  4. Uninstall - install problem
50 Beiträge 7 Kommentatoren 18.2k Aufrufe
  • derAugeD Offline
    derAugeD Offline
    derAuge
    nachdem nun bei mit einige Testinstallationen "zerschossen" sind habe ich eine neue VM aufgesetzt
    nach der installation von nodejs
    root@VMioBrokerMaster:~# node -v
    v0.10.38
    kommt
    root@VMioBrokerMaster:~# npm install iobroker
    > iobroker@0.5.1 install /root/node_modules/iobroker
    > node lib/setup.js
    npm install iobroker.js-controller --production --silent --prefix "/root/node_modules/iobroker/lib/../../../"
    /root/node_modules/iobroker.js-controller/lib/tools.js:452
        if (adapter.substring(0, 'iobroker.'.length) == 'iobroker.') adapter = ada
    TypeError: Cannot call method 'substring' of undefined
        at Object.getAdapterDir (/root/node_modules/iobroker.js-controller/lib/tools.js:452:17)
        at uploadAdapter (/root/node_modules/iobroker.js-controller/lib/setup.js:1615:28)
        at installAdapter (/root/node_modules/iobroker.js-controller/lib/setup.js:2054:9)
        at Socket. <anonymous>(/root/node_modules/iobroker.js-controller/lib/setup.js:2080:13)
        at Socket.onack (/root/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:294:6)
        at Socket.onpacket (/root/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:219:12)
        at Manager. <anonymous>(/root/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
        at Manager.Emitter.emit (/root/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
        at Manager.ondecoded (/root/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:274:8)
        at Decoder. <anonymous>(/root/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    npm install iobroker.admin --production --silent --prefix "/root/node_modules/iobroker/lib/../../../"
    Write "./iobroker start" to start the ioBroker
    Non-critical error: ENOENT, no such file or directory '/root/node_modules/iobroker/lib/../../iobroker.js-controller/iobroker'
    iobroker@0.5.1 node_modules/iobroker
    └── yargs@1.2.6 (minimist@0.1.0)
    root@VMioBrokerMaster:~#</anonymous></anonymous></anonymous>
    auch der beschriebene WorkAround klappt nicht ganz
    der js.controller kann zwar gestartet werden
    jedoch läuft io.admin nicht. somit auch keine Möglichkeit aid das UI zuzugreifen
    root@VMioBrokerMaster:~# cd /opt/iobroker/node_modules/iobroker.js-controller
    root@VMioBrokerMaster:/opt/iobroker/node_modules/iobroker.js-controller# ./iobroker restart
    Stopping ioBroker controller daemon...
    ioBroker controller daemon stopped.
    Starting ioBroker controller daemon...
    ioBroker controller daemon started. PID: 2686
    root@VMioBrokerMaster:/opt/iobroker/node_modules/iobroker.js-controller# ps -A |grep io
         6 ?        00:00:00 migration/0
       191 ?        00:00:00 ext4-dio-unwrit
      1691 ?        00:00:00 rpciod
      1693 ?        00:00:00 nfsiod
      2686 ?        00:00:00 io.js-controlle
    Also heist es nun wohl: Warten bis der Urlauber zurück ist
      Hast du es so:
      http://forum.iobroker.org/viewtopic.php?p=3933#p3933
      Versucht?
      Gesendet von meinem Cynus T7 mit Tapatalk
        smiling_Jack
        Hallo
        ich habe die neue version vom js-controller zurückgezogen
        Eine Installation sollte wieder ganz normal funktioniren. Wichtig ist ein
        npm cache clean
        vorweg zumachen.
        Zur info es wird jetzt wieder Version 0.5.15 installiert
        Steffen
        • derAugeD Offline
          derAugeD Offline
          derAuge
          @smiling-Jack:
          Hallo
          npm cache clean
          vorweg zumachen.
          Steffen `
          OK. Getestet
          root@VMioBrokerMaster:/opt/iobroker# npm cache clean
          root@VMioBrokerMaster:/opt/iobroker# npm install iobroker
          npm ERR! not a package /tmp/npm-2534-cP-PEs+a/1427660539077-0.291726277442649/tmp.tgz
          > iobroker@0.5.1 install /opt/iobroker/node_modules/iobroker
          > node lib/setup.js
          npm install iobroker.js-controller --production --silent --prefix "/opt/iobroker/node_modules/iobroker/lib/../../../"
          npm install iobroker.admin --production --silent --prefix "/opt/iobroker/node_modules/iobroker/lib/../../../"
          Auto-start was enabled. Write "update-rc.d -f iobroker.sh remove" to disable auto-start
          iobroker is started. Go to "http://ip-addr:8081" to open the admin UI.
          root@VMioBrokerMaster:/opt/iobroker# ps -A |grep io
             170 ?        00:00:00 ext4-dio-unwrit
            1679 ?        00:00:00 rpciod
            1681 ?        00:00:00 nfsiod
            2641 ?        00:00:00 io.js-controlle
          Leider wird admin nicht gestartet.
          Manuell kann man auch nicht starten.
          root@VMioBrokerMaster:/opt/iobroker# iobroker update
          Cannot get version of "virtual".
