  4. Adapter: iobroker.backitup (stable Release)
adapterbackitupiobroker backupbackupiobroker.backitup
2.3k Beiträge 185 Kommentatoren 1.6m Aufrufe 50 Beobachtet
  • OberjembkerO Offline
    Oberjembker
    #1620
    OK. Ich habe den Adapter vorher gestoppt/gestartet.
    Die Backupdatei liegt erfolgreich auf dem FTP-Ziel (1177 kB).
    Hier das Logfile:
    ! 2019-01-22 22:14:27.961 - info: backitup.0 terminating 2019-01-22 22:14:27.985 - info: host.raspi01 instance system.adapter.backitup.0 terminated with code 0 (OK) 2019-01-22 22:14:42.237 - info: host.raspi01 object change system.adapter.backitup.0 2019-01-22 22:14:42.255 - info: host.raspi01 instance system.adapter.backitup.0 started with pid 25997 2019-01-22 22:14:43.552 - debug: backitup.0 objectDB connected 2019-01-22 22:14:43.618 - debug: backitup.0 statesDB connected 2019-01-22 22:14:43.777 - info: backitup.0 starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.11.4 2019-01-22 22:14:43.822 - info: backitup.0 [minimal] backup was activated at 02:00 every 1 day(s) 2019-01-22 22:14:43.852 - debug: backitup.0 [minimal] 10 00 02 */1 * * 2019-01-22 22:14:43.852 - info: backitup.0 [ccu] backup was activated at 03:00 every 14 day(s) 2019-01-22 22:14:43.858 - debug: backitup.0 [ccu] 10 00 03 */14 * * 2019-01-22 22:14:43.858 - info: backitup.0 [total] backup was activated at 02:30 every 7 day(s) 2019-01-22 22:14:43.867 - debug: backitup.0 [total] 10 30 02 */7 * * 2019-01-22 22:15:38.256 - debug: backitup.0 sendTo "getTelegramUser" to system.adapter.admin.0 from system.adapter.backitup.0: {"567282727":"Arne"} 2019-01-22 22:15:56.652 - debug: backitup.0 [minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2019_01_22-22_15_50_backupiobroker.tar.gz 2019-01-22 22:15:56.695 - debug: backitup.0 [minimal/minimal] done 2019-01-22 22:15:58.681 - debug: backitup.0 [minimal/ftp] FTP connected. 2019-01-22 22:15:58.686 - debug: backitup.0 [minimal/ftp] Send minimal_2019_01_22-22_15_50_backupiobroker.tar.gz !
    … und die Ausgabe im Terminal:
    Gestartet... [DEBUG] [minimal] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"mysqlEnabled":false,"redisEnabled":false,"ftp":{"enabled":true,"type":"storage","source":"Local","host":"nas-server","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupper/SMARTHOME","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"backupper","pass":"****","port":"21"},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"Local","host":"nas-server","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupper/SMARTHOME","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"backupper","pass":"************","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"Local","mount":"","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","smb":"vers=1.0","sudo":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"","pass":""},"dropbox":{"enabled":false,"type":"storage","source":"Local","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"15","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"} [DEBUG] [minimal] - Backup created: /opt/iobroker/backups/minimal_2019_01_22-22_15_50_backupiobroker.tar.gz ! [DEBUG] [minimal] - done [DEBUG] [ftp] start with {"type":"storage","source":"Local","host":"nas-server","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupper/SMARTHOME","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"backupper","pass":"****","port":"21","deleteBackupAfter":0} [DEBUG] [ftp] - FTP connected. [DEBUG] [ftp] - Send minimal_2019_01_22-22_15_50_backupiobroker.tar.gz
    Danach kommen keine Backitup-Meldungen mehr.
    ! Da ich den Haken "Schließen wenn fertig" nicht gesetzt habe, wartet das Fenster "Backitup-Ausführung" noch immer auf eine Rück-/Fertigmeldung.
