  4. [Aufruf] Xbox Adapter testen
    1.0k
    6.1k
adapterxbox
205 Beiträge 13 Kommentatoren 50.4k Aufrufe 2 Beobachtet
  • Jey CeeJ Online
    Jey CeeJ Online
    Jey Cee
    Mein Installationsversuch unter Windows scheitert:
    2018-09-21 18:10:14.025 - [32minfo[39m: iobroker url "https://github.com/foxriver76/ioBroker.xbox" --debug 2018-09-21 18:10:14.444 - [32minfo[39m: iobroker install https://github.com/foxriver76/ioBroker.xbox/tarball/master 2018-09-21 18:10:15.519 - [32minfo[39m: iobroker npm install https://github.com/foxriver76/ioBroker.xbox/tarball/master --production --save --prefix "C:/iobroker" (System call) 2018-09-21 18:10:29.841 - [32minfo[39m: iobroker > iobroker.xbox@0.0.6 preinstall C:\iobroker\node_modules\iobroker.xbox apt install -y build-essential libssl-dev libffi-dev python3-dev || echo -e '[INFO] Cant install build-essential libssl-dev libffi-dev python3-dev Debian packages. If you are on a Linux system, try installing the package via: sudo npm i iobroker.xbox --unsafe-perm, otherwise you have to manage to install the packages by yourself. If you are not running on Linux, you can ignore this INFO.' ! 2018-09-21 18:10:29.874 - [32minfo[39m: iobroker Der Befehl "apt" ist entweder falsch geschrieben oder konnte nicht gefunden werden. ! 2018-09-21 18:10:29.874 - [32minfo[39m: iobroker -e '[INFO] Cant install build-essential libssl-dev libffi-dev python3-dev Debian packages. If you are on a Linux system, try installing the package via: sudo npm i iobroker.xbox --unsafe-perm, otherwise you have to manage to install the packages by yourself. If you are not running on Linux, you can ignore this INFO.' ! 2018-09-21 18:10:29.935 - [32minfo[39m: iobroker > iobroker.xbox@0.0.6 install C:\iobroker\node_modules\iobroker.xbox npip install ! 2018-09-21 18:10:30.149 - [32minfo[39m: iobroker No python_modules directory; installing pip locally if needed. 2018-09-21 18:10:30.161 - [32minfo[39m: iobroker Error: No python executable. at getPythonInfo (C:\iobroker\node_modules\iobroker.xbox\node_modules\nopy\src\api.js:52:11) at Promise.then.catch.error (C:\iobroker\node_modules\iobroker.xbox\node_modules\nopy\src\api.js:115:14) at <anonymous> at process._tickCallback (internal/process/next_tick.js:188:7) ! 2018-09-21 18:10:30.326 - [32minfo[39m: iobroker npm 2018-09-21 18:10:30.326 - [32minfo[39m: iobroker ERR! code ELIFECYCLEnpm ERR! errno 1 ! 2018-09-21 18:10:30.327 - [32minfo[39m: iobroker npm 2018-09-21 18:10:30.327 - [32minfo[39m: iobroker ERR! iobroker.xbox@0.0.6 install: npip installnpm 2018-09-21 18:10:30.327 - [32minfo[39m: iobroker ERR! Exit status 1npm ERR! npm 2018-09-21 18:10:30.327 - [32minfo[39m: iobroker ERR! Failed at the iobroker.xbox@0.0.6 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above. ! 2018-09-21 18:10:30.344 - [32minfo[39m: iobroker 2018-09-21 18:10:30.344 - [32minfo[39m: iobroker npm ERR! A complete log of this run can be found in:npm ERR! C:\Windows\system32\config\systemprofile\AppData\Roaming\npm-cache\_logs\2018-09-21T16_10_30_331Z-debug.log ! 2018-09-21 18:10:30.624 - [32minfo[39m: iobroker exit 0[/code]</anonymous>
    ! [quote]
    Schicke dir gerne meine Adresse zum Recycling meinenkiddoes streiten sich immer über die eine hier
    ;-) das behalte ich mal im Hinterkopf, für den Fall das ich so los werden will.
