  4. Test Adapter lovelace v0.2.x
    6.5k
testcall for actionlovelacevisualisierung
1.1k Beiträge 131 Kommentatoren 455.1k Aufrufe 99 Beobachtet
  • M mandragora
    Hallo Leute,
    Hab mir den Adapter auch gerade installiert aber bekomme die Instanz nicht gestartet.
    Bekomme im Log folgendes:
    host.ioBroker	2019-06-09 21:04:57.232	error	instance system.adapter.lovelace.0 terminated with code 1 ()
    host.ioBroker	2019-06-09 21:04:57.232	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.lovelace/node_modules/ws/index.js:3:19)
    host.ioBroker	2019-06-09 21:04:57.232	error	Caught by controller[0]: at require (internal/module.js:20:19)
    host.ioBroker	2019-06-09 21:04:57.232	error	Caught by controller[0]: at Module.require (module.js:504:17)
    host.ioBroker	2019-06-09 21:04:57.232	error	Caught by controller[0]: at Function.Module._load (module.js:445:3)
    host.ioBroker	2019-06-09 21:04:57.232	error	Caught by controller[0]: at tryModuleLoad (module.js:453:12)
    host.ioBroker	2019-06-09 21:04:57.232	error	Caught by controller[0]: at Module.load (module.js:494:32)
    host.ioBroker	2019-06-09 21:04:57.232	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:586:10)
    host.ioBroker	2019-06-09 21:04:57.232	error	Caught by controller[0]: at Module._compile (module.js:549:28)
    host.ioBroker	2019-06-09 21:04:57.232	error	Caught by controller[0]: at Object.runInThisContext (vm.js:97:10)
    host.ioBroker	2019-06-09 21:04:57.231	error	Caught by controller[0]: at createScript (vm.js:56:10)
    host.ioBroker	2019-06-09 21:04:57.231	error	Caught by controller[0]: SyntaxError: Unexpected token ...
    host.ioBroker	2019-06-09 21:04:57.231	error	Caught by controller[0]: ^^^
    host.ioBroker	2019-06-09 21:04:57.231	error	Caught by controller[0]: ...options
    host.ioBroker	2019-06-09 21:04:57.231	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.lovelace/node_modules/ws/lib/websocket.js:347
    host.ioBroker	2019-06-09 21:04:56.731	info	instance system.adapter.lovelace.0 started with pid 1035
    Kann mir vielleicht jemand ein wenig auf die Sprünge helfen was eventuell falsch läuft ?
    Vielen Dank
    lg
    mandragora
    BluefoxB Offline
    BluefoxB Offline
    #66
    @mandragora node.js zu alt?
    • R Raducanu
      Ich habe gerade die ersten Sachen ausprobiert. Was ich nicht verstehe oder den Fehler nicht finde:
      • Ich habe mehrere Sonoff Relais die über den Sonoff Adapter eingebunden sind.
        Steuere ich das Relais über Lovelace, wird zwar das Objekt auf True/False gestellt, das Sonoff Relais schaltet aber nicht. Stelle ich das Objekt im Objekt Browser manuell auf True/False schaltet das Relais normal....
      dontobiD Offline
      dontobiD Offline
      dontobi
      #67
      @Raducanu Wird der STATE der Geräte im ioBroker unter Objekte mit ON und OFF angezeigt? Das war bei mir der Fall. Hab mir daher ein kleines Script gebastelt. Kann es gerne hier anhängen, wenn das mit dem STATE so ist.
      Smart Home Zentrale: Raspberry Pi 4 4GB
      Meine Homepage: https://www.myHome.zone
      R 1 Antwort Letzte Antwort
      • dontobiD dontobi
        Raducanu
        schrieb am zuletzt editiert von Raducanu
        #68
        @dontobi
        Der State ist "TRUE" / "FALSE"
        Hier als Beispiel:
        Sonoff07 -> POWER1 ist der "Terrasse" Schalter im Lovelace. Oben Rechts die Tasmota WebGUI mit dem "ECHTEN" State.
