /opt/iobroker/node_modules/iobroker
        > node lib/checkVersions.js
        NPM version: 6.9.0
        > iobroker@2.0.2 postinstall /opt/iobroker/node_modules/iobroker
        > node lib/install.js
        lib/install.js is not being run as part of an installation - skipping...
        > usb@1.6.0 install /opt/iobroker/node_modules/iobroker.ble/node_modules/usb
        > prebuild-install --verbose || node-gyp rebuild
        prebuild-install info begin Prebuild-install version 5.3.0
        prebuild-install info looking for cached prebuild @ /home/tyrone/.npm/_prebuilds/f78b17-usb-v1.6.0-node-v64-linux-x64.tar.gz
        prebuild-install info found cached prebuild
        prebuild-install info unpacking @ /home/tyrone/.npm/_prebuilds/f78b17-usb-v1.6.0-node-v64-linux-x64.tar.gz
        prebuild-install WARN install EACCES: permission denied, open 'build/Release/usb_bindings.node'
        gyp ERR! clean error
        gyp ERR! stack Error: EACCES: permission denied, rmdir 'build'
        gyp ERR! System Linux 4.18.0-25-generic
        gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        gyp ERR! cwd /opt/iobroker/node_modules/iobroker.ble/node_modules/usb
        gyp ERR! not ok
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! usb@1.6.0 install: `prebuild-install --verbose || node-gyp rebuild`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the usb@1.6.0 install script.
        npm ERR!     /home/tyrone/.npm/_logs/2019-07-06T19_04_34_967Z-debug.log
        • Z Offline
          Z Offline
          zgadgeter
          #197
          Oh, kann mir keiner hier helfen? Vielleicht bin ich im falschem Thema?
          StabilostickS 1 Antwort Letzte Antwort
          • Z zgadgeter
            StabilostickS Offline
            Stabilostick
            schrieb am zuletzt editiert von Stabilostick
            #198
            @zgadgeter
            Führe als normaler User den ioBoker-Installationsfixer testhalber im iobroker-Ordner aus:
            curl -sL https://iobroker.net/fix.sh | bash -
            Bleibt das Problem bestehen?
            Z 1 Antwort Letzte Antwort
            • StabilostickS Stabilostick
              @zgadgeter
              Z Offline
              Z Offline
              zgadgeter
              #199
              @Stabilostick Hallo und danke fuer die Antwort. Habe ich gerade ausgefueht...leider keine Aenderung. Alle Adapter funktionieren, nur der Zigbee nicht, und der ist leider der wichtigste bei mir. Alle Komponenten sind weg. :(.
              Hast Du noch einen Tipp?
              danke nochmals.
              • Z zgadgeter
                danke nochmals.
                Stabilostick
                #200
                @zgadgeter
                apropos keine Änderung... Der ‚rebuild‘-Fehler ist geblieben?
                • StabilostickS Offline
                  Stabilostick
                  #201
                  Folgende Info habe ich im ersten Artikel mit aufgenommen.
                  Hinweis: Falls die Version des js-controllers <= 1.5.12 ist, muss VOR dem Update in den Einstellungen der Admin-Instanz "Verschlüsselung (https) benutzen" ausgeschaltet werden. Das in ioBroker bis dahin integrierte Zertifikat kann zu Problemen beim Starten des Admin bei Node.js-Versionen >= 10 führen.
                  Fall jemand schon das Node.js-Update gemacht hat und der Admin nicht startet:
                  Einfach mit
                  iobroker add admin
                  eine weitere Admin-Instanz installieren. Die ist dann ohne SSL erreichbar.
                    @zgadgeter
                    Z Offline
                    Z Offline
                    zgadgeter
                    #202
                    @Stabilostick
                    @Stabilostick said in [How-to] Node.js für ioBroker richtig updaten:
                    @zgadgeter
                    Hi, also ich habe rebuild laufen lassen, und es lange gelaufen mit vielen angaben. Also auf jeden Fall viel anders als zuvor.
                    Am Ende kam dann folgende Fehler. Nur, dann startete ich iobroker wieder, und die Adapter waren (fast) alle Rot. Nach und nach wurden die dann Gruen...auch der Zigbee. Beim öffnen vom zigbee kam eine Nachricht das ich den zuerst "saving" muss, und keine Geräte waren drin. Es gab aber nichts zu saven. Jetzt steht er nur auf Geld, und diese save Nachricht kommt immer bei aufmachen. Ich starte mal mein Iobroker von neu...
                    gyp ERR! build error
                    gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
                    gyp ERR! node-gyp -v v4.0.0
                    gyp ERR! not ok
                    npm ERR! errno 1
                    npm ERR! unix-dgram@0.2.3 install: `node-gyp rebuild`
                    npm ERR!
                    npm ERR! Failed at the unix-dgram@0.2.3 install script.
                    npm ERR!     /home/tyrone/.npm/_logs/2019-07-07T19_47_38_330Z-debug.log
                    • Z zgadgeter
                      @Stabilostick
                      @zgadgeter
                      gyp ERR! not ok
                      npm ERR! errno 1
                      npm ERR!
                      Stabilostick
                      #203
                      @zgadgeter
                      Zu unix.dgram verweise ich auf Post #2 dieses threads (die FAQ dazu) Punkt 3
                      3.) npm rebuild Fehler mit "unix-dgram 0.2.3" (js-controller 1.x mit Node.js 10/12) ...
                      Am Ende "ignore" wenn Du kein syslog brauchst. Wir arbeiten an einer 1.5.13 wo das weg sein sollte
                        @zgadgeter
                        Z Offline
                        Z Offline
                        zgadgeter
                        #204
                        @Stabilostick
                        Hi, gesagt getan, hier der output danach:
                        Dann habe ich npm rebuild ausgefuehrt, und der lief ohne (Probleme/errors durch, und auch schnell. Aber Zigbee will immer noch nicht, und beim klicken auf Zigbee immer noch folgendes auf dem Bild unten.