    Persönlicher Support
    Spenden -> paypal.me/J3YC33
    • DutchmanD Offline
      DutchmanD Offline
      Dutchman
      Ich glaube der Fehler bei dir ist, wen ich den Log richtig lese, das dir die Python Sachen fehlen und die Installation kein apt ausführen kann (logisch ist ein Linux Commando).
      Hast du per Admin oder per console installiert?
      • Jey CeeJ Online
        Jey CeeJ Online
        Jey Cee
        Hab per admin installiert.
        Python hab ich 3.6.4 installiert.
        • DutchmanD Offline
          DutchmanD Offline
          Dutchman
          @Jey Cee:
          Python hab ich 3.6.4 installiert. `
          Mal in der command Line probiert?
          • Jey CeeJ Online
            Jey CeeJ Online
            Jey Cee
            C:\iobroker>npm install https://github.com/foxriver76/ioBroker.xbox
            npm WARN enoent ENOENT: no such file or directory, open 'C:\iobroker\node_module
            s\admin\package.json'
            s\lib\package.json'
            s\tasks\package.json'
            s\scripts\package.json'
            s\test\package.json'
            npm ERR! path C:\iobroker\node_modules\ioBroker.deconz
            npm ERR! code EISGIT
            npm ERR! git C:\iobroker\node_modules\ioBroker.deconz: Appears to be a git repo
            or submodule.
            npm ERR! git Refusing to remove it. Update manually,
            npm ERR! git or move it out of the way first.
            npm ERR!     C:\Users\Jey Cee\AppData\Roaming\npm-cache\_logs\2018-09-21T17_31_3
            8_444Z-debug.log
            • DutchmanD Offline
              DutchmanD Offline
              Dutchman
              Alles Fehler bezüglich fehlender Ordner, console als Admin gestartet?
              • Jey CeeJ Online
                Jey CeeJ Online
                Jey Cee
                @Dutchman:
                console als Admin gestartet? ` Nein, war auch mein erster Gedanke und mit Admin rechten aber genau das gleiche.
                • DutchmanD Offline
                  DutchmanD Offline
                  Dutchman
                  @Jey Cee:
                  Nein, war auch mein erster Gedanke und mit Admin rechten aber genau das gleiche. `
                  Hmm okay sorry dann bin ich raus habe selber keine Windows Installation und auf Basis der Fehler kam ich keine anderen Schritte mehr bedenken.
                  Finde es nur komisch das er die allgemeine node Module Ordner und paclage json nicht findet
                  • Jey CeeJ Online
                    Jey CeeJ Online
                    Jey Cee
                    @Dutchman:
                    Finde es nur komisch das er die allgemeine node Module Ordner und paclage json nicht findet ` Scheint ein Problem mit meiner installation zu sein, hat aber bisher nie die Installation eines Adapters verhindert.
                    • DutchmanD Offline
                      DutchmanD Offline
                      Dutchman
                      Die Installation befindet sich aber in diesem Ordner ?
                      Poste Mal deine Ordnerstruktur die Situation macht mich neugierig
                      • Jey CeeJ Online
                        Jey CeeJ Online
                        Jey Cee
                        @Dutchman:
                        Die Installation befindet sich aber in diesem Ordner ? ` Ja.
