  4. Raspberrypi install iobroker - node.js 8.12
    6.4k
27 Beiträge 6 Kommentatoren 6.3k Aufrufe
    Arnulf
    schrieb am zuletzt editiert von Jey Cee
    :shock:
    waves of errors
    sudo npm rebuild
    log.txt
    • AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      > Error: EACCES: permission denied, scandir '/root/.npm/_logs'
      Run
      sudo chown -R $(whoami) ~/.npm
      and try again.
      And try npm rebuild without sudo before resorting to sudo npm rebuild. sudo is known to cause problems.
        Arnulf
        ah thx.
        the zigbee adapter still had problems. So I decided to deinstall this adapter and reinstall it
        Now it wprks
        thank you
        Before I make any othe changes I will do a full backup tomorrow… :lol:
          Arnulf
          @AlCalzone:
          Run
          and try again.
          And try npm rebuild without sudo before resorting to sudo npm rebuild. sudo is known to cause problems. `
          hm…
          just to clarity first...
          means that the ohnership of all files and subdirectories are transferred to user "pi"?
          and I have to set this commad at /opt/iobroker ?
          and what is with iobroker? do I have to stop it first?
            AlCalzoneA Offline
            AlCalzone
            @Arnulf:
            just to clarity first…
            means that the ohnership of all files and subdirectories are transferred to user "pi"? `
            Newer npm versions have the tendency to change the ownership of the .npm folder in the current user's homedir (~). So when you execute npm install with sudo and later without, it won't be able to access ~/.npm (e.g. /home/pi/.npm) because it now belongs to root.
            The above command changes the ownership back to whomever it belonged in the first place.
            And no, you don't need to do anything with iobroker or change folder to execute that command.
              Arnulf
              I tryed n
              ==> no output, cursor prompt returns within miliseconds
              then
              npm rebuild
              from the root directory shows this
              ! pi@ioBroker-Pi:~ $ npm rebuild
              ! ajv@6.5.5 /home/pi/node_modules/ajv
              ! fast-deep-equal@2.0.1 /home/pi/node_modules/fast-deep-equal
              ! fast-json-stable-stringify@2.0.0 /home/pi/node_modules/fast-json-stable-stringify
              ! json-schema-traverse@0.4.1 /home/pi/node_modules/json-schema-traverse
              ! uri-js@4.2.2 /home/pi/node_modules/uri-js
              ! punycode@2.1.1 /home/pi/node_modules/punycode
              ! asap@2.0.6 /home/pi/node_modules/asap
              ! asn1@0.2.4 /home/pi/node_modules/asn1
              ! safer-buffer@2.1.2 /home/pi/node_modules/safer-buffer
              ! assert-plus@1.0.0 /home/pi/node_modules/assert-plus
              ! asynckit@0.4.0 /home/pi/node_modules/asynckit
              ! aws-sign2@0.7.0 /home/pi/node_modules/aws-sign2
              ! aws4@1.8.0 /home/pi/node_modules/aws4
              ! bcrypt-pbkdf@1.0.2 /home/pi/node_modules/bcrypt-pbkdf
              ! tweetnacl@0.14.5 /home/pi/node_modules/tweetnacl
              ! caseless@0.12.0 /home/pi/node_modules/caseless
              ! combined-stream@1.0.7 /home/pi/node_modules/combined-stream
              ! delayed-stream@1.0.0 /home/pi/node_modules/delayed-stream
              ! core-util-is@1.0.2 /home/pi/node_modules/core-util-is
              ! dashdash@1.14.1 /home/pi/node_modules/dashdash
              ! debug@2.6.9 /home/pi/node_modules/debug
              ! ms@2.0.0 /home/pi/node_modules/ms
              ! ecc-jsbn@0.1.2 /home/pi/node_modules/ecc-jsbn
              ! jsbn@0.1.1 /home/pi/node_modules/jsbn
