  4. [gelöst]SayIt Adapter Fehler - läuft nicht mehr
sayitnode 10
9 Beiträge 2 Kommentatoren 428 Aufrufe 2 Beobachtet
  • liv-in-skyL Offline
    liv-in-skyL Offline
    hallo,
    hatte probleme beim deinstallieren eines adapter. anschliedssend crash - nur jeder 2te adapter startete noch - habe dann einen restore gemacht und alle neusten updates aufgespielt --nodejs 10.16.0 - npm 6.19 js-contr 1.5.12 - fixer script
    jetzt läuft wieder alles - außer 2 problemen:
    • 1: der sayit adapter startet machmal - macht dann aber folgende fehler:
    host.raspberry3	2019-06-09 12:20:32.974	error	instance system.adapter.sayit.0 terminated with code 0 (OK)
    host.raspberry3	2019-06-09 12:20:32.974	error	Caught by controller[5]: at GetAddrInfoReqWrap.oncomplete (/opt/iobroker/node_modules/mdns/lib/resolver_sequence_tasks.js:120:9) code: -3008, errno: -3008, syscall: 'getaddrinfo' }
    host.raspberry3	2019-06-09 12:20:32.974	error	Caught by controller[5]: at getaddrinfo_complete (/opt/iobroker/node_modules/mdns/lib/resolver_sequence_tasks.js:112:10)
    host.raspberry3	2019-06-09 12:20:32.974	error	Caught by controller[5]: at errnoException (/opt/iobroker/node_modules/mdns/lib/resolver_sequence_tasks.js:199:11)
    host.raspberry3	2019-06-09 12:20:32.974	error	Caught by controller[5]: { Error: getaddrinfo -3008
    host.raspberry3	2019-06-09 12:20:32.974	error	Caught by controller[4]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
    host.raspberry3	2019-06-09 12:20:32.974	error	Caught by controller[3]: *** WARNING *** Please fix your application to use the native API of Avahi!
    host.raspberry3	2019-06-09 12:20:32.974	error	Caught by controller[2]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
    host.raspberry3	2019-06-09 12:20:32.974	error	Caught by controller[2]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
    host.raspberry3	2019-06-09 12:20:32.974	error	Caught by controller[1]: *** WARNING *** Please fix your application to use the native API of Avahi!
    host.raspberry3	2019-06-09 12:20:32.974	error	Caught by controller[0]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
    habe sayit schon deinstalliert und installiert - keine änderung
    • 2: ein npm rebuild bricht mit folgenden fehler ab:
    18869 info lifecycle unix-dgram@0.2.3~install: unix-dgram@0.2.3
    18870 verbose lifecycle unix-dgram@0.2.3~install: unsafe-perm in lifecycle false
    18871 verbose lifecycle unix-dgram@0.2.3~install: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/opt/iobroker/node_modules/unix-dgram/node_modules/.bin:/opt/iobroker/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
    18872 verbose lifecycle unix-dgram@0.2.3~install: CWD: /opt/iobroker/node_modules/unix-dgram
    18873 silly lifecycle unix-dgram@0.2.3~install: Args: [ '-c', 'node-gyp rebuild' ]
    18874 silly lifecycle unix-dgram@0.2.3~install: Returned: code: 1  signal: null
    18875 info lifecycle unix-dgram@0.2.3~install: Failed to exec install script
    18876 verbose stack Error: unix-dgram@0.2.3 install: `node-gyp rebuild`
    18876 verbose stack Exit status 1
    18876 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:301:16)
    18876 verbose stack     at EventEmitter.emit (events.js:198:13)
    18876 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
    18876 verbose stack     at ChildProcess.emit (events.js:198:13)
    18876 verbose stack     at maybeClose (internal/child_process.js:982:16)
    18876 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
    18877 verbose pkgid unix-dgram@0.2.3
    18878 verbose cwd /opt/iobroker
    18879 verbose Linux 4.19.0-4-amd64
    18880 verbose argv "/usr/bin/node" "/usr/bin/npm" "rebuild"
    18881 verbose node v10.16.0
    18882 verbose npm  v6.9.0
    18883 error code ELIFECYCLE
    18884 error errno 1
    18885 error unix-dgram@0.2.3 install: `node-gyp rebuild`
    18885 error Exit status 1
    18886 error Failed at the unix-dgram@0.2.3 install script.
    18886 error This is probably not a problem with npm. There is likely additional logging output above.
    18887 verbose exit [ 1, true ]
    hat jmd eine idee was das sein könnte ?
    • liv-in-skyL liv-in-sky
      hallo,
      18884 error errno 1
      crunchipC Abwesend
      crunchipC Abwesend
      @liv-in-sky sagte in SayIt Adapter Fehler und funktioniert nicht (und npm rebuild error):
      unix-dgram@0.2.3
      hatte auch diese probleme mit sayit
      https://www.npmjs.com/package/unix-dgram version 2.03
        unix-dgram@0.2.3
        liv-in-skyL Offline
        liv-in-skyL Offline
        hi @crunchip
        aber wie hast du das gelöst
          hi @crunchip
          crunchipC Abwesend
          crunchipC Abwesend
          @liv-in-sky
          npm i unix-dgram
            @liv-in-sky
            npm i unix-dgram
            liv-in-skyL Offline
            liv-in-skyL Offline
            @crunchip sagte in SayIt Adapter Fehler - läuft nicht mehr (und npm rebuild error):
            npm i unix-dgram
            tausend dank - das wars - funzt/redet zumindest das mal - versuche seit 2 tagen iobroker wieder vollständig zum laufen zu bringen :-(
            zu dem anderen (npm rebuild) wird dir nix einfallen - oder
              npm i unix-dgram
              crunchipC Abwesend
              crunchipC Abwesend
              @liv-in-sky zu welchem?
                liv-in-skyL Offline
                liv-in-skyL Offline
                @crunchip
                hab da was verwechselt - und nur sayit ausprobiert - aber habe mittlerweile auch einen npm rebuild laufen lassen und der funktioniert auch wieder - wußte nicht, dass dieser fehler ein und der selbe war
                nochmals vielen dank
                ps: nur eine zeile kopieren, ins terminal pasten und enter drücken - und schon ist der taq wieder positiver !!!
                  @crunchip
                  crunchipC Abwesend
                  crunchipC Abwesend
                  @liv-in-sky dann hoff ich mal das es auch so bleibt, hehe
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    @crunchip klopfe auf holz
                    hatte eh probleme mit node 10 - plotzliche iobroker crashes - aber scheuen wir mal, wie lang der tag positiv ist !
                    82.8k
