  4. Raspberrypi install iobroker - node.js 8.12
    6.4k
27 Beiträge 6 Kommentatoren 6.3k Aufrufe
  • AlCalzoneA Offline
    AlCalzoneA Offline
    AlCalzone
    > Error: EACCES: permission denied, scandir '/root/.npm/_logs'
    Run
    sudo chown -R $(whoami) ~/.npm
    and try again.
    And try npm rebuild without sudo before resorting to sudo npm rebuild. sudo is known to cause problems.
      Arnulf
      ah thx.
      the zigbee adapter still had problems. So I decided to deinstall this adapter and reinstall it
      Now it wprks
      thank you
      Before I make any othe changes I will do a full backup tomorrow… :lol:
        Arnulf
        @AlCalzone:
        Run
        and try again.
        And try npm rebuild without sudo before resorting to sudo npm rebuild. sudo is known to cause problems. `
        hm…
        just to clarity first...
        means that the ohnership of all files and subdirectories are transferred to user "pi"?
        and I have to set this commad at /opt/iobroker ?
        and what is with iobroker? do I have to stop it first?
          AlCalzoneA Offline
          AlCalzone
          @Arnulf:
          just to clarity first…
          means that the ohnership of all files and subdirectories are transferred to user "pi"? `
          Newer npm versions have the tendency to change the ownership of the .npm folder in the current user's homedir (~). So when you execute npm install with sudo and later without, it won't be able to access ~/.npm (e.g. /home/pi/.npm) because it now belongs to root.
          The above command changes the ownership back to whomever it belonged in the first place.
          And no, you don't need to do anything with iobroker or change folder to execute that command.
            Arnulf
            I tryed n
            ==> no output, cursor prompt returns within miliseconds
            then
            npm rebuild
            from the root directory shows this
            ! pi@ioBroker-Pi:~ $ npm rebuild
            ! ajv@6.5.5 /home/pi/node_modules/ajv
            ! fast-deep-equal@2.0.1 /home/pi/node_modules/fast-deep-equal
            ! fast-json-stable-stringify@2.0.0 /home/pi/node_modules/fast-json-stable-stringify
            ! json-schema-traverse@0.4.1 /home/pi/node_modules/json-schema-traverse
            ! uri-js@4.2.2 /home/pi/node_modules/uri-js
            ! punycode@2.1.1 /home/pi/node_modules/punycode
            ! asap@2.0.6 /home/pi/node_modules/asap
            ! asn1@0.2.4 /home/pi/node_modules/asn1
            ! safer-buffer@2.1.2 /home/pi/node_modules/safer-buffer
            ! assert-plus@1.0.0 /home/pi/node_modules/assert-plus
            ! asynckit@0.4.0 /home/pi/node_modules/asynckit
            ! aws-sign2@0.7.0 /home/pi/node_modules/aws-sign2
            ! aws4@1.8.0 /home/pi/node_modules/aws4
            ! bcrypt-pbkdf@1.0.2 /home/pi/node_modules/bcrypt-pbkdf
            ! tweetnacl@0.14.5 /home/pi/node_modules/tweetnacl
            ! caseless@0.12.0 /home/pi/node_modules/caseless
            ! combined-stream@1.0.7 /home/pi/node_modules/combined-stream
            ! delayed-stream@1.0.0 /home/pi/node_modules/delayed-stream
            ! core-util-is@1.0.2 /home/pi/node_modules/core-util-is
            ! dashdash@1.14.1 /home/pi/node_modules/dashdash
            ! debug@2.6.9 /home/pi/node_modules/debug
            ! ms@2.0.0 /home/pi/node_modules/ms
            ! ecc-jsbn@0.1.2 /home/pi/node_modules/ecc-jsbn
            ! jsbn@0.1.1 /home/pi/node_modules/jsbn
            ! extend@3.0.2 /home/pi/node_modules/extend
