  3. Entwicklung
  4. [Adapter] Neuer radar2-Adapter
adapterradar2 adapter
840 Beiträge 80 Kommentatoren 319.9k Aufrufe 54 Beobachtet
    stimezo
    Forum Testing
    Auch von mir Danke für den Adapter.
    Bekomme auch den Fehler: node-bluetooth not found.
    npm install node-bluetooth --save
    führt zu:
    oot@orangepiplus:~# npm install node-bluetooth --save
    > node-bluetooth@1.2.5 install /root/node_modules/node-bluetooth
    > node-gyp configure build
    make: Entering directory '/root/node_modules/node-bluetooth/build'
      CXX(target) Release/obj.target/BluetoothSerialPort/src/linux/BluetoothSerialPort.o
      CXX(target) Release/obj.target/BluetoothSerialPort/src/linux/DeviceINQ.o
    ../src/linux/DeviceINQ.cc: In static member function ‘static void DeviceINQ::EIO_AfterSdpSearch(uv_work_t*)’:
    ../src/linux/DeviceINQ.cc:139:28: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated (declared at ../../nan/nan.h:1674) [-Wdeprecated-declarations]
         baton->cb->Call(1, argv);
    ../src/linux/DeviceINQ.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE DeviceINQ::InquireSync(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/linux/DeviceINQ.cc:251:26: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated (declared at ../../nan/nan.h:1674) [-Wdeprecated-declarations]
           found->Call(2, argv);
    ../src/linux/DeviceINQ.cc:255:27: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated (declared at ../../nan/nan.h:1674) [-Wdeprecated-declarations]
         callback->Call(0, argv);
    ../src/linux/DeviceINQ.cc: In member function ‘virtual void InquireWorker::HandleOKCallback()’:
    ../src/linux/DeviceINQ.cc:284:26: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated (declared at ../../nan/nan.h:1674) [-Wdeprecated-declarations]
    ../src/linux/DeviceINQ.cc:288:27: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated (declared at ../../nan/nan.h:1674) [-Wdeprecated-declarations]
      CXX(target) Release/obj.target/BluetoothSerialPort/src/linux/BTSerialPortBinding.o
    ../src/linux/BTSerialPortBinding.cc: In static member function ‘static void BTSerialPortBinding::EIO_AfterConnect(uv_work_t*)’:
    ../src/linux/BTSerialPortBinding.cc:83:32: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated (declared at ../../nan/nan.h:1674) [-Wdeprecated-declarations]
             baton->cb->Call(0, NULL);
    ../src/linux/BTSerialPortBinding.cc:89:33: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated (declared at ../../nan/nan.h:1674) [-Wdeprecated-declarations]
             baton->ecb->Call(1, argv);
    ../src/linux/BTSerialPortBinding.cc: In static member function ‘static void BTSerialPortBinding::EIO_Write(uv_work_t*)’:
    ../src/linux/BTSerialPortBinding.cc:115:22: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
         if (data->result != data->bufferLength) {
    ../src/linux/BTSerialPortBinding.cc: In static member function ‘static void BTSerialPortBinding::EIO_AfterWrite(uv_work_t*)’:
    ../src/linux/BTSerialPortBinding.cc:135:33: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated (declared at ../../nan/nan.h:1674) [-Wdeprecated-declarations]
         data->callback->Call(2, argv);
    ../src/linux/BTSerialPortBinding.cc: In static member function ‘static void BTSerialPortBinding::EIO_AfterRead(uv_work_t*)’:
    ../src/linux/BTSerialPortBinding.cc:207:28: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated (declared at ../../nan/nan.h:1674) [-Wdeprecated-declarations]
         baton->cb->Call(2, argv);
    ../src/linux/BTSerialPortBinding.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BTSerialPortBinding::Read(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/linux/BTSerialPortBinding.cc:383:25: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated (declared at ../../nan/nan.h:1674) [-Wdeprecated-declarations]