              ! extend@3.0.2 /home/pi/node_modules/extend
              ! extsprintf@1.3.0 /home/pi/node_modules/extsprintf
              ! forever-agent@0.6.1 /home/pi/node_modules/forever-agent
              ! form-data@2.3.3 /home/pi/node_modules/form-data
              ! mime-types@2.1.21 /home/pi/node_modules/mime-types
              ! mime-db@1.37.0 /home/pi/node_modules/mime-db
              ! getpass@0.1.7 /home/pi/node_modules/getpass
              ! har-schema@2.0.0 /home/pi/node_modules/har-schema
              ! har-validator@5.1.3 /home/pi/node_modules/har-validator
              ! http-signature@1.2.0 /home/pi/node_modules/http-signature
              ! jsprim@1.4.1 /home/pi/node_modules/jsprim
              ! json-schema@0.2.3 /home/pi/node_modules/json-schema
              ! verror@1.10.0 /home/pi/node_modules/verror
              ! sshpk@1.15.2 /home/pi/node_modules/sshpk
              ! ip@1.1.5 /home/pi/node_modules/ip
              ! is-absolute@0.2.6 /home/pi/node_modules/is-absolute
              ! is-relative@0.2.1 /home/pi/node_modules/is-relative
              ! is-unc-path@0.1.2 /home/pi/node_modules/is-unc-path
              ! unc-path-regex@0.1.2 /home/pi/node_modules/unc-path-regex
              ! is-windows@0.2.0 /home/pi/node_modules/is-windows
              ! is-typedarray@1.0.0 /home/pi/node_modules/is-typedarray
              ! isstream@0.1.2 /home/pi/node_modules/isstream
              ! json-stringify-safe@5.0.1 /home/pi/node_modules/json-stringify-safe
              ! lodash@4.17.11 /home/pi/node_modules/lodash
              ! minimist@0.0.8 /home/pi/node_modules/minimist
              ! mkdirp@0.5.1 /home/pi/node_modules/mkdirp
              ! node-persist@2.1.0 /home/pi/node_modules/node-persist
              ! q@1.1.2 /home/pi/node_modules/q
              ! node-red-contrib-alexa-local@0.3.12 /home/pi/node_modules/node-red-contrib-alexa-local
              ! peer-ssdp@0.0.5 /home/pi/node_modules/peer-ssdp
              ! stoppable@1.0.5 /home/pi/node_modules/stoppable
              ! node-red-contrib-bool-gate@1.0.2 /home/pi/node_modules/node-red-contrib-bool-gate
              ! node-red-contrib-wemo-emulator@0.6.0 /home/pi/node_modules/node-red-contrib-wemo-emulator
              ! wemore@0.6.0 /home/pi/node_modules/wemore
              ! node-ssdp@2.9.1 /home/pi/node_modules/node-ssdp
              ! q@2.0.3 /home/pi/node_modules/wemore/node_modules/q
              ! pop-iterate@1.0.1 /home/pi/node_modules/pop-iterate
              ! weak-map@1.0.5 /home/pi/node_modules/weak-map
              ! request@2.88.0 /home/pi/node_modules/request
              ! oauth-sign@0.9.0 /home/pi/node_modules/oauth-sign
              ! performance-now@2.1.0 /home/pi/node_modules/performance-now
              ! qs@6.5.2 /home/pi/node_modules/qs
              ! safe-buffer@5.1.2 /home/pi/node_modules/safe-buffer
              ! tough-cookie@2.4.3 /home/pi/node_modules/tough-cookie
              ! psl@1.1.29 /home/pi/node_modules/psl
              ! punycode@1.4.1 /home/pi/node_modules/tough-cookie/node_modules/punycode
              ! tunnel-agent@0.6.0 /home/pi/node_modules/tunnel-agent
              ! uuid@3.3.2 /home/pi/node_modules/uuid
              ! xml2js@0.4.19 /home/pi/node_modules/xml2js
              ! sax@1.2.4 /home/pi/node_modules/sax
              ! xmlbuilder@9.0.7 /home/pi/node_modules/xmlbuilder
              but with starting point /opt/iobroker all the same sh… again
                AlCalzoneA Offline
                AlCalzone
                You have to execute "npm rebuild" in /opt/iobroker.
                  Arnulf
                  @AlCalzone:
                  This is what I've done.
