  4. [erledigt] BackitUP keine Emailbenachrichtigung bei Komplettbackup
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
backitupemailnaskomplett
19 Beiträge 2 Kommentatoren 1.9k Aufrufe 2 Beobachtet
  • S sol21
    Habe nun ein Backup auf 16:05 Uhr geplant (ohne Stop). Das Email wurde wunderbar verschickt.
    2019-03-04 16:01:28.538  - debug: backitup.0 system.adapter.admin.0: logging true
    2019-03-04 16:05:21.531  - debug: backitup.0 [total/mount] done
    2019-03-04 16:05:21.547  - debug: backitup.0 [total/total] TAR started...
    2019-03-04 16:05:21.549  - debug: backitup.0 [total/total] Ignore dir: /opt/iobroker/backups
    2019-03-04 16:05:31.548  - debug: backitup.0 [total/total] Packed 17MB so far...
    2019-03-04 16:05:41.550  - debug: backitup.0 [total/total] Packed 21MB so far...
    2019-03-04 16:05:51.552  - debug: backitup.0 [total/total] Packed 29MB so far...
    2019-03-04 16:06:01.556  - debug: backitup.0 [total/total] Packed 37MB so far...
    2019-03-04 16:06:11.577  - debug: backitup.0 [total/total] Packed 47MB so far...
    2019-03-04 16:06:21.686  - debug: backitup.0 [total/total] Packed 51MB so far...
    2019-03-04 16:06:31.688  - debug: backitup.0 [total/total] Packed 57MB so far...
    2019-03-04 16:06:41.693  - debug: backitup.0 [total/total] Packed 63MB so far...
    2019-03-04 16:06:51.787  - debug: backitup.0 [total/total] Packed 68MB so far...
    2019-03-04 16:07:01.789  - debug: backitup.0 [total/total] Packed 74MB so far...
    2019-03-04 16:07:11.791  - debug: backitup.0 [total/total] Packed 78MB so far...
    2019-03-04 16:07:19.873  - debug: backitup.0 [total/total] done
    2019-03-04 16:07:19.884  - debug: backitup.0 [total/cifs] done
    2019-03-04 16:07:19.913  - debug: backitup.0 [total/clean] delete /opt/iobroker/backups/total_2018_12_11-04_15_33_backupiobroker.tar.gz
    2019-03-04 16:07:19.944  - debug: backitup.0 [total/clean] done
    2019-03-04 16:07:19.954  - debug: backitup.0 [total/email] [total] used E-Mail-Instance: email.0
    2019-03-04 16:07:19.958  - debug: backitup.0 sendTo "send" to system.adapter.email.0 from system.adapter.backitup.0
    2019-03-04 16:07:19.959  - debug: backitup.0 [total/email] done
    2019-03-04 16:07:20.002  - debug: backitup.0 [total/history] backitup.0.history.html
    2019-03-04 16:07:20.047  - debug: backitup.0 [total/umount] mount activ... umount in 60 Seconds!!
    2019-03-04 16:07:20.170  - info: email.0 Send email: {"text":"BackItUp:\nEin neues total Backup wurde am 04. Maerz 2019 um 16:07 Uhr erstellt, und unter //192.168.188.40/Backup/iobroker/komplett/ gespeichert.","to":"xx.yy@gmx.ch","subject":"Backitup","from":"qq@gmail.com"}
    2019-03-04 16:07:21.931  - info: email.0 sent to xx.yy@gmx.ch
    2019-03-04 16:08:20.276  - debug: backitup.0 [total/umount] done
    2019-03-04 16:08:20.281  - debug: backitup.0 [total] exec: done
    simatecS Offline
    simatecS Offline
    simatec
    @sol21
    Dann baue ich da mal eine Verzögerung ein, wenn iobroker gestoppt wird.
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    • simatecS simatec
      @sol21
      sol21
      @simatec
      Danke, kann ich dann wieder testen. Denke betrifft nicht nur mich...?
      • S sol21
        @simatec
        simatecS Offline
        simatecS Offline
        simatec
        @sol21
        Hmmm das kann ich schwer beurteilen.
        Ich habe auf allen Testsystemen diese Probleme nicht nachvollziehen können.
        Was nutzt du für ein System? Eventuell ist die Hardware etwas zu schwach.
