  4. [Aufruf] ZigBee CC253x Adapter
1.1k Beiträge 131 Kommentatoren 488.7k Aufrufe 7 Beobachtet
  • arteckA Offline
    arteckA Offline
    arteck
    #829
    @LJSven:
    Ich nochmal - habe jetzt mal die beiden Plugs getauscht - das gleiche Problem, wenn ich die Geräte über die VIS / Blockly steuere:
    ! 2018-12-23 12:46:26.813 - error: zigbee.0 Zigbee publish to '0x84182600000fa6d0', genOnOff - on - {} - 3 failed with error Error: AF data request fails, status code: 205. No network route. Please confirm that the device has (re)joined the network.
    ! 2018-12-23 12:46:26.870 - error: zigbee.0 Zigbee publish to '0x84182600000fa6d0', genOnOff - read - [{"attrId":0}] - 3 failed with error Error: AF data request fails, status code: 205. No network route. Please confirm that the device has (re)joined the network.
    ! 2018-12-23 12:46:44.297 - error: zigbee.0 Zigbee publish to '0x84182600000fa6d0', genOnOff - off - {} - 3 failed with error Error: AF data request fails, status code: 205. No network route. Please confirm that the device has (re)joined the network.
    ! 2018-12-23 12:46:44.517 - error: zigbee.0 Zigbee publish to '0x84182600000fa6d0', genOnOff - read - [{"attrId":0}] - 3 failed with error Error: AF data request fails, status code: 205. No network route. Please confirm that the device has (re)joined the network.
    ! 2018-12-23 12:46:48.313 - error: zigbee.0 Zigbee publish to '0x84182600000fa6d0', genOnOff - on - {} - 3 failed with error Error: AF data request fails, status code: 205. No network route. Please confirm that the device has (re)joined the network.
    ! 2018-12-23 12:46:48.360 - error: zigbee.0 Zigbee publish to '0x84182600000fa6d0', genOnOff - read - [{"attrId":0}] - 3 failed with error Error: AF data request fails, status code: 205. No network route. Please confirm that the device has (re)joined the network.
    Gibt es noch eine andere Idee? `
    es ist immer die eine Dose… tausch die um.. wie ich schon im TS sagte.. kann sein dass die einen Weg hat
    • arteckA Offline
      arteckA Offline
      arteck
      #830
      @mismk:
      Hallo, ich habe eine Frage, welche hier schon einmal aufgekommen ist.
      Ist es möglich die IKEA Floalt parallel über den 2531-Stick und über die Ikea-FB zu steuern?
      Ich bekomme es irgendwie nicht hin. Das Panel lässt sich nach Reset problemlos in Iobroker einbinden und
      ich habe eine stabile Verbindung. Wenn ich nun aber die IKEA-FB mit der Lampe verbinde, dann geht die Verbindungsanzeige im Adapter auf 0
      und ich kann das Panel auch nicht mehr steuern. `
      nein es ist immer eine Exlusiv Verbindung…
      • L Offline
        LJSven
        #831
        @arteck:
        @LJSven:
        es ist immer die eine Dose… tausch die um.. wie ich schon im TS sagte.. kann sein dass die einen Weg hat `
        Nein, sind beide Dosen.
        • arteckA Offline
          arteckA Offline
          arteck
          #832
          dann stell mal den..was wars rock oder banana woanders hin… also irgndwas an der Hardware/Aufstellung musst du ändern..
          • L Offline
            LJSven
            #833
            @arteck:
            dann stell mal den..was wars rock oder banana woanders hin… also irgndwas an der Hardware/Aufstellung musst du ändern.. `
            Okay, das die Link Quality über 30 bei beiden ist, ist in diesem Fall egal?
              donderda
              #834
              Habe das gleiche Problem mit den Osram Plugs temporär so gelöst: Alle 10 Sekunden für 2 Minuten lasse ich die schalten. Mehr so der Brute-force ansatz, funktioniert aber… Dann funktioniert das zumindest für die Weihnachtsbeleuchtung. Aber irgendwie ist das echt nervig...
              • L Offline
                ltsalvatore
                #835
                @arteck:
                den Objekten kannst du mehr vertrauen…
                hier wird die link_quality jedesmal beim schalten aktualisiert
                lerne doch mal die plugs nochmal alle an dem weichnachtsmann_groß plug an `
                hm.. bist du dir da ganz sicher..
                gerade habe ich den aqara switch an den "weichnachtsmann_groß plug" angelernt, welcher 30cm vom zigbee adapter entfernt ist, und der aqara switch ist nur 15cm vom osram plug entfernt, und dennoch
                die link quality des aqara switch ist bei max. 5
                und der aqara switch schaltet ohne zu meckern. von 20 schalt versuchen sind 20 problemlos durchgegangen.
                und bei anderen geräten, wo die link quality auf über 50 ist, ist das gegenteil der fall. mal geht's mal nicht…
                jetzt kann man weder der map noch den werten glauben schenken.
                dann kommt noch hinzu, dass man irgendwann auch den überblick verloren hat, welches gerät wo angelernt wurde...
