  4. Adapter: iobroker.backitup (stable Release)
adapterbackitupiobroker backupbackupiobroker.backitup
2.3k Beiträge 185 Kommentatoren 1.6m Aufrufe 50 Beobachtet
  • simatecS Online
    simatecS Online
    simatec
    #1594
    @MathiasJ:
    guten morgen zusammen.
    Hier das versprochene Logfile:
    einmal mit IP-Adresse:
    backitup.0	2019-01-20 09:14:54.757	debug	system.adapter.admin.0: logging true
    backitup.0	2019-01-20 09:12:55.851	debug	[minimal/history] backitup.0.history.html
    backitup.0	2019-01-20 09:12:55.833	debug	[minimal/clean] done
    backitup.0	2019-01-20 09:12:55.832	debug	[minimal/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
    backitup.0	2019-01-20 09:12:55.829	debug	[minimal/cifs] done
    backitup.0	2019-01-20 09:12:55.824	debug	[minimal/minimal] done
    backitup.0	2019-01-20 09:12:55.795	debug	[minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2019_01_20-09_12_52_backupiobroker.tar.gz
    backitup.0	2019-01-20 09:12:52.694	debug	[minimal/mount] mount: only root can use "--options" option
    backitup.0	2019-01-20 09:12:52.694	debug	[minimal/mount] [IGNORED] Error: Command failed: mount -t cifs -o username=IObroker,password=geheim,rw,file_mode=0777,dir_mode=0777 //192.168.1.53/Backup/IObroker /opt/iobroker/backups
    backitup.0	2019-01-20 09:12:52.690	debug	[minimal/mount] [undefined mount: only root can use "--options" option
    backitup.0	2019-01-20 09:12:27.639	debug	[minimal/mount] Wake on LAN MAC-Address: 00:11:32:83:47:D4
    backitup.0	2019-01-20 09:12:27.630	debug	[minimal/mount] Wake on LAN wait 25 Seconds for NAS!
    backitup.0	2019-01-20 09:12:22.883	debug	[minimal] 10 00 02 */1 * *
    einmal mit Hostname:
    backitup.0	2019-01-20 09:17:44.362	debug	[minimal/history] backitup.0.history.html
    backitup.0	2019-01-20 09:17:44.332	debug	[minimal/clean] done
    backitup.0	2019-01-20 09:17:44.332	debug	[minimal/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
    backitup.0	2019-01-20 09:17:44.328	debug	[minimal/cifs] done
    backitup.0	2019-01-20 09:17:44.325	debug	[minimal/minimal] done
    backitup.0	2019-01-20 09:17:44.302	debug	[minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2019_01_20-09_17_41_backupiobroker.tar.gz
    backitup.0	2019-01-20 09:17:41.168	debug	[minimal/mount] mount: only root can use "--options" option
    backitup.0	2019-01-20 09:17:41.168	debug	[minimal/mount] [IGNORED] Error: Command failed: mount -t cifs -o username=IObroker,password=geheim,rw,file_mode=0777,dir_mode=0777 //dahoam.fritz.box/Backup/IObroker /opt/iobroker/backups
    backitup.0	2019-01-20 09:17:41.165	debug	[minimal/mount] [undefined mount: only root can use "--options" option
    backitup.0	2019-01-20 09:17:16.111	debug	[minimal/mount] Wake on LAN MAC-Address: 00:11:32:83:47:D4
    backitup.0	2019-01-20 09:17:16.098	debug	[minimal/mount] Wake on LAN wait 25 Seconds for NAS!
    Gruß,
    Mathias `
    Dein iobroker ist mit der neuen Installationsroutine installiert und hat keine sudo rechte.
    Dafür bitte den Script sudo4backitup nehmen und für den User „iobroker“ die Rechte anlegen.
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    • MathiasJM Offline
      MathiasJM Offline
      MathiasJ
      #1595
      Schon passiert.
      Aber:
      es geht weder mit der alten, noch mit der neuen Installationsroutine.
      Das heißt, ich musste das so oder so machen….....
      WoL ist auch abgeschaltet, weil nicht benötigt.
      habe nur ein test-backup gemacht, dann Backitup deaktiviert bei der Beebox.
      Wenn ich mein Netzwerk ausgemistet habe, läuft die Beebox wieder als produktives System und Backitup ist wieder online
      Gruß,
      Mathias
      IObroker auf dem NUC als VM.
