  4. [Aufruf] ZigBee CC253x Adapter
1.1k Beiträge 131 Kommentatoren 488.7k Aufrufe 7 Beobachtet
  • L Offline
    LJSven
    #822
    Was mache ich falsch - habe das Device gerade nochmal neu angelernt - trotzdem geht es nicht. Es lässt sich schalten, aber die Fehlermeldung tritt immer auf.
    ! 2018-12-23 09:23:24.285 - error: zigbee.0 Zigbee publish to '0x7cb03eaa00b2249d', genOnOff - read - [{"attrId":0}] - 3 failed with error Error: AF data request fails, status code: 233. MAC no ack.
    ! 2018-12-23 09:23:30.046 - error: zigbee.0 Zigbee publish to '0x7cb03eaa00b2249d', genOnOff - read - [{"attrId":0}] - 3 failed with error Error: AF data request fails, status code: 233. MAC no ack.
    ! 2018-12-23 09:23:30.078 - error: zigbee.0 Zigbee publish to '0x7cb03eaa00b2249d', genOnOff - on - {} - 3 failed with error Error: AF data request fails, status code: 233. MAC no ack.
    ! 2018-12-23 09:23:33.441 - error: zigbee.0 Zigbee publish to '0x7cb03eaa00b2249d', genOnOff - read - [{"attrId":0}] - 3 failed with error Error: AF data request fails, status code: 183. APS no ack.
    ! 2018-12-23 09:23:37.653 - error: zigbee.0 Zigbee publish to '0x7cb03eaa00b2249d', genOnOff - off - {} - 3 failed with error Error: AF data request fails, status code: 233. MAC no ack.
    ! 2018-12-23 09:23:46.087 - error: zigbee.0 Zigbee publish to '0x7cb03eaa00b2249d', genOnOff - on - {} - 3 failed with error Error: AF data request fails, status code: 233. MAC no ack.
    ! 2018-12-23 09:23:47.925 - error: zigbee.0 Zigbee publish to '0x7cb03eaa00b2249d', genOnOff - off - {} - 3 failed with error Error: Timed out after 30000 ms
    ! 2018-12-23 09:24:03.566 - error: zigbee.0 Zigbee publish to '0x7cb03eaa00b2249d', genOnOff - read - [{"attrId":0}] - 3 failed with error Error: Timed out after 30000 ms
    ! 2018-12-23 09:24:07.303 - error: zigbee.0 Zigbee publish to '0x7cb03eaa00b2249d', genOnOff - read - [{"attrId":0}] - 3 failed with error Error: Timed out after 30000 ms
    ! 2018-12-23 09:24:08.936 - error: zigbee.0 Zigbee publish to '0x7cb03eaa00b2249d', genOnOff - read - [{"attrId":0}] - 3 failed with error Error: Timed out after 30000 ms
    • arteckA Offline
      arteckA Offline
      arteck
      #823
      bin gerade auch wach.. kommst kurz ins TS
      • L Offline
        LJSven
        #824
        @arteck:
        bin gerade auch wach.. kommst kurz ins TS `
        Was ist das? Geht so in 30 Minuten?
        • arteckA Offline
          arteckA Offline
          arteck
          #825
          joa… ich hol mir nen kaff....
          teamspeak
          hier die Daten
          Teamspeak : Smarthome.Teamspeak.de oder 62.104.20.86:10038
          • L Offline
            LJSven
            #826
            Ich nochmal - habe jetzt mal die beiden Plugs getauscht - das gleiche Problem, wenn ich die Geräte über die VIS / Blockly steuere:
            ! 2018-12-23 12:46:26.813 - error: zigbee.0 Zigbee publish to '0x84182600000fa6d0', genOnOff - on - {} - 3 failed with error Error: AF data request fails, status code: 205. No network route. Please confirm that the device has (re)joined the network.
            ! 2018-12-23 12:46:26.870 - error: zigbee.0 Zigbee publish to '0x84182600000fa6d0', genOnOff - read - [{"attrId":0}] - 3 failed with error Error: AF data request fails, status code: 205. No network route. Please confirm that the device has (re)joined the network.
