  4. CPU Last hoch
CPU Last hoch
fehler
49 Beiträge 3 Kommentatoren 6.8k Aufrufe 2 Beobachtet
  • totocotonioT totocotonio
    history, shelly
    das wars
    wendy2702W Offline
    wendy2702W Offline
    @totocotonio dann nacheinander deaktivieren und schauen was mit der Last passiert.
    Kannst aber auch im Container mal mit „top“ schauen wer denn da CPU frisst
    • totocotonioT Offline
      totocotonio
      Das ist plötzlich mein log
      javascript.0	2019-02-24 22:18:04.544	warn	at TCP.onread (net.js:559:20)
      javascript.0	2019-02-24 22:18:04.544	warn	at Socket.Readable.push (_stream_readable.js:134:10)
      javascript.0	2019-02-24 22:18:04.544	warn	at readableAddChunk (_stream_readable.js:176:18)
      javascript.0	2019-02-24 22:18:04.544	warn	at Socket.emit (events.js:188:7)
      javascript.0	2019-02-24 22:18:04.544	warn	at emitOne (events.js:96:13)
      javascript.0	2019-02-24 22:18:04.544	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/redis/index.js:274:27)
      javascript.0	2019-02-24 22:18:04.544	warn	at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:574:12)
      javascript.0	2019-02-24 22:18:04.544	warn	at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/redis/index.js:192:18)
      javascript.0	2019-02-24 22:18:04.544	warn	at RedisClient.return_reply (/opt/iobroker/node_modules/redis/index.js:833:9)
      javascript.0	2019-02-24 22:18:04.544	warn	at return_pub_sub (/opt/iobroker/node_modules/redis/index.js:794:18)
      javascript.0	2019-02-24 22:18:04.543	warn	at RedisClient.emit (events.js:194:7)
      javascript.0	2019-02-24 22:18:04.543	warn	at emitThree (events.js:116:13)
      javascript.0	2019-02-24 22:18:04.543	warn	at RedisClient.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:603:25)
      javascript.0	2019-02-24 22:18:04.543	warn	at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37)
      javascript.0	2019-02-24 22:18:04.543	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:358:25)
      javascript.0	2019-02-24 22:18:04.543	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:961:38)
      javascript.0	2019-02-24 22:18:04.543	warn	at Object.<anonymous> (script.js.common.Service.Stromverbrauch:106:1)
      javascript.0	2019-02-24 22:18:04.543	warn	at berechneVerbrauchKosten (script.js.common.Service.Stromverbrauch:215:76)
      javascript.0	2019-02-24 22:18:04.543	warn	getState "javascript.0.Strom.Pumpe_Solaranlage_1.Zaehlerstand.Jahr" not found (3) states[id]=null
      javascript.0	2019-02-24 22:18:04.543	warn	at TCP.onread (net.js:559:20)
      javascript.0	2019-02-24 22:18:04.543	warn	at Socket.Readable.push (_stream_readable.js:134:10)
      javascript.0	2019-02-24 22:18:04.543	warn	at readableAddChunk (_stream_readable.js:176:18)
      javascript.0	2019-02-24 22:18:04.543	warn	at Socket.emit (events.js:188:7)
      javascript.0	2019-02-24 22:18:04.543	warn	at emitOne (events.js:96:13)
      javascript.0	2019-02-24 22:18:04.543	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/redis/index.js:274:27)
      javascript.0	2019-02-24 22:18:04.543	warn	at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:574:12)
      javascript.0	2019-02-24 22:18:04.543	warn	at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/redis/index.js:192:18)
      javascript.0	2019-02-24 22:18:04.542	warn	at RedisClient.return_reply (/opt/iobroker/node_modules/redis/index.js:833:9)
      javascript.0	2019-02-24 22:18:04.542	warn	at return_pub_sub (/opt/iobroker/node_modules/redis/index.js:794:18)
      javascript.0	2019-02-24 22:18:04.542	warn	at RedisClient.emit (events.js:194:7)
      javascript.0	2019-02-24 22:18:04.542	warn	at emitThree (events.js:116:13)
      javascript.0	2019-02-24 22:18:04.542	warn	at RedisClient.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:603:25)
      javascript.0	2019-02-24 22:18:04.534	warn	at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37)
      javascript.0	2019-02-24 22:18:04.534	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:358:25)
      javascript.0	2019-02-24 22:18:04.534	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:961:38)
      javascript.0	2019-02-24 22:18:04.534	warn	at Object.<anonymous> (script.js.common.Service.Stromverbrauch:106:1)
      javascript.0	2019-02-24 22:18:04.534	warn	at berechneVerbrauchKosten (script.js.common.Service.Stromverbrauch:214:78)
      javascript.0	2019-02-24 22:18:04.534	warn	getState "javascript.0.Strom.Pumpe_Solaranlage_1.Zaehlerstand.Jahr" not found (3) states[id]=null
      javascript.0	2019-02-24 22:18:04.534	warn	at TCP.onread (net.js:559:20)
      javascript.0	2019-02-24 22:18:04.534	warn	at Socket.Readable.push (_stream_readable.js:134:10)
