  2. English
  3. Visualization
  4. getting started with visualisations
Geplant Angeheftet Gesperrt Verschoben Visualization
vis
43 Beiträge 4 Kommentatoren 11.0k Aufrufe 4 Beobachtet
  • T
    T
    Taragorm
    Another question - what is the best procedure for visualisation development?
    I have a local project (under home) that contains the development package; I can install that using the customURL function.
    So far, so good.
    After I've changed the package, and re-installed, nothing seems to change, so there must be more to it.
    BluefoxB 1 Antwort Letzte Antwort
    • T Taragorm
      So far, so good.
      @Taragorm Have you seen that? https://github.com/ioBroker/ioBroker/wiki/How-to-debug-vis-and-to-write-own-widget-set
      T S 2 Antworten Letzte Antwort
      • BluefoxB Bluefox
        T
        T
        Taragorm
        @Bluefox I have, and I think I followed the instructions, but if I reinstall my adaptor using "from custom URL", nothing much seems to change, even if I restart iobroker.
        Clearly I'm doing something wrong?
        • T Taragorm
          schrieb am zuletzt editiert von Bluefox
          @Taragorm I do it like this.
          My folder structure is like this one:
          /opt/iobroker
                  iobroker.my-new-adapter
                  node_modules
                         iobroker.js-controle
                         iobroker.xxxx
          Then I install my new adapter by writing npm i iobroker.my-new-adapter in /opt/iobroker.
          As result the npm creates a sym-link to my developer folder:
          /opt/iobroker
                  node_modules
                         iobroker.my-new-adapter (symlink)
                         iobroker.xxxx
          after that I develop my adapter as usual in /opt/iobroker/iobroker.my-new-adapter even as a git repo.
          after every change I write iobroker r vis && iobroker u vis This should work 100%.
          Additionally I can write iobroker visdebug my-new-adapter and if I see the output
          Disable cache I restart the iobroker (only for the first time).
          After that I can directly modify the file /opt/iobroker/iobroker-data/files/vis/widgets/my-new-adapter.html and after every browser refresh it will be loaded anew from disk. So you can fast see your changes.
          But, the changes in /opt/iobroker/iobroker-data/files/vis/widgets/my-new-adapter.html must be copied to /opt/iobroker/iobroker.my-new-adapter/widgets/ manually and you may not call iobroker u vis till you do that, else they will be overwritten
          • T
            T
            Taragorm
            Thanks - that's exactly what I needed to know
            • T
              T
              Taragorm
              Hmm.
              The module is iobroker.vis-taragorm
              iobroker@iobrokerdev /o/iobroker> iobroker visdebug vis-taragorm
              /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupVisDebug.js:64
                          if (!adapterDir) throw 'Adapter not found. Tried: ' + adapterNames2Try.join(', ');
              Adapter not found. Tried: vis-vis-taragorm, vis-taragorm
              however, vis-taragorm.html does exist in widgets, and there is an instance installed ok. I can't see my widget in the list though.
              Possiby unrelated, I should also note that I got some errors installing (and many warnings, but I didn't include those):
              unix_dgram.target.mk:101: recipe for target 'Release/obj.target/unix_dgram/src/unix_dgram.o' failed
              make: *** [Release/obj.target/unix_dgram/src/unix_dgram.o] Error 1
              make: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
              gyp ERR! build error
              gyp ERR! stack Error: `make` failed with exit code: 2
              gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
              gyp ERR! stack     at ChildProcess.emit (events.js:197:13)
              gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:254:12)
              gyp ERR! System Linux 4.9.0-8-amd64
              gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
              gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
              gyp ERR! node -v v11.10.1
              gyp ERR! node-gyp -v v3.8.0
              gyp ERR! not ok
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules/unix-dgram):
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install: `node-gyp rebuild`
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
              The last message implies this isn't fatal, but I'm new to NodeJS...
              The dev env is Debian Stretch
              iobroker@iobrokerdev ~/projects> uname -a
              Linux iobrokerdev 4.9.0-8-amd64 #1 SMP Debian 4.9.130-2 (2018-10-27) x86_64 GNU/Linux
              • BluefoxB
                Участник @Taragorm написал в getting started with visualisations:
                It would be easier, if I can see the repo on github.
                Do you have file /opt/iobroker/node_modules/iobroker.vis-taragorm/widgets/taragorm.html ?
                • BluefoxB
                  BTW, you can deliver in your adapter https://github.com/Taragorm/ioBroker.evohome the widgets too. It is even better.
                  • T
                    T
                    Taragorm
                    Thanks for the quick response!
                    The repo is up at: https://github.com/Taragorm/ioBroker.vis-taragorm
                    It's mostly template right now.
                    This is intended for some generic visualisations (and to practice in) so I didn't include it in the evohome repo. I'll add some specific visualisations there once I know what I'm doing.
