  2. English
  3. Visualization
  4. getting started with visualisations
Geplant Angeheftet Gesperrt Verschoben Visualization
vis
43 Beiträge 4 Kommentatoren 9.7k Aufrufe 4 Beobachtet
  • T Taragorm
    Thanks, I will do some more reading.
    What do you mean with custom editor? Custom editor of the parameter field, like color picker or OID Selector?
    Yes. Probably won't need it right away, but I like to know "how stuff works".
    -T
    schrieb am zuletzt editiert von Bluefox
    @Taragorm There is no easy possibility for that, but your callback will be called after the value set:
    if you define the attribute like attrName[defaultValue]/type/callbackName
    Example: https://github.com/ioBroker/ioBroker.vis-hqwidgets/blob/master/widgets/hqwidgets.html#L41
    So the callback must exists vis.binds.evohome.callbackName, like here:
    https://github.com/ioBroker/ioBroker.vis-hqwidgets/blob/master/widgets/hqwidgets/js/hqwidgets.js#L3069
    Of course you can overload the code and bind your own click handler on the button, but for that you must know, how vis editor works, and jquery.... and naming.
    • T
      T
      Taragorm
      Thanks. I'll leave that alone for now then. :)
      • T
        T
        Taragorm
        Another question - what is the best procedure for visualisation development?
        I have a local project (under home) that contains the development package; I can install that using the customURL function.
        So far, so good.
        After I've changed the package, and re-installed, nothing seems to change, so there must be more to it.
        BluefoxB 1 Antwort Letzte Antwort
        • T Taragorm
          So far, so good.
          @Taragorm Have you seen that? https://github.com/ioBroker/ioBroker/wiki/How-to-debug-vis-and-to-write-own-widget-set
          T S 2 Antworten Letzte Antwort
          • BluefoxB Bluefox
            T
            T
            Taragorm
            @Bluefox I have, and I think I followed the instructions, but if I reinstall my adaptor using "from custom URL", nothing much seems to change, even if I restart iobroker.
            Clearly I'm doing something wrong?
            • T Taragorm
              @Taragorm I do it like this.
              My folder structure is like this one:
              /opt/iobroker
                      iobroker.my-new-adapter
                      node_modules
                             iobroker.js-controle
                             iobroker.xxxx
              Then I install my new adapter by writing npm i iobroker.my-new-adapter in /opt/iobroker.
              As result the npm creates a sym-link to my developer folder:
              /opt/iobroker
                      node_modules
                             iobroker.my-new-adapter (symlink)
                             iobroker.xxxx
              after that I develop my adapter as usual in /opt/iobroker/iobroker.my-new-adapter even as a git repo.
              after every change I write iobroker r vis && iobroker u vis This should work 100%.
              Additionally I can write iobroker visdebug my-new-adapter and if I see the output
              Disable cache I restart the iobroker (only for the first time).
              After that I can directly modify the file /opt/iobroker/iobroker-data/files/vis/widgets/my-new-adapter.html and after every browser refresh it will be loaded anew from disk. So you can fast see your changes.
              But, the changes in /opt/iobroker/iobroker-data/files/vis/widgets/my-new-adapter.html must be copied to /opt/iobroker/iobroker.my-new-adapter/widgets/ manually and you may not call iobroker u vis till you do that, else they will be overwritten
              • T
                T
                Taragorm
                Thanks - that's exactly what I needed to know
                • T
                  T
                  Taragorm
                  Hmm.
                  The module is iobroker.vis-taragorm
                  iobroker@iobrokerdev /o/iobroker> iobroker visdebug vis-taragorm
                  /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupVisDebug.js:64
                              if (!adapterDir) throw 'Adapter not found. Tried: ' + adapterNames2Try.join(', ');
                  Adapter not found. Tried: vis-vis-taragorm, vis-taragorm
                  however, vis-taragorm.html does exist in widgets, and there is an instance installed ok. I can't see my widget in the list though.
                  Possiby unrelated, I should also note that I got some errors installing (and many warnings, but I didn't include those):
                  unix_dgram.target.mk:101: recipe for target 'Release/obj.target/unix_dgram/src/unix_dgram.o' failed
                  make: *** [Release/obj.target/unix_dgram/src/unix_dgram.o] Error 1
                  make: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
                  gyp ERR! build error
                  gyp ERR! stack Error: `make` failed with exit code: 2
                  gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
                  gyp ERR! stack     at ChildProcess.emit (events.js:197:13)
                  gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:254:12)
                  gyp ERR! System Linux 4.9.0-8-amd64
                  gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                  gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
                  gyp ERR! node -v v11.10.1
                  gyp ERR! node-gyp -v v3.8.0
                  gyp ERR! not ok
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules/unix-dgram):
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install: `node-gyp rebuild`
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                  The last message implies this isn't fatal, but I'm new to NodeJS...