        Normal wird die Mail erst nach iobroker Start versendet.
        Aber deine Adapter brauchen anscheinend sehr lange zum starten.
        Könnte an der Hardware liegen
        • simatecS simatec
          @sol21
          sol21
          @simatec
          Habe einen RaspberryPi 3B. Läuft aber sehr wenig darauf.
          Solange sich nicht mehr Leute mit dem gleichen Problem melden, kannst Du es so belassen. Ich weiss ja, dass das Backup erstellt wird und kann auf die Benachrichtigung verzichten. Ich werde es aber mal noch länger im Auge behalten.
          Nochmals vielen herzlichen Dank!
          • S sol21
            @simatec
            simatecS Offline
            simatecS Offline
            simatec
            @sol21
            Nutzt du redis? Wenn ja musst du nicht stoppen.
            Auch ohne Redis musst du nicht stoppen.
            Der stop ist nur dafür da, falls es Probleme beim erstellen des totals gibt.
            Ich werde das aber fixen, damit die Meldung etwas zeitverzögert rausgeht
            • simatecS Offline
              simatecS Offline
              simatec
              Installiere mal die Version 1.1.3 vom Github und berichte mal bitte, ob deine Benachrichtigung per Mail jetzt kommt.
              • simatecS simatec
                sol21
                @simatec
                habe nun mit der Version 1.1.3 getestet. Leider kam auch keine Email-Benachrichtigung.
                Hatte das Komplett-Backup auf 14:00:00 eingeplant.
                2019-03-05 13:57:12.261  - info: backitup.0 starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.11.1
                2019-03-05 13:57:12.337  - info: backitup.0 [minimal] backup was activated at 04:00 every 1 day(s)
                2019-03-05 13:57:12.373  - debug: backitup.0 [minimal] 10 00 04 */1 * *
                2019-03-05 13:57:12.373  - info: backitup.0 [total] backup was activated at 14:00:00 every 1 day(s)
                2019-03-05 13:57:12.379  - debug: backitup.0 [total] 10 00 14 */1 * *
                2019-03-05 13:57:12.923  - debug: backitup.0 system.adapter.admin.0: logging true
                2019-03-05 13:58:08.082  - debug: backitup.0 system.adapter.admin.0: logging false
                2019-03-05 13:58:16.367  - debug: backitup.0 system.adapter.admin.0: logging true
                2019-03-05 14:00:00.057  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 8859
                2019-03-05 14:00:04.429  - info: daswetter.0 starting. Version 2.7.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v8.11.1
                2019-03-05 14:00:10.080  - debug: backitup.0 [total] exec: done
                2019-03-05 14:00:10.358  - info: host.raspberrypi received SIGTERM
                2019-03-05 14:00:10.359  - info: web.0 terminating http server on port 8082
                2019-03-05 14:00:10.367  - info: admin.0 terminating http server on port 8081
                2019-03-05 14:00:10.372  - info: javascript.0 terminating
                2019-03-05 14:00:10.380  - info: web.0 terminated http server on port 8082
                2019-03-05 14:00:10.386  - info: admin.0 terminating
                2019-03-05 14:00:10.386  - info: tr-064.0 terminating
                2019-03-05 14:00:10.393  - info: modbus.0 terminating
                2019-03-05 14:00:10.434  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (OK)
                2019-03-05 14:00:10.435  - debug: backitup.0 system.adapter.admin.0: logging false
                2019-03-05 14:00:10.439  - info: host.raspberrypi instance system.adapter.web.0 terminated with code 0 (OK)
                2019-03-05 14:00:10.443  - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 0 (OK)
                2019-03-05 14:00:10.447  - info: host.raspberrypi instance system.adapter.modbus.0 terminated with code 0 (OK)
                2019-03-05 14:00:10.451  - info: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 0 (OK)
                2019-03-05 14:00:10.875  - info: backitup.0 terminating
                2019-03-05 14:00:10.874  - info: daswetter.0 terminating
                2019-03-05 14:00:10.882  - info: email.0 terminating
                2019-03-05 14:00:10.898  - info: host.raspberrypi instance system.adapter.email.0 terminated with code 0 (OK)
