  4. Homematic IP Heizkörperthermostate
    6.1k
65 Beiträge 17 Kommentatoren 18.0k Aufrufe 19 Beobachtet
  • RöstkartoffelR Offline
    Röstkartoffel
    schrieb am zuletzt editiert von Röstkartoffel
    Hier die Widgets mit den Werten
    Widget "Status Auto":
    [{"tpl":"tplValueListHtml8","data":{"oid":"hm-rpc.2.000393C99BF07D.1.SET_POINT_MODE","visibility-cond":"==","visibility-val":"false","count":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"value0":"AUTO","value1":"Hand","style0":"background-color: green; padding-top:3px;","style1":"background-color: red; padding-top:3px;","test_list":"0","visibility-groups-action":"hide","style2":"","value2":"","value3":"Boost","style3":"background-color: blue; padding-top:3px;","name":"Arbeitszimmer Status AUTO","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"visibility-oid":"hm-rpc.2.000393C99BF07D.1.BOOST_MODE"},"style":{"left":"805px","top":"214px","z-index":"2","color":"#ffffff","text-align":"center","width":"72px","height":"27px","border-radius":"4px","padding-top":"","line-height":"1.5","font-size":"small","background-color":"#FFFFFF"},"widgetSet":"basic"}]
    Widget "Status Boost":
    [{"tpl":"tplValueListHtml8","data":{"oid":"hm-rpc.2.000393C99BF07D.1.SET_POINT_MODE","visibility-cond":"==","visibility-val":"true","count":"2","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"value0":"Boost","value1":"Boost","style0":"background-color: blue; padding-top:3px;","style1":"background-color: blue; padding-top:3px;","test_list":"1","visibility-groups-action":"hide","style2":"","value2":"","value3":"","style3":"","name":"Arbeitszimmer Status boost","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"visibility-oid":"hm-rpc.2.000393C99BF07D.1.BOOST_MODE"},"style":{"left":"889px","top":"216px","z-index":"2","color":"#ffffff","text-align":"center","width":"72px","height":"25px","border-radius":"4px","padding-top":"","line-height":"1.5","font-size":"small","background-color":"#FFFFFF"},"widgetSet":"basic"}]
    NUC7i3BNH mit Proxmox und ioBroker (VM Debian Buster), Raspi3 (Slave Smartmeter für eHZ easymeter), Hardware CCU2, SMA SB5000TL-21
    • RöstkartoffelR Röstkartoffel
      Alero
      schrieb am zuletzt editiert von Alero
      @Röstkartoffel
      Danke das wars. Ein Icon fehlte. Hatte noch das Problem, das bei boost er einfach nicht mit dem Radiobutton arbeiten wollte. Habe ihn jetzt gelöscht. Jetzt klappt alles. Die Taste ist markiert, das Icon zwischen Plus und Minus wird richtig angezeigt und wird auch ausgeführt.
      Die Ansicht wäre halt schöner mit dem Radiobutton. Aber nicht so schlimm.
      Jetzt muss ich mich an die Rolladen ran machen. Da habe ich noch ein kleines Problem. ;-)
      Vielen Dank noch einmal. Du hast mir sehr weiter geholfen.
      Alero
      RöstkartoffelR 1 Antwort Letzte Antwort
      • A Alero
        @Röstkartoffel
        Alero
        Röstkartoffel
        @Alero
        Wenn es dir geholfen hat:
        Benutze das Voting rechts unten in den einen Beitrag, der dir am meisten geholfen hat.
        • MicM Offline
          MicM Offline
          Mic
          schrieb am zuletzt editiert von Mic
          (sorry, Doppelpost, bitte löschen)
          • MicM Offline
            MicM Offline
            Mic
            Vielen Dank für die Anregungen hier. Ich habe es in meine Visualisierung auch mal so umgesetzt.
            Beispiel:
            Mit Boost (Farben muss ich noch etwas spielen):
            Fenster offen:
            Die unterschiedlichen Widgets hatte ich nicht ganz verstanden. Ich verwende für "Automatik / Manuell" das Widget "jqui - Radiobuttons ValueList" mit entsprechender CSS-Formatierung, daneben für Boost ein Widget ""hqwidgets - On/Off"" (geschaltet auf Datenpunkt hm-rpc.0.xxxxxxxxxx.1.BOOST_MODE). Funktioniert super.
            Die Schaltleiste "Aus / Standard / Urlaub" schaltet die Heizprofile 1-3.
            RöstkartoffelR TJJochenT 2 Antworten Letzte Antwort
            -1
              Alero
              Hi Mic,
              sieht gut aus.
              Alero
                skokarl
                Moin,
                wir reden hier von Homematic IP Thermostaten ?
                Ich habe da kein Objekt Boost_Mode ????
                Hab drei Ventile...aber von Boost keine Spur.
                • MicM Offline
                  MicM Offline
                  Mic
                  ja, bei HmIP-eTRV-2 sieht es so aus:
                    skokarl
                    ich hab den hmip adapter.....komisch...
                    • MicM Mic
                      Beispiel:
                      Fenster offen:
                      Röstkartoffel
                      @Mic sagte in Homematic IP Heizkörperthermostate:
                      Ich habe mich schon bei den Bildern gefragt, wie du das mit dem "Aus / Standard / Urlaub" machst.
