  4. [Yeelight-2 Adapter] Rebuild Version 0.9.X
91 Beiträge 21 Kommentatoren 14.8k Aufrufe 5 Beobachtet
  • H Offline
    hanniko
    2018-11-25 16:17:41.672 - [32minfo[39m: yeelight-2.0 cleaned everything up…
    2018-11-25 16:17:41.685 - [32minfo[39m: yeelight-2.0 terminating
    2018-11-25 16:17:41.711 - [32minfo[39m: host.hjkDiskStation instance system.adapter.yeelight-2.0 terminated with code 0 (OK)
    2018-11-25 16:17:44.178 - [32minfo[39m: host.hjkDiskStation instance system.adapter.yeelight-2.0 started with pid 19394
    2018-11-25 16:17:45.255 - [34mdebug[39m: yeelight-2.0 objectDB connected
    2018-11-25 16:17:45.311 - [34mdebug[39m: yeelight-2.0 statesDB connected
    2018-11-25 16:17:45.420 - [32minfo[39m: yeelight-2.0 starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
    2018-11-25 16:17:45.429 - [34mdebug[39m: yeelight-2.0 DEVICES IN CONFIG: [{"name":"color1","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}]
    2018-11-25 16:17:45.453 - [34mdebug[39m: yeelight-2.0 DEVICES IN OBJECTS: {"yeelight-2.0.color1":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"color1","type":"color"},"from":"system.adapter.yeelight-2.0","ts":1543096628806,"_id":"yeelight-2.0.color1","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"enums":{}}}
    2018-11-25 16:17:45.453 - [34mdebug[39m: yeelight-2.0 DEVICES IN OBJECTS FOUND: 1
    2018-11-25 16:17:45.453 - [34mdebug[39m: yeelight-2.0 OBJ_ELEMENT: yeelight-2.0.color1
    2018-11-25 16:17:45.463 - [34mdebug[39m: yeelight-2.0 OLD CONF. FROM OBJ: {"name":"color1","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
    2018-11-25 16:17:45.466 - [34mdebug[39m: yeelight-2.0 SMARTNAME:
    2018-11-25 16:17:47.475 - [34mdebug[39m: yeelight-2.0 YEELIGHT FOUND: 192.168.1.36:55443 id: 0x000000000000000 model: color
    2018-11-25 16:17:57.726 - [32minfo[39m: host.hjkDiskStation object change system.adapter.yeelight-2.0
    2018-11-25 16:17:57.729 - [32minfo[39m: yeelight-2.0 cleaned everything up…
    2018-11-25 16:17:57.727 - [32minfo[39m: host.hjkDiskStation stopInstance system.adapter.yeelight-2.0
    2018-11-25 16:17:57.727 - [32minfo[39m: host.hjkDiskStation stopInstance system.adapter.yeelight-2.0 killing pid 19394
    2018-11-25 16:17:57.736 - [32minfo[39m: yeelight-2.0 terminating
    2018-11-25 16:17:57.755 - [32minfo[39m: host.hjkDiskStation instance system.adapter.yeelight-2.0 terminated with code 0 (OK)
    2018-11-25 16:18:00.240 - [32minfo[39m: host.hjkDiskStation instance system.adapter.yeelight-2.0 started with pid 19410
    2018-11-25 16:18:01.230 - [34mdebug[39m: yeelight-2.0 objectDB connected
    2018-11-25 16:18:01.301 - [34mdebug[39m: yeelight-2.0 statesDB connected
    2018-11-25 16:18:01.410 - [32minfo[39m: yeelight-2.0 starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
    2018-11-25 16:18:01.419 - [34mdebug[39m: yeelight-2.0 DEVICES IN CONFIG: [{"name":"color1","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}]
    2018-11-25 16:18:01.456 - [34mdebug[39m: yeelight-2.0 DEVICES IN OBJECTS: {"yeelight-2.0.color1":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"color1","type":"color"},"from":"system.adapter.yeelight-2.0","ts":1543096628806,"_id":"yeelight-2.0.color1","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"enums":{}}}
    2018-11-25 16:18:01.457 - [34mdebug[39m: yeelight-2.0 DEVICES IN OBJECTS FOUND: 1
    2018-11-25 16:18:01.457 - [34mdebug[39m: yeelight-2.0 OBJ_ELEMENT: yeelight-2.0.color1
    2018-11-25 16:18:01.462 - [34mdebug[39m: yeelight-2.0 OLD CONF. FROM OBJ: {"name":"color1","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
    2018-11-25 16:18:01.465 - [34mdebug[39m: yeelight-2.0 SMARTNAME:
    2018-11-25 16:18:03.477 - [34mdebug[39m: yeelight-2.0 YEELIGHT FOUND: 192.168.1.36:55443 id: 0x000000000000000 model: color
    2018-11-25 16:19:37.558 - [34mdebug[39m: yeelight-2.0 system.adapter.admin.0: logging false
    2018-11-25 16:19:43.591 - [32minfo[39m: host.hjkDiskStation object change system.adapter.firetv.0
    2018-11-25 16:20:03.478 - [34mdebug[39m: yeelight-2.0 YEELIGHT OFFLINE: 0x000000000000000
    2018-11-25 16:20:13.706 - [34mdebug[39m: yeelight-2.0 system.adapter.admin.0: logging true
    2018-11-25 16:21:03.493 - [34mdebug[39m: yeelight-2.0 YEELIGHT OFFLINE: 0x000000000000000
    2018-11-25 16:22:03.496 - [34mdebug[39m: yeelight-2.0 YEELIGHT OFFLINE: 0x000000000000000
    2018-11-25 16:22:06.730 - [34mdebug[39m: yeelight-2.0 NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"power":"on"}}
    2018-11-25 16:22:06.731 - [34mdebug[39m: yeelight-2.0 DEVICE FOUND SET NOTIFY STATE: {"name":"color1","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
    2018-11-25 16:22:23.181 - [34mdebug[39m: yeelight-2.0 NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"power":"off"}}
    2018-11-25 16:22:23.182 - [34mdebug[39m: yeelight-2.0 DEVICE FOUND SET NOTIFY STATE: {"name":"color1","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
    2018-11-25 16:22:26.178 - [34mdebug[39m: yeelight-2.0 NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"power":"on"}}
    2018-11-25 16:22:26.179 - [34mdebug[39m: yeelight-2.0 DEVICE FOUND SET NOTIFY STATE: {"name":"color1","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
    2018-11-25 16:22:54.606 - [34mdebug[39m: yeelight-2.0 NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"flow_params":"0,1,4000,1,65515,55","flowing":1}}