                2019-03-05 14:00:10.906  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 0 (OK)
                2019-03-05 14:00:10.908  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (OK)
                2019-03-05 14:00:20.368  - info: host.raspberrypi force terminating
                2019-03-05 14:02:23.152  - info: host.raspberrypi iobroker.js-controller version 1.4.2 js-controller starting
                2019-03-05 14:02:23.161  - info: host.raspberrypi Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
                2019-03-05 14:02:23.162  - info: host.raspberrypi hostname: raspberrypi, node: v8.11.1
                2019-03-05 14:02:23.167  - info: host.raspberrypi ip addresses: 192.168.188.28 fe80::90f8:966e:754:6247
                2019-03-05 14:02:23.339  - info: host.raspberrypi  inMem-states listening on port 9000
                2019-03-05 14:02:23.878  - info: host.raspberrypi  inMem-objects listening on port 9001
                2019-03-05 14:02:23.909  - info: host.raspberrypi InMemoryDB connected
                2019-03-05 14:02:23.943  - info: host.raspberrypi 11 instances found
                2019-03-05 14:02:23.985  - info: host.raspberrypi starting 11 instances
                2019-03-05 14:02:24.050  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 8960
                2019-03-05 14:02:28.006  - info: host.raspberrypi instance system.adapter.web.0 started with pid 8967
                2019-03-05 14:02:28.724  - error: admin.0 setObject id missing!!
                2019-03-05 14:02:28.743  - info: admin.0 starting. Version 3.6.0 in /opt/iobroker/node_modules/iobroker.admin, node: v8.11.1
                2019-03-05 14:02:28.806  - info: admin.0 requesting all states
                2019-03-05 14:02:28.810  - info: admin.0 requesting all objects
                2019-03-05 14:02:28.813  - info: admin.0 Request actual repository...
                2019-03-05 14:02:30.631  - info: admin.0 received all states
                2019-03-05 14:02:32.169  - error: web.0 setObject id missing!!
                2019-03-05 14:02:32.191  - info: web.0 starting. Version 2.4.1 in /opt/iobroker/node_modules/iobroker.web, node: v8.11.1
                2019-03-05 14:02:32.786  - info: web.0 socket.io server listening on port 8082
                2019-03-05 14:02:32.792  - info: web.0 http server listening on port 8082
                2019-03-05 14:02:33.034  - info: admin.0 received all objects
                2019-03-05 14:02:33.191  - info: admin.0 http server listening on port 8081
                2019-03-05 14:02:33.192  - info: admin.0 Use link "http://localhost:8081" to configure.
                2019-03-05 14:02:33.318  - info: host.raspberrypi Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                2019-03-05 14:02:35.794  - info: vis.0 starting. Version 1.1.10 in /opt/iobroker/node_modules/iobroker.vis, node: v8.11.1
                2019-03-05 14:02:35.935  - info: admin.0 Repository received successfully.
                2019-03-05 14:02:36.007  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 8991
                2019-03-05 14:02:36.123  - info: vis.0 vis license is OK.
                2019-03-05 14:02:37.084  - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
                2019-03-05 14:02:41.450  - info: javascript.0 starting. Version 3.6.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v8.11.1
                2019-03-05 14:02:41.467  - info: javascript.0 requesting all states
                2019-03-05 14:02:41.470  - info: javascript.0 requesting all objects
                2019-03-05 14:02:42.638  - info: javascript.0 received all states
                2019-03-05 14:02:44.008  - info: host.raspberrypi instance system.adapter.modbus.0 started with pid 9001
                2019-03-05 14:02:44.960  - info: javascript.0 received all objects
                2019-03-05 14:02:45.083  - info: javascript.0 Start javascript script.js.Skalierung_PV_Leistung
                2019-03-05 14:02:45.182  - info: javascript.0 script.js.Skalierung_PV_Leistung: registered 0 subscriptions and 0 schedules
                2019-03-05 14:02:45.184  - info: javascript.0 Start javascript script.js.Skalierung_Meter_Leistung