      javascript.0	2019-02-24 22:18:04.534	warn	at readableAddChunk (_stream_readable.js:176:18)
      javascript.0	2019-02-24 22:18:04.534	warn	at Socket.emit (events.js:188:7)
      javascript.0	2019-02-24 22:18:04.534	warn	at emitOne (events.js:96:13)
      javascript.0	2019-02-24 22:18:04.534	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/redis/index.js:274:27)
      javascript.0	2019-02-24 22:18:04.534	warn	at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:574:12)
      javascript.0	2019-02-24 22:18:04.534	warn	at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/redis/index.js:192:18)
      javascript.0	2019-02-24 22:18:04.534	warn	at RedisClient.return_reply (/opt/iobroker/node_modules/redis/index.js:833:9)
      javascript.0	2019-02-24 22:18:04.533	warn	at return_pub_sub (/opt/iobroker/node_modules/redis/index.js:794:18)
      javascript.0	2019-02-24 22:18:04.533	warn	at RedisClient.emit (events.js:194:7)
      javascript.0	2019-02-24 22:18:04.533	warn	at emitThree (events.js:116:13)
      javascript.0	2019-02-24 22:18:04.533	warn	at RedisClient.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:603:25)
      javascript.0	2019-02-24 22:18:04.533	warn	at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37)
      javascript.0	2019-02-24 22:18:04.533	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:358:25)
      javascript.0	2019-02-24 22:18:04.533	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:961:38)
      javascript.0	2019-02-24 22:18:04.533	warn	at Object.<anonymous> (script.js.common.Service.Stromverbrauch:106:1)
      javascript.0	2019-02-24 22:18:04.533	warn	at berechneVerbrauchKosten (script.js.common.Service.Stromverbrauch:212:79)
      javascript.0	2019-02-24 22:18:04.533	warn	getState "javascript.0.Strom.Pumpe_Solaranlage_1.Zaehlerstand.Quartal" not found (3) states[id]=null
      javascript.0	2019-02-24 22:18:04.533	warn	at TCP.onread (net.js:559:20)
      javascript.0	2019-02-24 22:18:04.533	warn	at Socket.Readable.push (_stream_readable.js:134:10)
      javascript.0	2019-02-24 22:18:04.533	warn	at readableAddChunk (_stream_readable.js:176:18)
      javascript.0	2019-02-24 22:18:04.533	warn	at Socket.emit (events.js:188:7)
      javascript.0	2019-02-24 22:18:04.533	warn	at emitOne (events.js:96:13)
      javascript.0	2019-02-24 22:18:04.533	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/redis/index.js:274:27)
      javascript.0	2019-02-24 22:18:04.533	warn	at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:574:12)
      javascript.0	2019-02-24 22:18:04.532	warn	at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/redis/index.js:192:18)
      javascript.0	2019-02-24 22:18:04.532	warn	at RedisClient.return_reply (/opt/iobroker/node_modules/redis/index.js:833:9)
      javascript.0	2019-02-24 22:18:04.532	warn	at return_pub_sub (/opt/iobroker/node_modules/redis/index.js:794:18)
      javascript.0	2019-02-24 22:18:04.532	warn	at RedisClient.emit (events.js:194:7)
      javascript.0	2019-02-24 22:18:04.532	warn	at emitThree (events.js:116:13)
      javascript.0	2019-02-24 22:18:04.532	warn	at RedisClient.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:603:25)
      javascript.0	2019-02-24 22:18:04.532	warn	at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37)
      javascript.0	2019-02-24 22:18:04.532	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:358:25)
      javascript.0	2019-02-24 22:18:04.532	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:961:38)
      javascript.0	2019-02-24 22:18:04.532	warn	at Object.<anonymous> (script.js.common.Service.Stromverbrauch:106:1)
      javascript.0	2019-02-24 22:18:04.532	warn	at berechneVerbrauchKosten (script.js.common.Service.Stromverbrauch:211:81)
      javascript.0	2019-02-24 22:18:04.532	warn	getState "javascript.0.Strom.Pumpe_Solaranlage_1.Zaehlerstand.Quartal" not found (3) states[id]=null
      web.0	2019-02-24 22:17:53.435	info	==>Connected system.user.admin from ::ffff:192.168.178.55
      web.0	2019-02-24 22:17:53.350	info	<==Disconnect system.user.admin from ::ffff:192.168.178.55 flot
      javascript.0	2019-02-24 22:17:28.838	warn	at TCP.onread (net.js:559:20)
      javascript.0	2019-02-24 22:17:28.838	warn	at Socket.Readable.push (_stream_readable.js:134:10)
      javascript.0	2019-02-24 22:17:28.838	warn	at readableAddChunk (_stream_readable.js:176:18)
      javascript.0	2019-02-24 22:17:28.838	warn	at Socket.emit (events.js:188:7)
      javascript.0	2019-02-24 22:17:28.834	warn	at emitOne (events.js:96:13)
      javascript.0	2019-02-24 22:17:28.834	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/redis/index.js:274:27)
      javascript.0	2019-02-24 22:17:28.834	warn	at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:574:12)