        Aktuell ist alles aus:
        Schalte ich das Licht über Lovelace ein, wird der Wert im Objekt auf "TRUE" gesetzt, das Relais schaltet aber nicht:
        Setze ich den Wert allerdings direkt im Objekt Browser auf TRUIE, schaltet das Relais (Und Lovelace zeigt auch den Status an)
        Beim Ausschalten das Selbe: IOBroker und Lovelace zeigen "FALSE" als State an, das Relais hat aber nicht geschaltet
        Ich werde nochmal schauen was im MQTT Protokoll steht, aber irgendwas ist dort faul
        • R Raducanu
          @dontobi
          Hier als Beispiel:
          Raducanu
          #69
          @Raducanu said in [Aufruf] Test lovelace Adapter:
          @dontobi
          Hier als Beispiel:
          Sorry, gerade gesehen dass dieses in 0.1.1 gefixed ist
          • sigi234S Online
            sigi234S Online
            #70
            Hallo, kann man die Fehlermeldungen unterdrücken?
            lovelace.0	2019-06-11 11:54:15.363	error	Invalid attribute name for {"friendly_name":"Multimedia Badzimmer","entity_picture":"./adapter/alexa2/icons/echo_dot.png","icon":"mdi:play-network","media_content_type":"unknown","supported_features"
            lovelace.0	2019-06-11 11:54:15.360	error	Invalid attribute name for {"friendly_name":"Multimedia Küche","entity_picture":"./adapter/alexa2/icons/echo_dot.png","icon":"mdi:play-network","media_content_type":"unknown","supported_features":174
            lovelace.0	2019-06-11 11:54:15.357	error	Invalid attribute name for {"friendly_name":"Multimedia roomLivingRoom","entity_picture":"./adapter/alexa2/icons/echo_dot.png","icon":"mdi:play-network","media_content_type":"unknown","supported_feat
            BluefoxB 1 Antwort Letzte Antwort
            • sigi234S sigi234
              BluefoxB Offline
              BluefoxB Offline
              #71
              @sigi234 Das muss ich noch fixen/implementieren. Die müssen als Errinerung für mich da bleiben :)
              • dontobiD Offline
                dontobiD Offline
                dontobi
                #72
                Ich versuche gerade eine Custom Card zu verwenden. Genauer gesagt diese hier...
                https://github.com/kalkih/mini-graph-card
                Hier ist mein Code:
                type: 'custom:mini-graph-card'
                icon: mdi:server
                entities:
                  - entity: sensor.System_CPU_Load1
                  - entity: sensor.System_CPU_Load5
                  - entity: sensor.System_CPU_Load15
                Als Fehlermeldung bekomme ich dann das hier:
                Custom element doesn't exist: mini-graph-card.
                  "type": "custom:mini-graph-card",
                  "name": "CPU Load",
                  "icon": "mdi:server",
                  "entities": [
                      "entity": "sensor.System_CPU_Load1",
                      "name": "Load 1"
                      "entity": "sensor.System_CPU_Load5",
                      "name": "Load 5"
                      "entity": "sensor.System_CPU_Load15",
                      "name": "Load 15"
                Die JS Datei habe ich im Admin per Drag & Drop eingespielt und der Adapter wurde neugestartet.
                Vielleicht mache ich etwas falsch oder die Custom Card klappt nicht.
                sigi234S BluefoxB 2 Antworten Letzte Antwort
                • dontobiD dontobi
                  Hier ist mein Code:
                  icon: mdi:server
                  entities:
                    "name": "CPU Load",
                    "entities": [
                        "name": "Load 1"
                        "name": "Load 5"
                        "name": "Load 15"
                  sigi234S Online
                  sigi234S Online
                  #73
                  @dontobi sagte in [Aufruf] Test lovelace Adapter:
                  Wohin genau?
                  dontobiD 1 Antwort Letzte Antwort
                  • sigi234S sigi234
                    Wohin genau?
                    dontobiD Offline
                    dontobiD Offline
                    dontobi
                    #74
                    @sigi234 geh Mal in die Instanz Einstellungen. Ist dort selbsterklärend.
                    Und ich hab noch etwas festgestellt. Die Weather Card geht auch mit Weatherunderground, jedoch werden da (genauso wie bei yr.no) keine Icons angezeigt. Hat einer die Wetter Karte mit Icons am laufen?
