  3. Entwicklung
  4. ZigBee CC253x Adapter - nur neue/unbekannte Geräte Version 0.9.x
894 Beiträge 82 Kommentatoren 331.6k Aufrufe 23 Beobachtet
  • R Offline
    rewe9
    #283
    Hallo ArtecL,
    nachdem ich nun den Adapter neu installiert habe , bekomme ich folgendes Log:
    host.zbox-debian 2019-01-30 10:57:24.560 info Restart adapter system.adapter.zigbee.0 because enabled
    host.zbox-debian 2019-01-30 10:57:24.560 error instance system.adapter.zigbee.0 terminated with code 1 ()
    host.zbox-debian 2019-01-30 10:57:24.560 error Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
    host.zbox-debian 2019-01-30 10:57:24.560 error Caught by controller[0]: at Module._compile (module.js:653:30)
    host.zbox-debian 2019-01-30 10:57:24.560 error Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/serialport/lib/bindings/linux.js:2:36)
    host.zbox-debian 2019-01-30 10:57:24.559 error Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:81:44)
    host.zbox-debian 2019-01-30 10:57:24.559 error Caught by controller[0]: at require (internal/module.js:11:18)
    host.zbox-debian 2019-01-30 10:57:24.559 error Caught by controller[0]: at Module.require (module.js:597:17)
    host.zbox-debian 2019-01-30 10:57:24.559 error Caught by controller[0]: at Function.Module._load (module.js:498:3)
    host.zbox-debian 2019-01-30 10:57:24.559 error Caught by controller[0]: at tryModuleLoad (module.js:506:12)
    host.zbox-debian 2019-01-30 10:57:24.559 error Caught by controller[0]: at Module.load (module.js:566:32)
    host.zbox-debian 2019-01-30 10:57:24.559 error Caught by controller[0]: at Object.Module._extensions..node (module.js:682:18)
    host.zbox-debian 2019-01-30 10:57:24.559 error Caught by controller[0]: Error: /opt/iobroker/node_modules/serialport/build/Release/serialport.node: wrong ELF class: ELFCLASS32
    host.zbox-debian 2019-01-30 10:57:24.559 error Caught by controller[0]: ^
    host.zbox-debian 2019-01-30 10:57:24.559 error Caught by controller[0]: throw e
    host.zbox-debian 2019-01-30 10:57:24.559 error Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:88
    host.zbox-debian 2019-01-30 10:57:24.371 info instance system.adapter.zigbee.0 started with pid 6688
    und er bleibt dauerhaft rot. Bin gerade etwas am verzweifeln. habe meinerseits alleemögliche getestet, ohne Erfolg.
    Gruß René</anonymous>
    • arteckA Offline
      arteckA Offline
      arteck
      #284
      @Smarti2019:
      hi,
      ich habe auch das Ikea Tradfri Remote Control E1524.
      Auf der Github Seite von koenkk steht beschrieben wie man die Group daten des Remote Controlls sniffen kann.
      Hab das auch erfolgreich hinbekommen.
      Dann steht da geschrieben
      https://github.com/Koenkk/zigbee2mqtt/b … devices.md
      wie man diese daten in eine datei configuraton.yaml hinterlegt:
      devices:
      '0x000b57fffecb472d':
      friendly_name: '0x000b57fffecb472d'
      retain: false
      coordinator_group: 0xeb12
      wo finde ich das bei iobroker? `
      garnicht..wir nutzen nur den converter…
      • arteckA Offline
        arteckA Offline
        arteck
        #285
        @rewe9:
        Hallo ArtecL,
        Gruß René</anonymous> `
        das richt nach Rechte sind falsch…
        at Object. <anonymous>(/opt/iobroker/node_modules/serialport/lib/bindings/linux.js:2:36)</anonymous>
        • I Offline
          I Offline
          ich-auch
          #286
          und hier die RGB E27 Variante
          • arteckA Offline
            arteckA Offline
            arteck
            #287
            @ich-auch:
            Aldi Bulb E27 rgb200x200.png `
            danke dir aber so genau müssen wir nicht sein… bei 128x128 sieht man den unterschied nicht
            • R Offline
              rewe9
              #288
              Hallo Arteck,
              kannst du mir einen Tip geben, wie man das mit der Rechtevergabe macht.
              Vielen Dank.
              Gruß René
              • G Offline
                gosund
                #289
                Du wechselst mit cd [verzeichnisname] in das entsprechende Verzeichnis, dann kannst Du Dir den Inhalt mittels
                ls -la
                anzeigen lassen.
                Die Berechtigungen änderst Du mit chmod, also z.B.
                chmod -R ugo+rwX *
                womit Du alles im aktuellen Ordner einschließlich Unterordner für jeden freigibst.
                das -R steht für rekursiv, ugo steht für user, group, other und +rwX steht für lesen/schreiben/ausführen bzw. öffnen (bei Ordnern)
                Normalerweise sollte eigentlich der richtige User gesetzt werden, mittels
                chown -R [user].[group] [Verzeichnis oder Datei]
                Wenn Du nicht weiter kommst, dann schreib hier mal was Du siehst, wenn Du ls -la eingibst.
