  4. [Aufruf] Neuer Adapter ioBroker.tuya (WLAN devices Tuya Smart Life und andere)
547 Beiträge 97 Kommentatoren 280.1k Aufrufe 20 Beobachtet
  • N
    N
    nfidel
    #385
    @nfidel said in [Aufruf] Neuer Adapter ioBroker.tuya (WLAN devices Tuya Smart Life und andere):
    {"schema":"[{"mode":"rw","c
    2019-03-03 21:31:21.568  - info: tuya.0 {"schema":"[{\"mode\":\"rw\",\"code\":\"led_switch\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power\",\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"work_mode\",\"name\":\"工作模式\",\"property\":{\"range\":[\"white\",\"colour\",\"scene\",\"scene_1\",\"scene_2\",\"scene_3\",\"scene_4\"],\"type\":\"enum\"},\"iconname\":\"icon-dp_mode\",\"id\":2,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"bright_value\",\"name\":\"亮度值\",\"property\":{\"unit\":\"\",\"min\":25,\"max\":255,\"scale\":0,\"step\":1,\"type\":\"value\"},\"iconname\":\"icon-dp_sun\",\"id\":3,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"temp_value\",\"name\":\"冷暖值\",\"property\":{\"unit\":\"\",\"min\":0,\"max\":255,\"scale\":0,\"step\":1,\"type\":\"value\"},\"iconname\":\"icon-dp_light\",\"id\":4,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"colour_data\",\"name\":\"彩光模式数\",\"property\":{\"type\":\"string\",\"maxlen\":14},\"id\":5,\"type\":\"obj\",\"desc\":\"rgbhsv\"},{\"mode\":\"rw\",\"code\":\"scene_data\",\"name\":\"情景模式数\",\"property\":{\"type\":\"string\",\"maxlen\":14},\"id\":6,\"type\":\"obj\",\"desc\":\"rgbhsv\"},{\"mode\":\"rw\",\"code\":\"flash_scene_1\",\"name\":\"柔光情景\",\"property\":{\"type\":\"string\",\"maxlen\":14},\"id\":7,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"flash_scene_2\",\"name\":\"缤纷情景\",\"property\":{\"type\":\"string\",\"maxlen\":44},\"id\":8,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"flash_scene_3\",\"name\":\"炫彩情景\",\"property\":{\"type\":\"string\",\"maxlen\":14},\"id\":9,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"flash_scene_4\",\"name\":\"斑斓情景\",\"property\":{\"type\":\"string\",\"maxlen\":44},\"id\":10,\"type\":\"obj\",\"desc\":\"\"}]","schemaExt":"[{\"id\":3,\"inputType\":\"\"},{\"id\":4,\"inputType\":\"\"}]"}
    ja Gerät funktioniert. Habe Schwierigkeiten mich auf github zu registrieren. Captcha kann wohl nicht angezeigt werden...meine doofheit sicherlich :(
    Lampe ist erkannt und kann geschalten werden, ein und aus, die Farbkodierungen sind mir allerdings ein Rätsel. Danke für deine Arbeit!
    • apollon77A
      apollon77A
      #386
      Brauche auch die Zeile oben drüber/drunter mit dem typen des Devices
      • S
        S
        Superdad
        schrieb am zuletzt editiert von Superdad
        #387
        Habe gestern einen ganzen Tag lang versucht das Ganze mit dem iPhone einzurichten.
        Keine Chance!
        Ich kann alles installieren, aber beim letzten Schritt bekomme ich keine Verbindung zum Proxy mit der App.
        Über IP-IoBroker:8889 in Chrome habe ich es auch schon probiert.
        Da bekomme ich eine Verbindung.
        Wenn ich aber die App (Smart-Life) öffne, passiert nix.
        Dann habe ich es mit Elzershark probiert.
        Da komme ich bis zur Wlan-Einstellung (sprich Proxy).
        Die Verbindung MemuWifi habe ich gar nicht und die vorhandene kann ich nicht ändern.
        Mein ioBroker ist im Docker auf einer Synology installiert.
        Diese ist per Lan-Kabel am Unifi-USG.
        Heisst dass, wenn ich keine WLan-Verbindung zum ioBroker habe, dass das Ganze nicht funktioniert?