    ! Gruß, Arne.[/ftp][/ftp][/ftp]
    • 2 Offline
      2 Offline
      2hot4you
      #1621
      Hallo Zusammen
      mir ist aufgefallen, dass mein neuen Virenscanner, "Bitdefender 2019" eine Datei im Backup Ordner auf dem NAS anzeigt. :shock:
      In das Verzeichnis kann nur der IObroker schreiben
      Hatte jemand schon diese Meldung ? Die Datei "Photo.scr" ist in allen Verzeichnissen
      • simatecS Online
        simatecS Online
        simatec
        #1622
        Die Datei ist mir völlig fremd und wird weder durch iobroker noch durch backitup erzeugt.
        Der Code dazu liegt auf github offen und ist für alle einsehbar.
        Da musst du mal dein gesamtes System prüfen, was sich da eventuell breit macht.
        • Besuche meine Github Seite
        • HowTo Restore ioBroker
        • 2 Offline
          2 Offline
          2hot4you
          #1623
          Ok, werde mal alles löschen und beobachten.
          • PeoplesP Offline
            PeoplesP Offline
            Peoples
            #1624
            @2hot4you:
            Ok, werde mal alles löschen und beobachten. `
            Oder einfach Mal photo.scr google'n und du wirst zig Ergebnisse finden die sich u.a. auch mit dem Vorhandensein dieser Datei auf nassystemen beschäftigen.
            • U Offline
              U Offline
              Unbekannt
              #1625
              ich versuche mal hier in diesem Thread eine Lösung für mein Backupproblem zu finden.
              Kurz zusammengefasst, es wird kein Backup erstellt - Verbindung per ftp zu Nas funktioniert.
              Debug Meldung beim ausführen des minimal Backups
              [DEBUG] [minimal] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"mysqlEnabled":false,"redisEnabled":false,"ftp":{"enabled":true,"type":"storage","source":"FTP","host":"192.168.178.32","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/Freigabe/Programme/ioBroker/Backup","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"ioBroker","pass":"****","port":"21"},"mysql":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"FTP","host":"192.168.178.32","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/Freigabe/Programme/ioBroker/Backup","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"ioBroker","pass":"Smarth0me","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"FTP","mount":"192.168.178.32","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/Freigabe/Programme/ioBroker/Backup","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"ioBroker","pass":"Smarth0me"},"dropbox":{"enabled":false,"type":"storage","source":"FTP","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"dbName":"iobroker","user":"","pass":"****","deleteBackupAfter":5,"host":"localhost","port":"3306","exe":""},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"FTP","host":"192.168.178.32","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/Freigabe/Programme/ioBroker/Backup","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"ioBroker","pass":"Smarth0me","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"FTP","mount":"192.168.178.32","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/Freigabe/Programme/ioBroker/Backup","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"ioBroker","pass":"Smarth0me"},"dropbox":{"enabled":false,"type":"storage","source":"FTP","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"shortTelegramNotice","User":"allTelegramUsers","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"} [ERROR] [minimal] - host.raspberrypi Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error: EACCES: permission denied, open '/opt/iobroker/backups/minimal_2019_01_23-09_35_14_backupiobroker.tar.gz' ! [DEBUG] [minimal] - done [DEBUG] [ftp] start with {"type":"storage","source":"FTP","host":"192.168.178.32","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/Freigabe/Programme/ioBroker/Backup","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"ioBroker","pass":"****","port":"21","deleteBackupAfter":0} [DEBUG] [ftp] - FTP connected. [DEBUG] [ftp] - Send minimal_2019_01_23-09_35_14_backupiobroker.tar.gz [ERROR] [ftp] - File "/opt/iobroker/backups/minimal_2019_01_23-09_35_14_backupiobroker.tar.gz" not found [DEBUG] [ftp] - done [DEBUG] [clean] start with {"deleteBackupAfter":0} [DEBUG] [clean] - done [DEBUG] [telegram] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"mysqlEnabled":false,"redisEnabled":false,"ftp":{"enabled":true,"type":"storage","source":"FTP","host":"192.168.178.32","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/Freigabe/Programme/ioBroker/Backup","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"ioBroker","pass":"****","port":"21"},"mysql":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"FTP","host":"192.168.178.32","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/Freigabe/Programme/ioBroker/Backup","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"ioBroker","pass":"Smarth0me","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"FTP","mount":"192.168.178.32","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/Freigabe/Programme/ioBroker/Backup","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