          Cannot get version of "geofency".
          update done
          Adapter    "zwave"         : 0.1.0
          Adapter    "yr"            : 0.1.5
          Adapter    "web"           : 0.2.6
          Adapter    "vis"           : 0.2.11
          Adapter    "virtual"
          Adapter    "sonos"         : 0.1.6
          Adapter    "rickshaw"      : 0.2.2
          Adapter    "pushover"      : 0.1.0
          Adapter    "onkyo"         : 0.1.0
          Adapter    "telnet"        : 0.0.0
          Adapter    "socketio"      : 0.2.3
          Adapter    "simple-api"    : 0.0.4
          Adapter    "sayit"         : 0.3.6
          Adapter    "ping"          : 0.1.3
          Adapter    "node-red"      : 0.1.9
          Adapter    "mqtt"          : 0.1.7
          Adapter    "mobile"        : 0.0.2
          Adapter    "legacy"        : 0.1.12
          Adapter    "knx"           : 0.0.1
          Controller "js-controller" : 0.5.15   , installed 0.5.15
          Adapter    "javascript"    : 0.3.0
          Adapter    "ical"          : 0.1.0
          Adapter    "hmm"           : 0.0.17
          Adapter    "hue"           : 0.2.0
          Adapter    "hm-rpc"        : 0.4.0
          Adapter    "hm-rega"       : 0.2.1
          Adapter    "history"       : 0.1.3
          Adapter    "highcharts"    : 0.0.0
          Adapter    "graphite"      : 0.1.0
          Adapter    "geofency"
          Adapter    "example"       : 0.1.1    , installed 0.1.1
          Adapter    "email"         : 0.1.0
          Adapter    "dwd"           : 0.1.7
          Adapter    "cul"           : 0.0.2
          Adapter    "b-control-em"  : 0.1.1
          Adapter    "artnet"        : 0.0.3
          Adapter    "admin"         : 0.3.26   , installed 0.3.26
          root@VMioBrokerMaster:/opt/iobroker# iobroker start admin
          Please enter instance of adapter, e.g. "web.0"
          root@VMioBrokerMaster:/opt/iobroker# iobroker start admin.0
          Adapter "admin.0 does not exist.
            smiling_Jack
            Komish kannst du mal den web einzelt nachinstalliren (npm install iobroker.web )
            • derAugeD Offline
              derAugeD Offline
              derAuge
              @smiling-Jack:
              Komish kannst du mal den web einzelt nachinstalliren (npm install iobroker.web ) `
              keine Änderung
              root@VMioBrokerMaster:/opt/iobroker# npm install iobroker.web
              npm WARN deprecated object-keys@0.2.0: Please update to the latest object-keys
              > ws@0.4.31 install /opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/engine.io/node_modules/ws
              > (node-gyp rebuild 2> builderror.log) || (exit 0)
              > ws@0.4.31 install /opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws
              iobroker.web@0.2.6 node_modules/iobroker.web
              ├── connect-flash@0.1.1
              ├── iobroker.simple-api@0.0.4
              ├── passport-local@1.0.0 (passport-strategy@1.0.0)
              ├── cookie-parser@1.3.4 (cookie@0.1.2, cookie-signature@1.0.6)
              ├── passport@0.2.1 (pause@0.0.1, passport-strategy@1.0.0)
              ├── xtend@2.0.6 (is-object@0.1.2, object-keys@0.2.0)
              ├── body-parser@1.5.2 (qs@0.6.6, media-typer@0.2.0, bytes@1.0.0, raw-body@1.3.0, depd@0.4.4, type-is@1.3.2, iconv-lite@0.4.4)
              ├── express-session@1.7.6 (utils-merge@1.0.0, cookie@0.1.2, cookie-signature@1.0.4, on-headers@1.0.0, parseurl@1.3.0, buffer-crc32@0.2.3, depd@0.4.4, debug@1.0.4, uid-safe@1.0.1)
              ├── express@4.4.5 (parseurl@1.0.1, utils-merge@1.0.0, merge-descriptors@0.0.2, cookie@0.1.2, cookie-signature@1.0.4, escape-html@1.0.1, range-parser@1.0.0, fresh@0.2.2, vary@0.1.0, qs@0.6.6, methods@1.0.1, serve-static@1.2.3, buffer-crc32@0.2.3, path-to-regexp@0.1.2, debug@1.0.2, type-is@1.2.1, accepts@1.0.7, proxy-addr@1.0.1, send@0.4.3)
              ├── request@2.38.0 (json-stringify-safe@5.0.0, aws-sign2@0.5.0, forever-agent@0.5.2, oauth-sign@0.3.0, stringstream@0.0.4, tunnel-agent@0.4.0, qs@0.6.6, node-uuid@1.4.3, mime-types@1.0.2, tough-cookie@0.12.1, http-signature@0.10.1, form-data@0.1.4, hawk@1.1.1)
              └── iobroker.socketio@0.2.3 (request@2.51.0, socket.io@1.1.0)
                 204 ?        00:00:00 ext4-dio-unwrit
                1711 ?        00:00:00 rpciod
                1713 ?        00:00:00 nfsiod
              root@VMioBrokerMaster:/opt/iobroker# iobroker restart
              ioBroker controller daemon is not running
              ioBroker controller daemon started. PID: 2596
                2596 ?        00:00:00 io.js-controlle
                starfish
                nur zur Info, der workaround funktioniert nun grösstenteils.
                ausser hm-rega - lässt sich nicht als instanz installieren. auch nicht bei manueller neu-installation (npm install iobroker.hm-rega)
                vielleicht wäre grundsätzlich eine npm-repo (heisst das hier auch so?) mit der Vor-Version nicht schlecht - oder sonst eine Möglichkeit, Vor-Versionen zu installieren.