    2018-11-25 16:22:54.607 - [34mdebug[39m: yeelight-2.0 DEVICE FOUND SET NOTIFY STATE: {"name":"color1","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
    2018-11-25 16:23:03.500 - [34mdebug[39m: yeelight-2.0 YEELIGHT OFFLINE: 0x000000000000000
    2018-11-25 16:23:18.266 - [34mdebug[39m: yeelight-2.0 system.adapter.admin.0: logging false
    2018-11-25 16:24:03.504 - [34mdebug[39m: yeelight-2.0 YEELIGHT OFFLINE: 0x000000000000000
    2018-11-25 16:24:05.927 - [34mdebug[39m: yeelight-2.0 system.adapter.admin.0: logging true
    2018-11-25 16:24:21.375 - [34mdebug[39m: yeelight-2.0 SEND SCENE: id:0x000000000000000, state: happy_birthday, value: true
    2018-11-25 16:24:22.114 - [34mdebug[39m: yeelight-2.0 system.adapter.admin.0: logging false
    2018-11-25 16:24:22.312 - [34mdebug[39m: yeelight-2.0 SEND SCENE: id:0x000000000000000, state: happy_birthday, value: true
    2018-11-25 16:24:32.179 - [34mdebug[39m: yeelight-2.0 system.adapter.admin.0: logging true
    2018-11-25 16:24:55.823 - [34mdebug[39m: yeelight-2.0 NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"bright":50,"ct":3000,"flowing":0,"color_mode":2}}
    2018-11-25 16:24:55.826 - [34mdebug[39m: yeelight-2.0 DEVICE FOUND SET NOTIFY STATE: {"name":"color1","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
    2018-11-25 16:25:00.021 - [32minfo[39m: host.hjkDiskStation instance system.adapter.tankerkoenig.0 started with pid 19454
    2018-11-25 16:25:01.714 - [32minfo[39m: tankerkoenig.0 starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v4.9.1
    2018-11-25 16:25:02.253 - [32minfo[39m: host.hjkDiskStation instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
    2018-11-25 16:25:03.508 - [34mdebug[39m: yeelight-2.0 YEELIGHT OFFLINE: 0x000000000000000
    2018-11-25 16:26:03.512 - [34mdebug[39m: yeelight-2.0 YEELIGHT OFFLINE: 0x000000000000000
    2018-11-25 16:27:03.515 - [34mdebug[39m: yeelight-2.0 YEELIGHT OFFLINE: 0x000000000000000
    2018-11-25 16:27:27.898 - [32minfo[39m: hm-rpc.1 xmlrpc <- listDevices ["hm-rpc.1"]
    2018-11-25 16:27:27.907 - [32minfo[39m: hm-rpc.1 xmlrpc -> 0 devices
    2018-11-25 16:27:28.139 - [32minfo[39m: hm-rpc.1 xmlrpc <- newDevices 15
    2018-11-25 16:27:28.155 - [32minfo[39m: hm-rpc.1 new HmIP devices/channels after filter: 0
    2018-11-25 16:28:03.519 - [34mdebug[39m: yeelight-2.0 YEELIGHT OFFLINE: 0x000000000000000
    2018-11-25 16:29:03.522 - [34mdebug[39m: yeelight-2.0 YEELIGHT OFFLINE: 0x000000000000000
    2018-11-25 16:30:03.526 - [34mdebug[39m: yeelight-2.0 YEELIGHT OFFLINE: 0x000000000000000
    2018-11-25 16:31:03.530 - [34mdebug[39m: yeelight-2.0 YEELIGHT OFFLINE: 0x000000000000000
    2018-11-25 16:32:03.532 - [34mdebug[39m: yeelight-2.0 YEELIGHT OFFLINE: 0x000000000000000
    2018-11-25 16:33:03.535 - [34mdebug[39m: yeelight-2.0 YEELIGHT OFFLINE: 0x000000000000000
    2018-11-25 16:34:03.538 - [34mdebug[39m: yeelight-2.0 YEELIGHT OFFLINE: 0x000000000000000
    2018-11-25 16:35:03.542 - [34mdebug[39m: yeelight-2.0 YEELIGHT OFFLINE: 0x000000000000000
    2018-11-25 16:36:03.546 - [34mdebug[39m: yeelight-2.0 YEELIGHT OFFLINE: 0x000000000000000
    2018-11-25 16:37:03.548 - [34mdebug[39m: yeelight-2.0 YEELIGHT OFFLINE: 0x000000000000000
    2018-11-25 16:38:03.552 - [34mdebug[39m: yeelight-2.0 YEELIGHT OFFLINE: 0x000000000000000
    2018-11-25 16:39:03.556 - [34mdebug[39m: yeelight-2.0 YEELIGHT OFFLINE: 0x000000000000000
    2018-11-25 16:39:13.527 - [34mdebug[39m: yeelight-2.0 NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"power":"off"}}
    2018-11-25 16:39:13.528 - [34mdebug[39m: yeelight-2.0 DEVICE FOUND SET NOTIFY STATE: {"name":"color1","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
    2018-11-25 16:40:03.560 - [34mdebug[39m: yeelight-2.0 YEELIGHT OFFLINE: 0x000000000000000
    • ? Offline
      deine Yeelights sind offline, sagt das Protokoll, funktionieren Sie denn in dem Moment über die App??
      Hatte mit den Yeelights das gleiche, nach einem Powerreset gingen sie wieder, hab sie verkauft und Sonoff B1 - die funktionieren zuverlässig, sind aber nicht so hell… :-/
      • H Offline
        hanniko
        Über die App klappt die Steuerung einwandfrei. Die Änderungen über die App und das ein bzw. aus Schalten wird auch im Logfile angezeigt. Nur im IO Broker gibt es gar keinen State oder Button oder sonst etwas, womit ich die Lampe steuern könnte.
        • MeistertrM Offline
          MeistertrM Offline
          Meistertr
          @hanniko:
          Über die App klappt die Steuerung einwandfrei. Die Änderungen über die App und das ein bzw. aus Schalten wird auch im Logfile angezeigt. Nur im IO Broker gibt es gar keinen State oder Button oder sonst etwas, womit ich die Lampe steuern könnte. `
          schalte den adapter mal ab, und lösche den yeelight ordner unter objekte. dann wieder einschalten. dann sollten der ordner neu erstellt werden mit den states
          • H Offline
            hanniko
            control bleibt weiterhin leer
              MeistertrM Offline
              Meistertr
              @hanniko:
              control bleibt weiterhin leer ` Kannst du das nochmal durchfühten und vom Start an den log posten
              Gesendet von meinem Handy
              • H Offline
                hanniko
                Ich hatte zuerst alles gelöscht, und die Lampe zurück gesetzt, dann vergessen die Lan Steuerung zu aktivieren.
                Danach wurde die Lampe erkannt, es gab aber immer noch nichts unter control.
