  4. [Aufruf] Test Shelly Adapter
shellyadapter
717 Beiträge 81 Kommentatoren 263.1k Aufrufe 30 Beobachtet
    Merowinger
    schrieb am zuletzt editiert von Merowinger
    #373
    kleines Problem mit den Jalousien?
    2019-05-18 14:19:43.798 error Error in function dp.mqtt.mqtt_publish_funct for stateSHSW-21#5B2AFA#1.Shutter.state
    shelly.0 2019-05-18 14:19:43.798 error Error in function dp.mqtt.mqtt_publish_funct for stateSHSW-21#5B2AFA#1.online
    das hier sieht auch nicht so gut aus...
    host.iobroker 2019-05-18 14:25:04.775 info Restart adapter system.adapter.shelly.0 because enabled
    host.iobroker 2019-05-18 14:25:04.775 error instance system.adapter.shelly.0 terminated with code 0 (OK)
    Caught 2019-05-18 14:25:04.775 error by controller[0]: at process._tickCallback (internal/process/next_tick.js:181:9)
    Caught 2019-05-18 14:25:04.775 error by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:136:11)
    Caught 2019-05-18 14:25:04.775 error by controller[0]: at uncork (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:81:10)
    Caught 2019-05-18 14:25:04.775 error by controller[0]: at Socket.Writable.uncork (_stream_writable.js:312:7)
    Caught 2019-05-18 14:25:04.775 error by controller[0]: at clearBuffer (_stream_writable.js:500:5)
    Caught 2019-05-18 14:25:04.775 error by controller[0]: at doWrite (_stream_writable.js:394:12)
    Caught 2019-05-18 14:25:04.775 error by controller[0]: at Socket._writev (net.js:782:8)
    Caught 2019-05-18 14:25:04.775 error by controller[0]: at Socket._writeGeneric (net.js:733:18)
    Caught 2019-05-18 14:25:04.775 error by controller[0]: Error: This socket is closed
    shelly.0 2019-05-18 14:25:04.763 info Closing Adapter
    shelly.0 2019-05-18 14:25:04.763 error at process._tickCallback (internal/process/next_tick.js:181:9)
    shelly.0 2019-05-18 14:25:04.763 error at _combinedTickCallback (internal/process/next_tick.js:136:11)
    shelly.0 2019-05-18 14:25:04.763 error at uncork (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:81:10)
    shelly.0 2019-05-18 14:25:04.763 error at Socket.Writable.uncork (_stream_writable.js:312:7)
    shelly.0 2019-05-18 14:25:04.763 error at clearBuffer (_stream_writable.js:500:5)
    shelly.0 2019-05-18 14:25:04.763 error at doWrite (_stream_writable.js:394:12)
    shelly.0 2019-05-18 14:25:04.763 error at Socket._writev (net.js:782:8)
    shelly.0 2019-05-18 14:25:04.763 error at Socket._writeGeneric (net.js:733:18)
    shelly.0 2019-05-18 14:25:04.763 error Error: This socket is closed
    shelly.0 2019-05-18 14:25:04.762 error uncaught exception: This socket is closed
    shelly.0 2019-05-18 14:25:04.760 info Destroy 192.168.178.171 (shelly4pro-4A44FB)
    shelly.0 2019-05-18 14:25:04.760 error Device 192.168.178.171 (shelly4pro-4A44FB) unknown.
    StuebiS 1 Antwort Letzte Antwort
    • M Merowinger
      StuebiS Offline
      StuebiS Offline
      Stuebi
      #374
      @Merowinger sagte in [Aufruf] Test Shelly Adapter:
      danke, Fehler habe ich eben behoben (Version bleibt bei 3.0.0, muss nur nochmals über die Github Katze geladen werden).
      Fahren die Rollläden richtig rauf u. runter?
      ioBroker auf Synology DS216+II im Docker Container
      • StuebiS Stuebi
        Merowinger
        #375
        @Stuebi oh nein ;-) shelly.0 2019-05-18 14:42:12.177 error Device 192.168.178.171 (shelly4pro-YYYYYY) unknown.
        in einem shutter ist als protocol mqtt drin und hoch und runter gehen... denke wenn einer geht, sollten es alle tun ;-)
        StuebiS 2 Antworten Letzte Antwort
        • M Merowinger
          StuebiS Offline
          StuebiS Offline
          Stuebi
          #376
          @Merowinger , den Shelly 4 Pro habe ich nicht eingebunden, da ich diesen wie den Plug S auch nicht besitze. Ist immer schwierig blind zu programmieren.
