  4. Uninstall - install problem
50 Beiträge 7 Kommentatoren 18.2k Aufrufe
    smiling_Jack
    Komish kannst du mal den web einzelt nachinstalliren (npm install iobroker.web )
    • derAugeD Offline
      derAugeD Offline
      derAuge
      @smiling-Jack:
      Komish kannst du mal den web einzelt nachinstalliren (npm install iobroker.web ) `
      keine Änderung
      root@VMioBrokerMaster:/opt/iobroker# npm install iobroker.web
      npm WARN deprecated object-keys@0.2.0: Please update to the latest object-keys
      > ws@0.4.31 install /opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/engine.io/node_modules/ws
      > (node-gyp rebuild 2> builderror.log) || (exit 0)
      > ws@0.4.31 install /opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws
      iobroker.web@0.2.6 node_modules/iobroker.web
      ├── connect-flash@0.1.1
      ├── iobroker.simple-api@0.0.4
      ├── passport-local@1.0.0 (passport-strategy@1.0.0)
      ├── cookie-parser@1.3.4 (cookie@0.1.2, cookie-signature@1.0.6)
      ├── passport@0.2.1 (pause@0.0.1, passport-strategy@1.0.0)
      ├── xtend@2.0.6 (is-object@0.1.2, object-keys@0.2.0)
      ├── body-parser@1.5.2 (qs@0.6.6, media-typer@0.2.0, bytes@1.0.0, raw-body@1.3.0, depd@0.4.4, type-is@1.3.2, iconv-lite@0.4.4)
      ├── express-session@1.7.6 (utils-merge@1.0.0, cookie@0.1.2, cookie-signature@1.0.4, on-headers@1.0.0, parseurl@1.3.0, buffer-crc32@0.2.3, depd@0.4.4, debug@1.0.4, uid-safe@1.0.1)
      ├── express@4.4.5 (parseurl@1.0.1, utils-merge@1.0.0, merge-descriptors@0.0.2, cookie@0.1.2, cookie-signature@1.0.4, escape-html@1.0.1, range-parser@1.0.0, fresh@0.2.2, vary@0.1.0, qs@0.6.6, methods@1.0.1, serve-static@1.2.3, buffer-crc32@0.2.3, path-to-regexp@0.1.2, debug@1.0.2, type-is@1.2.1, accepts@1.0.7, proxy-addr@1.0.1, send@0.4.3)
      ├── request@2.38.0 (json-stringify-safe@5.0.0, aws-sign2@0.5.0, forever-agent@0.5.2, oauth-sign@0.3.0, stringstream@0.0.4, tunnel-agent@0.4.0, qs@0.6.6, node-uuid@1.4.3, mime-types@1.0.2, tough-cookie@0.12.1, http-signature@0.10.1, form-data@0.1.4, hawk@1.1.1)
      └── iobroker.socketio@0.2.3 (request@2.51.0, socket.io@1.1.0)
      root@VMioBrokerMaster:/opt/iobroker# ps -A |grep io
           6 ?        00:00:00 migration/0
         204 ?        00:00:00 ext4-dio-unwrit
        1711 ?        00:00:00 rpciod
        1713 ?        00:00:00 nfsiod
      root@VMioBrokerMaster:/opt/iobroker# iobroker restart
      ioBroker controller daemon is not running
      Starting ioBroker controller daemon...
      ioBroker controller daemon started. PID: 2596
        2596 ?        00:00:00 io.js-controlle
        starfish
        nur zur Info, der workaround funktioniert nun grösstenteils.
        ausser hm-rega - lässt sich nicht als instanz installieren. auch nicht bei manueller neu-installation (npm install iobroker.hm-rega)
        vielleicht wäre grundsätzlich eine npm-repo (heisst das hier auch so?) mit der Vor-Version nicht schlecht - oder sonst eine Möglichkeit, Vor-Versionen zu installieren.
        Wie auch immer , habe mich auf warten eingestellt.
          starfish
          gibts news - läuft die Installation wieder?
          • BluefoxB Offline
            BluefoxB Offline
            Also. Ich will immer noch nicht auf npm hoch legen, bis ich eine Bestätigung bekomme, dass es noch bei jemandem geht.
            Es gibt aktuelle ioBroker.js-controller version 0.6.1. Die kann man mit
            npm install https://github.com/ioBroker/ioBroker.js-controller/tarball/master
            installieren.
            Für die Neuinstallation, dann:
            Kann jemand ausprobieren? Ich habe Windows, Debian und Ubuntu getestet. Update und Neuinstallation. Node.js 0.10.29/0.10.35/0.12.2
              Habe eben mal schnell drüberinstalliert.
              Keine Fehlermeldungen während des install.
              Nach anschließendem reboot auch keine Fehlermeldungen im log beim Hochfahren!
