  4. [SOLVED] Instal.auf FreeBSD funktioniert nicht.
freenasfreebsdinstaller
74 Beiträge 6 Kommentatoren 10.8k Aufrufe 2 Beobachtet
  • AlCalzoneA AlCalzone
    @mrMuppet Und wenn du iobroker start ausführst?
    mrMuppet
    @AlCalzone
    root@iobroker_v2:~ # cd /opt
    root@iobroker_v2:/opt # cd iobroker
    root@iobroker_v2:/opt/iobroker # iobroker start
    iobroker: Command not found.
    root@iobroker_v2:/opt/iobroker # node iobroker start
    /opt/iobroker/iobroker:2
    sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobro              ker.js $@
    SyntaxError: Unexpected identifier
        at createScript (vm.js:56:10)
        at Object.runInThisContext (vm.js:97:10)
        at Module._compile (module.js:549:28)
        at Object.Module._extensions..js (module.js:586:10)
        at Module.load (module.js:494:32)
        at tryModuleLoad (module.js:453:12)
        at Function.Module._load (module.js:445:3)
        at Module.runMain (module.js:611:10)
        at run (bootstrap_node.js:394:7)
        at startup (bootstrap_node.js:160:9)
    ioBroker auf NUC (Celeron mit Ubuntu-Server)
    Homematic, HMIP, Hue, Unifi, Plex, Nest, Roborock, Google Assistant
      mrMuppet
      Ich habe jetzt einen Weg gefunden: Analog zu dieser Anleitung
      habe ich
      npm install iobroker.js-controller
      npm install iobroker.admin
      von Hand installiert. Danach klappt der
      node iobroker start
      Aber ist das sinnvoll zu vorzugehen? Ich hatte recht viele Warnungen:
      root@iobroker_v2:/opt/iobroker # npm install iobroker.js-controller
      > iobroker.js-controller@1.5.9 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/preinstallCheck.js
      NPM version: 6.9.0
      npm version >= 5: disabling package-lock
      > unix-dgram@0.2.3 install /opt/iobroker/node_modules/unix-dgram
      > node-gyp rebuild
      gmake: Entering directory '/opt/iobroker/node_modules/unix-dgram/build'
        CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
      ../src/unix_dgram.cc:53:13: warning: unused function 'SetNonBlock' [-Wunused-function]
      inline void SetNonBlock(int fd) {
      ../src/unix_dgram.cc:65:13: warning: unused function 'SetCloExec' [-Wunused-function]
      inline void SetCloExec(int fd) {
      2 warnings generated.
        SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
        COPY Release/unix_dgram.node
      gmake: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
      > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
      > node rebuild.js
      > diskusage@0.2.6 install /opt/iobroker/node_modules/diskusage
      > node-gyp rebuild
      gmake: Entering directory '/opt/iobroker/node_modules/diskusage/build'
        CXX(target) Release/obj.target/diskusage/src/main.o
        CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
        SOLINK_MODULE(target) Release/obj.target/diskusage.node
        COPY Release/diskusage.node
      gmake: Leaving directory '/opt/iobroker/node_modules/diskusage/build'
      > iobroker.js-controller@1.5.9 install /opt/iobroker/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      creating conf/iobroker.json
      object system.certificates created
      object system.repositories created
      object system.config created
      object enum.functions created
      object enum.rooms created
      object system.group.user created
      object system.group.administrator created
      object _design/system created
      object system.user.admin created
      host.iobroker_v2 install adapter admin
      object system.meta.uuid created: 4816af3f-b9c0-a627-638c-43a3e3bfa2e0
      npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.admin"
      npm WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
      npm notice created a lockfile as package-lock.json. You should commit this file.
      got /opt/iobroker/node_modules/iobroker.admin/admin
      upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
      upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
      upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
      upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
      host.iobroker_v2 object system.adapter.admin created
      host.iobroker_v2 create instance admin
      host.iobroker_v2 object admin.0.connected created
      host.iobroker_v2 object admin.0 created
      host.iobroker_v2 object admin.0.info created
      host.iobroker_v2 object system.adapter.admin.upload created
      host.iobroker_v2 object system.adapter.admin.0.outputCount created
      host.iobroker_v2 object system.adapter.admin.0.inputCount created
      host.iobroker_v2 object system.adapter.admin.0.uptime created
      host.iobroker_v2 object system.adapter.admin.0.memRss created
      host.iobroker_v2 object system.adapter.admin.0.memHeapTotal created
      host.iobroker_v2 object system.adapter.admin.0.memHeapUsed created
      host.iobroker_v2 object system.adapter.admin.0.cputime created
      host.iobroker_v2 object system.adapter.admin.0.cpu created
      host.iobroker_v2 object system.adapter.admin.0.connected created
      host.iobroker_v2 object system.adapter.admin.0.alive created
      host.iobroker_v2 object system.adapter.admin.0 created
      npm WARN saveError ENOENT: no such file or directory, open '/opt/iobroker/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
      npm WARN iobroker No description
      npm WARN iobroker No repository field.
      npm WARN iobroker No README data
      npm WARN iobroker No license field.
