  3. Entwicklung
  4. Adapter: broadlink2
Adapter: broadlink2
broad2broadlinkrm prorm3 minirm4
1.4k Beiträge 169 Kommentatoren 790.0k Aufrufe 93 Beobachtet
  • padrinoP padrino
    @frankjoke
    Ist das normal?
    $ ./iobroker url "https://github.com/frankjoke/ioBroker.broadlink2/tree/V2Beta"
    install https://github.com/frankjoke/ioBroker.broadlink2/tree/V2Beta/tarball/master
    npm install https://github.com/frankjoke/ioBroker.broadlink2/tree/V2Beta/tarball/master --production --save --prefix "/opt/iobroker" (System call)
    npm
     ERR! code E404
    npm
    ERR! 404 Not Found - GET https://github.com/frankjoke/ioBroker.broadlink2/tree/V2Beta/tarball/masternpm ERR! 404
    npm ERR! 404  'https://github.com/frankjoke/ioBroker.broadlink2/tree/V2Beta/tarball/master' is not in the npm registry.
    npm ERR! 404 Your package name is not valid, because npm ERR! 404  1. name can only contain URL-friendly characters
    npm ERR! 404  2. name can no longer contain capital letters
    npm ERR! 404 npm ERR! 404 Note that you can also install from a
    npm ERR! 404 tarball, folder, http url, or git url.
    npm ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2019-03-31T21_01_46_763Z-debug.log
    process exited with code 0
    frankjokeF Offline
    frankjokeF Offline
    frankjoke
    #393
    @padrino
    Bitte nicht https://github.com/frankjoke/ioBroker.broadlink2/tree/V2Beta
    sondern https://github.com/frankjoke/ioBroker.broadlink2/tarball/V2Beta !
    Frank,
    NUC's, VM's und Raspi's unter Raspian, Ubuntu und Debian zum Testen.
    Adapter die ich selbst beigesteuert habe: BMW, broadlink2, radar2, systeminfo, km200, xs1 und einige im Anmarsch!
    • frankjokeF frankjoke
      @padrino
      padrinoP Offline
      padrinoP Offline
      padrino
      #394
      @frankjoke sagte in Adapter: broadlink2:
      @padrino
      Hoppla. Danke. =)
      Nun ging es wohl.
      Log beim Start des Adapters
       Promise problem unhandledRejection of Promise Promise { <rejected> TypeError: Cannot read property 'split' of undefined at main (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink2.js:783:22) a
      frankjokeF 1 Antwort Letzte Antwort
      • padrinoP padrino
        @padrino
        Hoppla. Danke. =)
        Nun ging es wohl.
        frankjokeF Offline
        frankjokeF Offline
        frankjoke
        schrieb am zuletzt editiert von frankjoke
        #395
        @padrino
        Ok, auch schon gefunden, du hast natürlich ein leeres rename da du keine Neuinstallation gemacht hast...
        Sollte auf git gelöst sein!
        Frank,
          @padrino
          padrinoP Offline
          padrinoP Offline
          padrino
          schrieb am zuletzt editiert von padrino
          #396
          @frankjoke
          Ok, läuft. :)
          Das neue "rename" kann mir aber nicht helfen, dass mein altes Gerät mit "-local" im Namen wieder (also als neues ohne den Zusatz) erkannt wird, oder?
          • padrinoP padrino
            @frankjoke
            Ok, läuft. :)
            frankjokeF Offline
            frankjokeF Offline
            frankjoke
            #397
            @padrino sagte in Adapter: broadlink2:
            @frankjoke
            Ok, läuft. :)
            Sollte schon! neuerName=alterName und den Objekt.Baum des neuen namens im Admin.objects löschen...
            Ok, hab's noch nicht in diese Richtung probiert aber musst ja nicht löschen wenn nicht funktioniert.
            Frank,
              @frankjoke
              Ok, läuft. :)
              padrinoP Offline
              padrinoP Offline
              padrino
              #398
              @frankjoke
              Ok.
