  4. Iobroker Logging zu syslog
26 Beiträge 11 Kommentatoren 8.2k Aufrufe 4 Beobachtet
  • apollon77A Offline
    Siehe https://github.com/ioBroker/ioBroker.js … -dist.json
    Ist an sich alles drin.
    Musst nur log -> transport -> syslog1 das "enabled": true machen und unter "Host" den Server eintragen wenn nicht localhost
    • sissiwupS Offline
      sissiwupS Offline
      sissiwup
      bei mir passiert da nix. Hat das schon wer zum laufen bekommen?
      Habe die CCU2 und div. andere Logs auf meinen Log-Server liegen,
      ioBroker will aber nicht.
       "log": {
          "level": "info",
          "maxDays": 30,
          "transport": {
            "file1": {
              "type": "file",
              "enabled": true,
              "filename": "log/iobroker",
              "fileext": ".log",
              "maxsize": null,
              "maxFiles": null
            "syslog1": {
                      "type":                 "syslog",
                      "enabled":              true,
                      "host":                 "192.168.1.13",
                      "host_comment":         "The host running syslogd, defaults to localhost.",
                      "port_comment":         "The port on the host that syslog is running on, defaults to syslogd's default port(514/UD
      P).",
                      "protocol":             "udp4",
                      "protocol_comment":     "The network protocol to log over (e.g. tcp4, udp4, unix, unix-connect, etc).",
                      "path_comment":         "The path to the syslog dgram socket (i.e. /dev/log or /var/run/syslog for OS X).",
                      "facility_comment":     "Syslog facility to use (Default: local0).",
                      "localhost":            "iobroker",
                      "localhost_comment":    "Host to indicate that log messages are coming from (Default: localhost).",
                      "sysLogType_comment":   "The type of the syslog protocol to use (Default: BSD).",
                      "app_name_comment":     "The name of the application (Default: process.title).",
                      "eol_comment":          "The end of line character to be added to the end of the message (Default: Message without
       modifications)."
      MfG
      Sissi
      1 CCU3 1 CCU2-Gateway 1 LanGateway 1 Pi-Gateway 1 I7 für ioBroker/MySQL
      • sissiwupS Offline
        sissiwupS Offline
        sissiwup
        da fehlte noch was, jetzt gehts bei mir:
              "syslog1": {
                        "type":                 "syslog",
                        "enabled":              true,
                        "port":                 "514",
                        "port_comment":         "The port on the host that syslog is running on, defaults to syslogd's default port(514/UDP).",
                        "protocol":             "udp4",
                        "path":                 "",
                        "eol_comment":          "The end of line character to be added to the end of the message (Default: Message without modifications)."
        MfG
        Sissi
        • sissiwupS Offline
          sissiwupS Offline
          sissiwup
            "syslog1": {
                          "type":                 "syslog",
                          "enabled":              true,
                          "port":                 "514",
                          "pid":                  "0",
                          "protocol":             "udp4",
                          "path":                 "",
          Mit "pid" = 0 erreicht man, das die Prozess-ID nicht mit im Namen geloggt wird, das stört oft beim Filtern.
          MfG
          Sissi
          • sissiwupS Offline
            sissiwupS Offline
            sissiwup
            Kann es sein dass
            process.title nur vom js-controller verwendet wird und nicht von den Adaptern?
            Wie kann ich adapter.appName oder ähnliches übergeben?
            MfG
            Sissi
            • sissiwupS Offline
              sissiwupS Offline
              sissiwup
              das "pid = 0" kann man entfernen wenn man seinen Logging Server beibringt pid und syslogtag zu trennen:
              /etc/rsyslog.d/mysql.conf
              ### Configuration file for rsyslog-mysql
              ### Changes are preserved
              $template dbFormat,"insert into SystemEvents (Message, Facility, FromHost, Priority, DeviceReportedTime, ReceivedAt, InfoUnitID, SysLogTag, processid) values ('%msg%', %syslogfacility%, '%HOSTNAME%
              ', %syslogpriority%, '%timereported:::date-mysql%', '%timegenerated:::date-mysql%', %iut%, '%syslogtag:R,ERE,1,FIELD:([a-zA-Z\/]+)(\[[0-9]{1,5}\])*:--end%', '%syslogtag:R,ERE,1,BLANK:\[([0-9]{1,5})
              \]--end%')",sql
              $ModLoad ommysql
              *.* :ommysql:localhost,Syslog,rsyslog-mysql,PASSWORT;dbFormat
              Mysql-User:
              User: rsyslog-mysql
              Passwort: PASSWORT
              MfG
              Sissi
              • wendy2702W Online
                wendy2702W Online
                Damit ich das richtig verstehe:
                Bedeutet das iobroker.log wird zusätzlich in Linux SYSLOG geschrieben?