                  The dev env is Debian Stretch
                  iobroker@iobrokerdev ~/projects> uname -a
                  Linux iobrokerdev 4.9.0-8-amd64 #1 SMP Debian 4.9.130-2 (2018-10-27) x86_64 GNU/Linux
                  • BluefoxB
                    Участник @Taragorm написал в getting started with visualisations:
                    It would be easier, if I can see the repo on github.
                    Do you have file /opt/iobroker/node_modules/iobroker.vis-taragorm/widgets/taragorm.html ?
                    • BluefoxB
                      BTW, you can deliver in your adapter https://github.com/Taragorm/ioBroker.evohome the widgets too. It is even better.
                      • T
                        T
                        Taragorm
                        Thanks for the quick response!
                        The repo is up at: https://github.com/Taragorm/ioBroker.vis-taragorm
                        It's mostly template right now.
                        This is intended for some generic visualisations (and to practice in) so I didn't include it in the evohome repo. I'll add some specific visualisations there once I know what I'm doing.
                        • BluefoxB Bluefox
                          T
                          T
                          Taragorm
                          @Bluefox
                          iobroker@iobrokerdev ~/projects> ls -l /opt/iobroker/node_modules/iobroker.vis-taragorm/widgets
                          total 12
                          drwxrwxrwx+ 4 iobroker iobroker 4096 Mar  2 10:26 vis-taragorm/
                          -rw-r--r--+ 1 iobroker iobroker 6521 Mar  2 11:47 vis-taragorm.html
                          Seems to be there...
                          • T Taragorm
                            @Bluefox
                            total 12
                            @Taragorm No matter. With iobroker r vis && iobroker u vis it should work.
                            Not Fast, but work.
                            Just tried to execute (windows):
                            and cannot see any errors
                            • T
                              T
                              Taragorm
                              Something broken with my install, maybe?
                              I added a bit of logging to the empty catch block (line 24 here):
                                  this.enableDebug = function (widgetset) {
                                      console.log( "widgetset=" + widgetset );
                                      if (widgetset) {
                                          // Try to find out the adapter directory out of a list of options
                                          var adapterDir;
                                          var adapterNames2Try = ['vis-' + widgetset, widgetset];
                                          if (adapterNames2Try[0] === adapterNames2Try[1]) adapterNames2Try.splice(1, 1);
                                          for (var i = 0; i < adapterNames2Try.length; i++) {
                                              try {
                                                  var adapterDir2Try = tools.getAdapterDir(adapterNames2Try[i]);
                                                  // Query the entry
                                                  var stats = fs.lstatSync(adapterDir2Try);
                                                  console.log(stats.toString() );
                                                  // Is it a directory?
                                                  if (stats.isDirectory()) {
                                                      //found it!
                                                      adapterDir = adapterDir2Try;
                                                      break;
                                              } catch (e) {
                                                  console.error(e);
                              and got this:
                              widgetset=vis-taragorm
                              TypeError [ERR_INVALID_ARG_TYPE]: The "path" argument must be one of type string, Buffer, or URL. Received type object
                                  at Object.lstatSync (fs.js:857:3)
                                  at VisDebug.enableDebug (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupVisDebug.js:52:36)
                                  at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2464:30
                                  at Object.connected (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3145:70)
                                  at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:87:68)
                                  at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
                                  at Socket.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:138:10)
                                  at Socket.onconnect (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:335:8)
                                  at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:232:12)
                                  at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                              [object Object]
                              /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupVisDebug.js:67
                              • T
                              • T Taragorm
                                        if (widgetset) {
                                            var adapterDir;
                                                try {
                                                    // Query the entry
                                                        //found it!
                                                        break;
                                                } catch (e) {
                                                    console.error(e);
                                and got this:
                                [object Object]
                                • T
                                @Taragorm Can it be, that you have js-controller 1.4.2? Please update to 1.5.7
                                • T
                                  T
                                  Taragorm
                                  Certainly looks to be 1.4.2
                                  iobroker@iobrokerdev /o/iobroker> npm outdated
                                  Package                 Current  Wanted  Latest  Location
                                  iobroker.js-controller    1.4.2   1.4.2   1.5.7  iobroker.inst
                                  yargs                     7.1.0   7.1.0  13.2.2  iobroker.inst
                                  main iobroker package calls for "stable", rather than a particular rev - do I just alter the depend there and npm update - or is there a "proper" way to do it?
