  2. English
  3. Visualization
  4. getting started with visualisations
    5.6k
Geplant Angeheftet Gesperrt Verschoben Visualization
vis
43 Beiträge 4 Kommentatoren 9.2k Aufrufe 4 Beobachtet
  • T Taragorm
    Certainly looks to be 1.4.2
    iobroker@iobrokerdev /o/iobroker> npm outdated
    Package                 Current  Wanted  Latest  Location
    iobroker.js-controller    1.4.2   1.4.2   1.5.7  iobroker.inst
    yargs                     7.1.0   7.1.0  13.2.2  iobroker.inst
    main iobroker package calls for "stable", rather than a particular rev - do I just alter the depend there and npm update - or is there a "proper" way to do it?
    BluefoxB Offline
    BluefoxB Offline
    @Taragorm via npm is ok. Just stop iob before update
      Taragorm
      Update
      Reloaded iobroker from scratch, just to be sure
      Updated iob.js-controller to 1.5.7
      iobroker@iobrokerdev /o/iobroker> npm list iobroker.js-controller
      iobroker.inst@2.0.2 /opt/iobroker
      └── iobroker.js-controller@1.5.7
      Same error on iob visdebug
      Also
      Lots of warnings caused by this:
      └─┬ iobroker.js-controller@1.5.7
        └─┬ winston-syslog@1.2.6
          └── UNMET OPTIONAL DEPENDENCY unix-dgram@~0.2.1
      Is there any way to suppress it? I hate clutter in the logfiles!
      Also2
      I can't see my widget in the vis builder. There's no obvious error in the log tho.
        Taragorm
        done a bit more digging into the visdebug error, and it seems like the project folder isn't being recognised as a directory:
        Trying:/opt/iobroker/iobroker.vis-taragorm
        Got stats:{"dev":2049,"mode":41471,"nlink":1,"uid":1001,"gid":1001,"rdev":0,"blksize":4096,"ino":792374,"size":24,"blocks":0,"atimeMs":1552471012718.894,"mtimeMs":1552471012714.892,"ctimeMs":1552471012714.892,"birthtimeMs":1552471012714.892,"atime":"2019-03-13T09:56:52.719Z","mtime":"2019-03-13T09:56:52.715Z","ctime":"2019-03-13T09:56:52.715Z","birthtime":"2019-03-13T09:56:52.715Z"}  isDir=false
        trace code:
                            console.log("Trying:" + process.cwd() + "/" + adapterNames2Try[i]);
                            var adapterDir2Try = tools.getAdapterDir(adapterNames2Try[i]);
                            // Query the entry
                            var stats = fs.lstatSync(adapterDir2Try);
                            console.log("Got stats:" + JSON.stringify(stats) + "  isDir=" + stats.isDirectory());
        But it surely is a dir:
        iobroker@iobrokerdev /o/iobroker> ls -l
        total 248
        -rw-rwxr--+   1 iobroker iobroker   1474 Mar 13 09:40 CHANGELOG_INSTALLER_LINUX.md*
        drwxrwxr-x+   3 iobroker iobroker   4096 Mar 13 09:40 install/
        -rwxrwxrwx+   1 iobroker iobroker    169 Mar 13 09:41 INSTALLER_INFO.txt*
        lrwxrwxrwx    1 iobroker iobroker     22 Mar 13 09:41 iob -> /opt/iobroker/iobroker*
        -rwxrwxr-x+   1 iobroker iobroker    209 Mar 13 09:41 iobroker*
        drwxrwxrwx+   4 iobroker iobroker   4096 Mar 13 09:42 iobroker-data/
        drwxrwxrwx+   8 iobroker iobroker   4096 Mar 13 09:59 iobroker.vis-taragorm/
        -rw-rwxrw-+   1 iobroker iobroker     92 Mar 13 09:41 killall.sh*
        drwxrwxr-x+   2 iobroker iobroker   4096 Mar 13 09:40 lib/
        -rw-rwxr--+   1 iobroker iobroker   1137 Mar 13 09:40 LICENSE*
        drwxrwxrwx+   2 iobroker iobroker   4096 Mar 13 09:41 log/
        drwxrwxr-x+ 451 iobroker iobroker  20480 Mar 13 09:56 node_modules/
        -rw-rwxrw-+   1 iobroker iobroker    658 Mar 13 09:56 package.json*
        -rw-rwxrw-+   1 iobroker iobroker 166878 Mar 13 09:41 package-lock.json*
        -rw-rwxr--+   1 iobroker iobroker   6101 Mar 13 09:40 README.md*
        -rw-rw-rw-+   1 iobroker iobroker   5868 Mar 13 09:51 reinstall.js
        -rw-rwxrw-+   1 iobroker iobroker    709 Mar 13 09:41 reinstall.sh*
        it's as if fs is misbehaving?