                • a200A Offline
                  a200A Offline
                  a200
                  #290
                  Also verstehe ich das richtig, dass die Aldi Lampen mit dem 0.9.1 Adapter laufen?
                  Ich bin zu blöd die zu pairen. :oops:
                  IoBroker auf QNAP TS-451, Raspi und NUC
                  • R Offline
                    rewe9
                    #291
                    @gosund:
                    ls -la
                    anzeigen lassen.
                    chmod -R ugo+rwX *
                    Wenn Du nicht weiter kommst, dann schreib hier mal was Du siehst, wenn Du ls -la eingibst. `
                    das gibt die Konsole aus:
                    insgesamt 900
                    drwxr-xr-x 21 iobroker iobroker 4096 Jan 19 22:49 .
                    drwxr-xr-x 3 root root 4096 Jan 3 23:32 ..
                    -rw–----- 1 iobroker iobroker 5147 Jan 30 14:57 .bash_history
                    -rw-r--r-- 1 iobroker iobroker 220 Jan 3 23:32 .bash_logout
                    -rw-r--r-- 1 iobroker iobroker 3526 Jan 3 23:32 .bashrc
                    drwxr-xr-x 2 iobroker iobroker 4096 Jan 3 23:33 Bilder
                    drwx------ 11 iobroker iobroker 4096 Jan 4 14:34 .cache
                    drwx------ 11 iobroker iobroker 4096 Jan 19 22:48 .config
                    drwxr-xr-x 2 iobroker iobroker 4096 Jan 3 23:33 Dokumente
                    drwxr-xr-x 2 iobroker iobroker 4096 Jan 3 23:33 Downloads
                    drwx------ 3 iobroker iobroker 4096 Jan 3 23:33 .gnupg
                    -rw------- 1 iobroker iobroker 4012 Jan 5 18:54 .ICEauthority
                    drwxr-xr-x 6 iobroker iobroker 4096 Jan 19 11:10 libmicrohttpd
                    -rw-r--r-- 1 iobroker iobroker 800143 Jan 19 11:09 libmicrohttpd-0.9.19.tar.gz
                    drwxr-xr-x 3 iobroker iobroker 4096 Jan 3 23:33 .local
                    drwx------ 5 iobroker iobroker 4096 Jan 4 14:34 .mozilla
                    drwxr-xr-x 2 iobroker iobroker 4096 Jan 3 23:33 Musik
                    drwxr-xr-x 2 iobroker iobroker 4096 Jan 12 20:24 .nano
                    drwxr-xr-x 3 iobroker iobroker 4096 Jan 19 22:49 .node-gyp
                    drwxr-xr-x 5 iobroker iobroker 4096 Jan 25 13:01 node_modules
                    drwxr-xr-x 6 iobroker iobroker 4096 Jan 25 13:49 .npm
                    drwxr-xr-x 2 iobroker iobroker 4096 Jan 3 23:33 Öffentlich
                    -rw-r--r-- 1 iobroker iobroker 921 Jan 19 22:49 package-lock.json
                    drwx------ 3 iobroker iobroker 4096 Jan 5 18:08 .pki
                    -rw-r--r-- 1 iobroker iobroker 675 Jan 3 23:32 .profile
                    drwxr-xr-x 2 iobroker iobroker 4096 Jan 3 23:33 Schreibtisch
                    -rw-r--r-- 1 iobroker iobroker 66 Jan 12 20:24 .selected_editor
                    drwxr-xr-x 2 iobroker iobroker 4096 Jan 3 23:33 Videos
                    drwxr-xr-x 2 iobroker iobroker 4096 Jan 3 23:33 Vorlagen
                    Gruß René
                    • E Offline
                      enemy2003
                      #292
                      @arteck:
                      @Smarti2019:
                      hi,
                      devices:
                      retain: false
                      garnicht..wir nutzen nur den converter… `
                      sry dass ich so unwissend nachfragen muss :oops: aber ich finde es einfach nicht. Wo kann man das mit dem converter nachlesen? Braucht man dann zusätzlich zigbee2mqtt oder wie ist das? Wäre so toll dieses Gerät zum laufen zu bekommen :)
                      Vielen Dank!
                      // Update… mit Browser Cache leeren, Gerät nochmal löschen (auch aus der shepherd.db) und neu verbinden ist es nun zu sehen. Die Buttons wurden als Objekte angelegt. Leider ohne Funktion. Was fehlt noch?
                      • R Offline
                        rewe9
                        #293
                        @rewe9:
                        @gosund:
                        ls -la
                        anzeigen lassen.