                        @Dutchman:
                        Poste Mal deine Ordnerstruktur die Situation macht mich neugierig ` Du wolltest es so :mrgreen:
                        • DutchmanD Offline
                          DutchmanD Offline
                          Dutchman
                          Hmm ok sieht alles gut aus sorry Dan kommt ich auch nicht mehr weiter
                          • foxriver76F Offline
                            foxriver76F Offline
                            foxriver76
                            @Jey Cee:
                            ! `2018-09-21 18:10:14.025 - [32minfo[39m: iobroker url "https://github.com/foxriver76/ioBroker.xbox" --debug 2018-09-21 18:10:14.444 - [32minfo[39m: iobroker install https://github.com/foxriver76/ioBroker.xbox/tarball/master 2018-09-21 18:10:15.519 - [32minfo[39m: iobroker npm install https://github.com/foxriver76/ioBroker.xbox/tarball/master --production --save --prefix "C:/iobroker" (System call) 2018-09-21 18:10:29.841 - [32minfo[39m: iobroker > iobroker.xbox@0.0.6 preinstall C:\iobroker\node_modules\iobroker.xbox apt install -y build-essential libssl-dev libffi-dev python3-dev || echo -e '[INFO] Cant install build-essential libssl-dev libffi-dev python3-dev Debian packages. If you are on a Linux system, try installing the package via: sudo npm i iobroker.xbox --unsafe-perm, otherwise you have to manage to install the packages by yourself. If you are not running on Linux, you can ignore this INFO.' ! 2018-09-21 18:10:29.874 - [32minfo[39m: iobroker Der Befehl "apt" ist entweder falsch geschrieben oder konnte nicht gefunden werden. ! 2018-09-21 18:10:29.874 - [32minfo[39m: iobroker -e '[INFO] Cant install build-essential libssl-dev libffi-dev python3-dev Debian packages. If you are on a Linux system, try installing the package via: sudo npm i iobroker.xbox --unsafe-perm, otherwise you have to manage to install the packages by yourself. If you are not running on Linux, you can ignore this INFO.' ! 2018-09-21 18:10:29.935 - [32minfo[39m: iobroker > iobroker.xbox@0.0.6 install C:\iobroker\node_modules\iobroker.xbox npip install ! 2018-09-21 18:10:30.149 - [32minfo[39m: iobroker No python_modules directory; installing pip locally if needed. 2018-09-21 18:10:30.161 - [32minfo[39m: iobroker Error: No python executable. at getPythonInfo (C:\iobroker\node_modules\iobroker.xbox\node_modules\nopy\src\api.js:52:11) at Promise.then.catch.error (C:\iobroker\node_modules\iobroker.xbox\node_modules\nopy\src\api.js:115:14) at <anonymous> at process._tickCallback (internal/process/next_tick.js:188:7) ! 2018-09-21 18:10:30.326 - [32minfo[39m: iobroker npm 2018-09-21 18:10:30.326 - [32minfo[39m: iobroker ERR! code ELIFECYCLEnpm ERR! errno 1 ! 2018-09-21 18:10:30.327 - [32minfo[39m: iobroker npm 2018-09-21 18:10:30.327 - [32minfo[39m: iobroker ERR! iobroker.xbox@0.0.6 install: `npip install`npm 2018-09-21 18:10:30.327 - [32minfo[39m: iobroker ERR! Exit status 1npm ERR! npm 2018-09-21 18:10:30.327 - [32minfo[39m: iobroker ERR! Failed at the iobroker.xbox@0.0.6 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above. ! 2018-09-21 18:10:30.344 - [32minfo[39m: iobroker 2018-09-21 18:10:30.344 - [32minfo[39m: iobroker npm ERR! A complete log of this run can be found in:npm ERR! C:\Windows\system32\config\systemprofile\AppData\Roaming\npm-cache\_logs\2018-09-21T16_10_30_331Z-debug.log ! 2018-09-21 18:10:30.624 - [32minfo[39m: iobroker exit 0[/code]</anonymous>` ! Das schaut so aus als würde er die --unsafe-perm flag benötigen. ! Probier mal noch ! `~~[code]~~npm i iobroker.xbox --unsafe-perm [/code]` `
                            Videotutorials & mehr
                            • DutchmanD Offline
                              DutchmanD Offline
                              Dutchman
                              @foxriver76:
                              Okay, leider kein Link für nopy vorhanden.. another try:
                              Wenn du dich in /opt/iobroker/node_modules/iobroker.xbox/ befindest und den Befehlnpm rootabsetzt, was kommt dabei raus? `
                              Hier das ergebnis :
                              rafal@HomeControl:/opt/iobroker/node_modules/iobroker.xbox$ npm root
                              /opt/iobroker/node_modules/iobroker.xbox/node_modules
                              Ich habe den adapter jetzt mal komplett geloescht und per console mit sudo installiert das ergebnis ==> Er laeuft !