                    • dontobiD dontobi
                      Hier ist mein Code:
                      icon: mdi:server
                      entities:
                        "name": "CPU Load",
                        "entities": [
                            "name": "Load 1"
                            "name": "Load 5"
                            "name": "Load 15"
                      BluefoxB Offline
                      BluefoxB Offline
                      schrieb am zuletzt editiert von Bluefox
                      #75
                      Участник @dontobi написал в [Aufruf] Test lovelace Adapter:
                      icon: mdi:server
                      entities:
                      • entity: sensor.System_CPU_Load1
                      • entity: sensor.System_CPU_Load5
                      • entity: sensor.System_CPU_Load15
                      Welche Datei hast du uploaded?
                      Diese hier: https://github.com/kalkih/mini-graph-card/releases/download/v0.4.3/mini-graph-card-bundle.js
                      9da95f1c-cf27-44e5-9683-54b0fcad1d84-image.png35c86934-2cdf-4af4-a15d-5a4251a10b86-image.png
                        mandragora
                        #76
                        Hallo Leute,
                        Vielen Dank für die Info.
                        Hab noch wie ihr schon vermutet eine alte Version drauf
                        Ich hab iobroker auf einer Synology unter Docker laufen.
                        node hab ich bereits auf die 10.16.0 bringen können.
                        Kann mir jemand eventuell noch sagen wie ich gefahrlos (Backup mit Backitup ist vorhanden) ein Update von nodejs und npm machen kann ?
                        Hab schon einiges hier gefunden aber hab ein wenig die Scheu das was schiefgehen könnte.
                        Müsste es so funktionieren ?
                        iobroker stop
                        apt-get --purge remove node nodejs
                        apt-get autoremove
                        reboot
                        Nach dem Reboot geht es mit diesen Befehlen weiter:
                        curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
                        apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev libpam0g-dev nodejs
                        reboot
                        Vielen Dank nochmals
                        lg
                        mandragora
                        ioBroker auf Synology DS218+ (Docker); VIS: 2x8" Tablets; Homematic CCU2 und Komponenten; Echo DOT; Unifi Ap-Ac Pro; Landroid S; Jovision IPCams
                        • M mandragora
                          Hallo Leute,
                          iobroker stop
                          apt-get autoremove
                          reboot
                          reboot
                          lg
                          mandragora
                          BluefoxB Offline
                          BluefoxB Offline
                          #77
                          @mandragora https://www.iobroker.net/#de/documentation/install/updatenode.md
                          • G Offline
                            Gerni
                            schrieb am zuletzt editiert von Gerni
                            #78
                            Bin gespannt, auf die schnelle sieht es gut aus. Hoffe nur, dass es besser als Material UI wird. Da werden, trotz zugewiesen Räumen usw usw nicht alle Geräte angezeigt.
                            Mal sehen was dieser Adapter kann.
                            Update:
                            Soeben installiert und versucht zwei identisch eingerichtete Temp Sensoren von Xiaomi einzubinden. Einer geht. Einer nicht und wird in der Auswahl schon erst gar nicht angezeigt.
                            UpDate 2:
                            Schaltet man in iobroker wird der Status nicht übergeben.
                            Ist ja noch ein Test aber selbe Probleme wie bei Material bisher aber an sich schon cooler von der Bedienung!
                            Jede Menge verschiedenes Zeug
                            • BluefoxB Bluefox
                              icon: mdi:server
                              entities:
                              dontobiD Offline
                              dontobiD Offline
                              dontobi
                              #79
                              @Bluefox ja, genau den. Hab ich was falsch gemacht?
                              • chmilli1C Offline
                                chmilli1C Offline
                                chmilli1
                                schrieb am zuletzt editiert von Jey Cee
                                #80
                                Hallo !
                                Ich bekomme Ihn nicht einmal installiert.....
                                0 info it worked if it ends with ok
                                1 verbose cli [ '/usr/bin/node',
                                1 verbose cli   '/usr/bin/npm',
                                1 verbose cli   'install',
                                1 verbose cli   'https://www.home-assistant.io/lovelace/',
                                1 verbose cli   '--production',
                                1 verbose cli   '--save',
                                1 verbose cli   '--prefix',
                                1 verbose cli   '/opt/iobroker' ]
                                2 info using npm@6.4.1
                                3 info using node@v8.16.0
                                4 verbose npm-session 675c4ef117ea92cb
                                5 silly install loadCurrentTree
                                6 silly install readLocalPackageData
                                7 http fetch GET 200 https://www.home-assistant.io/lovelace/ 55ms (from cache)
                                8 silly fetchPackageMetaData error for https://www.home-assistant.io/lovelace/ Non-registry package missing package.json: https://www.home-assistant.io/lovelace/.