                und von dem anlernen von geräten wollen wir am besten erst garnicht reden.. da hat man ja fast mehr glück beim lotto spielen...
                das ist jetzt wirklich nicht bös gemeint und ich habe auch respekt vor eurer arbeit.
                im großen und ganzen macht das ganze thema smart home ja auch weiterhin viel spaß, aber offen gestanden vergeht mir langsam etwas die lust an diesem adapter...
                gefühlt wird es immer komplizierter und unverständlicher je mehr man sich mit dem adapter beschäftigt. eigentlich sollte es doch umgekehrt sein.
                bitte das jetzt auch nicht falsch verstehen, aber gibt es eine alternative zu diesem universal zigbee stick und adapter.
                am liebsten würde ich ja die xiaomi gateway mit dem entsprechenden adapter benutzen denn da funktioniert bis jetzt alles was ich angeschlossen habe (die aqara tür sensoren und der cube) seit einrichtung 100% tadellos.
                jedoch werden ja osram plugs nicht erkannt/unterstützt.
                nochmals, es macht spaß und man lernt dadurch einiges dazu und selbstverständlich muss man auch viel zeit investieren, doch irgendwann will man sich gerne auch anderen smart home projekten widmen, dann ist so ein adapter, der bis jetzt alles andere als stabil läuft und nur probleme verursacht echt frustrierend.
                EDIT:
                Das ist im Übrigen das ergebnis, wenn man sich denkt, ok.. gibt dem ganzen nochmal ne chance, fang mal bei null an und lerne die geräte so an wie dir vorgeschlagen wurde..
                das ganze log ist jetzt voll damit und funktioniert jetzt beschissener als vorher. :roll:
                  Masteryotta
                  #836
                  Hallo, ich hatte am Anfang Probleme gleichzeitig die Tradfri Fernbedienung (Remote Control) und den Adapter zu nutzen. Ich habe eine Tradfri E27 980 lm und eine Tradfri E14 400 lm.
                  Folgende Reihenfolge zum paaren hat denn geklappt:
                  Tradfri RC mit Stick paaren (Reset RC 4mal hinterer Knopf drucken, 10cm max Entfernung), Adapter wird zwar erkannt, ist aber noch nicht programmiert > ok
                  Stick mit Tradfri Birne paaren (6 mal an und aus, 10cm max Entfernung), Birne wird erkannt und kann auch gesteuert werden.
                  Denn erst die RC mit die Birne paaren (hinterer Knopf 10 sec drücken, 10cm max Entfernung).
                  In ioBroker geht dann das an/aus, Dimmen und auch Farbwechsel aber auf der Fernbedienung geht nur noch das an/aus und Dimmen, die Farbe bleibt immer gleich und kann nur noch in iobroker gewechselt werden.
                  Fehler weil die Fernbedienung noch nicht voll unterstützt ist?
                    denjo
                    #837
                    @arteck:
                    @Pocky:
                    Sorry @ arteck
                    Wie soll ich das denn machen?
                    Mit welchen Objekten?
                    Aus dem Zigbee Adapter? Das geht nicht.
                    Welche Objekte soll ich anlegen? `
                    so mein kleiner Padawan ;)
                    ersmal lösche die Birne aus dem Cloud Adapter ..dann aus Alexa App..
                    zigbee Objekte auf und die Lampe/Birne was du steuern willst
                    bei jedem Datenpunkt muss du das machen mit der gleichen Bezeichnung
                    dann
                    "smartName": {
                          "de": "bürolampe",
                          "smartType": "LIGHT"
                    eintragen .. achte auf die Formatierung und , nicht vergessen
                    dann müsstest du die auch im Cloud adapter sehen
                    jetzt noch nach neuen Geräten suchen in der Alexa App `
                    Hallo, habe es so gemacht wie du geschrieben hast.
                    habe auch alle werte in der Cloud drin aber kann keine farben mit alexa steuern, kannst du mir da helfen?
                    ich sage zb: Alexa, Philips Go Blau
                    und dann kommt: Gerät unterstützt das nicht
                    • arteckA Offline
                      arteckA Offline
                      arteck
                      #838
                      @denjo:
                      @arteck:
                      @Pocky:
                      Sorry @ arteck
                      dann
                      "smartName": {
                            "de": "bürolampe",
                      und dann kommt: Gerät unterstützt das nicht `
                      du musst den block an jedes Datenpunkt hängen.. wobei ich seh gerade.. bei mir macht der das auch nicht..
                      wasisendalos???