        Kann ich jetzt also die Gosund SP1 wieder zurückschicken?
        Oder gibt es eine Lösung?
        Unter Objekten sehe ich ja die Steckdosen mit Wlan-Adresse.
        Aber steuern kann ich die dann nicht, oder?
        P.S.: Habe es geschafft!
        Für die, die das gleiche Problem haben:
        In MEmu auf die Netzwerkverbindung Click mit Maus und gedrückt halten.
        Dann erscheint ein Menü, wo man den Proxy eingeben kann!
        CCU3
        iOBroker auf IntelNUC Proxmox
        • N
          N
          nfidel
          #388
          2019-03-03 21:30:50.023  - info: tuya.0 starting. Version 1.0.7 in /opt/iobroker/node_modules/iobroker.tuya, node: v8.15.0
          2019-03-03 21:30:50.239  - info: tuya.0 86678280ecfabca1bb84 Init with IP=192.168.0.54, Key=undefined
          2019-03-03 21:30:50.274  - info: tuya.0 86678280ecfabca1bb84: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
          2019-03-03 21:30:50.276  - info: tuya.0 Existing devices initialized
          2019-03-03 21:30:50.300  - info: tuya.0 Discover for local Tuya devices on port 6666
          2019-03-03 21:30:50.354  - info: tuya.0 86678280ecfabca1bb84: No schema exists, init basic states ...
          2019-03-03 21:30:58.178  - info: tuya.0 Anyproxy ready to receive requests
          2019-03-03 21:31:21.567  - info: tuya.0 new Shema added for product type rrOujSy4Pf1BwEgV. Please send next line from logfile on disk to developer!
          2019-03-03 21:31:22.797  - info: tuya.0 86678280ecfabca1bb84 Init with IP=192.168.0.54, Key=acbfa997c79863f1
          2019-03-03 21:31:22.804  - info: tuya.0 86678280ecfabca1bb84 Init with IP=192.168.0.54, Key=acbfa997c79863f1
          2019-03-03 21:31:22.875  - info: tuya.0 86678280ecfabca1bb84 Init with IP=192.168.0.54, Key=acbfa997c79863f1
          2019-03
          sorry, habe es erst jetzt gesehen. Passt es so?
          • apollon77A apollon77
            Ja, Bitte über den Proxy im Adapter-Admin mit der App syncen, danach sollten die Werte passen
            B
            B
            BigFM87
            #389
            @apollon77 sagte in [Aufruf] Neuer Adapter ioBroker.tuya (WLAN devices Tuya Smart Life und andere):
            Danke für die Kurzanleitung! Ich bin den Anweisungen gefolgt, leider ist keine Veränderung sichtbar.
            In der App werden die Werte richtig angezeigt aber im IoBroker leider nicht!
            Kann ich noch etwas machen?
            • apollon77A
              apollon77A
              #390
              Hast das mit dem Proxy geklappt? Kam die Meldung im Admin das alles super ist, der grüne Haken und so ?
                B
                B
                BigFM87
                #391
                Nein, der kam nicht. Habe ich zu zeitig abgebrochen?!
                Mein Ablauf:
                1. Admin Proxy gestartet
                2. QR-Code gescannt mit Handy und unter WLAN Verbindung installiert
                3. Smart Life App gestartet
                4. Proxy Verbindung für ca. 20s laufen lassen
                5. Abgebrochen und keine Veränderung
                Was war falsch? :D
                nukleuzN 1 Antwort Letzte Antwort
                • apollon77A
                  apollon77A
                  #392
                  Da fehlt aber noch ein Schritt nämlich das aktivieren des proxies im handy... Bitte Github README und so schauen.
                  Es hat geklappt wenn Admin von sich aus sagt das alles da ist
                  • B BigFM87
                    Mein Ablauf:
                    Was war falsch? :D
                    nukleuzN
                    nukleuzN
                    nukleuz
                    #393
                    @BigFM87
                    Ich glaube dir fehlt die Aktivierung der Sicherheitszertifikateinstellungen für das Proxyzertifikat.
                    Gleiches Problem vor einiger Zeit.
