  4. [Aufruf] Neuer Adapter ioBroker.tuya (WLAN devices Tuya Smart Life und andere)
    6.5k
547 Beiträge 97 Kommentatoren 208.7k Aufrufe 20 Beobachtet
  • arteckA Offline
    arteckA Offline
    arteck
    Version 0.1.1
    2 Geräte wurden erkannt und das wars
    a.0	2018-10-30 21:36:09.696	info	0620097468c63ac6ad74: Error from device (3): App still open on your mobile phone? Error: Error from socket
    tuya.0	2018-10-30 21:36:09.687	info	05200288bcddc2e893ce: Error from device (3): App still open on your mobile phone? Error: Error from socket
    tuya.0	2018-10-30 21:36:08.691	info	0620097468c63ac6ad74: Error from device (2): App still open on your mobile phone? Error: Error from socket
    tuya.0	2018-10-30 21:36:08.683	info	05200288bcddc2e893ce: Error from device (2): App still open on your mobile phone? Error: Error from socket
    tuya.0	2018-10-30 21:36:07.684	info	0620097468c63ac6ad74: Error from device (1): App still open on your mobile phone? Error: Error from socket
    tuya.0	2018-10-30 21:36:07.679	info	05200288bcddc2e893ce: Error from device (1): App still open on your mobile phone? Error: Error from socket
    tuya.0	2018-10-30 21:36:06.673	info	05200288bcddc2e893ce: Error from device (0): App still open on your mobile phone? Error: Error from socket
    tuya.0	2018-10-30 21:36:06.672	info	0620097468c63ac6ad74: Error from device (0): App still open on your mobile phone? Error: Error from socket
    tuya.0	2018-10-30 21:36:06.662	info	05200288bcddc2e893ce Init with IP=undefined, Key=81f082cfd10e1f51
    tuya.0	2018-10-30 21:36:06.661	info	05200288bcddc2e893ce: Can not start because IP unknown
    tuya.0	2018-10-30 21:36:06.660	info	Discover for local Tuya devices on port 6666
    dann
    2018-10-30 21:39:41.997	info	05200288bcddc2e893ce: Error from device (1): App still open on your mobile phone? Error: Error from socket
    tuya.0	2018-10-30 21:39:40.991	info	05200288bcddc2e893ce: Error from device (0): App still open on your mobile phone? Error: Error from socket
    tuya.0	2018-10-30 21:39:40.990	info	0620097468c63ac6ad74: Error from device (0): App still open on your mobile phone? Error: Error from socket
    tuya.0	2018-10-30 21:39:40.980	info	05200288bcddc2e893ce Init with IP=undefined, Key=81f082cfd10e1f51
    tuya.0	2018-10-30 21:39:40.980	info	05200288bcddc2e893ce: Can not start because IP unknown
    tuya.0	2018-10-30 21:39:40.979	info	Discover for local Tuya devices on port 6666
    tuya.0	2018-10-30 21:39:40.965	info	Existing devices initialized
    tuya.0	2018-10-30 21:39:40.947	info	0620097468c63ac6ad74 Init with IP=undefined, Key=a33c0ecbcd456db8
    tuya.0	2018-10-30 21:39:40.947	info	0620097468c63ac6ad74: Can not start because IP unknown
    tuya.0	2018-10-30 21:39:40.872	warn	0620097468c63ac6ad74.102: Value from device not defined in Schema: undefined
    tuya.0	2018-10-30 21:39:40.830	info	starting. Version 0.1.1 in /opt/iobroker/node_modules/iobroker.tuya, node: v8.12.0
    tuya.0	2018-10-30 21:39:40.667	info	States connected to redis: 192.168.1.199:6379
    die APP ist zu
    • apollon77A Offline
      @jogiibaer: Hm … er konnte scheinbar mal kurz verbinden und dann nicht mehr ... Wäre interessant zu sehen was passiert wenn er dann wieder online kommt. Kannst Du davon auch log senden?
      @arteck: Die IP ermittelt er wenn das Device das erste mal online war. In den "Metadaten über Proxy-Sync" steht die lokale IP leider nicht drin. Also muss das gerät mindestens einmal online gewesen sein das der Adapter es kennt, Alternativ versuch mal die IP (siehe weiter oben) in Deviec-Object native.ip reinzuschreiben ...
      Und am besten debug log ...
      Scheinbar sind diese "Nicht immer online"-Devices durchaus interessant. Sowas hab ich leider nicht.
