  4. Raspberrypi install iobroker - node.js 8.12
    6.4k
27 Beiträge 6 Kommentatoren 6.3k Aufrufe
  • apollon77A Offline
    How you installed nodejs? Directly using your distribution or using the nodesource curl command? If district then this may be the reason because the often only have older versions. .
    What npm Version you have?
    Gesendet vom Handy …
    • J Offline
      j_poool
      I used this instructions
      http://www.iobroker.net/docu/?page_id=5090&lang=en
      Installation of Node.js
      	1\. Kernel Update: sudo apt-get update && sudo apt-get upgrade
      	2\. Deinstall old node.je Version (not required by Jessie Light)
      		1.apt-get --purge remove node
      		2.apt-get --purge remove nodejs
      		3.apt-get autoremove
      		4.reboot
      	3\. login as root via Putty
      	4\. Install Node.js anew for Raspbery 2/3
      		1.curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash -
      		2.sudo apt-get install -y build-essential python-rpi.gpio python nodejs
      		3.reboot
      	5\. login as root via Putty sudo su (now is Root Mode active)
      	6\. After installation of node.js the command “node -v” should show the node.js version. if not, create alias to bin file::
      sudo ln -s /usr/local/bin/nodejs /usr/bin/node
      npm is up to date?
      pi@panel:~ $ npm -v
      1.4.21
      (node:2450) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpd        ir() instead.
      pi@panel:~ $ node -v
      v8.11.1
      pi@panel:~ $ nodejs -v
      v8.11.1
      Thank you
        please remove node and nodejs again
        sudo apt-get purge node
        sudo apt-get purge nodejs
        and check the versions again
        node -v
        nodejs -v
        npm -v
        the actual npm version is very strange
        looks like ther was a nodejs already installed by the OS
        Greets
        • J Offline
          j_poool
          Ok, node and nodejs is deinstalled
          How or where can i find the nodejs v8.12 for Raspberrypi?
          • paul53P Offline
            @j_poool:
            How or where can i find the nodejs v8.12 for Raspberrypi? `
            curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
            sudo apt-get install -y nodejs
            node -v
            npm -v
            • J Offline
              j_poool
              :idea:
              Thank you! wrks finally :D
                The problem is that your linux district updated their node version to 8.x and because you had installed node 6 it was updated and this broke it.
                  Arnulf
                  today i had to reinstall node.js because my latest update crashed.
                  Now I habe node.js 8.14 and ble-adaptes as well as the zigbee-adapter don't run.
                  I sems that the node.js is to new for these adapters.
                  Is this possible?
                    No when changing nodejs versions you may need to rebuild some native modules.
                    Running „npm rebuild“ in your iobroker directory should fix this.
                      Arnulf
                      thank you. I will try it :)
                        Arnulf
                        schrieb am zuletzt editiert von Jey Cee
                        :shock:
                        waves of errors
                        sudo npm rebuild
                        log.txt
                        • AlCalzoneA Offline
                          AlCalzoneA Offline
                          AlCalzone
                          > Error: EACCES: permission denied, scandir '/root/.npm/_logs'
                          Run
                          sudo chown -R $(whoami) ~/.npm
                          and try again.
                          And try npm rebuild without sudo before resorting to sudo npm rebuild. sudo is known to cause problems.
                            Arnulf
                            ah thx.
                            the zigbee adapter still had problems. So I decided to deinstall this adapter and reinstall it
                            Now it wprks
                            thank you
                            Before I make any othe changes I will do a full backup tomorrow… :lol:
                              Arnulf
                              @AlCalzone:
                              Run
                              and try again.
                              And try npm rebuild without sudo before resorting to sudo npm rebuild. sudo is known to cause problems. `
                              hm…
                              just to clarity first...
                              means that the ohnership of all files and subdirectories are transferred to user "pi"?
                              and I have to set this commad at /opt/iobroker ?
                              and what is with iobroker? do I have to stop it first?
                                AlCalzoneA Offline
                                AlCalzone
                                @Arnulf:
                                just to clarity first…
                                means that the ohnership of all files and subdirectories are transferred to user "pi"? `
                                Newer npm versions have the tendency to change the ownership of the .npm folder in the current user's homedir (~). So when you execute npm install with sudo and later without, it won't be able to access ~/.npm (e.g. /home/pi/.npm) because it now belongs to root.
