  4. [gelöst] Sonoff Error beim flashen mit Atom
18 Beiträge 6 Kommentatoren 5.7k Aufrufe 4 Beobachtet
  • SmarthomeMFS Offline
    SmarthomeMF
    nun habe ich die neue Tasmota Software heruntergeladen und noch mal probiert….
    nur bekomme ich einige neue ERROR
    [05/31/18 10:25:41] Processing sonoff-DE (platform: espressif8266@1.5.0; board: esp01_1m; framework: arduino)
    Verbose mode can be enabled via -v, --verbose option
    PLATFORM: Espressif 8266 > Espressif Generic ESP8266 ESP-01 1M
    SYSTEM: ESP8266 80MHz 80KB RAM (1MB Flash)
    Converting sonoff.ino
    ! Library Dependency Finder -> http://bit.ly/configure-pio-ldf
    LDF MODES: FINDER(chain) COMPATIBILITY(soft)
    Collected 40 compatible libraries
    Scanning dependencies...
    Dependency Graph
    |-- <wire> v1.0
    |-- <mutichannel_gas_sensor> v0.0.1
    | |-- <wire> v1.0
    |-- <arduinoota> v1.0
    | |-- <esp8266wifi> v1.0
    | |-- <esp8266mdns>
    |-- <esp8266webserver> v1.0
    |-- <esp knx/ip/library=""> v0.5.1
    | |-- <eeprom> v1.0
    |-- <esp8266httpupdate> v1.1
    | |-- <esp8266httpclient> v1.1
    |-- <i2cdevlib-ads1115>
    | |-- <i2cdevlib-core>
    | | |-- <wire> v1.0
    |-- <adafruit bme680/library=""> v1.0.5
    | |-- <spi> v1.0
    | |-- <wire> v1.0
    | |-- <adafruit unified/sensor=""> v1.0.2
    |-- <onewire> v2.3.2
    |-- <pubsubclient> v2.6
    |-- <ticker> v1.0
    |-- <spi> v1.0
    |-- <esp mqtt=""> v1.0.1
    ! |-- <irremoteesp8266> v2.2.1
    |-- <joba_tsl2561> v2.0.1
    | |-- <wire> v1.0
    |-- <neopixelbus> v2.2.9
    | |-- <spi> v1.0
    |-- <tasmotaserial> v2.0.0
    |-- <arduinojson> v5.11.2
    |-- <tasmotamqtt> v1.0.0
    |-- <dnsserver> v1.1.0
    |-- <adafruit sgp30/sensor=""> v1.0.2
    | |-- <wire> v1.0
    |-- <esp8266mdns>
    Compiling .pioenvs\sonoff-DE\src\sonoff.ino.cpp.o
    Linking .pioenvs\sonoff-DE\firmware.elf
    Checking program size
    text data bss dec hex filename
    533611 11016 44248 588875 8fc4b .pioenvs\sonoff-DE\firmware.elf
    Building .pioenvs\sonoff-DE\firmware.bin
    Configuring upload protocol...
    Looking for upload port...
