  4. [Projekt] Adapter: ioBroker.loxone
143 Beiträge 50 Kommentatoren 66.3k Aufrufe 16 Beobachtet
    Majoh
    #86
    @apollon77:
    Issue bekannt: https://github.com/UncleSamSwiss/ioBrok … /issues/14 `
    Müsste der entwilder sich nur mal zu Wort melden. Leider komm ich so mit meiner Alexa und lox nicht weiter =(
    • R Offline
      rudiraz
      #87
      nach vielen Monaten habe ich Loxone an IObroker angebunden.
      Beim Start kommen die Fehlermeldungen:
      loxone.0 2018-09-19 09:30:29.973 error Unsupported control type Daytimer: ReferenceError: loadDaytimerControl is not defined
      loxone.0 2018-09-19 09:30:29.958 error Unsupported control type IRoomController: ReferenceError: loadIRoomControllerControl is not defined
      loxone.0 2018-09-19 09:30:29.890 error Unsupported control type IRoomController: ReferenceError: loadIRoomControllerControl is not defined
      loxone.0 2018-09-19 09:30:29.860 error Unsupported control type IRoomController: ReferenceError: loadIRoomControllerControl is not defined
      loxone.0 2018-09-19 09:30:29.736 error Unsupported control type IRoomController: ReferenceError: loadIRoomControllerControl is not defined
      loxone.0 2018-09-19 09:30:29.591 error Unsupported control type IRoomController: ReferenceError: loadIRoomControllerControl is not defined
      loxone.0 2018-09-19 09:30:29.402 error Unsupported control type IRoomController: ReferenceError: loadIRoomControllerControl is not defined
      loxone.0 2018-09-19 09:30:29.317 error Unsupported control type IRoomController: ReferenceError: loadIRoomControllerControl is not defined
      loxone.0 2018-09-19 09:30:29.310 error Unsupported control type IRoomController: ReferenceError: loadIRoomControllerControl is not defined
      loxone.0 2018-09-19 09:30:29.303 error Unsupported control type Daytimer: ReferenceError: loadDaytimerControl is not defined
      loxone.0 2018-09-19 09:30:29.135 error Unsupported control type IRoomController: ReferenceError: loadIRoomControllerControl is not defined
      loxone.0 2018-09-19 09:30:29.101 error Unsupported control type IRoomController: ReferenceError: loadIRoomControllerControl is not defined
      Somit lässt sich die "intelligente Raumregelung" nicht steuern.
      Ist geplant, diese noch in den Adapter zu integrieren?
      • apollon77A Offline
        #88
        Dann am besten ein GitHub issue auf machen. Und die Fehlermeldung mit rein packen.
        Gesendet vom Handy …
          butsch
          #89
          Also, falls du die Fehler bzgl iRoom Controller meinst, das hat nix mit der raumregelung zu tun…Oder was meinst du?
          • R Offline
            rudiraz
            #90
            ja ich meinte iRoomController bzw loadDaytimerControl
            iRoomController hat nichts mit der Raumregelung zu tun? Klingt aber so :-)
            Naja wenn ich die Fehler dann "ignorieren" kann, ist ja gut.
              butsch
              #91
              https://www.loxone.com/dede/kb/iroom-controller/
              • R Offline
                rudiraz
                #92
                Ahh ok, danke.
                Ich nutze sowas aber gar nicht und ist auch nicht aufgelistet im Miniserver :?:
                • O Offline
                  O Offline
                  Ostpower
                  #93
                  ich versuche gerade meine Jalousien über iobroker und "shutter + jqui" zu steuern.
                  Die Signale bekomme ich über loxone in meinen iobroker.
                  meine Jalousien fahren entweder ganz hoch oder runter, aber nicht auf 25%,50 oder 75% ,wenn ich es über den Auswahlschalter in meiner Visu ansteuere. nur hoch oder runter.
                  Was mache ich falsch?
                  Direkt noch eine zweite Frage, kann ich im Miniserver (loxone) meine Räume von der Bezeichnung einfach ändern, ohne das die Verlinkung in ioBroker weg fällt? meine texte sind nicht gut gewählt und ich würde diese gern anpassen.
                  Danke Euch
                  Ostpower
                    StoRmtec
                    #94
                    Hallo
                    Ich bin neu hier und mir gefällt der ioBroker extrem gut. Jetzt wäre es noch toll wenn mir jemand mit dem Loxone noch weiter helfen kann.