             nc->Call(2, argv);
      SOLINK_MODULE(target) Release/obj.target/BluetoothSerialPort.node
      COPY Release/BluetoothSerialPort.node
      CXX(target) Release/obj.target/BluetoothSerialPortServer/src/linux/BluetoothSerialPortServer.o
      CXX(target) Release/obj.target/BluetoothSerialPortServer/src/linux/BTSerialPortBindingServer.o
    ../src/linux/BTSerialPortBindingServer.cc: In static member function ‘static void BTSerialPortBindingServer::EIO_AfterListen(uv_work_t*)’:
    ../src/linux/BTSerialPortBindingServer.cc:176:33: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated (declared at ../../nan/nan.h:1674) [-Wdeprecated-declarations]
    ../src/linux/BTSerialPortBindingServer.cc: In static member function ‘static void BTSerialPortBindingServer::TryListenAgain()’:
    ../src/linux/BTSerialPortBindingServer.cc:199:31: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated (declared at ../../nan/nan.h:1674) [-Wdeprecated-declarations]
    ../src/linux/BTSerialPortBindingServer.cc: In static member function ‘static void BTSerialPortBindingServer::EIO_AfterWrite(uv_work_t*)’:
    ../src/linux/BTSerialPortBindingServer.cc:239:33: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated (declared at ../../nan/nan.h:1674) [-Wdeprecated-declarations]
    ../src/linux/BTSerialPortBindingServer.cc: In static member function ‘static void BTSerialPortBindingServer::EIO_AfterRead(uv_work_t*)’:
    ../src/linux/BTSerialPortBindingServer.cc:311:36: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated (declared at ../../nan/nan.h:1674) [-Wdeprecated-declarations]
    ../src/linux/BTSerialPortBindingServer.cc:326:28: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated (declared at ../../nan/nan.h:1674) [-Wdeprecated-declarations]
    ../src/linux/BTSerialPortBindingServer.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BTSerialPortBindingServer::Read(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/linux/BTSerialPortBindingServer.cc:618:25: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated (declared at ../../nan/nan.h:1674) [-Wdeprecated-declarations]
             nc->Call(2, argv);
    ../src/linux/BTSerialPortBindingServer.cc: In member function ‘virtual void BTSerialPortBindingServer::ClientWorker::HandleOKCallback()’:
    ../src/linux/BTSerialPortBindingServer.cc:672:27: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated (declared at ../../nan/nan.h:1674) [-Wdeprecated-declarations]
         callback->Call(1, argv);
      SOLINK_MODULE(target) Release/obj.target/BluetoothSerialPortServer.node
      COPY Release/BluetoothSerialPortServer.node
    make: Leaving directory '/root/node_modules/node-bluetooth/build'
    npm WARN saveError ENOENT: no such file or directory, open '/root/package.json'
    /root
    └─┬ node-bluetooth@1.2.5
      ├── bindings@1.2.1
      └── nan@2.12.1
    npm WARN enoent ENOENT: no such file or directory, open '/root/package.json'
    npm WARN root No description
    npm WARN root No repository field.
    npm WARN root No README data
    npm WARN root No license field.
    root@orangepiplus:~# device.listPairedDevices(console.log);
    -bash: Syntaxfehler beim unerwarteten Wort `console.log'
    root@orangepiplus:~# ^C
    Danke für einen Tipp hierzu.
    Christian
      Master77
      schrieb am zuletzt editiert von Master77
      Mir ist eben noch eine Sache aufgefallen.
      Alle eingetragenen Geräte werden unter Objekte, im Radar2 Ordner unter Valeu State notHere angezeigt obwohl mindestens eins online ist. Es scheint so als findet er keines der eingetragenen Geräte.
      Im alten Radar Adapter wurde in den Objekten für jedes Gerät ein extra Ordner erstellt. Beim Radar2 Adapter ist dem nicht so. Ist das normal? Hier ein Bild der Ordnerstruktur. Normal müsste da ja für jedes Gerät ein Ordner sein.