                Wie auch immer , habe mich auf warten eingestellt.
                  starfish
                  gibts news - läuft die Installation wieder?
                  • BluefoxB Offline
                    BluefoxB Offline
                    Also. Ich will immer noch nicht auf npm hoch legen, bis ich eine Bestätigung bekomme, dass es noch bei jemandem geht.
                    Es gibt aktuelle ioBroker.js-controller version 0.6.1. Die kann man mit
                    npm install https://github.com/ioBroker/ioBroker.js-controller/tarball/master
                    installieren.
                    Für die Neuinstallation, dann:
                    Kann jemand ausprobieren? Ich habe Windows, Debian und Ubuntu getestet. Update und Neuinstallation. Node.js 0.10.29/0.10.35/0.12.2
                      Habe eben mal schnell drüberinstalliert.
                      Keine Fehlermeldungen während des install.
                      Nach anschließendem reboot auch keine Fehlermeldungen im log beim Hochfahren!
                      RPi2 mit Raspian, nodejs 10.22.
                        akamia
                        Neuinstallation auf CubieTruck funktioniert auch gut –> Restart ist erforderlich
                        NUC6i3 / ProxMox / HM/FHEM/WifiLight/HUE/Tradfri/KM200/InfluxDB/RFlink/Plex/Smartmeter
                        piVCCU, Arduinos, X4000, Z2000, Solo4K, SAMSUNG C & H, NAS OMV4/Win10Pro (JRMC/JRemote), 4x4 HDMImatrix, ...
                          Hallo Bluefox,
                          Ist doch wohl noch irgendetwas im Argen
                          Habe heute morgen auf dem PC den admin geöffnet:
                          Habe es gestern nur vom Handy aus gemacht - habe da evtl. die unteren Zeilen nicht gesehen!
                          Weder ./iobroker restart noch reboot haben geholfen.
                          Auch ein erneutes
                          brachte nichts, weder mit restart noch mit reboot
                          Jedoch keine Fehler während des Install oder nach dem reboot im log.
                          EDIT:
                          nach mehrmaligem reboot ist es jetzt auf einmal (ohne weiteren reboot) wieder ok !???
                          Im Vorfeld hatte ich Browsercache mehrfach gelöscht - ohne Änderungen ?!!???
                          Dafür fielen mir folgende Meldungen im log auf:
                          history-0	2015-04-15 10:43:02	info	moved 18 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150415
                          history-0	2015-04-15 10:43:02	info	moved 52 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150414
                          history-0	2015-04-15 10:43:02	info	18 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                          history-0	2015-04-15 10:43:02	info	moved 146 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150413
                          history-0	2015-04-15 10:43:02	info	52 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                          history-0	2015-04-15 10:43:02	info	moved 183 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150412
                          history-0	2015-04-15 10:43:02	info	146 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                          history-0	2015-04-15 10:43:02	info	moved 213 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150411
                          history-0	2015-04-15 10:43:02	info	183 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                          history-0	2015-04-15 10:43:02	info	moved 239 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150410
                          history-0	2015-04-15 10:43:02	info	213 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                          history-0	2015-04-15 10:43:02	info	moved 258 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150409
                          history-0	2015-04-15 10:43:02	info	239 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                          history-0	2015-04-15 10:43:02	info	moved 294 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150408
                          history-0	2015-04-15 10:43:02	info	258 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                          history-0	2015-04-15 10:43:02	info	moved 331 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150407
                          history-0	2015-04-15 10:43:02	info	294 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                          history-0	2015-04-15 10:43:02	info	moved 413 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150406
                          history-0	2015-04-15 10:43:02	info	331 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                          history-0	2015-04-15 10:43:02	info	[color]moved 445 history datapoints [b]from Redis[/b] history.hm-rpc.0.JEQ0267518.1.HUMIDITY [b]to CouchDB[/b][/color] history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150405
                          history-0	2015-04-15 10:43:02	info	413 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                          history-0	2015-04-15 10:43:02	info	moved 480 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150404
                          history-0	2015-04-15 10:43:02	info	445 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                          moved … datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB
                            akamia
                            Konnte gestern keinen Adapter installieren.
                              Bei mir kommt jetzt - nach längerer Laufzeit - alle paar minuten von hmm und node-red Adaptern:
                              quad-pi	2015-04-15 14:02:44	error	host.quad-pi instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
                              auch die folgende Meldung nach ./iobroker update über putty ist recht amüsant:
                              Controller "js-controller" : 0.5.15   , installed 0.6.1 [Updateable]
                              • derAugeD Offline
                                derAugeD Offline
                                derAuge
                                @Bluefox:
                                installieren.