        BluefoxB 1 Antwort Letzte Antwort
        • T Taragorm
          trace code:
                              // Query the entry
          total 248
          BluefoxB Offline
          BluefoxB Offline
          schrieb am zuletzt editiert von Bluefox
          @Taragorm is the normal iobroker upload vis does not work?
          You can force all the steps manually.
          1. Copy your widgets files into /opt/iobroker/node_modules/iobroker.vis/www/widgets directory.
          2. Change /opt/iobroker/node_modules/iobroker.vis/www/js/config.js
          3. Change /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest (just add/change some char to change the hash)
          4. iobroker u vis
          5. To be sure clear the browser cache
            Taragorm
            fyi, in enableDebug I think:
            maybe should be
            var stats = fs.statSync(adapterDir2Try);
            As diagnostics suggest we're finding the link, and lstatSync() returns the link itself, rather than the target of the link.
            Changing it, lets things go a bit further, but it still fails somewhat messily:
            Got stats:{"dev":2049,"mode":16895,"nlink":8,"uid":1001,"gid":1001,"rdev":0,"blksize":4096,"ino":791105,"size":4096,"blocks":8,"atimeMs":1552471286715.824,"mtimeMs":1552471172270.63,"ctimeMs":1552471172270.63,"birthtimeMs":1552471172270.63,"atime":"2019-03-13T10:01:26.716Z","mtime":"2019-03-13T09:59:32.271Z","ctime":"2019-03-13T09:59:32.271Z","birthtime":"2019-03-13T09:59:32.271Z"}  isDir=true isLink=false
            Upload "/opt/iobroker/node_modules/iobroker.vis/www/index.html.original"
            fs.js:119
                throw err;
            Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../iobroker.vis/www/index.html.original'
                at Object.openSync (fs.js:448:3)
                at Object.readFileSync (fs.js:348:35)
                at VisDebug.enableDebug (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupVisDebug.js:91:23)
                at _objects (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2460:30)
                at Object.connected (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3133:17)
                at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:87:68)
                at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                at Socket.emit (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:136:10)
                at Socket.onconnect (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:328:8)
                at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:224:12)
            For now, I'm going to switch my development environment to Windows, as that seems to be working for you.
            • T Taragorm
              maybe should be
              fs.js:119
                  throw err;
              BluefoxB Offline
              BluefoxB Offline
              @Taragorm It is very well, that you want to get the visbebug runnnig, but
              I don't understand, why you ignore my other suggestions:
              • https://forum.iobroker.net/topic/19929/getting-started-with-visualisations/15
              • https://forum.iobroker.net/topic/19929/getting-started-with-visualisations/8
              The problem with non existing index.html.original is fixed only on github.
              • BluefoxB Bluefox
                @Taragorm No matter. With iobroker r vis && iobroker u vis it should work.
                Not Fast, but work.
                Just tried to execute (windows):
                and cannot see any errors
                Taragorm
                @Bluefox I
                @Bluefox said in getting started with visualisations:
                Not Fast, but work.