      + iobroker.js-controller@1.5.9
      added 344 packages from 279 contributors and audited 855 packages in 70.532s
      found 27 vulnerabilities (19 low, 8 high)
        run `npm audit fix` to fix them, or `npm audit` for details
      root@iobroker_v2:/opt/iobroker # npm install iobroker.admin
      + iobroker.admin@3.6.2
      removed 177 packages, updated 1 package and audited 2650 packages in 3.835s
      found 64 vulnerabilities (43 low, 21 high)
      • AlCalzoneA Offline
        AlCalzoneA Offline
        AlCalzone
        Auch die Warnungen sind vollkommen normal. Aber manuell per npm nachzuinstallieren, sollte nicht nötig sein. Das Blöde ist, dass keiner von uns FreeBSD zum Testen hat. Da hängen wir maßgeblich vom Feedback ab, daher würde ich dich bitten, hier noch etwas Unterstützung zu leisten.
        node iobroker start ist aber nicht das richtige Kommando. iobroker start sollte funktionieren. Kannst du mal den Inhalt deiner PATH-Variable posten?
        echo "$PATH"
          echo "$PATH"
          mrMuppet
          @AlCalzone sagte in Neue Installation auf FreeBSD/FreeNAS 11.2 funktioniert nicht.:
          echo "$PATH"
          Ich bin froh wenn ich mal was beitragen kann: :-)
          root@iobroker_v2:/ # echo "$PATH"
          /sbin:/bin:/usr/sbin:/usr/bin:/usr/local/sbin:/usr/local/bin:/root/bin
          • M mrMuppet
            echo "$PATH"
            AlCalzoneA Offline
            AlCalzoneA Offline
            AlCalzone
            @mrMuppet sagte in Neue Installation auf FreeBSD/FreeNAS 11.2 funktioniert nicht.:
            /usr/local/bin
            Das ist schon mal gut, da wird nämlich die Executable hingeschrieben. ls -la /usr/local/bin bitte.
            EDIT: Und am besten noch ls -la /opt/iobroker
              mrMuppet
              root@iobroker_v2:/ # ls -la /usr/local/bin
              total 84788
              drwxr-xr-x    2 root  wheel       194 May  7 21:13 .
              drwxr-xr-x   14 root  wheel        14 May  7 21:12 ..
              lrwxr-xr-x    1 root  wheel         6 Apr  4 02:35 2to3 -> 2to3-2
              lrwxr-xr-x    1 root  wheel         8 Apr  2 21:32 2to3-2 -> 2to3-2.7
              -rwxr-xr-x    1 root  wheel       101 Apr  2 03:16 2to3-2.7
              -rwxr-xr-x    1 root  wheel       101 Apr  2 03:17 2to3-3.6
              -r-xr-xr-x    1 root  wheel     20384 Apr  2 03:14 acountry
              -r-xr-xr-x    1 root  wheel   5279360 Apr  2 03:46 addr2line
              -r-xr-xr-x    1 root  wheel     20816 Apr  2 03:14 adig
              -r-xr-xr-x    1 root  wheel     11384 Apr  2 03:14 ahost
              -r-xr-xr-x    2 root  wheel   5309416 Apr  2 03:46 ar
              -r-xr-xr-x    2 root  wheel   6053840 Apr  2 03:46 as
              -rwxr-xr-x    1 root  wheel     24120 Apr  2 08:06 avahi-browse
              lrwxr-xr-x    1 root  wheel        12 Apr  2 08:06 avahi-browse-domains -> avahi-browse
              -rwxr-xr-x    1 root  wheel     17336 Apr  2 08:06 avahi-publish
              lrwxr-xr-x    1 root  wheel        13 Apr  2 08:06 avahi-publish-address -> avahi-publish
              lrwxr-xr-x    1 root  wheel        13 Apr  2 08:06 avahi-publish-service -> avahi-publish
              -rwxr-xr-x    1 root  wheel     14440 Apr  2 08:06 avahi-resolve
              lrwxr-xr-x    1 root  wheel        13 Apr  2 08:06 avahi-resolve-address -> avahi-resolve