                    Und zwar hätte ich einen Virtuellen Texteingang den ich mit Daten befüllen möchte. Leider bekomme ich das zur Zeit nicht hin da er immer sagt das dieser Baustein unsupported ist. Gibt es hier schon eine Lösung oder muss ich weiter das ganze mit NodeRed abdecken was natürlich schön wäre wenn ich den nicht brauchen würde.
                    • O Offline
                      O Offline
                      Ostpower
                      #95
                      Servus,
                      ich habe mein Problem mit virtuellen Eingängen in Loxone gelöst und kann so jetzt meine Rollo´s in % ansteuern.
                      Falls Dir in IoBroke etwas nicht angezigt wird, kannst du es mit "VI" in Loxone versuchen, sichtbar zu machen.
                      Aktuell konnte ich damit meine Ansteuerung der Rollos so lösen. Ob das mit der Textausgabe auch geht, kann ich dir nicht sagen.
                      Ostpower
                      • L Offline
                        LE_O
                        #96
                        Hallo wie kann ich einen Statusbaustein an IBroker weitergeben, wird dort nur als unsupported erkannt.
                        Virtueller Status wird erkannt aber nicht aktualisiert.
                        Welche Möglichkeiten gibt es??
                          Stanzi
                          #97
                          Hallo Loxonauten,
                          ich hab mich jetzt auch mal an iobroker rangetraut und muss sagen der Loxoneadapter ist ne Wucht. ICh hab jetzt nur ein kleines Problem mit dem Dimmen :o
                          ICh verwende das button dimmer widget und weis nicht auf welchen datenpunkt ich verbinden soll. In meinem Objektbrowser
                          wird mir keine möglich gegeben zu dimmen???
                          Ich hab mal einen screenshot von meinem Datenpunkt im Objektbrowser angehängt mit der hoffnung das mir jemand von euch helfen kann.
                          So long, der Stanzi
                            SlowMoe
                            #98
                            @The Spirit:
                            @The Spirit:
                            HI.
                            Bei mir läuft es aktuell sehr gut.
                            Hab jetzt nen mihome Bewegungsmelder bekommen und will den in Loxone nutzen.
                            Ich hab einen virtuellen Eingang (digital) angelegt.
                            Wenn am mihome Bewegungsmelder eine Bewegung erkannt wird, dann setze ich für 1 sek den virtuellen Eingang in loxone auf true.
                            Jedoch kommt das nicht in Loxone an (mit liveview kontrolliert).
                            Drücke ich im Liveview von der Loxone Config den virtuellen Eingang, sehe ich in ioBroker, das er sich auch von false auf true und wieder zurück ändert.
                            Aber warum kommt dann meine aktion von iobroker nicht in Loxone an?
                            Wo habe ich da einen Fehler?
                            Hier mein Blockly script (dies funtioniert wohl, da bei Bewegung sich der wert von false auf true und wieder zurück in iobroker ändert):
                            Aber in Loxone sehe ich die Änderung nicht.
                            Diese Warning taucht im ioBroker log auf:
                            Wrong type of loxone.0.10dd44b4-02fd-81c3-ffffeea5295594c0.value: "boolean". Please fix, while deprecated and will not work in next versions.
                            Danke für eure Hilfe,
                            Andreas `
                            bin jetzt selbst ein wenig weiter gekommen.
                            wenn ich den vi von loxone in iobroker von hand von false nach true setze, sehe ich das auch im liveview der loxone config.
                            wenn aber mein script den vi von loxone in iobroker von false nach true setzt, dann sehe ich das nicht im liveview in der loxone config.
                            ist das ein bug, oder was kann ich noch testen?
                            Danke `
                            Moin,
                            habe ein ähnliches Phänomen. Ich habe folgendes festgestellt…
                            Das Szenario mit dem Bewegungsmelder klappt bei mir, allerdings mach ich es etwas anders. Ich überspringe den virtuellen digitlaen Eingang und schalte auf Basis des Events vom BWM via Blockly direkt einen (Licht)Schalterbaustein in Loxone.
                            Aktuell versuche ich über einen virtuellen analogen Loxone-Eingang sowie einen dahinterliegenden Statusbaustein in ioBroker Temperaturwerte an Loxone zu übergeben um diese in der App zu visualisieren. Wenn ich den entsprechenden Status händisch in der Objektansicht von ioBroker reinschreibe, dann wird der Status aktualisiert. Triggert mein Blockly Script einen entsprechenden Befehl, wird zwar der Wert im ioBroker angepasst, in Loxone tut sich allerdings nichts (siehe Anhang):
                            Szenario 1:
                            -> "value" Parameter am virtuellen Eingang wird durch Blockly-Skript aktualisiert => keine Veränderung am "formatted value" Parameter
                            -> Anmerkung: Würde sich der "formatted value" am virtuellen analogen Eingang ändern, so würde der Statusbastein aktualisiert werden.
