  2. English
  3. Visualization
  4. getting started with visualisations
Geplant Angeheftet Gesperrt Verschoben Visualization
vis
43 Beiträge 4 Kommentatoren 9.7k Aufrufe 4 Beobachtet
  • T
    T
    Taragorm
    My, it's quiet in here.
    Having just written my first adaptor, https://github.com/Taragorm/ioBroker.evohome, I'd like to make some custom Visulaisations for it.
    I know enough JS, HTML and CSS to know how to do the business logic. I don't (I think) need help with that.
    I've pulled the template, but there seems to be a lot there I don't understand, doubtless due to a lot of libraries I'm not familiar with. I can guess at some of the following, but I prefer not to guess :)
    Specifics would be:
    • How must a widget register itself/what interface must it provide to be loaded into ioBroker.vis?
    • How are configuration parameters provided?
    • Do you have to provide a custom editor view? Can you, if you need to?
    • How does live data subscription work?
    • Conversely, how are values written back to states?
    If there's a good description somewhere (even in German, that I can use Google Translate on), I'm happy to go and read it before asking further questions.
    -T
    BluefoxB 1 Antwort Letzte Antwort
    • T Taragorm
      Specifics would be:
      -T
      schrieb am zuletzt editiert von Bluefox
      @Taragorm
      Adapter has to have the "widgets" folder in the iobroker.evohome and inside must be evohome.html
      https://github.com/ioBroker/ioBroker.template/blob/master/VIS/widgets/template.html#L13
      What do you mean with custom editor? Custom editor of the parameter field, like color picker or OID Selector?
      You have 2 ways:
      • build in EJS engine, like this one https://github.com/ioBroker/ioBroker.template/blob/master/VIS/widgets/template.html#L114 <%== vis.states[this.data.attr('oid') + '.val'] %>
        Description: https://v2.canjs.com/guides/EJS.html
      • or via javascript code like this one: https://github.com/ioBroker/ioBroker.template/blob/master/VIS/widgets/template/js/template.js#L47
      Don't forget to unsubscribe, when the widget will be destroyed. This can be done by storing of all OIDs and onChange function in the main div:
                      // remember all ids, that bound
                      $div.data('bound', bound);
                      // remember bind handler
                      $div.data('bindHandler', onChange);
      Example here: https://github.com/ioBroker/ioBroker.vis-hqwidgets/blob/master/widgets/hqwidgets/js/hqwidgets.js#L1436
      Elsewise by page destroy you function will still exist and consume browser resources.
      https://github.com/ioBroker/ioBroker.vis-hqwidgets/blob/master/widgets/hqwidgets/js/hqwidgets.js#L1468
      Only from JS code
      vis.setValue(data.oid, data.value);
      • T
        T
        Taragorm
        Thanks, I will do some more reading.
        Yes. Probably won't need it right away, but I like to know "how stuff works".
        -T
        • T Taragorm
          -T
          @Taragorm There is no easy possibility for that, but your callback will be called after the value set:
          if you define the attribute like attrName[defaultValue]/type/callbackName
          Example: https://github.com/ioBroker/ioBroker.vis-hqwidgets/blob/master/widgets/hqwidgets.html#L41
          So the callback must exists vis.binds.evohome.callbackName, like here:
          https://github.com/ioBroker/ioBroker.vis-hqwidgets/blob/master/widgets/hqwidgets/js/hqwidgets.js#L3069
          Of course you can overload the code and bind your own click handler on the button, but for that you must know, how vis editor works, and jquery.... and naming.
          • T
            T
            Taragorm
            Thanks. I'll leave that alone for now then. :)
            • T
              T
              Taragorm
              Another question - what is the best procedure for visualisation development?
              I have a local project (under home) that contains the development package; I can install that using the customURL function.
              So far, so good.
              After I've changed the package, and re-installed, nothing seems to change, so there must be more to it.
              • T Taragorm
                So far, so good.
