  4. [Aufruf] Xbox Adapter testen
    1.0k
    6.1k
adapterxbox
205 Beiträge 13 Kommentatoren 50.4k Aufrufe 2 Beobachtet
  • foxriver76F Offline
    foxriver76F Offline
    foxriver76
    #90
    Wie steht es umnode -v,nodejs -vund````
    npm -v
    Videotutorials & mehr
      DKM
      #91
      System: BeeLink Gemini X / Windows 10 Home 64-bit / 8 GB RAM
      iobroker-Admin 3.5.10
      npm 4.6.1
      node 8.12.0
      Python 3.7.1
      Ich habe es direkt über die Konsole als Admin probiert.
      Der erste Versuch mit npm i iobroker.xbox –unsafe-perm ist fehlgeschlagen:
      C:\ioBroker>npm i iobroker.xbox --unsafe-perm
      npm WARN addRemoteGit Error: not found: git
      npm WARN addRemoteGit at getNotFoundError (C:\Users\krist\AppData\Roaming\npm\node_modules\npm\node_modules\which\which.js:13:12)
      npm WARN addRemoteGit at F (C:\Users\krist\AppData\Roaming\npm\node_modules\npm\node_modules\which\which.js:68:19)
      npm WARN addRemoteGit at E (C:\Users\krist\AppData\Roaming\npm\node_modules\npm\node_modules\which\which.js:80:29)
      npm WARN addRemoteGit at C:\Users\krist\AppData\Roaming\npm\node_modules\npm\node_modules\which\which.js:89:16
      npm WARN addRemoteGit at C:\Users\krist\AppData\Roaming\npm\node_modules\npm\node_modules\which\node_modules\isexe\index.js:42:5
      npm WARN addRemoteGit at C:\Users\krist\AppData\Roaming\npm\node_modules\npm\node_modules\which\node_modules\isexe\windows.js:36:5
      npm WARN addRemoteGit at C:\Users\krist\AppData\Roaming\npm\node_modules\npm\node_modules\graceful-fs\polyfills.js:284:29
      npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:152:21)
      npm WARN addRemoteGit git://github.com/noopkat/browser-serialport.git#api-updates resetting remote C:\Users\krist\AppData\Roaming\npm-cache_git-remotes\git-github-com-noopkat-browser-serialport-git-api-updates-0f82caf3 because of error: { Error: not found: git
      npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:152:21) code: 'ENOGIT' }
      npm WARN addRemoteGit git://github.com/noopkat/js-stk500v1.git#avrgirl resetting remote C:\Users\krist\AppData\Roaming\npm-cache_git-remotes\git-github-com-noopkat-js-stk500v1-git-avrgirl-31bc3a47 because of error: { Error: not found: git
      npm ERR! git clone --template=C:\Users\krist\AppData\Roaming\npm-cache_git-remotes_templates --mirror git://github.com/noopkat/browser-serialport.git C:\Users\krist\AppData\Roaming\npm-cache_git-remotes\git-github-com-noopkat-browser-serialport-git-api-updates-0f82caf3: undefined
      npm ERR! git clone --template=C:\Users\krist\AppData\Roaming\npm-cache_git-remotes_templates --mirror git://github.com/noopkat/js-stk500v1.git C:\Users\krist\AppData\Roaming\npm-cache_git-remotes\git-github-com-noopkat-js-stk500v1-git-avrgirl-31bc3a47: undefined
      ! > iobroker.xbox@0.1.4 preinstall C:\ioBroker\node_modules.staging\iobroker.xbox-831ff231
      apt install -y build-essential libssl-dev libffi-dev python3-dev || echo -e '[INFO] Cant install build-essential libssl-dev libffi-dev python3-dev Debian packages. If you are on a Linux system, try installing the package via: sudo npm i iobroker.xbox --unsafe-perm, otherwise you have to manage to install the packages by yourself. If you are not running on Linux, you can ignore this INFO.'
      ! Der Befehl "apt" ist entweder falsch geschrieben oder
      konnte nicht gefunden werden.
      ! > iobroker.xbox@0.1.4 install C:\ioBroker\node_modules\iobroker.xbox
      npip install
      ! No python_modules directory; installing pip locally if needed.
      Error: No python executable.
