Raspberrypi install iobroker - node.js 8.12
:idea:
Thank you! wrks finally
The problem is that your linux district updated their node version to 8.x and because you had installed node 6 it was updated and this broke it.
Gesendet vom Handy …
today i had to reinstall node.js because my latest update crashed.
Now I habe node.js 8.14 and ble-adaptes as well as the zigbee-adapter don't run.
I sems that the node.js is to new for these adapters.
Is this possible?
No when changing nodejs versions you may need to rebuild some native modules.
Running „npm rebuild“ in your iobroker directory should fix this.
thank you. I will try it
> Error: EACCES: permission denied, scandir '/root/.npm/_logs'
Runsudo chown -R $(whoami) ~/.npm
and try again.
And try
npm rebuild
without sudo before resorting tosudo npm rebuild
. sudo is known to cause problems. -
ah thx.
the zigbee adapter still had problems. So I decided to deinstall this adapter and reinstall it
Now it wprks
thank you
Before I make any othe changes I will do a full backup tomorrow… :lol:
and try again.
And try
npm rebuild
. sudo is known to cause problems. `hm…
just to clarity first...
means that the ohnership of all files and subdirectories are transferred to user "pi"?
and I have to set this commad at /opt/iobroker ?
and what is with iobroker? do I have to stop it first?
just to clarity first…
means that the ohnership of all files and subdirectories are transferred to user "pi"? `
Newer npm versions have the tendency to change the ownership of the .npm folder in the current user's homedir (~). So when you execute npm install with sudo and later without, it won't be able to access ~/.npm (e.g. /home/pi/.npm) because it now belongs to root.
The above command changes the ownership back to whomever it belonged in the first place.
And no, you don't need to do anything with iobroker or change folder to execute that command.
I tryed n
==> no output, cursor prompt returns within miliseconds
then
npm rebuild
from the root directory shows this
! pi@ioBroker-Pi:~ $ npm rebuild
! ajv@6.5.5 /home/pi/node_modules/ajv
! fast-deep-equal@2.0.1 /home/pi/node_modules/fast-deep-equal
! fast-json-stable-stringify@2.0.0 /home/pi/node_modules/fast-json-stable-stringify
! json-schema-traverse@0.4.1 /home/pi/node_modules/json-schema-traverse
! uri-js@4.2.2 /home/pi/node_modules/uri-js
! punycode@2.1.1 /home/pi/node_modules/punycode
! asap@2.0.6 /home/pi/node_modules/asap
! asn1@0.2.4 /home/pi/node_modules/asn1
! safer-buffer@2.1.2 /home/pi/node_modules/safer-buffer
! assert-plus@1.0.0 /home/pi/node_modules/assert-plus
! asynckit@0.4.0 /home/pi/node_modules/asynckit
! aws-sign2@0.7.0 /home/pi/node_modules/aws-sign2
! aws4@1.8.0 /home/pi/node_modules/aws4
! bcrypt-pbkdf@1.0.2 /home/pi/node_modules/bcrypt-pbkdf
! tweetnacl@0.14.5 /home/pi/node_modules/tweetnacl
! caseless@0.12.0 /home/pi/node_modules/caseless
! combined-stream@1.0.7 /home/pi/node_modules/combined-stream
! delayed-stream@1.0.0 /home/pi/node_modules/delayed-stream
! core-util-is@1.0.2 /home/pi/node_modules/core-util-is