              lrwxr-xr-x    1 root  wheel        13 Apr  2 08:06 avahi-resolve-host-name -> avahi-resolve
              -rwxr-xr-x    1 root  wheel     11472 Apr  2 08:06 avahi-set-host-name
              -rwxr-xr-x    1 root  wheel   1157192 Apr  2 03:26 bash
              -r-xr-xr-x    1 root  wheel      6774 Apr  2 03:26 bashbug
              -rwxr-xr-x    4 root  wheel   1052008 Apr 28 07:06 c++8
              -r-xr-xr-x    1 root  wheel   5281696 Apr  2 03:46 c++filt
              -rwxr-xr-x    1 root  wheel     15100 Apr  2 03:20 corelist
              -rwxr-xr-x    1 root  wheel      8168 Apr  2 03:20 cpan
              -rwxr-xr-x    1 root  wheel   1048456 Apr 28 07:06 cpp8
              -rwxr-xr-x    1 root  wheel    192528 Apr  2 03:27 curl
              -r-xr-xr-x    1 root  wheel      7334 Apr  2 03:27 curl-config
              -r-xr-xr-x    1 root  wheel     69576 Feb  7 02:07 cvsps
              -rwxr-xr-x    1 root  wheel    244744 Apr  2 03:14 cvtsudoers
              -rwxr-xr-x    1 root  wheel     91560 Apr  2 03:33 dbus-binding-tool
              -rwxr-xr-x    1 root  wheel     11360 Apr  2 03:31 dbus-cleanup-sockets
              -rwxr-xr-x    1 root  wheel    196096 Apr  2 03:31 dbus-daemon
              -rwxr-xr-x    1 root  wheel     25672 Apr  2 03:31 dbus-launch
              -rwxr-xr-x    1 root  wheel     21640 Apr  2 03:31 dbus-monitor
              -rwxr-xr-x    1 root  wheel     11368 Apr  2 03:31 dbus-run-session
              -rwxr-xr-x    1 root  wheel     22776 Apr  2 03:31 dbus-send
              -rwxr-xr-x    1 root  wheel     18616 Apr  2 03:31 dbus-test-tool
              -rwxr-xr-x    1 root  wheel     10472 Apr  2 03:31 dbus-update-activation-environment
              -rwxr-xr-x    1 root  wheel      7840 Apr  2 03:31 dbus-uuidgen
              -rwxr-xr-x    1 root  wheel     24640 Apr 20 03:25 derb
              -r-xr-xr-x    1 root  wheel   2381144 Apr  2 03:46 dwp
              -r-xr-xr-x    1 root  wheel     37200 Apr  2 03:46 elfedit
              -rwxr-xr-x    1 root  wheel     42056 Apr  2 03:20 enc2xs
              -rwxr-xr-x    1 root  wheel      3078 Apr  2 03:20 encguess
              -rwxr-xr-x    1 root  wheel     40432 Feb  7 02:07 envsubst
              -r-xr-xr-x    1 root  wheel     27720 Feb  7 05:14 funzip
              lrwxr-xr-x    1 root  wheel         4 Apr 28 07:13 g++ -> g++8
              -rwxr-xr-x    4 root  wheel   1052008 Apr 28 07:06 g++8
              -r-xr-xr-x    1 root  wheel      2269 Apr  2 08:02 g-ir-annotation-tool
              -rwxr-xr-x    1 root  wheel    169472 Apr  2 08:02 g-ir-compiler
              -rwxr-xr-x    1 root  wheel     37296 Apr  2 08:02 g-ir-generate
              -rwxr-xr-x    1 root  wheel      8392 Apr  2 08:02 g-ir-inspect
              -r-xr-xr-x    1 root  wheel      2260 Apr  2 08:02 g-ir-scanner
              -rwxr-xr-x    1 root  wheel     16064 Apr  2 03:33 gapplication
              lrwxr-xr-x    1 root  wheel         4 Apr 28 07:13 gcc -> gcc8
              -rwxr-xr-x    2 root  wheel     26160 Apr 28 07:06 gcc-ar8
              -rwxr-xr-x    2 root  wheel     26128 Apr 28 07:06 gcc-nm8
              -rwxr-xr-x    2 root  wheel     26128 Apr 28 07:06 gcc-ranlib8
              -rwxr-xr-x    3 root  wheel   1047912 Apr 28 07:06 gcc8
              -rwxr-xr-x    1 root  wheel    508240 Apr 28 07:06 gcov-dump8
              -rwxr-xr-x    1 root  wheel    532880 Apr 28 07:06 gcov-tool8
              -rwxr-xr-x    1 root  wheel    660880 Apr 28 07:06 gcov8