      • R Offline
        RKBroker
        BTW, die neuen Gosund werden auch ausgelesen. Gosund-SW: 1.0.5. Muss nur mal schauen, was welcher Wert bedeutet…
        tuya.0	2018-10-31 00:28:14.839	debug	stateChange tuya.0.80434151dc4f22d49f6a.25 {"val":995,"ack":true,"ts":1540942094826,"q":0,"from":"system.adapter.tuya.0","lc":1540939602677}
        tuya.0	2018-10-31 00:28:14.839	debug	stateChange tuya.0.80434151dc4f22d49f6a.24 {"val":20895,"ack":true,"ts":1540942094826,"q":0,"from":"system.adapter.tuya.0","lc":1540939602669}
        tuya.0	2018-10-31 00:28:14.838	debug	stateChange tuya.0.80434151dc4f22d49f6a.23 {"val":31090,"ack":true,"ts":1540942094825,"q":0,"from":"system.adapter.tuya.0","lc":1540939602661}
        tuya.0	2018-10-31 00:28:14.838	debug	stateChange tuya.0.80434151dc4f22d49f6a.22 {"val":721,"ack":true,"ts":1540942094825,"q":0,"from":"system.adapter.tuya.0","lc":1540939602653}
        tuya.0	2018-10-31 00:28:14.837	debug	stateChange tuya.0.80434151dc4f22d49f6a.21 {"val":1,"ack":true,"ts":1540942094824,"q":0,"from":"system.adapter.tuya.0","lc":1540939602646}
        tuya.0	2018-10-31 00:28:14.837	debug	stateChange tuya.0.80434151dc4f22d49f6a.20 {"val":2285,"ack":true,"ts":1540942094824,"q":0,"from":"system.adapter.tuya.0","lc":1540942094824}
        tuya.0	2018-10-31 00:28:14.836	debug	stateChange tuya.0.80434151dc4f22d49f6a.19 {"val":262,"ack":true,"ts":1540942094824,"q":0,"from":"system.adapter.tuya.0","lc":1540942094824}
        tuya.0	2018-10-31 00:28:14.836	debug	stateChange tuya.0.80434151dc4f22d49f6a.18 {"val":167,"ack":true,"ts":1540942094823,"q":0,"from":"system.adapter.tuya.0","lc":1540942094823}
        tuya.0	2018-10-31 00:28:14.826	debug	stateChange tuya.0.80434151dc4f22d49f6a.9 {"val":0,"ack":true,"ts":1540942094822,"q":0,"from":"system.adapter.tuya.0","lc":1540939602615}
        tuya.0	2018-10-31 00:28:14.819	debug	stateChange tuya.0.80434151dc4f22d49f6a.1 {"val":true,"ack":true,"ts":1540942094808,"q":0,"from":"system.adapter.tuya.0","lc":1540939632505}
        tuya.0	2018-10-31 00:28:14.807	debug	80434151dc4f22d49f6a: Received data: {"1":true,"9":0,"18":167,"19":262,"20":2285,"21":1,"22":721,"23":31090,"24":20895,"25":995}
          Sync mit der App dann sollte sichtbar sein was was ist.
          Gesendet vom Handy …
          • surfer09S Offline
            surfer09S Offline
            surfer09
            Hallo Apollon! :)
            Vielen Dank für den Adapter! Mit meinen Gosund SP111 funktioniert das Ganze einwandfrei! Der Proxy-Start hat am Anfang etwas rumgezickt, hat dann aber doch irgendwann geklappt.
            Ich nutze IOS und habe Screenshots angehangen bezüglich Proxy / Zertifikat.
            Der QR-Code, der vom Proxy nach dem Start erzeugt wird, kann mit der normalen Kamera abgescannt werden. Nach dem Scannen wird gefragt, ob eine Seite im Safari geöffnet werden soll. Dies muss akzeptiert werden und das Zertifikat wird anschließend installiert.
            Gruß surfer ;)
              Cool Danke!!
              Ist es bei dir auch so das Du die Trust-Einstellung zum Zertifkat unter ettings -> Allgemein -> Info -> (ganz unten) Zertifkatseinstellungen ein/ausschalten kannst?
                PS: Und bitte IMMER beim Prox Sync ins log schauen und unbekannte Schemata an mich senden!
                • surfer09S Offline
                  surfer09S Offline
                  surfer09
                  @apollon77:
                  Cool Danke!!
                  Ist es bei dir auch so das Du die Trust-Einstellung zum Zertifkat unter ettings -> Allgemein -> Info -> (ganz unten) Zertifkatseinstellungen ein/ausschalten kannst? `
                  Ja genau, das ist abschaltbar (siehe Screenshot)
                    So, auf Github (und morgen im latest) gibt es die 0.1.2 vom Adapter
                    Changelog 0.1.2:
                    • Admin Optimiert (Proxy und so)
                    • Fehler abgefangen und Abläufe optimiert.