    Use manually specified: COM5
    Uploading .pioenvs\sonoff-DE\firmware.bin
    error: Failed to open COM5
    error: espcomm_open failed
    error: espcomm_upload_mem failed
    *** [upload] Error -1
    [ERROR] Took 8.53 seconds
    [SUMMARY]
    Environment sonoff [SKIP]
    Environment sonoff-minimal [SKIP]
    Environment sonoff-classic [SKIP]
    Environment sonoff-knx [SKIP]
    Environment sonoff-allsensors [SKIP]
    Environment sonoff-BG [SKIP]
    Environment sonoff-BR [SKIP]
    Environment sonoff-CN [SKIP]
    Environment sonoff-CZ [SKIP]
    Environment sonoff-ES [SKIP]
    Environment sonoff-FR [SKIP]
    Environment sonoff-GR [SKIP]
    Environment sonoff-HU [SKIP]
    Environment sonoff-IT [SKIP]
    Environment sonoff-NL [SKIP]
    Environment sonoff-PL [SKIP]
    Environment sonoff-PT [SKIP]
    Environment sonoff-RU [SKIP]
    Environment sonoff-UK [SKIP]
    Environment sonoff-TW [SKIP]
    Environment sonoff-DE [ERROR]
    [ERROR] Took 8.53 seconds</esp8266wifi></esp8266httpclient></esp8266wifi></esp8266mdns></wire></adafruit></esp8266wifi></dnsserver></tasmotamqtt></arduinojson></tasmotaserial></esp8266wifi></spi></neopixelbus></wire></joba_tsl2561></irremoteesp8266></esp></spi></ticker></pubsubclient></onewire></adafruit></wire></spi></adafruit></wire></i2cdevlib-core></i2cdevlib-ads1115></esp8266wifi></esp8266httpclient></esp8266wifi></esp8266httpupdate></esp8266wifi></eeprom></esp8266wifi></esp8266webserver></esp></esp8266wifi></esp8266webserver></esp8266wifi></esp8266mdns></esp8266wifi></arduinoota></wire></mutichannel_gas_sensor></wire>
    Max
    ioBroker auf einem NUC ,16GB RAM, 120GB SSD) mit Proxmox
    Cloud Pro, iot, Alexa, Sonos, sonoff, Fronius, Harmony, Doorbird, Shelly, Hue, Loxone, Mihome, …
      SmarthomeMF
      Kann mir wer sagen was das für ein Fehler ist?
      Assembler messages:
      Fatal error: can't create .pioenvs\sonoff-DE\src\sonoff.ino.cpp.o: No such file or directory
      ! *** [.pioenvs\sonoff-DE\src\sonoff.ino.cpp.o] Error 1
      WindowsError: [Error 2] Das System kann die angegebene Datei nicht finden: 'C:\Users\marku\Downloads\Sonoff-Tasmota-development1\Sonoff-Tasmota-development\.pioenvs\.sconsign.dblite':
      File "C:\Users\marku.platformio\packages\tool-scons\script..\engine\SCons\Script\Main.py", line 1346:
      _exec_main(parser, values)
      Was habe ich da wieder falsch gemacht
      Bitte um Hilfe.
      Max
      • J Offline
        Jan1
        Steht doch da, das der Pfad ins leere läuft. Schmeiß mal alles raus und öffne den Projekt Ordner neu. Bei Atom auch mal auf den Mülleimer oben klicken, dann sollte das wieder passen
          SmarthomeMF
          @Jan1:
          Schmeiß mal alles raus und öffne den Projekt Ordner neu. Bei Atom auch mal auf den Mülleimer oben klicken, dann sollte das wieder passen `
          habe ich schon gefühlt 100mal gemacht aber immer das gleiche…
          Habe den Speicherort schon geändert ….
          und das gleich...
          Atom auch schon neu installiert...
          Auf einem anderen Rechner das ganze probiert...
          immer ERROR
          ich weiß nicht mehr was ich ton soll!!
          Bitte um Hilfe.
          Max
          • SchubiS Offline
            SchubiS Offline
            Schubi
            Nur mal so zum Testen - der Pfad kommt mit sehr lang vor - Probier mal einen kürzeren Pfad.
            LG
            / Synology DS716+ / Logitech Harmony Ultimate / Netatmo / ESP8266 / RPi 3 / 4* Möller Easy 820 / Lupusec XT2 Plus /
              SmarthomeMF
              Hallo
              Ich melde mich dann wieder mal mit dem selben Problem!!
              Beim letzten mal habe ich dabei Sonoff Datei auf dem Bildschirm gespeichert und dann ging es!!
              Nun möchte ich wieder mal mit der selben Einstellung einen Sonoff Basic neu flashen…
              der wurde schon mal geflasht und hat funktioniert.
              Nun möchte ich eine neu Tasmota drauf flashen….
