  2. English
  3. Visualization
  4. getting started with visualisations
Geplant Angeheftet Gesperrt Verschoben Visualization
vis
43 Beiträge 4 Kommentatoren 9.7k Aufrufe 4 Beobachtet
  • BluefoxB Bluefox
    Участник @Taragorm написал в getting started with visualisations:
    /opt/iobroker/node_modules/iobroker.js-controller/
    It would be easier, if I can see the repo on github.
    Do you have file /opt/iobroker/node_modules/iobroker.vis-taragorm/widgets/taragorm.html ?
    T
    T
    Taragorm
    @Bluefox
    iobroker@iobrokerdev ~/projects> ls -l /opt/iobroker/node_modules/iobroker.vis-taragorm/widgets
    total 12
    drwxrwxrwx+ 4 iobroker iobroker 4096 Mar  2 10:26 vis-taragorm/
    -rw-r--r--+ 1 iobroker iobroker 6521 Mar  2 11:47 vis-taragorm.html
    Seems to be there...
    BluefoxB 1 Antwort Letzte Antwort
    • T Taragorm
      @Bluefox
      total 12
      @Taragorm No matter. With iobroker r vis && iobroker u vis it should work.
      Not Fast, but work.
      Just tried to execute (windows):
      and cannot see any errors
      • T
        T
        Taragorm
        Something broken with my install, maybe?
        I added a bit of logging to the empty catch block (line 24 here):
            this.enableDebug = function (widgetset) {
                console.log( "widgetset=" + widgetset );
                if (widgetset) {
                    // Try to find out the adapter directory out of a list of options
                    var adapterDir;
                    var adapterNames2Try = ['vis-' + widgetset, widgetset];
                    if (adapterNames2Try[0] === adapterNames2Try[1]) adapterNames2Try.splice(1, 1);
                    for (var i = 0; i < adapterNames2Try.length; i++) {
                        try {
                            var adapterDir2Try = tools.getAdapterDir(adapterNames2Try[i]);
                            // Query the entry
                            var stats = fs.lstatSync(adapterDir2Try);
                            console.log(stats.toString() );
                            // Is it a directory?
                            if (stats.isDirectory()) {
                                //found it!
                                adapterDir = adapterDir2Try;
                                break;
                        } catch (e) {
                            console.error(e);
                    if (!adapterDir) throw 'Adapter not found. Tried: ' + adapterNames2Try.join(', ');
        and got this:
        obroker@iobrokerdev /o/iobroker> iobroker visdebug vis-taragorm
        widgetset=vis-taragorm
        TypeError [ERR_INVALID_ARG_TYPE]: The "path" argument must be one of type string, Buffer, or URL. Received type object
            at Object.lstatSync (fs.js:857:3)
            at VisDebug.enableDebug (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupVisDebug.js:52:36)
            at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2464:30
            at Object.connected (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3145:70)
            at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:87:68)
            at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
            at Socket.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:138:10)
            at Socket.onconnect (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:335:8)
            at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:232:12)
            at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
        [object Object]
        /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupVisDebug.js:67
        Adapter not found. Tried: vis-vis-taragorm, vis-taragorm
        • T
        • T Taragorm
                  if (widgetset) {
                      var adapterDir;
                          try {
                              // Query the entry
                                  //found it!
                                  break;
                          } catch (e) {
                              console.error(e);
          and got this:
          [object Object]
          • T
          @Taragorm Can it be, that you have js-controller 1.4.2? Please update to 1.5.7
          • T
            T
            Taragorm
            Certainly looks to be 1.4.2
            iobroker@iobrokerdev /o/iobroker> npm outdated
            Package                 Current  Wanted  Latest  Location
            iobroker.js-controller    1.4.2   1.4.2   1.5.7  iobroker.inst
            yargs                     7.1.0   7.1.0  13.2.2  iobroker.inst
            main iobroker package calls for "stable", rather than a particular rev - do I just alter the depend there and npm update - or is there a "proper" way to do it?
            • T Taragorm
              @Taragorm via npm is ok. Just stop iob before update
              • T
                T
                Taragorm
                Update
                Reloaded iobroker from scratch, just to be sure
                Updated iob.js-controller to 1.5.7
                iobroker@iobrokerdev /o/iobroker> npm list iobroker.js-controller
                iobroker.inst@2.0.2 /opt/iobroker
                └── iobroker.js-controller@1.5.7
                Same error on iob visdebug
                Also
                Lots of warnings caused by this:
                └─┬ iobroker.js-controller@1.5.7
                  └─┬ winston-syslog@1.2.6
                    └── UNMET OPTIONAL DEPENDENCY unix-dgram@~0.2.1
                Is there any way to suppress it? I hate clutter in the logfiles!
