  4. Adapter: Radar
Adapter: Radar
350 Beiträge 59 Kommentatoren 109.7k Aufrufe 2 Beobachtet
  • frankjokeF Offline
    frankjokeF Offline
    frankjoke
    #303
    Hallo mitsammen!
    Nach 9 Monaten Auslandsjob und einigen Änderungen meiner Systeme (neuer switch, neues NAS, kaputte s OrangePi, …) konnte ich mich diese Woche wieder erstmals den Adaptern widmen.
    Habe einen neue Version des Radar-Adapters auf git gestellt welcher folgendes ## Changelog enthält:
    1.2
    • Added arp-scan command line into configuration and added Admin v3.x style
    • changed noble to '@abandonware/noble' as default to try to get V10 compatibility
    • Removed ECB-Funtion because ECB moved to variable https site and the simple tools cannot resolve the data anymore. Hope that systemstatus adapter will be able to do so.
    • arp-scan --retry was set to 4 to reduce traffic, it can be changed lower or higher with arp-scan command line
    • if you upgrade your radar and nothing appears in the arp-scan command line please enter --retry=3 (or 4).
    • HTTP checks can also use HTTPS now
    • Vendor name is grabbed but maybe later than on first scan because free API allows only one vendor check/second and 1000/day. If you have 30 devices on IP or BT this means it will take about 40 seconds to grab vendors and they should be visible in 2nd or 3rd scan. The adapter caches the vendor information so no further requests happen until adapter restart or new device on BT or network.
    • For HP printers the adapter collects now all individual inks in an '.ink' subfolder to reduce the number of items/printer.
    • Please run ioBroker as root! Some functions like l2ping or arp-scan and noble may not function!
    • Reduced the minimum scan interval to 15 seconds, if not all IP's or BT's are found please increase!
    ECB-Funktion wurde rausgeschmissen aber alles andere etwas verbessert und beschleuinigt.
    Der Adapter sollte nicht mehr so viel Netwerktraffic generieren, ihr könnt auch noch weiter runtergehen...
    Man kann auch die arp-scan-Argumente jetzt ändern und damit andere als das erste Interface ansprechen.
    Die vendor-information für die MAC's funktionieren wieder, leider hat der der Anbieter der API die freie Abfrage auf 1/sekunde limitiert wodurch bei den ersten scans möglicherweise nicht alle Infos zur Verfügung stehen.
    Ach sorry, iobroker muss unter root laufen um alle Funktionen wie arp-scan, hcitool oder l2ping benutzen zu können!
    Bitte um Tests um zu sehen ob ich vielleicht noch einen neuen Fehler mit-eingebaut hab!
    LG Frank
    Frank,
    NUC's, VM's und Raspi's unter Raspian, Ubuntu und Debian zum Testen.
    Adapter die ich selbst beigesteuert habe: BMW, broadlink2, radar2, systeminfo, km200, xs1 und einige im Anmarsch!
    • apollon77A Offline
      #304
      Neben root sollten auch die „passwordless sudo“ Varianten aus anderen Threads tun. Finde sie gerade am Handy nicht.
      @fsjoke: vllt das mal testen?
      Schön das du wieder zurück bist.
      Wir wollen weg von „iobroker läuft als root“ aus Sicherheitsgründen.
      Gesendet vom Handy …
      • R Offline
        RappiRN
        #305
        Ich wollte nochmal ein kurzes Feedback geben zu meinen geänderten Einstellungen.
        Ich hatte ja zusätzlich zu den IP-Adressen noch die Mac-Adressen eingegeben, seitdem werden die IPs wieder einwandfrei erkannt! Zuverlässiger, als die gleichen Geräte über BT. Bei BT wird der Grund für das Problem aber im schlechten Empfang in manchen Hausbereichen sein. Jetzt, da die IPs wieder einwandfrei funktionieren, kann ich die BT-Erweiterung im Haus nach ganz hinten stellen! :D
        Enrico
        • C Offline
          cyberindy
          #306
          Bei mir tut der Adapter leider gar nicht mehr. Selbst ein Downgrade habe ich versucht, bekomme ihn aber nicht mehr ordentlich zum Laufen.