      at getPythonInfo (C:\ioBroker\node_modules\nopy\src\api.js:52:11)
      at Promise.then.catch.error (C:\ioBroker\node_modules\nopy\src\api.js:115:14)
      at <anonymous>
      at process._tickCallback (internal/process/next_tick.js:189:7)
      • buffer-equal@0.0.1 node_modules\buffer-equal
      • intel-hex@0.1.1 node_modules\intel-hex
      • chip.avr.avr109@1.1.1 node_modules\chip.avr.avr109
      • isval@0.0.2 node_modules\isval
      • awty@0.1.0 node_modules\awty
      • async@0.9.2 node_modules\stk500-v2\node_modules\async
      • stk500-v2@1.0.3 node_modules\stk500-v2
        iobroker.inst@1.1.2 C:\ioBroker
        -- iobroker@1.1.2 -- yargs@7.1.0
        +-- camelcase@3.0.0
        +-- cliui@3.2.0
        +-- os-locale@1.4.0
        +-- read-pkg-up@1.0.1
        | +-- find-up@1.1.2
        | | +-- path-exists@2.1.0
        | | | -- pinkie-promise@2.0.1 deduped | | -- pinkie-promise@2.0.1
        | | -- pinkie@2.0.4 | -- read-pkg@1.1.0
        | +-- load-json-file@1.1.0
        | | +-- parse-json@2.2.0
        | | | -- error-ex@1.3.2 | | | -- is-arrayish@0.2.1
        | | +-- pify@2.3.0
        | | +-- pinkie-promise@2.0.1 deduped
        | | -- strip-bom@2.0.0 | +-- normalize-package-data@2.4.0 | | +-- hosted-git-info@2.7.1 | | +-- is-builtin-module@1.0.0 | | | -- builtin-modules@1.1.1
        | | -- validate-npm-package-license@3.0.4 | | +-- spdx-correct@3.0.2 | | | +-- spdx-expression-parse@3.0.0 deduped | | | -- spdx-license-ids@3.0.2
        | | -- spdx-expression-parse@3.0.0 | | +-- spdx-exceptions@2.2.0 | | -- spdx-license-ids@3.0.2 deduped
        | -- path-type@1.1.0 | +-- pify@2.3.0 deduped | -- pinkie-promise@2.0.1 deduped
        +-- which-module@1.0.0
        -- yargs-parser@5.0.0 -- camelcase@3.0.0 deduped
      ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: browser-serialport@git://github.com/noopkat/browser-serialport.git#api-updates (node_modules\iobroker.rflink\node_modules\avrgirl-arduino\node_modules\browser-serialport):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: not found: git
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: stk500@git://github.com/noopkat/js-stk500v1.git#avrgirl (node_modules\iobroker.rflink\node_modules\avrgirl-arduino\node_modules\stk500):
      npm WARN enoent ENOENT: no such file or directory, open 'C:\ioBroker\node_modules\avrgirl-arduino\package.json'
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! iobroker.xbox@0.1.4 install: npip install
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the iobroker.xbox@0.1.4 install script.
      ! npm ERR! A complete log of this run can be found in:
      npm ERR! C:\Users\krist\AppData\Roaming\npm-cache_logs\2018-11-12T07_00_41_732Z-debug.log</anonymous>
      Der zweite Versuch mit npm i iobroker.xbox –production --unsafe-perm ist auch fehlgeschlagen:
      C:\ioBroker>npm i iobroker.xbox --production --unsafe-perm
      npm WARN addRemoteGit  git://github.com/noopkat/browser-serialport.git#api-updates resetting remote C:\Users\krist\AppData\Roaming\npm-cache\_git-remotes\git-github-com-noopkat-browser-serialport-git-api-updates-0f82caf3 because of error: { Error: not found: git
      npm WARN addRemoteGit  git://github.com/noopkat/js-stk500v1.git#avrgirl resetting remote C:\Users\krist\AppData\Roaming\npm-cache\_git-remotes\git-github-com-noopkat-js-stk500v1-git-avrgirl-31bc3a47 because of error: { Error: not found: git
      npm ERR! git clone --template=C:\Users\krist\AppData\Roaming\npm-cache\_git-remotes\_templates --mirror git://github.com/noopkat/browser-serialport.git C:\Users\krist\AppData\Roaming\npm-cache\_git-remotes\git-github-com-noopkat-browser-serialport-git-api-updates-0f82caf3: undefined
      npm ERR! git clone --template=C:\Users\krist\AppData\Roaming\npm-cache\_git-remotes\_templates --mirror git://github.com/noopkat/js-stk500v1.git C:\Users\krist\AppData\Roaming\npm-cache\_git-remotes\git-github-com-noopkat-js-stk500v1-git-avrgirl-31bc3a47: undefined
      >! > iobroker.xbox@0.1.4 preinstall C:\ioBroker\node_modules\.staging\iobroker.xbox-831ff231
      > npip install
          at <anonymous>
      +-- chip.avr.avr109@1.1.1  extraneous
      `-- stk500-v2@1.0.3  extraneous
      npm ERR! errno 1
      npm ERR! iobroker.xbox@0.1.4 install: `npip install`
      npm ERR!
      npm ERR!     C:\Users\krist\AppData\Roaming\npm-cache\_logs\2018-11-12T07_02_10_592Z-debug.log</anonymous>
      Als letztes habe ich es über den Admin-Adapter versucht. Hier der Auszug aus dem Log
      iobroker
      2018-11-12 08:13:34.312
      info
      exit 0
      iobroker
      2018-11-12 08:13:34.296
      error
      Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'C:\ioBroker\node_modules\iobroker\null\io-package.json'
      iobroker
      2018-11-12 08:13:34.265
      info
      ! iobroker
      info
      npm ERR! A complete log of this run can be found in:npm ERR! C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache_logs\2018-11-12T07_13_34_265Z-debug.log
      iobroker
      info
      ! iobroker
      info
      ERR! 404 Not Found: https://github.com/foxriver76/ioBroker.xbox --production --save --prefix C:/ioBroker
      iobroker
      info
      npm
      iobroker
      2018-11-12 08:13:34.249
      info
      ERR! code E404
      iobroker
      info
      npm
      iobroker
      2018-11-12 08:13:31.313
      info
      npm install "https://github.com/foxriver76/ioBroker.xbox --production --save --prefix "C:/ioBroker" (System call)
      iobroker
      2018-11-12 08:13:30.141
      info
      iobroker
      2018-11-12 08:13:29.610
      info
      url "https://github.com/foxriver76/ioBroker.xbox "
        foxriver76F Offline
        foxriver76
        #92
        @DKM:
        npm 4.6.1
        node 8.12.0
        Python 3.7.1
        Der erste Versuch mit npm i iobroker.xbox –unsafe-perm ist fehlgeschlagen: `
        Dir fehlt auf jeden Fall Python im Pfad. Wie hast du deine Python Version festgestellt?
        Bezüglich dem Rest habe ich mich mal überwunden und probiere es mal auf meiner Windows VM.
          DKM
          #93
          Hallo und danke für Deine schnelle Antwort.