                yeelight-2.0 2018-11-25 20:01:45.692 debug YEELIGHT FOUND: 192.168.1.36:55443 id: 0x000000000000000 model: color
                yeelight-2.0 2018-11-25 20:01:43.678 debug SMARTNAME:
                yeelight-2.0 2018-11-25 20:01:43.676 debug OLD CONF. FROM OBJ: {"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
                yeelight-2.0 2018-11-25 20:01:43.672 debug OBJ_ELEMENT: yeelight-2.0.color2
                yeelight-2.0 2018-11-25 20:01:43.672 debug DEVICES IN OBJECTS FOUND: 1
                yeelight-2.0 2018-11-25 20:01:43.671 debug DEVICES IN OBJECTS: {"yeelight-2.0.color2":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"color2","type":"color"},"from":"system.adapter.yeelight-2.0","ts":1543
                yeelight-2.0 2018-11-25 20:01:43.638 debug DEVICES IN CONFIG: [{"name":"color2","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright",
                yeelight-2.0 2018-11-25 20:01:43.628 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
                yeelight-2.0 2018-11-25 20:01:43.522 debug statesDB connected
                yeelight-2.0 2018-11-25 20:01:43.454 debug objectDB connected
                yeelight-2.0 2018-11-25 20:01:14.397 info terminating
                yeelight-2.0 2018-11-25 20:01:14.392 info cleaned everything up…
                yeelight-2.0 2018-11-25 20:01:14.391 error at Timer.listOnTimeout (timers.js:92:15)
                yeelight-2.0 2018-11-25 20:01:14.391 error at null._onTimeout (/opt/iobroker/node_modules/iobroker.yeelight-2/main.js:481:74)
                yeelight-2.0 2018-11-25 20:01:14.391 error at YeelightSearch.addInitLights (/opt/iobroker/node_modules/yeelight-wifi/build/index.js:103:22)
                yeelight-2.0 2018-11-25 20:01:14.391 error at new Yeelight (/opt/iobroker/node_modules/yeelight-wifi/build/Yeelight.js:125:18)
                yeelight-2.0 2018-11-25 20:01:14.391 error at Socket.connect (net.js:888:37)
                yeelight-2.0 2018-11-25 20:01:14.391 error at Socket.connect (net.js:925:5)
                yeelight-2.0 2018-11-25 20:01:14.391 error at lookupAndConnect (net.js:946:13)
                yeelight-2.0 2018-11-25 20:01:14.391 error TypeError: port should be a number or string: null
                yeelight-2.0 2018-11-25 20:01:14.389 error uncaught exception: port should be a number or string: null
                yeelight-2.0 2018-11-25 20:01:12.368 debug SMARTNAME:
                yeelight-2.0 2018-11-25 20:01:12.366 debug OLD CONF. FROM OBJ: {"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
                yeelight-2.0 2018-11-25 20:01:12.362 debug OBJ_ELEMENT: yeelight-2.0.color2
                yeelight-2.0 2018-11-25 20:01:12.362 debug DEVICES IN OBJECTS FOUND: 1
                yeelight-2.0 2018-11-25 20:01:12.362 debug DEVICES IN OBJECTS: {"yeelight-2.0.color2":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"color2","type":"color"},"from":"system.adapter.yeelight-2.0","ts":1543
                yeelight-2.0 2018-11-25 20:01:12.333 debug DEVICES IN CONFIG: [{"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
                yeelight-2.0 2018-11-25 20:01:12.324 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
                yeelight-2.0 2018-11-25 20:01:12.217 debug statesDB connected
                yeelight-2.0 2018-11-25 20:01:12.157 debug objectDB connected
                yeelight-2.0 2018-11-25 20:00:41.136 info terminating
                yeelight-2.0 2018-11-25 20:00:41.131 info cleaned everything up...
                yeelight-2.0 2018-11-25 20:00:41.130 error at Timer.listOnTimeout (timers.js:92:15)
                yeelight-2.0 2018-11-25 20:00:41.130 error at null._onTimeout (/opt/iobroker/node_modules/iobroker.yeelight-2/main.js:481:74)
                yeelight-2.0 2018-11-25 20:00:41.130 error at YeelightSearch.addInitLights (/opt/iobroker/node_modules/yeelight-wifi/build/index.js:103:22)
                yeelight-2.0 2018-11-25 20:00:41.130 error at new Yeelight (/opt/iobroker/node_modules/yeelight-wifi/build/Yeelight.js:125:18)
                yeelight-2.0 2018-11-25 20:00:41.130 error at Socket.connect (net.js:888:37)
                yeelight-2.0 2018-11-25 20:00:41.130 error at Socket.connect (net.js:925:5)
                yeelight-2.0 2018-11-25 20:00:41.130 error at lookupAndConnect (net.js:946:13)
                yeelight-2.0 2018-11-25 20:00:41.130 error TypeError: port should be a number or string: null
                yeelight-2.0 2018-11-25 20:00:41.128 error uncaught exception: port should be a number or string: null
                yeelight-2.0 2018-11-25 20:00:39.107 debug SMARTNAME:
                yeelight-2.0 2018-11-25 20:00:39.105 debug OLD CONF. FROM OBJ: {"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
                yeelight-2.0 2018-11-25 20:00:39.101 debug OBJ_ELEMENT: yeelight-2.0.color2
                yeelight-2.0 2018-11-25 20:00:39.100 debug DEVICES IN OBJECTS FOUND: 1
                yeelight-2.0 2018-11-25 20:00:39.100 debug DEVICES IN OBJECTS: {"yeelight-2.0.color2":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"color2","type":"color"},"from":"system.adapter.yeelight-2.0","ts":1543
                yeelight-2.0 2018-11-25 20:00:39.038 debug DEVICES IN CONFIG: [{"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
                yeelight-2.0 2018-11-25 20:00:39.028 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
                yeelight-2.0 2018-11-25 20:00:38.921 debug statesDB connected
                yeelight-2.0 2018-11-25 20:00:38.868 debug objectDB connected
                yeelight-2.0 2018-11-25 20:00:07.838 info terminating
                yeelight-2.0 2018-11-25 20:00:07.807 info cleaned everything up...
                yeelight-2.0 2018-11-25 20:00:07.806 error at Timer.listOnTimeout (timers.js:92:15)
                yeelight-2.0 2018-11-25 20:00:07.806 error at null._onTimeout (/opt/iobroker/node_modules/iobroker.yeelight-2/main.js:481:74)
                yeelight-2.0 2018-11-25 20:00:07.806 error at YeelightSearch.addInitLights (/opt/iobroker/node_modules/yeelight-wifi/build/index.js:103:22)
                yeelight-2.0 2018-11-25 20:00:07.806 error at new Yeelight (/opt/iobroker/node_modules/yeelight-wifi/build/Yeelight.js:125:18)
                yeelight-2.0 2018-11-25 20:00:07.806 error at Socket.connect (net.js:888:37)
                yeelight-2.0 2018-11-25 20:00:07.806 error at Socket.connect (net.js:925:5)
                yeelight-2.0 2018-11-25 20:00:07.806 error at lookupAndConnect (net.js:946:13)
                yeelight-2.0 2018-11-25 20:00:07.806 error TypeError: port should be a number or string: null
                yeelight-2.0 2018-11-25 20:00:07.803 error uncaught exception: port should be a number or string: null
                yeelight-2.0 2018-11-25 20:00:07.776 debug CREATE DEVICE: yeelight-2.0.color2
                yeelight-2.0 2018-11-25 20:00:05.771 debug DEVICES IN OBJECTS FOUND: 0
                yeelight-2.0 2018-11-25 20:00:05.771 debug DEVICES IN OBJECTS: {}
                yeelight-2.0 2018-11-25 20:00:05.738 debug DEVICES IN CONFIG: [{"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
                yeelight-2.0 2018-11-25 20:00:05.729 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
                yeelight-2.0 2018-11-25 20:00:05.619 debug statesDB connected
                yeelight-2.0 2018-11-25 20:00:05.539 debug objectDB connected
                yeelight-2.0 2018-11-25 19:59:46.714 info terminating
                yeelight-2.0 2018-11-25 19:59:46.705 info cleaned everything up...
                yeelight-2.0 2018-11-25 19:59:46.666 debug SMARTNAME:
                yeelight-2.0 2018-11-25 19:59:46.665 debug OLD CONF. FROM OBJ: {"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
                yeelight-2.0 2018-11-25 19:59:46.662 debug OBJ_ELEMENT: yeelight-2.0.color2
                yeelight-2.0 2018-11-25 19:59:46.662 debug DEVICES IN OBJECTS FOUND: 1
                yeelight-2.0 2018-11-25 19:59:46.661 debug DEVICES IN OBJECTS: {"yeelight-2.0.color2":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"color2","type":"color"},"from":"system.adapter.yeelight-2.0","ts":1543
                yeelight-2.0 2018-11-25 19:59:46.631 debug DEVICES IN CONFIG: [{"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
                yeelight-2.0 2018-11-25 19:59:46.622 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
                yeelight-2.0 2018-11-25 19:59:46.515 debug statesDB connected
                yeelight-2.0 2018-11-25 19:59:46.460 debug objectDB connected
                yeelight-2.0 2018-11-25 19:59:12.497 info terminating
                yeelight-2.0 2018-11-25 19:59:12.406 info cleaned everything up...
