  2. English
  3. Visualization
  4. getting started with visualisations
    5.6k
Geplant Angeheftet Gesperrt Verschoben Visualization
vis
43 Beiträge 4 Kommentatoren 9.2k Aufrufe 4 Beobachtet
    Taragorm
    Thanks for the quick response!
    The repo is up at: https://github.com/Taragorm/ioBroker.vis-taragorm
    It's mostly template right now.
    This is intended for some generic visualisations (and to practice in) so I didn't include it in the evohome repo. I'll add some specific visualisations there once I know what I'm doing.
    • BluefoxB Bluefox
      Участник @Taragorm написал в getting started with visualisations:
      /opt/iobroker/node_modules/iobroker.js-controller/
      It would be easier, if I can see the repo on github.
      Do you have file /opt/iobroker/node_modules/iobroker.vis-taragorm/widgets/taragorm.html ?
      Taragorm
      @Bluefox
      iobroker@iobrokerdev ~/projects> ls -l /opt/iobroker/node_modules/iobroker.vis-taragorm/widgets
      total 12
      drwxrwxrwx+ 4 iobroker iobroker 4096 Mar  2 10:26 vis-taragorm/
      -rw-r--r--+ 1 iobroker iobroker 6521 Mar  2 11:47 vis-taragorm.html
      Seems to be there...
      BluefoxB 1 Antwort Letzte Antwort
      • T Taragorm
        @Bluefox
        total 12
        BluefoxB Offline
        BluefoxB Offline
        @Taragorm No matter. With iobroker r vis && iobroker u vis it should work.
        Not Fast, but work.
        Just tried to execute (windows):
        and cannot see any errors
          Taragorm
          Something broken with my install, maybe?
          I added a bit of logging to the empty catch block (line 24 here):
              this.enableDebug = function (widgetset) {
                  console.log( "widgetset=" + widgetset );
                  if (widgetset) {
                      // Try to find out the adapter directory out of a list of options
                      var adapterDir;
                      var adapterNames2Try = ['vis-' + widgetset, widgetset];
                      if (adapterNames2Try[0] === adapterNames2Try[1]) adapterNames2Try.splice(1, 1);
                      for (var i = 0; i < adapterNames2Try.length; i++) {
                          try {
                              var adapterDir2Try = tools.getAdapterDir(adapterNames2Try[i]);
                              // Query the entry
                              var stats = fs.lstatSync(adapterDir2Try);
                              console.log(stats.toString() );
                              // Is it a directory?
                              if (stats.isDirectory()) {
                                  //found it!
                                  adapterDir = adapterDir2Try;
                                  break;
                          } catch (e) {
                              console.error(e);
                      if (!adapterDir) throw 'Adapter not found. Tried: ' + adapterNames2Try.join(', ');
          and got this:
          obroker@iobrokerdev /o/iobroker> iobroker visdebug vis-taragorm
          widgetset=vis-taragorm
          TypeError [ERR_INVALID_ARG_TYPE]: The "path" argument must be one of type string, Buffer, or URL. Received type object
              at Object.lstatSync (fs.js:857:3)
              at VisDebug.enableDebug (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupVisDebug.js:52:36)
              at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2464:30
              at Object.connected (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3145:70)
              at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:87:68)
              at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
              at Socket.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:138:10)
              at Socket.onconnect (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:335:8)
              at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:232:12)
              at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
          [object Object]
          /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupVisDebug.js:67
          Adapter not found. Tried: vis-vis-taragorm, vis-taragorm
          • T
          • T Taragorm
                    if (widgetset) {
                        var adapterDir;
                            try {
                                // Query the entry
                                    //found it!
                                    break;
                            } catch (e) {
                                console.error(e);
            and got this:
            [object Object]
            • T
            BluefoxB Offline
            BluefoxB Offline
            @Taragorm Can it be, that you have js-controller 1.4.2? Please update to 1.5.7
              Taragorm
              Certainly looks to be 1.4.2
              iobroker@iobrokerdev /o/iobroker> npm outdated
              Package                 Current  Wanted  Latest  Location
              iobroker.js-controller    1.4.2   1.4.2   1.5.7  iobroker.inst
              yargs                     7.1.0   7.1.0  13.2.2  iobroker.inst
              main iobroker package calls for "stable", rather than a particular rev - do I just alter the depend there and npm update - or is there a "proper" way to do it?
