  4. Iobroker Logging zu syslog
26 Beiträge 11 Kommentatoren 8.2k Aufrufe 4 Beobachtet
  • P Offline
    pid5be0
    Habe mal die Installation vom iobroker Verzeichnis gemacht.
    ` > root@debian-iobroker:/opt/iobroker# npm install winston-syslog
    • winston-syslog@2.0.0
    added 1 package from 2 contributors, updated 1 package and audited 4794 packages in 39.864s
    found 52 vulnerabilities (38 low, 14 high)
    run npm audit fix to fix them, or npm audit for details
    root@debian-iobroker:/opt/iobroker# npm audit
    npm ERR! code ELOCKVERIFY
    npm ERR! Errors were found in your package-lock.json, run npm install to fix them.
    npm ERR! Missing: iobroker.flot@^1.9.2
    npm ERR! Missing: iobroker.fritzbox@^0.2.1
    npm ERR! Missing: iobroker.geofency@^0.3.2
    npm ERR! Invalid: lock file's iobroker.hm-rega@2.0.1 does not satisfy iobroker.hm-rega@^2.1.2
    npm ERR! Invalid: lock file's iobroker.hm-rpc@1.8.3 does not satisfy iobroker.hm-rpc@^1.9.1
    npm ERR! Invalid: lock file's iobroker.iot@0.2.2 does not satisfy iobroker.iot@^0.3.1
    npm ERR! Invalid: lock file's iobroker.shelly@2.0.2 does not satisfy iobroker.shelly@^2.0.5
    npm ERR! Missing: iobroker.simple-api@^2.0.0
    npm ERR! Missing: iobroker.sql@^1.9.2
    npm ERR! Invalid: lock file's iobroker.type-detector@0.1.0 does not satisfy iobroker.type-detector@file:node_modules/iobroker.type-detector
    npm ERR! Missing: iobroker.unifi@^0.3.1
    npm ERR! Missing: iobroker.web@^2.4.1
    npm ERR! Invalid: lock file's winston-syslog@1.2.6 does not satisfy winston-syslog@^2.0.0
    npm ERR! /root/.npm/_logs/2019-01-14T05_26_12_350Z-debug.log `
    @pid5be0:
    Moin moin…
    Da mich das Thema ebenfalls interessiert, wollte ich den Winston-Syslog-Service ebenfalls installieren.
    Dabei erhielt ich diese Ausgabe. Kann es sein, das ich die Installation nicht von der ROOT des Hosts machen kann?
    root@debian-iobroker:~# npm install winston-syslog
    > unix-dgram@0.2.3 install /root/node_modules/unix-dgram
    > node-gyp rebuild
    make: Entering directory '/root/node_modules/unix-dgram/build'
      CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
      SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
      COPY Release/unix_dgram.node
    make: Leaving directory '/root/node_modules/unix-dgram/build'
    npm WARN saveError ENOENT: no such file or directory, open '/root/package.json'
    npm notice created a lockfile as package-lock.json. You should commit this file.
    npm WARN enoent ENOENT: no such file or directory, open '/root/package.json'
    npm WARN root No description
    npm WARN root No repository field.
    npm WARN root No README data
    npm WARN root No license field.
    + winston-syslog@2.0.0
    added 6 packages from 18 contributors and audited 6 packages in 11.999s
    found 0 vulnerabilities
    Grüße,
    Daniel `
    IOBROKER via VM auf QNAP TS453, Unify Network (Switch/WLAN), Hardware Firewall - SIF, Raspberry für Homematic
    • apollon77A Offline
      Das sieht erstmal ok aus. Ich weiß nur nicht mehr aus dem Kopf ob die 2.0.0 geht oder ob man aktuell die letzte 1.x von der Winston-syslog nehmen muss.
      Starte iobroker mal neu und konfiguriere es. Dann siehst du es ja
      Gesendet vom Handy …
      • nieIPN Offline
        nieIPN Offline
        nieIP
        Hallo
        ich habe winston-syslog in /opt/iobroker nach installiert und mich bei der Konfig nach dem obrigen Beispiel gerichtet.
        Hat sofort funktioniert.
          MrLee
          Moin!
          Genial!!!! Vielen Dank für den Tipp!