              -rwxr-xr-x    1 root  wheel     20080 Feb  7 02:13 gdbm_dump
              -rwxr-xr-x    1 root  wheel     22272 Feb  7 02:13 gdbm_load
              -rwxr-xr-x    1 root  wheel     99088 Feb  7 02:13 gdbmtool
              -rwxr-xr-x    1 root  wheel     38584 Apr  2 03:33 gdbus
              -r-xr-xr-x    1 root  wheel      2065 Apr  2 03:33 gdbus-codegen
              -rwxr-xr-x    1 root  wheel     12264 Apr 20 03:25 genbrk
              -rwxr-xr-x    1 root  wheel     10456 Apr 20 03:25 gencfu
              -rwxr-xr-x    1 root  wheel     20232 Apr 20 03:25 gencnval
              -rwxr-xr-x    1 root  wheel     24408 Apr 20 03:25 gendict
              -rwxr-xr-x    1 root  wheel    163800 Apr 20 03:25 genrb
              -rwxr-xr-x    1 root  wheel     40416 Feb  7 02:07 gettext
              -r-xr-xr-x    1 root  wheel      4629 Feb  7 02:07 gettext.sh
              lrwxr-xr-x    1 root  wheel         9 Apr 28 07:13 gfortran -> gfortran8
              -rwxr-xr-x    2 root  wheel   1052008 Apr 28 07:06 gfortran8
              -rwxr-xr-x    1 root  wheel     70360 Apr  2 03:33 gio
              -rwxr-xr-x    1 root  wheel     10248 Apr  2 03:33 gio-querymodules
              -rwxr-xr-x  127 root  wheel   2568208 Apr  2 03:35 git
              -rwxr-xr-x    2 root  wheel    162751 Apr  2 03:35 git-cvsserver
              -r-xr-xr-x    1 root  wheel    156977 Apr  2 03:35 git-p4.py
              -rwxr-xr-x  127 root  wheel   2568208 Apr  2 03:35 git-receive-pack
              -rwxr-xr-x    2 root  wheel   1461608 Apr  2 03:35 git-shell
              -rwxr-xr-x  127 root  wheel   2568208 Apr  2 03:35 git-upload-archive
              -rwxr-xr-x  127 root  wheel   2568208 Apr  2 03:35 git-upload-pack
              -rwxr-xr-x    1 root  wheel     37880 Apr  2 03:33 glib-compile-resources
              -rwxr-xr-x    1 root  wheel     42336 Apr  2 03:33 glib-compile-schemas
              -r-xr-xr-x    1 root  wheel     40933 Apr  2 03:33 glib-genmarshal
              -r-xr-xr-x    1 root  wheel      5381 Apr  2 03:33 glib-gettextize
              -r-xr-xr-x    1 root  wheel     27808 Apr  2 03:33 glib-mkenums
              -r-xr-xr-x    1 root  wheel    221600 Feb  7 02:08 gmake
              -rwxr-xr-x    1 root  wheel      8736 Apr  2 03:33 gobject-query
              -r-xr-xr-x    1 root  wheel   5344720 Apr  2 03:46 gprof
              -rwxr-xr-x    1 root  wheel     15832 Apr  2 03:33 gresource
              -rwxr-xr-x    1 root  wheel     21880 Apr  2 03:33 gsettings
              -rwxr-xr-x    1 root  wheel     20728 Apr  2 03:33 gtester
              -rwxr-xr-x    1 root  wheel     18839 Apr  2 03:33 gtester-report
              -rwxr-xr-x    1 root  wheel     29236 Apr  2 03:20 h2ph
              -rwxr-xr-x    1 root  wheel     60878 Apr  2 03:20 h2xs
              -rwxr-xr-x    1 root  wheel     24912 Feb  7 02:07 iconv
              -r-xr-xr-x    1 root  wheel     22122 Apr 20 03:25 icu-config
              -rwxr-xr-x    1 root  wheel      9048 Apr 20 03:25 icuinfo
              lrwxr-xr-x    1 root  wheel         5 Apr  4 02:35 idle -> idle2
              lrwxr-xr-x    1 root  wheel         7 Apr  2 21:32 idle2 -> idle2.7
              -rwxr-xr-x    1 root  wheel        99 Apr  2 03:16 idle2.7
              -rwxr-xr-x    1 root  wheel        99 Apr  2 03:17 idle3.6
              -rwxr-xr-x    1 root  wheel     11496 Feb  7 02:07 indexinfo