              Also Du meinst
              RM:RMPROPLUS-xx-xx-xx=RM:RMPROPLUS-xx-xx-xx-local
              nicht
              RM:RMPROPLUS-xx-xx-xx-local=RM:RMPROPLUS-xx-xx-xx
              (Hab' Angst mir etas zu zerschießen 😇)
              Hatte vermutet, neues (non-local) Objekt zu löschen und dann das -local umzubennen - ist wohl genau falsch rum. :D
              frankjokeF 2 Antworten Letzte Antwort
              • padrinoP padrino
                @frankjoke
                Ok.
                Also Du meinst
                nicht
                frankjokeF Offline
                frankjokeF Offline
                frankjoke
                #399
                @padrino
                Ja, genau, neues Objekt solltest du löschen können und altes behalten.
                Frank,
                • padrinoP padrino
                  @frankjoke
                  Ok.
                  Also Du meinst
                  nicht
                  frankjokeF Offline
                  frankjokeF Offline
                  frankjoke
                  #400
                  Ja, kannst auch : alters-objekt=WohnzimmerRM, neues-objekt=WohnzimmerRM
                  dann solltest alles unter WohnzimmerRM haben!
                  Frank,
                  • padrinoP Offline
                    padrinoP Offline
                    padrino
                    #401
                    Hmm, geht nicht, oder ich blick es nicht :(
                    Nachdem es nicht ging, habe ich mal versucht:
                    RM:RMPROPLUS-xx-xx-xx=RM:RMPROPLUS-xx-xx-xx-temp
                    Ergebnis: immer noch (nur) RM:RMPROPLUS-xx-xx-xx im Objektebaum.
                    Edit: Im log steht
                    Devices to rename:
                    Devices to add: RM:RMPROPLUS-xx-xx-xx,RM:RMPROPLUS-xx-xx-xx-temp RM:RMPROPLUS-xx-xx-xx=RM:RMPROPLUS-xx-xx-xx-temp
                    • padrinoP padrino
                      Edit: Im log steht
                      Devices to rename:
                      frankjokeF Offline
                      frankjokeF Offline
                      frankjoke
                      #402
                      @padrino
                      Ich habe eine Version auf git welche die originalen Namen (vor dem umbenennen) im debug-mode zu jedem Gerät listet.
                      Das schaut z.B. bei mir so aus:
                      Device SP:Gibssi3 dedected: address=192.168.178.118, mac=34:ea:34:f4:9e:2d, typ=sp2, id=0x2728 devtype=OEM branded SPMini2
                      Device AirAZ1 dedected: address=192.168.178.104, mac=34:ea:34:b2:bf:3d, typ=a1, id=0x2714 devtype=A1, originalName=A1:EAIR1
                      Device RMAZ1 dedected: address=192.168.178.102, mac=34:ea:34:f4:53:11, typ=rmp, id=0x272a devtype=RM2 Pro Plus, originalName=RM:RMPROPLUS
                      Device SP:Gibssi1 dedected: address=192.168.178.53, mac=34:ea:34:f5:75:dc, typ=sp2, id=0x2728 devtype=OEM branded SPMini2
                      Device SP:Jessi3-Switch dedected: address=192.168.178.100, mac=34:ea:34:f4:fe:a2, typ=sp2, id=0x2728 devtype=OEM branded SPMini2
                      Device SP:Steckdose-BL1 dedected: address=192.168.178.39, mac=34:ea:34:f5:27:06, typ=sp2, id=0x2728 devtype=OEM branded SPMini2
                      Device SP:SDKlima dedected: address=192.168.178.50, mac=34:ea:34:f4:9d:57, typ=sp2, id=0x2728 devtype=OEM branded SPMini2
                      Device Beok313 dedected: address=192.168.178.111, mac=78:0f:77:fa:83:7c, typ=t1, id=0x4ead devtype=T1 Floureon, originalName=T1:BroadLink-OEM-T1-fa-83-7c
                      Device SP:SP3S dedected: address=192.168.178.121, mac=34:ea:34:9d:2c:95, typ=sp3p, id=0x947a devtype=SP3SPower
                      Device SP:Gibssi2 dedected: address=192.168.178.117, mac=34:ea:34:f4:ce:f7, typ=sp2, id=0x2728 devtype=OEM branded SPMini2
                      Device SP:SM1 dedected: address=192.168.178.114, mac=34:ea:34:bd:92:4a, typ=sp2, id=0x7547 devtype=OEM branded SPMini2
                      debug: ChangeState ack:true of _NewDeviceScan = false
                      debug: broadlink2 has 94 old states!
