  4. [SOLVED] Instal.auf FreeBSD funktioniert nicht.
freenasfreebsdinstaller
74 Beiträge 6 Kommentatoren 10.8k Aufrufe 2 Beobachtet
    mrMuppet
    Ich habe jetzt einen Weg gefunden: Analog zu dieser Anleitung
    habe ich
    npm install iobroker.js-controller
    npm install iobroker.admin
    von Hand installiert. Danach klappt der
    node iobroker start
    Aber ist das sinnvoll zu vorzugehen? Ich hatte recht viele Warnungen:
    root@iobroker_v2:/opt/iobroker # npm install iobroker.js-controller
    > iobroker.js-controller@1.5.9 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.9.0
    npm version >= 5: disabling package-lock
    > unix-dgram@0.2.3 install /opt/iobroker/node_modules/unix-dgram
    > node-gyp rebuild
    gmake: Entering directory '/opt/iobroker/node_modules/unix-dgram/build'
      CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
    ../src/unix_dgram.cc:53:13: warning: unused function 'SetNonBlock' [-Wunused-function]
    inline void SetNonBlock(int fd) {
    ../src/unix_dgram.cc:65:13: warning: unused function 'SetCloExec' [-Wunused-function]
    inline void SetCloExec(int fd) {
    2 warnings generated.
      SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
      COPY Release/unix_dgram.node
    gmake: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
    > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
    > node rebuild.js
    > diskusage@0.2.6 install /opt/iobroker/node_modules/diskusage
    > node-gyp rebuild
    gmake: Entering directory '/opt/iobroker/node_modules/diskusage/build'
      CXX(target) Release/obj.target/diskusage/src/main.o
      CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
      SOLINK_MODULE(target) Release/obj.target/diskusage.node
      COPY Release/diskusage.node
    gmake: Leaving directory '/opt/iobroker/node_modules/diskusage/build'
    > iobroker.js-controller@1.5.9 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    creating conf/iobroker.json
    object system.certificates created
    object system.repositories created
    object system.config created
    object enum.functions created
    object enum.rooms created
    object system.group.user created
    object system.group.administrator created
    object _design/system created
    object system.user.admin created
    host.iobroker_v2 install adapter admin
    object system.meta.uuid created: 4816af3f-b9c0-a627-638c-43a3e3bfa2e0
    npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.admin"
    npm WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
    npm notice created a lockfile as package-lock.json. You should commit this file.
    got /opt/iobroker/node_modules/iobroker.admin/admin
    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
    upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    host.iobroker_v2 object system.adapter.admin created
    host.iobroker_v2 create instance admin
    host.iobroker_v2 object admin.0.connected created
    host.iobroker_v2 object admin.0 created
    host.iobroker_v2 object admin.0.info created
    host.iobroker_v2 object system.adapter.admin.upload created
    host.iobroker_v2 object system.adapter.admin.0.outputCount created
    host.iobroker_v2 object system.adapter.admin.0.inputCount created
    host.iobroker_v2 object system.adapter.admin.0.uptime created
    host.iobroker_v2 object system.adapter.admin.0.memRss created
    host.iobroker_v2 object system.adapter.admin.0.memHeapTotal created
    host.iobroker_v2 object system.adapter.admin.0.memHeapUsed created
    host.iobroker_v2 object system.adapter.admin.0.cputime created
    host.iobroker_v2 object system.adapter.admin.0.cpu created
    host.iobroker_v2 object system.adapter.admin.0.connected created
    host.iobroker_v2 object system.adapter.admin.0.alive created
    host.iobroker_v2 object system.adapter.admin.0 created
    npm WARN saveError ENOENT: no such file or directory, open '/opt/iobroker/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
    npm WARN iobroker No description
    npm WARN iobroker No repository field.
    npm WARN iobroker No README data
    npm WARN iobroker No license field.
    + iobroker.js-controller@1.5.9
    added 344 packages from 279 contributors and audited 855 packages in 70.532s
    found 27 vulnerabilities (19 low, 8 high)
      run `npm audit fix` to fix them, or `npm audit` for details
    root@iobroker_v2:/opt/iobroker # npm install iobroker.admin
    + iobroker.admin@3.6.2
    removed 177 packages, updated 1 package and audited 2650 packages in 3.835s
    found 64 vulnerabilities (43 low, 21 high)
    ioBroker auf NUC (Celeron mit Ubuntu-Server)
    Homematic, HMIP, Hue, Unifi, Plex, Nest, Roborock, Google Assistant
    • AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      Auch die Warnungen sind vollkommen normal. Aber manuell per npm nachzuinstallieren, sollte nicht nötig sein. Das Blöde ist, dass keiner von uns FreeBSD zum Testen hat. Da hängen wir maßgeblich vom Feedback ab, daher würde ich dich bitten, hier noch etwas Unterstützung zu leisten.
      node iobroker start ist aber nicht das richtige Kommando. iobroker start sollte funktionieren. Kannst du mal den Inhalt deiner PATH-Variable posten?
      echo "$PATH"
      • AlCalzoneA AlCalzone
        echo "$PATH"
        mrMuppet
        @AlCalzone sagte in Neue Installation auf FreeBSD/FreeNAS 11.2 funktioniert nicht.:
        echo "$PATH"
        Ich bin froh wenn ich mal was beitragen kann: :-)
        root@iobroker_v2:/ # echo "$PATH"
        /sbin:/bin:/usr/sbin:/usr/bin:/usr/local/sbin:/usr/local/bin:/root/bin
        • M mrMuppet
          echo "$PATH"
          AlCalzoneA Offline
          AlCalzoneA Offline
          AlCalzone
          @mrMuppet sagte in Neue Installation auf FreeBSD/FreeNAS 11.2 funktioniert nicht.:
          /usr/local/bin
          Das ist schon mal gut, da wird nämlich die Executable hingeschrieben. ls -la /usr/local/bin bitte.