          Ich habe vor dem Test Python installiert, daher kenne ich die Version. Nach deiner Antwort habe ich in die Umgebungsvariablen geschaut, da taucht Python auch auf.
          Ich hab den Rechner dann mal neugestartet und die Installation erneut versucht. Im erstem Moment habe ich gedacht, dass es nun funktioniert, da auch einige Daten heruntergeladen wurden. Am Ende erscheint dann doch eine Fehlermeldung und die Installation ist fehlgeschlagen.
          iobroker.xbox@0.1.4 preinstall C:\WINDOWS\system32\node_modules.staging\iobroker.xbox-6e00f71c
          ! > iobroker.xbox@0.1.4 install C:\WINDOWS\system32\node_modules\iobroker.xbox
          npip install
          Successfully completed pip check.
          Collecting xbox-smartglass-rest>=0.9.7
          Downloading https://files.pythonhosted.org/packages/05/69/9bc572f4e0b015cf461110212f23301e820c1da4d83e292d81f1b2f23764/xbox_smartglass_rest-0.9.7-py2.py3-none-any.whl
          Collecting xbox-smartglass-core>=1.0.11 (from xbox-smartglass-rest>=0.9.7)
          Downloading https://files.pythonhosted.org/packages/e2/f2/66046ed3c475722561b20f1787cf5c5d8d2e5ef81d89e9d3279db82f0df6/xbox_smartglass_core-1.0.11-py2.py3-none-any.whl (57kB)
          100% |████████████████████████████████| 61kB 564kB/s
          Collecting xbox-smartglass-stump>=0.9.4 (from xbox-smartglass-rest>=0.9.7)
          Downloading https://files.pythonhosted.org/packages/7e/ea/fae9ae03e3ef0afc3c27638e8872254bf96bd14f06dc1ba5bce08b7916c7/xbox_smartglass_stump-0.9.4-py2.py3-none-any.whl
          Collecting Flask (from xbox-smartglass-rest>=0.9.7)
          Downloading https://files.pythonhosted.org/packages/7f/e7/08578774ed4536d3242b14dacb4696386634607af824ea997202cd0edb4b/Flask-1.0.2-py2.py3-none-any.whl (91kB)
          100% |████████████████████████████████| 92kB 1.6MB/s
          Collecting appdirs==1.4.3 (from xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
          Downloading https://files.pythonhosted.org/packages/56/eb/810e700ed1349edde4cbdc1b2a21e28cdf115f9faf263f6bbf8447c1abf3/appdirs-1.4.3-py2.py3-none-any.whl
          Collecting urwid==2.0.1 (from xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
          Downloading https://files.pythonhosted.org/packages/c7/90/415728875c230fafd13d118512bde3184d810d7bf798a631abc05fac09d0/urwid-2.0.1.tar.gz (604kB)
          100% |████████████████████████████████| 614kB 3.6MB/s
          Collecting dpkt==1.9.1 (from xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
          Downloading https://files.pythonhosted.org/packages/bf/a4/8e4622fac4841b5e4a347fa9da4c057a7974258df247031280008d6ac0d0/dpkt-1.9.1.tar.gz (115kB)
          100% |████████████████████████████████| 122kB 2.8MB/s
          Collecting construct==2.9.41 (from xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
          Downloading https://files.pythonhosted.org/packages/e6/f5/064be5013506d54212b396e8fc3e9890e60ed6a27df6d52529f0b8361cd5/construct-2.9.41.tar.gz (54kB)
          100% |████████████████████████████████| 61kB 2.2MB/s
          Collecting xbox-webapi>=1.1.2 (from xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
          Downloading https://files.pythonhosted.org/packages/2d/bf/aaf24cc78184393c5c2472e822c0e145b793e346a8085bee02e89a3428ba/xbox_webapi-1.1.7-py2.py3-none-any.whl (45kB)
          100% |████████████████████████████████| 51kB 2.0MB/s
          Collecting gevent==1.2.2 (from xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
          Downloading https://files.pythonhosted.org/packages/1b/92/b111f76e54d2be11375b47b213b56687214f258fd9dae703546d30b837be/gevent-1.2.2.tar.gz (3.1MB)
          100% |████████████████████████████████| 3.1MB 1.9MB/s
          Collecting cryptography==2.3.1 (from xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
          Downloading https://files.pythonhosted.org/packages/39/dd/43985388f82ac0b4698671e96235c6324bdf14339e21eb3647f4e5b99017/cryptography-2.3.1-cp37-cp37m-win_amd64.whl (1.3MB)
          100% |████████████████████████████████| 1.3MB 3.0MB/s
          Collecting marshmallow-objects (from xbox-smartglass-stump>=0.9.4->xbox-smartglass-rest>=0.9.7)
          Downloading https://files.pythonhosted.org/packages/9e/ae/c044161526096617ed2523749ae3187449910b83dae12610f30a42672fae/marshmallow_objects-1.0.17-py2.py3-none-any.whl
          Collecting Werkzeug>=0.14 (from Flask->xbox-smartglass-rest>=0.9.7)
          Downloading https://files.pythonhosted.org/packages/20/c4/12e3e56473e52375aa29c4764e70d1b8f3efa6682bef8d0aae04fe335243/Werkzeug-0.14.1-py2.py3-none-any.whl (322kB)
          100% |████████████████████████████████| 327kB 307kB/s
          Collecting itsdangerous>=0.24 (from Flask->xbox-smartglass-rest>=0.9.7)
          Downloading https://files.pythonhosted.org/packages/76/ae/44b03b253d6fade317f32c24d100b3b35c2239807046a4c953c7b89fa49e/itsdangerous-1.1.0-py2.py3-none-any.whl
          Collecting click>=5.1 (from Flask->xbox-smartglass-rest>=0.9.7)
          Downloading https://files.pythonhosted.org/packages/fa/37/45185cb5abbc30d7257104c434fe0b07e5a195a6847506c074527aa599ec/Click-7.0-py2.py3-none-any.whl (81kB)
          100% |████████████████████████████████| 81kB 2.3MB/s
          Collecting Jinja2>=2.10 (from Flask->xbox-smartglass-rest>=0.9.7)
          Downloading https://files.pythonhosted.org/packages/7f/ff/ae64bacdfc95f27a016a7bed8e8686763ba4d277a78ca76f32659220a731/Jinja2-2.10-py2.py3-none-any.whl (126kB)
          100% |████████████████████████████████| 133kB 3.8MB/s
          Collecting demjson (from xbox-webapi>=1.1.2->xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
