Online Version
{ "_id": "system.adapter.web", "type": "adapter", "common": { "name": "web", "version": "0.4.0", "title": "ioBroker simple web Adapter", "desc": { "en": "opens a webserver for the ioBroker", "de": "Stellt webserver für 'ioBroker Adapter' zur Verfügung", "ru": "Запускает веб сервер для 'ioBroker драйверов'" }, "mode": "daemon", "platform": "Javascript/Node.js", "loglevel": "info", "icon": "web.png", "readme": "https://github.com/ioBroker/ioBroker.web/blob/master/README.md", "enabled": true, "keywords": [ "web", "server", "www", "express" ], "extIcon": "https://raw.githubusercontent.com/ioBroker/ioBroker.web/master/admin/web.png", "type": "visualisation", "installedVersion": "0.4.0" }, "native": { "port": 8082, "auth": false, "secure": false, "bind": "0.0.0.0", "cache": false, "socketio": "", "simpleapi": false, "defaultUser": "admin", "ttl": 3600, "secret": "86ce20d98ed710b3abc957d57acc65a5efdba4784cddaca4" } } -
` > Hallo Bluefox,
das Verhalten kann ich bestätigen. `
Kannst du bitte das ausführen in /opt/iobroker
iobroker object get system.adapter.web --prettyund Ergebniss mir schicken. `
Sorry habe ein Fehler gemacht.Bitte:
iobroker object get system.adapter.web.0 --prettyaufrufen.
{ "_id": "system.adapter.web.0", "type": "instance", "common": { "name": "web", "version": "0.4.0", "title": "ioBroker simple web Adapter", "desc": { "en": "opens a webserver for the ioBroker", "de": "Stellt webserver für 'ioBroker Adapter' zur Verfügung", "ru": "Запускает веб сервер для 'ioBroker драйверов'" }, "mode": "daemon", "platform": "Javascript/Node.js", "loglevel": "debug", "icon": "web.png", "readme": "https://github.com/ioBroker/ioBroker.web/blob/master/README.md", "enabled": true, "keywords": [ "web", "server", "www", "express" ], "extIcon": "https://raw.githubusercontent.com/ioBroker/ioBroker.web/master/admin/web.png", "type": "visualisation", "installedVersion": "0.4.0", "host": "Christians-MacBook-Pro.local", "schedule": "" }, "native": { "port": "8082", "auth": false, "secure": false, "bind": "192.168.1.90", "cache": false, "socketio": "", "simpleapi": false, "defaultUser": "admin", "ttl": 3600, "certPublic": "", "certPrivate": "" } } -
Ich habe 3 Systeme ausprobiert. Ich kann es nicht reproduzieren….
Seid ihr sicher, dass mindestens das ausgeführt habt?
iobroker stop npm install https://github.com/ioBroker/ioBroker.js-controller/tarball/master --production npm install https://github.com/ioBroker/ioBroker.admin/tarball/master --production npm install https://github.com/ioBroker/ioBroker.web/tarball/master --production cd node_modules/iobroker.web npm install https://github.com/ioBroker/ioBroker.simple-api/tarball/master --production npm install https://github.com/ioBroker/ioBroker.socketio/tarball/master --production cd .. cd .. iobroker upload web sudo rebootVielleicht noch das hier:
iobroker chmod 777 vis/* iobroker chown admin vis/*und Konfiguration von Web-Instanz aufmachen was verändern/zurückändern und speichern.
also ich habe folgendes gemacht: (bin Mac User)
mkdir /Users/christian/DEVELOPMENT cd /Users/christian/DEVELOPMENT npm install https://github.com/ioBroker/ioBroker.js-controller/tarball/master npm install https://github.com/ioBroker/ioBroker.admin/tarball/master npm install https://github.com/ioBroker/ioBroker.web/tarball/master npm install https://github.com/ioBroker/ioBroker.simple-api/tarball/master npm install https://github.com/ioBroker/ioBroker.vis/tarball/master cd node_modules/iobroker.web npm install https://github.com/ioBroker/ioBroker.simple-api/tarball/master npm install https://github.com/ioBroker/ioBroker.socketio/tarball/master cd .. cd .. ln -s ./node_modules/iobroker.js-controller/iobroker iobroker ./iobroker upload web ./iobroker upload vis ./iobroker upload simple-api cd node_modules npm install iobroker.occ cd .. ./iobroker startDanach in der Weboberfläche vis und occ hinzugefügt.
Dann kamen die Fehler.
Aber was noch wichtiger ist, ich habe eine komplette Neuinstallation gemacht.
Ev. verhält sich das System anders, wenn es auf eine bestehende draufgestülpt wird,
das muss ich erst ausprobieren.
Hallo Bluefox,
Bin leider heute beruflich in München.
Kann das also erst morgen Abend ausführen.
Herzliche Grüße
Bernhard
Auf meinem Mac (Entwicklung) hatte ich nicht das Problem.
Auf meinem RPi allerdings auch. Liegt definitiv an den Rechten (getraced bis hin zum checkFileRights). Wie von bluefox vorgeschlagen, mit
iobroker chmod 777 vis/* iobroker chown admin vis/*kann ich vis dann auch wieder auf meinem RPi aufrufen.
Brauchen wir für die neue Version einen Migrationsleitfaden :-)?