          EDIT: Und am besten noch ls -la /opt/iobroker
            mrMuppet
            root@iobroker_v2:/ # ls -la /usr/local/bin
            total 84788
            drwxr-xr-x    2 root  wheel       194 May  7 21:13 .
            drwxr-xr-x   14 root  wheel        14 May  7 21:12 ..
            lrwxr-xr-x    1 root  wheel         6 Apr  4 02:35 2to3 -> 2to3-2
            lrwxr-xr-x    1 root  wheel         8 Apr  2 21:32 2to3-2 -> 2to3-2.7
            -rwxr-xr-x    1 root  wheel       101 Apr  2 03:16 2to3-2.7
            -rwxr-xr-x    1 root  wheel       101 Apr  2 03:17 2to3-3.6
            -r-xr-xr-x    1 root  wheel     20384 Apr  2 03:14 acountry
            -r-xr-xr-x    1 root  wheel   5279360 Apr  2 03:46 addr2line
            -r-xr-xr-x    1 root  wheel     20816 Apr  2 03:14 adig
            -r-xr-xr-x    1 root  wheel     11384 Apr  2 03:14 ahost
            -r-xr-xr-x    2 root  wheel   5309416 Apr  2 03:46 ar
            -r-xr-xr-x    2 root  wheel   6053840 Apr  2 03:46 as
            -rwxr-xr-x    1 root  wheel     24120 Apr  2 08:06 avahi-browse
            lrwxr-xr-x    1 root  wheel        12 Apr  2 08:06 avahi-browse-domains -> avahi-browse
            -rwxr-xr-x    1 root  wheel     17336 Apr  2 08:06 avahi-publish
            lrwxr-xr-x    1 root  wheel        13 Apr  2 08:06 avahi-publish-address -> avahi-publish
            lrwxr-xr-x    1 root  wheel        13 Apr  2 08:06 avahi-publish-service -> avahi-publish
            -rwxr-xr-x    1 root  wheel     14440 Apr  2 08:06 avahi-resolve
            lrwxr-xr-x    1 root  wheel        13 Apr  2 08:06 avahi-resolve-address -> avahi-resolve
            lrwxr-xr-x    1 root  wheel        13 Apr  2 08:06 avahi-resolve-host-name -> avahi-resolve
            -rwxr-xr-x    1 root  wheel     11472 Apr  2 08:06 avahi-set-host-name
            -rwxr-xr-x    1 root  wheel   1157192 Apr  2 03:26 bash
            -r-xr-xr-x    1 root  wheel      6774 Apr  2 03:26 bashbug
            -rwxr-xr-x    4 root  wheel   1052008 Apr 28 07:06 c++8
            -r-xr-xr-x    1 root  wheel   5281696 Apr  2 03:46 c++filt
            -rwxr-xr-x    1 root  wheel     15100 Apr  2 03:20 corelist
            -rwxr-xr-x    1 root  wheel      8168 Apr  2 03:20 cpan
            -rwxr-xr-x    1 root  wheel   1048456 Apr 28 07:06 cpp8
            -rwxr-xr-x    1 root  wheel    192528 Apr  2 03:27 curl
            -r-xr-xr-x    1 root  wheel      7334 Apr  2 03:27 curl-config
            -r-xr-xr-x    1 root  wheel     69576 Feb  7 02:07 cvsps
            -rwxr-xr-x    1 root  wheel    244744 Apr  2 03:14 cvtsudoers
            -rwxr-xr-x    1 root  wheel     91560 Apr  2 03:33 dbus-binding-tool
            -rwxr-xr-x    1 root  wheel     11360 Apr  2 03:31 dbus-cleanup-sockets
            -rwxr-xr-x    1 root  wheel    196096 Apr  2 03:31 dbus-daemon
            -rwxr-xr-x    1 root  wheel     25672 Apr  2 03:31 dbus-launch
            -rwxr-xr-x    1 root  wheel     21640 Apr  2 03:31 dbus-monitor
            -rwxr-xr-x    1 root  wheel     11368 Apr  2 03:31 dbus-run-session
            -rwxr-xr-x    1 root  wheel     22776 Apr  2 03:31 dbus-send
            -rwxr-xr-x    1 root  wheel     18616 Apr  2 03:31 dbus-test-tool
            -rwxr-xr-x    1 root  wheel     10472 Apr  2 03:31 dbus-update-activation-environment
            -rwxr-xr-x    1 root  wheel      7840 Apr  2 03:31 dbus-uuidgen
            -rwxr-xr-x    1 root  wheel     24640 Apr 20 03:25 derb
            -r-xr-xr-x    1 root  wheel   2381144 Apr  2 03:46 dwp
            -r-xr-xr-x    1 root  wheel     37200 Apr  2 03:46 elfedit
            -rwxr-xr-x    1 root  wheel     42056 Apr  2 03:20 enc2xs
            -rwxr-xr-x    1 root  wheel      3078 Apr  2 03:20 encguess
            -rwxr-xr-x    1 root  wheel     40432 Feb  7 02:07 envsubst
            -r-xr-xr-x    1 root  wheel     27720 Feb  7 05:14 funzip
            lrwxr-xr-x    1 root  wheel         4 Apr 28 07:13 g++ -> g++8
            -rwxr-xr-x    4 root  wheel   1052008 Apr 28 07:06 g++8
            -r-xr-xr-x    1 root  wheel      2269 Apr  2 08:02 g-ir-annotation-tool
            -rwxr-xr-x    1 root  wheel    169472 Apr  2 08:02 g-ir-compiler
            -rwxr-xr-x    1 root  wheel     37296 Apr  2 08:02 g-ir-generate
            -rwxr-xr-x    1 root  wheel      8392 Apr  2 08:02 g-ir-inspect
            -r-xr-xr-x    1 root  wheel      2260 Apr  2 08:02 g-ir-scanner
            -rwxr-xr-x    1 root  wheel     16064 Apr  2 03:33 gapplication