                2019-03-05 14:02:45.256  - info: javascript.0 script.js.Skalierung_Meter_Leistung: registered 0 subscriptions and 0 schedules
                2019-03-05 14:02:45.257  - info: javascript.0 Start javascript script.js.Sonneuntergang
                2019-03-05 14:02:45.351  - info: javascript.0 script.js.Sonneuntergang: registered 0 subscriptions and 1 schedule
                2019-03-05 14:02:45.352  - info: javascript.0 Start javascript script.js.PV_Leistung_Durchschnitt
                2019-03-05 14:02:45.432  - info: javascript.0 script.js.PV_Leistung_Durchschnitt: registered 0 subscriptions and 1 schedule
                2019-03-05 14:02:45.433  - info: javascript.0 Start javascript script.js.eth002_R1
                2019-03-05 14:02:45.514  - info: javascript.0 script.js.eth002_R1: registered 1 subscription and 0 schedules
                2019-03-05 14:02:45.515  - info: javascript.0 Start javascript script.js.Steure_R1
                2019-03-05 14:02:45.594  - info: javascript.0 script.js.Steure_R1: registered 1 subscription and 0 schedules
                2019-03-05 14:02:45.595  - info: javascript.0 Start javascript script.js.Steure_R2
                2019-03-05 14:02:45.674  - info: javascript.0 script.js.Steure_R2: registered 2 subscriptions and 0 schedules
                2019-03-05 14:02:45.675  - info: javascript.0 Start javascript script.js.in_zeit_auto_R2
                2019-03-05 14:02:45.758  - info: javascript.0 script.js.in_zeit_auto_R2: registered 1 subscription and 1 schedule
                2019-03-05 14:02:45.759  - info: javascript.0 Start javascript script.js.eth002_R2
                2019-03-05 14:02:45.843  - info: javascript.0 script.js.eth002_R2: registered 1 subscription and 0 schedules
                2019-03-05 14:02:45.844  - info: javascript.0 Start javascript script.js.WLAN
                2019-03-05 14:02:45.928  - info: javascript.0 script.js.WLAN: registered 0 subscriptions and 1 schedule
                2019-03-05 14:02:45.929  - info: javascript.0 Start javascript script.js.Zeit_WP_Sperre_Ein_dynamisch
                2019-03-05 14:02:46.017  - info: javascript.0 script.js.Zeit_WP_Sperre_Ein_dynamisch: registered 0 subscriptions and 2 schedules
                2019-03-05 14:02:46.018  - info: javascript.0 Start javascript script.js.in_zeit_sperre_R1_mitWetter
                2019-03-05 14:02:46.103  - info: javascript.0 script.js.in_zeit_sperre_R1_mitWetter: registered 1 subscription and 1 schedule
                2019-03-05 14:02:46.104  - info: javascript.0 Start javascript script.js.Test_Ausgaben
                2019-03-05 14:02:46.191  - info: javascript.0 script.js.Test_Ausgaben: registered 0 subscriptions and 1 schedule
                2019-03-05 14:02:47.440  - info: modbus.0 starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.modbus, node: v8.11.1
                2019-03-05 14:02:47.493  - warn: modbus.0 Serial is not available
                2019-03-05 14:02:47.854  - info: modbus.0 Connected to slave 192.168.188.36
                2019-03-05 14:02:48.007  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 9011
                2019-03-05 14:02:52.017  - info: tr-064.0 starting. Version 0.4.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v8.11.1
                2019-03-05 14:02:54.555  - error: tr-064.0 forEachConfiguredDevice: in GetSpecificHostEntry 0(fritz.box/5C:49:79:3E:4C:24):Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                2019-03-05 14:02:56.025  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 9021
                2019-03-05 14:02:59.341  - debug: backitup.0 objectDB connected
                2019-03-05 14:02:59.416  - debug: backitup.0 statesDB connected
                2019-03-05 14:02:59.599  - info: backitup.0 starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.11.1
                2019-03-05 14:03:00.121  - info: host.raspberrypi instance scheduled system.adapter.daswetter.0 */15 * * * *
                2019-03-05 14:02:59.611  - debug: backitup.0 Printing logs of previous backup
                2019-03-05 14:02:59.615  - debug: backitup.0 [DEBUG] [total/mount] done
                2019-03-05 14:02:59.617  - debug: backitup.0 [DEBUG] [total/total] TAR started...