          Downloading https://files.pythonhosted.org/packages/96/67/6db789e2533158963d4af689f961b644ddd9200615b8ce92d6cad695c65a/demjson-2.2.4.tar.gz (131kB)
          100% |████████████████████████████████| 133kB 419kB/s
          Collecting requests (from xbox-webapi>=1.1.2->xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
          Downloading https://files.pythonhosted.org/packages/ff/17/5cbb026005115301a8fb2f9b0e3e8d32313142fe8b617070e7baad20554f/requests-2.20.1-py2.py3-none-any.whl (57kB)
          100% |████████████████████████████████| 61kB 2.6MB/s
          Collecting greenlet>=0.4.10 (from gevent==1.2.2->xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
          Downloading https://files.pythonhosted.org/packages/90/a3/da8593df08ee2efeb86ccf3201508a1fd2a3749e2735b7cadb7dd00416c6/greenlet-0.4.15-cp37-cp37m-win_amd64.whl
          Collecting cffi!=1.11.3,>=1.7 (from cryptography==2.3.1->xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
          Downloading https://files.pythonhosted.org/packages/ca/f2/e375b7469a2dfe9d1feac81a10df97f18cd771b9a10ac62ca9864b760f7c/cffi-1.11.5-cp37-cp37m-win_amd64.whl (165kB)
          100% |████████████████████████████████| 174kB 3.7MB/s
          Collecting asn1crypto>=0.21.0 (from cryptography==2.3.1->xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
          Downloading https://files.pythonhosted.org/packages/ea/cd/35485615f45f30a510576f1a56d1e0a7ad7bd8ab5ed7cdc600ef7cd06222/asn1crypto-0.24.0-py2.py3-none-any.whl (101kB)
          100% |████████████████████████████████| 102kB 3.4MB/s
          Collecting six>=1.4.1 (from cryptography==2.3.1->xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
          Downloading https://files.pythonhosted.org/packages/67/4b/141a581104b1f6397bfa78ac9d43d8ad29a7ca43ea90a2d863fe3056e86a/six-1.11.0-py2.py3-none-any.whl
          Collecting idna>=2.1 (from cryptography==2.3.1->xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
          Downloading https://files.pythonhosted.org/packages/4b/2a/0276479a4b3caeb8a8c1af2f8e4355746a97fab05a372e4a2c6a6b876165/idna-2.7-py2.py3-none-any.whl (58kB)
          100% |████████████████████████████████| 61kB 2.3MB/s
          Collecting marshmallow (from marshmallow-objects->xbox-smartglass-stump>=0.9.4->xbox-smartglass-rest>=0.9.7)
          Downloading https://files.pythonhosted.org/packages/6e/12/2a4239760bc78564434d1daecd9a504e7b6efb4f5722d5388b74407bb3b3/marshmallow-2.16.3-py2.py3-none-any.whl (49kB)
          Collecting MarkupSafe>=0.23 (from Jinja2>=2.10->Flask->xbox-smartglass-rest>=0.9.7)
          Downloading https://files.pythonhosted.org/packages/44/6e/41ac9266e3db762dfd9089f6b0d2298c84160f54ef2a7257c17b0e7ec2ec/MarkupSafe-1.1.0-cp37-cp37m-win_amd64.whl
          Collecting certifi>=2017.4.17 (from requests->xbox-webapi>=1.1.2->xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
          Downloading https://files.pythonhosted.org/packages/56/9d/1d02dd80bc4cd955f98980f28c5ee2200e1209292d5f9e9cc8d030d18655/certifi-2018.10.15-py2.py3-none-any.whl (146kB)
          100% |████████████████████████████████| 153kB 3.9MB/s
          Collecting urllib3<1.25,>=1.21.1 (from requests->xbox-webapi>=1.1.2->xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
          Downloading https://files.pythonhosted.org/packages/62/00/ee1d7de624db8ba7090d1226aebefab96a2c71cd5cfa7629d6ad3f61b79e/urllib3-1.24.1-py2.py3-none-any.whl (118kB)
          100% |████████████████████████████████| 122kB 3.2MB/s
          Collecting chardet<3.1.0,>=3.0.2 (from requests->xbox-webapi>=1.1.2->xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
          Downloading https://files.pythonhosted.org/packages/bc/a9/01ffebfb562e4274b6487b4bb1ddec7ca55ec7510b22e4c51f14098443b8/chardet-3.0.4-py2.py3-none-any.whl (133kB)
          100% |████████████████████████████████| 143kB 3.9MB/s
          Collecting pycparser (from cffi!=1.11.3,>=1.7->cryptography==2.3.1->xbox-smartglass-core>=1.0.11->xbox-smartglass-rest>=0.9.7)
          Downloading https://files.pythonhosted.org/packages/68/9e/49196946aee219aead1290e00d1e7fdeab8567783e83e1b9ab5585e6206a/pycparser-2.19.tar.gz (158kB)
          100% |████████████████████████████████| 163kB 3.7MB/s
          Building wheels for collected packages: urwid, dpkt, construct, gevent, demjson, pycparser
          Running setup.py bdist_wheel for urwid ... done
          Stored in directory: C:\Users\krist\AppData\Local\pip\Cache\wheels\34\06\50\24011714e101b5ad8518c69175d117a257413e3c15a92983f0
          Running setup.py bdist_wheel for dpkt ... done
          Stored in directory: C:\Users\krist\AppData\Local\pip\Cache\wheels\0a\5f\3c\e0ffceb6554711f12a7101384f29ec13b85136dfcf1f692b8f
          Running setup.py bdist_wheel for construct ... done
          Stored in directory: C:\Users\krist\AppData\Local\pip\Cache\wheels\13\cd\02\acabe4bfa9899d53c3e3b13675610d2e2dcb9ae110359d4f61
          Running setup.py bdist_wheel for gevent ... error
          Complete output from command C:\Users\krist\AppData\Local\Programs\Python\Python37\python.exe -u -c "import setuptools, tokenize;file='C:\Users\krist\AppData\Local\Temp\pip-install-9qetwh8j\gevent\setup.py';f=getattr(tokenize, 'open', open)(file);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, file, 'exec'))" bdist_wheel -d C:\Users\krist\AppData\Local\Temp\pip-wheel-8m2sb2t3 --python-tag cp37:
          C:\Users\krist\AppData\Local\Programs\Python\Python37\lib\distutils\dist.py:274: UserWarning: Unknown distribution option: 'cffi_modules'
          warnings.warn(msg)
          running bdist_wheel
          running build
          running build_py
          creating build
          creating build\lib.win-amd64-3.7
          creating build\lib.win-amd64-3.7\gevent