                    Intel NUC -> ProxMox -> Debian -> ioBroker (Master)| RPI3B+ -> rtl_433 (Slave) | CCU2
                      B
                      B
                      BigFM87
                      schrieb am zuletzt editiert von BigFM87
                      #394
                      Das war nochmal ein guter Hinweis, bis zum Ende habe ich nicht gelesen. Er hat die Wert korrigiert, Danke für Alles!
                      • MyzerATM
                        MyzerATM
                        MyzerAT
                        schrieb am zuletzt editiert von MyzerAT
                        #395
                        wie immer, leider bei fast allem im iobroker, habe ich mehrere Stunden gebraucht meine Lampen 8 Stück im Tuya angezeigt zu bekommen, nun habe ich es geschafft, ist schon sehr kompliziert, egal ob ios oder android, fast keine Anleitung hier hat gepasst und letztendlich hat es dann irgend wie doch auf einmal geklappt und ich habe endlich den Haken zu sehen bekommen, nach immerhin fast 4 Stunden "facepalm"
                        bin dennoch verwirrt !
                        normal sehen meine Lampendatenpunkte so aus:
                        jetzt mit dem Tuya Adapter so:
                        Finde dies nicht sehr Eindrucksvoll und von der Bedienbarkeit im ersten Moment, nicht zu gebrauchen! Hat jemand einen Ahnung welcher der Datenpunkte was macht, mir ist es bei einigen klar, aber wo gebe ich den Farbwert ein und wie? oder die Helligkeit und auch da die Frage wie, also welches Format!
                        dann noch eine frage, läuft nun alles über Smartlife oder über Tuya ? wie ändere ich das bzw. wo sehe ich es?!
                        zu guter letzt habe ich gelesen, das eventuell Meross auch noch kommen soll, das wäre echt toll, da die immer wieder ausfallen, also die Server!
                        dennoch thx an @apollon77 für seine Mühe !!!!!!!
                        lg Rudi
                        Node 22.23.0
                        Nodejs 22.23.0
                        npm 10.9.8
                        js-controller 7.2.2
                        • apollon77A
                          apollon77A
                          #396
                          Die ganzen unterschwelligen Aussagen in Deinem Post überlese ich jetzt mal geflissentlich, aber Du solltest für die Zukunft mal über Deine Schreibweise nachdenken. Auch das "Danke" am Ende macht den Rest gerade nicht mehr ganz wett. Sorry, musste raus.
                          Wenn für Dich keine der Anleitungen und Informationen funktioniert hat, wäre es ja spitze wenn Du uns sagst WIE es denn dann funktioniert hat. Damit könntest Du anderen Nutzern helfen das Sie vllt nicht auf 4 Stunden investieren müssen.
                          Es gibt ein paar tausend Tuya Geräte auf dem Markt. Der Adapter liesst beim Sync mit der App die offiziellen Schema-Daten aus und versucht somit eine bestmögliche Abbildung Deiner Geräte herzustellen. Das bedeutet: Die Zahlen als IDs sind so weil es so eindeutig ist und auch so vom gerät definiert ist. Durch den Sync sind aber noch Namen, Rollen und zB Units hinzugekommen.
                          Geräte-Objekte verschiedener Hersteller und Dinge miteinander zu Vergleichen ist ein bissl grenzwertig, weil am Ende jedes Gerät anders ist. Aber ja, aufgrund der Vielfalt der Geräte und des damit einzig möglichen generischen Ansatzes ist es genau so.
                          Einige Funktionen sollten sich aufgrund der Namen, Rollen und Units erschliessen wie "bright_value = 255" (Brightness 0-255?) oder "colour_data mit rgbhsv" (ein warum auch immer aber hier kombinierter RGB/HSV Wert in Hex-Notation).
                          Am Ende bei anderen Werten hast Du die Wahl: Ändere in ioBroker und schaue was passiert oder ändere es in der Smartlife-App (am besten aber im Handy WLAN ausschalten das du per Cloud änderst sonst störst Du die Verbindung vom Adapter) und schau was passend dazu im Adapter passiert. Und ja, wenn Du oder jemand anders nicht eine "Wissensdatenbank für Werte und Ihre Bedeutungen" startest, dann muss das leider jeder selbst rausfinden.