! dashdash@1.14.1 /home/pi/node_modules/dashdash
! debug@2.6.9 /home/pi/node_modules/debug
! ms@2.0.0 /home/pi/node_modules/ms
! ecc-jsbn@0.1.2 /home/pi/node_modules/ecc-jsbn
! jsbn@0.1.1 /home/pi/node_modules/jsbn
! extend@3.0.2 /home/pi/node_modules/extend
! extsprintf@1.3.0 /home/pi/node_modules/extsprintf
! forever-agent@0.6.1 /home/pi/node_modules/forever-agent
! form-data@2.3.3 /home/pi/node_modules/form-data
! mime-types@2.1.21 /home/pi/node_modules/mime-types
! mime-db@1.37.0 /home/pi/node_modules/mime-db
! getpass@0.1.7 /home/pi/node_modules/getpass
! har-schema@2.0.0 /home/pi/node_modules/har-schema
! har-validator@5.1.3 /home/pi/node_modules/har-validator
! http-signature@1.2.0 /home/pi/node_modules/http-signature
! jsprim@1.4.1 /home/pi/node_modules/jsprim
! json-schema@0.2.3 /home/pi/node_modules/json-schema
! verror@1.10.0 /home/pi/node_modules/verror
! sshpk@1.15.2 /home/pi/node_modules/sshpk
! ip@1.1.5 /home/pi/node_modules/ip
! is-absolute@0.2.6 /home/pi/node_modules/is-absolute
! is-relative@0.2.1 /home/pi/node_modules/is-relative
! is-unc-path@0.1.2 /home/pi/node_modules/is-unc-path
! unc-path-regex@0.1.2 /home/pi/node_modules/unc-path-regex
! is-windows@0.2.0 /home/pi/node_modules/is-windows
! is-typedarray@1.0.0 /home/pi/node_modules/is-typedarray
! isstream@0.1.2 /home/pi/node_modules/isstream
! json-stringify-safe@5.0.1 /home/pi/node_modules/json-stringify-safe
! lodash@4.17.11 /home/pi/node_modules/lodash
! minimist@0.0.8 /home/pi/node_modules/minimist
! mkdirp@0.5.1 /home/pi/node_modules/mkdirp
! node-persist@2.1.0 /home/pi/node_modules/node-persist
! q@1.1.2 /home/pi/node_modules/q
! node-red-contrib-alexa-local@0.3.12 /home/pi/node_modules/node-red-contrib-alexa-local
! peer-ssdp@0.0.5 /home/pi/node_modules/peer-ssdp
! stoppable@1.0.5 /home/pi/node_modules/stoppable
! node-red-contrib-bool-gate@1.0.2 /home/pi/node_modules/node-red-contrib-bool-gate
! node-red-contrib-wemo-emulator@0.6.0 /home/pi/node_modules/node-red-contrib-wemo-emulator
! wemore@0.6.0 /home/pi/node_modules/wemore
! node-ssdp@2.9.1 /home/pi/node_modules/node-ssdp
! q@2.0.3 /home/pi/node_modules/wemore/node_modules/q
! pop-iterate@1.0.1 /home/pi/node_modules/pop-iterate
! weak-map@1.0.5 /home/pi/node_modules/weak-map
! request@2.88.0 /home/pi/node_modules/request
! oauth-sign@0.9.0 /home/pi/node_modules/oauth-sign
! performance-now@2.1.0 /home/pi/node_modules/performance-now
! qs@6.5.2 /home/pi/node_modules/qs
! safe-buffer@5.1.2 /home/pi/node_modules/safe-buffer
! tough-cookie@2.4.3 /home/pi/node_modules/tough-cookie
! psl@1.1.29 /home/pi/node_modules/psl
! punycode@1.4.1 /home/pi/node_modules/tough-cookie/node_modules/punycode
! tunnel-agent@0.6.0 /home/pi/node_modules/tunnel-agent
! uuid@3.3.2 /home/pi/node_modules/uuid
! xml2js@0.4.19 /home/pi/node_modules/xml2js
! sax@1.2.4 /home/pi/node_modules/sax
! xmlbuilder@9.0.7 /home/pi/node_modules/xmlbuilderbut with starting point /opt/iobroker all the same sh… again
You have to execute "npm rebuild" in /opt/iobroker.
This is what I've done.