          Ich werde es mal versuchen und Dir bescheid geben :-)
            Merowinger
            #377
            Dann vermute ich mal das du die HT auch nicht hast?
            hmm oder moment, die melden sich ja nur alle 6h
            • eric2905E Offline
              eric2905E Offline
              eric2905
              #378
              Hab mir die v3.0.0 jetzt auch mal installiert und derzeit mit einem Shelly1 im Einsatz.
              Jetzt klappt es auch mit dem Subnetz-Übergriff mit mqtt und ich muss keinen weiteren ioBroker-Host im IoT-VLAN betreiben.
              Bis jetzt keine Fehler, o.ä. festgestellt.
              Gruß,
              Eric
              • M Merowinger
                StuebiS Offline
                StuebiS Offline
                Stuebi
                #379
                @Merowinger , die HT sind drin. Musst Du einfach einmal aufmachen und den Knopf drücken. Dann melden die sich an.
                • M Merowinger
                  StuebiS Offline
                  StuebiS Offline
                  Stuebi
                  schrieb am zuletzt editiert von Stuebi
                  #380
                  @Merowinger , Shelly 4 Pro eben (blind) eingebunden. Ich hoffe es passt. Also wenn du einmal testen könntest wäre das klasse.
                  Bitte dafür nochmals über die GitHub Katze die Version 3.0.0. laden
                  Noch eine Frage heißen die nachher in ioBroker shelly.0.SHSW-4#xxxxxx#1 ?
                  • eric2905E eric2905
                    Gruß,
                    Eric
                    StuebiS Offline
                    StuebiS Offline
                    Stuebi
                    #381
                    @eric2905 , großartig! Genau für solche Fälle habe ich MQTT eingebunden.
                    VG und Danke fürs Testen
                      Merowinger
                      #382
                      im alten Adapter heißen sie
                      Device SHSW-44#BugsBunny#1
                      im neuen
                      Device SHSW-4#DonaldDuck#1
                      • M Merowinger
                        im neuen
                        StuebiS Offline
                        StuebiS Offline
                        Stuebi
                        #383
                        im neuen
                        Das ändere ich noch auf 44. Muss jetzt einmal vor die Tür mit meiner Frau. Kleiner Spaziergang😏
                        • M Merowinger
                          im neuen
                          StuebiS Offline
                          StuebiS Offline
                          Stuebi
                          #384
                          @Merowinger , die 4 habe ich jetzt auf 44 geändert. Nur das da jetzt DonaldDuck statt BugsBunny als Name steht ist nicht mein Verdienst ;-)
                          Kannst bitte nochmals testen. Die Version ist weiterhin 3.0.0
                          Stübi
                            Merowinger
                            #385
                            Jippie, es taucht alles auf. Nur irgendwie bin ich noch zu deppert die plug s auch zu schalten.
                            Der Link hier
                            shelly.0.SHPLG-1#s,MickeyMouse#1.Relay0.Switch
                            scheint nicht zu schalten
                            ja okay, auch wenn ich die Kontrollkiste aktiviere. Es schaltet nicht.
                            • M Merowinger
                              Der Link hier
                              StuebiS Offline
                              StuebiS Offline
                              Stuebi
                              #386
                              Schaltet der Shelly Plug S in Coap und MQTT nicht?
                              • StuebiS Offline
                                StuebiS Offline
                                Stuebi
                                #387
                                Hat jemand von Euch den Shelly Sense im Einsatz und kann die neue Adapter Version (3.0.0) mit MQTT Unterstützung testen?
                                • A Apropo
                                  Also über coap lässt sich die Steckdose zwar einschalten, aber der Wert bleibt auf false stehen. Wenn ich den Haken für true dann nochmal setze bleibt das true zwar stehen, aber in rot und ich kann die Dose nicht mehr ausschalten.