"ioBroker","pass":"Smarth0me"},"dropbox":{"enabled":false,"type":"storage","source":"FTP","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"dbName":"iobroker","user":"","pass":"****","deleteBackupAfter":5,"host":"localhost","port":"3306","exe":""},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"FTP","host":"192.168.178.32","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/Freigabe/Programme/ioBroker/Backup","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"ioBroker","pass":"Smarth0me","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"FTP","mount":"192.168.178.32","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/Freigabe/Programme/ioBroker/Backup","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"ioBroker","pass":"Smarth0me"},"dropbox":{"enabled":false,"type":"storage","source":"FTP","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"shortTelegramNotice","User":"allTelegramUsers","systemLang":"de","time":"23\. Januar 2019 um 09:35 Uhr"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"} [DEBUG] [telegram] - [minimal] used Telegram-Instance: telegram.0 [DEBUG] [telegram] - done [DEBUG] [history] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"mysqlEnabled":false,"redisEnabled":false,"ftp":{"enabled":true,"type":"storage","source":"FTP","host":"192.168.178.32","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/Freigabe/Programme/ioBroker/Backup","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"ioBroker","pass":"****","port":"21"},"mysql":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"FTP","host":"192.168.178.32","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/Freigabe/Programme/ioBroker/Backup","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"ioBroker","pass":"Smarth0me","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"FTP","mount":"192.168.178.32","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/Freigabe/Programme/ioBroker/Backup","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"ioBroker","pass":"Smarth0me"},"dropbox":{"enabled":false,"type":"storage","source":"FTP","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"dbName":"iobroker","user":"","pass":"****","deleteBackupAfter":5,"host":"localhost","port":"3306","exe":""},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"FTP","host":"192.168.178.32","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/Freigabe/Programme/ioBroker/Backup","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"ioBroker","pass":"Smarth0me","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"FTP","mount":"192.168.178.32","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/Freigabe/Programme/ioBroker/Backup","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"ioBroker","pass":"Smarth0me"},"dropbox":{"enabled":false,"type":"storage","source":"FTP","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"23\. Januar 2019 um 09:35 Uhr"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"shortTelegramNotice","User":"allTelegramUsers","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"} [DEBUG] [history] - backitup.0.history.html [EXIT] 9
              ! Es wird also das Backupfile nicht gefunden.
              ! Also habe ich das Backup über Putty mal manuell ausführen wollen. Hier hat sich herausgestellt, dass dies auch nicht klappt. Ich hatte https://forum.iobroker.net/viewtopic.php?f=22&t=20974 einen Thread dazu eröffnet, doch leider keine Antwort erhalten.
              ! Warum ich nun hier poste? Ich erhoffe mir hier mehr Hilfe, da das gesamte Thema ums Backup geht und der andere Thread evtl. einfach unter geht in der Masse der (für Andere interessantere) Themen.
              ! Der Einfachheit halber habe ich den Inhalt des o.g. Threads hier nochmal eingefügt, damit man nicht zwischen den Beiträgen hin und her springen muss:
              ! >! ~~[spoiler]~~wenn ich ein manuelles Backup machen möchte:
              ! ~~[code]~~pi@raspberrypi:/opt/iobroker/backups $ cd /opt/iobroker pi@raspberrypi:/opt/iobroker $ iobroker backup host.raspberrypi Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../backups/2019_01_16-08_00_31_backupiobroker.tar.gz' [/code]
              ! bekomme ich folgenden Fehler:
              ! ~~[code]~~host.raspberrypi Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../backups/2019_01_16-08_00_31_backupiobroker.tar.gz'[/code]
              ! Ich habe versucht mit
              ! ~~[code]~~chmod -R 777 /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup [/code]
              ! die Zugriffsrechte zu setzen, jedoch mit diesem Resultat:
              ! ~~[code]~~chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup': Die Operation ist nicht erlaubt chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files': Die Operation ist nicht erlaubt chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis.0': Die Operation ist nicht erlaubt chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json': Die Operation ist nicht erlaubt [/code]
              [/spoiler]
              ! Ich hoffe, dass ihr mir helfen könnt. Ich bin aufgrund meiner fehlenden Linuxskills leider echt aufgeschmissen und auf eure Hilfe angewiesen.