              -rwxr-xr-x    1 root  wheel      4299 Apr  2 03:20 instmodsh
              lrwxr-xr-x    1 root  wheel        22 May  7 21:13 iob -> /opt/iobroker/iobroker
              lrwxr-xr-x    1 root  wheel        22 May  7 21:13 iobroker -> /opt/iobroker/iobroker
              -rwxr-xr-x    1 root  wheel      4391 Apr  2 03:20 json_pp
              -r-xr-xr-x    4 root  wheel  11461040 Apr  2 03:46 ld
              -r-xr-xr-x    4 root  wheel  11461040 Apr  2 03:46 ld.bfd
              -r-xr-xr-x    2 root  wheel   4478752 Apr  2 03:46 ld.gold
              -rwxr-xr-x    1 root  wheel     15787 Apr  2 03:20 libnetcfg
              -rwxr-xr-x    1 root  wheel     53536 Apr 20 03:25 makeconv
              -rwxr-xr-x    1 root  wheel     40424 Feb  7 02:07 ngettext
              -r-xr-xr-x    2 root  wheel   5291408 Apr  2 03:46 nm
              -rwxr-xr-x    1 root  wheel  22650048 Apr 20 04:06 node
              lrwxr-xr-x    1 root  wheel        38 Mar  7 16:09 npm -> ../lib/node_modules/npm/bin/npm-cli.js
              lrwxr-xr-x    1 root  wheel        38 Mar  7 16:09 npx -> ../lib/node_modules/npm/bin/npx-cli.js
              -r-xr-xr-x    2 root  wheel   5421952 Apr  2 03:46 objcopy
              -r-xr-xr-x    2 root  wheel  18191336 Apr  2 03:46 objdump
              -r-xr-xr-x    1 root  wheel      2367 Apr  2 03:17 pcre-config
              -rwxr-xr-x    1 root  wheel     38144 Apr  2 03:17 pcregrep
              -rwxr-xr-x    1 root  wheel    110424 Apr  2 03:17 pcretest
              -rwxr-xr-x    1 root  wheel      7800 Apr  2 03:21 perl
              lrwxr-xr-x    1 root  wheel         4 Apr  2 03:21 perl5 -> perl
              lrwxr-xr-x    1 root  wheel         4 Apr  2 03:21 perl5.28.1 -> perl
              -rwxr-xr-x    2 root  wheel     46374 Apr  2 03:20 perlbug
              -rwxr-xr-x    1 root  wheel       274 Apr  2 03:20 perldoc
              -rwxr-xr-x    1 root  wheel     10831 Apr  2 03:20 perlivp
              -rwxr-xr-x    2 root  wheel     46374 Apr  2 03:20 perlthanks
              -rwxr-xr-x    1 root  wheel      8369 Apr  2 03:20 piconv
              -rwxr-xr-x    1 root  wheel     45624 Apr 20 03:25 pkgdata
              -rwxr-xr-x    1 root  wheel      4545 Apr  2 03:20 pl2pm
              -rwxr-xr-x    1 root  wheel      4146 Apr  2 03:20 pod2html
              -rwxr-xr-x    1 root  wheel     15225 Apr  2 03:20 pod2man
              -rwxr-xr-x    1 root  wheel     11122 Apr  2 03:20 pod2text
              -rwxr-xr-x    1 root  wheel      3954 Apr  2 03:20 pod2usage
              -rwxr-xr-x    1 root  wheel      3664 Apr  2 03:20 podchecker
              -rwxr-xr-x    1 root  wheel      2533 Apr  2 03:20 podselect
              -rwxr-xr-x    1 root  wheel     13667 Apr  2 03:20 prove
              -rwxr-xr-x    1 root  wheel      3561 Apr  2 03:20 ptar
              -rwxr-xr-x    1 root  wheel      2640 Apr  2 03:20 ptardiff
              -rwxr-xr-x    1 root  wheel      4404 Apr  2 03:20 ptargrep
              lrwxr-xr-x    1 root  wheel         6 Apr  4 02:35 pydoc -> pydoc2
              lrwxr-xr-x    1 root  wheel         8 Apr  2 21:32 pydoc2 -> pydoc2.7
              -rwxr-xr-x    1 root  wheel        84 Apr  2 03:16 pydoc2.7
              -rwxr-xr-x    1 root  wheel        84 Apr  2 03:17 pydoc3.6
              lrwxr-xr-x    1 root  wheel         7 Apr  4 02:35 python -> python2
              lrwxr-xr-x    1 root  wheel        14 Apr  4 02:35 python-config -> python2-config