          copying src\gevent\backdoor.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\baseserver.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\builtins.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\core.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\event.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\fileobject.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\greenlet.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\hub.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\local.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\lock.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\monkey.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\os.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\pool.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\pywsgi.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\queue.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\resolver_ares.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\resolver_thread.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\select.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\server.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\signal.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\socket.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\ssl.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\subprocess.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\thread.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\threading.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\threadpool.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\timeout.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\util.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\win32util.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\wsgi.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent_compat.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent_fileobjectcommon.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent_fileobjectposix.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent_semaphore.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent_socket2.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent_socket3.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent_socketcommon.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent_ssl2.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent_ssl3.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent_sslgte279.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent_tblib.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent_threading.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent_util.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent_util_py2.py -> build\lib.win-amd64-3.7\gevent
          copying src\gevent_init_.py -> build\lib.win-amd64-3.7\gevent
          creating build\lib.win-amd64-3.7\gevent\libev
          copying src\gevent\libev\corecffi.py -> build\lib.win-amd64-3.7\gevent\libev
          copying src\gevent\libev_corecffi_build.py -> build\lib.win-amd64-3.7\gevent\libev
          copying src\gevent\libev_init_.py -> build\lib.win-amd64-3.7\gevent\libev
          running egg_info
          writing src\gevent.egg-info\PKG-INFO
          writing dependency_links to src\gevent.egg-info\dependency_links.txt
          writing requirements to src\gevent.egg-info\requires.txt
          writing top-level names to src\gevent.egg-info\top_level.txt
          reading manifest file 'src\gevent.egg-info\SOURCES.txt'
          reading manifest template 'MANIFEST.in'
          warning: no files found matching 'changelog.rst'
          warning: no files found matching 'known_failures.py'
          warning: no files found matching '.pep8'
          no previously-included directories found matching '_pycache_'
          warning: no previously-included files matching '
          .so' found anywhere in distribution
          warning: no previously-included files matching '.o' found anywhere in distribution
          .lo' found anywhere in distribution
          warning: no previously-included files matching '.la' found anywhere in distribution
          warning: no previously-included files matching 'config.log' found anywhere in distribution
          warning: no previously-included files matching 'config.status' found anywhere in distribution
          no previously-included directories found matching 'doc_build'
          .pyc' found anywhere in distribution
          warning: no previously-included files matching '.coverage' found under directory 'src\greentest'
          no previously-included directories found matching 'src\greentest\htmlcov'
          warning: no previously-included files matching 'stamp-h?' found under directory 'deps\c-ares'
          warning: no previously-included files matching 'ares_build.h.orig' found under directory 'deps\c-ares'
          no previously-included directories found matching 'deps\libev.deps'
          warning: no previously-included files matching 'Makefile' found under directory 'deps\libev'
          warning: no previously-included files matching 'libtool' found under directory 'deps\libev'
          warning: no previously-included files matching 'stamp-h?' found under directory 'deps\libev'
          warning: no previously-included files matching 'config.h' found under directory 'deps\libev'
          warning: no previously-included files matching 'corecffi.c' found under directory 'src\gevent'
          warning: no previously-included files found matching 'Makefile'
          warning: no previously-included files found matching 'configure-output'
          writing manifest file 'src\gevent.egg-info\SOURCES.txt'