            ! extsprintf@1.3.0 /home/pi/node_modules/extsprintf
            ! forever-agent@0.6.1 /home/pi/node_modules/forever-agent
            ! form-data@2.3.3 /home/pi/node_modules/form-data
            ! mime-types@2.1.21 /home/pi/node_modules/mime-types
            ! mime-db@1.37.0 /home/pi/node_modules/mime-db
            ! getpass@0.1.7 /home/pi/node_modules/getpass
            ! har-schema@2.0.0 /home/pi/node_modules/har-schema
            ! har-validator@5.1.3 /home/pi/node_modules/har-validator
            ! http-signature@1.2.0 /home/pi/node_modules/http-signature
            ! jsprim@1.4.1 /home/pi/node_modules/jsprim
            ! json-schema@0.2.3 /home/pi/node_modules/json-schema
            ! verror@1.10.0 /home/pi/node_modules/verror
            ! sshpk@1.15.2 /home/pi/node_modules/sshpk
            ! ip@1.1.5 /home/pi/node_modules/ip
            ! is-absolute@0.2.6 /home/pi/node_modules/is-absolute
            ! is-relative@0.2.1 /home/pi/node_modules/is-relative
            ! is-unc-path@0.1.2 /home/pi/node_modules/is-unc-path
            ! unc-path-regex@0.1.2 /home/pi/node_modules/unc-path-regex
            ! is-windows@0.2.0 /home/pi/node_modules/is-windows
            ! is-typedarray@1.0.0 /home/pi/node_modules/is-typedarray
            ! isstream@0.1.2 /home/pi/node_modules/isstream
            ! json-stringify-safe@5.0.1 /home/pi/node_modules/json-stringify-safe
            ! lodash@4.17.11 /home/pi/node_modules/lodash
            ! minimist@0.0.8 /home/pi/node_modules/minimist
            ! mkdirp@0.5.1 /home/pi/node_modules/mkdirp
            ! node-persist@2.1.0 /home/pi/node_modules/node-persist
            ! q@1.1.2 /home/pi/node_modules/q
            ! node-red-contrib-alexa-local@0.3.12 /home/pi/node_modules/node-red-contrib-alexa-local
            ! peer-ssdp@0.0.5 /home/pi/node_modules/peer-ssdp
            ! stoppable@1.0.5 /home/pi/node_modules/stoppable
            ! node-red-contrib-bool-gate@1.0.2 /home/pi/node_modules/node-red-contrib-bool-gate
            ! node-red-contrib-wemo-emulator@0.6.0 /home/pi/node_modules/node-red-contrib-wemo-emulator
            ! wemore@0.6.0 /home/pi/node_modules/wemore
            ! node-ssdp@2.9.1 /home/pi/node_modules/node-ssdp
            ! q@2.0.3 /home/pi/node_modules/wemore/node_modules/q
            ! pop-iterate@1.0.1 /home/pi/node_modules/pop-iterate
            ! weak-map@1.0.5 /home/pi/node_modules/weak-map
            ! request@2.88.0 /home/pi/node_modules/request
            ! oauth-sign@0.9.0 /home/pi/node_modules/oauth-sign
            ! performance-now@2.1.0 /home/pi/node_modules/performance-now
            ! qs@6.5.2 /home/pi/node_modules/qs
            ! safe-buffer@5.1.2 /home/pi/node_modules/safe-buffer
            ! tough-cookie@2.4.3 /home/pi/node_modules/tough-cookie
            ! psl@1.1.29 /home/pi/node_modules/psl
            ! punycode@1.4.1 /home/pi/node_modules/tough-cookie/node_modules/punycode
            ! tunnel-agent@0.6.0 /home/pi/node_modules/tunnel-agent
            ! uuid@3.3.2 /home/pi/node_modules/uuid
            ! xml2js@0.4.19 /home/pi/node_modules/xml2js
            ! sax@1.2.4 /home/pi/node_modules/sax
            ! xmlbuilder@9.0.7 /home/pi/node_modules/xmlbuilder
            but with starting point /opt/iobroker all the same sh… again
              AlCalzoneA Offline
              AlCalzone
              You have to execute "npm rebuild" in /opt/iobroker.
                Arnulf
                schrieb am zuletzt editiert von Jey Cee
                @AlCalzone:
                This is what I've done.
