  4. History will mich net!
history.0 errorusb-stick
7 Beiträge 4 Kommentatoren 284 Aufrufe 3 Beobachtet
  • MathiasJM Offline
    MathiasJM Offline
    MathiasJ
    Ich wollte mal anfangen, Systemzustände zu loggen.
    Aber irgendwie will History mich net.
    Ich habe einen USB-Stick reingesteckt und in der Config-Seite als Speicherort /dva/sda1/ eingegeben.
    Dabei kam das dann raus:
    host.rock64	2019-06-30 23:24:57.762	error	instance system.adapter.history.0 terminated with code 0 (OK)
    host.rock64	2019-06-30 23:24:57.762	error	Caught by controller[0]: path: '/dev/sda1/history/' }
    host.rock64	2019-06-30 23:24:57.762	error	Caught by controller[0]: code: 'ENOTDIR',
    host.rock64	2019-06-30 23:24:57.762	error	Caught by controller[0]: syscall: 'mkdir',
    host.rock64	2019-06-30 23:24:57.762	error	Caught by controller[0]: errno: -20,
    host.rock64	2019-06-30 23:24:57.761	error	Caught by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    host.rock64	2019-06-30 23:24:57.761	error	Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
    host.rock64	2019-06-30 23:24:57.761	error	Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
    host.rock64	2019-06-30 23:24:57.761	error	Caught by controller[0]: at Socket.that.getForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:869:25)
    host.rock64	2019-06-30 23:24:57.761	error	Caught by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:830:13)
    host.rock64	2019-06-30 23:24:57.761	error	Caught by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:869:54)
    host.rock64	2019-06-30 23:24:57.760	error	Caught by controller[0]: at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5288:62)
    host.rock64	2019-06-30 23:24:57.760	error	Caught by controller[0]: at Object.ready (/opt/iobroker/node_modules/iobroker.history/main.js:144:22)
    host.rock64	2019-06-30 23:24:57.760	error	Caught by controller[0]: at main (/opt/iobroker/node_modules/iobroker.history/main.js:348:12)
    host.rock64	2019-06-30 23:24:57.759	error	Caught by controller[0]: at Object.mkdirSync (fs.js:757:3)
    host.rock64	2019-06-30 23:24:57.759	error	Caught by controller[0]: { Error: ENOTDIR: not a directory, mkdir '/dev/sda1/history/'
    host.rock64	2019-06-30 23:24:56.217	info	instance system.adapter.history.0 started with pid 7129
    Dann wollte ich sudo mkdir /dev/sda1 machen, aber mein Rock64 erzählt mir, die Dateien existieren schon.
    Hat jemand eine Idee?
    Als System habe ich mal das Bild hier eingefügt:
    Gruß,
    Mathias
    IObroker auf dem NUC als VM.
    • MathiasJM MathiasJ
      Gruß,
      Mathias
      crunchipC Abwesend
      crunchipC Abwesend
      @MathiasJ ja mit einfach reinstecken ist das aber nicht getan😁
      https://linuxhint.com/how-to-mount-usb-drive-on-linux/
      • MathiasJM Offline
        MathiasJM Offline
        MathiasJ
        schrieb am zuletzt editiert von MathiasJ
        danke, habe es so gemacht..... aber geht trotzdem nicht, weil er die Unterordner anmeckert.
        Ist ja erst mal egal. So wichtig is es wirklich nicht.
        habe noch andere (wichtigere) Baustellen......
        • SBorgS Offline
          SBorgS Offline
          SBorg
          Hat der User iobroker überhaupt genügend Rechte auf '/dev/sda1/' ?
          LG SBorg ( SBorg auf GitHub)
          • MathiasJM Offline
            MathiasJM Offline
            MathiasJ
            wie finde ich das heraus?
              @MathiasJ sagte in History will mich net!:
              Gar nicht, denn man kann nicht direkt auf /dev/sda1 zugreifen, sondern muss erst ein Verzeichnis mounten. Gibt es schon das Verzeichnis /media ? Was sagt ?
              df -h
              • MathiasJM Offline
                MathiasJM Offline
                MathiasJ
                ach so, ih habe als Verweis mnt genommen, das hat auch funktioniert.
                Aber IObroker konnte eben keine Unterverzeichnisse anlegen.
                82.8k