                Also2
                I can't see my widget in the vis builder. There's no obvious error in the log tho.
                • T
                  T
                  Taragorm
                  done a bit more digging into the visdebug error, and it seems like the project folder isn't being recognised as a directory:
                  Trying:/opt/iobroker/iobroker.vis-taragorm
                  Got stats:{"dev":2049,"mode":41471,"nlink":1,"uid":1001,"gid":1001,"rdev":0,"blksize":4096,"ino":792374,"size":24,"blocks":0,"atimeMs":1552471012718.894,"mtimeMs":1552471012714.892,"ctimeMs":1552471012714.892,"birthtimeMs":1552471012714.892,"atime":"2019-03-13T09:56:52.719Z","mtime":"2019-03-13T09:56:52.715Z","ctime":"2019-03-13T09:56:52.715Z","birthtime":"2019-03-13T09:56:52.715Z"}  isDir=false
                  trace code:
                                      console.log("Trying:" + process.cwd() + "/" + adapterNames2Try[i]);
                                      // Query the entry
                                      console.log("Got stats:" + JSON.stringify(stats) + "  isDir=" + stats.isDirectory());
                  But it surely is a dir:
                  iobroker@iobrokerdev /o/iobroker> ls -l
                  total 248
                  -rw-rwxr--+   1 iobroker iobroker   1474 Mar 13 09:40 CHANGELOG_INSTALLER_LINUX.md*
                  drwxrwxr-x+   3 iobroker iobroker   4096 Mar 13 09:40 install/
                  -rwxrwxrwx+   1 iobroker iobroker    169 Mar 13 09:41 INSTALLER_INFO.txt*
                  lrwxrwxrwx    1 iobroker iobroker     22 Mar 13 09:41 iob -> /opt/iobroker/iobroker*
                  -rwxrwxr-x+   1 iobroker iobroker    209 Mar 13 09:41 iobroker*
                  drwxrwxrwx+   4 iobroker iobroker   4096 Mar 13 09:42 iobroker-data/
                  drwxrwxrwx+   8 iobroker iobroker   4096 Mar 13 09:59 iobroker.vis-taragorm/
                  -rw-rwxrw-+   1 iobroker iobroker     92 Mar 13 09:41 killall.sh*
                  drwxrwxr-x+   2 iobroker iobroker   4096 Mar 13 09:40 lib/
                  -rw-rwxr--+   1 iobroker iobroker   1137 Mar 13 09:40 LICENSE*
                  drwxrwxrwx+   2 iobroker iobroker   4096 Mar 13 09:41 log/
                  drwxrwxr-x+ 451 iobroker iobroker  20480 Mar 13 09:56 node_modules/
                  -rw-rwxrw-+   1 iobroker iobroker    658 Mar 13 09:56 package.json*
                  -rw-rwxrw-+   1 iobroker iobroker 166878 Mar 13 09:41 package-lock.json*
                  -rw-rwxr--+   1 iobroker iobroker   6101 Mar 13 09:40 README.md*
                  -rw-rw-rw-+   1 iobroker iobroker   5868 Mar 13 09:51 reinstall.js
                  -rw-rwxrw-+   1 iobroker iobroker    709 Mar 13 09:41 reinstall.sh*
                  it's as if fs is misbehaving?
                  • T Taragorm
                    trace code:
                                        // Query the entry
                    total 248
                    schrieb am zuletzt editiert von Bluefox
                    @Taragorm is the normal iobroker upload vis does not work?
                    You can force all the steps manually.
                    1. Copy your widgets files into /opt/iobroker/node_modules/iobroker.vis/www/widgets directory.
                    2. Change /opt/iobroker/node_modules/iobroker.vis/www/js/config.js
                    3. Change /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest (just add/change some char to change the hash)
                    4. iobroker u vis
                    5. To be sure clear the browser cache
                    • T
                      T
                      Taragorm
                      fyi, in enableDebug I think:
                      maybe should be
                      var stats = fs.statSync(adapterDir2Try);
                      As diagnostics suggest we're finding the link, and lstatSync() returns the link itself, rather than the target of the link.