              ! Besten Dank schon mal,
              ! Gruß Markus[/ftp][/ftp][/ftp][/ftp][/ftp]
              • simatecS Online
                simatecS Online
                simatec
                #1626
                Das sieht mir so aus, als ob deinem backup Ordner Rechte fehlen.
                Mache mal über Konsole folgendes:
                sudo chmod 777 /opt/iobroker/backups
                sudo chmod 777 /opt/iobroker/backups/*
                • U Offline
                  U Offline
                  Unbekannt
                  #1627
                  Das war es. Oh man, so simple. Ich danke dir vielmals.
                  Wie kann denn sowas passieren, das dem Ordner die Rechte fehlen?
                  Die haben wie es aussieht seit der Installation gefehlt.
                  • H Offline
                    homecineplexx
                    #1628
                    bekommt man eigentlich irgendwo raus, an welchem Tag das nächste update gemacht wird?
                    denn ich muss immer per script mein NAS aufwecken. Das WoL von Backitup funkt ned.
                    • simatecS Online
                      simatecS Online
                      simatec
                      #1629
                      @homecineplexx:
                      denn ich muss immer per script mein NAS aufwecken. Das WoL von Backitup funkt ned. `
                      Der wol funktioniert.
                      Wir lange braucht dein NAS zum hochfahren?
                      Wir werden da demnächst noch eine Zeitauswahl einbauen.
                      • H Offline
                        homecineplexx
                        #1630
                        Genau die Zeit ist das Problem… 15 Minuten bis alles fertig geladen ist.
                        Coole Sache
                        • simatecS Online
                          simatecS Online
                          simatec
                          #1631
                          Wie 15 Minuten?
                          dein Nas braucht doch keine 15 Minuten zum hochfahren
                            klausiob
                            #1632
                            @simatec:
                            @klausiob:
                            @simatec:
                            Auch die History kannst du begrenzen.
                            Dafür gibt es in den Haupteinstellungen einen Menüpunkt.
                            Gesendet von iPhone mit Tapatalk `
                            Anzahl History Einträge auf 5 gestellt, aber nach dem letzten Backup sind trotzdem noch alle drin.
                            Gruß klausiob `
                            Danke für den Hinweis. Bug wurde gerade behoben und ist somit in der nächsten Version gefixt. `
                            Da ich noch relativ neu bin. Wie läuft das hier mit den Versionen? Muß man da auf offizielle stable warten oder verfügbare beta oder kann man hier irgendwie sich noch aktuellere installieren? Gibt es so ein Releaseplan?
                            Gruß Klaus
                            Pi4B, Pi3B+, Master-Slave, EchoPlus, 3xEchoDot, FireTVstick, Xiaomi Sensoren, Fritzbox, DECT200, HS100, ZBT-ExtendedColor (ALDI), Shelly 2.5, 2xZigBee-Router-Plugs, Sileno 500 smart, Somfy switch, IONIQ5, tibber
                            node.js: 22.21.0 - npm: 10.9.4 - linux: raspbian-trixie - admin 7.7.19 - vis 1.5.6 - js-controller: 7.0.7
                            • PeoplesP Offline
                              PeoplesP Offline
                              Peoples
                              #1633
                              Du kannst in den Adapter installieren aus Url machen und dort dann die GitHub Url einfügen so hast du den aktuellen Stand von Git.
                              • simatecS Online
                                simatecS Online
                                simatec
                                #1634
                                Ab sofort ist die Version 1.0.8 im Github und ab heute Nacht im latest verfügbar.