                yeelight-2.0 2018-11-25 19:59:12.405 error at Timer.listOnTimeout (timers.js:92:15)
                yeelight-2.0 2018-11-25 19:59:12.405 error at null._onTimeout (/opt/iobroker/node_modules/iobroker.yeelight-2/main.js:481:74)
                yeelight-2.0 2018-11-25 19:59:12.405 error at YeelightSearch.addInitLights (/opt/iobroker/node_modules/yeelight-wifi/build/index.js:103:22)
                yeelight-2.0 2018-11-25 19:59:12.405 error at new Yeelight (/opt/iobroker/node_modules/yeelight-wifi/build/Yeelight.js:125:18)
                yeelight-2.0 2018-11-25 19:59:12.405 error at Socket.connect (net.js:888:37)
                yeelight-2.0 2018-11-25 19:59:12.405 error at Socket.connect (net.js:925:5)
                yeelight-2.0 2018-11-25 19:59:12.405 error at lookupAndConnect (net.js:946:13)
                yeelight-2.0 2018-11-25 19:59:12.405 error TypeError: port should be a number or string: null
                yeelight-2.0 2018-11-25 19:59:12.403 error uncaught exception: port should be a number or string: null
                yeelight-2.0 2018-11-25 19:59:12.372 debug CREATE DEVICE: yeelight-2.0.color2
                yeelight-2.0 2018-11-25 19:59:10.368 debug DEVICES IN OBJECTS FOUND: 0
                yeelight-2.0 2018-11-25 19:59:10.368 debug DEVICES IN OBJECTS: {}
                yeelight-2.0 2018-11-25 19:59:10.330 debug DEVICES IN CONFIG: [{"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
                yeelight-2.0 2018-11-25 19:59:10.320 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
                yeelight-2.0 2018-11-25 19:59:10.212 debug statesDB connected
                yeelight-2.0 2018-11-25 19:59:10.155 debug objectDB connected
                yeelight-2.0 2018-11-25 19:58:50.951 error adapter disabled
                yeelight-2.0 2018-11-25 19:58:50.846 debug statesDB connected
                yeelight-2.0 2018-11-25 19:58:50.780 debug objectDB connected
                yeelight-2.0 2018-11-25 19:58:19.770 info terminating
                yeelight-2.0 2018-11-25 19:58:19.765 info cleaned everything up...
                yeelight-2.0 2018-11-25 19:58:19.764 error at Timer.listOnTimeout (timers.js:92:15)
                yeelight-2.0 2018-11-25 19:58:19.764 error at null._onTimeout (/opt/iobroker/node_modules/iobroker.yeelight-2/main.js:481:74)
                yeelight-2.0 2018-11-25 19:58:19.764 error at YeelightSearch.addInitLights (/opt/iobroker/node_modules/yeelight-wifi/build/index.js:103:22)
                yeelight-2.0 2018-11-25 19:58:19.764 error at new Yeelight (/opt/iobroker/node_modules/yeelight-wifi/build/Yeelight.js:125:18)
                yeelight-2.0 2018-11-25 19:58:19.764 error at Socket.connect (net.js:888:37)
                yeelight-2.0 2018-11-25 19:58:19.764 error at Socket.connect (net.js:925:5)
                yeelight-2.0 2018-11-25 19:58:19.764 error at lookupAndConnect (net.js:946:13)
                yeelight-2.0 2018-11-25 19:58:19.764 error TypeError: port should be a number or string: null
                yeelight-2.0 2018-11-25 19:58:19.762 error uncaught exception: port should be a number or string: null
                yeelight-2.0 2018-11-25 19:58:17.743 debug SMARTNAME:
                yeelight-2.0 2018-11-25 19:58:17.742 debug OLD CONF. FROM OBJ: {"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
                yeelight-2.0 2018-11-25 19:58:17.737 debug OBJ_ELEMENT: yeelight-2.0.color2
                yeelight-2.0 2018-11-25 19:58:17.737 debug DEVICES IN OBJECTS FOUND: 1
                yeelight-2.0 2018-11-25 19:58:17.737 debug DEVICES IN OBJECTS: {"yeelight-2.0.color2":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"color2","type":"color"},"from":"system.adapter.yeelight-2.0","ts":1543
                yeelight-2.0 2018-11-25 19:58:17.704 debug DEVICES IN CONFIG: [{"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
                yeelight-2.0 2018-11-25 19:58:17.694 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
                yeelight-2.0 2018-11-25 19:58:17.588 debug statesDB connected
                yeelight-2.0 2018-11-25 19:58:17.536 debug objectDB connected
                yeelight-2.0 2018-11-25 19:58:14.882 info terminating
                yeelight-2.0 2018-11-25 19:58:14.873 info cleaned everything up...
                yeelight-2.0 2018-11-25 19:58:13.186 debug SMARTNAME:
                yeelight-2.0 2018-11-25 19:58:13.184 debug OLD CONF. FROM OBJ: {"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
                yeelight-2.0 2018-11-25 19:58:13.180 debug OBJ_ELEMENT: yeelight-2.0.color2
                yeelight-2.0 2018-11-25 19:58:13.180 debug DEVICES IN OBJECTS FOUND: 1
                yeelight-2.0 2018-11-25 19:58:13.179 debug DEVICES IN OBJECTS: {"yeelight-2.0.color2":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"color2","type":"color"},"from":"system.adapter.yeelight-2.0","ts":1543
                yeelight-2.0 2018-11-25 19:58:13.142 debug DEVICES IN CONFIG: [{"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
                yeelight-2.0 2018-11-25 19:58:13.132 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
                yeelight-2.0 2018-11-25 19:58:13.028 debug statesDB connected
                yeelight-2.0 2018-11-25 19:58:12.970 debug objectDB connected
                yeelight-2.0 2018-11-25 19:57:55.622 info terminating
                yeelight-2.0 2018-11-25 19:57:55.616 info cleaned everything up...
                yeelight-2.0 2018-11-25 19:57:55.615 error at Timer.listOnTimeout (timers.js:92:15)
                yeelight-2.0 2018-11-25 19:57:55.615 error at null._onTimeout (/opt/iobroker/node_modules/iobroker.yeelight-2/main.js:481:74)
                yeelight-2.0 2018-11-25 19:57:55.615 error at YeelightSearch.addInitLights (/opt/iobroker/node_modules/yeelight-wifi/build/index.js:103:22)
                yeelight-2.0 2018-11-25 19:57:55.615 error at new Yeelight (/opt/iobroker/node_modules/yeelight-wifi/build/Yeelight.js:125:18)
                yeelight-2.0 2018-11-25 19:57:55.615 error at Socket.connect (net.js:888:37)
                yeelight-2.0 2018-11-25 19:57:55.615 error at Socket.connect (net.js:925:5)
                yeelight-2.0 2018-11-25 19:57:55.615 error at lookupAndConnect (net.js:946:13)
                yeelight-2.0 2018-11-25 19:57:55.615 error TypeError: port should be a number or string: null
                yeelight-2.0 2018-11-25 19:57:55.613 error uncaught exception: port should be a number or string: null
                yeelight-2.0 2018-11-25 19:57:53.595 debug SMARTNAME:
                yeelight-2.0 2018-11-25 19:57:53.593 debug OLD CONF. FROM OBJ: {"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
                yeelight-2.0 2018-11-25 19:57:53.590 debug OBJ_ELEMENT: yeelight-2.0.color2
                yeelight-2.0 2018-11-25 19:57:53.589 debug DEVICES IN OBJECTS FOUND: 1
                yeelight-2.0 2018-11-25 19:57:53.589 debug DEVICES IN OBJECTS: {"yeelight-2.0.color2":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"color2","type":"color"},"from":"system.adapter.yeelight-2.0","ts":1543
                yeelight-2.0 2018-11-25 19:57:53.552 debug DEVICES IN CONFIG: [{"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
                yeelight-2.0 2018-11-25 19:57:53.543 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
                yeelight-2.0 2018-11-25 19:57:53.435 debug statesDB connected
                yeelight-2.0 2018-11-25 19:57:53.343 debug objectDB connected
                yeelight-2.0 2018-11-25 19:57:45.240 info terminating
                yeelight-2.0 2018-11-25 19:57:45.235 info cleaned everything up...