            ! 2018-12-23 12:46:44.297 - error: zigbee.0 Zigbee publish to '0x84182600000fa6d0', genOnOff - off - {} - 3 failed with error Error: AF data request fails, status code: 205. No network route. Please confirm that the device has (re)joined the network.
            ! 2018-12-23 12:46:44.517 - error: zigbee.0 Zigbee publish to '0x84182600000fa6d0', genOnOff - read - [{"attrId":0}] - 3 failed with error Error: AF data request fails, status code: 205. No network route. Please confirm that the device has (re)joined the network.
            ! 2018-12-23 12:46:48.313 - error: zigbee.0 Zigbee publish to '0x84182600000fa6d0', genOnOff - on - {} - 3 failed with error Error: AF data request fails, status code: 205. No network route. Please confirm that the device has (re)joined the network.
            ! 2018-12-23 12:46:48.360 - error: zigbee.0 Zigbee publish to '0x84182600000fa6d0', genOnOff - read - [{"attrId":0}] - 3 failed with error Error: AF data request fails, status code: 205. No network route. Please confirm that the device has (re)joined the network.
            Gibt es noch eine andere Idee?
              mismk
              #827
              Hallo, ich habe eine Frage, welche hier schon einmal aufgekommen ist.
              Ist es möglich die IKEA Floalt parallel über den 2531-Stick und über die Ikea-FB zu steuern?
              Ich bekomme es irgendwie nicht hin. Das Panel lässt sich nach Reset problemlos in Iobroker einbinden und
              ich habe eine stabile Verbindung. Wenn ich nun aber die IKEA-FB mit der Lampe verbinde, dann geht die Verbindungsanzeige im Adapter auf 0
              und ich kann das Panel auch nicht mehr steuern.
              • L Offline
                LJSven
                #828
                Ich habe jetzt mal beide Plugs im Umkreis von 1-3 Metern - trotzdem bleibt das Problem beim schalten. Ich bin echt am verzweifeln - kann es auch am Stick liegen? Was bedeuten die beiden Button auf dem Stick? Wenn ich den Adapter deaktiviere, kommen folgende Einträge - kann man daraus was erkennen?
                ! 2018-12-23 15:19:41.826 - info: host.bananapimaster stopInstance system.adapter.zigbee.0 killing pid 24713
                ! 2018-12-23 15:19:41.962 - error: Caught by controller[1]: Sun, 23 Dec 2018 14:19:13 GMT zigbee-shepherd:request REQ –> ZDO:mgmtLqiReq
                ! 2018-12-23 15:19:41.963 - error: Caught by controller[2]: Sun, 23 Dec 2018 14:19:13 GMT cc-znp:SREQ –> ZDO:mgmtLqiReq, { dstaddr: 0, scanchannels: undefined, scanduration: undefined, startindex: 0 }
                ! 2018-12-23 15:19:41.964 - error: Caught by controller[3]: Sun, 23 Dec 2018 14:19:13 GMT cc-znp:SRSP <– ZDO:mgmtLqiReq, { status: 0 }
                ! 2018-12-23 15:19:41.964 - error: Caught by controller[4]: Sun, 23 Dec 2018 14:19:13 GMT cc-znp:AREQ <– ZDO:mgmtLqiRsp, { srcaddr: 0, status: 0, neighbortableentries: 5, startindex: 0, neighborlqilistcount: 3, neighborlqilist: [ { extPandId: '0xdddddddddddddddd', extAddr: '0x7cb03eaa00b2249d', nwkAddr: 41663, deviceType: 1, rxOnWhenIdle: 1, relationship: 1, permitJoin: 2, depth: 1, lqi: 37 }, { extPandId: '0xdddddddddddddddd', extAddr: '0x00158d000233f838', nwkAddr: 15965, deviceType: 2, rxOnWhenIdle: 0, relationship: 1, permitJoin: 2, depth: 1, lqi: 124 }, { extPandId: '0xdddddddddddddddd', extAddr: '0x84182600000fa6d0', nwkAddr: 55124, deviceType: 1, rxOnWhenIdle: 2, relationship: 3, permitJoin: 2, depth: 255, lqi: 55 } ] }