            lrwxr-xr-x    1 root  wheel         4 Apr 28 07:13 gcc -> gcc8
            -rwxr-xr-x    2 root  wheel     26160 Apr 28 07:06 gcc-ar8
            -rwxr-xr-x    2 root  wheel     26128 Apr 28 07:06 gcc-nm8
            -rwxr-xr-x    2 root  wheel     26128 Apr 28 07:06 gcc-ranlib8
            -rwxr-xr-x    3 root  wheel   1047912 Apr 28 07:06 gcc8
            -rwxr-xr-x    1 root  wheel    508240 Apr 28 07:06 gcov-dump8
            -rwxr-xr-x    1 root  wheel    532880 Apr 28 07:06 gcov-tool8
            -rwxr-xr-x    1 root  wheel    660880 Apr 28 07:06 gcov8
            -rwxr-xr-x    1 root  wheel     20080 Feb  7 02:13 gdbm_dump
            -rwxr-xr-x    1 root  wheel     22272 Feb  7 02:13 gdbm_load
            -rwxr-xr-x    1 root  wheel     99088 Feb  7 02:13 gdbmtool
            -rwxr-xr-x    1 root  wheel     38584 Apr  2 03:33 gdbus
            -r-xr-xr-x    1 root  wheel      2065 Apr  2 03:33 gdbus-codegen
            -rwxr-xr-x    1 root  wheel     12264 Apr 20 03:25 genbrk
            -rwxr-xr-x    1 root  wheel     10456 Apr 20 03:25 gencfu
            -rwxr-xr-x    1 root  wheel     20232 Apr 20 03:25 gencnval
            -rwxr-xr-x    1 root  wheel     24408 Apr 20 03:25 gendict
            -rwxr-xr-x    1 root  wheel    163800 Apr 20 03:25 genrb
            -rwxr-xr-x    1 root  wheel     40416 Feb  7 02:07 gettext
            -r-xr-xr-x    1 root  wheel      4629 Feb  7 02:07 gettext.sh
            lrwxr-xr-x    1 root  wheel         9 Apr 28 07:13 gfortran -> gfortran8
            -rwxr-xr-x    2 root  wheel   1052008 Apr 28 07:06 gfortran8
            -rwxr-xr-x    1 root  wheel     70360 Apr  2 03:33 gio
            -rwxr-xr-x    1 root  wheel     10248 Apr  2 03:33 gio-querymodules
            -rwxr-xr-x  127 root  wheel   2568208 Apr  2 03:35 git
            -rwxr-xr-x    2 root  wheel    162751 Apr  2 03:35 git-cvsserver
            -r-xr-xr-x    1 root  wheel    156977 Apr  2 03:35 git-p4.py
            -rwxr-xr-x  127 root  wheel   2568208 Apr  2 03:35 git-receive-pack
            -rwxr-xr-x    2 root  wheel   1461608 Apr  2 03:35 git-shell
            -rwxr-xr-x  127 root  wheel   2568208 Apr  2 03:35 git-upload-archive
            -rwxr-xr-x  127 root  wheel   2568208 Apr  2 03:35 git-upload-pack
            -rwxr-xr-x    1 root  wheel     37880 Apr  2 03:33 glib-compile-resources
            -rwxr-xr-x    1 root  wheel     42336 Apr  2 03:33 glib-compile-schemas
            -r-xr-xr-x    1 root  wheel     40933 Apr  2 03:33 glib-genmarshal
            -r-xr-xr-x    1 root  wheel      5381 Apr  2 03:33 glib-gettextize
            -r-xr-xr-x    1 root  wheel     27808 Apr  2 03:33 glib-mkenums
            -r-xr-xr-x    1 root  wheel    221600 Feb  7 02:08 gmake
            -rwxr-xr-x    1 root  wheel      8736 Apr  2 03:33 gobject-query
            -r-xr-xr-x    1 root  wheel   5344720 Apr  2 03:46 gprof
            -rwxr-xr-x    1 root  wheel     15832 Apr  2 03:33 gresource
            -rwxr-xr-x    1 root  wheel     21880 Apr  2 03:33 gsettings
            -rwxr-xr-x    1 root  wheel     20728 Apr  2 03:33 gtester
            -rwxr-xr-x    1 root  wheel     18839 Apr  2 03:33 gtester-report
            -rwxr-xr-x    1 root  wheel     29236 Apr  2 03:20 h2ph
            -rwxr-xr-x    1 root  wheel     60878 Apr  2 03:20 h2xs
            -rwxr-xr-x    1 root  wheel     24912 Feb  7 02:07 iconv
            -r-xr-xr-x    1 root  wheel     22122 Apr 20 03:25 icu-config
            -rwxr-xr-x    1 root  wheel      9048 Apr 20 03:25 icuinfo
            lrwxr-xr-x    1 root  wheel         5 Apr  4 02:35 idle -> idle2
            lrwxr-xr-x    1 root  wheel         7 Apr  2 21:32 idle2 -> idle2.7
            -rwxr-xr-x    1 root  wheel        99 Apr  2 03:16 idle2.7
            -rwxr-xr-x    1 root  wheel        99 Apr  2 03:17 idle3.6
            -rwxr-xr-x    1 root  wheel     11496 Feb  7 02:07 indexinfo
            -rwxr-xr-x    1 root  wheel      4299 Apr  2 03:20 instmodsh
            lrwxr-xr-x    1 root  wheel        22 May  7 21:13 iob -> /opt/iobroker/iobroker
            lrwxr-xr-x    1 root  wheel        22 May  7 21:13 iobroker -> /opt/iobroker/iobroker
            -rwxr-xr-x    1 root  wheel      4391 Apr  2 03:20 json_pp
            -r-xr-xr-x    4 root  wheel  11461040 Apr  2 03:46 ld
            -r-xr-xr-x    4 root  wheel  11461040 Apr  2 03:46 ld.bfd
            -r-xr-xr-x    2 root  wheel   4478752 Apr  2 03:46 ld.gold
            -rwxr-xr-x    1 root  wheel     15787 Apr  2 03:20 libnetcfg