                yeelight-2.0 2018-11-25 19:57:45.234 error at Timer.listOnTimeout (timers.js:92:15)
                yeelight-2.0 2018-11-25 19:57:45.234 error at null._onTimeout (/opt/iobroker/node_modules/iobroker.yeelight-2/main.js:481:74)
                yeelight-2.0 2018-11-25 19:57:45.234 error at YeelightSearch.addInitLights (/opt/iobroker/node_modules/yeelight-wifi/build/index.js:103:22)
                yeelight-2.0 2018-11-25 19:57:45.234 error at new Yeelight (/opt/iobroker/node_modules/yeelight-wifi/build/Yeelight.js:125:18)
                yeelight-2.0 2018-11-25 19:57:45.234 error at Socket.connect (net.js:888:37)
                yeelight-2.0 2018-11-25 19:57:45.234 error at Socket.connect (net.js:925:5)
                yeelight-2.0 2018-11-25 19:57:45.234 error at lookupAndConnect (net.js:946:13)
                yeelight-2.0 2018-11-25 19:57:45.234 error TypeError: port should be a number or string: null
                yeelight-2.0 2018-11-25 19:57:45.233 error uncaught exception: port should be a number or string: null
                yeelight-2.0 2018-11-25 19:57:43.215 debug SMARTNAME:
                yeelight-2.0 2018-11-25 19:57:43.212 debug OLD CONF. FROM OBJ: {"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
                yeelight-2.0 2018-11-25 19:57:43.209 debug OBJ_ELEMENT: yeelight-2.0.color2
                yeelight-2.0 2018-11-25 19:57:43.208 debug DEVICES IN OBJECTS FOUND: 1
                yeelight-2.0 2018-11-25 19:57:43.208 debug DEVICES IN OBJECTS: {"yeelight-2.0.color2":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"color2","type":"color"},"from":"system.adapter.yeelight-2.0","ts":1543
                yeelight-2.0 2018-11-25 19:57:43.176 debug DEVICES IN CONFIG: [{"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
                yeelight-2.0 2018-11-25 19:57:43.166 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
                yeelight-2.0 2018-11-25 19:57:43.060 debug statesDB connected
                yeelight-2.0 2018-11-25 19:57:43.002 debug objectDB connected
                • H Offline
                  hanniko
                  oder kann es an meiner node Version 4.9.1 liegen?
                  • H Offline
                    hanniko
                    yeelight-2.0 2018-11-25 20:25:28.778 debug YEELIGHT OFFLINE: 0x0000000007c48da4
                    yeelight-2.0 2018-11-25 20:24:28.775 debug YEELIGHT OFFLINE: 0x0000000007c48da4
                    yeelight-2.0 2018-11-25 20:23:28.772 debug YEELIGHT OFFLINE: 0x0000000007c48da4
                    yeelight-2.0 2018-11-25 20:22:28.766 debug YEELIGHT OFFLINE: 0x0000000007c48da4
                    yeelight-2.0 2018-11-25 20:20:28.762 debug YEELIGHT FOUND: 192.168.1.36:55443 id: 0x0000000007c48da4 model: color
                    yeelight-2.0 2018-11-25 20:20:26.748 debug SMARTNAME:
                    yeelight-2.0 2018-11-25 20:20:26.746 debug OLD CONF. FROM OBJ: {"name":"color2","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright",
                    yeelight-2.0 2018-11-25 20:20:26.743 debug OBJ_ELEMENT: yeelight-2.0.color2
                    yeelight-2.0 2018-11-25 20:20:26.742 debug DEVICES IN OBJECTS FOUND: 1
                    yeelight-2.0 2018-11-25 20:20:26.742 debug DEVICES IN OBJECTS: {"yeelight-2.0.color2":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"color2","type":"color"},"from":"system.adapter.yeelight-2.0","ts":1543
                    yeelight-2.0 2018-11-25 20:20:26.705 debug DEVICES IN CONFIG: [{"name":"color2","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x0000000007c48da4"}]
                    yeelight-2.0 2018-11-25 20:20:26.696 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
                    yeelight-2.0 2018-11-25 20:20:26.589 debug statesDB connected
                    yeelight-2.0 2018-11-25 20:20:26.503 debug objectDB connected
                    yeelight-2.0 2018-11-25 20:20:23.004 info terminating
                    yeelight-2.0 2018-11-25 20:20:22.997 info cleaned everything up…
                    yeelight-2.0 2018-11-25 20:20:15.940 debug DEVICE FOUND SET NOTIFY STATE: {"name":"color2","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","s
                    yeelight-2.0 2018-11-25 20:20:15.938 debug NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"power":"on"}}
                    yeelight-2.0 2018-11-25 20:20:14.439 debug DEVICE FOUND SET NOTIFY STATE: {"name":"color2","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","s
                    yeelight-2.0 2018-11-25 20:20:14.437 debug NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"power":"off"}}
                    yeelight-2.0 2018-11-25 20:20:11.107 debug sendTo "discovery" to system.adapter.admin.0 from system.adapter.yeelight-2.0: [{"model":"color","host":"192.168.1.36","port":"55443","id":"0x0000000007c48da4"}]
                    yeelight-2.0 2018-11-25 20:20:06.153 debug supports: get_prop,set_default,set_power,toggle,set_bright,start_cf,stop_cf,set_scene,cron_add,cron_get,cron_del,set_ct_abx,set_rgb,set_hsv,set_adjust,adjust_bright,adjust_ct,adjust_color,set_music,se
                    yeelight-2.0 2018-11-25 20:20:06.153 debug Found Light{ id: 0x0000000007c48da4, name: , model: color,
                    yeelight-2.0 2018-11-25 20:20:06.096 debug here is a Message{"command":"discovery","message":{"turnon":1},"from":"system.adapter.admin.0","callback":{"message":{"turnon":1},"id":38,"ack":false,"time":1543173606091},"_id":18687355}
                    yeelight-2.0 2018-11-25 20:20:01.302 debug YEELIGHT FOUND: 192.168.1.36:55443 id: 0x000000000000000 model: color
                    yeelight-2.0 2018-11-25 20:20:01.270 debug CREATE DEVICE: yeelight-2.0.color2
                    yeelight-2.0 2018-11-25 20:19:59.266 debug DEVICES IN OBJECTS FOUND: 0
                    yeelight-2.0 2018-11-25 20:19:59.266 debug DEVICES IN OBJECTS: {}
                    yeelight-2.0 2018-11-25 20:19:59.233 debug DEVICES IN CONFIG: [{"name":"color2","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright",
                    yeelight-2.0 2018-11-25 20:19:59.224 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
                    yeelight-2.0 2018-11-25 20:19:59.108 debug statesDB connected
                    yeelight-2.0 2018-11-25 20:19:59.056 debug objectDB connected
                    yeelight-2.0 2018-11-25 20:19:35.472 info terminating
                    yeelight-2.0 2018-11-25 20:19:35.466 info cleaned everything up…
                    yeelight-2.0 2018-11-25 20:18:45.767 debug YEELIGHT OFFLINE: 0x000000000000000
                    yeelight-2.0 2018-11-25 20:17:45.762 debug YEELIGHT OFFLINE: 0x000000000000000
                    yeelight-2.0 2018-11-25 20:16:45.760 debug YEELIGHT OFFLINE: 0x000000000000000
                    yeelight-2.0 2018-11-25 20:15:45.756 debug YEELIGHT OFFLINE: 0x000000000000000
                    yeelight-2.0 2018-11-25 20:14:45.754 debug YEELIGHT OFFLINE: 0x000000000000000
                    yeelight-2.0 2018-11-25 20:13:45.752 debug YEELIGHT OFFLINE: 0x000000000000000
                    yeelight-2.0 2018-11-25 20:12:45.748 debug YEELIGHT OFFLINE: 0x000000000000000
                    yeelight-2.0 2018-11-25 20:12:33.367 debug SEND SCENE: id:0x000000000000000, state: notification, value:
                    yeelight-2.0 2018-11-25 20:12:16.323 debug SEND SCENE: id:0x000000000000000, state: notification, value: true
                    yeelight-2.0 2018-11-25 20:11:55.375 debug SEND SCENE: id:0x000000000000000, state: notification, value: true
                    yeelight-2.0 2018-11-25 20:11:46.326 debug SEND SCENE: id:0x000000000000000, state: notification, value: false
                    yeelight-2.0 2018-11-25 20:11:45.738 debug YEELIGHT OFFLINE: 0x000000000000000