                    • BluefoxB Bluefox
                      T
                      T
                      Taragorm
                      @Bluefox
                      iobroker@iobrokerdev ~/projects> ls -l /opt/iobroker/node_modules/iobroker.vis-taragorm/widgets
                      total 12
                      drwxrwxrwx+ 4 iobroker iobroker 4096 Mar  2 10:26 vis-taragorm/
                      -rw-r--r--+ 1 iobroker iobroker 6521 Mar  2 11:47 vis-taragorm.html
                      Seems to be there...
                      • T Taragorm
                        @Bluefox
                        total 12
                        @Taragorm No matter. With iobroker r vis && iobroker u vis it should work.
                        Not Fast, but work.
                        Just tried to execute (windows):
                        and cannot see any errors
                        • T
                          T
                          Taragorm
                          Something broken with my install, maybe?
                          I added a bit of logging to the empty catch block (line 24 here):
                              this.enableDebug = function (widgetset) {
                                  console.log( "widgetset=" + widgetset );
                                  if (widgetset) {
                                      // Try to find out the adapter directory out of a list of options
                                      var adapterDir;
                                      var adapterNames2Try = ['vis-' + widgetset, widgetset];
                                      if (adapterNames2Try[0] === adapterNames2Try[1]) adapterNames2Try.splice(1, 1);
                                      for (var i = 0; i < adapterNames2Try.length; i++) {
                                          try {
                                              var adapterDir2Try = tools.getAdapterDir(adapterNames2Try[i]);
                                              // Query the entry
                                              var stats = fs.lstatSync(adapterDir2Try);
                                              console.log(stats.toString() );
                                              // Is it a directory?
                                              if (stats.isDirectory()) {
                                                  //found it!
                                                  adapterDir = adapterDir2Try;
                                                  break;
                                          } catch (e) {
                                              console.error(e);
                          and got this:
                          widgetset=vis-taragorm
                          TypeError [ERR_INVALID_ARG_TYPE]: The "path" argument must be one of type string, Buffer, or URL. Received type object
                              at Object.lstatSync (fs.js:857:3)
                              at VisDebug.enableDebug (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupVisDebug.js:52:36)
                              at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2464:30
                              at Object.connected (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3145:70)
                              at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:87:68)
                              at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
                              at Socket.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:138:10)
                              at Socket.onconnect (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:335:8)
                              at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:232:12)
                              at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                          [object Object]
                          /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupVisDebug.js:67
                          • T
                          • T Taragorm
                                    if (widgetset) {
                                        var adapterDir;
                                            try {
                                                // Query the entry
                                                    //found it!
                                                    break;
                                            } catch (e) {
                                                console.error(e);
                            and got this:
                            [object Object]
                            • T
                            @Taragorm Can it be, that you have js-controller 1.4.2? Please update to 1.5.7
                            • T
                              T
                              Taragorm
                              Certainly looks to be 1.4.2
                              iobroker@iobrokerdev /o/iobroker> npm outdated
                              Package                 Current  Wanted  Latest  Location
                              iobroker.js-controller    1.4.2   1.4.2   1.5.7  iobroker.inst
                              yargs                     7.1.0   7.1.0  13.2.2  iobroker.inst
                              main iobroker package calls for "stable", rather than a particular rev - do I just alter the depend there and npm update - or is there a "proper" way to do it?
                              • T Taragorm
                                @Taragorm via npm is ok. Just stop iob before update
                                • T
                                  T
                                  Taragorm
                                  Update
                                  Reloaded iobroker from scratch, just to be sure
                                  Updated iob.js-controller to 1.5.7
                                  iobroker@iobrokerdev /o/iobroker> npm list iobroker.js-controller
                                  iobroker.inst@2.0.2 /opt/iobroker
                                  └── iobroker.js-controller@1.5.7
                                  Same error on iob visdebug
                                  Also
                                  Lots of warnings caused by this:
                                  └─┬ iobroker.js-controller@1.5.7
                                    └─┬ winston-syslog@1.2.6
                                      └── UNMET OPTIONAL DEPENDENCY unix-dgram@~0.2.1
                                  Is there any way to suppress it? I hate clutter in the logfiles!
                                  Also2
                                  I can't see my widget in the vis builder. There's no obvious error in the log tho.