                    • SBorgS Offline
                      SBorgS Offline
                      SBorg
                      Super genial, danke :mrgreen:
                      tuya.0	2018-11-03 10:53:58.578	info	{"schema":"[{\"mode\":\"rw\",\"code\":\"led_switch\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"work_mode\",\"name\":\"模式\",
                      tuya.0	2018-11-03 10:53:58.578	info	new Shema added for product type t0TDGBQFFw1AZG1I. Please send next line from logfile on disk to developer!
                      Ist ein LED-Stripe-Controller: https://www.banggood.com/LUSTREON-WIFI-Smart-Voice-Control-LED-Strip-Light-Controller-Work-with-Alexa-Google-Home-DC5-23V-p-1320164.html
                      Proxy-Einrichtung habe ich leider erst zu spät gelesen… ;)
                      LG SBorg ( SBorg auf GitHub)
                        Bitte Zeile aus dem log auf Platte holen. Leider unvollständig.
                        • SBorgS Offline
                          SBorgS Offline
                          SBorg
                          Ah, sorry…
                          <code>tuya.0 {"schema":"[{\"mode\":\"rw\",\"code\":\"led_switch\",\"name\":\"埀关\",\"property\":{\"type\":\"bool\"},\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"work_mode\",\"name\":\"樥埮\",\"property\":{\"range\":[\"white\",\"colour\",\"scene\",\"scene_1\",\"scene_2\",\"scene_3\",\"scene_4\"],\"type\":\"enum\"},\"id\":2,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"bright_value\",\"name\":\"于庌\",\"property\":{\"unit\":\"\",\"min\":25,\"max\":255,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":3,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"temp_value\",\"name\":\"冡汖\",\"property\":{\"unit\":\"\",\"min\":0,\"max\":255,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":4,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"colour_data\",\"name\":\"彊光樥埮数\",\"property\":{\"type\":\"string\",\"maxlen\":14},\"id\":5,\"type\":\"obj\",\"desc\":\"rgbhsv\"},{\"mode\":\"rw\",\"code\":\"scene_data\",\"name\":\"情景樥埮数\",\"property\":{\"type\":\"string\",\"maxlen\":14},\"id\":6,\"type\":\"obj\",\"desc\":\"rgbhsv\"},{\"mode\":\"rw\",\"code\":\"flash_scene_1\",\"name\":\"滔光樥埮\",\"property\":{\"type\":\"string\",\"maxlen\":14},\"id\":7,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"flash_scene_2\",\"name\":\"矤纡樥埮\",\"property\":{\"type\":\"string\",\"maxlen\":44},\"id\":8,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"flash_scene_3\",\"name\":\"炍彊樥埮\",\"property\":{\"type\":\"string\",\"maxlen\":14},\"id\":9,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"flash_scene_4\",\"name\":\"斑斓樥埮\",\"property\":{\"type\":\"string\",\"maxlen\":44},\"id\":10,\"type\":\"obj\",\"desc\":\"\"}]","schemaExt":"[]"}[/code]</code>
                            Michi68
                            Danke für den nächsten schönen Adapter :)
                            2018-11-03 03:47:21.375  - [32minfo[39m: tuya.0 new Shema added for product type 2fISFtnNO1j4GWU4\. Please send next line from logfile on disk to developer!
                            2018-11-03 03:47:21.376  - [32minfo[39m: tuya.0 {"schema":"[{\"mode\":\"rw\",\"code\":\"led_switch\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power2\",\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"work_mode\",\"name\":\"模式\",\"property\":{\"range\":[\"white\",\"colour\",\"scene\",\"scene_1\",\"scene_2\",\"scene_3\",\"scene_4\"],\"type\":\"enum\"},\"iconname\":\"icon-dp_mode\",\"id\":2,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"bright_value\",\"name\":\"亮度\",\"property\":{\"unit\":\"\",\"min\":25,\"max\":255,\"scale\":0,\"step\":1,\"type\":\"value\"},\"iconname\":\"icon-dp_sun\",\"id\":3,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"temp_value\",\"name\":\"冷暖\",\"property\":{\"unit\":\"\",\"min\":0,\"max\":255,\"scale\":0,\"step\":1,\"type\":\"value\"},\"iconname\":\"icon-dp_light\",\"id\":4,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"colour_data\",\"name\":\"彩光模式数\",\"property\":{\"type\":\"string\",\"maxlen\":14},\"id\":5,\"type\":\"obj\",\"desc\":\"rgbhsv\"},{\"mode\":\"rw\",\"code\":\"scene_data\",\"name\":\"情景模式数\",\"property\":{\"type\":\"string\",\"maxlen\":14},\"id\":6,\"type\":\"obj\",\"desc\":\"rgbhsv\"},{\"mode\":\"rw\",\"code\":\"flash_scene_1\",\"name\":\"柔光模式\",\"property\":{\"type\":\"string\",\"maxlen\":14},\"id\":7,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"flash_scene_2\",\"name\":\"缤纷模式\",\"property\":{\"type\":\"string\",\"maxlen\":44},\"id\":8,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"flash_scene_3\",\"name\":\"炫彩模式\",\"property\":{\"type\":\"string\",\"maxlen\":14},\"id\":9,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"flash_scene_4\",\"name\":\"斑斓模式\",\"property\":{\"type\":\"string\",\"maxlen\":44},\"id\":10,\"type\":\"obj\",\"desc\":\"\"}]","schemaExt":"[{\"id\":1,\"inputType\":\"plain\"},{\"id\":2,\"inputType\":\" \"},{\"id\":3,\"inputType\":\"percent\"},{\"id\":4,\"inputType\":\" \"}]"}