                2019-03-05 14:02:59.617  - debug: backitup.0 [DEBUG] [total/total] Ignore dir: /opt/iobroker/backups
                2019-03-05 14:02:59.618  - debug: backitup.0 [DEBUG] [total/total] done
                2019-03-05 14:02:59.618  - debug: backitup.0 [DEBUG] [total/cifs] done
                2019-03-05 14:02:59.618  - debug: backitup.0 [DEBUG] [total/clean] delete /opt/iobroker/backups/total_2019_01_01-04_15_33_backupiobroker.tar.gz
                2019-03-05 14:02:59.619  - debug: backitup.0 [DEBUG] [total/clean] done
                2019-03-05 14:02:59.619  - debug: backitup.0 [DEBUG] [total/start] done
                2019-03-05 14:02:59.619  - debug: backitup.0 [DEBUG] [total/start] IoBroker started ...
                2019-03-05 14:02:59.619  - debug: backitup.0 [DEBUG] [total/email] done
                2019-03-05 14:03:00.598  - info: backitup.0 [minimal] backup was activated at 04:00 every 1 day(s)
                2019-03-05 14:03:00.634  - debug: backitup.0 [minimal] 10 00 04 */1 * *
                2019-03-05 14:03:00.634  - info: backitup.0 [total] backup was activated at 14:00:00 every 1 day(s)
                2019-03-05 14:03:00.650  - debug: backitup.0 [total] 10 00 14 */1 * *
                2019-03-05 14:03:00.737  - debug: backitup.0 mount activ... umount in 2 Seconds!!
                2019-03-05 14:03:04.028  - info: host.raspberrypi instance system.adapter.email.0 started with pid 9044
                2019-03-05 14:03:05.545  - debug: backitup.0 [total/email] [total] used E-Mail-Instance: email.0
                2019-03-05 14:03:05.554  - debug: backitup.0 sendTo "send" to system.adapter.email.0 from system.adapter.backitup.0
                2019-03-05 14:03:05.556  - debug: backitup.0 [total/email] done
                2019-03-05 14:03:05.603  - debug: backitup.0 [total/history] backitup.0.history.html
                2019-03-05 14:03:07.317  - info: email.0 starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.email, node: v8.11.1
                2019-03-05 14:07:10.010  - debug: backitup.0 system.adapter.admin.0: logging false
                2019-03-05 14:10:22.786  - debug: backitup.0 system.adapter.admin.0: logging true
                • simatecS Offline
                  simatecS Offline
                  simatec
                  Hatte 5 Sekunden Verzögerung drin. Aber laut Log startet dein mail Adapter weitere 2 Sekunden später.
                  Ich habe nun die zeit auf 10 Sekunden angepasst. Probiere bitte noch einmal
                  • simatecS simatec
                    sol21
                    @simatec
                    Super! Hat geklappt. -> Email kam sofort an.
                    2019-03-05 15:43:09.736  - debug: backitup.0 statesDB connected
                    2019-03-05 15:43:09.905  - info: backitup.0 starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.11.1
                    2019-03-05 15:43:09.975  - info: backitup.0 [minimal] backup was activated at 04:00 every 1 day(s)
                    2019-03-05 15:43:10.012  - debug: backitup.0 [minimal] 10 00 04 */1 * *
                    2019-03-05 15:43:10.013  - info: backitup.0 [total] backup was activated at 15:45:00 every 1 day(s)
                    2019-03-05 15:43:10.019  - debug: backitup.0 [total] 10 45 15 */1 * *
                    2019-03-05 15:43:14.240  - debug: backitup.0 system.adapter.admin.0: logging true
                    2019-03-05 15:45:00.046  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 9680
                    2019-03-05 15:45:04.044  - info: daswetter.0 starting. Version 2.7.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v8.11.1
                    2019-03-05 15:45:10.052  - debug: backitup.0 [total] exec: done
                    2019-03-05 15:45:10.247  - info: admin.0 terminating http server on port 8081
                    2019-03-05 15:45:10.248  - info: web.0 terminating http server on port 8082
                    2019-03-05 15:45:10.249  - info: web.0 terminated http server on port 8082
                    2019-03-05 15:45:10.257  - info: tr-064.0 terminating
                    2019-03-05 15:45:10.259  - info: modbus.0 terminating
                    2019-03-05 15:45:10.264  - info: javascript.0 terminating
                    2019-03-05 15:45:10.272  - info: host.raspberrypi received SIGTERM
                    2019-03-05 15:45:10.272  - info: admin.0 terminating