          copying src\gevent_semaphore.pxd -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\ares.pyx -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\cares.pxd -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\cares_ntop.h -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\cares_pton.h -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\dnshelper.c -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\gevent.semaphore.c -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\gevent.ares.c -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\gevent.ares.h -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\python.pxd -> build\lib.win-amd64-3.7\gevent
          copying src\gevent\libev_corecffi_cdef.c -> build\lib.win-amd64-3.7\gevent\libev
          copying src\gevent\libev_corecffi_source.c -> build\lib.win-amd64-3.7\gevent\libev
          copying src\gevent\libev\callbacks.c -> build\lib.win-amd64-3.7\gevent\libev
          copying src\gevent\libev\callbacks.h -> build\lib.win-amd64-3.7\gevent\libev
          copying src\gevent\libev\corecext.ppyx -> build\lib.win-amd64-3.7\gevent\libev
          copying src\gevent\libev\corecext.pyx -> build\lib.win-amd64-3.7\gevent\libev
          copying src\gevent\libev\gevent.corecext.c -> build\lib.win-amd64-3.7\gevent\libev
          copying src\gevent\libev\libev.h -> build\lib.win-amd64-3.7\gevent\libev
          copying src\gevent\libev\libev.pxd -> build\lib.win-amd64-3.7\gevent\libev
          copying src\gevent\libev\libev_vfd.h -> build\lib.win-amd64-3.7\gevent\libev
          copying src\gevent\libev\stathelper.c -> build\lib.win-amd64-3.7\gevent\libev
          running build_ext
          building 'gevent.libev.corecext' extension
          error: Microsoft Visual C++ 14.0 is required. Get it with "Microsoft Visual C++ Build Tools": http://landinghub.visualstudio.com/visual-cpp-build-tools
          Failed building wheel for gevent
          Running setup.py clean for gevent
          Running setup.py bdist_wheel for demjson ... done
          Stored in directory: C:\Users\krist\AppData\Local\pip\Cache\wheels\c5\d2\ab\a54fb5ea53ac3badba098160e8452fa126a51febda80440ded
          Running setup.py bdist_wheel for pycparser ... done
          Stored in directory: C:\Users\krist\AppData\Local\pip\Cache\wheels\f2\9a\90\de94f8556265ddc9d9c8b271b0f63e57b26fb1d67a45564511
          Successfully built urwid dpkt construct demjson pycparser
          Failed to build gevent
          Installing collected packages: appdirs, urwid, dpkt, construct, demjson, certifi, urllib3, chardet, idna, requests, xbox-webapi, greenlet, gevent, pycparser, cffi, asn1crypto, six, cryptography, xbox-smartglass-core, marshmallow, marshmallow-objects, xbox-smartglass-stump, Werkzeug, itsdangerous, click, MarkupSafe, Jinja2, Flask, xbox-smartglass-rest
          Running setup.py install for gevent ... error
          Complete output from command C:\Users\krist\AppData\Local\Programs\Python\Python37\python.exe -u -c "import setuptools, tokenize;file='C:\Users\krist\AppData\Local\Temp\pip-install-9qetwh8j\gevent\setup.py';f=getattr(tokenize, 'open', open)(file);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, file, 'exec'))" install --record C:\Users\krist\AppData\Local\Temp\pip-record-qpz44q8l\install-record.txt --single-version-externally-managed --compile --user --prefix=:
          warnings.warn(msg)
          running install
          running build
          running build_py
          creating build
          running egg_info
          warning: no previously-included files matching '_corecffi.c' found under directory 'src\gevent'
          copying src\gevent\gevent._semaphore.c -> build\lib.win-amd64-3.7\gevent
          running build_ext
          Command "C:\Users\krist\AppData\Local\Programs\Python\Python37\python.exe -u -c "import setuptools, tokenize;file='C:\Users\krist\AppData\Local\Temp\pip-install-9qetwh8j\gevent\setup.py';f=getattr(tokenize, 'open', open)(file);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, file, 'exec'))" install --record C:\Users\krist\AppData\Local\Temp\pip-record-qpz44q8l\install-record.txt --single-version-externally-managed --compile --user --prefix=" failed with error code 1 in C:\Users\krist\AppData\Local\Temp\pip-install-9qetwh8j\gevent
          npm WARN enoent ENOENT: no such file or directory, open 'C:\WINDOWS\system32\package.json'
          npm WARN system32 No description
          npm WARN system32 No repository field.
          npm WARN system32 No README data
          npm WARN system32 No license field.
          npm ERR! errno 1
          npm ERR!
          npm ERR! C:\Users\krist\AppData\Roaming\npm-cache_logs\2018-11-12T08_35_20_483Z-debug.log
          Im Log ist mir noch aufgefallen, dass z.B. in Zeile 7638 immer ein doppelter "\" genutzt wird. Kann das u,a, auch einen Fehler verursachen? Ich hab das Log mal mit angehängt
            DKM
            #94
            Nachtrag:
            Mir ist aufgefallen, dass bei einer der fehlgeschlagenen Installationen unter Objekte
            ".admin
            gelistet war. Die Seite mit den Objekten hat dann in Dauerschleife geladen. Erst ein Restore hat da Abhilfe geschaffen.
            Da ich nicht wusste, wann das ganze passiert ist, habe ich danach nochmal den Adapter versucht zu installieren. Die Fehlermeldungen sind wieder erschienen, aber unter Adapter taucht nun bei aktiviertem XBox Filter folgendes auf:
              foxriver76F Offline
              foxriver76
              #95
              Ich kümmere mich mal um die Win-Installation. Notfalls gibt es einen Workaround, den ich jedoch vermeiden möchte.