      Im Log stehen bis auf die bereits von mir genannten Bluetooth Warnung nichts drin.
      Gruß Markus
        aw1980
        Bei mir springt der Datenpunkt für die "Anwesenheit" nicht auf false. Obwohl ich schon eine Stunde nicht zuhause bin.
        Komischerweise stimmt aber der lasthere Datenpunkt, das ist die Uhrzeit wo ich das Haus verlassen habe.
        frankjokeF 1 Antwort Letzte Antwort
        • SegwayS Segway
          @crunchip sagte in [Adapter] Neuer radar2-Adapter:
          @Segway hatte ich auch nicht, erst als ich die Geräte genau so benannt habe, wie sie in der Fritzbox stehen und natürlich online sind.
          Habe ich jetzt genauso mit dem Namen und IPAdresse so eingetragen aber die Lasche unter Objekte kommt nicht
          SegwayS Offline
          SegwayS Offline
          Segway
          @Segway sagte in [Adapter] Neuer radar2-Adapter:
          Möchte noch einmal nachfragen, warum ich nichts unter Objekte bekomme ... würde ja gerne was testen aber so gehts nicht.
          Gruß Dirk
            aw1980
            Nochwas ist mir aufgefallen, nach einem Neustart des Adapters werden keine Datenpunkte für die eingetragenen Devices erzeugt bzw. die alten gelöscht wenn das Gerät nicht anwesend ist.
            Dadurch läuft mein Log durch Fehler vom javascript Adapter voll, weil der in einem Script abgefragte Datenpunkt nicht gefunden wird.
            • JohGreJ Offline
              JohGreJ Offline
              JohGre
              schrieb am zuletzt editiert von JohGre
              auch bei mir funktioniert er nicht wirklich. Hab den Adapter mal so gestartet
              node /opt/iobroker/node_modules/iobroker.radar2/radar2.js --force --logs --nolazy
              und folgende Fehlermeldungen erhalten.
              radar set to scan every 20 sec and printers every 720 scans.
              { Error: bind EADDRINUSE 0.0.0.0:67
                  at _handle.lookup (dgram.js:266:18)
                  at _combinedTickCallback (internal/process/next_tick.js:142:11)
                  at process._tickCallback (internal/process/next_tick.js:181:9)
                errno: 'EADDRINUSE',
                code: 'EADDRINUSE',
                syscall: 'bind',
                address: '0.0.0.0',
                port: 67 }
              Adapter disconnected and stopped with dostop(false) and callback(true)
              Error updating manufacturer database:  { Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.radar2/node_modules/oui/oui.json'
                errno: -13,
                code: 'EACCES',
                syscall: 'open',
                path: '/opt/iobroker/node_modules/iobroker.radar2/node_modules/oui/oui.json' }
              radar initialization finished with error TypeError: Cannot read property 'push' of null    at A.isApp.then.then.then.then.then.then.then.catch.then (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:502:25)    at <anonymous>    at process._tickCallback (internal/process/next_tick.js:189:7), will stop adapter!
              nuc i5: RaspberryMatic, ioBroker, pi-hole, SQL-Server, OMV-NAS, Influx-DB & Grafana, OpenHab, tasmoadmin
              frankjokeF 2 Antworten Letzte Antwort
              • U Offline
                U Offline
                Unbekannt
                Ich habe ebenfalls den Adapter ausprobiert, es werden keine Bluetooth Objekte angelegt.
                Nach Eingabe von
                bekomme ich folgendes Ergebnis:
                starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.radar2, node: v8.14.0
                { Error: EACCES: permission denied, open '/opt/iobroker/log/iobroker.2019-02-13.log'
                  errno: -13,
                  code: 'EACCES',
                  syscall: 'open',
                  path: '/opt/iobroker/log/iobroker.2019-02-13.log' }
                Adapter will exit in latest 1 sec with code false!
                terminating
                • ? Offline
                  Der Adapter legt bei mir erst dann Objekte an, wenn diese einmal weg und dann wieder da sind, egal ob Bluetooth oder Wlan, egal ob mit IP oder Mac.