                                9 timing stage:rollbackFailedOptional Completed in 1ms
                                10 timing stage:runTopLevelLifecycles Completed in 6676ms
                                11 verbose stack Error: Non-registry package missing package.json: https://www.home-assistant.io/lovelace/.
                                11 verbose stack     at BB.join (/usr/lib/node_modules/npm/node_modules/pacote/lib/finalize-manifest.js:162:23)
                                11 verbose stack     at tryCatcher (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
                                11 verbose stack     at Holder$5._callFunction (eval at generateHolderClass (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/join.js:92:16), <anonymous>:14:44)
                                11 verbose stack     at Holder$5.checkFulfillment (eval at generateHolderClass (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/join.js:92:16), <anonymous>:29:30)
                                11 verbose stack     at Promise.eval (eval at thenCallback (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/join.js:14:16), <anonymous>:6:20)
                                11 verbose stack     at Promise._settlePromise (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:566:21)
                                11 verbose stack     at Promise._settlePromise0 (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:614:10)
                                11 verbose stack     at Promise._settlePromises (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:693:18)
                                11 verbose stack     at Async._drainQueue (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:133:16)
                                11 verbose stack     at Async._drainQueues (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:143:10)
                                11 verbose stack     at Immediate.Async.drainQueues (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:17:14)
                                11 verbose stack     at runCallback (timers.js:810:20)
                                11 verbose stack     at tryOnImmediate (timers.js:768:5)
                                11 verbose stack     at processImmediate [as _immediateCallback] (timers.js:745:5)
                                12 verbose cwd /
                                13 verbose Linux 4.15.0-20-generic
                                14 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "https://www.home-assistant.io/lovelace/" "--production" "--save" "--prefix" "/opt/iobroker"
                                15 verbose node v8.16.0
                                16 verbose npm  v6.4.1
                                17 error code ENOPACKAGEJSON
                                18 error package.json Non-registry package missing package.json: https://www.home-assistant.io/lovelace/.
                                19 error package.json npm can't find a package.json file in your current directory.
                                20 verbose exit [ 1, true ]
                                MOD Edit Jey Cee: Bitte Code und logs in code Tags packen
                                thewhoboxT sigi234S 2 Antworten Letzte Antwort
                                • chmilli1C chmilli1
                                  Hallo !
                                  12 verbose cwd /
                                  thewhoboxT Offline
                                  thewhoboxT Offline
                                  thewhobox
                                  #81
                                  @chmilli1 Du benutzt den falschen Link.
                                  Das was du eingibst ist nicht der Github link sondern einfach nur die Infoseite von lovelance.
                                  https://github.com/ioBroker/ioBroker.lovelace
                                  Das ist der richtige.
                                  Meine Adapter: emby | discovery
                                    Hallo !
                                    12 verbose cwd /
                                    sigi234S Online
                                    sigi234S Online
                                    #82
                                    @chmilli1
                                    https://forum.iobroker.net/topic/23156/lovelace-in-iobroker-installieren/2
                                    • marcusklM Offline
                                      marcusklM Offline
                                      marcuskl
                                      #83
                                      Bei mir werden einige Aufzählungen, z.B. Lampen die definiert sind in Aufzählungen nicht angezeigt?
                                      Nutze Material Ui, da sind sie alle vorhanden.
                                      Host: Intel Nuc6cayh (16GB Ram, 240GB SSD) mit Proxmox.
                                      Iobroker VM, InfluxDB LXC, Pihole LXC, Tasmoadmin LXC, Easy2connect VM
                                      • marcusklM marcuskl
                                        sigi234S Online
                                        sigi234S Online
                                        #84
                                        @marcuskl
                                        Raum und Funktion zugeordnet?
                                        • marcusklM Offline
                                          marcusklM Offline
                                          marcuskl
                                          #85
                                          Jap, habs sogar nochmal geprüft aber passt alles.
                                          Sonst würde es ja im Material Ui Adapter auch net gehen.