                ! 2018-12-23 15:19:41.965 - error: Caught by controller[5]: Sun, 23 Dec 2018 14:19:13 GMT zigbee-shepherd:msgHdlr IND <– ZDO:mgmtLqiRsp
                ! 2018-12-23 15:19:41.965 - error: Caught by controller[6]: Sun, 23 Dec 2018 14:19:13 GMT cc-znp:SREQ –> ZDO:mgmtLqiReq, { dstaddr: 0, scanchannels: undefined, scanduration: undefined, startindex: 3 }
                ! 2018-12-23 15:19:41.966 - error: Caught by controller[7]: Sun, 23 Dec 2018 14:19:13 GMT cc-znp:SRSP <– ZDO:mgmtLqiReq, { status: 0 }
                ! 2018-12-23 15:19:41.966 - error: Caught by controller[8]: Sun, 23 Dec 2018 14:19:13 GMT cc-znp:AREQ <– ZDO:mgmtLqiRsp, { srcaddr: 0, status: 0, neighbortableentries: 5, startindex: 3, neighborlqilistcount: 2, neighborlqilist: [ { extPandId: '0xdddddddddddddddd', extAddr: '0x0000000000000000', nwkAddr: 58470, deviceType: 1, rxOnWhenIdle: 2, relationship: 3, permitJoin: 2, depth: 255, lqi: 0 }, { extPandId: '0xdddddddddddddddd', extAddr: '0x0000000000000000', nwkAddr: 33448, deviceType: 1, rxOnWhenIdle: 2, relationship: 3, permitJoin: 2, depth: 255, lqi: 28 } ] }
                ! 2018-12-23 15:19:41.967 - error: Caught by controller[8]: Sun, 23 Dec 2018 14:19:13 GMT zigbee-shepherd:msgHdlr IND <– ZDO:mgmtLqiRsp
                ! 2018-12-23 15:19:41.967 - error: Caught by controller[8]: Sun, 23 Dec 2018 14:19:13 GMT zigbee-shepherd:request REQ –> ZDO:mgmtLqiReq
                ! 2018-12-23 15:19:41.968 - error: Caught by controller[9]: Sun, 23 Dec 2018 14:19:13 GMT cc-znp:SREQ –> ZDO:mgmtLqiReq, { dstaddr: 41663, scanchannels: undefined, scanduration: undefined, startindex: 0 }
                ! 2018-12-23 15:19:41.969 - error: Caught by controller[10]: Sun, 23 Dec 2018 14:19:13 GMT cc-znp:SRSP <– ZDO:mgmtLqiReq, { status: 0 }
                ! 2018-12-23 15:19:41.969 - error: Caught by controller[11]: 2018-12-23T14:19:16.939Z zigbee:controller debug lqiScan result: [ { ieeeAddr: '0x7cb03eaa00b2249d',
                ! 2018-12-23 15:19:41.970 - error: Caught by controller[11]: nwkAddr: 41663,
                ! 2018-12-23 15:19:41.971 - error: Caught by controller[11]: lqi: 37,
                ! 2018-12-23 15:19:41.971 - error: Caught by controller[11]: depth: 1,
                ! 2018-12-23 15:19:41.972 - error: Caught by controller[11]: deviceType: 1,
                ! 2018-12-23 15:19:41.973 - error: Caught by controller[11]: parent: '0x00124b0014d9e2d6',
                ! 2018-12-23 15:19:41.973 - error: Caught by controller[11]: status: 'offline' },
                ! 2018-12-23 15:19:41.974 - error: Caught by controller[11]: { ieeeAddr: '0x00158d000233f838',
                ! 2018-12-23 15:19:41.974 - error: Caught by controller[11]: nwkAddr: 15965,
                ! 2018-12-23 15:19:41.975 - error: Caught by controller[11]: lqi: 124,
                ! 2018-12-23 15:19:41.975 - error: Caught by controller[11]: depth: 1,
                ! 2018-12-23 15:19:41.976 - error: Caught by controller[11]: deviceType: 2,
                ! 2018-12-23 15:19:41.976 - error: Caught by controller[11]: parent: '0x00124b0014d9e2d6',
                ! 2018-12-23 15:19:41.977 - error: Caught by controller[11]: status: 'online' },