              RPi2 mit Raspian, nodejs 10.22.
                akamia
                Neuinstallation auf CubieTruck funktioniert auch gut –> Restart ist erforderlich
                NUC6i3 / ProxMox / HM/FHEM/WifiLight/HUE/Tradfri/KM200/InfluxDB/RFlink/Plex/Smartmeter
                piVCCU, Arduinos, X4000, Z2000, Solo4K, SAMSUNG C & H, NAS OMV4/Win10Pro (JRMC/JRemote), 4x4 HDMImatrix, ...
                  Hallo Bluefox,
                  Ist doch wohl noch irgendetwas im Argen
                  Habe heute morgen auf dem PC den admin geöffnet:
                  Habe es gestern nur vom Handy aus gemacht - habe da evtl. die unteren Zeilen nicht gesehen!
                  Weder ./iobroker restart noch reboot haben geholfen.
                  Auch ein erneutes
                  brachte nichts, weder mit restart noch mit reboot
                  Jedoch keine Fehler während des Install oder nach dem reboot im log.
                  EDIT:
                  nach mehrmaligem reboot ist es jetzt auf einmal (ohne weiteren reboot) wieder ok !???
                  Im Vorfeld hatte ich Browsercache mehrfach gelöscht - ohne Änderungen ?!!???
                  Dafür fielen mir folgende Meldungen im log auf:
                  history-0	2015-04-15 10:43:02	info	moved 18 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150415
                  history-0	2015-04-15 10:43:02	info	moved 52 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150414
                  history-0	2015-04-15 10:43:02	info	18 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                  history-0	2015-04-15 10:43:02	info	moved 146 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150413
                  history-0	2015-04-15 10:43:02	info	52 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                  history-0	2015-04-15 10:43:02	info	moved 183 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150412
                  history-0	2015-04-15 10:43:02	info	146 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                  history-0	2015-04-15 10:43:02	info	moved 213 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150411
                  history-0	2015-04-15 10:43:02	info	183 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                  history-0	2015-04-15 10:43:02	info	moved 239 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150410
                  history-0	2015-04-15 10:43:02	info	213 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                  history-0	2015-04-15 10:43:02	info	moved 258 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150409
                  history-0	2015-04-15 10:43:02	info	239 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                  history-0	2015-04-15 10:43:02	info	moved 294 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150408
                  history-0	2015-04-15 10:43:02	info	258 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                  history-0	2015-04-15 10:43:02	info	moved 331 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150407
                  history-0	2015-04-15 10:43:02	info	294 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                  history-0	2015-04-15 10:43:02	info	moved 413 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150406
                  history-0	2015-04-15 10:43:02	info	331 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                  history-0	2015-04-15 10:43:02	info	[color]moved 445 history datapoints [b]from Redis[/b] history.hm-rpc.0.JEQ0267518.1.HUMIDITY [b]to CouchDB[/b][/color] history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150405
                  history-0	2015-04-15 10:43:02	info	413 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                  history-0	2015-04-15 10:43:02	info	moved 480 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150404
                  history-0	2015-04-15 10:43:02	info	445 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                  moved … datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB
                    akamia
                    Konnte gestern keinen Adapter installieren.
                      Bei mir kommt jetzt - nach längerer Laufzeit - alle paar minuten von hmm und node-red Adaptern:
                      quad-pi	2015-04-15 14:02:44	error	host.quad-pi instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
                      auch die folgende Meldung nach ./iobroker update über putty ist recht amüsant:
                      Controller "js-controller" : 0.5.15   , installed 0.6.1 [Updateable]
                      • derAugeD Offline
                        derAugeD Offline
                        derAuge
                        @Bluefox:
                        installieren.