                    yeelight-2.0 2018-11-25 20:10:45.730 debug YEELIGHT OFFLINE: 0x000000000000000
                    yeelight-2.0 2018-11-25 20:09:45.726 debug YEELIGHT OFFLINE: 0x000000000000000
                    yeelight-2.0 2018-11-25 20:08:45.722 debug YEELIGHT OFFLINE: 0x000000000000000
                    yeelight-2.0 2018-11-25 20:07:45.718 debug YEELIGHT OFFLINE: 0x000000000000000
                    yeelight-2.0 2018-11-25 20:06:53.745 debug DEVICE FOUND SET NOTIFY STATE: {"name":"color2","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","s
                    yeelight-2.0 2018-11-25 20:06:53.744 debug NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"bright":100}}
                    yeelight-2.0 2018-11-25 20:06:52.248 debug DEVICE FOUND SET NOTIFY STATE: {"name":"color2","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","s
                    yeelight-2.0 2018-11-25 20:06:52.247 debug NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"bright":65}}
                    yeelight-2.0 2018-11-25 20:06:50.755 debug DEVICE FOUND SET NOTIFY STATE: {"name":"color2","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","s
                    yeelight-2.0 2018-11-25 20:06:50.752 debug NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"bright":6}}
                    yeelight-2.0 2018-11-25 20:06:45.716 debug YEELIGHT OFFLINE: 0x000000000000000
                    yeelight-2.0 2018-11-25 20:06:40.280 debug DEVICE FOUND SET NOTIFY STATE: {"name":"color2","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","s
                    yeelight-2.0 2018-11-25 20:06:40.278 debug NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"save_state":0}}
                    yeelight-2.0 2018-11-25 20:06:25.318 debug DEVICE FOUND SET NOTIFY STATE: {"name":"color2","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","s
                    yeelight-2.0 2018-11-25 20:06:25.317 debug NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"bright":1,"hue":36,"rgb":16750848,"color_mode":1}}
                    yeelight-2.0 2018-11-25 20:06:23.824 debug DEVICE FOUND SET NOTIFY STATE: {"name":"color2","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","s
                    yeelight-2.0 2018-11-25 20:06:23.823 debug NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"power":"on"}}
                    yeelight-2.0 2018-11-25 20:06:19.335 debug DEVICE FOUND SET NOTIFY STATE: {"name":"color2","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","s
                    yeelight-2.0 2018-11-25 20:06:19.333 debug NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"power":"off"}}
                    yeelight-2.0 2018-11-25 20:05:45.713 debug YEELIGHT OFFLINE: 0x000000000000000
                    yeelight-2.0 2018-11-25 20:04:45.706 debug YEELIGHT OFFLINE: 0x000000000000000
                    yeelight-2.0 2018-11-25 20:03:45.696 debug YEELIGHT OFFLINE: 0x000000000000000
                    yeelight-2.0
                      MeistertrM Offline
                      Meistertr
                      es sieht so aus als ob bei dir garnicht gesendet wird. Die Steuer objecte werden erst erstellt, wenn eine rückmeldung von der Lampe gegeben wird, und dass passiert nicht, kannst du mal den adapter komplett löschen und noch einmal installieren, am besten auch unter adapter löschen. ich glaube, dass eine benötigtes repo nicht ordnungsgemäß geladen wurde.
                      • H Offline
                        hanniko
                        #66
                        Das ist das Log der Installation. Da gibt es gleich ein Warning zu beginn.
                        $ ./iobroker add yeelight-2 –host hjkDiskStation
                        NPM version: 4.6.1
                        npm install iobroker.yeelight-2 --production --save --prefix "/opt/iobroker" (System call)
                        npm
                        WARN deprecated circular-json@0.5.9: CircularJSON is in maintenance only, flatted is its successor.
                        host.hjkDiskStation install adapter yeelight-2
                        got /opt/iobroker/node_modules/iobroker.yeelight-2/admin
                        upload [19] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/yeelight.png yeelight.png image/png
                        upload [18] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/words.js words.js application/javascript
                        upload [17] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/lan.jpg lan.jpg image/jpeg
                        upload [16] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/index_m.html index_m.html text/html
                        upload [15] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/index.html index.html text/html
                        upload [14] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/stripe.png icons/stripe.png image/png
                        upload [13] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/mono.png icons/mono.png image/png
                        upload [12] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/desklamp.png icons/desklamp.png image/png
                        upload [11] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/color.png icons/color.png image/png
                        upload [10] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling4.png icons/ceiling4.png image/png
                        upload [9] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling3.png icons/ceiling3.png image/png
                        upload [8] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling1.png icons/ceiling1.png image/png
                        upload [7] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/bslamp1.png icons/bslamp1.png image/png
                        upload [6] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/7.png icons/7.png image/png
                        upload [5] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/6.png icons/6.png image/png
                        upload [4] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/5.png icons/5.png image/png
                        upload [3] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/4.png icons/4.png image/png
                        upload [2] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/3.png icons/3.png image/png
                        upload [1] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/2.png icons/2.png image/png
                        upload [0] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/1.png icons/1.png image/png
                        host.hjkDiskStation object system.adapter.yeelight-2 created
                        host.hjkDiskStation create instance yeelight-2
                        host.hjkDiskStation object system.adapter.yeelight-2.0.outputCount created
                        host.hjkDiskStation object system.adapter.yeelight-2.0.inputCount created
                        host.hjkDiskStation object system.adapter.yeelight-2.0.uptime created
                        host.hjkDiskStation object system.adapter.yeelight-2.0.memRss created
                        host.hjkDiskStation object system.adapter.yeelight-2.0.memHeapTotal created
                        host.hjkDiskStation object system.adapter.yeelight-2.0.memHeapUsed created
                        host.hjkDiskStation object system.adapter.yeelight-2.0.connected created
                        host.hjkDiskStation object system.adapter.yeelight-2.0.alive created
                        host.hjkDiskStation object system.adapter.yeelight-2.0 created
                        process exited with code 0
                        Dann das Log mit dem Anlegen der Lampe, wobei wieder keine Control Items angelegt werden.