                        chmod -R ugo+rwX *
                        insgesamt 900
                        Gruß René `
                        sorry,die konsole im iobroker gibt folgendes aus:
                        insgesamt 268
                        4 drwxrwxrwx 2 iobroker root 4096 Jan 25 18:06 backups
                        4 drwxrwxrwx 2 iobroker root 4096 Jan 21 08:12 cache
                        4 drwxrwxrwx 2 iobroker root 4096 Mär 30 2018 etc
                        4 drwxr-xr-x 5 iobroker root 4096 Jan 5 18:16 install
                        4 -rwxrwxrwx 1 iobroker root 297 Apr 1 2018 install.sh
                        4 -rwxr-xr-x 1 iobroker root 67 Jan 4 14:52 iob
                        4 -rwxr-xr-x 1 iobroker root 67 Apr 1 2018 iobroker
                        4 drwxrwxrwx 8 iobroker root 4096 Jan 27 18:05 iobroker-data
                        4 -rwxrwxrwx 1 iobroker root 92 Nov 9 14:35 killall.sh
                        4 drwxr-xr-x 2 iobroker root 4096 Jan 5 18:16 lib
                        4 -rw-r–r-- 1 iobroker root 1137 Jan 5 18:16 LICENSE
                        4 drwxrwxrwx 2 iobroker root 4096 Jan 30 01:29 log
                        24 drwxrwxrwx 661 iobroker root 20480 Jan 30 10:54 node_modules
                        16 -rw-r--r-- 1 iobroker root 16177 Jan 4 00:27 npm-debug.log
                        4 -rwxrwxrwx 1 iobroker iobroker 841 Jan 30 10:54 package.json
                        164 -rw-r--r-- 1 iobroker root 164479 Jan 4 14:52 package-lock.json
                        8 -rw-r--r-- 1 iobroker root 6101 Jan 5 18:16 README.md
                        4 -rwxrwxrwx 1 iobroker root 709 Nov 9 14:35 reinstall.sh
                          Mordrad
                          #294
                          @enemy2003:
                          @arteck:
                          @Smarti2019:
                          hi,
                          devices:
                          retain: false
                          Vielen Dank!
                          // Update… mit Browser Cache leeren, Gerät nochmal löschen (auch aus der shepherd.db) und neu verbinden ist es nun zu sehen. Die Buttons wurden als Objekte angelegt. Leider ohne Funktion. Was fehlt noch? `
                          An die Frage würde ich mich auch gerne anschließen. Anmelden der Remote war erfolgreich, allerdings ändern sich die States nicht. Beim Ersten ButtonPress hatte ich folgende Zeile im Log: "Zigbee publish to '0x000b57fffe3089cc', genBasic - 0 - [{"attrId":16384},{"attrId":3}] - 1 failed with error Error: AF data request fails, status code: 183. APS no ack."
                            Smarti2019
                            #295
                            @Smarti2019:
                            hi,
                            devices:
                            retain: false
                            hier aktuell gelöst:
                            https://github.com/ioBroker/ioBroker.zigbee/issues/178
                            funktioniert danach 1A, kann jetzt meine Tradfri Leuchten oder andere Dinge per Remote FB zumindest an und ausschalten.
                            Es werden aber alle Tasten unter den Objekten aufgeführt und es kommt auch treffend eine Reaktion
                            gruss
                            • E Offline
                              enemy2003
                              #296
                              @Smarti2019:
                              @Smarti2019:
                              hi,
                              devices:
                              retain: false
                              gruss `
                              Wo sind die Gruppen? Den Tab gibt es bei mir nicht <emoji seq="1f648">🙈</emoji>
                                Smarti2019
                                #297
                                du hast den aktuellen adapter zigbee installiert?
                                0.9.1 ist aktuell !
                                gruss
                                  Siegfried
                                  Forum Testing
                                  #298
                                  Nach update auf 0.9.0 geht der Xiaomi lumi.sensor_86sw2 nicht mehr
                                  Rest ok
                                  sg
                                  Edit: nach update auf 0.9.1 wieder alles super; danke für den super Adapter
                                  • E Offline
                                    enemy2003
                                    #299
                                    @Smarti2019:
                                    0.9.1 ist aktuell !
                                    gruss `
                                    Ja war schon installiert. Aber Adapter und Instanz sauber löschen und neu installieren dann klappt’s auch <emoji seq="1f44d-1f3fb">👍🏻</emoji> Danke
                                    Kann man die Group ohne 2. Stick auslesen?
                                    • G Offline
                                      gosund
                                      #300
                                      @enemy2003:
                                      Wie hast Du das gemacht?
                                      • E Offline
                                        enemy2003
                                        #301
                                        @gosund:
                                        @enemy2003:
                                        Wie hast Du das gemacht? `
                                        Na erst die Instanz löschen, dann den Adapter. Dann aus der git repo den Adapter neu installieren und daraus eine Instanz erzeugen <emoji seq="263a">☺️</emoji> Viel Erfolg
                                        • G Offline
                                          gosund
                                          #302
                                          Ok, Danke. Also nur über die Web-Oberfläche reicht.
                                          Aber wo finde ich die aktuelle 0.9.1?
                                          Nachdem ich eben alles entfernt habe und dann https://github.com/arteck/ioBroker.zigbee
                                          installiert habe, bin ich laut Version immer noch bei 0.9.0 - allerdings jetzt auf deutsch :)
