  4. [Aufruf] fullyBrowser Adapter
    6.6k
fullybrowserfullybrowser adapter
289 Beiträge 45 Kommentatoren 72.4k Aufrufe 26 Beobachtet
  • ostseereiterO ostseereiter
    @Issi sagte in [Aufruf] fullyBrowser Adapter:
    <block type="on" id="{EfUQy(n:93(-oC=/?~" x="63" y="88">
    <field name="OID">javascript.0.MeinTablet.Galaxy_Tab_A_2016.Sperrbildschirm</field>
    <statement name="STATEMENT">
    <block type="controls_if" id="m9C{!a.RmUjc|DY(a9(|">
    <value name="IF0">
    <block type="on_source" id="x~tcRc6R;$qQhB}
    ?C{">
    </block>
    </value>
    <statement name="DO0">
    <block type="comment" id="1L^TU4E.@)=~Ov;Y(9@"> <field name="COMMENT">Sperrbildschirm aus</field> <next> <block type="request" id="JF~X9VqXim]s0o2iJOhy"> <mutation with_statement="false"></mutation> <field name="WITH_STATEMENT">FALSE</field> <field name="LOG"></field> <value name="URL"> <shadow type="text" id="]l4kV|5|OQ]Ks*Bxmjr{"> <field name="TEXT">text</field> </shadow> <block type="text" id="O#:nwn9P=.Cb}Ytu{+_">
    <field name="TEXT">http://xxx.xxx.xxx.xx:2323/?cmd=setBooleanSetting&amp;key=forceScreenUnlock&amp;value=true&amp;password=xxxxxxxxxxxxx</field>
    </block>
    </value>
    </block>
    </next>
    </block>
    </statement>
    <statement name="ELSE">
    <block type="comment" id="l(uLH%|uS)7]m{((.!^J">
    <field name="COMMENT">Sperrbildschirm an</field>
    <next>
    <block type="request" id="oiiYZ,`J8V]jZ]Wd6k0l">
    <value name="URL">
    Bxmjr{">
    </shadow>
    <block type="text" id="sHMIU.gbbNyK^X2!W?xr">
    <field name="TEXT">http://xxx.xxx.xxx.xx:2323/?cmd=setBooleanSetting&amp;key=forceScreenUnlock&amp;value=false&amp;password=xxxxxxxxxxxxx</field>
    </block>
    </value>
    </block>
    </next>
    </block>
    </statement>
    </block>
    </statement>
    <next>
    <block type="comment" id="rUbvx7=@8{y%9[{tfec$">
    <field name="COMMENT">Datenpunkt wird erstellt</field>
    <next>
    <block type="procedures_callcustomnoreturn" id="8l2]F0|.wkI4Gq%DQD~">
    <mutation name="Datenpunkt erstellen"></mutation>
    </block>
    </next>
    </block>
    </next>
    </block>
    <block type="procedures_defcustomnoreturn" id="D^4vwd-2
    I=:dUDrEhIo" x="63" y="588">
    <mutation statements="false"></mutation>
    <field name="NAME">Datenpunkt erstellen</field>
    <field name="SCRIPT">Y29uc3QgU3RhdGUgPSAnamF2YXNjcmlwdC4wLk1laW5UYWJsZXQuR2FsYXh5X1RhYl9BXzIwMTYnOw0KY3JlYXRlU3RhdGUoJ01laW5UYWJsZXQuR2FsYXh5X1RhYl9BXzIwMTYuU3BlcnJiaWxkc2NoaXJtJywgZmFsc2Use3R5cGU6ICJib29sZWFuIixuYW1lOiJTcGVycmJpbGRzY2hpcm0ifSk7</field>
    </block>
    </xml>
    Danke erst mal
    Habe es installiert so wie du es beschrieben hast. dann habe ich mal den Datenpunkt auf true gesetzt da wurde was auf den Tablet angezeigt aber er ist nicht in den Sperrmodus gegangen.Mache ich was falsch?
    IssiI Online
    IssiI Online
    Issi
    #234
    @ostseereiter hast du deine ip und dein PW eingetragen ?
    ostseereiterO 1 Antwort Letzte Antwort
    • IssiI Issi
      ostseereiterO Offline
      ostseereiter
      #235
      @Issi ja alles so gemacht wie du beschrieben hast. irgendwas hat das Tablet ja beim ersten mal auch angezeigt dann leider nicht mehr.