            -rwxr-xr-x    1 root  wheel     53536 Apr 20 03:25 makeconv
            -rwxr-xr-x    1 root  wheel     40424 Feb  7 02:07 ngettext
            -r-xr-xr-x    2 root  wheel   5291408 Apr  2 03:46 nm
            -rwxr-xr-x    1 root  wheel  22650048 Apr 20 04:06 node
            lrwxr-xr-x    1 root  wheel        38 Mar  7 16:09 npm -> ../lib/node_modules/npm/bin/npm-cli.js
            lrwxr-xr-x    1 root  wheel        38 Mar  7 16:09 npx -> ../lib/node_modules/npm/bin/npx-cli.js
            -r-xr-xr-x    2 root  wheel   5421952 Apr  2 03:46 objcopy
            -r-xr-xr-x    2 root  wheel  18191336 Apr  2 03:46 objdump
            -r-xr-xr-x    1 root  wheel      2367 Apr  2 03:17 pcre-config
            -rwxr-xr-x    1 root  wheel     38144 Apr  2 03:17 pcregrep
            -rwxr-xr-x    1 root  wheel    110424 Apr  2 03:17 pcretest
            -rwxr-xr-x    1 root  wheel      7800 Apr  2 03:21 perl
            lrwxr-xr-x    1 root  wheel         4 Apr  2 03:21 perl5 -> perl
            lrwxr-xr-x    1 root  wheel         4 Apr  2 03:21 perl5.28.1 -> perl
            -rwxr-xr-x    2 root  wheel     46374 Apr  2 03:20 perlbug
            -rwxr-xr-x    1 root  wheel       274 Apr  2 03:20 perldoc
            -rwxr-xr-x    1 root  wheel     10831 Apr  2 03:20 perlivp
            -rwxr-xr-x    2 root  wheel     46374 Apr  2 03:20 perlthanks
            -rwxr-xr-x    1 root  wheel      8369 Apr  2 03:20 piconv
            -rwxr-xr-x    1 root  wheel     45624 Apr 20 03:25 pkgdata
            -rwxr-xr-x    1 root  wheel      4545 Apr  2 03:20 pl2pm
            -rwxr-xr-x    1 root  wheel      4146 Apr  2 03:20 pod2html
            -rwxr-xr-x    1 root  wheel     15225 Apr  2 03:20 pod2man
            -rwxr-xr-x    1 root  wheel     11122 Apr  2 03:20 pod2text
            -rwxr-xr-x    1 root  wheel      3954 Apr  2 03:20 pod2usage
            -rwxr-xr-x    1 root  wheel      3664 Apr  2 03:20 podchecker
            -rwxr-xr-x    1 root  wheel      2533 Apr  2 03:20 podselect
            -rwxr-xr-x    1 root  wheel     13667 Apr  2 03:20 prove
            -rwxr-xr-x    1 root  wheel      3561 Apr  2 03:20 ptar
            -rwxr-xr-x    1 root  wheel      2640 Apr  2 03:20 ptardiff
            -rwxr-xr-x    1 root  wheel      4404 Apr  2 03:20 ptargrep
            lrwxr-xr-x    1 root  wheel         6 Apr  4 02:35 pydoc -> pydoc2
            lrwxr-xr-x    1 root  wheel         8 Apr  2 21:32 pydoc2 -> pydoc2.7
            -rwxr-xr-x    1 root  wheel        84 Apr  2 03:16 pydoc2.7
            -rwxr-xr-x    1 root  wheel        84 Apr  2 03:17 pydoc3.6
            lrwxr-xr-x    1 root  wheel         7 Apr  4 02:35 python -> python2
            lrwxr-xr-x    1 root  wheel        14 Apr  4 02:35 python-config -> python2-config
            lrwxr-xr-x    1 root  wheel         9 Apr  2 21:32 python2 -> python2.7
            lrwxr-xr-x    1 root  wheel        16 Apr  2 21:32 python2-config -> python2.7-config
            -r-xr-xr-x    1 root  wheel      5600 Apr  2 03:15 python2.7
            -r-xr-xr-x    1 root  wheel      1769 Apr  2 03:16 python2.7-config
            -r-xr-xr-x    2 root  wheel      7304 Apr  2 03:17 python3.6
            lrwxr-xr-x    1 root  wheel        17 Apr  2 03:17 python3.6-config -> python3.6m-config
            -r-xr-xr-x    2 root  wheel      7304 Apr  2 03:17 python3.6m
            -r-xr-xr-x    1 root  wheel      3120 Apr  2 03:17 python3.6m-config
            -rwxr-xr-x    1 root  wheel       441 Apr  2 03:17 pyvenv-3.6
            -r-xr-xr-x    2 root  wheel   5309432 Apr  2 03:46 ranlib
            lrwxr-xr-x    1 root  wheel         4 Apr  2 03:26 rbash -> bash
            -r-xr-xr-x    2 root  wheel    633248 Apr  2 03:46 readelf
            -rwxr-xr-x    1 root  wheel      9988 Apr  2 03:20 shasum
            -r-xr-xr-x    1 root  wheel   5280816 Apr  2 03:46 size
            -rwxr-xr-x    1 root  wheel     19162 Apr  2 03:20 splain
            -r-xr-xr-x    1 root  wheel   5280480 Apr  2 03:46 strings
            -r-xr-xr-x    2 root  wheel   5421968 Apr  2 03:46 strip
            -rwsr-xr-x    1 root  wheel    128872 Apr  2 03:14 sudo
            lrwxr-xr-x    1 root  wheel         4 Apr  2 03:14 sudoedit -> sudo
            -rwxr-xr-x    1 root  wheel     57376 Apr  2 03:14 sudoreplay
            -rwxr-xr-x    1 root  wheel     49504 Apr 20 03:25 uconv
            -r-xr-xr-x    1 root  wheel    154560 Feb  7 05:14 unzip