                  Das doofe ist, dass bei einem Adapter restart alle Objekte gelöscht werden, und man dann wieder warten muss, bis welche angelegt werden..
                    frankjokeF Offline
                    frankjokeF Offline
                    frankjoke
                    @ilovegym sagte in [Adapter] Neuer radar2-Adapter:
                    Hallo!
                    Das ist nicht genau wie radar2 funktioniert: Alle Objekte welche im Konfig angegeben sind bleiven immer da, damit bleibt auch die Info wann derjenige gesehen wurde auch vorhanden.
                    Nur unknown's werden beim Adapterstart gelöscht!
                    Ich hab ein paar printscreens von meiner Test-Raspi3B+ gemacht:
                    In diesem Fall scannt radar2 alle 20 Sekunden und meldet Abwesenheit wenn was länger als 2 Minuten nicht gefunden wurde.
                    Das Rufzeichen hinter der Fritzbox schaltet den Debug ein und fast alles wird dann geloggt.
                    Ohne Debug schaut das log beim Start so aus:
                    Und die Objekte welche generiert werden so:
                    Frank,
                    NUC's, VM's und Raspi's unter Raspian, Ubuntu und Debian zum Testen.
                    Adapter die ich selbst beigesteuert habe: BMW, broadlink2, radar2, systeminfo, km200, xs1 und einige im Anmarsch!
                    • frankjokeF frankjoke
                      Hallo!
                      aw1980
                      @frankjoke sagte in [Adapter] Neuer radar2-Adapter:
                      Hallo!
                      ok, dass könnte auch mein Problem erklären warum die Objekte gelöscht wurden, hab die IP's und MAC's nicht bei known eingetragen und die waren weg bei Adapter neustart.
                      Kann man das vielleicht automatisieren? Wenn ich die als Geräte unter Suchobjekte eintrage, ist es ja irgendwie logisch dass diese nicht unknown sind
                      • JohGreJ JohGre
                          code: 'EADDRINUSE',
                          syscall: 'bind',
                          address: '0.0.0.0',
                          port: 67 }
                          errno: -13,
                          code: 'EACCES',
                          syscall: 'open',
                        frankjokeF Offline
                        frankjokeF Offline
                        frankjoke
                        @JohGre sagte in [Adapter] Neuer radar2-Adapter:
                          code: 'EADDRINUSE',
                          syscall: 'bind',
                          address: '0.0.0.0',
                          port: 67 }
                          errno: -13,
                          code: 'EACCES',
                          syscall: 'open',
                        Das sind Fehlermeldungen da der Adapter nicht auf einige Daten zugreifen kann/darf.
                        1. Frage: Hast
                        sudo apt-get install libcap2-bin arp-scan bluetooth bluez libbluetooth-dev libudev-dev
                        sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp-scan`)
                        sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which node`)
                        gemacht? Dadurch wird der Zugriff von von node und arp-scan erlaubt. Beineueren iobroker-Installationen läuft ioBroker als iobroker user und nicht mehr als root, und deshalb kann nicht auf alles zugregriffen werden.
                        Übrigens, in solchem Fall kann man auch nicht vom Benutzer pi einfach iobroker managen, anstatt früher sudo muss dann sudo -u iobroker ....vorangestellt werden um Zugriff auf Daten im iobroker-Verzeichnis zu erhalten!
                        Nun zu 0.0.0.0:67: Das ist der port für DNS, hast auf deinem Raspi einen DNS-Server laufen? Wenn ein anderes Programm das blockiert ist's dumm. Werde eine Änderung machen dass der Adapter nicht abstürzt wenn das der Fall ist, DNS-Erkennung gibt's dann halt nicht!
                        Der andere Fehler mit EACCES schaut eher aus dass die setcap's nicht gemacht worden sind!