      javascript.0	2019-02-24 22:17:28.834	warn	at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/redis/index.js:192:18)
      javascript.0	2019-02-24 22:17:28.834	warn	at RedisClient.return_reply (/opt/iobroker/node_modules/redis/index.js:833:9)
      javascript.0	2019-02-24 22:17:28.834	warn	at return_pub_sub (/opt/iobroker/node_modules/redis/index.js:794:18)
      javascript.0	2019-02-24 22:17:28.834	warn	at RedisClient.emit (events.js:194:7)
      javascript.0	2019-02-24 22:17:28.834	warn	at emitThree (events.js:116:13)
      javascript.0	2019-02-24 22:17:28.834	warn	at RedisClient.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:603:25)
      javascript.0	2019-02-24 22:17:28.834	warn	at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37)
      javascript.0	2019-02-24 22:17:28.834	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:358:25)
      javascript.0	2019-02-24 22:17:28.834	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:961:38)
      javascript.0	2019-02-24 22:17:28.834	warn	at Object.<anonymous> (script.js.common.Service.Stromverbrauch:106:1)
      javascript.0	2019-02-24 22:17:28.834	warn	at berechneVerbrauchKosten (script.js.common.Service.Stromverbrauch:215:76)
      javascript.0	2019-02-24 22:17:28.834	warn	getState "javascript.0.Strom.Messwert_Waschmaschine.Zaehlerstand.Jahr" not found (3) states[id]=null
      javascript.0	2019-02-24 22:17:28.834	warn	at TCP.onread (net.js:559:20)
      javascript.0	2019-02-24 22:17:28.834	warn	at Socket.Readable.push (_stream_readable.js:134:10)
      javascript.0	2019-02-24 22:17:28.834	warn	at readableAddChunk (_stream_readable.js:176:18)
      javascript.0	2019-02-24 22:17:28.834	warn	at Socket.emit (events.js:188:7)
      javascript.0	2019-02-24 22:17:28.833	warn	at emitOne (events.js:96:13)
      javascript.0	2019-02-24 22:17:28.833	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/redis/index.js:274:27)
      javascript.0	2019-02-24 22:17:28.833	warn	at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:574:12)
      javascript.0	2019-02-24 22:17:28.833	warn	at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/redis/index.js:192:18)
      javascript.0	2019-02-24 22:17:28.833	warn	at RedisClient.return_reply (/opt/iobroker/node_modules/redis/index.js:833:9)
      javascript.0	2019-02-24 22:17:28.833	warn	at return_pub_sub (/opt/iobroker/node_modules/redis/index.js:794:18)
      javascript.0	2019-02-24 22:17:28.833	warn	at RedisClient.emit (events.js:194:7)
      javascript.0	2019-02-24 22:17:28.833	warn	at emitThree (events.js:116:13)
      javascript.0	2019-02-24 22:17:28.833	warn	at RedisClient.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:603:25)
      javascript.0	2019-02-24 22:17:28.833	warn	at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37)
      javascript.0	2019-02-24 22:17:28.833	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:358:25)
      javascript.0	2019-02-24 22:17:28.833	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:961:38)
      javascript.0	2019-02-24 22:17:28.833	warn	at Object.<anonymous> (script.js.common.Service.Stromverbrauch:106:1)
      javascript.0	2019-02-24 22:17:28.833	warn	at berechneVerbrauchKosten (script.js.common.Service.Stromverbrauch:214:78)
      javascript.0	2019-02-24 22:17:28.833	warn	getState "javascript.0.Strom.Messwert_Waschmaschine.Zaehlerstand.Jahr" not found (3) states[id]=null
      javascript.0	2019-02-24 22:17:28.833	warn	at TCP.onread (net.js:559:20)
      javascript.0	2019-02-24 22:17:28.833	warn	at Socket.Readable.push (_stream_readable.js:134:10)
      javascript.0	2019-02-24 22:17:28.833	warn	at readableAddChunk (_stream_readable.js:176:18)
      javascript.0	2019-02-24 22:17:28.833	warn	at Socket.emit (events.js:188:7)
      javascript.0	2019-02-24 22:17:28.832	warn	at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/redis/index.js:192:18)
      javascript.0	2019-02-24 22:17:28.832	warn	at RedisClient.return_reply (/opt/iobroker/node_modules/redis/index.js:833:9)
      javascript.0	2019-02-24 22:17:28.832	warn	at return_pub_sub (/opt/iobroker/node_modules/redis/index.js:794:18)
      javascript.0	2019-02-24 22:17:28.832	warn	at RedisClient.emit (events.js:194:7)
      javascript.0	2019-02-24 22:17:28.832	warn	at emitThree (events.js:116:13)
      javascript.0	2019-02-24 22:17:28.832	warn	at RedisClient.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:603:25)
      javascript.0	2019-02-24 22:17:28.832	warn	at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37)
      javascript.0	2019-02-24 22:17:28.832	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:358:25)
      javascript.0	2019-02-24 22:17:28.832	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:961:38)