            -r-xr-xr-x    1 root  wheel     70304 Feb  7 05:14 unzipsfx
            -rwxr-xr-x    4 root  wheel   1052008 Apr 28 07:06 x86_64-portbld-freebsd11.2-c++8
            -rwxr-xr-x    4 root  wheel   1052008 Apr 28 07:06 x86_64-portbld-freebsd11.2-g++8
            -rwxr-xr-x    3 root  wheel   1047912 Apr 28 07:06 x86_64-portbld-freebsd11.2-gcc-8.3.0
            -rwxr-xr-x    2 root  wheel     26160 Apr 28 07:06 x86_64-portbld-freebsd11.2-gcc-ar8
            -rwxr-xr-x    2 root  wheel     26128 Apr 28 07:06 x86_64-portbld-freebsd11.2-gcc-nm8
            -rwxr-xr-x    2 root  wheel     26128 Apr 28 07:06 x86_64-portbld-freebsd11.2-gcc-ranlib8
            -rwxr-xr-x    3 root  wheel   1047912 Apr 28 07:06 x86_64-portbld-freebsd11.2-gcc8
            -rwxr-xr-x    2 root  wheel   1052008 Apr 28 07:06 x86_64-portbld-freebsd11.2-gfortran8
            -r-xr-xr-x    1 root  wheel      1735 Apr  2 03:15 xml2-config
            -rwxr-xr-x    1 root  wheel     15984 Apr  2 03:15 xmlcatalog
            -rwxr-xr-x    1 root  wheel     61384 Apr  2 03:15 xmllint
            -rwxr-xr-x    1 root  wheel     28480 Feb  7 02:07 xmlwf
            -rwxr-xr-x    1 root  wheel      5176 Apr  2 03:20 xsubpp
            -rwxr-xr-x    1 root  wheel     48509 Apr  2 03:20 zipdetails
            -r-xr-xr-x    1 root  wheel      2953 Feb  7 05:14 zipgrep
            lrwxr-xr-x    1 root  wheel         5 Feb  7 05:14 zipinfo -> unzip
              mrMuppet
              root@iobroker_v2:/ # ls -la /opt/iobroker
              total 134
              drwxr-xr-x    5 root  wheel     12 May 21 16:40 .
              drwxr-xr-x    3 root  wheel      3 May  7 21:12 ..
              -rw-r--r--    1 root  wheel     19 May 21 16:38 .npmrc
              -rwxrwxrwx    1 root  wheel    129 May  7 21:13 INSTALLER_INFO.txt
              -rwxr-xr-x    1 root  wheel    102 May  7 21:13 iobroker
              drwxr-xr-x    4 root  wheel      9 May 21 16:41 iobroker-data
              drwxr-xr-x    2 root  wheel      3 May 21 16:40 log
              drwxr-xr-x  306 root  wheel    306 May 21 16:39 node_modules
              -rw-r--r--    1 root  wheel  94547 May 21 16:39 package-lock.json
              -rw-rw-rw-    1 root  wheel     70 May 21 16:40 package.json
              -rw-r--r--    1 root  wheel   5868 May 21 16:40 reinstall.js
              • M mrMuppet
                total 84788
                AlCalzoneA Offline
                AlCalzoneA Offline
                AlCalzone
                Danke, das sieht soweit alles gut aus.
                Kannst du bitte mal zum Testen die Executable bearbeiten:
                nano /opt/iobroker/iobroker
                Und die erste Zeile ändern zu
                #!/usr/local/bin/bash
                Danach funktioniert iobroker start hoffentlich
                  mrMuppet
                  @AlCalzone
                  root@iobroker_v2:/ # iobroker start
                  Starting iobroker controller daemon...
                  iobroker controller daemon failed to start:  Failed to write pidfile (EACCES)
                  Error: Failed to write pidfile (EACCES)
                  • M mrMuppet
                    @AlCalzone
                    AlCalzoneA Offline
                    AlCalzoneA Offline
                    AlCalzone
                    @mrMuppet Schon besser. Jetzt stimmen nur die Rechte nicht mehr, weil du als root die Module installiert hast 😆
                    Ich passe mal den Installer an, dann darfst du wieder testen. Dauert ein paar Minuten, kannst ja schon mal das System neu aufsetzen.
                      mrMuppet
                      Ok. Wird gemacht. Ich installiere schon mal die Pakete wie oben beschrieben.
                        AlCalzoneA Offline
                        AlCalzone
                        Ok, neue Version ist zum Testen online. Bis sie gemerged ist, kannst du diese per
                        curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/freebsd-fix/installer.sh | bash -
                        installieren.
                          installieren.
                          mrMuppet
                          @AlCalzone Super! Danke. Ich melde mich sobald ich soweit bin. Aktuell hänge ich bei Paket 4/38 ... dauert also noch ... (vielleicht 30 min.?)
                          • M mrMuppet
                            AlCalzoneA Offline
                            AlCalzoneA Offline
                            AlCalzone
                            @mrMuppet Prima, kein Stress...