              Ach so und da ich es noch in deinem Log gesehen habe – hat jetzt nix mit dem Fehlschalg zu tun -- du solltest das Kommando im ioBroker Ordner ausführen oder mit dem --prefix Flag den ioBroker Ordner als Pfad mitgeben. also müsstest du vorher mittels dem Change Directory Befehl (cd) in den ioB Ordner wechseln, vermutlich C:\ioBroker\
              • NegaleinN Offline
                NegaleinN Offline
                Negalein
                #96
                @foxriver76:
                Wie steht es umnode -v,nodejs -vundnpm -v `
                C:\ioBroker>node -v
                v8.12.0
                C:\ioBroker>nodejs -v
                Der Befehl "nodejs" ist entweder falsch geschrieben oder
                C:\ioBroker>npm -v
                6.4.1
                C:\ioBroker>
                ° Fixer ---> iob fix
                  DKM
                  #97
                  @foxriver76:
                  Ach so und da ich es noch in deinem Log gesehen habe – hat jetzt nix mit dem Fehlschalg zu tun -- du solltest das Kommando im ioBroker Ordner ausführen oder mit dem --prefix Flag den ioBroker Ordner als Pfad mitgeben. also müsstest du vorher mittels dem Change Directory Befehl (cd) in den ioB Ordner wechseln, vermutlich C:\ioBroker\ `
                  Hallo foxriver76,
                  danke für die Arbeit, die du Dir machst. Ich habe die Installation im Ordner ioBroker ausgeführt. Liegt es eventuell daran, dass z.B. Python nicht im ioBroker Verzeichnis installiert wird?
                  Falls Du weitere Infos über das System brauchst, sag ruhig Bescheid. Ich versuche Dir dann aus der Windowsseite zu helfen :)
                    foxriver76F Offline
                    foxriver76
                    #98
                    So, also das gevent nicht korrekt kompiliert wird, liegt wohl an Python 3.7. Ich konnte das Setup nun durchführen, durch die Nutzung von Python 3.6.5. Von der Python Seite direkt mittels Installer installieren und Pfad setzen lassen: https://www.python.org/downloads/release
                    Ich muss vermutlich noch was im Code anpassen, dass der Adapter korrekt läuft unter Windows (Python Pfade sind wohl doch anders als gedacht), jedoch hoffe ich, dass die Installation damit funktioniert.
                    Und da wahrscheinlich bei Windows pip direkt mitinstalliert wird, sollte das ein mal auf den neuen Stand gebracht werden:
                    python -m pip install --upgrade pip
                    • NegaleinN Offline
                      NegaleinN Offline
                      Negalein
                      #99
                      @foxriver76:
                      Hab Python 3.6.5 installiert.
                      Dann das Setup für den Adapter nochmal gestartet.
                      Es scheint der Adapter jetzt in ioBroker auf, er lässt sich aber noch nicht installiren.
                      Fehlermeldung beim Setup dass er unter Instanzen aufscheint:
                      $ ./iobroker add xbox  --host Nega-PC
                      host.Nega-PC install adapter xbox
                      npm install --production (System call) in "C:/ioBroker/node_modules/iobroker.xbox"
                      npm WARN
                       deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
                      npm WARN
                      deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
                      npm WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
                      npm WARN
                      deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
                      npm WARN
                       deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
                      Error: No python executable.    at getPythonInfo (C:\ioBroker\node_modules\iobroker.xbox\node_modules\nopy\src\api.js:52:11)
                          at Promise.then.catch.error (C:\ioBroker\node_modules\iobroker.xbox\node_modules\nopy\src\api.js:115:14)
                          at <anonymous>
                      npm
                      ERR! code ELIFECYCLEnpm ERR! errno 1
                      npm
                      ERR! iobroker.xbox@0.1.4 install: `npip install`npm ERR! Exit status 1
                      npm ERR!
                      npm ERR!
                       Failed at the iobroker.xbox@0.1.4 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                      npm ERR! A complete log of this run can be found in:npm ERR!     C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_logs\2018-11-12T13_50_31_670Z-debug.log
                      Cannot install iobroker.xbox: 1
                      ERROR: process exited with code 25</anonymous>
                        foxriver76F Offline
                        foxriver76
                        #100
                        Witzig, das Gleiche passiert bei mir wenn ich es über die GUI probiere. Im Terminal````
                        iobroker add xbox
                          foxriver76F Offline
                          foxriver76
                          #101
                          Also die Version 0.1.5 die gerade auf GitHub ist, sollte den Server nun auch auf Windows korrekt starten und dann läuft es sowieso äquivalent, bezüglich dem korrekten beenden muss ich nochmal schauen, da der Rest Server als Grand Child sozusagen gespawnt wird und ich bislang keine geeignete Lösung gefunden habe, das auf Windows zu beenden. Der Adapter läuft bei mir nur, wenn ich ioBroker als Administrator ausführe. Ansonsten sagt er, dass er keine PythonExecutable findet.
                          • Also bitte nicht Python 3.7 nutzen, wegen dem Bug (3.6.5 ist von mir empfohlen, damit laufen auch die Tests)
                          • ioB muss als Admin ausgeführt werden
                            DKM
                            #102
                            Bei mir geht es nun auch. Hier meine Vorgehensweise
                            Benötigte Programme:
                            Python 3.6.7 (Version 3.7.x funktioniert nicht)
                            https://www.python.org/downloads/release/python-367/
                            https://aka.ms/vs/15/release/vc_redist.x64.exe
                            https://aka.ms/vs/15/release/vc_redist.x86.exe
                            Installation Python 3.6.7
                            Setup starten und <u>Customize Installation</u> auswählen
                            Im Fenster Optional Features alle möglichen Häkchen setzen
                            Im Fenster Advanced Options die Punkte "Install for all Users" und "Add Python to environment tables" auswählen
                            Nach der Installation eine Kommandozeile als Administrator öffnen und zum Pythonpfad navigieren. Dort pip aktualisieren
                            Der Standardpfad lautet: C:\Program Files\Python36
                            Installation Microsoft Visual C++
                            Hier einfach die Standardroutine durchlaufen lassen und den Rechner danach neustarten.