                        Kann jemand ausprobieren? Ich habe Windows, Debian und Ubuntu getestet. Update und Neuinstallation. Node.js 0.10.29/0.10.35/0.12.2 `
                        Neuinstall auf einer VM
                        root@VMioBrokerMaster:~# cd /opt/iobroker/
                        root@VMioBrokerMaster:/opt/iobroker# npm install https://github.com/ioBroker/ioBroker.js-controller/tarball/master
                        > ws@0.5.0 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/node_modules/ws
                        > ws@0.4.31 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws
                        > iobroker.js-controller@0.6.1 install /opt/iobroker/node_modules/iobroker.js-controller
                        > node lib/setup.js setup first
                        creating conf/iobroker.json
                        object system.certificates created
                        object system.repositories created
                        object system.config created
                        object enum.rooms created
                        object system.group.user created
                        object system.group.administrator created
                        object _design/system created
                        object system.user.admin created
                        object system.meta.uuid created
                        install adapter admin
                        got /opt/iobroker/node_modules/iobroker.js-controller/node_modules/iobroker.admin/admin
                        upload admin.admin /opt/iobroker/node_modules/iobroker.js-controller/node_modules/iobroker.admin/admin/index.html index.html text/html
                        upload admin.admin /opt/iobroker/node_modules/iobroker.js-controller/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                        object system.adapter.admin created
                        create instance admin
                        object system.adapter.admin.0.uptime created
                        object system.adapter.admin.0.memRss created
                        object system.adapter.admin.0.memHeapTotal created
                        object system.adapter.admin.0.memHeapUsed created
                        object system.adapter.admin.0.connected created
                        object system.adapter.admin.0.alive created
                        object system.adapter.admin.0 created
                        iobroker.js-controller@0.6.1 node_modules/iobroker.js-controller
                        ├── daemonize2@0.4.2
                        ├── mime@1.3.4
                        ├── node-schedule@0.1.13
                        ├── ncp@2.0.0
                        ├── adm-zip@0.4.7
                        ├── node.extend@1.1.3 (is@2.1.0)
                        ├── yargs@3.7.2 (camelcase@1.0.2, decamelize@1.0.0, window-size@0.1.0, wordwrap@0.0.2)
                        ├── npm@2.7.6
                        ├── winston@1.0.0 (cycle@1.0.3, stack-trace@0.0.9, eyes@0.1.8, isstream@0.1.2, pkginfo@0.3.0, async@0.9.0, colors@1.0.3)
                        ├── socket.io@1.3.5 (debug@2.1.0, has-binary-data@0.1.3, socket.io-adapter@0.3.1, socket.io-parser@2.2.4, engine.io@1.5.1)
                        ├── tar.gz@0.1.1 (commander@1.1.1, tar@0.1.20, fstream@0.1.31)
                        ├── request@2.55.0 (caseless@0.9.0, json-stringify-safe@5.0.0, aws-sign2@0.5.0, forever-agent@0.6.1, stringstream@0.0.4, oauth-sign@0.6.0, tunnel-agent@0.4.0, isstream@0.1.2, node-uuid@1.4.3, qs@2.4.1, combined-stream@0.0.7, mime-types@2.0.10, form-data@0.2.0, http-signature@0.10.1, hawk@2.3.1, bl@0.9.4, tough-cookie@0.12.1, har-validator@1.6.1)
                        ├── socket.io-client@1.3.5 (to-array@0.1.3, indexof@0.0.1, component-bind@1.0.0, debug@0.7.4, backo2@1.0.2, object-component@0.0.3, component-emitter@1.1.2, has-binary@0.1.6, socket.io-parser@2.2.4, parseuri@0.0.2, engine.io-client@1.5.1)
                        └── iobroker.admin@0.3.27 (connect-flash@0.1.1, xtend@4.0.0, passport-local@1.0.0, passport@0.2.1, cookie-parser@1.3.4, express-session@1.11.1, body-parser@1.12.2, express@4.12.3)
                        > iobroker@0.5.1 install /opt/iobroker/node_modules/iobroker
                        > node lib/setup.js
                        npm install iobroker.js-controller --production --silent --prefix "/opt/iobroker/node_modules/iobroker/lib/../../../"
                        npm install iobroker.admin --production --silent --prefix "/opt/iobroker/node_modules/iobroker/lib/../../../"
                        Write "./iobroker start" to start the ioBroker
                        Auto-start was enabled. Write "update-rc.d -f iobroker.sh remove" to disable auto-start
                        iobroker is started. Go to "http://ip-addr:8081" to open the admin UI.