                        yeelight-2.0 2018-11-26 09:24:26.361 debug DEVICE FOUND SET NOTIFY STATE: {"name":"color-0x0000000007c3a46a","ip":"192.168.1.37","port":"55443","smart_name":"","type":"color","id":"0x0000000007c3a46a"}
                        yeelight-2.0 2018-11-26 09:24:26.360 debug NOTIFY MESSAGE: from: 0x0000000007c3a46a, message: {"method":"props","params":{"bright":1,"flowing":1}}
                        yeelight-2.0 2018-11-26 09:24:24.863 debug DEVICE FOUND SET NOTIFY STATE: {"name":"color-0x0000000007c3a46a","ip":"192.168.1.37","port":"55443","smart_name":"","type":"color","id":"0x0000000007c3a46a"}
                        yeelight-2.0 2018-11-26 09:24:24.862 debug NOTIFY MESSAGE: from: 0x0000000007c3a46a, message: {"method":"props","params":{"color_mode":1}}
                        yeelight-2.0 2018-11-26 09:24:07.536 debug DEVICE FOUND SET NOTIFY STATE: {"name":"color-0x0000000007c3a46a","ip":"192.168.1.37","port":"55443","smart_name":"","type":"color","id":"0x0000000007c3a46a"}
                        yeelight-2.0 2018-11-26 09:24:07.535 debug NOTIFY MESSAGE: from: 0x0000000007c3a46a, message: {"method":"props","params":{"bright":50,"flowing":1,"color_mode":2}}
                        yeelight-2.0 2018-11-26 09:24:06.039 debug DEVICE FOUND SET NOTIFY STATE: {"name":"color-0x0000000007c3a46a","ip":"192.168.1.37","port":"55443","smart_name":"","type":"color","id":"0x0000000007c3a46a"}
                        yeelight-2.0 2018-11-26 09:24:06.036 debug NOTIFY MESSAGE: from: 0x0000000007c3a46a, message: {"method":"props","params":{"flowing":1}}
                        yeelight-2.0 2018-11-26 09:24:05.952 debug YEELIGHT FOUND: 192.168.1.37:55443 id: 0x0000000007c3a46a model: color
                        yeelight-2.0 2018-11-26 09:24:03.940 debug SMARTNAME:
                        yeelight-2.0 2018-11-26 09:24:03.938 debug OLD CONF. FROM OBJ: {"name":"color-0x0000000007c3a46a","ip":"192.168.1.37","port":"55443","smart_name":"","type":"color","id":"0x0000000007c3a46a"}
                        yeelight-2.0 2018-11-26 09:24:03.931 debug OBJ_ELEMENT: yeelight-2.0.color-0x0000000007c3a46a
                        yeelight-2.0 2018-11-26 09:24:03.931 debug DEVICES IN OBJECTS FOUND: 1
                        yeelight-2.0 2018-11-26 09:24:03.930 debug DEVICES IN OBJECTS: {"yeelight-2.0.color-0x0000000007c3a46a":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"color-0x0000000007c3a46a","type":"color"},"from":"sy
                        yeelight-2.0 2018-11-26 09:24:03.896 debug DEVICES IN CONFIG: [{"name":"color-0x0000000007c3a46a","ip":"192.168.1.37","port":"55443","smart_name":"","type":"color","id":"0x0000000007c3a46a"}]
                        yeelight-2.0 2018-11-26 09:24:03.887 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
                        yeelight-2.0 2018-11-26 09:24:03.779 debug statesDB connected
                        yeelight-2.0 2018-11-26 09:24:03.719 debug objectDB connected
                        yeelight-2.0 2018-11-26 09:24:00.228 info terminating
                        yeelight-2.0 2018-11-26 09:24:00.218 info cleaned everything up…
                        yeelight-2.0 2018-11-26 09:23:50.515 debug YEELIGHT FOUND: 192.168.1.37:55443 id: 0x0000000007c3a46a model: color
                        yeelight-2.0 2018-11-26 09:23:48.500 debug SMARTNAME:
                        yeelight-2.0 2018-11-26 09:23:48.498 debug OLD CONF. FROM OBJ: {"name":"color-0x0000000007c3a46a","ip":"192.168.1.37","port":"55443","smart_name":"","type":"color","id":"0x0000000007c3a46a"}
                        yeelight-2.0 2018-11-26 09:23:48.494 debug OBJ_ELEMENT: yeelight-2.0.color-0x0000000007c3a46a
                        yeelight-2.0 2018-11-26 09:23:48.494 debug DEVICES IN OBJECTS FOUND: 1
                        yeelight-2.0 2018-11-26 09:23:48.493 debug DEVICES IN OBJECTS: {"yeelight-2.0.color-0x0000000007c3a46a":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"color-0x0000000007c3a46a","type":"color"},"from":"sy
                        yeelight-2.0 2018-11-26 09:23:48.454 debug DEVICES IN CONFIG: [{"name":"color-0x0000000007c3a46a","ip":"192.168.1.37","port":"55443","smart_name":"","type":"color","id":"0x0000000007c3a46a"}]
                        yeelight-2.0 2018-11-26 09:23:48.445 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
                        yeelight-2.0 2018-11-26 09:23:48.340 debug statesDB connected
                        yeelight-2.0 2018-11-26 09:23:48.259 debug objectDB connected
                        yeelight-2.0 2018-11-26 09:23:44.763 info terminating
                        yeelight-2.0 2018-11-26 09:23:44.755 info cleaned everything up…
                        yeelight-2.0 2018-11-26 09:23:26.562 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
                        yeelight-2.0 2018-11-26 09:23:22.883 info terminating
                        yeelight-2.0 2018-11-26 09:23:22.876 info cleaned everything up...
                        yeelight-2.0 2018-11-26 09:18:40.564 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
                        yeelight-2.0 2018-11-26 09:10:22.584 info terminating
                        yeelight-2.0 2018-11-26 09:10:22.579 info cleaned everything up...
                          MeistertrM Offline
                          Meistertr
                          #67
                          @hanniko:
                          NPM version: 4.6.1
                          npm
                          yeelight-2.0 2018-11-26 09:10:22.579 info cleaned everything up... `
                          warnings beim installieren sind nicht weiter schlimm, versuch mal bitte diese Version, installation übers terminal:
                           npm install https://github.com/MeisterTR/ioBroker.yeelight-2/tarball/add-yeelight-wifi --production --save
                          • H Offline
                            hanniko
                            #68
                            klappt; control ist vorhanden ;-) Morgen teste ich das mal weiter aus. Danke schon mal.
                            • L Offline
                              ltsalvatore
                              #69
                              @hanniko:
                              klappt; control ist vorhanden ;-) Morgen teste ich das mal weiter aus. Danke schon mal. `
                              bin mal gespannt auf deine Rückmeldung.