                          • MyzerATM
                            MyzerATM
                            MyzerAT
                            #397
                            @apollon77
                            Das sollen keine unterschwelligen Aussagen sein, sorry das ist meine direkte Art, mich mitzuteilen, ist aber nicht persönlich zu verstehen und ich bringe es gerne auf den Punkt, ohne drum herum zu Sülzen, ist eben meine Meinung! Und sein wir mal ehrlich, hier wird echt viel Angeboten, aber so richtige Anleitungen gibt es nicht, wohl aufgrund der Komplexität der Sache an sich, jedes System ist anderes und es unterliegt ständigen Änderungen und da wird man schon ziemlich unrund, wenn man mehrere Stunden nach diversen Anleitungen geht und nichts funktioniert. Warum es bei mir dann doch geklappt hat, konnte ich im Nachhinein nicht mehr nachvollziehen, es war der Haken auf einmal da!
                            mein Vergleich der Geräte, sind genau die selben Lampen, wie sie im Tuya Adapter angezeigt werden.
                            Ich versuche sooft und soviel zu helfen, wenn jemand fragt und ich davon eine Ahnung habe! Gebe mein Wissen jederzeit gerne weiter! Soll ja hier keine Einbahnstraße werden! Und trotzdem Danke für deine Mühen, kann man gar nicht oft genug sagen!
                            lg Rudi
                            Node 22.23.0
                            Nodejs 22.23.0
                            npm 10.9.8
                            js-controller 7.2.2
                            • apollon77A
                              apollon77A
                              #398
                              Kann es sein das Du das gleiche Gerät in zwei "Abbildungen" vergleichst? Einmal direkt und offiziell und einmal "So wie die Geräte per Alexa Skill dargestellt werden"? Damit Angepasst und Limitiert wie es Amazon gestattet? Das wäre dann der Grund warum es anders aussieht. Amazon definiert sehr exakt was Sie können und was nicht und Anbieter müssen sich 100% daran halten und damit Ihre Geräte auf das von Amazon "mappen" ...
                              MyzerATM 1 Antwort Letzte Antwort
                                MyzerATM
                                MyzerATM
                                MyzerAT
                                #399
                                @apollon77
                                du meinst diesen Vergleich?
                                lg Rudi
                                Node 22.23.0
                                Nodejs 22.23.0
                                npm 10.9.8
                                js-controller 7.2.2
                                • G
                                  G
                                  Grace13
                                  #400
                                  Hi, kann mir jemand sagen wie ich das Problem Löse das sich die Plugs nicht im Cloud Adapter einbinden lassen?
                                  desweiteren habe ich das Problem das keine neuen adapter angezeigt werden und ich sie nur über die URL installieren kann
                                  • apollon77A
                                    apollon77A
                                    #401
                                    @Grace13 sagte in [Aufruf] Neuer Adapter ioBroker.tuya (WLAN devices Tuya Smart Life und andere):
                                    Lade mal das Repo neu, da gabs einen Fehler mit dem Server aber schon vor 2 tagen gefixt an sich ...
                                    • apollon77A
                                      apollon77A
                                      #402
                                      Hey All,
                                      kleine Info: Falls Ihr FW Updates auf MCU 1.0.5 oder höher (2.0 oder so) angeboten bekommt: FINGER WEG! Es gibt erste Berichte von Geräten mit 1.0.5 und erst recht 2.0 wo scheinbar der lokale Port den der Adapter nutzt nicht mehr offen ist und auch die Firmware nicht mehr anderweitig geflasht werden kann.
                                        Hey All,
                                        K
                                        K
                                        Kueppert
                                        #403
                                        @apollon77 ein Glück hab ich alle Geräte mit tasmota OVA geflashed ;)
                                        • MoeM
                                          MoeM
                                          Moe
                                          schrieb am zuletzt editiert von Moe
                                          #404
                                          Habe heute diverse Steckdosen bekommen alle mit der MCU 1.07 :(
                                          Diese funktioniert leider nicht so ein misst.
                                          Wie kriegt man die Teckin SP22 Steckdosen denn auf ?
                                          Um diese ggf zu Flashen oder auch dieses nicht möglich ??
                                          Edit: geöffnet habe ich sie bekommen. Nun die Frage ob ich sie mit Löten flashen kann trotz der höheren Version ?
                                          W 1 Antwort Letzte Antwort
                                          33.2k
                                          84.3k