                                Kann jemand ausprobieren? Ich habe Windows, Debian und Ubuntu getestet. Update und Neuinstallation. Node.js 0.10.29/0.10.35/0.12.2 `
                                Neuinstall auf einer VM
                                root@VMioBrokerMaster:/opt/iobroker# npm install https://github.com/ioBroker/ioBroker.js-controller/tarball/master
                                > ws@0.5.0 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/node_modules/ws
                                > ws@0.4.31 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws
                                > iobroker.js-controller@0.6.1 install /opt/iobroker/node_modules/iobroker.js-controller
                                > node lib/setup.js setup first
                                creating conf/iobroker.json
                                object system.certificates created
                                object system.repositories created
                                object system.config created
                                object enum.rooms created
                                object system.group.user created
                                object system.group.administrator created
                                object _design/system created
                                object system.user.admin created
                                object system.meta.uuid created
                                install adapter admin
                                got /opt/iobroker/node_modules/iobroker.js-controller/node_modules/iobroker.admin/admin
                                upload admin.admin /opt/iobroker/node_modules/iobroker.js-controller/node_modules/iobroker.admin/admin/index.html index.html text/html
                                upload admin.admin /opt/iobroker/node_modules/iobroker.js-controller/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                                object system.adapter.admin created
                                create instance admin
                                object system.adapter.admin.0.uptime created
                                object system.adapter.admin.0.memRss created
                                object system.adapter.admin.0.memHeapTotal created
                                object system.adapter.admin.0.memHeapUsed created
                                object system.adapter.admin.0.connected created
                                object system.adapter.admin.0.alive created
                                object system.adapter.admin.0 created
                                iobroker.js-controller@0.6.1 node_modules/iobroker.js-controller
                                ├── daemonize2@0.4.2
                                ├── mime@1.3.4
                                ├── node-schedule@0.1.13
                                ├── ncp@2.0.0
                                ├── adm-zip@0.4.7
                                ├── node.extend@1.1.3 (is@2.1.0)
                                ├── yargs@3.7.2 (camelcase@1.0.2, decamelize@1.0.0, window-size@0.1.0, wordwrap@0.0.2)
                                ├── npm@2.7.6
                                ├── winston@1.0.0 (cycle@1.0.3, stack-trace@0.0.9, eyes@0.1.8, isstream@0.1.2, pkginfo@0.3.0, async@0.9.0, colors@1.0.3)
                                ├── socket.io@1.3.5 (debug@2.1.0, has-binary-data@0.1.3, socket.io-adapter@0.3.1, socket.io-parser@2.2.4, engine.io@1.5.1)
                                ├── tar.gz@0.1.1 (commander@1.1.1, tar@0.1.20, fstream@0.1.31)
                                ├── request@2.55.0 (caseless@0.9.0, json-stringify-safe@5.0.0, aws-sign2@0.5.0, forever-agent@0.6.1, stringstream@0.0.4, oauth-sign@0.6.0, tunnel-agent@0.4.0, isstream@0.1.2, node-uuid@1.4.3, qs@2.4.1, combined-stream@0.0.7, mime-types@2.0.10, form-data@0.2.0, http-signature@0.10.1, hawk@2.3.1, bl@0.9.4, tough-cookie@0.12.1, har-validator@1.6.1)
                                ├── socket.io-client@1.3.5 (to-array@0.1.3, indexof@0.0.1, component-bind@1.0.0, debug@0.7.4, backo2@1.0.2, object-component@0.0.3, component-emitter@1.1.2, has-binary@0.1.6, socket.io-parser@2.2.4, parseuri@0.0.2, engine.io-client@1.5.1)
                                └── iobroker.admin@0.3.27 (connect-flash@0.1.1, xtend@4.0.0, passport-local@1.0.0, passport@0.2.1, cookie-parser@1.3.4, express-session@1.11.1, body-parser@1.12.2, express@4.12.3)
                                > node lib/setup.js
                                ├── mime@1.3.4
                                ├── ncp@2.0.0
                                ├── adm-zip@0.4.7
                                ├── yargs@3.7.2 (decamelize@1.0.0, camelcase@1.0.2, window-size@0.1.0, wordwrap@0.0.2)
                                ├── socket.io@1.3.5 (debug@2.1.0, has-binary-data@0.1.3, socket.io-adapter@0.3.1, engine.io@1.5.1, socket.io-parser@2.2.4)
                                ├── request@2.55.0 (caseless@0.9.0, json-stringify-safe@5.0.0, aws-sign2@0.5.0, forever-agent@0.6.1, stringstream@0.0.4, oauth-sign@0.6.0, tunnel-agent@0.4.0, isstream@0.1.2, node-uuid@1.4.3, qs@2.4.1, combined-stream@0.0.7, form-data@0.2.0, mime-types@2.0.10, http-signature@0.10.1, bl@0.9.4, tough-cookie@0.12.1, hawk@2.3.1, har-validator@1.6.1)
                                ├── socket.io-client@1.3.5 (to-array@0.1.3, indexof@0.0.1, component-bind@1.0.0, debug@0.7.4, backo2@1.0.2, object-component@0.0.3, component-emitter@1.1.2, has-binary@0.1.6, parseuri@0.0.2, socket.io-parser@2.2.4, engine.io-client@1.5.1)
                                └── npm@2.7.6
                                controller = 0.6.1(Running: 0.5.15)
                                root@VMioBrokerMaster:/opt/iobroker# node -v
                                v0.10.38
                                Die Adapter wurden erst nach 2maligem Update angezeigt
                                Install VIS
