  4. Test Adapter lovelace v0.2.x
    6.5k
testcall for actionlovelacevisualisierung
1.1k Beiträge 131 Kommentatoren 455.1k Aufrufe 99 Beobachtet
  • R Offline
    Raducanu
    Endlich mal ein UI mit wirklich viel Potential. Irgendeine Möglichkeit Rolladensteuerung (level.blind) zu integrieren?
    • M mandragora
      Hallo Leute,
      Hab mir den Adapter auch gerade installiert aber bekomme die Instanz nicht gestartet.
      Bekomme im Log folgendes:
      host.ioBroker	2019-06-09 21:04:57.232	error	instance system.adapter.lovelace.0 terminated with code 1 ()
      host.ioBroker	2019-06-09 21:04:57.232	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.lovelace/node_modules/ws/index.js:3:19)
      host.ioBroker	2019-06-09 21:04:57.232	error	Caught by controller[0]: at require (internal/module.js:20:19)
      host.ioBroker	2019-06-09 21:04:57.232	error	Caught by controller[0]: at Module.require (module.js:504:17)
      host.ioBroker	2019-06-09 21:04:57.232	error	Caught by controller[0]: at Function.Module._load (module.js:445:3)
      host.ioBroker	2019-06-09 21:04:57.232	error	Caught by controller[0]: at tryModuleLoad (module.js:453:12)
      host.ioBroker	2019-06-09 21:04:57.232	error	Caught by controller[0]: at Module.load (module.js:494:32)
      host.ioBroker	2019-06-09 21:04:57.232	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:586:10)
      host.ioBroker	2019-06-09 21:04:57.232	error	Caught by controller[0]: at Module._compile (module.js:549:28)
      host.ioBroker	2019-06-09 21:04:57.232	error	Caught by controller[0]: at Object.runInThisContext (vm.js:97:10)
      host.ioBroker	2019-06-09 21:04:57.231	error	Caught by controller[0]: at createScript (vm.js:56:10)
      host.ioBroker	2019-06-09 21:04:57.231	error	Caught by controller[0]: SyntaxError: Unexpected token ...
      host.ioBroker	2019-06-09 21:04:57.231	error	Caught by controller[0]: ^^^
      host.ioBroker	2019-06-09 21:04:57.231	error	Caught by controller[0]: ...options
      host.ioBroker	2019-06-09 21:04:57.231	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.lovelace/node_modules/ws/lib/websocket.js:347
      host.ioBroker	2019-06-09 21:04:56.731	info	instance system.adapter.lovelace.0 started with pid 1035
      Kann mir vielleicht jemand ein wenig auf die Sprünge helfen was eventuell falsch läuft ?
      Vielen Dank
      lg
      mandragora
      @mandragora ja. Du hast denke ich nodejs 6 installiert. Du brauchst mindestens nodejs 8 für den Adapter. Nodejs 6 ist weiterhin eh end of life.update angeraten!
      • dontobiD dontobi
        Ihr könnt ja gerne weiterhin einen Browser verwenden. In meinem Fall werde ich aber nach einer App Lösung suchen. Das ist ja das schöne... Jeder kann die Software so nutzen, wie er oder sie es will...
        @dontobi iogo schon gesehn? Adapter mir android app
        dontobiD 1 Antwort Letzte Antwort
        • apollon77A apollon77
          dontobiD Offline
          dontobiD Offline
          dontobi
          @apollon77 Ja, habe ich. Nutze ich auch derzeit noch. Jedoch sind bei iogo die Möglichkeiten begrenzter. Bin daher auf der Suche nach einer Alternative und Lovelace ist super. Es gibt für Homeassistent auch ein paar Apps, jedoch klappt bisher nur WallPanel.
          Auf unserem Zentralen Tablet rennt WallPanel ohne Probleme und dort brauche ich keine andere App. Auf den Handy meiner Frau und meines Sohnes könnte die App auch zum Einsatz kommen, aber dazu muss ich erst alle Features in Lovelace einbauen. Bin aber bisher sehr zufrieden.
          Smart Home Zentrale: Raspberry Pi 4 4GB
          Meine Homepage: https://www.myHome.zone
          • R Offline
            Raducanu
            Ich habe gerade die ersten Sachen ausprobiert. Was ich nicht verstehe oder den Fehler nicht finde:
            • Ich habe mehrere Sonoff Relais die über den Sonoff Adapter eingebunden sind.