And I receive same error messages as shown in my former post
[Update]
nice
now, after one reboot iobroker is dead
pi@ioBroker-Pi:/opt/iobroker $ sudo iobroker start module.js:550 throw err; ^ Error: Cannot find module '/usr/local/www/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Function.Module._resolveFilename (module.js:548:15) at Function.Module._load (module.js:475:25) at Function.Module.runMain (module.js:694:10) at startup (bootstrap_node.js:204:16) at bootstrap_node.js:625:3
now (after iobroker is definately not running I tryed again npm rebuild
so my try was to do chmod 777 /var/lib/dpkg because of the first messages
E: Sperrdatei /var/lib/dpkg/lock konnte nicht geöffnet werden. - open (13: Keine Berechtigung) E: Sperren des Administrationsverzeichnisses (/var/lib/dpkg/) nicht möglich, sind Sie root?
but no change. Same errors
next try:sudo apt-get install build-essential
result:
Paketlisten werden gelesen… Fertig Abhängigkeitsbaum wird aufgebaut. Statusinformationen werden eingelesen.... Fertig build-essential ist schon die neueste Version (12.3). Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt: gyp javascript-common libc-ares2 libhttp-parser2.8 libjs-inherits libjs-jquery libjs-node-uuid libjs-underscore libssl-dev libssl-doc libuv1 libuv1-dev node-abbrev node-ansi node-ansi-color-table node-archy node-async node-balanced-match node-block-stream node-brace-expansion node-builtin-modules node-combined-stream node-concat-map node-cookie-jar node-delayed-stream node-forever-agent node-form-data node-fs.realpath node-fstream node-fstream-ignore node-github-url-from-git node-glob node-graceful-fs node-gyp node-hosted-git-info node-inflight node-inherits node-ini node-is-builtin-module node-isexe node-json-stringify-safe node-lockfile node-lru-cache node-mime node-minimatch node-mkdirp node-mute-stream node-node-uuid node-nopt node-normalize-package-data node-npmlog node-once node-osenv node-path-is-absolute node-pseudomap node-qs node-read node-read-package-json node-request node-retry node-rimraf node-semver node-sha node-slide node-spdx-correct node-spdx-expression-parse node-spdx-license-ids node-tar node-tunnel-agent node-underscore node-validate-npm-package-license node-which node-wrappy node-yallist nodejs-doc python-pkg-resources Verwenden Sie »sudo apt autoremove«, um sie zu entfernen. 0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
then again:
npm rebuild sudo npm rebuild
both with same errors.
Maybe I am wrong but i think with sudo I am same as root.
Or not?
Do I have to login as root?
[update]
as root the first errors are gore (lock) but rest is the same.
Then I tryedroot@ioBroker-Pi:/opt/iobroker# apt-get update Holen:1 http://archive.raspberrypi.org/debian stretch InRelease [25,3 kB] Holen:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15,0 kB] OK:3 https://deb.nodesource.com/node_8.x stretch InRelease Holen:4 http://archive.raspberrypi.org/debian stretch/main armhf Packages [199 kB] Holen:5 http://archive.raspberrypi.org/debian stretch/ui armhf Packages [39,2 kB] Es wurden 279 kB in 1 s geholt (198 kB/s). Paketlisten werden gelesen... Fertig root@ioBroker-Pi:/opt/iobroker# apt-get upgrade -y Paketlisten werden gelesen... Fertig Abhängigkeitsbaum wird aufgebaut. Statusinformationen werden eingelesen.... Fertig Paketaktualisierung (Upgrade) wird berechnet... Fertig Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt: gyp javascript-common libc-ares2 libhttp-parser2.8 libjs-inherits libjs-jquery libjs-node-uuid libjs-underscore libssl-dev libssl-doc libuv1 libuv1-dev node-abbrev node-ansi node-ansi-color-table node-archy node-async node-balanced-match node-block-stream node-brace-expansion node-builtin-modules node-combined-stream node-concat-map node-cookie-jar node-delayed-stream node-forever-agent node-form-data node-fs.realpath node-fstream node-fstream-ignore node-github-url-from-git node-glob node-graceful-fs node-gyp node-hosted-git-info node-inflight node-inherits node-ini node-is-builtin-module node-isexe node-json-stringify-safe node-lockfile node-lru-cache node-mime node-minimatch node-mkdirp node-mute-stream node-node-uuid node-nopt node-normalize-package-data node-npmlog node-once node-osenv node-path-is-absolute node-pseudomap node-qs node-read node-read-package-json node-request node-retry node-rimraf node-semver node-sha node-slide node-spdx-correct node-spdx-expression-parse node-spdx-license-ids node-tar node-tunnel-agent node-underscore node-validate-npm-package-license node-which node-wrappy node-yallist nodejs-doc python-pkg-resources Verwenden Sie »apt autoremove«, um sie zu entfernen. 0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
But iobroker is still dead
But you have seen that the path in the error Waage when starting iobroker is wrong?! /var/www/… inhale no idea where this path comes from.