                        iobroker@0.5.1 node_modules/iobroker
                        └── yargs@1.2.6 (minimist@0.1.0)
                        ├── mime@1.3.4
                        ├── ncp@2.0.0
                        ├── adm-zip@0.4.7
                        ├── yargs@3.7.2 (decamelize@1.0.0, camelcase@1.0.2, window-size@0.1.0, wordwrap@0.0.2)
                        ├── socket.io@1.3.5 (debug@2.1.0, has-binary-data@0.1.3, socket.io-adapter@0.3.1, engine.io@1.5.1, socket.io-parser@2.2.4)
                        ├── request@2.55.0 (caseless@0.9.0, json-stringify-safe@5.0.0, aws-sign2@0.5.0, forever-agent@0.6.1, stringstream@0.0.4, oauth-sign@0.6.0, tunnel-agent@0.4.0, isstream@0.1.2, node-uuid@1.4.3, qs@2.4.1, combined-stream@0.0.7, form-data@0.2.0, mime-types@2.0.10, http-signature@0.10.1, bl@0.9.4, tough-cookie@0.12.1, hawk@2.3.1, har-validator@1.6.1)
                        ├── socket.io-client@1.3.5 (to-array@0.1.3, indexof@0.0.1, component-bind@1.0.0, debug@0.7.4, backo2@1.0.2, object-component@0.0.3, component-emitter@1.1.2, has-binary@0.1.6, parseuri@0.0.2, socket.io-parser@2.2.4, engine.io-client@1.5.1)
                        └── npm@2.7.6
                        controller = 0.6.1(Running: 0.5.15)
                        root@VMioBrokerMaster:/opt/iobroker# node -v
                        v0.10.38
                        Die Adapter wurden erst nach 2maligem Update angezeigt
                        Install VIS
                        iobroker	2015-04-15 18:25:27	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.zwave/master/io-package.json. Error: Error: ETIMEDOUT
                        iobroker	2015-04-15 18:25:27	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.yr/master/io-package.json. Error: Error: ETIMEDOUT
                        iobroker	2015-04-15 18:25:27	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.onkyo/master/io-package.json. Error: Error: ETIMEDOUT
                        iobroker	2015-04-15 18:25:27	info	npm install iobroker.vis --production --prefix "/opt/iobroker" (System call)
                        iobroker	2015-04-15 18:25:22	info	add vis
                        nach der Installation von YR wurde auch vis noch mit installiert
                        VMioBrokerMaster	2015-04-15 18:27:55	info	iobroker object-keys@0.2.0: Please update to the latest object-keys
                        VMioBrokerMaster	2015-04-15 18:27:55	info	iobroker deprecated
                        VMioBrokerMaster	2015-04-15 18:27:55	info	iobroker WARN
                        VMioBrokerMaster	2015-04-15 18:27:55	info	iobroker npm
                        VMioBrokerMaster	2015-04-15 18:27:52	info	iobroker npm install iobroker.web --production --prefix "/opt/iobroker" (System call)
                        VMioBrokerMaster	2015-04-15 18:27:47	info	iobroker install adapter web
                        Anschließen konnte vis aufgerufen werden
                        derAuge
                        (Man sieht sich Samstag ;) )
                        • BluefoxB Offline
                          BluefoxB Offline
                          @Homoran:
                          EDIT:
                          Im Vorfeld hatte ich Browsercache mehrfach gelöscht - ohne Änderungen ?!!??? `
                          Es liegt an Timeout beim Zugang zu npmjs.org. Vielleicht war der WebServer gestern überlastet. Trotzdem habe ich Timeout erhöht.
                            Irgend etwas läuft da nicht sauber.
                            Habe eben über den admin nach updates suchen wollen. Dabei zeigt das log mir auf einmal an, dass er alle möglichen Adapter killt und auf terminating geht.
                            Nach dem wieder hochfahren gibt es wieder den Error 7, dass mindestens zwei Adapter doppelt laufen.
                            host-quad-pi 2015-04-16 15:45:23 info Restart adapter system.adapter.hmm.0 because enabled
                            host-quad-pi 2015-04-16 15:45:23 error instance system.adapter.hmm.0 terminated with code 7 (Adapter already running)
                            host-quad-pi 2015-04-16 15:45:21 info instance system.adapter.hmm.0 started with pid 1554
                            host-quad-pi 2015-04-16 15:45:17 info Restart adapter system.adapter.node-red.0 because enabled
                            host-quad-pi 2015-04-16 15:45:17 error instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
                            host-quad-pi 2015-04-16 15:45:15 info instance system.adapter.node-red.0 started with pid 1548
                            host-quad-pi 2015-04-16 15:44:58 info Update repository "default" under "conf/sources-dist.json"
                            host-quad-pi 2015-04-16 15:44:51 info Restart adapter system.adapter.hmm.0 because enabled
                            host-quad-pi 2015-04-16 15:44:51 error instance system.adapter.hmm.0 terminated with code 7 (Adapter already running)
                            host-quad-pi 2015-04-16 15:44:49 info instance system.adapter.hmm.0 started with pid 1510
                            host-quad-pi 2015-04-16 15:44:45 info Restart adapter system.adapter.node-red.0 because enabled
                            host-quad-pi 2015-04-16 15:44:45 error instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
                            host-quad-pi 2015-04-16 15:44:41 info instance system.adapter.node-red.0 started with pid 1493
                            javascript-0 2015-04-16 15:44:40 info received all states
                            javascript-0 2015-04-16 15:44:40 info received all objects
                            javascript-0 2015-04-16 15:44:37 info requesting all objects
                            javascript-0 2015-04-16 15:44:37 info requesting all states
                            javascript-0 2015-04-16 15:44:37 info starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.javascript