              lrwxr-xr-x    1 root  wheel         9 Apr  2 21:32 python2 -> python2.7
              lrwxr-xr-x    1 root  wheel        16 Apr  2 21:32 python2-config -> python2.7-config
              -r-xr-xr-x    1 root  wheel      5600 Apr  2 03:15 python2.7
              -r-xr-xr-x    1 root  wheel      1769 Apr  2 03:16 python2.7-config
              -r-xr-xr-x    2 root  wheel      7304 Apr  2 03:17 python3.6
              lrwxr-xr-x    1 root  wheel        17 Apr  2 03:17 python3.6-config -> python3.6m-config
              -r-xr-xr-x    2 root  wheel      7304 Apr  2 03:17 python3.6m
              -r-xr-xr-x    1 root  wheel      3120 Apr  2 03:17 python3.6m-config
              -rwxr-xr-x    1 root  wheel       441 Apr  2 03:17 pyvenv-3.6
              -r-xr-xr-x    2 root  wheel   5309432 Apr  2 03:46 ranlib
              lrwxr-xr-x    1 root  wheel         4 Apr  2 03:26 rbash -> bash
              -r-xr-xr-x    2 root  wheel    633248 Apr  2 03:46 readelf
              -rwxr-xr-x    1 root  wheel      9988 Apr  2 03:20 shasum
              -r-xr-xr-x    1 root  wheel   5280816 Apr  2 03:46 size
              -rwxr-xr-x    1 root  wheel     19162 Apr  2 03:20 splain
              -r-xr-xr-x    1 root  wheel   5280480 Apr  2 03:46 strings
              -r-xr-xr-x    2 root  wheel   5421968 Apr  2 03:46 strip
              -rwsr-xr-x    1 root  wheel    128872 Apr  2 03:14 sudo
              lrwxr-xr-x    1 root  wheel         4 Apr  2 03:14 sudoedit -> sudo
              -rwxr-xr-x    1 root  wheel     57376 Apr  2 03:14 sudoreplay
              -rwxr-xr-x    1 root  wheel     49504 Apr 20 03:25 uconv
              -r-xr-xr-x    1 root  wheel    154560 Feb  7 05:14 unzip
              -r-xr-xr-x    1 root  wheel     70304 Feb  7 05:14 unzipsfx
              -rwxr-xr-x    4 root  wheel   1052008 Apr 28 07:06 x86_64-portbld-freebsd11.2-c++8
              -rwxr-xr-x    4 root  wheel   1052008 Apr 28 07:06 x86_64-portbld-freebsd11.2-g++8
              -rwxr-xr-x    3 root  wheel   1047912 Apr 28 07:06 x86_64-portbld-freebsd11.2-gcc-8.3.0
              -rwxr-xr-x    2 root  wheel     26160 Apr 28 07:06 x86_64-portbld-freebsd11.2-gcc-ar8
              -rwxr-xr-x    2 root  wheel     26128 Apr 28 07:06 x86_64-portbld-freebsd11.2-gcc-nm8
              -rwxr-xr-x    2 root  wheel     26128 Apr 28 07:06 x86_64-portbld-freebsd11.2-gcc-ranlib8
              -rwxr-xr-x    3 root  wheel   1047912 Apr 28 07:06 x86_64-portbld-freebsd11.2-gcc8
              -rwxr-xr-x    2 root  wheel   1052008 Apr 28 07:06 x86_64-portbld-freebsd11.2-gfortran8
              -r-xr-xr-x    1 root  wheel      1735 Apr  2 03:15 xml2-config
              -rwxr-xr-x    1 root  wheel     15984 Apr  2 03:15 xmlcatalog
              -rwxr-xr-x    1 root  wheel     61384 Apr  2 03:15 xmllint
              -rwxr-xr-x    1 root  wheel     28480 Feb  7 02:07 xmlwf
              -rwxr-xr-x    1 root  wheel      5176 Apr  2 03:20 xsubpp
              -rwxr-xr-x    1 root  wheel     48509 Apr  2 03:20 zipdetails
              -r-xr-xr-x    1 root  wheel      2953 Feb  7 05:14 zipgrep
              lrwxr-xr-x    1 root  wheel         5 Feb  7 05:14 zipinfo -> unzip
                mrMuppet
                root@iobroker_v2:/ # ls -la /opt/iobroker
                total 134
                drwxr-xr-x    5 root  wheel     12 May 21 16:40 .
                drwxr-xr-x    3 root  wheel      3 May  7 21:12 ..