                            Szenario 2:
                            -> "value" Parameter am virtuellen Eingang wird manuell überschrieben => Veränderung am "formatted value" Parameter
                            -> Anmerkung: Weil sich der "formatted value" am virtuellen analogen Eingang ändert, wird der Statusbastein aktualisiert.
                            Im Log wird kein Fehler angezeigt in Szenario 1. Es hat fast den Anschein als würde bei Szenario 1 im Hintergrund die Aktualisierung des "value" Parameters nicht quittiert werden, wodurch sich dann auch der "fomatted value" Parameter nicht ändert.
                            Hat jemand eine Idee wie man das in den Griff bekommen könnte?
                              Sinus1986
                              #99
                              Werden Bausteine u.ä. in Loxone gelöscht,.nachdem diese an iobroker übergeben worden sind, bleiben diese weiterhin in iobroker bestehen.
                              Das.bläht den iobroker u.U. ungemein auf.
                              Gibt's hierzu eine Lösung?
                              • J Offline
                                joerg082
                                #100
                                Folgendes Problem, das die Nutzung des Loxone Adapters stark einschränkt.
                                Im Cloud Adapter füge ich alle Smart Geräte (Beleuchtung und Jalousien) manuell über das Plus hinzu. Ich gehe so vor, da der automatische Import bei mir nicht so gut funktioniert bzw. fehlen dort viele Lampen. Insofern lösche ich alle importierten Geräte und füge alles manuell hinzu.
                                Sobald ich den Loxone Adpater neu starte, sind all meine Einstellungen verschwunden und es wurden automatisch Smart Geräte wieder hinzugefügt. Hierbei fehlen aber wie gesagt viele Namen und die Bezeichnungen sind auch nicht so wie sie sollten. Gibt es hierfür eine Lösung? Das würde mir sehr helfen.
                                Danke für deine Unterstützung.
                                  Blacky085
                                  #101
                                  Hallo Leute,
                                  ich bin neu beim ioBroker und versuche hier gerade meine Alexa mit Loxone zu verbinden, was dank des Adapters auch ansich echt gut klappt.
                                  Vielen Dank an dieser Stelle für den genialen Adapter :)
                                  Ich habe nur das Problem, dass ich die dimmbaren Lampen leider nicht in der Cloud sehe und diese auch nicht mit dem + einfügen kann und somit auch nicht über Alexa steuern kann. Hat hier jemand einen Tip für mich, wie ich meine Dimmer in Alexa bekomme. Im Loxone Adapter wird alles ordentlich importiert und angezeigt aber ich bekomm das nicht in die Cloud rein.
                                  Ich bin über jede Antwort oder auch über Workarounds dankbar.
                                  Danke und Gruß Eugen
                                    atlas100
                                    #102
                                    Moinse,
                                    habe den Adapter schon erfolgreich am laufen und route hauptsächlich Status Meldungen zu loxone (Temp, etc.).
                                    Ich möchte jetzt aber die HUE über Loxone steuern - also z.B. im Wohnzimmer die Stehlampe mit HUE über den Lichtbaustein steuern können (AN/AUS, RGB Wechsel, etc.).
                                    Wir kann ich das realisieren?
                                    Würde es gerne über node-red machen - aber da muss ja irgendein Signal ankommen….
                                    Wir muss ich das in Loxone und node-red einrichten?
                                    Die Hue-Bridge läuft im iobroker und kann auch darüber gesteuert werden...
                                    DANKE!!
                                    Atlas
                                      SlowMoe
                                      #103
                                      @atlas100:
                                      Moinse,
                                      über welchen Loxone Baustein nimmst du denn die Temperaturwerte im iobroker auf?
                                      Gruß SlowMoe
                                        atlas100
                                        #104
                                        …habe ich per UDP Messages realisiert.
                                        Jeder Schalter/Sensor nutzt einen anderen Port - so kann ich ihn dann eindeutig in der Loxone zuordnen....funktioniert prima!
                                          atlas100
                                          #105
                                          hat hier niemand eine Idee / sowas schonmal gemacht?!