                        UPDATE: habe probiert einen zweiten Zigbee adapter zu installieren um zu sehen ob das besser funktioniert...Tut er nicht, selbes Ergebniss.
                        Brauche noch hilfe bitte :)
                        > unix-dgram@2.0.3 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/unix-dgram
                        > node-gyp rebuild
                        make: Entering directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/unix-dgram/build'
                          CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
                          SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
                          COPY Release/unix_dgram.node
                        make: Leaving directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/unix-dgram/build'
                        npm notice created a lockfile as package-lock.json. You should commit this file.
                        + unix-dgram@2.0.3
                        added 42 packages from 16 contributors and audited 61 packages in 11.054s
                        found 0 vulnerabilities
                        • MathiasJM Offline
                          MathiasJM Offline
                          MathiasJ
                          schrieb am zuletzt editiert von MathiasJ
                          #205
                          Wenn dann mein Raspberry PI4 dann endlich kommen sollte, traue ich mich gleich, IObroker mit node 12 zu installieren.
                          Als Test erst mal........ und werde weiter berichten.
                          Habe ich mit dem Tinkerboard schon umgesetzt.: https://forum.iobroker.net/topic/23703/testinstallation-unter-node-12-6-0/2
                          IObroker auf dem NUC als VM.
                          • Z zgadgeter
                            @Stabilostick
                            > node-gyp rebuild
                            + unix-dgram@2.0.3
                            Stabilostick
                            #206
                            @zgadgeter
                            Woher soll er bei der neu installierten Adapterinstanz, die nicht konfiguriert ist, eine Geräteliste bekommen?
                            Vielleicht musst Du alles neu pairen? Richtiger USB-Port? Irgendwelche zigbee-Fehler im Log?
                              @zgadgeter
                              Z Offline
                              Z Offline
                              zgadgeter
                              #207
                              @Stabilostick
                              Wie gesagt, sobald ich den Adapter auf mache bekomme ich den Hinweise das ich den Adapter speichern und laufen lassen muss. Wie in dem Bild oben.
                              Ein Fehler im Log ist folgender:
                              Error while starting zigbee-shepherd!. Error: Error: No such file or directory, cannot open /dev/ttyACM0
                              Ist ja ziemlich eindeutig. Ich habe dann nach USB ports gesucht mit:
                              ls -la /dev/serial/by-id/
                              Dabei bekomme ich:
                              ls: cannot access '/dev/serial/by-id/': No such file or directory
                              Und nach pruefen fehlt tatsaechlich das "serial" Verzeichnis. Also gehe ich davon aus das irgendwie oder irgendwas dieses Geloescht hat....Egal, wie bekomme ich das zurueck so das Iobroker mein USB port und somit den Zigbee finden kann?
                              • Z zgadgeter
                                @Stabilostick
                                Dabei bekomme ich:
                                Stabilostick
                                #208
                                @zgadgeter
                                Dann wird wohl der zigbee-Stick von Deinem OS nicht richtig erkannt. Das hat aber weniger mit dem Node.js-Update zu tun. Welche HW? Welches Os? Was sagt der Befehl „lsusb“? Neuer Thread?
                                  @zgadgeter
                                  Z Offline
                                  Z Offline
                                  zgadgeter
                                  #209
                                  @Stabilostick
                                  Der Rechner ist ein Nuc. OS is unten.
                                  Frage ist, kann ich das serial Verzeichnis von einem anderem Iobroker nehmen wo ich genau den selben stick nochmals habe, und der auch funktioniert? Da habe ich nach gesehen und habe den stick gefunden im serial Verzeichnis.
                                  Linux ubuntu_iobroker 4.18.0-25-generic #26~18.04.1-Ubuntu SMP Thu Jun 27 07:28:31 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
                                  lsusb
                                  Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                                  Bus 001 Device 008: ID 8087:0a2a Intel Corp.
                                  Bus 001 Device 007: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
                                  Bus 001 Device 006: ID 0a5c:2198 Broadcom Corp. Bluetooth 3.0 Device
                                  • Z zgadgeter
                                    @Stabilostick
                                    lsusb
                                    Stabilostick
                                    #210
                                    @zgadgeter sagte in [How-to] Node.js für ioBroker richtig updaten:
                                    Master-Slave iobroker-Installation.
                                    Oder stecke den Stick in andere USB-Ports und schaue mit lsusb nach.
                                      Z Offline
                                      Z Offline
                                      zgadgeter
                                      #211
                                      Nee, kann ich nicht...bin zur Zeit 200 km weg, login via VPN...
                                      Was ist mit dem Verzeichnis kopieren? Aber, in dem Verzeichnis "serial/byid" ist ein komisches file:
                                      ioBroker-Pi:/dev/serial/by-id $ ls -l
                                      insgesamt 0
                                      lrwxrwxrwx 1 root root 13 Jul  8 22:17 usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E208A1-if00 -> ../../ttyACM0
                                      Laesst sich nicht kopieren?
                                      • Z zgadgeter
                                        insgesamt 0
                                        Stabilostick
                                        #212
                                        @zgadgeter
                                        Das ist der zigbee-Stick. Und er wird nach /dev/ttyACM0 umgeleitet (siehe Ende der Zeile).
                                          @zgadgeter
                                          Z Offline
                                          Z Offline
                                          zgadgeter
                                          #213
                                          @zgadgeter
                                          ok, aber wie bekomme ich das ganze auf den anderen iobroker einfach kopiert?