                ! 2018-12-23 15:19:41.978 - error: Caught by controller[11]: { ieeeAddr: '0x84182600000fa6d0',
                ! 2018-12-23 15:19:41.978 - error: Caught by controller[11]: nwkAddr: 55124,
                ! 2018-12-23 15:19:41.978 - error: Caught by controller[11]: lqi: 55,
                ! 2018-12-23 15:19:41.979 - error: Caught by controller[11]: depth: 255,
                ! 2018-12-23 15:19:41.979 - error: Caught by controller[11]: deviceType: 1,
                ! 2018-12-23 15:19:41.980 - error: Caught by controller[11]: parent: '0x00124b0014d9e2d6',
                ! 2018-12-23 15:19:41.980 - error: Caught by controller[11]: status: 'offline' } ]
                ! 2018-12-23 15:19:41.981 - error: Caught by controller[12]: Sun, 23 Dec 2018 14:19:41 GMT zigbee-shepherd zigbee-shepherd is stopping.
                ! 2018-12-23 15:19:41.981 - error: Caught by controller[13]: Sun, 23 Dec 2018 14:19:41 GMT zigbee-shepherd:request REQ –> ZDO:mgmtPermitJoinReq
                ! 2018-12-23 15:19:41.982 - error: Caught by controller[13]: Sun, 23 Dec 2018 14:19:41 GMT cc-znp:SREQ –> ZDO:mgmtPermitJoinReq, { addrmode: 15, dstaddr: 65532, duration: 0, tcsignificance: 0 }
                ! 2018-12-23 15:19:41.982 - info: host.bananapimaster instance system.adapter.zigbee.0 terminated with code 0 (OK)
                Sorry, für die vielen Fragen - ich hätte es gern wieder reibungslos am laufen.
                • arteckA Offline
                  arteckA Offline
                  arteck
                  #829
                  @LJSven:
                  Gibt es noch eine andere Idee? `
                  es ist immer die eine Dose… tausch die um.. wie ich schon im TS sagte.. kann sein dass die einen Weg hat
                  • arteckA Offline
                    arteckA Offline
                    arteck
                    #830
                    @mismk:
                    und ich kann das Panel auch nicht mehr steuern. `
                    nein es ist immer eine Exlusiv Verbindung…
                    • L Offline
                      LJSven
                      #831
                      @arteck:
                      @LJSven:
                      es ist immer die eine Dose… tausch die um.. wie ich schon im TS sagte.. kann sein dass die einen Weg hat `
                      Nein, sind beide Dosen.
                      • arteckA Offline
                        arteckA Offline
                        arteck
                        #832
                        dann stell mal den..was wars rock oder banana woanders hin… also irgndwas an der Hardware/Aufstellung musst du ändern..
                        • L Offline
                          LJSven
                          #833
                          @arteck:
                          dann stell mal den..was wars rock oder banana woanders hin… also irgndwas an der Hardware/Aufstellung musst du ändern.. `
                          Okay, das die Link Quality über 30 bei beiden ist, ist in diesem Fall egal?
                            donderda
                            #834
                            Habe das gleiche Problem mit den Osram Plugs temporär so gelöst: Alle 10 Sekunden für 2 Minuten lasse ich die schalten. Mehr so der Brute-force ansatz, funktioniert aber… Dann funktioniert das zumindest für die Weihnachtsbeleuchtung. Aber irgendwie ist das echt nervig...