                              Installiert ist jetzt die 0.0.6 auf meinem ubuntu system
                              log der installation:
                              xxx@xxx:/opt/iobroker$ sudo npm i iobroker.xbox --unsafe-perm
                              > iobroker.xbox@0.0.6 preinstall /opt/iobroker/node_modules/.staging/iobroker.xbox-4a3b83e7
                              Reading package lists... Done
                              Building dependency tree
                              build-essential is already the newest version (12.1ubuntu2).
                              libssl-dev is already the newest version (1.0.2g-1ubuntu4.13).
                              The following additional packages will be installed:
                                libexpat1-dev libpython3-dev libpython3.5-dev python3.5-dev
                              The following NEW packages will be installed:
                                libexpat1-dev libffi-dev libpython3-dev libpython3.5-dev python3-dev python3.5-dev
                              0 upgraded, 6 newly installed, 0 to remove and 86 not upgraded.
                              Need to get 38.0 MB of archives.
                              After this operation, 55.3 MB of additional disk space will be used.
                              Get:1 http://nl.archive.ubuntu.com/ubuntu xenial-updates/main amd64 libexpat1-dev amd64 2.1.0-7ubuntu0.16.04.3 [115 kB]
                              Get:2 http://nl.archive.ubuntu.com/ubuntu xenial-updates/main amd64 libpython3.5-dev amd64 3.5.2-2ubuntu0~16.04.4 [37.3 MB]
                              Get:3 http://nl.archive.ubuntu.com/ubuntu xenial/main amd64 libpython3-dev amd64 3.5.1-3 [6,926 B]
                              Get:4 http://nl.archive.ubuntu.com/ubuntu xenial-updates/main amd64 python3.5-dev amd64 3.5.2-2ubuntu0~16.04.4 [413 kB]
                              Get:5 http://nl.archive.ubuntu.com/ubuntu xenial/main amd64 python3-dev amd64 3.5.1-3 [1,186 B]
                              Get:6 http://nl.archive.ubuntu.com/ubuntu xenial/main amd64 libffi-dev amd64 3.2.1-4 [161 kB]
                              Fetched 38.0 MB in 3s (9,803 kB/s)
                              Selecting previously unselected package libexpat1-dev:amd64.
                              (Reading database ... 100125 files and directories currently installed.)
                              Preparing to unpack .../libexpat1-dev_2.1.0-7ubuntu0.16.04.3_amd64.deb ...
                              Unpacking libexpat1-dev:amd64 (2.1.0-7ubuntu0.16.04.3) ...
                              Selecting previously unselected package libpython3.5-dev:amd64.
                              Preparing to unpack .../libpython3.5-dev_3.5.2-2ubuntu0~16.04.4_amd64.deb ...
                              Unpacking libpython3.5-dev:amd64 (3.5.2-2ubuntu0~16.04.4) ...
                              Selecting previously unselected package libpython3-dev:amd64.
                              Preparing to unpack .../libpython3-dev_3.5.1-3_amd64.deb ...
                              Unpacking libpython3-dev:amd64 (3.5.1-3) ...
                              Selecting previously unselected package python3.5-dev.
                              Preparing to unpack .../python3.5-dev_3.5.2-2ubuntu0~16.04.4_amd64.deb ...
                              Unpacking python3.5-dev (3.5.2-2ubuntu0~16.04.4) ...