      Gruß OSR
      Plattform
      IssiI 1 Antwort Letzte Antwort
        IssiI Online
        IssiI Online
        Issi
        schrieb am zuletzt editiert von Issi
        #236
        @ostseereiter ist das tablet vllt entsperrt wen es nämlich entsperrt ist passiert nichts wen man es so versucht zu umgehen also pin Password oder so rein machen
        • IssiI Issi
          ostseereiter
          #237
          @Issi ja ist entsperrt.
          Gruß OSR
          Plattform
          • IssiI Online
            IssiI Online
            Issi
            #238
            @ostseereiter im Fully Remote Admin solte Keyguard locked on sein
              IssiI Online
              IssiI Online
              Issi
              #239
              @ostseereiter sagte in [Aufruf] fullyBrowser Adapter:
              das tablet muss gesperrt sein also mit pin oder password
              • IssiI Issi
                ostseereiter
                #240
                @Issi
                aber Keyguard locked on ist bei mir
                Gruß OSR
                Plattform
                  @Issi
                  IssiI Online
                  IssiI Online
                  Issi
                  #241
                  @Issi
                  dann sollte es funktionieren tut es bei mir jedes mal
                  versuche mal das in dein browser zu öffnen
                  http:// deine Ip:2323/?cmd=setBooleanSetting&key=forceScreenUnlock&value=false&password=dein pw
                  dann sollte er in den Sperrbildschirm gehen
                  • IssiI Issi
                    @Issi
                    ostseereiter
                    #242
                    @Issi
                    also du meinst mal sperrbildpasswort setzen
                    Gruß OSR
                    Plattform
                      @Issi
                      ostseereiter
                      #243
                      @ostseereiter
                      habe mal Pin gesetzt, aber leider auch nichts.Schade danke dir trotzdem
                      Gruß OSR
                      Plattform
                        @ostseereiter
                        IssiI Online
                        IssiI Online
                        Issi
                        #244
                        @ostseereiter hmm das ist aber seltsam die ganzen app Berechtigungen hast du freigegeben oder?
                        • IssiI Issi
                          ostseereiter
                          #245
                          Kann man das irgendwo einsehen?
                          Gruß OSR
                          Plattform
                            IssiI Online
                            IssiI Online
                            Issi
                            #246
                            hmm bei mir funktioniert es auch ohne Berechtigungen und der fully meckert sowieso wen ihm Berechtigung fehlt also solltest du sie an haben
                            • IssiI Issi
                              ostseereiter
                              #247
                              Danke trotzdem.
                              Gruß OSR
                              Plattform
                                Danke trotzdem.
                                IssiI Online
                                IssiI Online
                                Issi
                                #248
                                @ostseereiter hab jetzt mal auf einem meiner Tablet's die noch kein pin hatten pin eingerichtet und neu start gemacht dann Fully startet ja eh beim booten von selber und hab's dann probiert es geht man darf das tablet nicht entsperren.
                                wenn nicht hilft dann weiß ich auch nicht mehr weiter wie gesagt bei mir funktioniert es hab nur Samsung Tablet's vllt hängt es mit dem Fire HD
                                • IssiI Issi
                                  ostseereiter
                                  #249
                                  @Issi
                                  Diese Fehlermeldung kommt :
                                  Gruß OSR
                                  Plattform
                                    @Issi
                                    ostseereiter
                                    #250
                                    @ostseereiter
                                    Ich denke jetzt auch das liegt am Fire Tablet
                                    Gruß OSR
                                    Plattform
                                      @ostseereiter
                                      IssiI Online
                                      IssiI Online
                                      Issi
                                      #251
                                      @ostseereiter
                                      ja glaub ich auch da das script anschein funktionirt und er versucht zu entsperren
                                      • IssiI Issi
                                        @ostseereiter
                                        ostseereiter
                                        #252
                                        Danke dir dann werde ich es über die Helligkeit steuern ab uhr auf 0 und morgens wieder auf
                                        255
                                        Gruß OSR
                                        Plattform
                                          255
                                          IssiI Online
                                          IssiI Online
                                          Issi
                                          #253
                                          255
                                          also wen du nur den bild schirm schwarz haben willst kannst du auch den startScreensaver nähmen da ist der ganze screen schwarz