                              ich muss nämlich sagen, auch wenn aktuell alles zur abwechslung problemlos und sehr reaktionsschnell funktioniert, es alles in allem nicht so ganz stabil läuft, wie ich es mir vorgestellt/erhofft habe.
                              was ich aber bemerkt habe und für den ein oder anderen evtl. interessant wäre zu wissen:
                              wenn ich die yeelight bulb über iobroker steuere (ob über vis oder aqara switch) und es einfach nicht (mehr) funktionieren will, dann funktioniert das steuern der bulb immer noch tadellos mit dem yeelight alexa skill.
                              als leihe würde ich sagen, das problem liegt entweder bei dem iobroker oder adapter.
                              zusätzlich war mir die tage aufgefallen, dass die yeelight bulb scheinbar enormst probleme hat, wenn man auf der fritzbox den 2,4GHz wifi kanal von auto auf manuell stellt.
                              das anlernen der bulb über die yeelight app funktioniert dann einfach überhaupt nicht mehr. setze ich den wifi kanal wieder zurück auf auto, funktioniert das anlernen tadellos.
                                MeistertrM Offline
                                Meistertr
                                #70
                                @ltsalvatore:
                                @hanniko:
                                das anlernen der bulb über die yeelight app funktioniert dann einfach überhaupt nicht mehr. setze ich den wifi kanal wieder zurück auf auto, funktioniert das anlernen tadellos. ` Die Kommunikation zwischen iobroker und den bulbs ist lokal über udp. Über den skill läuft und der app läuft es über den yeelight Server und hat mit deinem lokalen Netz nichts zu tun. Somit sind das zwei verschiedenen Sachen. Ich habe mittlerweile fast alle yeelight Modelle und alle laufen ohne probleme und Ausfälle. Der Adapter läuft auf drei Servern zum testen mit unterschiedlichen node Versionen und keiner hat bislang Probleme gemacht. Dann würde ich die Probleme eher in deinem Netzwerk oder bei deiner Installation suchen.
                                Desweiteren ist die Aussage dass es nicht läuft alles andere als konstruktiv. Hier wäre ein Debug log Auszug wenn es nicht läuft mehr als hilfreich. Dann kann ich dir auch sagen woran es liegt.
                                • ? Offline
                                  #71
                                  Als "Experdde" würd ich eher sagen, du hast n Wlan-Problem. Autokanal kann funktionieren, muss aber nicht, kommt drauf an, wo deine Empfänger stehen. Wenn am Standort der Fritzbox die Kanäle 1, 9, 13 belegt sind, wird Sie als Autokanal den 5er nehmen, wenn aber genau dann am Standort deines Empfängers (in dem Fall die Yeelight) dort ein Nachbar auf Kanal 5 sendet und dir den belegt, wirst du mit der Einstellung Probleme haben. Abgesehen davon, die Fritzbox eigenständig den Kanal von jetzt auf später wechseln kann, und du dich dann wunderst, warum es eben ging, und jetzt nicht mehr.
                                  Wenn man nur 2-3 Endgeräte hat, ist das alles halb so wild, aber bei einem Smarthomesystem katastrophal. Ich hab hier 23 Netze von den umliegenden Nachbarn im 2,4GHz und 5 im 5GHz Bereich, und versorge ein zweifamilien Haus mit 4 Etagen mit insgesamt 170 Netzwerkgeräten, dazu noch 75 Zigbee und 10 Dect, die auch stören, der ganze Mist liegt ja im 2,4GHz Bereich… Bin froh wenn irgendwas auf 5GHz schaltet und mir auf dem 2,4er aus den Füssen ist.
                                  Habe wochenlang nur durch ausprobieren herausgefunden, welcher Kanal für alle(und ich möchte mich nicht selbst im eigenen Haus mit verschiedenen Kanälen blockieren) am besten ist, und das ist genau der, den die Fritzbox nie! benutzt hat.. ;-)
                                  Also ich hab nur ein Yeelight-Stripe und das läuft mit dem Adapter zuverlässig. Skill und App verwende ich schon lange nicht mehr. Ganz am Anfang hatte ich hier im Forum ein Javascript, das mir das schaltete, mit dem alten Yeelight-Adapter war ich auch zufrieden. Finde es klasse, dass bei dem neuen die Scenen mit drin sind.
                                  ****Viel Erfolg bei der Fehlersuche, wenn sowas wieder auftritt, hilft nur eins, stell den Adapter mal auf Debug und poste hier dann das Logfile dazu.
                                  ( Instanzen - Expertenmodus - Logstufe auf Debug, der Adapter startet dann neu, das Logfile findest du in /opt/iobroker/log und mit dem Befehl "less iobroker.2018-12-02.log | grep yeelight" erhälst du die Meldungen nur vom Yeelight Adapter, das bitte per copy und paste hier dann posten. )****
                                  • L Offline
                                    ltsalvatore
                                    #72
                                    danke @Meistertr und @ilovegym für eure konstruktive kritik.
                                    werde mir das ganze nun mal etwas genauer anschauen, jetzt wo ich auch ein wenig mehr zeit dafür aufwenden kann. ;)
                                    denke auch, dass es irgendwie machbar sein sollte, das ganze so zu optimieren, dass es zuverlässig läuft.
                                    muss ich hierzu den yeelight und javascript adapter auf debug stellen?
                                      southparkler
                                      #73
                                      Ich kann ähnliche Probleme allerdings bestätigen.
                                      Meine Mono in der Küche wird seit kurzem über den ioBroker Adapter gesteuert und macht manchmal nicht mit. Der Yeelight Strip läuft hier deutlich zuverlässiger.
                                      Hab mich bisher noch nicht gemeldet weil das Problem nicht so tragisch ist, da es nicht immer vorkommt und ich momentan dafür keine Zeit hab, noch hab ich wichtigere Sachen die ich zum Laufen bekommen möchte. ;)
                                      iBroker läuft auf Raspi 3B über Gbit Lan
                                      Geräte:
                                      Licht: Hue Lampen mit Bridge, Osram Smart Plug, Tradfri Lampen über Hue, Yeelight Lampen
                                      Sensoren: Xiaomi Aqara Sensoren (Zigbee Stick)
                                      Heizung: Fritz!D…
                                      • ? Offline
                                        #74
                                        yeelight sollte erstmal reichen, mal schauen, was da so steht.
                                        • ? Offline
                                          #75
                                          @southparkler:
                                          Hab mich bisher noch nicht gemeldet weil das Problem nicht so tragisch ist, da es nicht immer vorkommt und ich momentan dafür keine Zeit hab, noch hab ich wichtigere Sachen die ich zum Laufen bekommen möchte. ;) `
                                          Ich hatte vor 6 Monaten nach einem Xiaomi -Firmwareupdate der Bulbs (hatte auch Mono und Color) und dem Stripe das Problem, dass sie sich manchmal aufhingen, erst ein Powerreset brachte sie wieder zur Funktion. Hatte damals nix als das xiaomi-firmware Update gemacht, downgrade ging nicht, hab die 3 Bulbs dann vertickert und mir sonoff B1 geholt ( die sind aber leider lange nicht so hell wie die Xiaomi) - aber die funktionieren. Habe seitdem nur noch das Stripe, das wird durch n Sonoff Basic einmal täglich for 1 minute vom Strom genommen.
                                          Ich denke daher nicht, dass dieser Fehler etwas mit dem Adapter zu tun hat, eher was mit der Firmware … und da kann man bei Xiaomi leider nix machen...