              • T Taragorm
                BluefoxB Offline
                BluefoxB Offline
                @Taragorm via npm is ok. Just stop iob before update
                  Taragorm
                  Update
                  Reloaded iobroker from scratch, just to be sure
                  Updated iob.js-controller to 1.5.7
                  iobroker@iobrokerdev /o/iobroker> npm list iobroker.js-controller
                  iobroker.inst@2.0.2 /opt/iobroker
                  └── iobroker.js-controller@1.5.7
                  Same error on iob visdebug
                  Also
                  Lots of warnings caused by this:
                  └─┬ iobroker.js-controller@1.5.7
                    └─┬ winston-syslog@1.2.6
                      └── UNMET OPTIONAL DEPENDENCY unix-dgram@~0.2.1
                  Is there any way to suppress it? I hate clutter in the logfiles!
                  Also2
                  I can't see my widget in the vis builder. There's no obvious error in the log tho.
                    Taragorm
                    done a bit more digging into the visdebug error, and it seems like the project folder isn't being recognised as a directory:
                    Trying:/opt/iobroker/iobroker.vis-taragorm
                    Got stats:{"dev":2049,"mode":41471,"nlink":1,"uid":1001,"gid":1001,"rdev":0,"blksize":4096,"ino":792374,"size":24,"blocks":0,"atimeMs":1552471012718.894,"mtimeMs":1552471012714.892,"ctimeMs":1552471012714.892,"birthtimeMs":1552471012714.892,"atime":"2019-03-13T09:56:52.719Z","mtime":"2019-03-13T09:56:52.715Z","ctime":"2019-03-13T09:56:52.715Z","birthtime":"2019-03-13T09:56:52.715Z"}  isDir=false
                    trace code:
                                        console.log("Trying:" + process.cwd() + "/" + adapterNames2Try[i]);
                                        // Query the entry
                                        console.log("Got stats:" + JSON.stringify(stats) + "  isDir=" + stats.isDirectory());
                    But it surely is a dir:
                    iobroker@iobrokerdev /o/iobroker> ls -l
                    total 248
                    -rw-rwxr--+   1 iobroker iobroker   1474 Mar 13 09:40 CHANGELOG_INSTALLER_LINUX.md*
                    drwxrwxr-x+   3 iobroker iobroker   4096 Mar 13 09:40 install/
                    -rwxrwxrwx+   1 iobroker iobroker    169 Mar 13 09:41 INSTALLER_INFO.txt*
                    lrwxrwxrwx    1 iobroker iobroker     22 Mar 13 09:41 iob -> /opt/iobroker/iobroker*
                    -rwxrwxr-x+   1 iobroker iobroker    209 Mar 13 09:41 iobroker*
                    drwxrwxrwx+   4 iobroker iobroker   4096 Mar 13 09:42 iobroker-data/
                    drwxrwxrwx+   8 iobroker iobroker   4096 Mar 13 09:59 iobroker.vis-taragorm/
                    -rw-rwxrw-+   1 iobroker iobroker     92 Mar 13 09:41 killall.sh*
                    drwxrwxr-x+   2 iobroker iobroker   4096 Mar 13 09:40 lib/
                    -rw-rwxr--+   1 iobroker iobroker   1137 Mar 13 09:40 LICENSE*
                    drwxrwxrwx+   2 iobroker iobroker   4096 Mar 13 09:41 log/
                    drwxrwxr-x+ 451 iobroker iobroker  20480 Mar 13 09:56 node_modules/
                    -rw-rwxrw-+   1 iobroker iobroker    658 Mar 13 09:56 package.json*
                    -rw-rwxrw-+   1 iobroker iobroker 166878 Mar 13 09:41 package-lock.json*
                    -rw-rwxr--+   1 iobroker iobroker   6101 Mar 13 09:40 README.md*
                    -rw-rw-rw-+   1 iobroker iobroker   5868 Mar 13 09:51 reinstall.js
                    -rw-rwxrw-+   1 iobroker iobroker    709 Mar 13 09:41 reinstall.sh*
                    it's as if fs is misbehaving?
                    • T Taragorm
                      trace code:
                                          // Query the entry
                      total 248
                      BluefoxB Offline
                      BluefoxB Offline
                      schrieb am zuletzt editiert von Bluefox
                      @Taragorm is the normal iobroker upload vis does not work?
                      You can force all the steps manually.
                      1. Copy your widgets files into /opt/iobroker/node_modules/iobroker.vis/www/widgets directory.
                      2. Change /opt/iobroker/node_modules/iobroker.vis/www/js/config.js
                      3. Change /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest (just add/change some char to change the hash)
                      4. iobroker u vis
                      5. To be sure clear the browser cache
                        Taragorm
                        fyi, in enableDebug I think:
                        maybe should be
                        var stats = fs.statSync(adapterDir2Try);
                        As diagnostics suggest we're finding the link, and lstatSync() returns the link itself, rather than the target of the link.