                                  Mit mqtt hab ich Fehlermeldungen im log die ich nicht zuordnen kann:
                                  host.iobrokervm	2019-05-18 12:03:37.312	error	instance system.adapter.shelly.0 terminated with code 0 (OK)
                                  host.iobrokervm	2019-05-18 12:03:37.311	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:181:9)
                                  host.iobrokervm	2019-05-18 12:03:37.311	error	Caught by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:136:11)
                                  host.iobrokervm	2019-05-18 12:03:37.311	error	Caught by controller[0]: at uncork (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:81:10)
                                  host.iobrokervm	2019-05-18 12:03:37.311	error	Caught by controller[0]: at Socket.Writable.uncork (_stream_writable.js:312:7)
                                  host.iobrokervm	2019-05-18 12:03:37.311	error	Caught by controller[0]: at clearBuffer (_stream_writable.js:500:5)
                                  host.iobrokervm	2019-05-18 12:03:37.311	error	Caught by controller[0]: at doWrite (_stream_writable.js:394:12)
                                  host.iobrokervm	2019-05-18 12:03:37.311	error	Caught by controller[0]: at Socket._writev (net.js:782:8)
                                  host.iobrokervm	2019-05-18 12:03:37.310	error	Caught by controller[0]: at Socket._writeGeneric (net.js:733:18)
                                  host.iobrokervm	2019-05-18 12:03:37.307	error	Caught by controller[0]: Error: This socket is closed
                                  shelly.0	2019-05-18 12:03:12.779	info	starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.14.0
                                  host.iobrokervm	2019-05-18 12:03:11.126	info	instance system.adapter.shelly.0 started with pid 3643
                                  host.iobrokervm	2019-05-18 12:02:41.110	info	Restart adapter system.adapter.shelly.0 because enabled
                                  jeg
                                  #388
                                  Wie schon @Apropo geschrieben hatte, ist es auch bei mir. Ich kann zwar schalten, aber der Wert bleibt bleibt immer bei False stehen. Auch wenn ich ihn gerade eingeschaltet habe. Wenn ich ihn wieder ausschalten will, dann kann ich nicht die Checkbox betätigen, weil diese ja nicht gesetzt ist. Wenn ich allerdings den Commit-Haken anklicke, dann wird der auch wieder ausgeschalten. Als würde der Shelly Plug S keine Rückmeldung für den Switch bekommen. Die Leistungsanzeige kommt aber.
                                  • J jeg
                                    StuebiS Offline
                                    StuebiS Offline
                                    Stuebi
                                    #389
                                    @jeg sagte in [Aufruf] Test Shelly Adapter:
                                    nutzt du CoAP oder MQTT ? Das wäre noch wichtig zu wissen. Und wenn Du MQTT eingestellt hast, kannst Du einmal den Shelly Adapter in den Debug Modus unter Instanzen wechseln.
                                    Jetzt die Einträge für den Plug S, wo so etwas mit Subscribe und Publish steht, mir per Email an thorsten @ stueben.de schicken. Das würde helfen
                                    • StuebiS Stuebi
                                      jeg
                                      #390
                                      @Stuebi Ich benutze CoAP. Habe MQTT noch nie aktiviert. Wie gesagt - neue Materie für mich ☹ .
                                      • J jeg
                                        StuebiS Offline
                                        StuebiS Offline
                                        Stuebi
                                        #391
                                        @jeg , okay, ich habe jetzt mal etwas eingebaut, damit ich sehe welche Befehle CoAP Kommando beim schalten gesendet werden.
                                        Kannst du bitte, die neue Version (immer noch 3.0.0) laden und starten. Nun in der Shelly App den Plug S mehrfach an und aus schalten. Im Log benötige ich die Einträge die mit CoAP Info : beginnnen
                                        • StuebiS Stuebi
                                          jeg
                                          #392
                                          Ich hoffe, ich habe das so gemacht, wie du das wolltest.
                                          2019-05-18 20:33:58.894 - info: shelly.0 CoAP Info : [[0,111,0],[0,112,1]]
                                          2019-05-18 20:34:00.201 - info: shelly.0 CoAP Info : [[0,111,0],[0,112,0]]
                                          2019-05-18 20:34:01.191 - info: shelly.0 CoAP Info : [[0,111,0],[0,112,1]]
                                          2019-05-18 20:34:02.126 - info: shelly.0 CoAP Info : [[0,111,0],[0,112,0]]
                                          2019-05-18 20:34:03.739 - info: shelly.0 CoAP Info : [[0,111,0],[0,112,1]]
                                          2019-05-18 20:34:04.590 - info: shelly.0 CoAP Info : [[0,111,0],[0,112,0]]
