  4. Adapter: iobroker.backitup (stable Release)
adapterbackitupiobroker backupbackupiobroker.backitup
2.3k Beiträge 185 Kommentatoren 1.6m Aufrufe 50 Beobachtet
  • C Offline
    chemieka
    #1714
    Das Backup hat wohl jetzt funktioniert. Gott sein Dank.
    Hat jemand noch einen Tip, wo die Blocky Skripts liegen?
    Aber eine Frage noch. Ich habe jetzt wieder Backitup geupdatet und ist auch drauf aber es kamen viele Fehler. Muss ich noch irgendwas machen und wenn ja wie?
    $ ./iobroker url "https://github.com/simatec/ioBroker.backitup/tarball/master" backitup
    install https://github.com/simatec/ioBroker.backitup/tarball/master
    npm install https://github.com/simatec/ioBroker.backitup/tarball/master --production --save --prefix "/opt/iobroker" (System call)
    node-pre-gyp
     info it worked if it ends with ok
    node-pre-gyp verb cli [ '/usr/bin/node',node-pre-gyp verb cli   '/opt/iobroker/node_modules/smartmeter-obis/node_modules/serialport/node_modules/.bin/node-pre-gyp',
    node-pre-gyp verb cli   'install',
    node-pre-gyp verb cli   '--fallback-to-build' ]
    node-pre-gyp info using node-pre-gyp@0.6.32
    node-pre-gyp info using node@8.11.1 | linux | arm
    node-pre-gyp verb command install []
    node-pre-gyp info check checked for "/opt/iobroker/node_modules/smartmeter-obis/node_modules/serialport/build/Release/serialport.node" (not found)
    node-pre-gyp http GET https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v57-linux-arm.tar.gz
    node-pre-gyp http 404 https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v57-linux-arm.tar.gz
    node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v57-linux-arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@8.11.1 (node-v57 ABI) (falling back to source compile with node-gyp)
    node-pre-gyp http 404 status code downloading tarball https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v57-linux-arm.tar.gz
    node-pre-gyp verb command build [ 'rebuild' ]
    gyp
    WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/8.11.1"gyp
     WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/smartmeter-obis/node_modules/serialport/.node-gyp"
    make: *** Keine Regel vorhanden, um das Ziel „../.node-gyp/8.11.1/include/node/common.gypi“,   benötigt von „Makefile“, zu erstellen.  Schluss.
    gyp
     ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/node_modules/node-gyp/lib/build.js:258:23)
    gyp ERR! stack     at emitTwo (events.js:126:13)
    gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
    gyp ERR! System Linux 4.14.30-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/npm-lifecycle/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/smartmeter-obis/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/opt/iobroker/node_modules/smartmeter-obis/node_modules/serialport/build/Release"
    gyp ERR! cwd /opt/iobroker/node_modules/smartmeter-obis/node_modules/serialport
    gyp ERR! node -v v8.11.1
    gyp ERR! node-gyp -v v3.6.2
    gyp ERR! not ok
    node-pre-gyp
     ERR! build error node-pre-gyp
     ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/smartmeter-obis/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/smartmeter-obis/node_modules/serialport/build/Release' (1)node-pre-gyp ERR! stack     at ChildProcess. <anonymous>(/opt/iobroker/node_modules/smartmeter-obis/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR! stack     at emitTwo (events.js:126:13)
         at ChildProcess.emit (events.js:214:7)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:925:16)
    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
    node-pre-gyp ERR! System Linux 4.14.30-v7+node-pre-gyp ERR!
     command "/usr/bin/node" "/opt/iobroker/node_modules/smartmeter-obis/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/smartmeter-obis/node_modules/serialport
    node-pre-gyp ERR! node -v v8.11.1
    node-pre-gyp ERR!
     node-pre-gyp -v v0.6.32node-pre-gyp ERR! not ok
    npm
     WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@4.0.7 (node_modules/smartmeter-obis/node_modules/serialport):npm
     WARN
     optional
     SKIPPING OPTIONAL DEPENDENCY: serialport@4.0.7 install: `node-pre-gyp install --fallback-to-build`npm
     WARN
     optional
     SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    got /opt/iobroker/node_modules/iobroker.backitup/admin
    upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
    upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
    upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
    upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
    process exited with code 0</anonymous>
    • simatecS Online
      simatecS Online
      simatec
      #1715
      Das hat nix mit backitup zu tun.