                                1.0.8 (26.01.2019)
                                __(simatec) modification for new installer
                                (simatec) WOL-waittime adjustable
                                (simatec) Fix History settings__
                                Mit dieser Version sollten die Start/Stop Probleme bei neuen Installationen behoben sein.
                                Ich habe die letzte Woche ausgiebige Test der Start/Stop Vorgänge inkl. Auswertungen gemacht.
                                Viel Spaß mit der neuen Version … ;)
                                • tripperT Offline
                                  tripperT Offline
                                  tripper
                                  #1635
                                  Bei mir funktioniert das Standard Backup nicht. Komplett Backup läuft soweit ich das sehe ohne Probleme
                                  Gestartet...
                                  [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.0.11","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=2.0","sudo":true,"deleteOldBackup":false,"ownDir":true,"bkpType":"Minimal","dir":"/Backup/backitup_iobroker/standard","dirMinimal":"/Backup/backitup_iobroker/standard","dirTotal":"/Backup/backitup_iobroker/komplett","user":"backup","pass":"****"}
                                  [DEBUG] [mount] - done
                                  [DEBUG] [minimal] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","nameSuffix":"test","deleteBackupAfter":0,"mysqlEnabled":false,"redisEnabled":false,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"//192.168.0.11","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=2.0","sudo":true,"deleteOldBackup":false,"ownDir":true,"bkpType":"Minimal","dir":"/Backup/backitup_iobroker/standard","dirMinimal":"/Backup/backitup_iobroker/standard","dirTotal":"/Backup/backitup_iobroker/komplett","user":"backup","pass":"****","context":{"fileNames":[],"errors":{},"done":["mount"],"types":[]},"adapter":null},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"Local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.0.11","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=2.0","sudo":true,"deleteOldBackup":false,"ownDir":true,"bkpType":"Minimal","dir":"/Backup/backitup_iobroker/standard","dirMinimal":"/Backup/backitup_iobroker/standard","dirTotal":"/Backup/backitup_iobroker/komplett","user":"backup","pass":"iobroker"},"dropbox":{"enabled":false,"type":"storage","source":"Local","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"email":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","systemLang":"de"},"pushover":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                                  [ERROR] [minimal] - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:193
                                                              result.objects[j].value.common.host === hostname) {
                                  TypeError: Cannot read property 'host' of undefined
                                      at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:193:60
                                      at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
                                      at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
                                      at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
                                      at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                      at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
                                      at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
                                      at Decoder. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                      at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
                                      at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-parser/index.js:251:12)
                                  [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"Local","mount":"//192.168.0.11","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=2.0","sudo":true,"deleteOldBackup":false,"ownDir":true,"bkpType":"Minimal","dir":"/Backup/backitup_iobroker/standard","dirMinimal":"/Backup/backitup_iobroker/standard","dirTotal":"/Backup/backitup_iobroker/komplett","user":"backup","pass":"****","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
                                  [DEBUG] [cifs] - done
                                  [DEBUG] [history] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","nameSuffix":"test","deleteBackupAfter":0,"mysqlEnabled":false,"redisEnabled":false,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"//192.168.0.11","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=2.0","sudo":true,"deleteOldBackup":false,"ownDir":true,"bkpType":"Minimal","dir":"/Backup/backitup_iobroker/standard","dirMinimal":"/Backup/backitup_iobroker/standard","dirTotal":"/Backup/backitup_iobroker/komplett","user":"backup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/minimal_2019_01_27-23_09_34_test_backupiobroker.tar.gz"],"errors":{},"done":["mount","minimal"],"types":["minimal"]},"adapter":null},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"Local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.0.11","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=2.0","sudo":true,"deleteOldBackup":false,"ownDir":true,"bkpType":"Minimal","dir":"/Backup/backitup_iobroker/standard","dirMinimal":"/Backup/backitup_iobroker/standard","dirTotal":"/Backup/backitup_iobroker/komplett","user":"backup","pass":"iobroker"},"dropbox":{"enabled":false,"type":"storage","source":"Local","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"27\. Januar 2019 um 23:09 Uhr"},"email":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","systemLang":"de"},"pushover":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                                  [DEBUG] [history] - backitup.1.history.html
                                  [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"Local","mount":"//192.168.0.11","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=2.0","sudo":true,"deleteOldBackup":false,"ownDir":true,"bkpType":"Minimal","dir":"/Backup/backitup_iobroker/standard","dirMinimal":"/Backup/backitup_iobroker/standard","dirTotal":"/Backup/backitup_iobroker/komplett","user":"backup","pass":"****","backupDir":"/opt/iobroker/backups"}
                                  [DEBUG] [umount] - wait 60 seconds for umount!