                              mrMuppet
                              Das war es noch nicht ganz:
                              root@iobroker_v2:~ # curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/freebsd-fix/installer.sh | bash -
                                  Welcome to the ioBroker installer!
                                  Installer version: 2019-05-21
                                  You might need to enter your password a couple of times.
                                  Installing prerequisites (1/4)
                              Installed sudo
                              Installed unzip
                              Installed avahi-libdns
                              Installed nss_mdns
                              Installed gcc
                              dbus_enable:  -> YES
                              avahi_daemon_enable:  -> YES
                              Starting dbus.
                              Starting avahi-daemon.
                                  Creating ioBroker user and directory (2/4)
                              tty:*:4
                              Directory /opt/iobroker created
                                  Installing ioBroker (3/4)
                              ../src/serialport.cpp:95:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
                                data->callback.Call(2, argv);
                              ../../nan/nan.h:1739:3: note: 'Call' has been explicitly marked deprecated here
                                NAN_DEPRECATED inline v8::Local<v8::Value>
                              ../../nan/nan.h:104:40: note: expanded from macro 'NAN_DEPRECATED'
                              # define NAN_DEPRECATED __attribute__((deprecated))
                              ../src/serialport.cpp:150:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
                                data->callback.Call(1, argv);
                              ../src/serialport.cpp:188:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
                              ../src/serialport.cpp:231:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
                              ../src/serialport.cpp:285:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
                              ../src/serialport.cpp:336:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
                              ../src/serialport.cpp:383:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
                              ../src/serialport.cpp:424:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
                              8 warnings generated.
                              ../src/serialport_unix.cpp:384:20: warning: variable 'outbaud' is uninitialized when used here
                                    [-Wuninitialized]
                                data->baudRate = outbaud;
                              ../src/serialport_unix.cpp:369:14: note: initialize the variable 'outbaud' to silence this
                                    warning
                                int outbaud;
                                            = 0
                              1 warning generated.
                              ../src/poller.cpp:69:17: warning: 'Call' is deprecated [-Wdeprecated-declarations]
                                obj->callback.Call(2, argv);
                                  Finalizing installation (4/4)
                              Enabling autostart...
                              iobroker_enable:  -> YES
                              platform: Undefined variable.
                              Autostart enabled!
                              root@iobroker_v2:~ # iobroker start
                              • M mrMuppet
                                Installed sudo
                                Installed unzip
                                Installed nss_mdns
                                Installed gcc
                                dbus_enable:  -> YES
                                Starting dbus.
                                tty:*:4
                                      [-Wuninitialized]
                                      warning
                                  int outbaud;
                                              = 0
                                Autostart enabled!
                                AlCalzoneA Offline
                                AlCalzoneA Offline
                                AlCalzone
                                @mrMuppet Ok gib mir ein paar Minuten
                                  AlCalzoneA Offline
                                  AlCalzone
                                  EACCES
                                  Was sagt ls -la /opt/iobroker/node_modules/iobroker.js-controller/lib ?
                                    AlCalzoneA Offline
                                    AlCalzone
                                    Kann es sein, dass ioBroker nach der Installation bereits läuft?
                                      EACCES
                                      mrMuppet
                                      Läuft noch nicht.
                                      root@iobroker_v2:~ # ls -la /opt/iobroker/node_modules/iobroker.js-controller/lib
                                      total 382
                                      drwxr-xr-x  9 root  wheel      28 May 21 18:05 .
                                      drwxr-xr-x  6 root  wheel      17 May 21 18:06 ..
                                      -rw-r--r--  1 root  wheel  225379 Oct 26  1985 adapter.js
                                      -rw-r--r--  1 root  wheel    2012 Oct 26  1985 dbdump.js
                                      -rw-r--r--  1 root  wheel    1828 Oct 26  1985 defaultObjs.js
                                      drwxr-xr-x  2 root  wheel       3 May 21 18:05 img
                                      -rw-r--r--  1 root  wheel    9114 Oct 26  1985 letsencrypt.js
                                      -rw-r--r--  1 root  wheel   26624 Oct 26  1985 letsencryptStore.js
                                      -rw-r--r--  1 root  wheel   11236 Oct 26  1985 logger.js
                                      -rw-r--r--  1 root  wheel    7177 Oct 26  1985 multihostClient.js
                                      -rw-r--r--  1 root  wheel    9174 Oct 26  1985 multihostServer.js
                                      drwxr-xr-x  2 root  wheel       5 May 21 18:05 objects
                                      -rw-r--r--  1 root  wheel     531 Oct 26  1985 objects.js
                                      -rw-r--r--  1 root  wheel    2644 Oct 26  1985 password.js
                                      -rw-r--r--  1 root  wheel    4544 Oct 26  1985 preinstall_check.js
                                      -rw-r--r--  1 root  wheel    1755 Oct 26  1985 renewal.conf.tpl
                                      -rw-r--r--  1 root  wheel    6026 Oct 26  1985 restart.js
                                      drwxr-xr-x  2 root  wheel       3 May 21 18:05 scripts
                                      -rw-r--r--  1 root  wheel    1809 Oct 26  1985 session.js
                                      drwxr-xr-x  2 root  wheel      14 May 21 18:05 setup
                                      -rw-r--r--  1 root  wheel  154618 Oct 26  1985 setup.js
                                      drwxr-xr-x  2 root  wheel       5 May 21 18:05 states
                                      -rw-r--r--  1 root  wheel     523 Oct 26  1985 states.js
                                      -rw-r--r--  1 root  wheel   47344 Oct 26  1985 tools.js
                                      -rw-r--r--  1 root  wheel    3808 Oct 26  1985 uploadFiles.js
                                      drwxr-xr-x  2 root  wheel       3 May 21 18:05 vis
                                      drwxr-xr-x  3 root  wheel       3 May 21 18:05 www
                                      -rw-r--r--  1 root  wheel   13190 Oct 26  1985 zipFiles.js
                                        AlCalzoneA Offline
                                        AlCalzone
                                        Hmm, da werden die Berechtigungen nicht richtig gesetzt... Evtl hat das mit der Meldung oben zu tun "unknown variable platform". Ich hab mal den Debug-Mode aktiviert, um (hoffentlich) zu sehen was los ist, bitte nochmal installieren (ohne System neu aufsetzen):