        Buddinski88
        #1596
        @MathiasJ:
        @Buddinski88:
        Das aufwecken klappt auch soweit, aber die 25 Sekunden Wartezeit bis das Backup startet, reicht leider nicht aus. `
        Eigenartig,
        Ich habe auf meiner DS wake up deaktiviert und es lief durch.
        Gruß,
        Mathias
        Gesendet von meinem MI 8 mit Tapatalk `
        Meinst du damit das du WOL ausgeschaltet hast und dann geht es?
        Deine DS nimmt dann doch gar keine WOL Pakete entgegen und kann nicht aufwachen?
        • MathiasJM Offline
          MathiasJM Offline
          MathiasJ
          #1597
          @Buddinski88
          wie machst Du Deine Backups?
          Mit NFS oder CIFS?
          Ich habe bei mir CIFS eingerichtet und es läuft auh ohne WoL.
          ist ja egal. hauptsache es läuft…......
          Gruß,
          Mathias
          • simatecS Online
            simatecS Online
            simatec
            #1598
            Was hat das mit backitup zu tun.
            Backitup kann nur bei richtig eingetragener mac eurer NAS aufwecken.
            Aber Einstellungen der NAS und oder ob dir wol können, bitte nicht hier diskutieren.
            • MathiasJM Offline
              MathiasJM Offline
              MathiasJ
              #1599
              @simatec
              eine Frage am Rande,
              wenn man jetzt immer den Script sudo4backitup braucht, sowohl bei der alten als auch bei der neuen Installationsroutine, hängt das nicht eher mit der Linux-Installation zusammen? Bei mir ist Ubuntu Server 18.04 installiert.
              Was bei sudo apt-get update && sudo apt-get upgrade geändert wird, weiß man ja nicht…....
                Kueppert
                #1600
                Off topic:
                Ich würde mein Nas nicht mehr ständig runter fahren… Nicht gut für die Platten, aber natürlich stromsparend.
                Gesendet von meinem HUAWEI RIO-L01 mit Tapatalk
                • simatecS Online
                  simatecS Online
                  simatec
                  #1601
                  Grundsätzlich hat sich einiges verändert an den Sicherheitsmaßnahmen.
                  Folgendes passiert, wenn du sudo als User nutzen willst und iobroker als User installiert hast.
                  Gibt man in der Konsole einen Befehl wie mount oder systemctl mit sudo ein, wird vom System das sudo (root Passwort) verlangt.
                  Nach Eingabe des Passworts wird der Befehl ausgeführt.
                  Wenn man nun ein sudo in einem Script verwendet passiert im Prinzip das Gleiche.
                  Da aber hier kein Passwort vom Script eingegeben werden kann, scheitert der Befehl.
                  Der Script sudo4backitup setzt für den eigegebenen User (mit neuen Installationsscript User iobroker) für die von backitup benötigen Befehle ein deaktivieren der Passwortabfrage.
                  Somit können dann über den User mount, umount und systemctl mit sudo aufgerufen werden, ohne dass eine Abfrage des root Passwort erfolgt.
                  Testen kann man das in der Konsole.
                  Im Moment arbeiten wir an einem Patch für den Installer, damit nach einer iobroker Installation die sudo Rechte bereits für sämtliche Befehle der diversen Adapter gesetzt sind.
                  Es hat halt Vor und Nachteile mit dem neuen Sicherheitskonzept.
                  Aber Grundsätzlich ist es definitiv sicherer, die neue Variante zu nutzen und iobroker nicht als root laufen zu haben.
                  • L Offline
                    Leviathan09
                    #1602
                    @simatec:
                    @Leviathan09:
                    Edit: Habe nun über die Backup Funktion von iobroker das minimal mit "iobroker restore" zurückspielen können.
                    Skripte, Szenen etc sind da. Adapter werden unter den Adaptern angezeig muss diese jedoch neu installieren bzw updaten, was aber ok ist.
                    Frage mich warum das aber über den Adapter nicht möglich war :?:
                    Also es funktionierte weder das minimal noch das total.
                    Ich lass es jetzt einfach und fange eben komplett von vorne an. `
                    Hast du denn über backitup ein minimal getestet?