                            Installation des Adapters
                            Nach dem Neustart wieder eine Kommandozeile als Administrator öffnen und ins iobroker Verzeichnis wechseln
                            Erst zur Sicherheit ein Backup, falls etwas schief gehen sollte:
                            iobroker backup
                            Danach folgenden Befehl ausführen:
                            Nicht von den Fehlermeldungen verwirren lassen, ich vermute, dass diese noch aus der Entwicklung unter Unix kommen, da auch auf einen AVR verwiesen wird. Ich habe nach der Installation den iobroker neugestartet, kann aber nicht sagen, ob dies erforderlich ist.
                            Nun in die Adminoberfläche wechseln und dort unter der Schaltfläche Adapter den Adapter per GitHub installieren. Auch hier werden bei der Installation Fehler angezeigt, aber dennoch wird der Adapter installiert.
                            Die Installation über die Adapterfunktion wird euch nur die Version
                            Die für den Betrieb des Adapters notwendige XBOX Live Geräte-ID findet Ihr unter:
                            Einstellungen -> System -> Konsoleninfo
                            Folgende auftretende Fehler konnte ich beheben:
                            Requested anonymous connection is not allowed
                            Solltet Ihr beim Verbinden in den Log-Dateien folgenden Fehler finden:
                            [CONNECT] <=== Connection to your Xbox failed: Requested anonymous connection is not allowed by console
                            müsst Ihr noch folgende Einstellung ändern:
                            Einstellungen -> Voreinstellungen -> Xbox-App-Verbindungen -> Verbindung über alle Geräte zulassen
                            Sollte die Fehlermeldung dann immer noch erscheinen, probiert bitte noch die Konsole vollständig neuzustarten. Dies macht Ihr, indem ihr den Power-Button solange gedrückt haltet, bis Sie sich ausgeschaltet hat. Das ist in der Regel ca. 5 Sekunden.
                            Nach einem Neustart sollte es gehen - ggf. nochmal die IP überprüfen, bei mir hatte Sie sich nach dem Neustart geändert.
                            Keine Verbindung zur Konsole (Port)
                            Richtet bitte euren Router / Switch so ein, dass Port 5007 TCP auf die XBox zeigt.
                            Konsole lässt sich über "xbox.0.settings.power" nicht einschalten
                            Um die Funktion nutzen zu können, muss der Schnellstart aktiviert sein
                            Einstellungen -> Energie & Start -> Energiemodus & Start -> Energiemodus = Schnelles Hochfahren
                              foxriver76F Offline
                              foxriver76
                              #103
                              Danke für die Vorgehensweise, läuft es jetzt so bei dir? Am besten noch von GitHub die 0.1.5 holen, glaube nicht dass die 0.1.4 unter Windows läuft, also funktional.
                              Erinnere mich gerade an meinen Kommilitonen der sagte: "Jedes mal wenn jemand Python auf Windows installiert, stirbt ein kleines unschuldiges Kätzchen" – jetzt weiß ich was er meinte. :lol:
                                DKM
                                #104
                                Hab den Beitrag nochmal angepasst. Der Adapter läuft, aber die Anmeldung klappt nicht. Ich erhalte den Fehler:
                                  foxriver76F Offline
                                  foxriver76
                                  #105
                                  Stimmt, das musst du in der Xbox erlauben. Fehlt in der Doku.
                                    DKM
                                    #106
                                    So nun geht alles :D
                                    Port-Freigabe war nötig und die fehlende Einstellung. Hab das noch alles hinzugefügt. Vielleicht kannst du ja den Beitrag in deinen Beitrag verlinken, ansonsten stell ich ihn Dir natürlich auch mit den BB-Codes gerne zur Verfügung. Die Hauptarbeit hattest du ja ;)
                                    P.S. Endlich bei GTA Online keine Auto-Logout mehr :P :P
                                      foxriver76F Offline
                                      foxriver76
                                      #107
                                      @DKM:
                                      P.S. Endlich bei GTA Online keine Auto-Logout mehr :P :P `
                                      Ich werde mal im ersten Beitrag darauf verweisen, später packe ich dann mal 0.1.5. auf npm, dann muss auch nicht mehr von Github installiert werden und das mit allow non authenticated users muss auf jeden fall mit in die ReadMe. Danke für deine Mühen.
                                      • NegaleinN Offline
                                        NegaleinN Offline
                                        Negalein
                                        #108
                                        @DKM:
                                        Bei mir geht es nun auch. Hier meine Vorgehensweise `
                                        Nachdem der Adapter bei mir nicht mehr aufgeschienen ist und nur unter Instanzen zu sehen war, hab ich ihn dort gelöscht und nach deiner Vorgehensweise neu installiert.
                                        Leider funktioniert es bei mir nicht.
                                        $ ./iobroker url "https://github.com/foxriver76/ioBroker.xbox"
                                        install https://github.com/foxriver76/ioBroker.xbox/tarball/master
                                        npm install https://github.com/foxriver76/ioBroker.xbox/tarball/master --production --save --prefix "C:/ioBroker" (System call)
                                            at <anonymous>
                                        npm
                                        npm
                                         ERR! iobroker.xbox@0.1.5 install: `npip install`npm ERR! Exit status 1
                                        npm ERR!
                                        npm ERR! Failed at the iobroker.xbox@0.1.5 install script.
                                        npm ERR! A complete log of this run can be found in:npm ERR!     C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_logs\2018-11-13T14_50_48_593Z-debug.log
                                        process exited with code 0</anonymous>
                                          DKM
                                          #109
                                          Hab es gerade auch nochmal versucht - nun bekomm ich auch massiv Fehler und eine Installation ist nicht mehr möglich :shock:
                                          Versuch die Adapterinstallation mal nur über die Konsole (Admin):
                                          iobroker install xbox
                                          iobroker upload xbox
                                          Danach hatte ich den wieder :D