              Ich habe die selbe Datei wie beim letzten mal (aber schon neuer als die alte)
              Bekomme aber immer ERROR
              Checking size .pioenvs\sonoff-DE\firmware.elf
              ! Memory Usage -> http://bit.ly/pio-memory-usage
              DATA: [======= ] 67.5% (used 55264 bytes from 81920 bytes)
              PROGRAM: [===== ] 51.9% (used 544643 bytes from 1048576 bytes)
              Use manually specified: COM4
              error: Failed to open COM4
              [ERROR] Took 13.95 seconds
              [SUMMARY]
              [ERROR] Took 13.96 seconds
              Wo liegt da der fehler??
              Ich habe mir die Aktuelle Tasmota von git geladen…
              aber immer ERROR
              my_user_config.h
              platformio.ini
              >! ; PlatformIO Project Configuration File
              ;   Build options: build flags, source filter, extra scripting
              ;   Upload options: custom port, speed and extra flags
              ;   Library options: dependencies, extra library storages
              ; Please visit documentation for the other options and examples
              ; http://docs.platformio.org/en/stable/projectconf.html
              [platformio]
              src_dir = sonoff
              >! 18.1 s
              platformio run --target upload
              DATA:    [=======   ]  67.6% (used 55352 bytes from 81920 bytes)
              PROGRAM: [=====     ]  48.0% (used 503331 bytes from 1048576 bytes)
              >! Use manually specified: COM4
               [ERROR] Took 17.52 seconds
               [SUMMARY]
              Environment sonoff-basic        [SKIP]
              Environment sonoff-sensors      [SKIP]
              Environment sonoff-display      [SKIP]
              Environment sonoff-HE           [SKIP]
              Environment sonoff-TR           [SKIP]
              Bitte um Hilfe!!
              Max
                SmarthomeMF
                Habs jetzt noch mit einem neuen Sonoff Basic probiert!
                Immer der gleiche Fehler.
                Was mach ich falsch?
                Max
                • SchubiS Offline
                  SchubiS Offline
                  Schubi
                  Failed to open COM Port!
                  Du verwendest den falschen COM Port.
                  Schau mal in der Systemsteuerung an welchem dein Sonoff angeschlossen ist.
                  LG
                  • SchubiS Offline
                    SchubiS Offline
                    Schubi
                      SmarthomeMF
                      Danke das wars!
                      Kann mir zwar nicht erklären das es plötzlich ein anderer COM ist aber gut so.
                      Hir wird man geholfen!!
                      Echt tolle unterstützung!!
                      Max
                      • SmarthomeMFS SmarthomeMF
                        Danke das wars!
                        Bammbozel
                        @SmarthomeMF
                        Ich habe das selbe Problem aber ich weiß nicht was ich dann hinschreiben soll Weil z.B. COM10 Hat nicht funktioniert.
                        • B Bammbozel
                          @SmarthomeMF
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @Bammbozel
                          Kannst du Dir in Serial Monitor / List Serial Ports anzeigen lassen , welcher Port überhaupt vorhanden ist .
                            Bammbozel
                            Es ist der hier Weil ich mit einem Arduino Nano Arbeite.
                              Bammbozel
                              OK, Danke jetzt funktioniert es dadurch das ich jetzt den/das richtige Com ausgewählt habe 😅 Denn in der Systemsteuerung steht Com 10
                              • P Offline
                                PhilippG
                                Beim flashen mit Atom oder VSC kommt jedes mal dieses Fehlermeldung, sowohl auf meinem PC als auch auf einem anderen PC, wo Atom und VSC neu installiert wurden.
                                habe bereits Atom neu installiert, die Tasmota Software neu heruntergeladen und weiß nicht weiter.