                                  [DEBUG] [umount] - done
                                  [EXIT] 1</anonymous></anonymous></anonymous>
                                  Leider verstehe ich nicht viel davon was mir hier gemeldet wird. Wenn ich in "/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/" nachschaue liegen da Dateien mit Datum um 1985 :) !
                                  Hab ich mir da evtl. mit der kürzlich per Komplett Backup (ja ich weiss das sollte man nicht, minimal ging aber auch dort schon nicht) wiederhergestellten iobroker Installation irgendwas eingeschleppt? Dort hatte ich auch öfters irgendwelche seltsamen Zeitstempel
                                  • MathiasJM Offline
                                    MathiasJM Offline
                                    MathiasJ
                                    #1636
                                    Ich habe ein produktives und ein unproduktives System aufgebaut.
                                    Bei beiden habe ich das lastest installiert und den hier abgelegete sh-datei per WinSCP hochgeladen und ausgeführt.
                                    Bei beiden Systemen arbeitet iobroker.backitup ohne zu murren.
                                    Ich dachte ich muß mal ein positives Feddback hier abgeben. negative bekommst Du mehr als genug.
                                    Gruß,
                                    Mathias
                                    IObroker auf dem NUC als VM.
                                    • simatecS Online
                                      simatecS Online
                                      simatec
                                      #1637
                                      @MathiasJ:
                                      Gruß,
                                      Mathias `
                                      Sehe ich ehrlich gesagt nicht so … das meiste waren im großen und ganzen sehr oft Bedienfehler [emoji4]
                                        mguenther
                                        #1638
                                        hmmm - bei mir funktionierte der Adapter auch 1a und speicherte auf meinem NAS die Standard-Backups täglich, die Komplett-Backups alle 2 Tage und meine CCU ebenfalls alle 2 Tage. Auf einmal speicherte der Adapter nichts mehr auf dem NAS. Warum, kann ich nicht sagen. Ich habe jetzt mehrmals den Adapter gestoppt und wieder neugestartet - jetzt bekomme ich zumindest wieder ein Backup von meiner CCU, allerdings nicht in dem vorgegebenen Ordner für die CCU, sondern im Ordner für meine Komplettbackup. Auch wenn ich händisch ein Standardbackup ausführe, wird es im Ordner für das Komplettbackup gespeichert. Ich habe keine Ahnung warum.
                                        installiert ist V1.0.1, ich habe js-controller 1.4.2, node und nodejs 8.15 und npm 6.4.1
                                        einer eine Idee?
                                        wenn ich das Backup händisch ausführe, bekomme ich folgendes:
                                        Gestartet...