                                  • T Taragorm
                                    @Taragorm via npm is ok. Just stop iob before update
                                    • T
                                      T
                                      Taragorm
                                      Update
                                      Reloaded iobroker from scratch, just to be sure
                                      Updated iob.js-controller to 1.5.7
                                      iobroker@iobrokerdev /o/iobroker> npm list iobroker.js-controller
                                      iobroker.inst@2.0.2 /opt/iobroker
                                      └── iobroker.js-controller@1.5.7
                                      Same error on iob visdebug
                                      Also
                                      Lots of warnings caused by this:
                                      └─┬ iobroker.js-controller@1.5.7
                                        └─┬ winston-syslog@1.2.6
                                          └── UNMET OPTIONAL DEPENDENCY unix-dgram@~0.2.1
                                      Is there any way to suppress it? I hate clutter in the logfiles!
                                      Also2
                                      I can't see my widget in the vis builder. There's no obvious error in the log tho.
                                      • T
                                        T
                                        Taragorm
                                        done a bit more digging into the visdebug error, and it seems like the project folder isn't being recognised as a directory:
                                        Trying:/opt/iobroker/iobroker.vis-taragorm
                                        Got stats:{"dev":2049,"mode":41471,"nlink":1,"uid":1001,"gid":1001,"rdev":0,"blksize":4096,"ino":792374,"size":24,"blocks":0,"atimeMs":1552471012718.894,"mtimeMs":1552471012714.892,"ctimeMs":1552471012714.892,"birthtimeMs":1552471012714.892,"atime":"2019-03-13T09:56:52.719Z","mtime":"2019-03-13T09:56:52.715Z","ctime":"2019-03-13T09:56:52.715Z","birthtime":"2019-03-13T09:56:52.715Z"}  isDir=false
                                        trace code:
                                                            console.log("Trying:" + process.cwd() + "/" + adapterNames2Try[i]);
                                                            // Query the entry
                                                            console.log("Got stats:" + JSON.stringify(stats) + "  isDir=" + stats.isDirectory());
                                        But it surely is a dir:
                                        iobroker@iobrokerdev /o/iobroker> ls -l
                                        total 248
                                        -rw-rwxr--+   1 iobroker iobroker   1474 Mar 13 09:40 CHANGELOG_INSTALLER_LINUX.md*
                                        drwxrwxr-x+   3 iobroker iobroker   4096 Mar 13 09:40 install/
                                        -rwxrwxrwx+   1 iobroker iobroker    169 Mar 13 09:41 INSTALLER_INFO.txt*
                                        lrwxrwxrwx    1 iobroker iobroker     22 Mar 13 09:41 iob -> /opt/iobroker/iobroker*
                                        -rwxrwxr-x+   1 iobroker iobroker    209 Mar 13 09:41 iobroker*
                                        drwxrwxrwx+   4 iobroker iobroker   4096 Mar 13 09:42 iobroker-data/
                                        drwxrwxrwx+   8 iobroker iobroker   4096 Mar 13 09:59 iobroker.vis-taragorm/
                                        -rw-rwxrw-+   1 iobroker iobroker     92 Mar 13 09:41 killall.sh*
                                        drwxrwxr-x+   2 iobroker iobroker   4096 Mar 13 09:40 lib/
                                        -rw-rwxr--+   1 iobroker iobroker   1137 Mar 13 09:40 LICENSE*
                                        drwxrwxrwx+   2 iobroker iobroker   4096 Mar 13 09:41 log/
                                        drwxrwxr-x+ 451 iobroker iobroker  20480 Mar 13 09:56 node_modules/
                                        -rw-rwxrw-+   1 iobroker iobroker    658 Mar 13 09:56 package.json*
                                        -rw-rwxrw-+   1 iobroker iobroker 166878 Mar 13 09:41 package-lock.json*
                                        -rw-rwxr--+   1 iobroker iobroker   6101 Mar 13 09:40 README.md*
                                        -rw-rw-rw-+   1 iobroker iobroker   5868 Mar 13 09:51 reinstall.js
                                        -rw-rwxrw-+   1 iobroker iobroker    709 Mar 13 09:41 reinstall.sh*
                                        it's as if fs is misbehaving?
                                        • T Taragorm
                                          trace code:
                                                              // Query the entry
                                          total 248
                                          @Taragorm is the normal iobroker upload vis does not work?
                                          You can force all the steps manually.
                                          1. Copy your widgets files into /opt/iobroker/node_modules/iobroker.vis/www/widgets directory.
                                          2. Change /opt/iobroker/node_modules/iobroker.vis/www/js/config.js
                                          3. Change /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest (just add/change some char to change the hash)
                                          4. iobroker u vis
                                          5. To be sure clear the browser cache
                                          83.8k