              Steuere ich das Relais über Lovelace, wird zwar das Objekt auf True/False gestellt, das Sonoff Relais schaltet aber nicht. Stelle ich das Objekt im Objekt Browser manuell auf True/False schaltet das Relais normal....
            • M mandragora
              Hallo Leute,
              Vielen Dank
              lg
              mandragora
              BluefoxB Offline
              BluefoxB Offline
              #66
              @mandragora node.js zu alt?
              • R Raducanu
                dontobiD Offline
                dontobiD Offline
                dontobi
                #67
                @Raducanu Wird der STATE der Geräte im ioBroker unter Objekte mit ON und OFF angezeigt? Das war bei mir der Fall. Hab mir daher ein kleines Script gebastelt. Kann es gerne hier anhängen, wenn das mit dem STATE so ist.
                R 1 Antwort Letzte Antwort
                • dontobiD dontobi
                  Raducanu
                  schrieb am zuletzt editiert von Raducanu
                  #68
                  @dontobi
                  Der State ist "TRUE" / "FALSE"
                  Hier als Beispiel:
                  Sonoff07 -> POWER1 ist der "Terrasse" Schalter im Lovelace. Oben Rechts die Tasmota WebGUI mit dem "ECHTEN" State.
                  Aktuell ist alles aus:
                  Schalte ich das Licht über Lovelace ein, wird der Wert im Objekt auf "TRUE" gesetzt, das Relais schaltet aber nicht:
                  Setze ich den Wert allerdings direkt im Objekt Browser auf TRUIE, schaltet das Relais (Und Lovelace zeigt auch den Status an)
                  Beim Ausschalten das Selbe: IOBroker und Lovelace zeigen "FALSE" als State an, das Relais hat aber nicht geschaltet
                  Ich werde nochmal schauen was im MQTT Protokoll steht, aber irgendwas ist dort faul
                  • R Raducanu
                    @dontobi
                    Hier als Beispiel:
                    Raducanu
                    #69
                    @Raducanu said in [Aufruf] Test lovelace Adapter:
                    @dontobi
                    Hier als Beispiel:
                    Sorry, gerade gesehen dass dieses in 0.1.1 gefixed ist
                    • sigi234S Online
                      sigi234S Online
                      #70
                      Hallo, kann man die Fehlermeldungen unterdrücken?
                      lovelace.0	2019-06-11 11:54:15.363	error	Invalid attribute name for {"friendly_name":"Multimedia Badzimmer","entity_picture":"./adapter/alexa2/icons/echo_dot.png","icon":"mdi:play-network","media_content_type":"unknown","supported_features"
                      lovelace.0	2019-06-11 11:54:15.360	error	Invalid attribute name for {"friendly_name":"Multimedia Küche","entity_picture":"./adapter/alexa2/icons/echo_dot.png","icon":"mdi:play-network","media_content_type":"unknown","supported_features":174
                      lovelace.0	2019-06-11 11:54:15.357	error	Invalid attribute name for {"friendly_name":"Multimedia roomLivingRoom","entity_picture":"./adapter/alexa2/icons/echo_dot.png","icon":"mdi:play-network","media_content_type":"unknown","supported_feat
                      BluefoxB 1 Antwort Letzte Antwort
                      • sigi234S sigi234
                        BluefoxB Offline
                        BluefoxB Offline
                        #71
                        @sigi234 Das muss ich noch fixen/implementieren. Die müssen als Errinerung für mich da bleiben :)
                        • dontobiD Offline
                          dontobiD Offline
                          dontobi
                          #72
                          Ich versuche gerade eine Custom Card zu verwenden. Genauer gesagt diese hier...
                          https://github.com/kalkih/mini-graph-card
                          Hier ist mein Code:
                          type: 'custom:mini-graph-card'
                          icon: mdi:server
                          entities:
                            - entity: sensor.System_CPU_Load1
                            - entity: sensor.System_CPU_Load5
                            - entity: sensor.System_CPU_Load15
                          Als Fehlermeldung bekomme ich dann das hier:
                          Custom element doesn't exist: mini-graph-card.