                        Frank,
                        JohGreJ U 3 Antworten Letzte Antwort
                            code: 'EADDRINUSE',
                            syscall: 'bind',
                            address: '0.0.0.0',
                            port: 67 }
                            errno: -13,
                            code: 'EACCES',
                            syscall: 'open',
                          1. Frage: Hast
                          JohGreJ Offline
                          JohGreJ Offline
                          JohGre
                          @frankjoke Danke mal für die Antworten
                          zu 1: Ja, genauso wie beschrieben
                          Hab eine neuere ioBroker Installation und habe natürlich unter User "pi" den Adapter mit
                          sudo
                          installiert. Soweit mal verstanden. DNS Server hab ich keinen am laufen.
                          Deinstalliere mal alles und dann probier ich's noch mal, is ja eh ein Testsystem ;-)
                          • JohGreJ JohGre
                            sudo
                            frankjokeF Offline
                            frankjokeF Offline
                            frankjoke
                            sudo
                            Wenn du eine neue ioBroker-Installation hast wo iobroker als iobroker user läuft (das kannst mit top erkunden) dann NICHT sudo sondern sudo -u iobroker !
                            Frank,
                            • A aw1980
                              frankjokeF Offline
                              frankjokeF Offline
                              frankjoke
                              @aw1980 sagte in [Adapter] Neuer radar2-Adapter:
                              Was hast denn in der Konfig unter Delay Away stehen? Das wird in Minuten gezählt, ich hab da 2 drinnen im Beispiel unten, werde die Beschreibug updaten....
                              Frank,
                              A OstfrieseUnterwegsO 3 Antworten Letzte Antwort
                                aw1980
                                auch die 2, habe den Wert nicht verändert. Kann das auch damit zusammenhängen, dass die IP/BT Mac nicht als "known devices" gelistet war?
                                  OstfrieseUnterwegsO Offline
                                  OstfrieseUnterwegs
                                  Kannst Du in der Config-Screen noch dazuschreiben was in sek und was in min angegeben wird?
                                  • JohGreJ JohGre
                                      code: 'EADDRINUSE',
                                      syscall: 'bind',
                                      address: '0.0.0.0',
                                      port: 67 }
                                      errno: -13,
                                      code: 'EACCES',
                                      syscall: 'open',
                                    frankjokeF Offline
                                    frankjokeF Offline
                                    frankjoke
                                      code: 'EADDRINUSE',
                                      syscall: 'bind',
                                      address: '0.0.0.0',
                                      port: 67 }
                                    Hab herausgefunden wann 0.0.0.0:67 auch noch benutzt wird: Wenn du den Adapter händisch gestartet hast dann bleibt er aktiv (warum auch immer node das kann/macht) und kann nur durch sudo pkill -f radar2 die Instanz killen und dann ist der Port nicht wieder belegt,,,
                                    Frank,
                                    JohGreJ 1 Antwort Letzte Antwort
                                    • OstfrieseUnterwegsO OstfrieseUnterwegs
                                      frankjokeF Offline
                                      frankjokeF Offline
                                      frankjoke
                                      @OstfrieseUnterwegs sagte in [Adapter] Neuer radar2-Adapter:
                                      Hab grad 0.1.2 Beta4 auf git geschickt, da sind die Texte überarbeitet und es steht dabei.
                                      https://github.com/frankjoke/ioBroker.radar2
                                      Frank,
                                      • A aw1980
                                        frankjokeF Offline
                                        frankjokeF Offline
                                        frankjoke
                                        Daran sollte es nicht liegen, es macht zwar nichts wenn sie darin gelistet sind aber wenn sie in Der Geräteliste sind kommen sie nie in die unknowns!
                                        Die unknows sind nur dass permanent für Geräte die nicht überwacht werden sollen Objekte angelegt werden und!
                                        Frank,
                                            code: 'EADDRINUSE',
                                            syscall: 'bind',
                                            address: '0.0.0.0',
                                            port: 67 }
                                          JohGreJ Offline
                                          JohGreJ Offline
                                          JohGre
                                          @frankjoke
                                          Werd ich dann gleich mal probieren