                                The above command changes the ownership back to whomever it belonged in the first place.
                                And no, you don't need to do anything with iobroker or change folder to execute that command.
                                  Arnulf
                                  I tryed n
                                  ==> no output, cursor prompt returns within miliseconds
                                  then
                                  npm rebuild
                                  from the root directory shows this
                                  ! pi@ioBroker-Pi:~ $ npm rebuild
                                  ! ajv@6.5.5 /home/pi/node_modules/ajv
                                  ! fast-deep-equal@2.0.1 /home/pi/node_modules/fast-deep-equal
                                  ! fast-json-stable-stringify@2.0.0 /home/pi/node_modules/fast-json-stable-stringify
                                  ! json-schema-traverse@0.4.1 /home/pi/node_modules/json-schema-traverse
                                  ! uri-js@4.2.2 /home/pi/node_modules/uri-js
                                  ! punycode@2.1.1 /home/pi/node_modules/punycode
                                  ! asap@2.0.6 /home/pi/node_modules/asap
                                  ! asn1@0.2.4 /home/pi/node_modules/asn1
                                  ! safer-buffer@2.1.2 /home/pi/node_modules/safer-buffer
                                  ! assert-plus@1.0.0 /home/pi/node_modules/assert-plus
                                  ! asynckit@0.4.0 /home/pi/node_modules/asynckit
                                  ! aws-sign2@0.7.0 /home/pi/node_modules/aws-sign2
                                  ! aws4@1.8.0 /home/pi/node_modules/aws4
                                  ! bcrypt-pbkdf@1.0.2 /home/pi/node_modules/bcrypt-pbkdf
                                  ! tweetnacl@0.14.5 /home/pi/node_modules/tweetnacl
                                  ! caseless@0.12.0 /home/pi/node_modules/caseless
                                  ! combined-stream@1.0.7 /home/pi/node_modules/combined-stream
                                  ! delayed-stream@1.0.0 /home/pi/node_modules/delayed-stream
                                  ! core-util-is@1.0.2 /home/pi/node_modules/core-util-is
                                  ! dashdash@1.14.1 /home/pi/node_modules/dashdash
                                  ! debug@2.6.9 /home/pi/node_modules/debug
                                  ! ms@2.0.0 /home/pi/node_modules/ms
                                  ! ecc-jsbn@0.1.2 /home/pi/node_modules/ecc-jsbn
                                  ! jsbn@0.1.1 /home/pi/node_modules/jsbn
                                  ! extend@3.0.2 /home/pi/node_modules/extend
                                  ! extsprintf@1.3.0 /home/pi/node_modules/extsprintf
                                  ! forever-agent@0.6.1 /home/pi/node_modules/forever-agent
                                  ! form-data@2.3.3 /home/pi/node_modules/form-data
                                  ! mime-types@2.1.21 /home/pi/node_modules/mime-types
                                  ! mime-db@1.37.0 /home/pi/node_modules/mime-db
                                  ! getpass@0.1.7 /home/pi/node_modules/getpass
                                  ! har-schema@2.0.0 /home/pi/node_modules/har-schema
                                  ! har-validator@5.1.3 /home/pi/node_modules/har-validator
                                  ! http-signature@1.2.0 /home/pi/node_modules/http-signature
                                  ! jsprim@1.4.1 /home/pi/node_modules/jsprim
                                  ! json-schema@0.2.3 /home/pi/node_modules/json-schema
                                  ! verror@1.10.0 /home/pi/node_modules/verror
                                  ! sshpk@1.15.2 /home/pi/node_modules/sshpk
                                  ! ip@1.1.5 /home/pi/node_modules/ip
                                  ! is-absolute@0.2.6 /home/pi/node_modules/is-absolute
                                  ! is-relative@0.2.1 /home/pi/node_modules/is-relative
                                  ! is-unc-path@0.1.2 /home/pi/node_modules/is-unc-path
                                  ! unc-path-regex@0.1.2 /home/pi/node_modules/unc-path-regex
                                  ! is-windows@0.2.0 /home/pi/node_modules/is-windows
                                  ! is-typedarray@1.0.0 /home/pi/node_modules/is-typedarray
                                  ! isstream@0.1.2 /home/pi/node_modules/isstream
                                  ! json-stringify-safe@5.0.1 /home/pi/node_modules/json-stringify-safe
                                  ! lodash@4.17.11 /home/pi/node_modules/lodash