                                iobroker	2015-04-15 18:25:27	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.zwave/master/io-package.json. Error: Error: ETIMEDOUT
                                iobroker	2015-04-15 18:25:27	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.yr/master/io-package.json. Error: Error: ETIMEDOUT
                                iobroker	2015-04-15 18:25:27	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.onkyo/master/io-package.json. Error: Error: ETIMEDOUT
                                iobroker	2015-04-15 18:25:27	info	npm install iobroker.vis --production --prefix "/opt/iobroker" (System call)
                                iobroker	2015-04-15 18:25:22	info	add vis
                                nach der Installation von YR wurde auch vis noch mit installiert
                                VMioBrokerMaster	2015-04-15 18:27:55	info	iobroker object-keys@0.2.0: Please update to the latest object-keys
                                VMioBrokerMaster	2015-04-15 18:27:55	info	iobroker deprecated
                                VMioBrokerMaster	2015-04-15 18:27:55	info	iobroker WARN
                                VMioBrokerMaster	2015-04-15 18:27:55	info	iobroker npm
                                VMioBrokerMaster	2015-04-15 18:27:52	info	iobroker npm install iobroker.web --production --prefix "/opt/iobroker" (System call)
                                VMioBrokerMaster	2015-04-15 18:27:47	info	iobroker install adapter web
                                Anschließen konnte vis aufgerufen werden
                                derAuge
                                (Man sieht sich Samstag ;) )
                                • BluefoxB Offline
                                  BluefoxB Offline
                                  @Homoran:
                                  EDIT:
                                  Im Vorfeld hatte ich Browsercache mehrfach gelöscht - ohne Änderungen ?!!??? `
                                  Es liegt an Timeout beim Zugang zu npmjs.org. Vielleicht war der WebServer gestern überlastet. Trotzdem habe ich Timeout erhöht.
                                    Irgend etwas läuft da nicht sauber.
                                    Habe eben über den admin nach updates suchen wollen. Dabei zeigt das log mir auf einmal an, dass er alle möglichen Adapter killt und auf terminating geht.
                                    Nach dem wieder hochfahren gibt es wieder den Error 7, dass mindestens zwei Adapter doppelt laufen.
                                    host-quad-pi 2015-04-16 15:45:23 info Restart adapter system.adapter.hmm.0 because enabled
                                    host-quad-pi 2015-04-16 15:45:23 error instance system.adapter.hmm.0 terminated with code 7 (Adapter already running)
                                    host-quad-pi 2015-04-16 15:45:21 info instance system.adapter.hmm.0 started with pid 1554
                                    host-quad-pi 2015-04-16 15:45:17 info Restart adapter system.adapter.node-red.0 because enabled
                                    host-quad-pi 2015-04-16 15:45:17 error instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
                                    host-quad-pi 2015-04-16 15:45:15 info instance system.adapter.node-red.0 started with pid 1548
                                    host-quad-pi 2015-04-16 15:44:58 info Update repository "default" under "conf/sources-dist.json"
                                    host-quad-pi 2015-04-16 15:44:51 info Restart adapter system.adapter.hmm.0 because enabled
                                    host-quad-pi 2015-04-16 15:44:51 error instance system.adapter.hmm.0 terminated with code 7 (Adapter already running)
                                    host-quad-pi 2015-04-16 15:44:49 info instance system.adapter.hmm.0 started with pid 1510
                                    host-quad-pi 2015-04-16 15:44:45 info Restart adapter system.adapter.node-red.0 because enabled
                                    host-quad-pi 2015-04-16 15:44:45 error instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
                                    host-quad-pi 2015-04-16 15:44:41 info instance system.adapter.node-red.0 started with pid 1493
                                    javascript-0 2015-04-16 15:44:40 info received all states
                                    javascript-0 2015-04-16 15:44:40 info received all objects
                                    javascript-0 2015-04-16 15:44:37 info requesting all objects
                                    javascript-0 2015-04-16 15:44:37 info requesting all states
                                    javascript-0 2015-04-16 15:44:37 info starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.javascript
                                    host-quad-pi 2015-04-16 15:44:35 info instance system.adapter.yr.0 terminated with code 0 (OK)
                                    host-quad-pi 2015-04-16 15:44:34 info instance system.adapter.javascript.0 started with pid 1485
                                    email-0 2015-04-16 15:44:31 info starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.email
                                    yr-0 2015-04-16 15:44:30 info got weather data from yr.no
                                    host-quad-pi 2015-04-16 15:44:29 info instance system.adapter.email.0 started with pid 1470
                                    yr-0 2015-04-16 15:44:28 info starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.yr
                                    host-quad-pi 2015-04-16 15:44:26 info instance system.adapter.ical.0 terminated with code 0 (OK)
                                    host-quad-pi 2015-04-16 15:44:25 info instance system.adapter.yr.0 started with pid 1464
                                    host-quad-pi 2015-04-16 15:44:25 info instance scheduled system.adapter.yr.0 0 * * * *