          Die Instanz leuchtet grün und es erscheinen keine Fehler im Log. Nach einem Neustart der Instanz erscheint:
          radar.0 2019-01-15 15:36:28.160 info Adapter initialization finished!
          radar.0 2019-01-15 15:36:27.378 info ScanAll: From all 8 devices dedected 0 are whoHere:
          radar.0 2019-01-15 15:35:00.659 info radar set use of noble(true), fping(true), doMac(true), doHci(false), doBtv(false) and doUwz(null,0,0,,false).
          radar.0 2019-01-15 15:35:00.659 info radar adapter initialized 22 devices, ExternalNetwork = 600.
          … danach Funktstille. Keine weiteren Logeinträge und keine Updates auf meine Datenpunkte.
          Arp-scan wäre bei mir installiert, aber ich sehe kein "arp-scan(true) mehr in meinen Logs.
          Meine Konfiguration:
          In der Zeile "arp-scan Kommandozeile" kann ich ausschließlich Zahlen eintragen. Alles andere wird sofort gelöscht. Ist das gewollt? Ich habe unterschiedliche Werte getestet … ohne Erfolg
            dondaik
            #307
            arp-scan - das ist doch wohl die interfacer … also 0 oder 1 ... ( würde ich sagen - sehe das ich diesen eintrag nicht habe )
            wer Schreibfehler findet darf sie behalten … :-(
            Ps: Anfänger im Bereich Tinkerboard + IOBROKER !
            • C Offline
              cyberindy
              #308
              @dondaik:
              arp-scan - das ist doch wohl die interfacer … also 0 oder 1 ... ( würde ich sagen - sehe das ich diesen eintrag nicht habe ) `
              Glaube nicht. Wenn ich die Logs richtig deute, wird der eingetragene Wert einfach an "arp-scan -lgq" angehängt:
              radar.0	2019-01-15 16:33:03.825	info	radar set to arp-scan with command "arp-scan -lgq 0" on Interface: enp4s0, datalink type: EN10MB (Ethernet)
              …demnach würde es nur Sinn machen, wenn ich hier "--retry=3" o.ä. eintragen könnte. Geht aber nicht, da anscheinend ein Event auf dem Input-Feld liegt, das alle Zeichen außer Ziffern sofort wieder löscht.
                frankjokeF Offline
                frankjoke
                #309
                cyberindy, bei updates wird die Kommandozeile nicht generiert weil sie nicht vorhanden ist, der erste Teil 'arp-scan -lqg ' wird immer vorangesetzt.
                Du musst--retry=3zumindest angeben, wenn ein anderes Interface verwendet werden soll dann auch ein````
                --interface=wlan0
                Das bedeutet dass dann dort wo du nur '4' stehen hast eigentlich````
                --retry=3 --interface=wlan0
                Das richtige Interface kannst über````
                ifconfig
                ````herausfinden, es listet alle interfaces und du musst das nehmen welches deine IP-Netwerk beinhaltet in welchem gesucht werden soll, wenn es keine IP anzeigt kann sie nicht verwendet werden.
                Frank,
                • C Offline
                  cyberindy
                  #310
                  @fsjoke
                  Vielen Dank für Deine Rückmeldung.
                  Ich kann in das Feld "arp-scan Kommandozeile" leider nichts anderes eintragen außer Ziffern. Wenn ich versuche "- - r e t r y = 4" einzutippen, werden alle Zeichen, außer "4" gelöscht. Das Feld scheint mit einem JS-Event belegt zu sein, dass alles außer Ziffern rauslöscht (mit Firefox und Chromium).
                  Den Satz "bei updates wird die Kommandozeile nicht generiert weil sie nicht vorhanden ist" habe ich leider nicht verstanden. Was meinst Du damit?
                  Egal was ich bislang probiert habe: ich bekomme immer nur einen "scanAll"-Aufruf beim Start der Instanz … Danach wird "scanAll" nicht mehr aufgerufen.
                    dondaik
                    #311
                    ach, welche radar-version ist das den ?
                    • C Offline
                      cyberindy
                      #312
                      @dondaik:
                      ach, welche radar-version ist das den ? `
                      Die aktuelle 1.2.0
                        dondaik
                        #313
                        danke,
                        dann gehe ich mal auf die "suche" - hier wird nur 1.1.3 angezeigt
                          frankjokeF Offline
                          frankjoke
                          #314
                          Alle bitte nochmal runterladen von git!
                          Habe hoffentlich den Fehler behoben dass der adapter nicht richtig funktioniert wenn keine Orts (longitude/latidude)-Daten im Admin angegeben sind!
                          Leider hat mein vorhergehender Versuch das Problem zu lösen einen anderen Fehler erzeugt bei allen die die Daten drinnen haben und UWZ abrufen!