                            Ist ein <url url="https://www.amazon.de/Luminea-Zubehör-Streifen-Alexa-WLAN-Controller/dp/B074SXSB5F/ref=sr_1_4?s=lighting&amp;ie=UTF8&amp;qid=1541271061&amp;sr=1-4&amp;keywords=Luminea">~~[url=https://www.amazon.de/Luminea-Zubehör-Streifen-Alexa-WLAN-Controller/dp/B074SXSB5F/ref=sr_1_4?s=lighting&ie=UTF8&qid=1541271061&sr=1-4&keywords=Luminea
                            ]~~Luminea WLAN-Controller (LED Serie LAC)</url>
                            Gruß Michael
                            • sigi234S Online
                              sigi234S Online
                              @sigi234:
                              Danke apollon77
                              für den tollen Adapter,
                              na dann fange ich mal an mit folgenden Gerät das funktioniert:
                              OxaOxe smart WLAN Steckdose 2 in 1, 16A 3520W, Einzel-/Gruppensteuerung, Überlastschutz, Energieüberwachung, Timer und Zeitpläne, 2-Fach intelligente Steckdose kompatibel mit Alexa Google und IFTTT
                              APP: Smart-Life App
                              https://www.amazon.de/gp/product/B07G2J … UTF8&psc=1 `
                              Hallo apollon77, wie bekomme ich den Wert in total vom Bild unten in den Adapter?
                              Könnte das dieser Wert sein?
                                Keine Ahnung. Es kann auch Gut sein das dieser Wert nur in der tuya Cloud errechnet wird oder so.
                                • P Offline
                                  PerfectAnswer
                                  Moin Zusammen,
                                  ich habe mir bei amazon diesen 4er-Pack WLAN-Steckdosen gekauft (https://www.amazon.de/gp/product/B07B91 … UTF8&psc=1)
                                  die funktionieren grundsätzlich schon so dass ich auswerten kann.
                                  Values die ausgegeben werden sind mA, mW, mV, IP, Online?, ein- oder ausgeschaltet. Kumulierte Werte wie in der App gibt es nicht, muss ich auch nicht zwingend haben.
                                  Da als Werte aktuell nur Guids ausgelesen werden, habe die mit normalen Namen überschrieben (z.B. Trockner oder WaMa) und die einzelnen Values mit (mA),(mW) etc. bezeichnet. blöderweise werden diese Werte dann aber regelmäßig wieder überschrieben (Siehe Screenshot).
                                  Wie kann ich unterstützen um die Werte dauerhaft zu speichern?
                                  • ElzersharkE Offline
                                    ElzersharkE Offline
                                    Elzershark
                                    Gibt es nicht eine Möglichkeit den Proxy auf ein Android einzustellen? Oder geht das nur mit einem Apple Handy wenn man die Geräte auch mal steuern möchte?
                                    https://www.youtube.com/c/Elzershark
                                    https://t.me/joinchat/BD87n3xMU0QzYmUy
                                    https://www.facebook.com/elzershark
                                      @PerfectAnswer:
                                      Moin Zusammen,
                                      filename="tuya.JPG" index="0">~~ `
                                      Namen werden mit dem überschrieben was im Schema definiert ist. Die Einheit sollte soweit schon hinten beim Wert stehen.
                                      Mit der App syncen und es stehen mal grob sinnvolle Namen drin. Und ja wird aktuell überschrieben … ich kann mal nachdenken. Bitte lege in GitHub issue als Feature request an. Danke
                                      Gesendet vom Handy ...
                                        @Elzershark:
                                        Gibt es nicht eine Möglichkeit den Proxy auf ein Android einzustellen? Oder geht das nur mit einem Apple Handy wenn man die Geräte auch mal steuern möchte? `
                                        Na klar geht das. Wo steht das es nur mit iOS tut? Habe nur kein android device und daher keine Screenshots. Gern machen Screenshots schicken. Dann nehme ich das in die Doku auf.
                                          ElzersharkE Offline
                                          Elzershark