                      seems that device SP:BroadLink-SPmini-T1-f5-75-dc got renamed to SP:Gibssi1! You may delete old device and change your scripts!
                      seems that device SP:BroadLink-SPmini-T1-f5-27-06 got renamed to SP:Steckdose-BL1! You may delete old device and change your scripts!
                      seems that device SP:BroadLink-SPmini-T1-f4-9d-57 got renamed to SP:SDKlima! You may delete old device and change your scripts!
                      Die letzten 3 Meldungen bedeuten dass alte und neue Namen im Objektbaum sind da sich Geräte zwischenzeitlich umbenannt haben, aber der Adapter hat dann wieder das Gerät mit dem richtigen namen (über die mac-adresse) gefunden.
                      p.s.: Löschen tut er nur RM's die erfolgreich umbenannt werden, sonst nix, da ja Logik in scripten dahinterstecken kann die noch geändert werden muss...
                      p.s.: Du siehst auch dass ich jetzt mehr mit den alten Namen arbeite, RMAZ1 heißt der Test-RM im Arbeitszimmer jetzt, sein Original-Name mit Fritz-Box zugewiesen ist aber RM:RMPROPLUS und wenn ich ihm keine feste Adresse und speziellen Namen in der Fritzbox gegeben hätte dann würde der origional-Name auch RM:Broadlink.....
                      Ach übrigens, du kannst beim Umbenennen links nur originalnamen verwenden, das ist der Originalname bei diesen die schon umbenannt sind oder die namen die bei 'Device .... found' im .... stehen wenn kein Originalname angegeben ist.
                      Also kannst auch keinen namen umbenennen welcher schon umbenannt wurde!
                      Frank,
                      ? padrinoP 2 Antworten Letzte Antwort
                        @padrino
                        #403
                        @frankjoke Super, die Version 1.99 auf Git funktioniert mit meinen SPMini's jetzt einwandfrei, auch der RM-Mini und der RM-ProPlus wird erkannt und beide funktionieren.
                        Nur ist beim RMProPlus die Temp.Anzeige verloren gegangen.. die ging in 1.9.1 noch :-)
                        Aber von der Erkennung und den States etc. jetzt bitte nichts mehr aendern... :-)
                        padrinoP frankjokeF 2 Antworten Letzte Antwort
                          padrinoP Offline
                          padrinoP Offline
                          padrino
                          #404
                          @ilovegym sagte in Adapter: broadlink2:
                          Hmm, seltsam. Eigentlich hat der RMpro+ überhaupt keinen Sensor mehr verbaut und der Wert müsste 0 gewesen sein... =)
                            frankjokeF Offline
                            frankjokeF Offline
                            frankjoke
                            #405
                            @ilovegym
                            Ok, das passiert wenn man ein Property einmal mit großem und einmal mit kleinem Buchstaben schreibt....
                            @padrino
                            Der neue Adapter versucht bei jedem RM die Temperatur zu lesen und zeigt sie also überall an wo es eben geht.
                            Egal, habe grad nen update auf Git gemacht und sollte nun gehen.
                            Frank,
                              @ilovegym
                              @padrino
                              #406
                              @ilovegym
                              leider zeigt er bei der Temp null C an, und nicht die Temperatur.. wenn ich mir den Code ansehe, dann sieht das so aus, als ob das Value falsch gesetzt ist..??
                              hier der Auszug aus V1.9.9 Beta2:
                              und hier vom alten V1.9.1:
                              Im log von iobroker steht leider nichts, obwohl der Adapter auf debug steht.. hmm.. ?