                                    ical-0 2015-04-16 15:44:19 info processing URL: calendar1 http://192.168.2.225:5000/fbsharing/IQExBXbr
                                    host-quad-pi 2015-04-16 15:44:19 info Restart adapter system.adapter.hmm.0 because enabled
                                    host-quad-pi 2015-04-16 15:44:19 error instance system.adapter.hmm.0 terminated with code 7 (Adapter already running)
                                    host-quad-pi 2015-04-16 15:44:17 info instance system.adapter.hmm.0 started with pid 1449
                                    ical-0 2015-04-16 15:44:17 info starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.ical
                                    host-quad-pi 2015-04-16 15:44:14 info instance system.adapter.ical.0 started with pid 1443
                                    host-quad-pi 2015-04-16 15:44:13 info instance scheduled system.adapter.ical.0 0,30 * * * *
                                    host-quad-pi 2015-04-16 15:44:11 info Restart adapter system.adapter.node-red.0 because enabled
                                    host-quad-pi 2015-04-16 15:44:11 error instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
                                    host-quad-pi 2015-04-16 15:44:10 info instance system.adapter.dwd.0 terminated with code 0 (OK)
                                    host-quad-pi 2015-04-16 15:44:10 info instance system.adapter.node-red.0 started with pid 1428
                                    ping-0 2015-04-16 15:44:07 info starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.ping
                                    host-quad-pi 2015-04-16 15:44:05 info instance system.adapter.ping.0 started with pid 1418
                                    dwd-0 2015-04-16 15:44:04 info setting states
                                    dwd-0 2015-04-16 15:44:04 info starting. Version 0.1.7 in /opt/iobroker/node_modules/iobroker.dwd
                                    web-0 2015-04-16 15:44:02 info http server listening on port 8082
                                    web-0 2015-04-16 15:44:02 info socket.io server listening on port 8082
                                    host-quad-pi 2015-04-16 15:44:01 info instance system.adapter.dwd.0 started with pid 1403
                                    host-quad-pi 2015-04-16 15:44:01 info instance scheduled system.adapter.dwd.0 5,20,35,50 * * * *
                                    web-0 2015-04-16 15:44:01 info starting. Version 0.2.6 in /opt/iobroker/node_modules/iobroker.web
                                    hm-rega-0 2015-04-16 15:43:57 info got state values
                                    hm-rega-0 2015-04-16 15:43:56 info request state values
                                    hm-rega-0 2015-04-16 15:43:56 info deleted 0 variables
                                    hm-rega-0 2015-04-16 15:43:56 info added/updated 64 variables
                                    hm-rega-0 2015-04-16 15:43:56 info got 64 variables
                                    hm-rega-0 2015-04-16 15:43:55 info deleted 0 programs
                                    hm-rega-0 2015-04-16 15:43:55 info added/updated 56 programs
                                    hm-rega-0 2015-04-16 15:43:54 info got 56 programs
                                    host-quad-pi 2015-04-16 15:43:53 info instance system.adapter.web.0 started with pid 1396
                                    hm-rega-0 2015-04-16 15:43:53 info added/updated rooms to enum.rooms
                                    hm-rega-0 2015-04-16 15:43:53 info added/updated functions to enum.functions
                                    hm-rega-0 2015-04-16 15:43:53 info added/updated 6 favorites to enum.favorites
                                    hm-rega-0 2015-04-16 15:43:53 info time difference local-ccu 0s
                                    hm-rega-0 2015-04-16 15:43:53 info ReGaHSS 192.168.2.186 up
                                    history-0 2015-04-16 15:43:53 info enabled logging of ping.0.quad-pi.192_168_2_120
                                    history-0 2015-04-16 15:43:53 info enabled logging of ping.0.quad-pi.192_168_2_7
                                    history-0 2015-04-16 15:43:53 info enabled logging of ping.0.quad-pi.192_168_2_142
                                    history-0 2015-04-16 15:43:53 info enabled logging of ping.0.quad-pi.192_168_2_75
                                    history-0 2015-04-16 15:43:53 info enabled logging of dwd.0.warning.severity
                                    history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.LEQ0081020.1.TEMPERATURE
                                    history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.LEQ0081020.1.HUMIDITY
                                    history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.KEQ0963067.1.TEMPERATURE
                                    history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.JEQ0459186.1.MOTION
                                    history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.JEQ0267518.1.TEMPERATURE
                                    history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.JEQ0267518.1.HUMIDITY
                                    history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.JEQ0140901.1.TEMPERATURE
                                    history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.JEQ0140901.1.HUMIDITY
                                    history-0 2015-04-16 15:43:53 info enabled logging of system.host.quad-pi.load
                                    history-0 2015-04-16 15:43:53 info enabled logging of system.host.quad-pi.mem
                                    hm-rega-0 2015-04-16 15:43:51 info subscribe hm-rpc.0.BidCoS-RF:50.PRESS_SHORT