                            "type": "custom:mini-graph-card",
                            "name": "CPU Load",
                            "icon": "mdi:server",
                            "entities": [
                                "entity": "sensor.System_CPU_Load1",
                                "name": "Load 1"
                                "entity": "sensor.System_CPU_Load5",
                                "name": "Load 5"
                                "entity": "sensor.System_CPU_Load15",
                                "name": "Load 15"
                          Die JS Datei habe ich im Admin per Drag & Drop eingespielt und der Adapter wurde neugestartet.
                          Vielleicht mache ich etwas falsch oder die Custom Card klappt nicht.
                          sigi234S BluefoxB 2 Antworten Letzte Antwort
                          • dontobiD dontobi
                            Hier ist mein Code:
                            icon: mdi:server
                            entities:
                              "name": "CPU Load",
                              "entities": [
                                  "name": "Load 1"
                                  "name": "Load 5"
                                  "name": "Load 15"
                            sigi234S Online
                            sigi234S Online
                            #73
                            @dontobi sagte in [Aufruf] Test lovelace Adapter:
                            Wohin genau?
                            • sigi234S sigi234
                              Wohin genau?
                              dontobiD Offline
                              dontobiD Offline
                              dontobi
                              #74
                              @sigi234 geh Mal in die Instanz Einstellungen. Ist dort selbsterklärend.
                              Und ich hab noch etwas festgestellt. Die Weather Card geht auch mit Weatherunderground, jedoch werden da (genauso wie bei yr.no) keine Icons angezeigt. Hat einer die Wetter Karte mit Icons am laufen?
                              • dontobiD dontobi
                                Hier ist mein Code:
                                icon: mdi:server
                                entities:
                                  "name": "CPU Load",
                                  "entities": [
                                      "name": "Load 1"
                                      "name": "Load 5"
                                      "name": "Load 15"
                                BluefoxB Offline
                                BluefoxB Offline
                                schrieb am zuletzt editiert von Bluefox
                                #75
                                Участник @dontobi написал в [Aufruf] Test lovelace Adapter:
                                icon: mdi:server
                                entities:
                                • entity: sensor.System_CPU_Load1
                                • entity: sensor.System_CPU_Load5
                                • entity: sensor.System_CPU_Load15
                                Welche Datei hast du uploaded?
                                Diese hier: https://github.com/kalkih/mini-graph-card/releases/download/v0.4.3/mini-graph-card-bundle.js
                                9da95f1c-cf27-44e5-9683-54b0fcad1d84-image.png35c86934-2cdf-4af4-a15d-5a4251a10b86-image.png
                                  mandragora
                                  #76
                                  Hallo Leute,
                                  Vielen Dank für die Info.
                                  Hab noch wie ihr schon vermutet eine alte Version drauf
                                  Ich hab iobroker auf einer Synology unter Docker laufen.
                                  node hab ich bereits auf die 10.16.0 bringen können.
                                  Kann mir jemand eventuell noch sagen wie ich gefahrlos (Backup mit Backitup ist vorhanden) ein Update von nodejs und npm machen kann ?
                                  Hab schon einiges hier gefunden aber hab ein wenig die Scheu das was schiefgehen könnte.
                                  Müsste es so funktionieren ?
                                  iobroker stop
                                  apt-get --purge remove node nodejs
                                  apt-get autoremove
                                  reboot
                                  Nach dem Reboot geht es mit diesen Befehlen weiter:
                                  curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
                                  apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev libpam0g-dev nodejs
                                  reboot
                                  Vielen Dank nochmals
                                  lg
                                  mandragora
                                  ioBroker auf Synology DS218+ (Docker); VIS: 2x8" Tablets; Homematic CCU2 und Komponenten; Echo DOT; Unifi Ap-Ac Pro; Landroid S; Jovision IPCams
                                  • M mandragora
                                    Hallo Leute,
                                    iobroker stop
                                    apt-get autoremove
                                    reboot
                                    reboot
                                    lg
                                    mandragora
                                    BluefoxB Offline
                                    BluefoxB Offline
                                    #77
                                    @mandragora https://www.iobroker.net/#de/documentation/install/updatenode.md
                                    • G Offline
                                      Gerni
                                      schrieb am zuletzt editiert von Gerni
                                      #78
                                      Bin gespannt, auf die schnelle sieht es gut aus. Hoffe nur, dass es besser als Material UI wird. Da werden, trotz zugewiesen Räumen usw usw nicht alle Geräte angezeigt.