                                  ! minimist@0.0.8 /home/pi/node_modules/minimist
                                  ! mkdirp@0.5.1 /home/pi/node_modules/mkdirp
                                  ! node-persist@2.1.0 /home/pi/node_modules/node-persist
                                  ! q@1.1.2 /home/pi/node_modules/q
                                  ! node-red-contrib-alexa-local@0.3.12 /home/pi/node_modules/node-red-contrib-alexa-local
                                  ! peer-ssdp@0.0.5 /home/pi/node_modules/peer-ssdp
                                  ! stoppable@1.0.5 /home/pi/node_modules/stoppable
                                  ! node-red-contrib-bool-gate@1.0.2 /home/pi/node_modules/node-red-contrib-bool-gate
                                  ! node-red-contrib-wemo-emulator@0.6.0 /home/pi/node_modules/node-red-contrib-wemo-emulator
                                  ! wemore@0.6.0 /home/pi/node_modules/wemore
                                  ! node-ssdp@2.9.1 /home/pi/node_modules/node-ssdp
                                  ! q@2.0.3 /home/pi/node_modules/wemore/node_modules/q
                                  ! pop-iterate@1.0.1 /home/pi/node_modules/pop-iterate
                                  ! weak-map@1.0.5 /home/pi/node_modules/weak-map
                                  ! request@2.88.0 /home/pi/node_modules/request
                                  ! oauth-sign@0.9.0 /home/pi/node_modules/oauth-sign
                                  ! performance-now@2.1.0 /home/pi/node_modules/performance-now
                                  ! qs@6.5.2 /home/pi/node_modules/qs
                                  ! safe-buffer@5.1.2 /home/pi/node_modules/safe-buffer
                                  ! tough-cookie@2.4.3 /home/pi/node_modules/tough-cookie
                                  ! psl@1.1.29 /home/pi/node_modules/psl
                                  ! punycode@1.4.1 /home/pi/node_modules/tough-cookie/node_modules/punycode
                                  ! tunnel-agent@0.6.0 /home/pi/node_modules/tunnel-agent
                                  ! uuid@3.3.2 /home/pi/node_modules/uuid
                                  ! xml2js@0.4.19 /home/pi/node_modules/xml2js
                                  ! sax@1.2.4 /home/pi/node_modules/sax
                                  ! xmlbuilder@9.0.7 /home/pi/node_modules/xmlbuilder
                                  but with starting point /opt/iobroker all the same sh… again
                                    AlCalzoneA Offline
                                    AlCalzone
                                    You have to execute "npm rebuild" in /opt/iobroker.
                                      Arnulf
                                      @AlCalzone:
                                      This is what I've done.
                                      And I receive same error messages as shown in my former post
                                      [Update]
                                      nice
                                      now, after one reboot iobroker is dead
                                      pi@ioBroker-Pi:/opt/iobroker $ sudo iobroker start
                                      module.js:550
                                          throw err;
                                      Error: Cannot find module '/usr/local/www/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                          at Function.Module._resolveFilename (module.js:548:15)
                                          at Function.Module._load (module.js:475:25)
                                          at Function.Module.runMain (module.js:694:10)
                                          at startup (bootstrap_node.js:204:16)
                                          at bootstrap_node.js:625:3
                                      now (after iobroker is definately not running I tryed again npm rebuild
                                      log.txt
                                      so my try was to do chmod 777 /var/lib/dpkg because of the first messages
                                      E: Sperrdatei /var/lib/dpkg/lock konnte nicht geöffnet werden. - open (13: Keine Berechtigung)
                                      E: Sperren des Administrationsverzeichnisses (/var/lib/dpkg/) nicht möglich, sind Sie root?
                                      but no change. Same errors
                                      next try:
                                       sudo apt-get install build-essential
                                      result:
                                       build-essential ist schon die neueste Version (12.3).