                      Changing it, lets things go a bit further, but it still fails somewhat messily:
                      Got stats:{"dev":2049,"mode":16895,"nlink":8,"uid":1001,"gid":1001,"rdev":0,"blksize":4096,"ino":791105,"size":4096,"blocks":8,"atimeMs":1552471286715.824,"mtimeMs":1552471172270.63,"ctimeMs":1552471172270.63,"birthtimeMs":1552471172270.63,"atime":"2019-03-13T10:01:26.716Z","mtime":"2019-03-13T09:59:32.271Z","ctime":"2019-03-13T09:59:32.271Z","birthtime":"2019-03-13T09:59:32.271Z"}  isDir=true isLink=false
                      Upload "/opt/iobroker/node_modules/iobroker.vis/www/index.html.original"
                      fs.js:119
                          throw err;
                      Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../iobroker.vis/www/index.html.original'
                          at Object.openSync (fs.js:448:3)
                          at Object.readFileSync (fs.js:348:35)
                          at VisDebug.enableDebug (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupVisDebug.js:91:23)
                          at _objects (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2460:30)
                          at Object.connected (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3133:17)
                          at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                          at Socket.emit (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:136:10)
                          at Socket.onconnect (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:328:8)
                          at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:224:12)
                      For now, I'm going to switch my development environment to Windows, as that seems to be working for you.
                      • T Taragorm
                        maybe should be
                        fs.js:119
                            throw err;
                        @Taragorm It is very well, that you want to get the visbebug runnnig, but
                        I don't understand, why you ignore my other suggestions:
                        • https://forum.iobroker.net/topic/19929/getting-started-with-visualisations/15
                        • https://forum.iobroker.net/topic/19929/getting-started-with-visualisations/8
                        The problem with non existing index.html.original is fixed only on github.
                        • BluefoxB Bluefox
                          Not Fast, but work.
                          T
                          T
                          Taragorm
                          @Bluefox I
                          @Bluefox said in getting started with visualisations:
                          Not Fast, but work.
                          I tried this; I don't get any errors, but I don't get a visualisation in the toolbox either.
                          That's why I trying to enable debug.
                          • BluefoxB Bluefox
                            @Taragorm I do it like this.
                            My folder structure is like this one:
                            /opt/iobroker
                                    iobroker.my-new-adapter
                                    node_modules
                                           iobroker.js-controle
                                           iobroker.xxxx
                            Then I install my new adapter by writing npm i iobroker.my-new-adapter in /opt/iobroker.
                            As result the npm creates a sym-link to my developer folder:
                            /opt/iobroker
                                    node_modules
                                           iobroker.my-new-adapter (symlink)
                                           iobroker.xxxx
                            after that I develop my adapter as usual in /opt/iobroker/iobroker.my-new-adapter even as a git repo.
                            after every change I write iobroker r vis && iobroker u vis This should work 100%.
                            Additionally I can write iobroker visdebug my-new-adapter and if I see the output
                            Disable cache I restart the iobroker (only for the first time).
                            After that I can directly modify the file /opt/iobroker/iobroker-data/files/vis/widgets/my-new-adapter.html and after every browser refresh it will be loaded anew from disk. So you can fast see your changes.
                            But, the changes in /opt/iobroker/iobroker-data/files/vis/widgets/my-new-adapter.html must be copied to /opt/iobroker/iobroker.my-new-adapter/widgets/ manually and you may not call iobroker u vis till you do that, else they will be overwritten
                            T
                            T
                            Taragorm
                            /opt/iobroker
                                    node_modules
                                           iobroker.xxxx
                            /opt/iobroker
                                    node_modules
                                           iobroker.xxxx
                            ...and I have also set my environment up like this.
                            • BluefoxB
                              Please set here the names without vis-
                              • BluefoxB
                                And you may not change class.
                                • T
                                  T
                                  Taragorm
                                  thanks, will do
                                  • T
                                    T
                                    Taragorm
                                    It's showing in the toolbox now - many thanks!
                                    • T
                                      T
                                      Taragorm
                                      Much progress, but another small issue.
                                      My visualisation shows values ok in the edit dialog.
                                      In the normal view, it shows the "undefined" value... unless the value is used by a different widget.
                                      This suggests I've done something wrong in binding, but as far as I can see, I've done pretty much what the template does.
                                      Have I missed something out? It feels like whatever code that populates vis.states[] hasn't been invoked correctly. (i.e. the view seems to be unaware of the points I'm asking for).
                                      • T
                                        T
                                        Taragorm
                                        ps: Changed the repo to: https://github.com/Taragorm/ioBroker.vistaragorm
                                        • T Taragorm
                                          @Taragorm It can be, that I forgot to describe, that all ObjectID Variables Names must start with "oid..." or end with "...oid" or "...oidN" (N is any number from 0 to 99)
                                          Please use following files, that work:
                                          vistaragorm.js
                                          vistaragorm.html
                                          83.8k