                And I receive same error messages as shown in my former post
                [Update]
                nice
                now, after one reboot iobroker is dead
                pi@ioBroker-Pi:/opt/iobroker $ sudo iobroker start
                module.js:550
                    throw err;
                Error: Cannot find module '/usr/local/www/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                    at Function.Module._resolveFilename (module.js:548:15)
                    at Function.Module._load (module.js:475:25)
                    at Function.Module.runMain (module.js:694:10)
                    at startup (bootstrap_node.js:204:16)
                    at bootstrap_node.js:625:3
                now (after iobroker is definately not running I tryed again npm rebuild
                log.txt
                so my try was to do chmod 777 /var/lib/dpkg because of the first messages
                E: Sperrdatei /var/lib/dpkg/lock konnte nicht geöffnet werden. - open (13: Keine Berechtigung)
                E: Sperren des Administrationsverzeichnisses (/var/lib/dpkg/) nicht möglich, sind Sie root?
                but no change. Same errors
                next try:
                 sudo apt-get install build-essential
                result:
                 build-essential ist schon die neueste Version (12.3).
                 Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                 gyp javascript-common libc-ares2 libhttp-parser2.8 libjs-inherits libjs-jquery
                 libjs-node-uuid libjs-underscore libssl-dev libssl-doc libuv1 libuv1-dev node-abbrev
                 node-ansi node-ansi-color-table node-archy node-async node-balanced-match
                 node-block-stream node-brace-expansion node-builtin-modules node-combined-stream
                 node-concat-map node-cookie-jar node-delayed-stream node-forever-agent node-form-data
                 node-fs.realpath node-fstream node-fstream-ignore node-github-url-from-git node-glob
                 node-graceful-fs node-gyp node-hosted-git-info node-inflight node-inherits node-ini
                 node-is-builtin-module node-isexe node-json-stringify-safe node-lockfile node-lru-cache
                 node-mime node-minimatch node-mkdirp node-mute-stream node-node-uuid node-nopt
                 node-normalize-package-data node-npmlog node-once node-osenv node-path-is-absolute
                 node-pseudomap node-qs node-read node-read-package-json node-request node-retry
                 node-rimraf node-semver node-sha node-slide node-spdx-correct
                 node-spdx-expression-parse node-spdx-license-ids node-tar node-tunnel-agent
                 node-underscore node-validate-npm-package-license node-which node-wrappy node-yallist
                 nodejs-doc python-pkg-resources
                 Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                 0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                then again:
                npm rebuild
                sudo npm rebuild
                both with same errors.
                Maybe I am wrong but i think with sudo I am same as root.
                Or not?
                Do I have to login as root?
                [update]
                as root the first errors are gore (lock) but rest is the same.
                Then I tryed
                root@ioBroker-Pi:/opt/iobroker#  apt-get update
                Holen:1 http://archive.raspberrypi.org/debian stretch InRelease [25,3 kB]
                Holen:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15,0 kB]
                OK:3 https://deb.nodesource.com/node_8.x stretch InRelease
                Holen:4 http://archive.raspberrypi.org/debian stretch/main armhf Packages [199 kB]
                Holen:5 http://archive.raspberrypi.org/debian stretch/ui armhf Packages [39,2 kB]
                Es wurden 279 kB in 1 s geholt (198 kB/s).
                root@ioBroker-Pi:/opt/iobroker#  apt-get upgrade -y
                Paketaktualisierung (Upgrade) wird berechnet... Fertig
                  gyp javascript-common libc-ares2 libhttp-parser2.8 libjs-inherits libjs-jquery libjs-node-uuid libjs-underscore
                  libssl-dev libssl-doc libuv1 libuv1-dev node-abbrev node-ansi node-ansi-color-table node-archy node-async
                  node-balanced-match node-block-stream node-brace-expansion node-builtin-modules node-combined-stream node-concat-map
                  node-cookie-jar node-delayed-stream node-forever-agent node-form-data node-fs.realpath node-fstream
                  node-fstream-ignore node-github-url-from-git node-glob node-graceful-fs node-gyp node-hosted-git-info node-inflight
                  node-inherits node-ini node-is-builtin-module node-isexe node-json-stringify-safe node-lockfile node-lru-cache
                  node-mime node-minimatch node-mkdirp node-mute-stream node-node-uuid node-nopt node-normalize-package-data node-npmlog
                  node-once node-osenv node-path-is-absolute node-pseudomap node-qs node-read node-read-package-json node-request
                  node-retry node-rimraf node-semver node-sha node-slide node-spdx-correct node-spdx-expression-parse
                  node-spdx-license-ids node-tar node-tunnel-agent node-underscore node-validate-npm-package-license node-which
                  node-wrappy node-yallist nodejs-doc python-pkg-resources
                Verwenden Sie »apt autoremove«, um sie zu entfernen.