                                  • T
                                    T
                                    Taragorm
                                    done a bit more digging into the visdebug error, and it seems like the project folder isn't being recognised as a directory:
                                    Trying:/opt/iobroker/iobroker.vis-taragorm
                                    Got stats:{"dev":2049,"mode":41471,"nlink":1,"uid":1001,"gid":1001,"rdev":0,"blksize":4096,"ino":792374,"size":24,"blocks":0,"atimeMs":1552471012718.894,"mtimeMs":1552471012714.892,"ctimeMs":1552471012714.892,"birthtimeMs":1552471012714.892,"atime":"2019-03-13T09:56:52.719Z","mtime":"2019-03-13T09:56:52.715Z","ctime":"2019-03-13T09:56:52.715Z","birthtime":"2019-03-13T09:56:52.715Z"}  isDir=false
                                    trace code:
                                                        console.log("Trying:" + process.cwd() + "/" + adapterNames2Try[i]);
                                                        // Query the entry
                                                        console.log("Got stats:" + JSON.stringify(stats) + "  isDir=" + stats.isDirectory());
                                    But it surely is a dir:
                                    iobroker@iobrokerdev /o/iobroker> ls -l
                                    total 248
                                    -rw-rwxr--+   1 iobroker iobroker   1474 Mar 13 09:40 CHANGELOG_INSTALLER_LINUX.md*
                                    drwxrwxr-x+   3 iobroker iobroker   4096 Mar 13 09:40 install/
                                    -rwxrwxrwx+   1 iobroker iobroker    169 Mar 13 09:41 INSTALLER_INFO.txt*
                                    lrwxrwxrwx    1 iobroker iobroker     22 Mar 13 09:41 iob -> /opt/iobroker/iobroker*
                                    -rwxrwxr-x+   1 iobroker iobroker    209 Mar 13 09:41 iobroker*
                                    drwxrwxrwx+   4 iobroker iobroker   4096 Mar 13 09:42 iobroker-data/
                                    drwxrwxrwx+   8 iobroker iobroker   4096 Mar 13 09:59 iobroker.vis-taragorm/
                                    -rw-rwxrw-+   1 iobroker iobroker     92 Mar 13 09:41 killall.sh*
                                    drwxrwxr-x+   2 iobroker iobroker   4096 Mar 13 09:40 lib/
                                    -rw-rwxr--+   1 iobroker iobroker   1137 Mar 13 09:40 LICENSE*
                                    drwxrwxrwx+   2 iobroker iobroker   4096 Mar 13 09:41 log/
                                    drwxrwxr-x+ 451 iobroker iobroker  20480 Mar 13 09:56 node_modules/
                                    -rw-rwxrw-+   1 iobroker iobroker    658 Mar 13 09:56 package.json*
                                    -rw-rwxrw-+   1 iobroker iobroker 166878 Mar 13 09:41 package-lock.json*
                                    -rw-rwxr--+   1 iobroker iobroker   6101 Mar 13 09:40 README.md*
                                    -rw-rw-rw-+   1 iobroker iobroker   5868 Mar 13 09:51 reinstall.js
                                    -rw-rwxrw-+   1 iobroker iobroker    709 Mar 13 09:41 reinstall.sh*
                                    it's as if fs is misbehaving?
                                    • T Taragorm
                                      trace code:
                                                          // Query the entry
                                      total 248
                                      @Taragorm is the normal iobroker upload vis does not work?
                                      You can force all the steps manually.
                                      1. Copy your widgets files into /opt/iobroker/node_modules/iobroker.vis/www/widgets directory.
                                      2. Change /opt/iobroker/node_modules/iobroker.vis/www/js/config.js
                                      3. Change /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest (just add/change some char to change the hash)
                                      4. iobroker u vis
                                      5. To be sure clear the browser cache
                                      • T
                                        T
                                        Taragorm
                                        fyi, in enableDebug I think:
                                        maybe should be
                                        var stats = fs.statSync(adapterDir2Try);
                                        As diagnostics suggest we're finding the link, and lstatSync() returns the link itself, rather than the target of the link.
                                        Changing it, lets things go a bit further, but it still fails somewhat messily:
                                        Got stats:{"dev":2049,"mode":16895,"nlink":8,"uid":1001,"gid":1001,"rdev":0,"blksize":4096,"ino":791105,"size":4096,"blocks":8,"atimeMs":1552471286715.824,"mtimeMs":1552471172270.63,"ctimeMs":1552471172270.63,"birthtimeMs":1552471172270.63,"atime":"2019-03-13T10:01:26.716Z","mtime":"2019-03-13T09:59:32.271Z","ctime":"2019-03-13T09:59:32.271Z","birthtime":"2019-03-13T09:59:32.271Z"}  isDir=true isLink=false
                                        Upload "/opt/iobroker/node_modules/iobroker.vis/www/index.html.original"
                                        fs.js:119
                                            throw err;
                                        Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../iobroker.vis/www/index.html.original'
                                            at Object.openSync (fs.js:448:3)
                                            at Object.readFileSync (fs.js:348:35)
                                            at VisDebug.enableDebug (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupVisDebug.js:91:23)
                                            at _objects (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2460:30)
                                            at Object.connected (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3133:17)
                                            at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                                            at Socket.emit (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:136:10)
                                            at Socket.onconnect (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:328:8)
                                            at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:224:12)
                                        For now, I'm going to switch my development environment to Windows, as that seems to be working for you.
                                        • T Taragorm
                                          maybe should be
                                          fs.js:119
                                              throw err;
                                          @Taragorm It is very well, that you want to get the visbebug runnnig, but
                                          I don't understand, why you ignore my other suggestions:
                                          • https://forum.iobroker.net/topic/19929/getting-started-with-visualisations/15
                                          • https://forum.iobroker.net/topic/19929/getting-started-with-visualisations/8
                                          The problem with non existing index.html.original is fixed only on github.
                                          84.2k