                @Taragorm Have you seen that? https://github.com/ioBroker/ioBroker/wiki/How-to-debug-vis-and-to-write-own-widget-set
                T S 2 Antworten Letzte Antwort
                • BluefoxB Bluefox
                  T
                  T
                  Taragorm
                  @Bluefox I have, and I think I followed the instructions, but if I reinstall my adaptor using "from custom URL", nothing much seems to change, even if I restart iobroker.
                  Clearly I'm doing something wrong?
                  • T Taragorm
                    @Taragorm I do it like this.
                    My folder structure is like this one:
                    /opt/iobroker
                            iobroker.my-new-adapter
                            node_modules
                                   iobroker.js-controle
                                   iobroker.xxxx
                    Then I install my new adapter by writing npm i iobroker.my-new-adapter in /opt/iobroker.
                    As result the npm creates a sym-link to my developer folder:
                    /opt/iobroker
                            node_modules
                                   iobroker.my-new-adapter (symlink)
                                   iobroker.xxxx
                    after that I develop my adapter as usual in /opt/iobroker/iobroker.my-new-adapter even as a git repo.
                    after every change I write iobroker r vis && iobroker u vis This should work 100%.
                    Additionally I can write iobroker visdebug my-new-adapter and if I see the output
                    Disable cache I restart the iobroker (only for the first time).
                    After that I can directly modify the file /opt/iobroker/iobroker-data/files/vis/widgets/my-new-adapter.html and after every browser refresh it will be loaded anew from disk. So you can fast see your changes.
                    But, the changes in /opt/iobroker/iobroker-data/files/vis/widgets/my-new-adapter.html must be copied to /opt/iobroker/iobroker.my-new-adapter/widgets/ manually and you may not call iobroker u vis till you do that, else they will be overwritten
                    • T
                      T
                      Taragorm
                      Thanks - that's exactly what I needed to know
                      • T
                        T
                        Taragorm
                        Hmm.
                        The module is iobroker.vis-taragorm
                        iobroker@iobrokerdev /o/iobroker> iobroker visdebug vis-taragorm
                        /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupVisDebug.js:64
                                    if (!adapterDir) throw 'Adapter not found. Tried: ' + adapterNames2Try.join(', ');
                        Adapter not found. Tried: vis-vis-taragorm, vis-taragorm
                        however, vis-taragorm.html does exist in widgets, and there is an instance installed ok. I can't see my widget in the list though.
                        Possiby unrelated, I should also note that I got some errors installing (and many warnings, but I didn't include those):
                        unix_dgram.target.mk:101: recipe for target 'Release/obj.target/unix_dgram/src/unix_dgram.o' failed
                        make: *** [Release/obj.target/unix_dgram/src/unix_dgram.o] Error 1
                        make: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
                        gyp ERR! build error
                        gyp ERR! stack Error: `make` failed with exit code: 2
                        gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
                        gyp ERR! stack     at ChildProcess.emit (events.js:197:13)
                        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:254:12)
                        gyp ERR! System Linux 4.9.0-8-amd64
                        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                        gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
                        gyp ERR! node -v v11.10.1
                        gyp ERR! node-gyp -v v3.8.0
                        gyp ERR! not ok
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules/unix-dgram):
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install: `node-gyp rebuild`
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                        The last message implies this isn't fatal, but I'm new to NodeJS...
                        The dev env is Debian Stretch
                        iobroker@iobrokerdev ~/projects> uname -a
                        Linux iobrokerdev 4.9.0-8-amd64 #1 SMP Debian 4.9.130-2 (2018-10-27) x86_64 GNU/Linux
                        • BluefoxB
                          Участник @Taragorm написал в getting started with visualisations:
                          It would be easier, if I can see the repo on github.
                          Do you have file /opt/iobroker/node_modules/iobroker.vis-taragorm/widgets/taragorm.html ?
                          • BluefoxB
                            BTW, you can deliver in your adapter https://github.com/Taragorm/ioBroker.evohome the widgets too. It is even better.