                But iobroker is still dead
                • apollon77A Offline
                  But you have seen that the path in the error Waage when starting iobroker is wrong?! /var/www/… inhale no idea where this path comes from.
                  The rebuild log seems ok because authenticate-Pam is an optional package.
                  Changing rights in system stuff like Dpkg is no good idea!!
                  Gesendet vom Handy ...
                    AlCalzoneA Offline
                    AlCalzone
                    I think you guys can talk in german :D
                      Arnulf
                      it is because the thread started in english.
                      :lol:
                        Arnulf
                        @apollon77:
                        Changing rights in system stuff like Dpkg is no good idea!! `
                        sure. it was only for testing
                        maybe it is a good idea to reinstall (only) iobroker.
                        But are these instructions correct?
                        cd /opt/iobroker
                        sudo chmod 777 * -R
                        sudo npm install iobroker.js-controller --production
                          AlCalzoneA Offline
                          AlCalzone
                          @Arnulf:
                          But are these instructions correct? `
                          They are pretty outdated. See viewtopic.php?f=8&t=19111 and viewtopic.php?f=8&t=19209
                          Since your installation is pretty fucked, I think one of the cleanest ways to get an almost fresh installation is deleting the old node_modules
                          cd /opt/iobroker
                          sudo rm -rf node_modules
                          and performing a clean install (while keeping iobroker-data)
                          curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/stable-installer/installer.sh | bash -
                          ioBroker should then detect which adapters are missing and install them again.
                            Arnulf
                            hmmm
                            pi@ioBroker-Pi:/opt/iobroker $ cd /opt/iobroker
                            pi@ioBroker-Pi:/opt/iobroker $ sudo rm -rf node_modules
                            pi@ioBroker-Pi:/opt/iobroker $ curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/stable-installer/installer.sh | bash -
                                Welcome to the ioBroker installer!
                                You might need to enter your password a couple of times.
                                Creating ioBroker directory (1/4)
                                Downloading installation files (2/4)
                            npm ERR! code ENOSELF
                            npm ERR! Refusing to install package with name "iobroker" under a package
                            npm ERR! also called "iobroker". Did you name your project the same
                            npm ERR! as the dependency you're installing?
                            npm ERR!
                            npm ERR! For more information, see:
                            npm ERR!     <https: docs.npmjs.com/cli/install#limitations-of-npms-install-algorithm="">npm ERR! A complete log of this run can be found in:
                            npm ERR!     /home/pi/.npm/_logs/2018-12-06T15_47_56_194Z-debug.log
                                Installing ioBroker (3/4)
                            npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
                            npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                            npm WARN deprecated nodemailer@1.11.0: All versions below 4.0.1 of Nodemailer are deprecated. See https://nodemailer.com/status/
                            npm WARN deprecated mailparser@0.6.2: Mailparser versions older than v2.3.0 are deprecated
                            npm WARN deprecated mailcomposer@2.1.0: This project is unmaintained
                            npm WARN deprecated mimelib@0.3.1: This project is unmaintained
                            npm WARN deprecated buildmail@2.0.0: This project is unmaintained
                            npm ERR! code 128
                            npm ERR! Command failed: /usr/bin/git submodule update -q --init --recursive
                            npm ERR! fatal: Could not change back to '/root/.npm/_cacache/tmp/git-clone-5787434c': Keine Berechtigung
                            npm ERR!
                            npm ERR!     /root/.npm/_logs/2018-12-06T15_48_43_483Z-debug.log
                                Finalizing installation (4/4)
                                ioBroker was installed successfully
                                Open http://localhost:8081 in a browser and start configuring!
                            ==========================================================================</https:>
                            and after reboot:
                            pi@ioBroker-Pi:~ $ iobroker start
                            module.js:550
                                throw err;
                            I don't know why there is a call to the webserver