                                        rm -rf /opt/iobroker
                                          mrMuppet
                                          + INSTALLER_VERSION=2019-05-21
                                          + [[ 0 -eq 0 ]]
                                          + IS_ROOT=true
                                          + ROOT_GROUP=root
                                          ++ uname
                                          + unamestr=FreeBSD
                                          + '[' FreeBSD = Linux ']'
                                          + '[' FreeBSD = Darwin ']'
                                          + '[' FreeBSD = FreeBSD ']'
                                          + platform=freebsd
                                          + ROOT_GROUP=wheel
                                          + IOB_DIR=/opt/iobroker
                                          + '[' freebsd = osx ']'
                                          + CONTROLLER_DIR=/opt/iobroker/node_modules/iobroker.js-controller
                                          + INSTALLER_INFO_FILE=/opt/iobroker/INSTALLER_INFO.txt
                                          + INSTALL_TARGET=iobroker
                                          + IOB_USER=iobroker
                                          + test -t 1
                                          ++ which tput
                                          ++ tput colors
                                          + ncolors=94
                                          + test -n 94
                                          + test 94 -ge 8
                                          ++ tput cols
                                          + termcols=94
                                          ++ tput bold
                                          + bold=
                                          ++ tput smul
                                          + underline=
                                          ++ tput smso
                                          + standout=
                                          ++ tput sgr0
                                          + normal=
                                          ++ tput setaf 0
                                          + black=''
                                          ++ tput setaf 1
                                          + red=''
                                          ++ tput setaf 2
                                          + green=''
                                          ++ tput setaf 3
                                          + yellow=''
                                          ++ tput setaf 4
                                          + blue=''
                                          ++ tput setaf 5
                                          + magenta=''
                                          ++ tput setaf 6
                                          + cyan=''
                                          ++ tput setaf 7
                                          + white=''
                                          + HLINE===========================================================================
                                          + print_bold 'Welcome to the ioBroker installer!' 'Installer version: 2019-05-21' '' 'You might need to enter your password a couple of times.'
                                          + title='Welcome to the ioBroker installer!'
                                          + echo
                                          + echo ==========================================================================
                                          + echo
                                          + echo '    Welcome to the ioBroker installer!'
                                          + for text in "${@:2}"
                                          + echo '    Installer version: 2019-05-21'
                                          + echo '    '
                                          + echo '    You might need to enter your password a couple of times.'
                                          + echo
                                          + echo
                                          + export AUTOMATED_INSTALLER=true
                                          + AUTOMATED_INSTALLER=true
                                          + NUM_STEPS=4
                                          + print_step 'Installing prerequisites' 1 4
                                          + stepname='Installing prerequisites'
                                          + stepnr=1
                                          + steptotal=4
                                          + echo
                                          + echo '    Installing prerequisites (1/4)'
                                          + echo
                                          + case "$platform" in
                                          + packages=("sudo" "git" "curl" "bash" "unzip" "avahi-libdns" "dbus" "nss_mdns" "gcc" "python")
                                          + declare -a packages
                                          + for pkg in "${packages[@]}"
                                          + install_package_freebsd sudo
                                          + package=sudo
                                          + pkg info sudo
                                          + install_package_freebsd git
                                          + package=git
                                          + pkg info git
                                          + install_package_freebsd curl
                                          + package=curl
                                          + pkg info curl
                                          + install_package_freebsd bash
                                          + package=bash
                                          + pkg info bash
                                          + install_package_freebsd unzip
                                          + package=unzip
                                          + pkg info unzip
                                          + install_package_freebsd avahi-libdns
                                          + package=avahi-libdns
                                          + pkg info avahi-libdns
                                          + install_package_freebsd dbus
                                          + package=dbus
                                          + pkg info dbus
                                          + install_package_freebsd nss_mdns
                                          + package=nss_mdns
                                          + pkg info nss_mdns
                                          + install_package_freebsd gcc
                                          + package=gcc
                                          + pkg info gcc
                                          + install_package_freebsd python
                                          + package=python
                                          + pkg info python
                                          + ln -s /usr/local/include/avahi-compat-libdns_sd/dns_sd.h /usr/include/dns_sd.h
                                          ln: /usr/include/dns_sd.h: File exists
                                          + sed -i -e s/#enable-dbus/enable-dbus/ /usr/local/etc/avahi/avahi-daemon.conf
                                          + sed -i -e 's/hosts: file dns/hosts: file dns mdns/' /etc/nsswitch.conf
                                          + sysrc -f /etc/rc.conf dbus_enable=YES
                                          dbus_enable: YES -> YES
                                          + sysrc -f /etc/rc.conf avahi_daemon_enable=YES
                                          avahi_daemon_enable: YES -> YES
                                          + service dbus start
                                          dbus already running?  (pid=55380).
                                          + service avahi-daemon start
                                          avahi_daemon already running?  (pid=55387).