                            • T
                              T
                              Taragorm
                              Thanks for the quick response!
                              The repo is up at: https://github.com/Taragorm/ioBroker.vis-taragorm
                              It's mostly template right now.
                              This is intended for some generic visualisations (and to practice in) so I didn't include it in the evohome repo. I'll add some specific visualisations there once I know what I'm doing.
                              • BluefoxB Bluefox
                                T
                                T
                                Taragorm
                                @Bluefox
                                iobroker@iobrokerdev ~/projects> ls -l /opt/iobroker/node_modules/iobroker.vis-taragorm/widgets
                                total 12
                                drwxrwxrwx+ 4 iobroker iobroker 4096 Mar  2 10:26 vis-taragorm/
                                -rw-r--r--+ 1 iobroker iobroker 6521 Mar  2 11:47 vis-taragorm.html
                                Seems to be there...
                                • T Taragorm
                                  @Bluefox
                                  total 12
                                  @Taragorm No matter. With iobroker r vis && iobroker u vis it should work.
                                  Not Fast, but work.
                                  Just tried to execute (windows):
                                  and cannot see any errors
                                  • T
                                    T
                                    Taragorm
                                    Something broken with my install, maybe?
                                    I added a bit of logging to the empty catch block (line 24 here):
                                        this.enableDebug = function (widgetset) {
                                            console.log( "widgetset=" + widgetset );
                                            if (widgetset) {
                                                // Try to find out the adapter directory out of a list of options
                                                var adapterDir;
                                                var adapterNames2Try = ['vis-' + widgetset, widgetset];
                                                if (adapterNames2Try[0] === adapterNames2Try[1]) adapterNames2Try.splice(1, 1);
                                                for (var i = 0; i < adapterNames2Try.length; i++) {
                                                    try {
                                                        var adapterDir2Try = tools.getAdapterDir(adapterNames2Try[i]);
                                                        // Query the entry
                                                        var stats = fs.lstatSync(adapterDir2Try);
                                                        console.log(stats.toString() );
                                                        // Is it a directory?
                                                        if (stats.isDirectory()) {
                                                            //found it!
                                                            adapterDir = adapterDir2Try;
                                                            break;
                                                    } catch (e) {
                                                        console.error(e);
                                    and got this:
                                    widgetset=vis-taragorm
                                    TypeError [ERR_INVALID_ARG_TYPE]: The "path" argument must be one of type string, Buffer, or URL. Received type object
                                        at Object.lstatSync (fs.js:857:3)
                                        at VisDebug.enableDebug (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupVisDebug.js:52:36)
                                        at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2464:30
                                        at Object.connected (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3145:70)
                                        at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:87:68)
                                        at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
                                        at Socket.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:138:10)
                                        at Socket.onconnect (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:335:8)
                                        at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:232:12)
                                        at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                    [object Object]
                                    /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupVisDebug.js:67
                                    • T
                                    • T Taragorm
                                              if (widgetset) {
                                                  var adapterDir;
                                                      try {
                                                          // Query the entry
                                                              //found it!
                                                              break;
                                                      } catch (e) {
                                                          console.error(e);
                                      and got this:
                                      [object Object]
                                      • T
                                      @Taragorm Can it be, that you have js-controller 1.4.2? Please update to 1.5.7
                                      • T
                                        T
                                        Taragorm
                                        Certainly looks to be 1.4.2
                                        iobroker@iobrokerdev /o/iobroker> npm outdated
                                        Package                 Current  Wanted  Latest  Location
                                        iobroker.js-controller    1.4.2   1.4.2   1.5.7  iobroker.inst
                                        yargs                     7.1.0   7.1.0  13.2.2  iobroker.inst
                                        main iobroker package calls for "stable", rather than a particular rev - do I just alter the depend there and npm update - or is there a "proper" way to do it?
                                        • T Taragorm
                                          @Taragorm via npm is ok. Just stop iob before update
                                          83.8k