      Dein total backup hat sicher ein komplett anderen Stand zwecks node Version.
      Warum machst du kein Minimal restore.
      So wird dein System sauber neu aufgesetzt.
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      • C Offline
        chemieka
        #1716
        Die Frage kann ich jetzt so nicht ganz beantworten.
        Sicher bin ich davon ausgegangen, dass ich so alle VIS Skripte und Einstellungen wieder bekomme.
        Was ist den bei Minimal nicht mit drin?
        Denke allerdings die Fehler kommen bestimmt weil npm geupdatet werden müsste oder?
        Im übrigen hatte ich Gestern viel Glück. Nachdem dann das System wieder lief rauchte dann auch meine Ersatzkarte ab. Allerdings ist diese Karte nun ein Totalausfall, sie wurde sehr heiß und nun Schrott. Das bedeutet ich kann heute noch einmal anfangen.
        • C Offline
          chemieka
          #1717
          Da wäre mir jetzt trotzdem nicht so klar wo der Unterschied wäre im Detail. Was könnte bei Minimal Backup dann fehlen?
          ` > Standard Backup
          Dieses Backup entspricht dem in IoBroker enthaltenen Backup welches man in der Konsole über den Aufruf „./iobroker backup“ starten kann. Nur wird es hier durch die festgelegten Einstellungen in der Adapterkonfiguration oder dem Widget OneClick-Backup durchgeführt ohne die Konsole verwenden zu müssen.
          Komplettes Backup
          Dieses Backup sichert den kompletten IoBroker Ordner inklusive aller Unterordner und deren Dateien samt Dateiberechtigungen. Hierbei sollte die Dateigröße nicht ausser Acht gelassen werden, denn ein solches Backup hat oft mehrere hundert MB. Um sicher zu gehen dass alle aktuellsten States gesichert werden muss hier in der Konfiguration der Hacken bei IoBroker Stop/Start gesetzt werden `
          • C Offline
            chemieka
            #1718
            Heute habe ich auf eine neue Karte mal das letzte Image Experimental von Anfang des Jahres auf die PI3 gemacht. BackItup drauf. Leider geht dann das wiederherstellen nicht. Laut Befehl Htop läuft kein Skript los. Noch eine Idee was ich dann noch versuchen könnte.
            • simatecS Online
              simatecS Online
              simatec
              #1719
              @chemieka:
              Heute habe ich auf eine neue Karte mal das letzte Image Experimental von Anfang des Jahres auf die PI3 gemacht. BackItup drauf. Leider geht dann das wiederherstellen nicht. Laut Befehl Htop läuft kein Skript los. Noch eine Idee was ich dann noch versuchen könnte. `
              Die neuen Images haben leider aktuell noch den Bug mit dem neuen Installer drin.
              Da hilft nur iobroker komplett löschen, am besten auch node, nodejs und npm deinstallieren und alles laut Anleitung neu aufsetzen.
              • C Offline
                chemieka
                #1720
                Gut dann nehme ich das Letzte aus 2018. Ich berichte.
                • C Offline
                  chemieka
                  #1721
                  So ich bin fertig. Das war zwar auch recht holbrig, weil er zunächst das Backup auf meiner FTP Quelle nicht finden wollte. Aber nach einigen Updates und Restart des Hosts wollte er dann doch. Das Backup lief dann durch aber ich konnte den Abschluss nur mit Befehl Htop erahnen.
                  Ich bin aber sehr erleichtert, das alles wieder da ist. Jetzt kann es ins Bett gehen.