The rebuild log seems ok because authenticate-Pam is an optional package.
Changing rights in system stuff like Dpkg is no good idea!!
Gesendet vom Handy ...
I think you guys can talk in german
it is because the thread started in english.
:lol:
Changing rights in system stuff like Dpkg is no good idea!! `
sure. it was only for testingmaybe it is a good idea to reinstall (only) iobroker.
But are these instructions correct?
cd /opt/iobroker sudo chmod 777 * -R sudo npm install iobroker.js-controller --production
But are these instructions correct? `
They are pretty outdated. See viewtopic.php?f=8&t=19111 and viewtopic.php?f=8&t=19209Since your installation is pretty fucked, I think one of the cleanest ways to get an almost fresh installation is deleting the old node_modules
cd /opt/iobroker sudo rm -rf node_modules
and performing a clean install (while keeping iobroker-data)
curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/stable-installer/installer.sh | bash -
ioBroker should then detect which adapters are missing and install them again.
hmmm
pi@ioBroker-Pi:/opt/iobroker $ cd /opt/iobroker pi@ioBroker-Pi:/opt/iobroker $ sudo rm -rf node_modules pi@ioBroker-Pi:/opt/iobroker $ curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/stable-installer/installer.sh | bash - ========================================================================== Welcome to the ioBroker installer! You might need to enter your password a couple of times. ========================================================================== ========================================================================== Creating ioBroker directory (1/4) ========================================================================== ========================================================================== Downloading installation files (2/4) ========================================================================== npm ERR! code ENOSELF npm ERR! Refusing to install package with name "iobroker" under a package npm ERR! also called "iobroker". Did you name your project the same npm ERR! as the dependency you're installing? npm ERR! npm ERR! For more information, see: npm ERR! <https: docs.npmjs.com/cli/install#limitations-of-npms-install-algorithm="">npm ERR! A complete log of this run can be found in: npm ERR! /home/pi/.npm/_logs/2018-12-06T15_47_56_194Z-debug.log ========================================================================== Installing ioBroker (3/4) ========================================================================== npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen) npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies. npm WARN deprecated nodemailer@1.11.0: All versions below 4.0.1 of Nodemailer are deprecated. See https://nodemailer.com/status/ npm WARN deprecated mailparser@0.6.2: Mailparser versions older than v2.3.0 are deprecated npm WARN deprecated mailcomposer@2.1.0: This project is unmaintained npm WARN deprecated mimelib@0.3.1: This project is unmaintained npm WARN deprecated buildmail@2.0.0: This project is unmaintained npm ERR! code 128 npm ERR! Command failed: /usr/bin/git submodule update -q --init --recursive npm ERR! fatal: Could not change back to '/root/.npm/_cacache/tmp/git-clone-5787434c': Keine Berechtigung npm ERR! npm ERR! A complete log of this run can be found in: npm ERR! /root/.npm/_logs/2018-12-06T15_48_43_483Z-debug.log ========================================================================== Finalizing installation (4/4) ========================================================================== ========================================================================== ioBroker was installed successfully Open http://localhost:8081 in a browser and start configuring! ==========================================================================</https:>
and after reboot:
pi@ioBroker-Pi:~ $ iobroker start module.js:550 throw err; ^ Error: Cannot find module '/usr/local/www/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Function.Module._resolveFilename (module.js:548:15) at Function.Module._load (module.js:475:25) at Function.Module.runMain (module.js:694:10) at startup (bootstrap_node.js:204:16) at bootstrap_node.js:625:3
I don't know why there is a call to the webserver