                            host-quad-pi 2015-04-16 15:44:35 info instance system.adapter.yr.0 terminated with code 0 (OK)
                            host-quad-pi 2015-04-16 15:44:34 info instance system.adapter.javascript.0 started with pid 1485
                            email-0 2015-04-16 15:44:31 info starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.email
                            yr-0 2015-04-16 15:44:30 info got weather data from yr.no
                            host-quad-pi 2015-04-16 15:44:29 info instance system.adapter.email.0 started with pid 1470
                            yr-0 2015-04-16 15:44:28 info starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.yr
                            host-quad-pi 2015-04-16 15:44:26 info instance system.adapter.ical.0 terminated with code 0 (OK)
                            host-quad-pi 2015-04-16 15:44:25 info instance system.adapter.yr.0 started with pid 1464
                            host-quad-pi 2015-04-16 15:44:25 info instance scheduled system.adapter.yr.0 0 * * * *
                            ical-0 2015-04-16 15:44:19 info processing URL: calendar1 http://192.168.2.225:5000/fbsharing/IQExBXbr
                            host-quad-pi 2015-04-16 15:44:19 info Restart adapter system.adapter.hmm.0 because enabled
                            host-quad-pi 2015-04-16 15:44:19 error instance system.adapter.hmm.0 terminated with code 7 (Adapter already running)
                            host-quad-pi 2015-04-16 15:44:17 info instance system.adapter.hmm.0 started with pid 1449
                            ical-0 2015-04-16 15:44:17 info starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.ical
                            host-quad-pi 2015-04-16 15:44:14 info instance system.adapter.ical.0 started with pid 1443
                            host-quad-pi 2015-04-16 15:44:13 info instance scheduled system.adapter.ical.0 0,30 * * * *
                            host-quad-pi 2015-04-16 15:44:11 info Restart adapter system.adapter.node-red.0 because enabled
                            host-quad-pi 2015-04-16 15:44:11 error instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
                            host-quad-pi 2015-04-16 15:44:10 info instance system.adapter.dwd.0 terminated with code 0 (OK)
                            host-quad-pi 2015-04-16 15:44:10 info instance system.adapter.node-red.0 started with pid 1428
                            ping-0 2015-04-16 15:44:07 info starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.ping
                            host-quad-pi 2015-04-16 15:44:05 info instance system.adapter.ping.0 started with pid 1418
                            dwd-0 2015-04-16 15:44:04 info setting states
                            dwd-0 2015-04-16 15:44:04 info starting. Version 0.1.7 in /opt/iobroker/node_modules/iobroker.dwd
                            web-0 2015-04-16 15:44:02 info http server listening on port 8082
                            web-0 2015-04-16 15:44:02 info socket.io server listening on port 8082
                            host-quad-pi 2015-04-16 15:44:01 info instance system.adapter.dwd.0 started with pid 1403
                            host-quad-pi 2015-04-16 15:44:01 info instance scheduled system.adapter.dwd.0 5,20,35,50 * * * *
                            web-0 2015-04-16 15:44:01 info starting. Version 0.2.6 in /opt/iobroker/node_modules/iobroker.web
                            hm-rega-0 2015-04-16 15:43:57 info got state values
                            hm-rega-0 2015-04-16 15:43:56 info request state values
                            hm-rega-0 2015-04-16 15:43:56 info deleted 0 variables
                            hm-rega-0 2015-04-16 15:43:56 info added/updated 64 variables
                            hm-rega-0 2015-04-16 15:43:56 info got 64 variables
                            hm-rega-0 2015-04-16 15:43:55 info deleted 0 programs
                            hm-rega-0 2015-04-16 15:43:55 info added/updated 56 programs
                            hm-rega-0 2015-04-16 15:43:54 info got 56 programs
                            host-quad-pi 2015-04-16 15:43:53 info instance system.adapter.web.0 started with pid 1396
                            hm-rega-0 2015-04-16 15:43:53 info added/updated rooms to enum.rooms
                            hm-rega-0 2015-04-16 15:43:53 info added/updated functions to enum.functions
                            hm-rega-0 2015-04-16 15:43:53 info added/updated 6 favorites to enum.favorites
                            hm-rega-0 2015-04-16 15:43:53 info time difference local-ccu 0s
                            hm-rega-0 2015-04-16 15:43:53 info ReGaHSS 192.168.2.186 up
                            history-0 2015-04-16 15:43:53 info enabled logging of ping.0.quad-pi.192_168_2_120
                            history-0 2015-04-16 15:43:53 info enabled logging of ping.0.quad-pi.192_168_2_7
                            history-0 2015-04-16 15:43:53 info enabled logging of ping.0.quad-pi.192_168_2_142
                            history-0 2015-04-16 15:43:53 info enabled logging of ping.0.quad-pi.192_168_2_75
                            history-0 2015-04-16 15:43:53 info enabled logging of dwd.0.warning.severity
                            history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.LEQ0081020.1.TEMPERATURE
                            history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.LEQ0081020.1.HUMIDITY
                            history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.KEQ0963067.1.TEMPERATURE
                            history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.JEQ0459186.1.MOTION
                            history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.JEQ0267518.1.TEMPERATURE
                            history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.JEQ0267518.1.HUMIDITY
                            history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.JEQ0140901.1.TEMPERATURE
