<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ioBroker als Dockerimage - mqtt Problem]]></title><description><![CDATA[<p dir="auto">Meine Installation ist Docker mit dem DockerImage von buanet, in dieser Installation funktioniert MQTT nicht.<br />
Wie kann man das beheben? (siehe LOG unten)</p>
<pre><code>host.homeserver	2019-06-10 17:10:39.322	info	Restart adapter system.adapter.mqtt.0 because enabled
host.homeserver	2019-06-10 17:10:39.321	error	instance system.adapter.mqtt.0 terminated with code 0 (OK)
host.homeserver	2019-06-10 17:10:39.321	error	Caught by controller[0]: port: 1883 }
host.homeserver	2019-06-10 17:10:39.321	error	Caught by controller[0]: address: '::',
host.homeserver	2019-06-10 17:10:39.321	error	Caught by controller[0]: syscall: 'listen',
host.homeserver	2019-06-10 17:10:39.321	error	Caught by controller[0]: code: 'EADDRINUSE',
host.homeserver	2019-06-10 17:10:39.321	error	Caught by controller[0]: errno: 'EADDRINUSE',
host.homeserver	2019-06-10 17:10:39.321	error	Caught by controller[0]: at Socket.&lt;anonymous&gt; (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
host.homeserver	2019-06-10 17:10:39.321	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4332:61
host.homeserver	2019-06-10 17:10:39.321	error	Caught by controller[0]: at adapter.getForeignStates (/opt/iobroker/node_modules/iobroker.mqtt/main.js:133:64)
host.homeserver	2019-06-10 17:10:39.321	error	Caught by controller[0]: at MQTTServer (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:12:47)
host.homeserver	2019-06-10 17:10:39.321	error	Caught by controller[0]: at new MQTTServer (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:1138:7)
host.homeserver	2019-06-10 17:10:39.320	error	Caught by controller[0]: at _constructor (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:1121:9)
host.homeserver	2019-06-10 17:10:39.320	error	Caught by controller[0]: at startServer (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:1018:28)
host.homeserver	2019-06-10 17:10:39.320	error	Caught by controller[0]: at Server.listen (net.js:1485:7)
host.homeserver	2019-06-10 17:10:39.320	error	Caught by controller[0]: at listenInCluster (net.js:1401:12)
host.homeserver	2019-06-10 17:10:39.320	error	Caught by controller[0]: at Server.setupListenHandle [as _listen2] (net.js:1360:14)
host.homeserver	2019-06-10 17:10:39.320	error	Caught by controller[0]: { Error: listen EADDRINUSE :::1883
mqtt.0	2019-06-10 17:10:38.801	error	Error: listen EADDRINUSE :::1883 at Server.setupListenHandle [as _listen2] (net.js:1360:14) at listenInCluster (net.js:1401:12) at Server.listen (net.js:1485:7) at startServer (/opt/io
mqtt.0	2019-06-10 17:10:38.801	error	uncaught exception: listen EADDRINUSE :::1883
mqtt.0	2019-06-10 17:10:38.608	info	starting. Version 2.0.4 in /opt/iobroker/node_modules/iobroker.mqtt, node: v8.15.0
host.homeserver	2019-06-10 17:10:37.795	info	instance system.adapter.mqtt.0 started with pid 21338
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/23092/iobroker-als-dockerimage-mqtt-problem</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Apr 2026 18:45:03 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/23092.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 10 Jun 2019 15:12:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ioBroker als Dockerimage - mqtt Problem on Thu, 27 Jun 2019 19:48:51 GMT]]></title><description><![CDATA[<p dir="auto">hast du sonoff adapter laufen ?? der hat den gleichen Port</p>
]]></description><link>https://forum.iobroker.net/post/276010</link><guid isPermaLink="true">https://forum.iobroker.net/post/276010</guid><dc:creator><![CDATA[arteck]]></dc:creator><pubDate>Thu, 27 Jun 2019 19:48:51 GMT</pubDate></item><item><title><![CDATA[Reply to ioBroker als Dockerimage - mqtt Problem on Thu, 27 Jun 2019 07:24:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/surfer2010" aria-label="Profile: Surfer2010">@<bdi>Surfer2010</bdi></a></p>
<p dir="auto">EADDRINUSE = ADDR IN USE = Die Adresse wird bereits benutzt. Scheint so als ob der Port 1883 schon belegt ist...</p>
]]></description><link>https://forum.iobroker.net/post/275781</link><guid isPermaLink="true">https://forum.iobroker.net/post/275781</guid><dc:creator><![CDATA[andre]]></dc:creator><pubDate>Thu, 27 Jun 2019 07:24:35 GMT</pubDate></item></channel></rss>