                -rw-r--r--    1 root  wheel     19 May 21 16:38 .npmrc
                -rwxrwxrwx    1 root  wheel    129 May  7 21:13 INSTALLER_INFO.txt
                -rwxr-xr-x    1 root  wheel    102 May  7 21:13 iobroker
                drwxr-xr-x    4 root  wheel      9 May 21 16:41 iobroker-data
                drwxr-xr-x    2 root  wheel      3 May 21 16:40 log
                drwxr-xr-x  306 root  wheel    306 May 21 16:39 node_modules
                -rw-r--r--    1 root  wheel  94547 May 21 16:39 package-lock.json
                -rw-rw-rw-    1 root  wheel     70 May 21 16:40 package.json
                -rw-r--r--    1 root  wheel   5868 May 21 16:40 reinstall.js
                • M mrMuppet
                  total 84788
                  AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  Danke, das sieht soweit alles gut aus.
                  Kannst du bitte mal zum Testen die Executable bearbeiten:
                  nano /opt/iobroker/iobroker
                  Und die erste Zeile ändern zu
                  #!/usr/local/bin/bash
                  Danach funktioniert iobroker start hoffentlich
                    mrMuppet
                    @AlCalzone
                    root@iobroker_v2:/ # iobroker start
                    Starting iobroker controller daemon...
                    iobroker controller daemon failed to start:  Failed to write pidfile (EACCES)
                    Error: Failed to write pidfile (EACCES)
                    • M mrMuppet
                      @AlCalzone
                      AlCalzoneA Offline
                      AlCalzoneA Offline
                      AlCalzone
                      @mrMuppet Schon besser. Jetzt stimmen nur die Rechte nicht mehr, weil du als root die Module installiert hast 😆
                      Ich passe mal den Installer an, dann darfst du wieder testen. Dauert ein paar Minuten, kannst ja schon mal das System neu aufsetzen.
                        mrMuppet
                        Ok. Wird gemacht. Ich installiere schon mal die Pakete wie oben beschrieben.
                          AlCalzoneA Offline
                          AlCalzone
                          Ok, neue Version ist zum Testen online. Bis sie gemerged ist, kannst du diese per
                          curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/freebsd-fix/installer.sh | bash -
                          installieren.
                            installieren.
                            mrMuppet
                            @AlCalzone Super! Danke. Ich melde mich sobald ich soweit bin. Aktuell hänge ich bei Paket 4/38 ... dauert also noch ... (vielleicht 30 min.?)
                            • M mrMuppet
                              AlCalzoneA Offline
                              AlCalzoneA Offline
                              AlCalzone
                              @mrMuppet Prima, kein Stress...
                                mrMuppet
                                Das war es noch nicht ganz:
                                root@iobroker_v2:~ # curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/freebsd-fix/installer.sh | bash -
                                    Welcome to the ioBroker installer!
                                    Installer version: 2019-05-21
                                    You might need to enter your password a couple of times.
                                    Installing prerequisites (1/4)
                                Installed sudo
                                Installed unzip
                                Installed avahi-libdns
                                Installed nss_mdns
                                Installed gcc
                                dbus_enable:  -> YES
                                avahi_daemon_enable:  -> YES
                                Starting dbus.
                                Starting avahi-daemon.
                                    Creating ioBroker user and directory (2/4)
                                tty:*:4
                                Directory /opt/iobroker created
                                    Installing ioBroker (3/4)
                                ../src/serialport.cpp:95:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
                                  data->callback.Call(2, argv);
                                ../../nan/nan.h:1739:3: note: 'Call' has been explicitly marked deprecated here
                                  NAN_DEPRECATED inline v8::Local<v8::Value>
                                ../../nan/nan.h:104:40: note: expanded from macro 'NAN_DEPRECATED'
                                # define NAN_DEPRECATED __attribute__((deprecated))
                                ../src/serialport.cpp:150:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
                                  data->callback.Call(1, argv);
                                ../src/serialport.cpp:188:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
                                ../src/serialport.cpp:231:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
                                ../src/serialport.cpp:285:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
                                ../src/serialport.cpp:336:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
                                ../src/serialport.cpp:383:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
                                ../src/serialport.cpp:424:18: warning: 'Call' is deprecated [-Wdeprecated-declarations]
                                8 warnings generated.
                                ../src/serialport_unix.cpp:384:20: warning: variable 'outbaud' is uninitialized when used here
                                      [-Wuninitialized]
                                  data->baudRate = outbaud;
                                ../src/serialport_unix.cpp:369:14: note: initialize the variable 'outbaud' to silence this
                                      warning
                                  int outbaud;
                                              = 0
                                1 warning generated.