                • nieIPN Offline
                  nieIPN Offline
                  nieIP
                  Hallo
                  ich würde das gern morgen mal testen. Wie ist der aktuelle Stand …
                  Muss ich
                   npm install winston-syslog
                  noch ausführen, oder ist das default schon mit installiert?
                  Der Beitrag ist ja schon 2 Jahre alt, daher die Nachfrage.
                    winston-syslog ist ein optionale dep … musst mal schauen ob es installiert ist oder du es manuell machen musst
                    • P Offline
                      pid5be0
                      Moin moin…
                      Da mich das Thema ebenfalls interessiert, wollte ich den Winston-Syslog-Service ebenfalls installieren.
                      Dabei erhielt ich diese Ausgabe. Kann es sein, das ich die Installation nicht von der ROOT des Hosts machen kann?
                      root@debian-iobroker:~# npm install winston-syslog
                      > unix-dgram@0.2.3 install /root/node_modules/unix-dgram
                      > node-gyp rebuild
                      make: Entering directory '/root/node_modules/unix-dgram/build'
                        CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
                        SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
                        COPY Release/unix_dgram.node
                      make: Leaving directory '/root/node_modules/unix-dgram/build'
                      npm WARN saveError ENOENT: no such file or directory, open '/root/package.json'
                      npm notice created a lockfile as package-lock.json. You should commit this file.
                      npm WARN enoent ENOENT: no such file or directory, open '/root/package.json'
                      npm WARN root No description
                      npm WARN root No repository field.
                      npm WARN root No README data
                      npm WARN root No license field.
                      + winston-syslog@2.0.0
                      added 6 packages from 18 contributors and audited 6 packages in 11.999s
                      found 0 vulnerabilities
                      Grüße,
                      Daniel
                      IOBROKER via VM auf QNAP TS453, Unify Network (Switch/WLAN), Hardware Firewall - SIF, Raspberry für Homematic
                      • P Offline
                        pid5be0
                        Habe mal die Installation vom iobroker Verzeichnis gemacht.
                        ` > root@debian-iobroker:/opt/iobroker# npm install winston-syslog
                        • winston-syslog@2.0.0
                        added 1 package from 2 contributors, updated 1 package and audited 4794 packages in 39.864s
                        found 52 vulnerabilities (38 low, 14 high)
                        run npm audit fix to fix them, or npm audit for details
                        root@debian-iobroker:/opt/iobroker# npm audit
                        npm ERR! code ELOCKVERIFY
                        npm ERR! Errors were found in your package-lock.json, run npm install to fix them.
                        npm ERR! Missing: iobroker.flot@^1.9.2
                        npm ERR! Missing: iobroker.fritzbox@^0.2.1
                        npm ERR! Missing: iobroker.geofency@^0.3.2
                        npm ERR! Invalid: lock file's iobroker.hm-rega@2.0.1 does not satisfy iobroker.hm-rega@^2.1.2
                        npm ERR! Invalid: lock file's iobroker.hm-rpc@1.8.3 does not satisfy iobroker.hm-rpc@^1.9.1
                        npm ERR! Invalid: lock file's iobroker.iot@0.2.2 does not satisfy iobroker.iot@^0.3.1
                        npm ERR! Invalid: lock file's iobroker.shelly@2.0.2 does not satisfy iobroker.shelly@^2.0.5
                        npm ERR! Missing: iobroker.simple-api@^2.0.0
                        npm ERR! Missing: iobroker.sql@^1.9.2
                        npm ERR! Invalid: lock file's iobroker.type-detector@0.1.0 does not satisfy iobroker.type-detector@file:node_modules/iobroker.type-detector
                        npm ERR! Missing: iobroker.unifi@^0.3.1
                        npm ERR! Missing: iobroker.web@^2.4.1
                        npm ERR! Invalid: lock file's winston-syslog@1.2.6 does not satisfy winston-syslog@^2.0.0
                        npm ERR! /root/.npm/_logs/2019-01-14T05_26_12_350Z-debug.log `
                        @pid5be0:
                        Moin moin…
                        > node-gyp rebuild
                        Grüße,
                        Daniel `
                          Das sieht erstmal ok aus. Ich weiß nur nicht mehr aus dem Kopf ob die 2.0.0 geht oder ob man aktuell die letzte 1.x von der Winston-syslog nehmen muss.
                          Starte iobroker mal neu und konfiguriere es. Dann siehst du es ja
                          Gesendet vom Handy …
                          • nieIPN Offline
                            nieIPN Offline
                            nieIP
                            Hallo
                            ich habe winston-syslog in /opt/iobroker nach installiert und mich bei der Konfig nach dem obrigen Beispiel gerichtet.