                                > Executing task: platformio.exe run <
                                Warning! `env_default` configuration option in section [platformio] is deprecated and will be removed in the next release! Please use `default_envs` instead
                                Processing sonoff-DE (framework: arduino; platform: espressif8266@1.5.0; board: esp01_1m)
                                Verbose mode can be enabled via `-v, --verbose` option
                                CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/esp01_1m.html
                                PLATFORM: Espressif 8266 1.5.0 > Espressif Generic ESP8266 ESP-01 1M
                                HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
                                PACKAGES: toolchain-xtensa 1.40802.0 (4.8.2), tool-esptool 1.409.0 (4.9), framework-arduinoespressif8266 1.20300.1 (2.3.0)
                                LDF: Library Dependency Finder -> http://bit.ly/configure-pio-ldf
                                LDF Modes: Finder ~ chain, Compatibility ~ soft
                                Found 52 compatible libraries
                                Dependency Graph
                                |-- <ESP8266WiFi> 1.0
                                |-- <TasmotaModbus> 1.1.0
                                |   |-- <TasmotaSerial> 2.3.0
                                |-- <Adafruit GFX Library> 1.2.9
                                |   |-- <SPI> 1.0
                                |-- <I2Cdevlib-MPU6050>
                                |   |-- <I2Cdevlib-Core>
                                |   |   |-- <Wire> 1.0
                                |-- <BME680_driver-bme680_v3.5.9>
                                Compiling .pio\build\sonoff-DE\src\sonoff.ino.cpp.o
                                Linking .pio\build\sonoff-DE\firmware.elf
                                c:/users/pc/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: .pio\build\sonoff-DE\firmware.elf section `.text' will not fit in region `iram1_0_seg'
                                collect2.exe: error: ld returned 1 exit status
                                *** [.pio\build\sonoff-DE\firmware.elf] Error 1
                                =============================================================================================== [ERROR] Took 12.07 seconds ===============================================================================================
                                ======================================================================================================= [SUMMARY] =======================================================================================================
                                Environment sonoff              [IGNORED]
                                Environment sonoff-minimal      [IGNORED]
                                Environment sonoff-basic        [IGNORED]
                                Environment sonoff-classic      [IGNORED]
                                Environment sonoff-knx          [IGNORED]
                                Environment sonoff-sensors      [IGNORED]
                                Environment sonoff-display      [IGNORED]
                                Environment sonoff-BG           [IGNORED]
                                Environment sonoff-BR           [IGNORED]
                                Environment sonoff-CN           [IGNORED]
                                Environment sonoff-CZ           [IGNORED]
                                Environment sonoff-DE           [FAILED]
                                Environment sonoff-ES           [IGNORED]
                                Environment sonoff-FR           [IGNORED]
                                Environment sonoff-GR           [IGNORED]
                                Environment sonoff-HE           [IGNORED]
                                Environment sonoff-HU           [IGNORED]
                                Atom funktionier bei mir garnicht mehr: bleibt bei Neuinstallation bei "Atom dependencies" hängen.
                                GlasfaserG J 2 Antworten Letzte Antwort
                                • P PhilippG
                                  Dependency Graph
                                  |   |-- <SPI> 1.0
                                  |   |-- <I2Cdevlib-Core>
                                  |   |   |-- <Wire> 1.0
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @PhilippG sagte in [gelöst] Sonoff Error beim flashen mit Atom:
                                  https://forum.iobroker.net/topic/14734/probleme-mit-der-installation-von-atom/5
                                  Hast du keine fertige Firmware.bin Datei , was möchtest du denn machen.
                                  • P PhilippG
                                    Dependency Graph
                                    |   |-- <SPI> 1.0
                                    |   |-- <I2Cdevlib-Core>
                                    |   |   |-- <Wire> 1.0
                                    Jan1
                                    @PhilippG
                                    Hatte ich auch und Atom nun endgültig runter geschmissen. VSC hatte auch zuerst Probleme, hab mir dann die aktuelle Version runter geladen und damit läuft es wieder. Kann auch sein, dass VSC erst noch was nach installiert und es erst beim zweiten Versuch kompiliert.