                            history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.JEQ0140901.1.HUMIDITY
                            history-0 2015-04-16 15:43:53 info enabled logging of system.host.quad-pi.load
                            history-0 2015-04-16 15:43:53 info enabled logging of system.host.quad-pi.mem
                            hm-rega-0 2015-04-16 15:43:51 info subscribe hm-rpc.0.BidCoS-RF:50.PRESS_SHORT
                            hm-rega-0 2015-04-16 15:43:51 info starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.hm-rega
                            history-0 2015-04-16 15:43:53 info starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.history
                            hm-rpc-0 2015-04-16 15:43:51 info xmlrpc -> 327 devices
                            hm-rpc-0 2015-04-16 15:43:51 info xmlrpc <- listDevices ["hm-rpc.0"]
                            hm-rpc-0 2015-04-16 15:43:51 info xmlrpc <- system.listMethods ["hm-rpc.0"]
                            hm-rpc-0 2015-04-16 15:43:51 info xmlrpc -> 192.168.2.186:2001 init ["http://192.168.2.190:2001","hm-rpc.0"]
                            hm-rpc-0 2015-04-16 15:43:51 info xmlrpc server is trying to listen on 192.168.2.190:2001
                            hm-rpc-0 2015-04-16 15:43:50 info starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.hm-rpc
                            host-quad-pi 2015-04-16 15:43:50 info instance system.adapter.history.0 started with pid 1377
                            hm-rpc-0 2015-04-16 15:43:48 error no connection to objects DB
                            host-quad-pi 2015-04-16 15:43:46 info Update repository "default" under "conf/sources-dist.json"
                            host-quad-pi 2015-04-16 15:43:46 info instance system.adapter.hm-rega.0 started with pid 1371
                            admin-0 2015-04-16 15:43:45 info received all states
                            admin-0 2015-04-16 15:43:45 info received all objects
                            admin-0 2015-04-16 15:43:42 info Use link "http://localhost:8081" to configure.
                            admin-0 2015-04-16 15:43:42 info http server listening on port 8081
                            admin-0 2015-04-16 15:43:42 info requesting all objects
                            admin-0 2015-04-16 15:43:42 info requesting all states
                            admin-0 2015-04-16 15:43:42 info starting. Version 0.3.27 in /opt/iobroker/node_modules/iobroker.admin
                            hmm-0 2015-04-16 15:43:42 warn Reconnection to DB.
                            hmm-0 2015-04-16 15:43:41 warn Reconnection to DB.
                            host-quad-pi 2015-04-16 15:43:41 info instance system.adapter.hm-rpc.0 started with pid 1356
                            host-quad-pi 2015-04-16 15:43:37 info instance system.adapter.admin.0 started with pid 1354
                            host-quad-pi 2015-04-16 15:43:37 info starting 15 instances
                            host-quad-pi 2015-04-16 15:43:37 info 18 instances found
                            host-quad-pi 2015-04-16 15:43:37 info InMemoryDB connected
                            node-red-0 2015-04-16 15:43:38 warn Reconnection to DB.
                            inMem-objects 2015-04-16 15:43:37 info listening on port 9001
                            inMem-states 2015-04-16 15:43:37 info listening on port 9000
                            host-quad-pi 2015-04-16 15:43:37 info ip addresses: 192.168.2.190
                            host-quad-pi 2015-04-16 15:43:37 info hostname: quad-pi
                            host-quad-pi 2015-04-16 15:43:37 info Copyright (c) 2014-2015 bluefox, hobbyquaker
                            host-quad-pi 2015-04-16 15:43:37 info ioBroker.js-controller version 0.6.1 js-controller starting
                            hmm-0 2015-04-16 15:43:36 info hmm exited with 0
                            node-red-0 2015-04-16 15:43:35 info node-red exited with 0
                            email-0 2015-04-16 15:43:35 info terminating with timeout
                            ping-0 2015-04-16 15:43:35 info terminating with timeout
                            javascript-0 2015-04-16 15:43:34 info terminating
                            admin-0 2015-04-16 15:43:34 info terminating
                            web-0 2015-04-16 15:43:34 info terminating
                            hm-rega-0 2015-04-16 15:43:34 info terminating
                            history-0 2015-04-16 15:43:34 info terminating
                            TypeError: 2015-04-16 15:43:33 error at Timer.listOnTimeout [as ontimeout] (timers.js:110:15)
                            TypeError: 2015-04-16 15:43:33 error at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/statesInMemServer.js:464:25)
                            TypeError: 2015-04-16 15:43:33 error at States.change (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:142:48)
                            TypeError: 2015-04-16 15:43:33 error Cannot read property 'time' of undefined
                            hm-rpc-0 2015-04-16 15:43:34 info terminating
                            hmm-0 2015-04-16 15:43:33 info kill hmm task
                            node-red-0 2015-04-16 15:43:33 info kill node-red task
                            web-0 2015-04-16 15:43:33 info terminated http server on port 8082
                            web-0 2015-04-16 15:43:33 info terminating http server on port 8082
                            hm-rpc-0 2015-04-16 15:43:33 info xmlrpc -> 192.168.2.186:2001 init ["http://192.168.2.190:2001",""]
                            admin-0 2015-04-16 15:43:33 info terminating http server on port 8081
                            uncaught 2015-04-16 15:43:33 error exception: Cannot read property 'time' of undefined
                            Daraufhin habe ich über den Reiter hosts einen restart des RPi2 ausgelöst.