                                          + print_step 'Creating ioBroker user and directory' 2 4
                                          + stepname='Creating ioBroker user and directory'
                                          + stepnr=2
                                          + steptotal=4
                                          + echo
                                          + echo '    Creating ioBroker user and directory (2/4)'
                                          + echo
                                          + '[' freebsd = linux ']'
                                          + '[' freebsd = freebsd ']'
                                          + create_user_freebsd iobroker
                                          + username=iobroker
                                          + id iobroker
                                          + '[' 0 -ne 0 ']'
                                          + groups=(audio bluetooth dialout gpio i2c redis tty)
                                          + declare -a groups
                                          + for grp in "${groups[@]}"
                                          + '[' true = true ']'
                                          + getent group audio
                                          + getent group bluetooth
                                          + getent group dialout
                                          + getent group gpio
                                          + getent group i2c
                                          + getent group redis
                                          + getent group tty
                                          tty:*:4:iobroker
                                          + pw group mod tty -m iobroker
                                          + mkdir -p /opt/iobroker
                                          + cd /opt/iobroker
                                          + echo 'Directory /opt/iobroker created'
                                          + touch /opt/iobroker/INSTALLER_INFO.txt
                                          + chmod 777 /opt/iobroker/INSTALLER_INFO.txt
                                          + echo 'Installer version: 2019-05-21'
                                          ++ date +%F
                                          + echo 'Installation date 2019-05-21'
                                          + echo 'Platform: freebsd'
                                          + print_step 'Installing ioBroker' 3 4
                                          + stepname='Installing ioBroker'
                                          + stepnr=3
                                          + steptotal=4
                                          + echo
                                          + echo '    Installing ioBroker (3/4)'
                                          + echo
                                          + echo 'Installed as root'
                                          + npm i iobroker --loglevel error --unsafe-perm
                                          + npm i --production --loglevel error --unsafe-perm
                                                [-Wuninitialized]
                                                warning
                                            int outbaud;
                                                        = 0
                                          + print_step 'Finalizing installation' 4 4
                                          + stepname='Finalizing installation'
                                          + stepnr=4
                                          + steptotal=4
                                          + echo
                                          + echo '    Finalizing installation (4/4)'
                                          + echo
                                          + INITSYSTEM=unknown
                                          + [[ freebsd = \f\r\e\e\b\s\d ]]
                                          + [[ -d /usr/local/etc/rc.d ]]
                                          + INITSYSTEM=rc.d
                                          + [[ -n '' ]]
                                          + echo 'init system: rc.d'
                                          + IOB_NODE_CMDLINE=node
                                          ++ which bash
                                          + BASH_CMDLINE=/usr/local/bin/bash
                                          + '[' iobroker '!=' root ']'
                                          + IOB_NODE_CMDLINE='sudo -H -u iobroker node'
                                          + '[' rc.d = systemd ']'
                                          + '[' rc.d = launchctl ']'
                                          ++ cat
                                          + IOB_EXECUTABLE='#!/usr/local/bin/bash
                                          sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js $@'
                                          + IOB_BIN_PATH=/usr/local/bin
                                          + ln -sfn /opt/iobroker/iobroker /usr/local/bin/iobroker
                                          + ln -sfn /opt/iobroker/iobroker /opt/iobroker/iob
                                          + echo '#!/usr/local/bin/bash
                                          + make_executable /opt/iobroker/iobroker
                                          + file=/opt/iobroker/iobroker
                                          + chmod 755 /opt/iobroker/iobroker
                                          + [[ rc.d = \i\n\i\t\.\d ]]
                                          + '[' rc.d = rc.d ']'
                                          + echo 'Enabling autostart...'
                                          ++ cat
                                          + RCD_FILE='#!/bin/sh
                                          # PROVIDE: iobroker
                                          # REQUIRE: DAEMON
                                          # KEYWORD: shutdown
                                          . /etc/rc.subr
                                          name="iobroker"
                                          rcvar="iobroker_enable"
                                          load_rc_config $name
                                          iobroker_enable=${iobroker_enable-"NO"}
                                          iobroker_pidfile=${iobroker_pidfile-"/opt/iobroker/node_modules/iobroker.js-controller/lib/iobroker.pid"}
                                          PIDF=/opt/iobroker/node_modules/iobroker.js-controller/lib/iobroker.pid
                                          NODECMD=$(which node)
                                          iobroker_start ()
                                          su -m iobroker -s "/usr/local/bin/bash" -c "${NODECMD} /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js start"
                                          iobroker_stop ()
                                          su -m iobroker -s "/usr/local/bin/bash" -c "${NODECMD} /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js stop"
                                          iobroker_status ()
                                          su -m iobroker -s "/usr/local/bin/bash" -c "${NODECMD} /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js status"
                                          PATH="${PATH}:/usr/local/bin"
                                          pidfile="${iobroker_pidfile}"
                                          start_cmd=iobroker_start
                                          stop_cmd=iobroker_stop
                                          status_cmd=iobroker_status
                                          run_rc_command "$1"'
                                          + SERVICE_FILENAME=/usr/local/etc/rc.d/iobroker
                                          + echo '#!/bin/sh
                                          # PROVIDE: iobroker
                                          # REQUIRE: DAEMON
                                          # KEYWORD: shutdown
                                          . /etc/rc.subr
                                          name="iobroker"
                                          iobroker_start ()
                                          iobroker_stop ()
                                          iobroker_status ()
                                          + set_root_permissions /usr/local/etc/rc.d/iobroker
                                          + file=/usr/local/etc/rc.d/iobroker
                                          + chown root:wheel /usr/local/etc/rc.d/iobroker
                                          + chmod 755 /usr/local/etc/rc.d/iobroker
                                          + sysrc iobroker_enable=YES
                                          iobroker_enable: YES -> YES
                                          + service iobroker start
                                          Before fixing dir permissions...
                                          + echo 'Autostart enabled!'
                                          Autostart enabled!
                                          + echo 'Autostart: rc.d'
                                          AlCalzoneA HomoranH 4 Antworten Letzte Antwort