                  And I receive same error messages as shown in my former post
                  [Update]
                  nice
                  now, after one reboot iobroker is dead
                  pi@ioBroker-Pi:/opt/iobroker $ sudo iobroker start
                  module.js:550
                      throw err;
                  Error: Cannot find module '/usr/local/www/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                      at Function.Module._resolveFilename (module.js:548:15)
                      at Function.Module._load (module.js:475:25)
                      at Function.Module.runMain (module.js:694:10)
                      at startup (bootstrap_node.js:204:16)
                      at bootstrap_node.js:625:3
                  now (after iobroker is definately not running I tryed again npm rebuild
                  log.txt
                  so my try was to do chmod 777 /var/lib/dpkg because of the first messages
                  E: Sperrdatei /var/lib/dpkg/lock konnte nicht geöffnet werden. - open (13: Keine Berechtigung)
                  E: Sperren des Administrationsverzeichnisses (/var/lib/dpkg/) nicht möglich, sind Sie root?
                  but no change. Same errors
                  next try:
                   sudo apt-get install build-essential
                  result:
                   build-essential ist schon die neueste Version (12.3).
                   Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                   gyp javascript-common libc-ares2 libhttp-parser2.8 libjs-inherits libjs-jquery
                   libjs-node-uuid libjs-underscore libssl-dev libssl-doc libuv1 libuv1-dev node-abbrev
                   node-ansi node-ansi-color-table node-archy node-async node-balanced-match
                   node-block-stream node-brace-expansion node-builtin-modules node-combined-stream
                   node-concat-map node-cookie-jar node-delayed-stream node-forever-agent node-form-data
                   node-fs.realpath node-fstream node-fstream-ignore node-github-url-from-git node-glob
                   node-graceful-fs node-gyp node-hosted-git-info node-inflight node-inherits node-ini
                   node-is-builtin-module node-isexe node-json-stringify-safe node-lockfile node-lru-cache
                   node-mime node-minimatch node-mkdirp node-mute-stream node-node-uuid node-nopt
                   node-normalize-package-data node-npmlog node-once node-osenv node-path-is-absolute
                   node-pseudomap node-qs node-read node-read-package-json node-request node-retry
                   node-rimraf node-semver node-sha node-slide node-spdx-correct
                   node-spdx-expression-parse node-spdx-license-ids node-tar node-tunnel-agent
                   node-underscore node-validate-npm-package-license node-which node-wrappy node-yallist
                   nodejs-doc python-pkg-resources
                   Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                   0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                  then again:
                  npm rebuild
                  sudo npm rebuild
                  both with same errors.
                  Maybe I am wrong but i think with sudo I am same as root.
                  Or not?
                  Do I have to login as root?
                  [update]
                  as root the first errors are gore (lock) but rest is the same.
                  Then I tryed
                  root@ioBroker-Pi:/opt/iobroker#  apt-get update
                  Holen:1 http://archive.raspberrypi.org/debian stretch InRelease [25,3 kB]
                  Holen:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15,0 kB]
                  OK:3 https://deb.nodesource.com/node_8.x stretch InRelease
                  Holen:4 http://archive.raspberrypi.org/debian stretch/main armhf Packages [199 kB]
                  Holen:5 http://archive.raspberrypi.org/debian stretch/ui armhf Packages [39,2 kB]
                  Es wurden 279 kB in 1 s geholt (198 kB/s).
                  root@ioBroker-Pi:/opt/iobroker#  apt-get upgrade -y
                  Paketaktualisierung (Upgrade) wird berechnet... Fertig
                    gyp javascript-common libc-ares2 libhttp-parser2.8 libjs-inherits libjs-jquery libjs-node-uuid libjs-underscore
                    libssl-dev libssl-doc libuv1 libuv1-dev node-abbrev node-ansi node-ansi-color-table node-archy node-async
                    node-balanced-match node-block-stream node-brace-expansion node-builtin-modules node-combined-stream node-concat-map
                    node-cookie-jar node-delayed-stream node-forever-agent node-form-data node-fs.realpath node-fstream
                    node-fstream-ignore node-github-url-from-git node-glob node-graceful-fs node-gyp node-hosted-git-info node-inflight
                    node-inherits node-ini node-is-builtin-module node-isexe node-json-stringify-safe node-lockfile node-lru-cache
                    node-mime node-minimatch node-mkdirp node-mute-stream node-node-uuid node-nopt node-normalize-package-data node-npmlog
                    node-once node-osenv node-path-is-absolute node-pseudomap node-qs node-read node-read-package-json node-request
                    node-retry node-rimraf node-semver node-sha node-slide node-spdx-correct node-spdx-expression-parse
                    node-spdx-license-ids node-tar node-tunnel-agent node-underscore node-validate-npm-package-license node-which
                    node-wrappy node-yallist nodejs-doc python-pkg-resources
                  Verwenden Sie »apt autoremove«, um sie zu entfernen.