                            jetzt beschwert er sich beim runterfahren, dass diverse Adapetr immer noch laufen.
                            entsprechend taucht da auch der error code 7 wieder auf
                            quad-pi	2015-04-16 15:45:48	info	host.quad-pi Restart adapter system.adapter.admin.0 because enabled
                            quad-pi	2015-04-16 15:45:48	error	host.quad-pi instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
                            history.0	2015-04-16 15:45:43	warn	history.0 Reconnection to DB.
                            web.0	2015-04-16 15:45:45	warn	web.0 Reconnection to DB.
                            javascript.0	2015-04-16 15:45:45	warn	javascript.0 Reconnection to DB.
                            history.0	2015-04-16 15:45:42	warn	history.0 Reconnection to DB.
                            hm-rpc.0	2015-04-16 15:45:47	warn	hm-rpc.0 Reconnection to DB.
                            hm-rega.0	2015-04-16 15:45:43	warn	hm-rega.0 Reconnection to DB.
                            ping.0	2015-04-16 15:45:47	warn	ping.0 Reconnection to DB.
                            email.0	2015-04-16 15:45:47	warn	email.0 Reconnection to DB.
                            quad-pi	2015-04-16 15:45:47	info	host.quad-pi instance system.adapter.hm-rpc.0 started with pid 1599
                            admin.0	2015-04-16 15:45:43	warn	admin.0 Reconnection to DB.
                            quad-pi	2015-04-16 15:45:37	info	Adapter javascript still running
                            quad-pi	2015-04-16 15:45:37	info	Adapter email still running
                            quad-pi	2015-04-16 15:45:37	info	Adapter ping still running
                            quad-pi	2015-04-16 15:45:37	info	Adapter web still running
                            quad-pi	2015-04-16 15:45:37	info	Adapter history still running
                            quad-pi	2015-04-16 15:45:37	info	Adapter hm-rega still running
                            quad-pi	2015-04-16 15:45:37	info	Adapter hm-rpc still running
                            quad-pi	2015-04-16 15:45:37	info	Adapter admin still running
                            quad-pi	2015-04-16 15:45:37	info	host.quad-pi force terminated after 10s
                            quad-pi	2015-04-16 15:45:37	info	host.quad-pi received SIGTERM
                            quad-pi	2015-04-16 15:45:36	info	host.quad-pi received SIGTERM
                            quad-pi	2015-04-16 15:45:35	info	host.quad-pi received SIGTERM
                            quad-pi	2015-04-16 15:45:34	info	host.quad-pi received SIGTERM
                            quad-pi	2015-04-16 15:45:33	info	host.quad-pi received SIGTERM
                            host-quad-pi	2015-04-16 15:45:32	info	received SIGTERM
                            host-quad-pi	2015-04-16 15:45:31	info	received SIGTERM
                            host-quad-pi	2015-04-16 15:45:30	info	received SIGTERM
                            host-quad-pi	2015-04-16 15:45:29	info	received SIGTERM
                            host-quad-pi	2015-04-16 15:45:28	info	received SIGTERM
                            host-quad-pi	2015-04-16 15:45:27	info	received SIGTERM
                            iobroker	2015-04-16 15:45:26	info	exit 0
                            iobroker	2015-04-16 15:45:26	info	Starting node restart.js
                            iobroker	2015-04-16 15:45:26	info	_restart
                            ich wollte eigentlich nicht wieder rebooten. Dann läuft er meistens stabil.
                            in den rechten Spalten wechselt es dauern von rot nach grün :(
                            jetzt ist doch reboot angesagt :(
                            • BluefoxB Offline
                              BluefoxB Offline
                              Es hat sich irgendwas verhackt. Da hilft nur reboot.
                              Es gibt 0.6.3, wo update wieder funktionieren soll.
                                starfish
                                kann ich bestätigen
                                wie auch die Logeinträge sehen bei mir gleich aus.
                                • derAugeD Offline
                                  derAugeD Offline
                                  derAuge
                                  @Bluefox:
                                  Es gibt 0.6.3, wo update wieder funktionieren soll. `
                                  Was ist nun zu tun?