                I tried this; I don't get any errors, but I don't get a visualisation in the toolbox either.
                That's why I trying to enable debug.
                • BluefoxB Bluefox
                  @Taragorm I do it like this.
                  My folder structure is like this one:
                  /opt/iobroker
                          iobroker.my-new-adapter
                          node_modules
                                 iobroker.js-controle
                                 iobroker.xxxx
                  Then I install my new adapter by writing npm i iobroker.my-new-adapter in /opt/iobroker.
                  As result the npm creates a sym-link to my developer folder:
                  /opt/iobroker
                          node_modules
                                 iobroker.my-new-adapter (symlink)
                                 iobroker.xxxx
                  after that I develop my adapter as usual in /opt/iobroker/iobroker.my-new-adapter even as a git repo.
                  after every change I write iobroker r vis && iobroker u vis This should work 100%.
                  Additionally I can write iobroker visdebug my-new-adapter and if I see the output
                  Disable cache I restart the iobroker (only for the first time).
                  After that I can directly modify the file /opt/iobroker/iobroker-data/files/vis/widgets/my-new-adapter.html and after every browser refresh it will be loaded anew from disk. So you can fast see your changes.
                  But, the changes in /opt/iobroker/iobroker-data/files/vis/widgets/my-new-adapter.html must be copied to /opt/iobroker/iobroker.my-new-adapter/widgets/ manually and you may not call iobroker u vis till you do that, else they will be overwritten
                  Taragorm
                  /opt/iobroker
                          node_modules
                                 iobroker.xxxx
                  /opt/iobroker
                          node_modules
                                 iobroker.xxxx
                  ...and I have also set my environment up like this.
                  • BluefoxB Offline
                    BluefoxB Offline
                    Please set here the names without vis-
                    • BluefoxB Offline
                      BluefoxB Offline
                      And you may not change class.
                        Taragorm
                        thanks, will do
                          Taragorm
                          It's showing in the toolbox now - many thanks!
                            Taragorm
                            Much progress, but another small issue.
                            My visualisation shows values ok in the edit dialog.
                            In the normal view, it shows the "undefined" value... unless the value is used by a different widget.
                            This suggests I've done something wrong in binding, but as far as I can see, I've done pretty much what the template does.
                            Have I missed something out? It feels like whatever code that populates vis.states[] hasn't been invoked correctly. (i.e. the view seems to be unaware of the points I'm asking for).
                              Taragorm
                              ps: Changed the repo to: https://github.com/Taragorm/ioBroker.vistaragorm
                              • T Taragorm
                                BluefoxB Offline
                                BluefoxB Offline
                                @Taragorm It can be, that I forgot to describe, that all ObjectID Variables Names must start with "oid..." or end with "...oid" or "...oidN" (N is any number from 0 to 99)
                                Please use following files, that work:
                                vistaragorm.js
                                vistaragorm.html
                                  Taragorm
                                  Ah, that would be it then - I may have missed it.
                                  I assumed that the /id type in the attr declaration was what did it.
                                    Taragorm
                                    That works nicely, thanks.
                                    Out of curiosity, is there any way to force subscription?
                                    I have a case where I have mutiple values on a sensor, and I'd like to be able to just specify the sensor oid for the widget, and have the implementation figure out the values.
                                    e.g. I have
                                    foo.bah.x
                                    foo.bah.y
                                    foo.bah.z
                                    .. I'd like to only have to supply an oid of foo.bah - the widget can add .x, .y etc as those are fixed.
                                    or does supplying an oid = "foo.bah" create a subscription for changes of all children too?
                                      Taragorm
                                      In case it's not obvious, I'd like a widget to be able to generate oids based on, or relative to, an oid in an attribute, and have the object correctly added to the widget/view so I can get data from it.
                                      Surely there must be a way to do this?
                                      • T Taragorm
                                        BluefoxB Offline
                                        BluefoxB Offline
                                        @Taragorm I must check it
                                          Taragorm
                                          Appreciated