                          Die Version ist 1.2.0 momentan zum Testen.
                          Frank,
                            frankjokeF Offline
                            frankjoke
                            #315
                            @cyberindy:
                            @fsjoke
                            Egal was ich bislang probiert habe: ich bekomme immer nur einen "scanAll"-Aufruf beim Start der Instanz … Danach wird "scanAll" nicht mehr aufgerufen. `
                            Du verwendest das alte admin und leider habe ich da drinnen einen Fehler den ich grad auch behoben hab. Alle mit neuem Admin sollten schon vorher texte eingeben können!
                            Also bitte nochmal runterladen :)
                            Frank,
                              #316
                              Admin updaten bitte!! Admin 2 ist EOL!
                              • C Offline
                                cyberindy
                                #317
                                Ich habe Admin 3.5.10 installiert und finde auch keinen anderen oder aktuelleren. Ist das nicht der aktuellste?
                                • C Offline
                                  cyberindy
                                  #318
                                  @fsjoke
                                  Mit dem neuen checkout aus dem Master branch funzt jetzt wieder alles wunderbar. Vielen Dank für den schnellen Fix. :)
                                    frankjokeF Offline
                                    frankjoke
                                    #319
                                    @apollon77:
                                    Wir wollen weg von „iobroker läuft als root“ aus Sicherheitsgründen. `
                                    Ok, hab mir das angesehen obwohl ich keinen Beitrag gefunden hab…
                                    Ich glaube dass ich die Lösung gefunden habe!
                                    Funktioniert bei mir auf 2 Rechnern.
                                    In der readme auf Git (noch immer Version 1.2) hab ich das so beschrieben:
                                    Bei neueren Installationen läuft ioBroker nicht als 'root' sondern als 'iobroker' user. In diesem Fall ist es notwendig iobroker als Benutzer für 'sudo' einzuritchen.
                                    Das erledigt man mit dem Kommando
                                    sudo visudo
                                    Und man fügt dort in eine Zeile unter '# User privilege'
                                    iobroker    ALL=(ALL:ALL) NOPASSWD: ALL
                                    ein. visudo funktioniert am Raspi wie Nano, auf manchen anderen Rechnern wie vi.
                                    Für noble muss dann noch folgendes ausgeführt
                                    sudo apt-get install libcap2-bin
                                    sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
                                    neu von git laden und es sollte funktionieren!
                                    LG Frank
                                    Frank,
                                      dondaik
                                      #320
                                      und später folgt die radar - version für laien ?
                                        #321
                                        Jain. Der iobroker installer wird gerade dahingehend überarbeitet das alles korrekt eingestellt wird.
                                        Aber je nachdem kann es sein das man Schritte wie oben noch manuell ausführen muss.
                                          frankjokeF Offline
                                          frankjoke
                                          #322
                                          Habe gestern extra einen Raspi aus der Lade geholt und komplett neu aufgesetzt um ihn zum Testen zu verwenden.
                                          Der Adapter läuft darauf aber das Bluetooth (und das WLan) sind so grottenschlecht dass sie mehr Probleme machen als wirklich verwendbar sind!
                                          Deshalb schlag ich immer vor:
                                          Raspi mit ioBroker nur über Netwerkschnittstelle und Bluetooth über einen USB-dongle!
                                          Dazu sollte man BT und W-Lan ausschalten und das gelingt mit
                                          sudo nano /etc/modprobe.d/raspi-blacklist.con
                                          und dort werden Treiber angegeben welche nicht geladen werden sollen:
                                          #wifi
                                          blacklist brcmfmac
                                          blacklist brcmutil
                                          #bt
                                          blacklist btbcm
                                          blacklist hci_uart
                                          einfügen oder anhängen, nach einem re-boot startet der Raspi ohne W-Lan und Bluetooth (kann auch einzeln abgeschaltet werden wenn die Teile dementsprechend weggelassen werden.
                                          Dann hat der USB-BT wieder die nummer hci0 und die Programme sprechen ihn per default an.
                                          p.s.: Ich verstehe dass das für Laien vielleicht komisch klingt aber die Technik ist nun mal nicht einfach!
                                          Ingo, kennst du eine Möglichkeit bestimmte Befehle im iobroker nur bei der Installation durchzuführen? Sowas wie eine Konfig die bei der Installation gemacht wird, nicht beim Start vom Adapter!
                                          LG
                                          Frank
                                          Frank,