                                  root@pi2:/mnt/ioBroker/iobroker# iobroker restart
                                  module.js:340
                                      throw err;
                                  Error: Cannot find module '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/iobroker.js'
                                      at Function.Module._resolveFilename (module.js:338:15)
                                      at Function.Module._load (module.js:280:25)
                                      at Function.Module.runMain (module.js:497:10)
                                      at startup (node.js:119:16)
                                      at node.js:935:3
                                  • BluefoxB Offline
                                    BluefoxB Offline
                                    cd /mnt/ioBroker/iobroker.Pi2/
                                    ./iobroker start
                                    • BluefoxB Offline
                                      BluefoxB Offline
                                      @starfish:
                                      kann ich bestätigen
                                      wie auch die Logeinträge sehen bei mir gleich aus. `
                                      Reboot
                                        Auch bei controller 0.6.3 und neuem admin bleibt es dabei, dass bei einem ./iobroker restart einzelne Adapter nicht beendet werden (erst mal nur node-red und hmm) und nach dem restart doppelt laufen.
                                        Dadurch kommt es andauernd zu terminating code 7
                                        Nach reboot ist gut!
                                        Gesendet von meinem LIFETAB_S785X mit Tapatalk
                                        • derAugeD Offline
                                          derAugeD Offline
                                          derAuge
                                          INSTALL lief durch
                                          root@pi2:/mnt/ioBroker/iobroker# npm install iobroker.js-controller
                                          > ws@0.5.0 install /mnt/ioBroker/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/node_m                                           odules/engine.io/node_modules/ws
                                          make: Entering directory '/mnt/ioBroker/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io                                           /node_modules/engine.io/node_modules/ws/build'
                                            CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
                                            SOLINK_MODULE(target) Release/obj.target/bufferutil.node
                                            SOLINK_MODULE(target) Release/obj.target/bufferutil.node: Finished
                                            COPY Release/bufferutil.node
                                            CXX(target) Release/obj.target/validation/src/validation.o
                                            SOLINK_MODULE(target) Release/obj.target/validation.node
                                            SOLINK_MODULE(target) Release/obj.target/validation.node: Finished
                                            COPY Release/validation.node
                                          make: Leaving directory '/mnt/ioBroker/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/                                           node_modules/engine.io/node_modules/ws/build'
                                          > ws@0.4.31 install /mnt/ioBroker/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-clien                                           t/node_modules/engine.io-client/node_modules/ws
                                          make: Entering directory '/mnt/ioBroker/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io                                           -client/node_modules/engine.io-client/node_modules/ws/build'
                                          make: Leaving directory '/mnt/ioBroker/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-cl           ient/node_modules/ws/build'
                                          > iobroker.js-controller@0.6.3 install /mnt/ioBroker/iobroker/node_modules/iobroker.js-controller
                                          iobroker.js-controller@0.6.3 node_modules/iobroker.js-controller
                                          ├── mime@1.3.4
                                          ├── ncp@2.0.0
                                          ├── adm-zip@0.4.7
                                          ├── request@2.55.0 (caseless@0.9.0, json-stringify-safe@5.0.0, aws-sign2@0.5.0, forever-agent@0.6.1, stringstream@0.0.4, tunnel-agent@0.4.0, oauth-sign@0.6.0, isstream@0.1.2, node-uuid@1.4.3, qs@2.4.1, combined-stream@0.0.7, form-data@0.2.0, mime-types@2.0.10, http-signature@0.10.1, bl@0.9.4, tough-cookie@0.12.1, hawk@2.3.1, har-validator@1.6.1)
                                          ├── socket.io-client@1.3.5 (to-array@0.1.3, indexof@0.0.1, component-bind@1.0.0, debug@0.7.4, object-component@0.0.3, backo2@1.0.2, component-emitter@1.1.2, has-binary@0.1.6, parseuri@0.0.2, socket.io-parser@2.2.4, engine.io-client@1.5.1)
                                          └── npm@2.7.6
                                          Jedoch ist etwas mit dem symLink
                                          root@pi2:/mnt/ioBroker/iobroker# iobroker start
                                          module.js:340
                                              throw err;
                                              at node.js:935:3
                                          so startet der controler
                                          root@pi2:/mnt/ioBroker/iobroker# ./iobroker start
                                          ioBroker controller daemon started. PID: 2821
                                          aber Admin wird nicht gestartet
                                          root@pi2:/mnt/ioBroker/iobroker# ps -A |grep io
                                             10 ?        00:00:00 migration/0
                                             11 ?        00:00:00 migration/1
                                             15 ?        00:00:00 migration/2
                                             19 ?        00:00:00 migration/3
                                             30 ?        00:00:00 bioset
                                             33 ?        00:00:00 rpciod
                                             37 ?        00:00:00 nfsiod
                                             49 ?        00:00:00 DWC Notificatio
                                           2821 ?        00:00:03 io.js-controlle