                                       Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                                       gyp javascript-common libc-ares2 libhttp-parser2.8 libjs-inherits libjs-jquery
                                       libjs-node-uuid libjs-underscore libssl-dev libssl-doc libuv1 libuv1-dev node-abbrev
                                       node-ansi node-ansi-color-table node-archy node-async node-balanced-match
                                       node-block-stream node-brace-expansion node-builtin-modules node-combined-stream
                                       node-concat-map node-cookie-jar node-delayed-stream node-forever-agent node-form-data
                                       node-fs.realpath node-fstream node-fstream-ignore node-github-url-from-git node-glob
                                       node-graceful-fs node-gyp node-hosted-git-info node-inflight node-inherits node-ini
                                       node-is-builtin-module node-isexe node-json-stringify-safe node-lockfile node-lru-cache
                                       node-mime node-minimatch node-mkdirp node-mute-stream node-node-uuid node-nopt
                                       node-normalize-package-data node-npmlog node-once node-osenv node-path-is-absolute
                                       node-pseudomap node-qs node-read node-read-package-json node-request node-retry
                                       node-rimraf node-semver node-sha node-slide node-spdx-correct
                                       node-spdx-expression-parse node-spdx-license-ids node-tar node-tunnel-agent
                                       node-underscore node-validate-npm-package-license node-which node-wrappy node-yallist
                                       nodejs-doc python-pkg-resources
                                       Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                                       0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                      then again:
                                      npm rebuild
                                      sudo npm rebuild
                                      both with same errors.
                                      Maybe I am wrong but i think with sudo I am same as root.
                                      Or not?
                                      Do I have to login as root?
                                      [update]
                                      as root the first errors are gore (lock) but rest is the same.
                                      Then I tryed
                                      root@ioBroker-Pi:/opt/iobroker#  apt-get update
                                      Holen:1 http://archive.raspberrypi.org/debian stretch InRelease [25,3 kB]
                                      Holen:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15,0 kB]
                                      OK:3 https://deb.nodesource.com/node_8.x stretch InRelease
                                      Holen:4 http://archive.raspberrypi.org/debian stretch/main armhf Packages [199 kB]
                                      Holen:5 http://archive.raspberrypi.org/debian stretch/ui armhf Packages [39,2 kB]
                                      Es wurden 279 kB in 1 s geholt (198 kB/s).
                                      root@ioBroker-Pi:/opt/iobroker#  apt-get upgrade -y
                                      Paketaktualisierung (Upgrade) wird berechnet... Fertig
                                        gyp javascript-common libc-ares2 libhttp-parser2.8 libjs-inherits libjs-jquery libjs-node-uuid libjs-underscore
                                        libssl-dev libssl-doc libuv1 libuv1-dev node-abbrev node-ansi node-ansi-color-table node-archy node-async
                                        node-balanced-match node-block-stream node-brace-expansion node-builtin-modules node-combined-stream node-concat-map
                                        node-cookie-jar node-delayed-stream node-forever-agent node-form-data node-fs.realpath node-fstream
                                        node-fstream-ignore node-github-url-from-git node-glob node-graceful-fs node-gyp node-hosted-git-info node-inflight
                                        node-inherits node-ini node-is-builtin-module node-isexe node-json-stringify-safe node-lockfile node-lru-cache
                                        node-mime node-minimatch node-mkdirp node-mute-stream node-node-uuid node-nopt node-normalize-package-data node-npmlog
                                        node-once node-osenv node-path-is-absolute node-pseudomap node-qs node-read node-read-package-json node-request
                                        node-retry node-rimraf node-semver node-sha node-slide node-spdx-correct node-spdx-expression-parse
                                        node-spdx-license-ids node-tar node-tunnel-agent node-underscore node-validate-npm-package-license node-which
                                        node-wrappy node-yallist nodejs-doc python-pkg-resources
                                      Verwenden Sie »apt autoremove«, um sie zu entfernen.
                                      But iobroker is still dead
                                        But you have seen that the path in the error Waage when starting iobroker is wrong?! /var/www/… inhale no idea where this path comes from.
                                        The rebuild log seems ok because authenticate-Pam is an optional package.
                                        Changing rights in system stuff like Dpkg is no good idea!!
                                        Gesendet vom Handy ...
                                          AlCalzoneA Offline
                                          AlCalzone
                                          I think you guys can talk in german :D