                    Gestern waren es doch noch total backups
                    Hast du den Script sudo4backitup mit Eingabe des Users iobroker gemacht?
                    Gesendet von iPhone mit Tapatalk `
                    Habe es mit Total als auch Minimal probiert.
                    Hatte beides nicht über den Adapter funktioniert.
                    Das sudo4backitup habe ich vorher so wie von dir beschrieben mit dem User ioBroker laufen lassen.
                    • simatecS Online
                      simatecS Online
                      simatec
                      #1603
                      IoBroker oder iobroker?
                      Die Schreibweise ist bei Usernamen sehr wichtig.
                      • L Offline
                        Leviathan09
                        #1604
                        @simatec:
                        Gesendet von iPhone mit Tapatalk ` iobroker…alles klein
                        Das B schreibt mein Handy immer automatisch groß
                        • simatecS Online
                          simatecS Online
                          simatec
                          #1605
                          Ich prüfe das nochmal und werde mal ne Testumgebung mit neuen Installer aufsetzen.
                          • F Offline
                            Frank_y
                            #1606
                            Ich benutze Backitup 1.0.0 mit Dropbox jetzt schon seit einigen Wochen. Grundsätzlich ein ganz toller Adapter.
                            Was ich aber feststelle ist, dass sich irgendwann der Zeitplan aufhängt und die Backups nicht mehr gestartet werden.
                            'Irgendwann' konnte ich leider noch nicht genauer eingrenzen. Gefühlt funktioniert die Zeitplanung 2-3 Wochen zuverlässig und hängt sich dann ohne Fehlermeldung auf.
                            (Wenn der Punkt schon diskutiert wurde, bitte ich um Entschuldigung, aber 80 Seiten sind zu lang, um alles durchzulesen)
                            • PeoplesP Offline
                              PeoplesP Offline
                              Peoples
                              #1607
                              @Frank_y:
                              (Wenn der Punkt schon diskutiert wurde, bitte ich um Entschuldigung, aber 80 Seiten sind zu lang, um alles durchzulesen) `
                              Auf meinem Produktiv-System läuft die Version 0.3.8 seit November und auf dem Testsystem die 1.0 seit dezember ohne Probleme. Aber bei einem Komplett-Backup wird ja alles neu gestartet wenn du kein Komplett machst, wäre das jedoch nicht der Fall. Führst du komplette aus?
                              • F Offline
                                Frank_y
                                #1608
                                @peoples:
                                @Frank_y:
                                Auf meinem Produktiv-System läuft die Version 0.3.8 seit November und auf dem Testsystem die 1.0 seit dezember ohne Probleme. Aber bei einem Komplett-Backup wird ja alles neu gestartet wenn du kein Komplett machst, wäre das jedoch nicht der Fall. Führst du komplette aus? `
                                Standard alle 2 Tage 2:00, max 10 Dateien auf Dropbox
                                Komplett alle 10 Tage 3:00, max 3 Dateien auf Dropbox
                                Homematic alle 15 Tage um 01:30, max. 10 Dateien auf Dropbox
                                • OberjembkerO Offline
                                  Oberjembker
                                  #1609
                                  Sorry, falls das in den letzten 1600 Beiträgen schon zur Sprache kam…:
                                  Ich führe einen erfolgreichen FTP-Backup (backitup V1.0.0) auf mein NAS durch:
                                  backitup.0   ...   debug   [minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2019_01_21-21_49_57_backupiobroker.tar.gz
                                  backitup.0   ...   debug   [minimal/minimal] done
                                  backitup.0   ...   debug   [minimal/ftp] FTP connected.
                                  backitup.0   ...   debug   [minimal/ftp] Send minimal_2019_01_21-21_49_57_backupiobroker.tar.gz
                                  Obwohl das Hochladen erfolgreich ist,
                                  • gibt es keine weitere Meldung mehr,
                                  • bleibt die Historie auf "Noch kein Backup erstellt" stehen,
                                  • wird der Datenpunkt backitup.0.oneClick.minimal offenbar nicht mehr auf false zurückgesetzt (wie lange ist die Wartezeit?).
                                  Kann das ein Rückmelde-Problem zwischen Raspberry FTP und dem NAS sein, oder kommt danach tatsächlich keine Meldung ("Ende FTP-Transfer" oder so) mehr?