                        denjo
                        #839
                        @arteck:
                        @denjo:
                        @arteck:
                        dann
                        "smartName": {
                              "de": "bürolampe",
                        du musst den block an jedes Datenpunkt hängen.. `
                        habe ich gemacht, in der alexa app steht auch bei Farbeinstellungen KEINE
                        • arteckA Offline
                          arteckA Offline
                          arteck
                          #840
                          @ltsalvatore:
                          @arteck:
                          EDIT:
                          Screenshot_2018.12.24_00_01_21_001.jpg `
                          was soll ich dazu sagen… bei mir läufts und das mit nicht wenig geräten und bunt gemischt von Xiaomi, Hue, Osram, und Tradfri
                          bei anderen läufts auch.. ich könnte jetzt die Glaskugel aus dem Keller holen nachschauen warum es bei dir so viele Probleme bereitet.. Es ist halt Technick ich würde nicht sagen Experimentell aber es trift zu... man muss sich mit beschäftigen.. die Gegebenheiten sind bei jedem einzelnen besonders.. bei einem läufts direkt bei anderem wiederrum nicht weil .. ja weil..
                          nicht falsch verstehen : wenn es dir nicht passt dann wechsel auf was anderes oder verbinde mehrere Sachen miteinander (iobroker macht ja sooooooo vieles mit) so das du eine Umgebung hast die dir gefällt bzw. die funktioniert..
                          ich betreibe das Netzwerk schon seit mahr als einem Jahr.. ich kenne die Probleme (wie nicht funktionierende Plugs die das ganze Netz lahmlegen oder Firmware die nicht mitmacht) und auch relativ viele Lösungen aber nichts desto trotz sind manche Umstände so besonders dass ich keine Lösung habe( fuck das hab ich echt gesagt ;) )
                          ich biete jedem der ein Problem hat sich mit mir im TS zu treffen und das Thema zu behandeln.. man muss es nur tun..
                          • arteckA Offline
                            arteckA Offline
                            arteck
                            #841
                            @denjo:
                            @arteck:
                            @denjo:
                            habe ich gemacht, in der alexa app steht auch bei Farbeinstellungen KEINE `
                            jo hab ich auch… zur Zeit keine Idee.. muss ich mir mal anschauen.. ich tippe auf den Cloud Adapter oder ion.. der nimmt den State colour nicht mit
                              denjo
                              #842
                              @arteck:
                              @denjo:
                              @arteck:
                              jo hab ich auch… zur Zeit keine Idee.. muss ich mir mal anschauen.. ich tippe auf den Cloud Adapter oder ion.. der nimmt den State colour nicht mit `
                              okay, ich hab den IOT, kenne mich leider zu wenig damit aus aber erst mal danke für deine hilfe
                              • arteckA Offline
                                arteckA Offline
                                arteck
                                #843
                                @denjo:
                                okay, ich hab den IOT, kenne mich leider zu wenig damit aus aber erst mal danke für deine hilfe `
                                alles gut..wundert mich auch.. ich schau mir das an… allerdings nicht heute ;)
                                so kurzer Zwischenstand es hängt mit den Rollen zusammen...
                                colortemp muss die Rolle level.color.temperature haben dann funktioniert schon mal warm kalt
                                  denjo
                                  #844
                                  @arteck:
                                  @denjo:
                                  alles gut..wundert mich auch.. ich schau mir das an… allerdings nicht heute ;) `
                                  ja das ist verständlich, schöne weihnachten an der stelle
                                  • L Offline
                                    LJSven
                                    #845
                                    Ist es normal, daß die Map immer die gleichen Objekte als nicht verbunden zeigt? Wenn ich unter den Objekten schaue, haben die Objekte eine Link Quality von über 30-40
                                      donderda
                                      #846
                                      Die Map ist nicht wirklich aussagekräftig
                                      • L Offline
                                        ltsalvatore
                                        #847
                                        @arteck:
                                        @ltsalvatore:
                                        @arteck:
                                        EDIT:
                                        ich biete jedem der ein Problem hat sich mit mir im TS zu treffen und das Thema zu behandeln.. man muss es nur tun.. `
                                        naja.. so schnell gebe ich schon nicht auf :-D
                                        doch erst werde ich mir nen neuen server anschaffen und das ganze nochmal von grund auf einrichten.
                                        der raspberry pi ist zwar ganz nett und für das ein oder andere vollkommen ausreichend, aber mein gefühl sagt mir, dass es am "fundament" liegt. :roll:
                                        und da ich ja eh einiges mehr vor habe.. ist son NUC denke ich auf lange sicht die bessere lösung,
                                        und somit kann ich auch ausschließen, dass diverse probleme mangels performance auftreten.
                                        und danke für das angebot bez. TS; da werde ich nochmal drauf zurückkommen, sobald die neue hardware bestellt und eingerichtet ist.
                                          Kueppert
                                          #848
                                          Ich habe mittlerweile auch viele Geräte am auch Stick angebunden. Ich habe bei mir/für mich festgestellt, dass die Osram Plugs und deren Sendeleistung miserabel ist, leider. Habe trotzdem 6 Stück in der Wohnung verteilt und auch Philips Birnen mittlerweile als repeater eingebunden. Ab und zu klappt trotzdem etwas nicht… Bei mir liegt es aber auch an der Fußboden Heizung und 2 Etagen denke ich... Werde irgendwann an den Stick ne dicke Antenne löten (lassen) und hoffe, dass ich dann alle Geräte durchweg erreichen kann
                                          Gesendet von meinem HUAWEI RIO-L01 mit Tapatalk