                  Danke. Für die Unterstützung. ;)
                  • PeoplesP Offline
                    PeoplesP Offline
                    Peoples
                    #1722
                    @chemieka:
                    Ich bin aber sehr erleichtert, das alles wieder da ist. Jetzt kann es ins Bett gehen. `
                    Wenigstens bin ich nicht der einzige der sowas immer mitten in der Nacht macht :D
                    • MathiasJM Offline
                      MathiasJM Offline
                      MathiasJ
                      #1723
                      Ein kleines Problemchen habe ich doch noch:
                      ich habe total-Backup alle 30 tage eingestellt.
                      Nun wird aber jeden letzten und ersten ein Backup gezogen.
                      Soweit funktioniert alles.
                      Gruß,
                      Mathias
                      IObroker auf dem NUC als VM.
                      • simatecS Online
                        simatecS Online
                        simatec
                        #1724
                        @MathiasJ:
                        Gruß,
                        Mathias `
                        So funktioniert ein crojob nunmal …
                        • MathiasJM Offline
                          MathiasJM Offline
                          MathiasJ
                          #1725
                          Ist ja richtig, aber vom letzten bis zum ersten ist es nur ein Tag und keine 30…..
                          Gesendet von meinem MI 8 mit Tapatalk
                          • simatecS Online
                            simatecS Online
                            simatec
                            #1726
                            Cronjob arbeitet bei der Funktion alle x Tage mit Monaten.
                            Das lässt sich nicht ändern.
                            • MathiasJM Offline
                              MathiasJM Offline
                              MathiasJ
                              #1727
                              Ah OK, habe verstanden.
                              Ist ja nicht wirklich schlimm.
                              Hat mich nur gewundert.
                              Gruß,
                              Mathias
                              • simatecS Online
                                simatecS Online
                                simatec
                                #1728
                                Ab sofort ist die Version 1.0.9 mit sehr vielen Änderungen im Github und ab heute Nacht im latest verfügbar.
                                1.0.9 (02.02.2019)
                                __(simatec) Add New umount query
                                (simatec) Add Umount wait by device busy
                                (simatec) Add Timeout for History settings
                                (simatec) Add Notification only on error__
                                • F Offline
                                  freisei
                                  #1729
                                  @simatec:
                                  Im Log steht aber auch host down.
                                  Dein problem liegt eher an deinem NAS `
                                  Der Menüpunkt wird schon gesetzt, aber im mount-Befehl wird das nicht berücksichtigt (ist auch so im log oben zu sehen)
                                  Der Fehler "host ist down" kommt ja gerade deswegen, weil der vers-Parameter nicht übergeben wird. Wenn ich den vers-Parameter auf der console manuell zum mount-befehl hinzufüge kann auch gemoutet werden.
                                  • simatecS Online
                                    simatecS Online
                                    simatec
                                    #1730
                                    Doch wird er … das was du im log siehst ist der zweite Versuch ohne vers=
                                    Schau dir den code an, dann siehst du was ich meine.
                                    Dein Problem liegt woanders.
                                      K_o_bold
                                      #1731
                                      ich habe ein Problem das SQL-Backup wiederherzustellen. Wenn ich über den Adapter Menüpunkt Wiederherstellung mein SQL- Backup auswählen kommt ein Fenster mit dem Hinweis -> ERR "not Configured".
                                      Kann mir jemand sagen was das heißt und wie ich die SQL Datenbank aus dem Backup wiederherstellen kann?
                                      • simatecS Online
                                        simatecS Online
                                        simatec
                                        #1732
                                        @K_o_bold:
                                        Kann mir jemand sagen was das heißt und wie ich die SQL Datenbank aus dem Backup wiederherstellen kann? `
                                        Stelle backitup in der den Adapterinstanzen bitte auf debug und poste die Logausgaben
                                        • N Offline
                                          N Offline
                                          new12345
                                          #1733
                                          Sorry für die späte Antwort und Danke für eure Vorschläge
                                          Da ich neu im Thema bin, root = sudo? ioBroker startet dann von root aus
                                          Habe mount as sudo auch aktiv
                                          Slash mit oder ohne habe ich auch getestet
                                          SMB 2 auch getestet
                                          Hilft leider alles nichts
                                          Wie lautet der mount befehl damit ich den über putty starten kann?