LG
Siedi
das muss ich erst ausprobieren. `
Habe genau diese Befehle jetzt auf eine Machine auf terminal.com ausgeführt.Mit kleiner Abweichung:
mkdir /opt/iobroker cd /opt/iobroker npm install https://github.com/ioBroker/ioBroker.js-controller/tarball/master --production npm install https://github.com/ioBroker/ioBroker.admin/tarball/master --production npm install https://github.com/ioBroker/ioBroker.web/tarball/master --production npm install https://github.com/ioBroker/ioBroker.vis/tarball/master --production cd node_modules/iobroker.web npm install https://github.com/ioBroker/ioBroker.simple-api/tarball/master --production npm install https://github.com/ioBroker/ioBroker.socketio/tarball/master --production cd .. cd .. ln -s ./node_modules/iobroker.js-controller/iobroker iobroker chmod 777 * -R echo Man muss Verzeichnis nicht ändern - cd node_modules npm install iobroker.occ --production echo Man muss Verzeichnis nicht ändern - cd .. ./iobroker startUnd dann lief es sofort.
Welche? -
LG
Siedi `
Halleluja. Mindestens bei jemandem geht. Sonst verstehe ich nicht die Welt.Eigentlich es soll ohne "chmod/chown" gehen. Aber…
Ich habe 3 mal windows (neu und update und von von "versteckt") ausprobiert. Alles geht
Ein mal update auf debian (odroid) geht.
Ein mal neu auf debian terminal.com geht.
iobroker chmod 777 vis/* iobroker chown admin vis/*Muss noch jemand bestätigen.
gerade auf einem Odroid XU3 mit aktuellen Archlinux nach der letzten Anleitung (OCC habe ich noch weggelassen) installiert.
Von einem Chrome Browser/Mac zugegriffen.
Ergebnis:
Auf den ersten Blick funktioniert alles.
VIS lies sich starten und funktioniert besser als Version 0.5.9
Alles in Allen "gute Arbeit"
Steve
Ich hab mal die letzte Version nach Bluefox Anleitung installiert.
Installation lief auf dem BananaPi Problemlos. Wenn ich die einzelnen Objekte anklicke kann ich auch schön die Rechte vergeben.
Leider bekomme ich den Zugriff über die Simple-API nicht mehr hin. Beim Zugriff auf z.B.
https://IP/getPlainValue/hm-rpc.1.HEQ0XXXXX.1.STATE?user=USERNAME&pass=PASSWORTbekomme ich immer````
error: permissionErrorEs ist egal welchen User ich als Owner eintrage. Es sind die Rechte für Alle (sowohl Objekt als auch Zustand) vergeben. Im Log ist kein Eintrag zu sehen. Ansonsten läuft alles problemlos (wobei ich VIS wegen ein paar fehlenden hq-Widgets) noch nicht nutze. Gruss Marco -
Hi Bluefox,
die Ausgabe von````
iobroker o get hm-rpc.1.HEQXXXXX.1.STATE{
"type": "state",
"common": {
"name": "Licht Arbeitszimmer.STATE",
"type": "boolean",
"role": "state",
"def": false,
"read": true,
"write": true
"native": {
"CONTROL": "SWITCH.STATE",
"ID": "STATE",
"TYPE": "BOOL",
"UNIT": "",
"FLAGS": 1,
"OPERATIONS": 7,
"TAB_ORDER": 0,
"DEFAULT": false,
"MAX": true,
"MIN": false
"_id": "hm-rpc.1.HEQ0XXXX.1.STATE",
"acl": {
"object": 1638,
"owner": "system.user.admin",
"state": 1638
}Dabei ist es egal ob ich den Besitzer vorher auf "marco" ändere oder "admin" lasse. Die Ausgabe vom owner bleibt system.users.admin, wohingegen im Admin Adapter der Benutzer korrekt dargestellt wird. Die Rechte liegen bei "777" also jeder darf alles. Wenn ich den Aufruf als "admin" tätige, bekomme ich den State angezeigt. Der Aufruf von```` https://IP:8087/getPlainValue/system.adapter.admin.0.uptime?user=admin&pass=iobroker ````funktioniert als admin. Also User "marco" nicht.iobroker list users
ID | Name | Active | Groups
system.user.admin | admin | enabled | administrator
system.user.marco | marco | enabled | administratoriobroker list users
``` `system.group | object | state | file | user | others | users | l r w d | l r w d | l r w c d | w c d | | --------------------+---------+---------+-----------+-------+------------------------+--------- /opt/iobroker/node_modules/iobroker.js-controller/lib/setupList.js:394 for (var m = 0; m < objs.rows[i].value.common.members.length; m ^ TypeError: Cannot read property 'length' of null at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setupList.js:394:82) at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6) at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:220:12) at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20) at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:301:8) at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20) at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12) at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:291:16)</anonymous></anonymous></anonymous>` Ich hoffe es hilft Dir im Debugging. Gruss Marco[/i] ``` -
Meine Güte das geht immer schnell bei Dir !
Ich hab das mal getestet und es geht wieder :) Danke
Ich hab allerdings mal testweise die Gruppen und Jeder Rechte entzogen (Objekt und State, lesen und schreiben) und kann als User "marco" noch auf das Objekt zugreifen, obwohl es dem User admin gehört. Ich bin zwar in der Admin Gruppe, habe aber die Rechte für die Gruppe entzogen, sollte doch eigentlich nicht mehr gehen oder ?
Ansonsten wie immer, vielen Dank für Deine Arbeit !
Gruss Marco
