  4. ioBroker als Dockerimage - mqtt Problem
dockermqtt
3 Beiträge 3 Kommentatoren 966 Aufrufe 2 Beobachtet
    Surfer2010
    Meine Installation ist Docker mit dem DockerImage von buanet, in dieser Installation funktioniert MQTT nicht.
    Wie kann man das beheben? (siehe LOG unten)
    host.homeserver	2019-06-10 17:10:39.322	info	Restart adapter system.adapter.mqtt.0 because enabled
    host.homeserver	2019-06-10 17:10:39.321	error	instance system.adapter.mqtt.0 terminated with code 0 (OK)
    host.homeserver	2019-06-10 17:10:39.321	error	Caught by controller[0]: port: 1883 }
    host.homeserver	2019-06-10 17:10:39.321	error	Caught by controller[0]: address: '::',
    host.homeserver	2019-06-10 17:10:39.321	error	Caught by controller[0]: syscall: 'listen',
    host.homeserver	2019-06-10 17:10:39.321	error	Caught by controller[0]: code: 'EADDRINUSE',
    host.homeserver	2019-06-10 17:10:39.321	error	Caught by controller[0]: errno: 'EADDRINUSE',
    host.homeserver	2019-06-10 17:10:39.321	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
    host.homeserver	2019-06-10 17:10:39.321	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4332:61
    host.homeserver	2019-06-10 17:10:39.321	error	Caught by controller[0]: at adapter.getForeignStates (/opt/iobroker/node_modules/iobroker.mqtt/main.js:133:64)
    host.homeserver	2019-06-10 17:10:39.321	error	Caught by controller[0]: at MQTTServer (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:12:47)
    host.homeserver	2019-06-10 17:10:39.321	error	Caught by controller[0]: at new MQTTServer (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:1138:7)
    host.homeserver	2019-06-10 17:10:39.320	error	Caught by controller[0]: at _constructor (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:1121:9)
    host.homeserver	2019-06-10 17:10:39.320	error	Caught by controller[0]: at startServer (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:1018:28)
    host.homeserver	2019-06-10 17:10:39.320	error	Caught by controller[0]: at Server.listen (net.js:1485:7)
    host.homeserver	2019-06-10 17:10:39.320	error	Caught by controller[0]: at listenInCluster (net.js:1401:12)
    host.homeserver	2019-06-10 17:10:39.320	error	Caught by controller[0]: at Server.setupListenHandle [as _listen2] (net.js:1360:14)
    host.homeserver	2019-06-10 17:10:39.320	error	Caught by controller[0]: { Error: listen EADDRINUSE :::1883
    mqtt.0	2019-06-10 17:10:38.801	error	Error: listen EADDRINUSE :::1883 at Server.setupListenHandle [as _listen2] (net.js:1360:14) at listenInCluster (net.js:1401:12) at Server.listen (net.js:1485:7) at startServer (/opt/io
    mqtt.0	2019-06-10 17:10:38.801	error	uncaught exception: listen EADDRINUSE :::1883
    mqtt.0	2019-06-10 17:10:38.608	info	starting. Version 2.0.4 in /opt/iobroker/node_modules/iobroker.mqtt, node: v8.15.0
    host.homeserver	2019-06-10 17:10:37.795	info	instance system.adapter.mqtt.0 started with pid 21338
    andreA 1 Antwort Letzte Antwort
    • S Surfer2010
      andreA Offline
      andreA Offline
      andre
      @Surfer2010
      EADDRINUSE = ADDR IN USE = Die Adresse wird bereits benutzt. Scheint so als ob der Port 1883 schon belegt ist...
      • arteckA Offline
        arteckA Offline
        arteck
        hast du sonoff adapter laufen ?? der hat den gleichen Port