                                @ilovegym
                                frankjokeF Offline
                                frankjokeF Offline
                                frankjoke
                                #407
                                @ilovegym
                                Hast du die Beta am Nachmittag runtergeladen? Hatte erst nach 14h das Update mit der Temperatur gemacht.
                                Übrigens, 'Learn' hjeisst jetzt '_Learn', natürlich musst das alte 'Learn' rauslöschen, der Adapter machts nicht automatisch...
                                Bei mir auf 3 Rechnern getestet, aber nur mit einem RM?-Plus.
                                Frank,
                                  @padrino
                                  padrinoP Offline
                                  padrinoP Offline
                                  padrino
                                  #408
                                  Sorrym ich blick es nicht. :(
                                  Und so eine Auflistung, wie Du sie zeigst, sehe ich im debug log auch nicht.
                                  Mein rmpro+ hieß immer "rm-mac-Adresse-local".
                                  Nun mit dem neuen Adapter heißt er nur noch "rm-mac-Adresse".
                                  Im Objektbaum gibt es beide "Ordner", der "-local" mit all meinen Befehlen, der ohne "-local" ist leer.
                                  Umbennen geht weder bei mit oder ohne "-local", der Objektebaum bleibt unverändert.
                                  Glaube, ich muss einfach alles wieder komplett neu anlernen. :(
                                  • padrinoP padrino
                                    frankjokeF Offline
                                    frankjokeF Offline
                                    frankjoke
                                    #409
                                    Der ohne '-local' ist der alte (du hattest in deiner alten Konfig nicht angegeben das '.local' am Ende entfernt werden soll (um die Namen zu kürzen), beim neuen Adapter brauchst das nicht mehr da er das '.local' nicht mehr nimmt ('.local' weil die Punkte auf '-' umbenannt werden da kein '.' im Namen eines ioBroker-Gerätes vorkommen darf)!
                                    In deinem Fall so vorgehen:
                                    • Stoppe adapter
                                    • Lösche die neue Instanz des Gerätes (ohne '-local')
                                    • In Admin/Instanzen gib in konfig/rename ein 'neuerName=alterName' wobei alter name mit '-local' und neuer ohne ist.
                                    • Starte adapter
                                    Warum? Der neue Adapter findet dein Gerät jetzt mit dem neuen Namen und du willst ihn auf den alten Namen umbenennen!
                                    Dann sollte ein neues Gerät ohne '-local' entstehen und die gelernten States vom alten enthalten.
                                    Er kann nicht umbenennen wenn der neue Name schon besteht!
                                    p.s.: Kannst den neuen Namen natürlich auch anders nennen, wie z.B: FernsteuerungWohnzimmer anstatt rm-mac-Adresse-local
                                    Frank,
                                    • padrinoP padrino
                                      frankjokeF Offline
                                      frankjokeF Offline
                                      frankjoke
                                      #410
                                      Sogar wenn dein Adapter im Admin auf Info ist wirst die Geräte sehen die er findet, alles wirst nur auf debug sehen!
                                      Frank,
                                        padrinoP Offline
                                        padrinoP Offline
                                        padrino
                                        #411
                                        @frankjoke
                                        Es geht leider nicht. :(
                                        Habe mich Schritt für Schritt an Deine Anweisung gehalten.
                                        Das Ergebnis, mein -local heißt wie vorher und es wird ein neues leeres Objekt angelegt, dass den Namen ohne -local hat.
                                        Adapter steht auf "debug", aber im Log steht nicht wirklich etwas drin (muss evtl. noch ein anderer Adapter zusätzlich auf "debug" stehen?).
                                        Wichtig ist nur der Broaslink mit "x", der mit "y" ist im Moment nicht angeschlossen, aber noch Teil der Konfig.
                                        ~~gelöscht~~
                                          @ilovegym
                                          #412
                                          @ilovegym
                                          Hi, hab nochmal drueber installiert, funktioniert jetzt, war anscheinend zu schnell ..
                                          Jetzt geht alles einwandfrei, super! Kommt heute abend aufs produktivsystem, sofern sich heute auf dem test keine macken mehr finden lassen.. :-)
                                          Vielen Dank!