                                ../src/poller.cpp:69:17: warning: 'Call' is deprecated [-Wdeprecated-declarations]
                                  obj->callback.Call(2, argv);
                                    Finalizing installation (4/4)
                                Enabling autostart...
                                iobroker_enable:  -> YES
                                platform: Undefined variable.
                                Autostart enabled!
                                root@iobroker_v2:~ # iobroker start
                                • M mrMuppet
                                  Installed sudo
                                  Installed unzip
                                  Installed nss_mdns
                                  Installed gcc
                                  dbus_enable:  -> YES
                                  Starting dbus.
                                  tty:*:4
                                        [-Wuninitialized]
                                        warning
                                    int outbaud;
                                                = 0
                                  Autostart enabled!
                                  AlCalzoneA Offline
                                  AlCalzoneA Offline
                                  AlCalzone
                                  @mrMuppet Ok gib mir ein paar Minuten
                                    AlCalzoneA Offline
                                    AlCalzone
                                    EACCES
                                    Was sagt ls -la /opt/iobroker/node_modules/iobroker.js-controller/lib ?
                                      AlCalzoneA Offline
                                      AlCalzone
                                      Kann es sein, dass ioBroker nach der Installation bereits läuft?
                                        EACCES
                                        mrMuppet
                                        Läuft noch nicht.
                                        root@iobroker_v2:~ # ls -la /opt/iobroker/node_modules/iobroker.js-controller/lib
                                        total 382
                                        drwxr-xr-x  9 root  wheel      28 May 21 18:05 .
                                        drwxr-xr-x  6 root  wheel      17 May 21 18:06 ..
                                        -rw-r--r--  1 root  wheel  225379 Oct 26  1985 adapter.js
                                        -rw-r--r--  1 root  wheel    2012 Oct 26  1985 dbdump.js
                                        -rw-r--r--  1 root  wheel    1828 Oct 26  1985 defaultObjs.js
                                        drwxr-xr-x  2 root  wheel       3 May 21 18:05 img
                                        -rw-r--r--  1 root  wheel    9114 Oct 26  1985 letsencrypt.js
                                        -rw-r--r--  1 root  wheel   26624 Oct 26  1985 letsencryptStore.js
                                        -rw-r--r--  1 root  wheel   11236 Oct 26  1985 logger.js
                                        -rw-r--r--  1 root  wheel    7177 Oct 26  1985 multihostClient.js
                                        -rw-r--r--  1 root  wheel    9174 Oct 26  1985 multihostServer.js
                                        drwxr-xr-x  2 root  wheel       5 May 21 18:05 objects
                                        -rw-r--r--  1 root  wheel     531 Oct 26  1985 objects.js
                                        -rw-r--r--  1 root  wheel    2644 Oct 26  1985 password.js
                                        -rw-r--r--  1 root  wheel    4544 Oct 26  1985 preinstall_check.js
                                        -rw-r--r--  1 root  wheel    1755 Oct 26  1985 renewal.conf.tpl
                                        -rw-r--r--  1 root  wheel    6026 Oct 26  1985 restart.js
                                        drwxr-xr-x  2 root  wheel       3 May 21 18:05 scripts
                                        -rw-r--r--  1 root  wheel    1809 Oct 26  1985 session.js
                                        drwxr-xr-x  2 root  wheel      14 May 21 18:05 setup
                                        -rw-r--r--  1 root  wheel  154618 Oct 26  1985 setup.js
                                        drwxr-xr-x  2 root  wheel       5 May 21 18:05 states
                                        -rw-r--r--  1 root  wheel     523 Oct 26  1985 states.js
                                        -rw-r--r--  1 root  wheel   47344 Oct 26  1985 tools.js
                                        -rw-r--r--  1 root  wheel    3808 Oct 26  1985 uploadFiles.js
                                        drwxr-xr-x  2 root  wheel       3 May 21 18:05 vis
                                        drwxr-xr-x  3 root  wheel       3 May 21 18:05 www
                                        -rw-r--r--  1 root  wheel   13190 Oct 26  1985 zipFiles.js
                                          AlCalzoneA Offline
                                          AlCalzone
                                          Hmm, da werden die Berechtigungen nicht richtig gesetzt... Evtl hat das mit der Meldung oben zu tun "unknown variable platform". Ich hab mal den Debug-Mode aktiviert, um (hoffentlich) zu sehen was los ist, bitte nochmal installieren (ohne System neu aufsetzen):
                                          rm -rf /opt/iobroker