          Kann ich nur jedem empfehlen der eh eine Syno mit ProtokollCenter laufen hat.
          Installation auf beiden Systemen völlig stressfrei.
          bis denne
          Mr.Lee
          • ScroungerS Offline
            ScroungerS Offline
            Scrounger
            Mir ist gerade aufgefallen das mein syslog server die 'warn' Meldungen von ioBroker nicht mitbekommt.
            Alle anderen severity levels gehen.
            Kann das daran liegen weil der server das level 'Warning' erwartet?
            Gibt es eine config Möglichkeit das iobrker aus 'warn' level 'warning' macht?
            • ScroungerS Scrounger
              Kueppert
              @scrounger hast du hierzu eine Lösung gefunden? Ich hab auch ne SYNO und würde gern starten, das LOG entsprechend bei mir im Protokoll-Server mit aufzuzeichnen.
              Danke dir und vG, Thorsten
              ScroungerS 1 Antwort Letzte Antwort
              • K Kueppert
                ScroungerS Offline
                ScroungerS Offline
                Scrounger
                @kueppert
                Ne hab leider keine Lösung dafür gefunden.
                  @kueppert
                  Aiouh
                  schrieb am zuletzt editiert von Aiouh
                  Ist zwar schon alt der Fred, aber ich denke SysLog ist nach wie vor für den ein oder Anderen von Interesse, also fasse ich das mal zusammen.
                  Ich logge alle Syslogs meiner Systeme auf einem Synology NAS mit LogCenter, daher wollte ich den ioBroker auch dort mit drin sehen.
                  Das waren bei mir die dazu erforderlichen Schritte:
                  sudo npm install winston-syslog
                  dann
                  sudo nano /opt/iobroker/iobroker-data/iobroker.json
                  In der Datei die Zeilen 4 und 5 entsprechend mit "true" und der IP eures Syslog Servers anpassen und die Zeilen 7 und 9 einfügen
                        "syslog1": {
                          "type": "syslog",
                          "enabled": true,
                          "host": "192.168.178.85",
                          "hostComment": "The host running syslogd, defaults to localhost.",
                          "port":        "514",
                          "portComment": "The port on the host that syslog is running on, default$
                          "pid":         "0",
                          "protocol":    "udp4",
                          "protocolComment": "The network protocol to log over (e.g. tcp4, udp4, $
                          "pathComment": "The path to the syslog dgram socket (i.e. /dev/log or /$
                          "facilityComment": "Syslog facility to use (Default: local0).",
                          "localhost": "iobroker",
                          "localhostComment": "Host to indicate that log messages are coming from$
                          "sysLogTypeComment": "The type of the syslog protocol to use (Default: $
                          "app_nameComment": "The name of the application (Default: process.title$
                          "eolComment": "The end of line character to be added to the end of the $
                  Im Synololgy NAS LogCenter, "Achive Settings" setzen
                  und unter "Log Receiving" eine Regel anlegen,
                  Den ioBroker neu starten
                  iobroker restart
                  Das war es schon, das LogCenter in der Syno bekommt jetzt die Meldungen vom iobroker, auch die Warnungen
                  @apollon77 weisst Du ob damit das gesamte logging vom ioBroker auf den syslog server verschoben wird, oder ist das syslog quasi doppelt, d.h. der ioBroker logged selbst immern noch auch lokal?
                  • A Aiouh
                    dann
                          "syslog1": {
                            "type": "syslog",
                            "enabled": true,
                            "port":        "514",
                            "pid":         "0",
                            "protocol":    "udp4",
                    iobroker restart
                    @aiouh also das npm install von Winston-syslog hätte an sich nicht nötig sein sollen und du hast jetzt ein extraneous Paket. Sollte jetzt aber kein Beinbruch sein.
                    Sonst schau ins iobroker.json. Da ist definiert welches logging aktiv ist. Wenn du unter log bei „file“ nichts geändert hast loggt er jetzt beides. Im zweifel kannst du file noch ausschalten.
                    Ansonsten geht die konfig inzwischen auch per Admin unter „hosts“. Da muss keiner mehr ans json file. Aber es geht beides.
                    • apollon77A apollon77
                      Aiouh
                      @apollon77 Ok danke, wieder was gelernt.