                            • L Offline
                              ltsalvatore
                              #835
                              @arteck:
                              den Objekten kannst du mehr vertrauen…
                              hier wird die link_quality jedesmal beim schalten aktualisiert
                              lerne doch mal die plugs nochmal alle an dem weichnachtsmann_groß plug an `
                              hm.. bist du dir da ganz sicher..
                              gerade habe ich den aqara switch an den "weichnachtsmann_groß plug" angelernt, welcher 30cm vom zigbee adapter entfernt ist, und der aqara switch ist nur 15cm vom osram plug entfernt, und dennoch
                              die link quality des aqara switch ist bei max. 5
                              und der aqara switch schaltet ohne zu meckern. von 20 schalt versuchen sind 20 problemlos durchgegangen.
                              und bei anderen geräten, wo die link quality auf über 50 ist, ist das gegenteil der fall. mal geht's mal nicht…
                              jetzt kann man weder der map noch den werten glauben schenken.
                              dann kommt noch hinzu, dass man irgendwann auch den überblick verloren hat, welches gerät wo angelernt wurde...
                              und von dem anlernen von geräten wollen wir am besten erst garnicht reden.. da hat man ja fast mehr glück beim lotto spielen...
                              das ist jetzt wirklich nicht bös gemeint und ich habe auch respekt vor eurer arbeit.
                              im großen und ganzen macht das ganze thema smart home ja auch weiterhin viel spaß, aber offen gestanden vergeht mir langsam etwas die lust an diesem adapter...
                              gefühlt wird es immer komplizierter und unverständlicher je mehr man sich mit dem adapter beschäftigt. eigentlich sollte es doch umgekehrt sein.
                              bitte das jetzt auch nicht falsch verstehen, aber gibt es eine alternative zu diesem universal zigbee stick und adapter.
                              am liebsten würde ich ja die xiaomi gateway mit dem entsprechenden adapter benutzen denn da funktioniert bis jetzt alles was ich angeschlossen habe (die aqara tür sensoren und der cube) seit einrichtung 100% tadellos.
                              jedoch werden ja osram plugs nicht erkannt/unterstützt.
                              nochmals, es macht spaß und man lernt dadurch einiges dazu und selbstverständlich muss man auch viel zeit investieren, doch irgendwann will man sich gerne auch anderen smart home projekten widmen, dann ist so ein adapter, der bis jetzt alles andere als stabil läuft und nur probleme verursacht echt frustrierend.
                              EDIT:
                              Das ist im Übrigen das ergebnis, wenn man sich denkt, ok.. gibt dem ganzen nochmal ne chance, fang mal bei null an und lerne die geräte so an wie dir vorgeschlagen wurde..
                              das ganze log ist jetzt voll damit und funktioniert jetzt beschissener als vorher. :roll:
                                Masteryotta
                                #836
                                Hallo, ich hatte am Anfang Probleme gleichzeitig die Tradfri Fernbedienung (Remote Control) und den Adapter zu nutzen. Ich habe eine Tradfri E27 980 lm und eine Tradfri E14 400 lm.
                                Folgende Reihenfolge zum paaren hat denn geklappt:
                                Tradfri RC mit Stick paaren (Reset RC 4mal hinterer Knopf drucken, 10cm max Entfernung), Adapter wird zwar erkannt, ist aber noch nicht programmiert > ok
                                Stick mit Tradfri Birne paaren (6 mal an und aus, 10cm max Entfernung), Birne wird erkannt und kann auch gesteuert werden.
                                Denn erst die RC mit die Birne paaren (hinterer Knopf 10 sec drücken, 10cm max Entfernung).
                                In ioBroker geht dann das an/aus, Dimmen und auch Farbwechsel aber auf der Fernbedienung geht nur noch das an/aus und Dimmen, die Farbe bleibt immer gleich und kann nur noch in iobroker gewechselt werden.
                                Fehler weil die Fernbedienung noch nicht voll unterstützt ist?
                                  denjo
                                  #837
                                  @arteck:
                                  @Pocky:
                                  Sorry @ arteck
                                  Wie soll ich das denn machen?