                    2019-03-05 15:45:10.282  - info: web.0 terminating
                    2019-03-05 15:45:10.300  - info: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 0 (OK)
                    2019-03-05 15:45:10.323  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (OK)
                    2019-03-05 15:45:10.324  - debug: backitup.0 system.adapter.admin.0: logging false
                    2019-03-05 15:45:10.328  - info: host.raspberrypi instance system.adapter.web.0 terminated with code 0 (OK)
                    2019-03-05 15:45:10.334  - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 0 (OK)
                    2019-03-05 15:45:10.338  - info: host.raspberrypi instance system.adapter.modbus.0 terminated with code 0 (OK)
                    2019-03-05 15:45:10.748  - info: email.0 terminating
                    2019-03-05 15:45:10.755  - info: backitup.0 terminating
                    2019-03-05 15:45:10.766  - info: daswetter.0 terminating
                    2019-03-05 15:45:10.780  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 0 (OK)
                    2019-03-05 15:45:10.810  - info: host.raspberrypi instance system.adapter.email.0 terminated with code 0 (OK)
                    2019-03-05 15:45:10.810  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (OK)
                    2019-03-05 15:45:20.281  - info: host.raspberrypi force terminating
                    2019-03-05 15:47:17.982  - info: host.raspberrypi iobroker.js-controller version 1.4.2 js-controller starting
                    2019-03-05 15:47:17.991  - info: host.raspberrypi Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
                    2019-03-05 15:47:17.992  - info: host.raspberrypi hostname: raspberrypi, node: v8.11.1
                    2019-03-05 15:47:17.997  - info: host.raspberrypi ip addresses: 192.168.188.28 fe80::90f8:966e:754:6247
                    2019-03-05 15:47:18.169  - info: host.raspberrypi  inMem-states listening on port 9000
                    2019-03-05 15:47:18.709  - info: host.raspberrypi  inMem-objects listening on port 9001
                    2019-03-05 15:47:18.740  - info: host.raspberrypi InMemoryDB connected
                    2019-03-05 15:47:18.773  - info: host.raspberrypi 11 instances found
                    2019-03-05 15:47:18.815  - info: host.raspberrypi starting 11 instances
                    2019-03-05 15:47:18.880  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 9761
                    2019-03-05 15:47:22.837  - info: host.raspberrypi instance system.adapter.web.0 started with pid 9767
                    2019-03-05 15:47:23.536  - error: admin.0 setObject id missing!!
                    2019-03-05 15:47:23.558  - info: admin.0 starting. Version 3.6.0 in /opt/iobroker/node_modules/iobroker.admin, node: v8.11.1
                    2019-03-05 15:47:23.619  - info: admin.0 requesting all states
                    2019-03-05 15:47:23.623  - info: admin.0 requesting all objects
                    2019-03-05 15:47:23.626  - info: admin.0 Request actual repository...
                    2019-03-05 15:47:25.711  - info: admin.0 received all states
                    2019-03-05 15:47:27.022  - error: web.0 setObject id missing!!
                    2019-03-05 15:47:27.045  - info: web.0 starting. Version 2.4.1 in /opt/iobroker/node_modules/iobroker.web, node: v8.11.1
                    2019-03-05 15:47:27.682  - info: web.0 socket.io server listening on port 8082
                    2019-03-05 15:47:27.688  - info: web.0 http server listening on port 8082
                    2019-03-05 15:47:28.060  - info: admin.0 received all objects
                    2019-03-05 15:47:28.208  - info: admin.0 http server listening on port 8081
                    2019-03-05 15:47:28.208  - info: admin.0 Use link "http://localhost:8081" to configure.
                    2019-03-05 15:47:28.332  - info: host.raspberrypi Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                    2019-03-05 15:47:30.838  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 9789
                    2019-03-05 15:47:31.225  - info: admin.0 Repository received successfully.
                    2019-03-05 15:47:31.115  - info: vis.0 starting. Version 1.1.10 in /opt/iobroker/node_modules/iobroker.vis, node: v8.11.1
                    2019-03-05 15:47:31.378  - info: vis.0 vis license is OK.