      javascript.0	2019-02-24 22:17:28.832	warn	at Object.<anonymous> (script.js.common.Service.Stromverbrauch:106:1)
      javascript.0	2019-02-24 22:17:28.832	warn	at berechneVerbrauchKosten (script.js.common.Service.Stromverbrauch:212:79)
      javascript.0	2019-02-24 22:17:28.832	warn	getState "javascript.0.Strom.Messwert_Waschmaschine.Zaehlerstand.Quartal" not found (3) states[id]=null
      javascript.0	2019-02-24 22:17:28.832	warn	at TCP.onread (net.js:559:20)
      javascript.0	2019-02-24 22:17:28.832	warn	at Socket.Readable.push (_stream_readable.js:134:10)
      javascript.0	2019-02-24 22:17:28.832	warn	at readableAddChunk (_stream_readable.js:176:18)
      Gruß Totocotonio
      Bin noch Anfänger in Sachen IO-Broker und lerne gerne dazu. :P
        totocotonio
        top
        Gruß Totocotonio
          totocotonio
          wieso erscheint der przess java script 2 mal
          Gruß Totocotonio
          • wendy2702W Offline
            wendy2702W Offline
            Laut log und Screenshot hast du ein Problem mit einem Script welches eine solar Pumpe beinhaltet.
              totocotonio
              ok, habe mal das Script gestoppt aber das läuft eigentlich schon lange
              Gruß Totocotonio
                @totocotonio sagte in CPU Last hoch:
                Bitte beide killen und einmal über den admin neu starten.
                Dann weiter beobachten
                totocotonioT 1 Antwort Letzte Antwort
                  totocotonio
                  schrieb am zuletzt editiert von totocotonio
                  @Homoran
                  wie mache ich das und wo
                  TOP läuft immer noch und geht nicht aus
                  Gruß Totocotonio
                  HomoranH wendy2702W 3 Antworten Letzte Antwort
                    @Homoran
                    @totocotonio
                    sudo kill -9 <PID>
                    wobei <PID> die Prozess ID ist
                      @Homoran
                      wendy2702W Offline
                      wendy2702W Offline
                      @totocotonio
                      Strg +c
                        @Homoran
                        STRG-C
                          totocotonio
                          bash: kill: (2014) - Kein passender Prozess gefunden
                          root@buanet-iobroker1:/opt/iobroker# kill -9 20014
                          bash: kill: (20014) - Kein passender Prozess gefunden
                          root@buanet-iobroker1:/opt/iobroker# sudo kill -9 20014
                          sudo: Hostname buanet-iobroker1 kann nicht aufgelöst werden
                          kill: (20014): Kein passender Prozess gefunden
                          geht nicht
                          Gruß Totocotonio
                            geht nicht
                            @totocotonio
                            Wenn sich da nichts geändert hat sind es 1583 und 341
                              totocotonio
                              ok, ist beendet
                              Und jetzt wie starte ich wieder.
                              Der Adapter ist grün
                              Gruß Totocotonio
                                ok, ist beendet
                                @totocotonio
                                Und was sagt top jetzt
                                  totocotonio
                                  Gruß Totocotonio
                                    totocotonio
                                    der Java Adapter ist grün woran hängt das denn
                                    Gruß Totocotonio
                                      @totocotonio
                                      Da hätte im log ein code7 error stehen müssen.
                                      Instace restartet because enabled...adapter already running code7
                                      Oder so.
                                      Da hat sich ioBroker irgendwo bei einem restart verschluckt
                                        totocotonio
                                        Ja, das habe ich im LOG gefunden.
                                        Das müsste doch aber bei einem Neustart weg sein.
                                        Ich habe den Docker mehrfach neu gestartet.
                                        Gruß Totocotonio
                                        totocotonioT HomoranH 2 Antworten Letzte Antwort
                                          totocotonio
                                          @totocotonio
                                          ist das jetzt gut so? 😓
                                          Gruß Totocotonio