                                  Mit welchen Objekten?
                                  Aus dem Zigbee Adapter? Das geht nicht.
                                  Welche Objekte soll ich anlegen? `
                                  so mein kleiner Padawan ;)
                                  ersmal lösche die Birne aus dem Cloud Adapter ..dann aus Alexa App..
                                  zigbee Objekte auf und die Lampe/Birne was du steuern willst
                                  bei jedem Datenpunkt muss du das machen mit der gleichen Bezeichnung
                                  dann
                                  "smartName": {
                                        "de": "bürolampe",
                                        "smartType": "LIGHT"
                                  eintragen .. achte auf die Formatierung und , nicht vergessen
                                  dann müsstest du die auch im Cloud adapter sehen
                                  jetzt noch nach neuen Geräten suchen in der Alexa App `
                                  Hallo, habe es so gemacht wie du geschrieben hast.
                                  habe auch alle werte in der Cloud drin aber kann keine farben mit alexa steuern, kannst du mir da helfen?
                                  ich sage zb: Alexa, Philips Go Blau
                                  und dann kommt: Gerät unterstützt das nicht
                                  • arteckA Offline
                                    arteckA Offline
                                    arteck
                                    #838
                                    @denjo:
                                    @arteck:
                                    @Pocky:
                                    Sorry @ arteck
                                    dann
                                    "smartName": {
                                          "de": "bürolampe",
                                    und dann kommt: Gerät unterstützt das nicht `
                                    du musst den block an jedes Datenpunkt hängen.. wobei ich seh gerade.. bei mir macht der das auch nicht..
                                    wasisendalos???
                                      denjo
                                      #839
                                      @arteck:
                                      @denjo:
                                      @arteck:
                                      dann
                                      "smartName": {
                                            "de": "bürolampe",
                                      du musst den block an jedes Datenpunkt hängen.. `
                                      habe ich gemacht, in der alexa app steht auch bei Farbeinstellungen KEINE
                                      • arteckA Offline
                                        arteckA Offline
                                        arteck
                                        #840
                                        @ltsalvatore:
                                        @arteck:
                                        EDIT:
                                        Screenshot_2018.12.24_00_01_21_001.jpg `
                                        was soll ich dazu sagen… bei mir läufts und das mit nicht wenig geräten und bunt gemischt von Xiaomi, Hue, Osram, und Tradfri
                                        bei anderen läufts auch.. ich könnte jetzt die Glaskugel aus dem Keller holen nachschauen warum es bei dir so viele Probleme bereitet.. Es ist halt Technick ich würde nicht sagen Experimentell aber es trift zu... man muss sich mit beschäftigen.. die Gegebenheiten sind bei jedem einzelnen besonders.. bei einem läufts direkt bei anderem wiederrum nicht weil .. ja weil..
                                        nicht falsch verstehen : wenn es dir nicht passt dann wechsel auf was anderes oder verbinde mehrere Sachen miteinander (iobroker macht ja sooooooo vieles mit) so das du eine Umgebung hast die dir gefällt bzw. die funktioniert..
                                        ich betreibe das Netzwerk schon seit mahr als einem Jahr.. ich kenne die Probleme (wie nicht funktionierende Plugs die das ganze Netz lahmlegen oder Firmware die nicht mitmacht) und auch relativ viele Lösungen aber nichts desto trotz sind manche Umstände so besonders dass ich keine Lösung habe( fuck das hab ich echt gesagt ;) )
                                        ich biete jedem der ein Problem hat sich mit mir im TS zu treffen und das Thema zu behandeln.. man muss es nur tun..
                                        • arteckA Offline
                                          arteckA Offline
                                          arteck
                                          #841
                                          @denjo:
                                          @arteck:
                                          @denjo:
                                          habe ich gemacht, in der alexa app steht auch bei Farbeinstellungen KEINE `
                                          jo hab ich auch… zur Zeit keine Idee.. muss ich mir mal anschauen.. ich tippe auf den Cloud Adapter oder ion.. der nimmt den State colour nicht mit