                    2019-03-05 15:47:32.301  - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
                    2019-03-05 15:47:36.480  - info: javascript.0 starting. Version 3.6.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v8.11.1
                    2019-03-05 15:47:36.498  - info: javascript.0 requesting all states
                    2019-03-05 15:47:36.501  - info: javascript.0 requesting all objects
                    2019-03-05 15:47:37.650  - info: javascript.0 received all states
                    2019-03-05 15:47:38.847  - info: host.raspberrypi instance system.adapter.modbus.0 started with pid 9803
                    2019-03-05 15:47:39.841  - info: javascript.0 received all objects
                    2019-03-05 15:47:39.961  - info: javascript.0 Start javascript script.js.Skalierung_PV_Leistung
                    2019-03-05 15:47:40.061  - info: javascript.0 script.js.Skalierung_PV_Leistung: registered 0 subscriptions and 0 schedules
                    2019-03-05 15:47:40.063  - info: javascript.0 Start javascript script.js.Skalierung_Meter_Leistung
                    2019-03-05 15:47:40.137  - info: javascript.0 script.js.Skalierung_Meter_Leistung: registered 0 subscriptions and 0 schedules
                    2019-03-05 15:47:40.138  - info: javascript.0 Start javascript script.js.Sonneuntergang
                    2019-03-05 15:47:40.234  - info: javascript.0 script.js.Sonneuntergang: registered 0 subscriptions and 1 schedule
                    2019-03-05 15:47:40.235  - info: javascript.0 Start javascript script.js.PV_Leistung_Durchschnitt
                    2019-03-05 15:47:40.317  - info: javascript.0 script.js.PV_Leistung_Durchschnitt: registered 0 subscriptions and 1 schedule
                    2019-03-05 15:47:40.318  - info: javascript.0 Start javascript script.js.eth002_R1
                    2019-03-05 15:47:40.404  - info: javascript.0 script.js.eth002_R1: registered 1 subscription and 0 schedules
                    2019-03-05 15:47:40.405  - info: javascript.0 Start javascript script.js.Steure_R1
                    2019-03-05 15:47:40.486  - info: javascript.0 script.js.Steure_R1: registered 1 subscription and 0 schedules
                    2019-03-05 15:47:40.487  - info: javascript.0 Start javascript script.js.Steure_R2
                    2019-03-05 15:47:40.568  - info: javascript.0 script.js.Steure_R2: registered 2 subscriptions and 0 schedules
                    2019-03-05 15:47:40.569  - info: javascript.0 Start javascript script.js.in_zeit_auto_R2
                    2019-03-05 15:47:40.655  - info: javascript.0 script.js.in_zeit_auto_R2: registered 1 subscription and 1 schedule
                    2019-03-05 15:47:40.656  - info: javascript.0 Start javascript script.js.eth002_R2
                    2019-03-05 15:47:40.742  - info: javascript.0 script.js.eth002_R2: registered 1 subscription and 0 schedules
                    2019-03-05 15:47:40.743  - info: javascript.0 Start javascript script.js.WLAN
                    2019-03-05 15:47:40.829  - info: javascript.0 script.js.WLAN: registered 0 subscriptions and 1 schedule
                    2019-03-05 15:47:40.830  - info: javascript.0 Start javascript script.js.Zeit_WP_Sperre_Ein_dynamisch
                    2019-03-05 15:47:40.917  - info: javascript.0 script.js.Zeit_WP_Sperre_Ein_dynamisch: registered 0 subscriptions and 2 schedules
                    2019-03-05 15:47:40.918  - info: javascript.0 Start javascript script.js.in_zeit_sperre_R1_mitWetter
                    2019-03-05 15:47:41.006  - info: javascript.0 script.js.in_zeit_sperre_R1_mitWetter: registered 1 subscription and 1 schedule
                    2019-03-05 15:47:41.006  - info: javascript.0 Start javascript script.js.Test_Ausgaben
                    2019-03-05 15:47:41.095  - info: javascript.0 script.js.Test_Ausgaben: registered 0 subscriptions and 1 schedule
                    2019-03-05 15:47:42.203  - info: modbus.0 starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.modbus, node: v8.11.1
                    2019-03-05 15:47:42.256  - warn: modbus.0 Serial is not available
                    2019-03-05 15:47:42.635  - info: modbus.0 Connected to slave 192.168.188.36
                    2019-03-05 15:47:42.836  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 9813
                    2019-03-05 15:47:46.789  - info: tr-064.0 starting. Version 0.4.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v8.11.1
                    2019-03-05 15:47:49.302  - error: tr-064.0 forEachConfiguredDevice: in GetSpecificHostEntry 0(fritz.box/5C:49:79:3E:4C:24):Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                    2019-03-05 15:47:50.853  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 9823
                    2019-03-05 15:47:54.128  - debug: backitup.0 objectDB connected
                    2019-03-05 15:47:54.203  - debug: backitup.0 statesDB connected
                    2019-03-05 15:47:54.379  - info: backitup.0 starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.11.1
                    2019-03-05 15:47:54.858  - info: host.raspberrypi instance scheduled system.adapter.daswetter.0 */15 * * * *
                    2019-03-05 15:47:54.391  - debug: backitup.0 Printing logs of previous backup
                    2019-03-05 15:47:54.395  - debug: backitup.0 [DEBUG] [total/mount] done
                    2019-03-05 15:47:54.397  - debug: backitup.0 [DEBUG] [total/total] TAR started...