                                    hm-rega-0 2015-04-16 15:43:51 info starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.hm-rega
                                    history-0 2015-04-16 15:43:53 info starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.history
                                    hm-rpc-0 2015-04-16 15:43:51 info xmlrpc -> 327 devices
                                    hm-rpc-0 2015-04-16 15:43:51 info xmlrpc <- listDevices ["hm-rpc.0"]
                                    hm-rpc-0 2015-04-16 15:43:51 info xmlrpc <- system.listMethods ["hm-rpc.0"]
                                    hm-rpc-0 2015-04-16 15:43:51 info xmlrpc -> 192.168.2.186:2001 init ["http://192.168.2.190:2001","hm-rpc.0"]
                                    hm-rpc-0 2015-04-16 15:43:51 info xmlrpc server is trying to listen on 192.168.2.190:2001
                                    hm-rpc-0 2015-04-16 15:43:50 info starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.hm-rpc
                                    host-quad-pi 2015-04-16 15:43:50 info instance system.adapter.history.0 started with pid 1377
                                    hm-rpc-0 2015-04-16 15:43:48 error no connection to objects DB
                                    host-quad-pi 2015-04-16 15:43:46 info Update repository "default" under "conf/sources-dist.json"
                                    host-quad-pi 2015-04-16 15:43:46 info instance system.adapter.hm-rega.0 started with pid 1371
                                    admin-0 2015-04-16 15:43:45 info received all states
                                    admin-0 2015-04-16 15:43:45 info received all objects
                                    admin-0 2015-04-16 15:43:42 info Use link "http://localhost:8081" to configure.
                                    admin-0 2015-04-16 15:43:42 info http server listening on port 8081
                                    admin-0 2015-04-16 15:43:42 info requesting all objects
                                    admin-0 2015-04-16 15:43:42 info requesting all states
                                    admin-0 2015-04-16 15:43:42 info starting. Version 0.3.27 in /opt/iobroker/node_modules/iobroker.admin
                                    hmm-0 2015-04-16 15:43:42 warn Reconnection to DB.
                                    hmm-0 2015-04-16 15:43:41 warn Reconnection to DB.
                                    host-quad-pi 2015-04-16 15:43:41 info instance system.adapter.hm-rpc.0 started with pid 1356
                                    host-quad-pi 2015-04-16 15:43:37 info instance system.adapter.admin.0 started with pid 1354
                                    host-quad-pi 2015-04-16 15:43:37 info starting 15 instances
                                    host-quad-pi 2015-04-16 15:43:37 info 18 instances found
                                    host-quad-pi 2015-04-16 15:43:37 info InMemoryDB connected
                                    node-red-0 2015-04-16 15:43:38 warn Reconnection to DB.
                                    inMem-objects 2015-04-16 15:43:37 info listening on port 9001
                                    inMem-states 2015-04-16 15:43:37 info listening on port 9000
                                    host-quad-pi 2015-04-16 15:43:37 info ip addresses: 192.168.2.190
                                    host-quad-pi 2015-04-16 15:43:37 info hostname: quad-pi
                                    host-quad-pi 2015-04-16 15:43:37 info Copyright (c) 2014-2015 bluefox, hobbyquaker
                                    host-quad-pi 2015-04-16 15:43:37 info ioBroker.js-controller version 0.6.1 js-controller starting
                                    hmm-0 2015-04-16 15:43:36 info hmm exited with 0
                                    node-red-0 2015-04-16 15:43:35 info node-red exited with 0
                                    email-0 2015-04-16 15:43:35 info terminating with timeout
                                    ping-0 2015-04-16 15:43:35 info terminating with timeout
                                    javascript-0 2015-04-16 15:43:34 info terminating
                                    admin-0 2015-04-16 15:43:34 info terminating
                                    web-0 2015-04-16 15:43:34 info terminating
                                    hm-rega-0 2015-04-16 15:43:34 info terminating
                                    history-0 2015-04-16 15:43:34 info terminating
                                    TypeError: 2015-04-16 15:43:33 error at Timer.listOnTimeout [as ontimeout] (timers.js:110:15)
                                    TypeError: 2015-04-16 15:43:33 error at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/statesInMemServer.js:464:25)
                                    TypeError: 2015-04-16 15:43:33 error at States.change (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:142:48)
                                    TypeError: 2015-04-16 15:43:33 error Cannot read property 'time' of undefined
                                    hm-rpc-0 2015-04-16 15:43:34 info terminating
                                    hmm-0 2015-04-16 15:43:33 info kill hmm task
                                    node-red-0 2015-04-16 15:43:33 info kill node-red task
                                    web-0 2015-04-16 15:43:33 info terminated http server on port 8082
                                    web-0 2015-04-16 15:43:33 info terminating http server on port 8082
                                    hm-rpc-0 2015-04-16 15:43:33 info xmlrpc -> 192.168.2.186:2001 init ["http://192.168.2.190:2001",""]
                                    admin-0 2015-04-16 15:43:33 info terminating http server on port 8081
                                    uncaught 2015-04-16 15:43:33 error exception: Cannot read property 'time' of undefined
                                    Daraufhin habe ich über den Reiter hosts einen restart des RPi2 ausgelöst.