                  But iobroker is still dead
                  • apollon77A Offline
                    But you have seen that the path in the error Waage when starting iobroker is wrong?! /var/www/… inhale no idea where this path comes from.
                    The rebuild log seems ok because authenticate-Pam is an optional package.
                    Changing rights in system stuff like Dpkg is no good idea!!
                    Gesendet vom Handy ...
                      AlCalzoneA Offline
                      AlCalzone
                      I think you guys can talk in german :D
                        Arnulf
                        it is because the thread started in english.
                        :lol:
                          Arnulf
                          @apollon77:
                          Changing rights in system stuff like Dpkg is no good idea!! `
                          sure. it was only for testing
                          maybe it is a good idea to reinstall (only) iobroker.
                          But are these instructions correct?
                          cd /opt/iobroker
                          sudo chmod 777 * -R
                          sudo npm install iobroker.js-controller --production
                            AlCalzoneA Offline
                            AlCalzone
                            @Arnulf:
                            But are these instructions correct? `
                            They are pretty outdated. See viewtopic.php?f=8&t=19111 and viewtopic.php?f=8&t=19209
                            Since your installation is pretty fucked, I think one of the cleanest ways to get an almost fresh installation is deleting the old node_modules
                            cd /opt/iobroker
                            sudo rm -rf node_modules
                            and performing a clean install (while keeping iobroker-data)
                            curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/stable-installer/installer.sh | bash -
                            ioBroker should then detect which adapters are missing and install them again.
                              Arnulf
                              hmmm
                              pi@ioBroker-Pi:/opt/iobroker $ cd /opt/iobroker
                              pi@ioBroker-Pi:/opt/iobroker $ sudo rm -rf node_modules
                              pi@ioBroker-Pi:/opt/iobroker $ curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/stable-installer/installer.sh | bash -
                                  Welcome to the ioBroker installer!
                                  You might need to enter your password a couple of times.
                                  Creating ioBroker directory (1/4)
                                  Downloading installation files (2/4)
                              npm ERR! code ENOSELF
                              npm ERR! Refusing to install package with name "iobroker" under a package
                              npm ERR! also called "iobroker". Did you name your project the same
                              npm ERR! as the dependency you're installing?
                              npm ERR!
                              npm ERR! For more information, see:
                              npm ERR!     <https: docs.npmjs.com/cli/install#limitations-of-npms-install-algorithm="">npm ERR! A complete log of this run can be found in:
                              npm ERR!     /home/pi/.npm/_logs/2018-12-06T15_47_56_194Z-debug.log
                                  Installing ioBroker (3/4)
                              npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
                              npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                              npm WARN deprecated nodemailer@1.11.0: All versions below 4.0.1 of Nodemailer are deprecated. See https://nodemailer.com/status/
                              npm WARN deprecated mailparser@0.6.2: Mailparser versions older than v2.3.0 are deprecated
                              npm WARN deprecated mailcomposer@2.1.0: This project is unmaintained
                              npm WARN deprecated mimelib@0.3.1: This project is unmaintained
                              npm WARN deprecated buildmail@2.0.0: This project is unmaintained
                              npm ERR! code 128
                              npm ERR! Command failed: /usr/bin/git submodule update -q --init --recursive
                              npm ERR! fatal: Could not change back to '/root/.npm/_cacache/tmp/git-clone-5787434c': Keine Berechtigung
                              npm ERR!
                              npm ERR!     /root/.npm/_logs/2018-12-06T15_48_43_483Z-debug.log
                                  Finalizing installation (4/4)
                                  ioBroker was installed successfully
                                  Open http://localhost:8081 in a browser and start configuring!
                              ==========================================================================</https:>
                              and after reboot:
                              pi@ioBroker-Pi:~ $ iobroker start
                              module.js:550
                                  throw err;
                              I don't know why there is a call to the webserver