                      Mit den Profilen kann man das machen, aber leider fehlt dir da die Möglichkeit, einen Zeitraum mit Start und Ende angeben zu können.
                      Ich wähle die Profile über ein Pulldown Widget aus:Raumklima Programmauswahl.JPG
                      Hast du eine Anzeige des Valve_States vorgesehen? Dort werden ja die Meldungen (Fehler und andere Stati) angezeigt, wie so z.B.:
                      Hat deine Widget-Bar für die Ventilöffnung einen Farbverlauf?
                      Ich habe das jetzt im Widget unter "Farbe" so gemacht:
                      {v:hm-rpc.3.xxxxxxxxx.1.LEVEL;v < 0.5 ? "#FDEE00" :: v < 0.7 ? "#FFA500" :: "#FF0000"}
                      damit ist die Bar bei einer Öffnung von weniger als 50% gelb, zwischen 50 und 70% orange und über 70% wird sie in rot angezeigt.
                      MicM A 2 Antworten Letzte Antwort
                        skokarl
                        welche Version des Adapters habt ihr ?
                          MicM Offline
                          MicM Offline
                          Mic
                          @Röstkartoffel
                          @Röstkartoffel sagte in Homematic IP Heizkörperthermostate:
                          Ich habe eben hier meine Lösung gepostet: [Vorlage] Homematic IP Thermostate: Urlaubssteuerung über VIS
                          Habe ich noch nicht, vielen Dank für den Hinweis, ich baue beides noch ein :-)
                          @skokarl:
                          bei mir HomeMatic RPC Version 1.9.11
                          • MicM Mic
                            @Röstkartoffel
                            @skokarl:
                            skokarl
                            @Mic
                            bin ich jetzt völlig kirre ? Alkohol 1.Mai ?
                            Ich rede vom HMIP Adapter.... da habe ich 0.0.10
                            Also nix CCU, Homematic IP mit Accesspoint.....
                            Von welchem redet ihr ?
                            • MicM Offline
                              MicM Offline
                              Mic
                              @skokarl
                              Aaaah, das erklärt es, ich rede vom Adapter, für den man die CCU braucht (oder entsprechendes), also nicht den Access Point.
                              Den Access Point hatte ich kurz mal getestet vor mehreren Wochen, aber der lieferte mir zu wenig Datenpunkte, daher zurück geschickt... Ich setzte eine CCU2 ein, für die Heizungssteuerung reicht es vollkommen. Gibt es auch gebraucht für kleines Geld.
                              • MicM Mic
                                @skokarl
                                skokarl
                                @Mic
                                Ah, ok Mic, Danke
                                  Alero
                                  @Röstkartoffel
                                  Habe den Code in Farbe eingetragen.
                                  Balken unter Ventilfahrt angeklickt und im Widget unter Allgemein , Farbe deinen Code einegtragen. Auch mein HM-RPC angepasst)
                                  Geht nicht :-( . Es wird nichts angezeigt.
                                  Mache ich hier was falsch?
                                  Alero
                                  • A Alero
                                    @Röstkartoffel
                                    Alero
                                    Röstkartoffel
                                    @Alero
                                    Ich habe das Widget jetzt nochmal exportiert, teste das mal bitte:
                                    [{"tpl":"tplValueFloatBar","data":{"oid":"hm-rpc.3.00039709xxxxxx.1.LEVEL","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","min":"0","max":"1.005","orientation":"horizontal","color":"{v:hm-rpc.3.00039709xxxxxx.1.LEVEL;v < 0.5 ? \"#FDEE00\" :: v < 0.7 ? \"#FFA500\" :: \"#FF0000\"}","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"name":"Ventilstellung","g_last_change":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"reverse":false},"style":{"left":"330px","top":"272px","width":"200px","height":"10px","z-index":"3"},"widgetSet":"basic"}]
                                      @Alero
                                      Alero
                                      @Röstkartoffel
                                      Hi, habe es importiert. Danke noch mal dafür.
                                      Nicht das ich hier was falsch verstehe. Der Balken ist doch dafür da um die Position des Ventils anzuzeigen, oder?
                                      Heisst, wenn ich auf 30 Grad gehe, sollte der Balken gelb oder sogar rot werden.
                                      Richtig?
                                      Alero
                                      • A Alero
                                        @Röstkartoffel
                                        Richtig?
                                        Alero
                                        Röstkartoffel
                                        @Alero
                                        Ja. Aber ... die Übertragung der Daten vom Thermostat zu ioBroker kann aber einige Minuten dauern.
                                        Du kannst auch über die VIS den Boost auslösen, dann sollte gleich was zu sehen sein. Oder du kannst den Datenpunkt "hm-rpc.3.00039709xxxxxx.1.LEVEL" von Hand ändern und bestätigen und in der VIS siehst du dann den farbigen Balken.
                                          @Alero
                                          Alero
                                          @Röstkartoffel
                                          Hi ,
                                          Bei Boost sehe ich jetzt auch einen Balken. Ich dachte der Blaken bleibt stehen. Nach dem Boost ist er wieder weg.
                                          Alero