                                    jetzt beschwert er sich beim runterfahren, dass diverse Adapetr immer noch laufen.
                                    entsprechend taucht da auch der error code 7 wieder auf
                                    quad-pi	2015-04-16 15:45:48	info	host.quad-pi Restart adapter system.adapter.admin.0 because enabled
                                    quad-pi	2015-04-16 15:45:48	error	host.quad-pi instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
                                    history.0	2015-04-16 15:45:43	warn	history.0 Reconnection to DB.
                                    web.0	2015-04-16 15:45:45	warn	web.0 Reconnection to DB.
                                    javascript.0	2015-04-16 15:45:45	warn	javascript.0 Reconnection to DB.
                                    history.0	2015-04-16 15:45:42	warn	history.0 Reconnection to DB.
                                    hm-rpc.0	2015-04-16 15:45:47	warn	hm-rpc.0 Reconnection to DB.
                                    hm-rega.0	2015-04-16 15:45:43	warn	hm-rega.0 Reconnection to DB.
                                    ping.0	2015-04-16 15:45:47	warn	ping.0 Reconnection to DB.
                                    email.0	2015-04-16 15:45:47	warn	email.0 Reconnection to DB.
                                    quad-pi	2015-04-16 15:45:47	info	host.quad-pi instance system.adapter.hm-rpc.0 started with pid 1599
                                    admin.0	2015-04-16 15:45:43	warn	admin.0 Reconnection to DB.
                                    quad-pi	2015-04-16 15:45:37	info	Adapter javascript still running
                                    quad-pi	2015-04-16 15:45:37	info	Adapter email still running
                                    quad-pi	2015-04-16 15:45:37	info	Adapter ping still running
                                    quad-pi	2015-04-16 15:45:37	info	Adapter web still running
                                    quad-pi	2015-04-16 15:45:37	info	Adapter history still running
                                    quad-pi	2015-04-16 15:45:37	info	Adapter hm-rega still running
                                    quad-pi	2015-04-16 15:45:37	info	Adapter hm-rpc still running
                                    quad-pi	2015-04-16 15:45:37	info	Adapter admin still running
                                    quad-pi	2015-04-16 15:45:37	info	host.quad-pi force terminated after 10s
                                    quad-pi	2015-04-16 15:45:37	info	host.quad-pi received SIGTERM
                                    quad-pi	2015-04-16 15:45:36	info	host.quad-pi received SIGTERM
                                    quad-pi	2015-04-16 15:45:35	info	host.quad-pi received SIGTERM
                                    quad-pi	2015-04-16 15:45:34	info	host.quad-pi received SIGTERM
                                    quad-pi	2015-04-16 15:45:33	info	host.quad-pi received SIGTERM
                                    host-quad-pi	2015-04-16 15:45:32	info	received SIGTERM
                                    host-quad-pi	2015-04-16 15:45:31	info	received SIGTERM
                                    host-quad-pi	2015-04-16 15:45:30	info	received SIGTERM
                                    host-quad-pi	2015-04-16 15:45:29	info	received SIGTERM
                                    host-quad-pi	2015-04-16 15:45:28	info	received SIGTERM
                                    host-quad-pi	2015-04-16 15:45:27	info	received SIGTERM
                                    iobroker	2015-04-16 15:45:26	info	exit 0
                                    iobroker	2015-04-16 15:45:26	info	Starting node restart.js
                                    iobroker	2015-04-16 15:45:26	info	_restart
                                    ich wollte eigentlich nicht wieder rebooten. Dann läuft er meistens stabil.
                                    in den rechten Spalten wechselt es dauern von rot nach grün :(
                                    jetzt ist doch reboot angesagt :(
                                    • BluefoxB Offline
                                      BluefoxB Offline
                                      Es hat sich irgendwas verhackt. Da hilft nur reboot.
                                      Es gibt 0.6.3, wo update wieder funktionieren soll.
                                        starfish
                                        kann ich bestätigen
                                        wie auch die Logeinträge sehen bei mir gleich aus.
                                        • derAugeD Offline
                                          derAugeD Offline
                                          derAuge
                                          @Bluefox:
                                          Es gibt 0.6.3, wo update wieder funktionieren soll. `
                                          Was ist nun zu tun?
                                          root@pi2:/mnt/ioBroker/iobroker# iobroker restart
                                          module.js:340
                                              throw err;
                                          Error: Cannot find module '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/iobroker.js'
                                              at Function.Module._resolveFilename (module.js:338:15)
                                              at Function.Module._load (module.js:280:25)
                                              at Function.Module.runMain (module.js:497:10)
                                              at startup (node.js:119:16)
                                              at node.js:935:3