                    2019-03-05 15:47:54.397  - debug: backitup.0 [DEBUG] [total/total] Ignore dir: /opt/iobroker/backups
                    2019-03-05 15:47:54.398  - debug: backitup.0 [DEBUG] [total/total] done
                    2019-03-05 15:47:54.398  - debug: backitup.0 [DEBUG] [total/cifs] done
                    2019-03-05 15:47:54.398  - debug: backitup.0 [DEBUG] [total/clean] delete /opt/iobroker/backups/total_2019_01_11-04_15_33_backupiobroker.tar.gz
                    2019-03-05 15:47:54.398  - debug: backitup.0 [DEBUG] [total/clean] done
                    2019-03-05 15:47:54.399  - debug: backitup.0 [DEBUG] [total/start] done
                    2019-03-05 15:47:54.399  - debug: backitup.0 [DEBUG] [total/start] IoBroker started ...
                    2019-03-05 15:47:54.399  - debug: backitup.0 [DEBUG] [total/email] done
                    2019-03-05 15:47:55.335  - info: backitup.0 [minimal] backup was activated at 04:00 every 1 day(s)
                    2019-03-05 15:47:55.372  - debug: backitup.0 [minimal] 10 00 04 */1 * *
                    2019-03-05 15:47:55.373  - info: backitup.0 [total] backup was activated at 15:45:00 every 1 day(s)
                    2019-03-05 15:47:55.389  - debug: backitup.0 [total] 10 45 15 */1 * *
                    2019-03-05 15:47:55.487  - debug: backitup.0 mount activ... umount in 2 Seconds!!
                    2019-03-05 15:47:58.860  - info: host.raspberrypi instance system.adapter.email.0 started with pid 9846
                    2019-03-05 15:48:02.166  - info: email.0 starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.email, node: v8.11.1
                    2019-03-05 15:48:05.274  - debug: backitup.0 [total/email] [total] used E-Mail-Instance: email.0
                    2019-03-05 15:48:05.281  - debug: backitup.0 sendTo "send" to system.adapter.email.0 from system.adapter.backitup.0
                    2019-03-05 15:48:05.282  - debug: backitup.0 [total/email] done
                    2019-03-05 15:48:05.316  - debug: backitup.0 [total/history] backitup.0.history.html
                    2019-03-05 15:48:05.521  - info: email.0 Send email: {"text":"BackItUp:\nEin neues total Backup wurde am 05. Maerz 2019 um 15:47 Uhr erstellt, und unter 192.168.188.40/Backup/iobroker/komplett/ gespeichert.","to":"xx.yy@gmx.ch","subject":"Backitup","from":"jj@gmail.com"}
                    2019-03-05 15:48:07.494  - info: email.0 sent to xx.yy@gmx.ch
                    Nochmals herzlichen Dank für die tolle Unterstützung!
                    • simatecS Offline
                      simatecS Offline
                      simatec
                      Ab Version 1.1.3 ist die Zeitverzögerung im Menü einstellbar.