                        Changing it, lets things go a bit further, but it still fails somewhat messily:
                        Got stats:{"dev":2049,"mode":16895,"nlink":8,"uid":1001,"gid":1001,"rdev":0,"blksize":4096,"ino":791105,"size":4096,"blocks":8,"atimeMs":1552471286715.824,"mtimeMs":1552471172270.63,"ctimeMs":1552471172270.63,"birthtimeMs":1552471172270.63,"atime":"2019-03-13T10:01:26.716Z","mtime":"2019-03-13T09:59:32.271Z","ctime":"2019-03-13T09:59:32.271Z","birthtime":"2019-03-13T09:59:32.271Z"}  isDir=true isLink=false
                        Upload "/opt/iobroker/node_modules/iobroker.vis/www/index.html.original"
                        fs.js:119
                            throw err;
                        Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../iobroker.vis/www/index.html.original'
                            at Object.openSync (fs.js:448:3)
                            at Object.readFileSync (fs.js:348:35)
                            at VisDebug.enableDebug (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupVisDebug.js:91:23)
                            at _objects (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2460:30)
                            at Object.connected (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3133:17)
                            at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                            at Socket.emit (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:136:10)
                            at Socket.onconnect (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:328:8)
                            at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:224:12)
                        For now, I'm going to switch my development environment to Windows, as that seems to be working for you.
                        • T Taragorm
                          maybe should be
                          fs.js:119
                              throw err;
                          BluefoxB Offline
                          BluefoxB Offline
                          @Taragorm It is very well, that you want to get the visbebug runnnig, but
                          I don't understand, why you ignore my other suggestions:
                          • https://forum.iobroker.net/topic/19929/getting-started-with-visualisations/15
                          • https://forum.iobroker.net/topic/19929/getting-started-with-visualisations/8
                          The problem with non existing index.html.original is fixed only on github.
                          • BluefoxB Bluefox
                            Not Fast, but work.
                            Taragorm
                            @Bluefox I
                            @Bluefox said in getting started with visualisations:
                            Not Fast, but work.
                            I tried this; I don't get any errors, but I don't get a visualisation in the toolbox either.
                            That's why I trying to enable debug.
                            • BluefoxB Bluefox
                              @Taragorm I do it like this.
                              My folder structure is like this one:
                              /opt/iobroker
                                      iobroker.my-new-adapter
                                      node_modules
                                             iobroker.js-controle
                                             iobroker.xxxx
                              Then I install my new adapter by writing npm i iobroker.my-new-adapter in /opt/iobroker.
                              As result the npm creates a sym-link to my developer folder:
                              /opt/iobroker
                                      node_modules
                                             iobroker.my-new-adapter (symlink)
                                             iobroker.xxxx
                              after that I develop my adapter as usual in /opt/iobroker/iobroker.my-new-adapter even as a git repo.
                              after every change I write iobroker r vis && iobroker u vis This should work 100%.
                              Additionally I can write iobroker visdebug my-new-adapter and if I see the output
                              Disable cache I restart the iobroker (only for the first time).
                              After that I can directly modify the file /opt/iobroker/iobroker-data/files/vis/widgets/my-new-adapter.html and after every browser refresh it will be loaded anew from disk. So you can fast see your changes.
                              But, the changes in /opt/iobroker/iobroker-data/files/vis/widgets/my-new-adapter.html must be copied to /opt/iobroker/iobroker.my-new-adapter/widgets/ manually and you may not call iobroker u vis till you do that, else they will be overwritten
                              Taragorm
                              /opt/iobroker
                                      node_modules
                                             iobroker.xxxx
                              /opt/iobroker
                                      node_modules
                                             iobroker.xxxx
                              ...and I have also set my environment up like this.
                              • BluefoxB Offline
                                BluefoxB Offline
                                Please set here the names without vis-
                                • BluefoxB Offline
                                  BluefoxB Offline
                                  And you may not change class.
                                    Taragorm
                                    thanks, will do
                                      Taragorm
                                      It's showing in the toolbox now - many thanks!
                                        Taragorm
                                        Much progress, but another small issue.
                                        My visualisation shows values ok in the edit dialog.
                                        In the normal view, it shows the "undefined" value... unless the value is used by a different widget.
                                        This suggests I've done something wrong in binding, but as far as I can see, I've done pretty much what the template does.
                                        Have I missed something out? It feels like whatever code that populates vis.states[] hasn't been invoked correctly. (i.e. the view seems to be unaware of the points I'm asking for).
                                          Taragorm
                                          ps: Changed the repo to: https://github.com/Taragorm/ioBroker.vistaragorm