                            Hat sofort funktioniert.
                              MrLee
                              Moin!
                              Genial!!!! Vielen Dank für den Tipp!
                              Kann ich nur jedem empfehlen der eh eine Syno mit ProtokollCenter laufen hat.
                              Installation auf beiden Systemen völlig stressfrei.
                              bis denne
                              Mr.Lee
                              • ScroungerS Offline
                                ScroungerS Offline
                                Scrounger
                                Mir ist gerade aufgefallen das mein syslog server die 'warn' Meldungen von ioBroker nicht mitbekommt.
                                Alle anderen severity levels gehen.
                                Kann das daran liegen weil der server das level 'Warning' erwartet?
                                Gibt es eine config Möglichkeit das iobrker aus 'warn' level 'warning' macht?
                                • ScroungerS Scrounger
                                  Kueppert
                                  @scrounger hast du hierzu eine Lösung gefunden? Ich hab auch ne SYNO und würde gern starten, das LOG entsprechend bei mir im Protokoll-Server mit aufzuzeichnen.
                                  Danke dir und vG, Thorsten
                                  ScroungerS 1 Antwort Letzte Antwort
                                  • K Kueppert
                                    ScroungerS Offline
                                    ScroungerS Offline
                                    Scrounger
                                    @kueppert
                                    Ne hab leider keine Lösung dafür gefunden.
                                      @kueppert
                                      Aiouh
                                      schrieb am zuletzt editiert von Aiouh
                                      Ist zwar schon alt der Fred, aber ich denke SysLog ist nach wie vor für den ein oder Anderen von Interesse, also fasse ich das mal zusammen.
                                      Ich logge alle Syslogs meiner Systeme auf einem Synology NAS mit LogCenter, daher wollte ich den ioBroker auch dort mit drin sehen.
                                      Das waren bei mir die dazu erforderlichen Schritte:
                                      sudo npm install winston-syslog
                                      dann
                                      sudo nano /opt/iobroker/iobroker-data/iobroker.json
                                      In der Datei die Zeilen 4 und 5 entsprechend mit "true" und der IP eures Syslog Servers anpassen und die Zeilen 7 und 9 einfügen
                                            "syslog1": {
                                              "type": "syslog",
                                              "enabled": true,
                                              "host": "192.168.178.85",
                                              "hostComment": "The host running syslogd, defaults to localhost.",
                                              "port":        "514",
                                              "portComment": "The port on the host that syslog is running on, default$
                                              "pid":         "0",
                                              "protocol":    "udp4",
                                              "protocolComment": "The network protocol to log over (e.g. tcp4, udp4, $
                                              "pathComment": "The path to the syslog dgram socket (i.e. /dev/log or /$
                                              "facilityComment": "Syslog facility to use (Default: local0).",
                                              "localhostComment": "Host to indicate that log messages are coming from$
                                              "sysLogTypeComment": "The type of the syslog protocol to use (Default: $
                                              "app_nameComment": "The name of the application (Default: process.title$
                                              "eolComment": "The end of line character to be added to the end of the $
                                      Im Synololgy NAS LogCenter, "Achive Settings" setzen
                                      und unter "Log Receiving" eine Regel anlegen,
                                      Den ioBroker neu starten
                                      iobroker restart
                                      Das war es schon, das LogCenter in der Syno bekommt jetzt die Meldungen vom iobroker, auch die Warnungen
                                      @apollon77 weisst Du ob damit das gesamte logging vom ioBroker auf den syslog server verschoben wird, oder ist das syslog quasi doppelt, d.h. der ioBroker logged selbst immern noch auch lokal?
                                      • A Aiouh
                                        dann
                                              "syslog1": {
                                                "type": "syslog",
                                                "enabled": true,
                                                "port":        "514",
                                                "pid":         "0",
                                                "protocol":    "udp4",
                                        iobroker restart
                                        @aiouh also das npm install von Winston-syslog hätte an sich nicht nötig sein sollen und du hast jetzt ein extraneous Paket. Sollte jetzt aber kein Beinbruch sein.
                                        Sonst schau ins iobroker.json. Da ist definiert welches logging aktiv ist. Wenn du unter log bei „file“ nichts geändert hast loggt er jetzt beides. Im zweifel kannst du file noch ausschalten.
                                        Ansonsten geht die konfig inzwischen auch per Admin unter „hosts“. Da muss keiner mehr ans json file. Aber es geht beides.
                                        • apollon77A apollon77
                                          Aiouh
                                          @apollon77 Ok danke, wieder was gelernt.