                                  • simatecS Online
                                    simatecS Online
                                    simatec
                                    #1610
                                    @Oberjembker:
                                    Kann das ein Rückmelde-Problem zwischen Raspberry FTP und dem NAS sein, oder kommt danach tatsächlich keine Meldung ("Ende FTP-Transfer" oder so) mehr? `
                                    Poste mal bitte den kompletten Log vom backupvorgang.
                                    • simatecS Online
                                      simatecS Online
                                      simatec
                                      #1611
                                      @Frank_y:
                                      @peoples:
                                      @Frank_y:
                                      Homematic alle 15 Tage um 01:30, max. 10 Dateien auf Dropbox `
                                      Die Frage war, ob du iobroker stoppst für das komplette Backup?
                                      • E Offline
                                        eMd
                                        #1612
                                        Habe probiert was zu finde, aber bei mir funktioniert umount nicht nach dem ersten Backup, dann gehen die anderen immer nicht.
                                        Drive busy Meldung kommt, wie kann ich die umgehen?
                                        MfG
                                        eMd
                                        Master: Intel NUC 16GB/500GB
                                        Slave: Raspberry Pi 3 + Homematicmodul
                                        Shelly, Google Home, Zigbee Aqara, Sonoff
                                        Meine VIS: https://youtu.be/JMYr2KYlpME
                                        • W Offline
                                          W Offline
                                          Wiggins
                                          #1613
                                          Guten Morgen zusammen,
                                          ich weiß nicht, ob ich mit dem Problem hier richtig bin, aber es passt bzgl Fehlermeldung bzw -zeitpunkt hierher. Ich hab mit viel Kampf das backitup zum Laufen gebracht (ich kann nur mit Haken gesetzt bei Mount als Root (sudo) auf meine NAS schreiben, per Zeitplan um 2 Uhr Standard alle 1 und um 3 Uhr Komplett alle 3 Tage). Ich hab dabei Haken gesetzt bei "iobroker stop bei Backup".
                                          iobroker läuft auf nem Beelink BT3 pro mit Debian und ich hab ioBroker mit der neuen Routine installiert. Wie mir scheint nicht mit nem User, sondern direkt root. Ich finde keinen Standard User iobroker.
                                          Heute morgen war der iobroker admin nicht mehr erreichbar. Per SSH Zugriff und iobroker restart admin lief er dann binnen Sek wieder.
                                          Diesen Log bekam ich um 3:00:
                                          ! Caught 2019-01-22 03:00:10.595 error by controller[0]: at tryOnTimeout (timers.js:323:5)
                                          ! Caught 2019-01-22 03:00:10.595 error by controller[0]: at ontimeout (timers.js:498:11)
                                          ! Caught 2019-01-22 03:00:10.595 error by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/schedule.js:510:7)
                                          ! Caught 2019-01-22 03:00:10.595 error by controller[0]: at /opt/iobroker/node_modules/node-schedule/lib/schedule.js:552:11
                                          ! Caught 2019-01-22 03:00:10.595 error by controller[0]: at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/schedule.js:173:10)
                                          ! Caught 2019-01-22 03:00:10.595 error by controller[0]: at Job.backupTimeSchedules.(anonymous function).schedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.backitup/main.js:196:17)
                                          ! Caught 2019-01-22 03:00:10.594 error by controller[0]: at startBackup (/opt/iobroker/node_modules/iobroker.backitup/main.js:37:9)
                                          ! Caught 2019-01-22 03:00:10.594 error by controller[0]: at executeScripts (/opt/iobroker/node_modules/iobroker.backitup/lib/execute.js:38:32)
                                          ! Caught 2019-01-22 03:00:10.594 error by controller[0]: at err (/opt/iobroker/node_modules/iobroker.backitup/main.js:39:19)
                                          ! Caught 2019-01-22 03:00:10.594 error by controller[0]: at err (/opt/iobroker/node_modules/iobroker.backitup/main.js:203:55)
                                          ! Caught 2019-01-22 03:00:10.594 error by controller[0]: TypeError: Cannot read property 'errors' of undefined
                                          Liegt es am backitup? Woran?
                                          Oder ist das hier die falsche Baustelle? Wo müsste ich dann um Hilfe bitten?
                                          Danke euch allen vorab für die Hilfe und wünsche schönen Tag!
                                          Wiggins