                                      Mal sehen was dieser Adapter kann.
                                      Update:
                                      Soeben installiert und versucht zwei identisch eingerichtete Temp Sensoren von Xiaomi einzubinden. Einer geht. Einer nicht und wird in der Auswahl schon erst gar nicht angezeigt.
                                      UpDate 2:
                                      Schaltet man in iobroker wird der Status nicht übergeben.
                                      Ist ja noch ein Test aber selbe Probleme wie bei Material bisher aber an sich schon cooler von der Bedienung!
                                      Jede Menge verschiedenes Zeug
                                      • BluefoxB Bluefox
                                        icon: mdi:server
                                        entities:
                                        dontobiD Offline
                                        dontobiD Offline
                                        dontobi
                                        #79
                                        @Bluefox ja, genau den. Hab ich was falsch gemacht?
                                        • chmilli1C Offline
                                          chmilli1C Offline
                                          chmilli1
                                          schrieb am zuletzt editiert von Jey Cee
                                          #80
                                          Hallo !
                                          Ich bekomme Ihn nicht einmal installiert.....
                                          0 info it worked if it ends with ok
                                          1 verbose cli [ '/usr/bin/node',
                                          1 verbose cli   '/usr/bin/npm',
                                          1 verbose cli   'install',
                                          1 verbose cli   'https://www.home-assistant.io/lovelace/',
                                          1 verbose cli   '--production',
                                          1 verbose cli   '--save',
                                          1 verbose cli   '--prefix',
                                          1 verbose cli   '/opt/iobroker' ]
                                          2 info using npm@6.4.1
                                          3 info using node@v8.16.0
                                          4 verbose npm-session 675c4ef117ea92cb
                                          5 silly install loadCurrentTree
                                          6 silly install readLocalPackageData
                                          7 http fetch GET 200 https://www.home-assistant.io/lovelace/ 55ms (from cache)
                                          8 silly fetchPackageMetaData error for https://www.home-assistant.io/lovelace/ Non-registry package missing package.json: https://www.home-assistant.io/lovelace/.
                                          9 timing stage:rollbackFailedOptional Completed in 1ms
                                          10 timing stage:runTopLevelLifecycles Completed in 6676ms
                                          11 verbose stack Error: Non-registry package missing package.json: https://www.home-assistant.io/lovelace/.
                                          11 verbose stack     at BB.join (/usr/lib/node_modules/npm/node_modules/pacote/lib/finalize-manifest.js:162:23)
                                          11 verbose stack     at tryCatcher (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
                                          11 verbose stack     at Holder$5._callFunction (eval at generateHolderClass (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/join.js:92:16), <anonymous>:14:44)
                                          11 verbose stack     at Holder$5.checkFulfillment (eval at generateHolderClass (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/join.js:92:16), <anonymous>:29:30)
                                          11 verbose stack     at Promise.eval (eval at thenCallback (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/join.js:14:16), <anonymous>:6:20)
                                          11 verbose stack     at Promise._settlePromise (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:566:21)
                                          11 verbose stack     at Promise._settlePromise0 (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:614:10)
                                          11 verbose stack     at Promise._settlePromises (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:693:18)
                                          11 verbose stack     at Async._drainQueue (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:133:16)
                                          11 verbose stack     at Async._drainQueues (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:143:10)
                                          11 verbose stack     at Immediate.Async.drainQueues (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:17:14)
                                          11 verbose stack     at runCallback (timers.js:810:20)
                                          11 verbose stack     at tryOnImmediate (timers.js:768:5)
                                          11 verbose stack     at processImmediate [as _immediateCallback] (timers.js:745:5)
                                          12 verbose cwd /
                                          13 verbose Linux 4.15.0-20-generic
                                          14 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "https://www.home-assistant.io/lovelace/" "--production" "--save" "--prefix" "/opt/iobroker"
                                          15 verbose node v8.16.0
                                          16 verbose npm  v6.4.1
                                          17 error code ENOPACKAGEJSON
                                          18 error package.json Non-registry package missing package.json: https://www.home-assistant.io/lovelace/.
                                          19 error package.json npm can't find a package.json file in your current directory.
                                          20 verbose exit [ 1, true ]
                                          MOD Edit Jey Cee: Bitte Code und logs in code Tags packen
                                          thewhoboxT sigi234S 2 Antworten Letzte Antwort