                                        [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"192.168.222.175","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Total","dir":"/iobroker_backup/standard","dirMinimal":"/iobroker_backup/standard","dirTotal":"/iobroker_backup/komplett/","user":"iobroker","pass":"****"}
                                        [ERROR] [mount] - [undefined mount error(95): Operation not supported
                                        Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
                                        [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=iobroker,password=XXXXXX,rw,file_mode=0777,dir_mode=0777 //192.168.222.175/iobroker_backup/standard /opt/iobroker/backups
                                        [DEBUG] [minimal] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"mysqlEnabled":false,"redisEnabled":false,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"//192.168.222.175","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Total","dir":"/iobroker_backup/standard","dirMinimal":"/iobroker_backup/standard","dirTotal":"/iobroker_backup/komplett/","user":"iobroker","pass":"****","context":{"fileNames":[],"errors":{},"done":[],"types":[]},"adapter":null},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"NAS / Copy","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Total","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"192.168.222.175","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Total","dir":"/iobroker_backup/standard","dirMinimal":"/iobroker_backup/standard","dirTotal":"/iobroker_backup/komplett/","user":"iobroker","pass":"XXXXXX"},"dropbox":{"enabled":false,"type":"storage","source":"NAS / Copy","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Total","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":true,"NoticeType":"shortTelegramNotice","User":"allTelegramUsers","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                                        [DEBUG] [minimal] - Backup created: /opt/iobroker/backups/minimal_2019_01_28-22_54_37_backupiobroker.tar.gz
                                        [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"//192.168.222.175","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Total","dir":"/iobroker_backup/standard","dirMinimal":"/iobroker_backup/standard","dirTotal":"/iobroker_backup/komplett/","user":"iobroker","pass":"****","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
                                        [DEBUG] [telegram] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"mysqlEnabled":false,"redisEnabled":false,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"//192.168.222.175","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Total","dir":"/iobroker_backup/standard","dirMinimal":"/iobroker_backup/standard","dirTotal":"/iobroker_backup/komplett/","user":"iobroker","pass":"****","context":{"fileNames":["/opt/iobroker/backups/minimal_2019_01_28-22_54_37_backupiobroker.tar.gz"],"errors":{},"done":["minimal"],"types":["minimal"]},"adapter":null},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"NAS / Copy","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Total","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"192.168.222.175","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Total","dir":"/iobroker_backup/standard","dirMinimal":"/iobroker_backup/standard","dirTotal":"/iobroker_backup/komplett/","user":"iobroker","pass":"XXXXXXx"},"dropbox":{"enabled":false,"type":"storage","source":"NAS / Copy","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Total","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":true,"NoticeType":"shortTelegramNotice","User":"allTelegramUsers","systemLang":"de","time":"28\. Januar 2019 um 22:54 Uhr"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                                        [DEBUG] [history] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"mysqlEnabled":false,"redisEnabled":false,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"//192.168.222.175","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Total","dir":"/iobroker_backup/standard","dirMinimal":"/iobroker_backup/standard","dirTotal":"/iobroker_backup/komplett/","user":"iobroker","pass":"****","context":{"fileNames":["/opt/iobroker/backups/minimal_2019_01_28-22_54_37_backupiobroker.tar.gz"],"errors":{},"done":["minimal"],"types":["minimal"]},"adapter":null},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"NAS / Copy","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Total","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"192.168.222.175","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Total","dir":"/iobroker_backup/standard","dirMinimal":"/iobroker_backup/standard","dirTotal":"/iobroker_backup/komplett/","user":"iobroker","pass":"XXXXXX"},"dropbox":{"enabled":false,"type":"storage","source":"NAS / Copy","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Total","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"28\. Januar 2019 um 22:54 Uhr"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":true,"NoticeType":"shortTelegramNotice","User":"allTelegramUsers","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                                        [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"//192.168.222.175","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Total","dir":"/iobroker_backup/standard","dirMinimal":"/iobroker_backup/standard","dirTotal":"/iobroker_backup/komplett/","user":"iobroker","pass":"****","backupDir":"/opt/iobroker/backups"}
                                        Obwohl in dem Fenster "Schließen wenn fertig" aktiviert ist, passiert nix, das Backup liegt aber auf dem NAS, nur eben im falschen Verzeichnis.
                                        • SegwayS Offline
                                          SegwayS Offline
                                          Segway
                                          #1639
                                          Wie verbindest du dich mit dem Nas ? Cifs oder nfs ?
                                          Ich mache es per cifs und habe gleiches Phänomen wie Du.
                                          Nach einigen Recherchen kann ich behaupten das am Ende anscheinend irgendwann das UMOUNT nicht mehr richtig abgeschlossen wird.
                                          Beim nächsten Mount vom Adapter hängt es dann.
                                          Manuelles umount per Putty und Neustart des Adapters behob alles wieder. Bin aber immer noxh am beobachten
                                          Gruß Dirk