                              Selecting previously unselected package python3-dev.
                              Preparing to unpack .../python3-dev_3.5.1-3_amd64.deb ...
                              Unpacking python3-dev (3.5.1-3) ...
                              Selecting previously unselected package libffi-dev:amd64.
                              Preparing to unpack .../libffi-dev_3.2.1-4_amd64.deb ...
                              Unpacking libffi-dev:amd64 (3.2.1-4) ...
                              Processing triggers for man-db (2.7.5-1) ...
                              Processing triggers for install-info (6.1.0.dfsg.1-5) ...
                              Setting up libexpat1-dev:amd64 (2.1.0-7ubuntu0.16.04.3) ...
                              Setting up libpython3.5-dev:amd64 (3.5.2-2ubuntu0~16.04.4) ...
                              Setting up libpython3-dev:amd64 (3.5.1-3) ...
                              Setting up python3.5-dev (3.5.2-2ubuntu0~16.04.4) ...
                              Setting up python3-dev (3.5.1-3) ...
                              Setting up libffi-dev:amd64 (3.2.1-4) ...
                              > authenticate-pam@1.0.2 install /opt/iobroker/node_modules/authenticate-pam
                              > node-gyp rebuild
                              make: Entering directory '/opt/iobroker/node_modules/authenticate-pam/build'
                                CXX(target) Release/obj.target/authenticate_pam/authenticate_pam.o
                              ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: No such file or directory
                              compilation terminated.
                              authenticate_pam.target.mk:94: recipe for target 'Release/obj.target/authenticate_pam/authenticate_pam.o' failed
                              make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Error 1
                              make: Leaving directory '/opt/iobroker/node_modules/authenticate-pam/build'
                              gyp ERR! build error
                              gyp ERR! stack Error: `make` failed with exit code: 2
                              gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
                              gyp ERR! stack     at emitTwo (events.js:106:13)
                              gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
                              gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
                              gyp ERR! System Linux 4.4.0-62-generic
                              gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                              gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
                              gyp ERR! node -v v6.14.1
                              gyp ERR! node-gyp -v v3.4.0
                              gyp ERR! not ok
                              > iobroker.xbox@0.0.6 install /opt/iobroker/node_modules/iobroker.xbox
                              > npip install
                              Successfully completed pip check.
                              The directory '/home/rafal/.cache/pip/http' or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
                              The directory '/home/rafal/.cache/pip' or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
                              Collecting xbox-smartglass-rest
                                Downloading https://files.pythonhosted.org/packages/d4/f6/73521851d42496d7d703036bc5cb79a49144602bf4fffd85ba3bfb4afa8f/xbox_smartglass_rest-0.9.5-py2.py3-none-any.whl
                              Collecting xbox-smartglass-core
                                Downloading https://files.pythonhosted.org/packages/3f/9f/2e9c16dce7523dabf37dd8f1cdff44de42851d5970534baf0fe2a4f9badb/xbox_smartglass_core-1.0.10-py2.py3-none-any.whl (56kB)
                                  100% |████████████████████████████████| 61kB 8.5MB/s
                              Collecting Flask (from xbox-smartglass-rest)
                                Downloading https://files.pythonhosted.org/packages/7f/e7/08578774ed4536d3242b14dacb4696386634607af824ea997202cd0edb4b/Flask-1.0.2-py2.py3-none-any.whl (91kB)
                                  100% |████████████████████████████████| 92kB 9.5MB/s
                              Collecting xbox-smartglass-stump>=0.9.4 (from xbox-smartglass-rest)
                                Downloading https://files.pythonhosted.org/packages/7e/ea/fae9ae03e3ef0afc3c27638e8872254bf96bd14f06dc1ba5bce08b7916c7/xbox_smartglass_stump-0.9.4-py2.py3-none-any.whl
                              Collecting urwid==2.0.1 (from xbox-smartglass-core)
                                Downloading https://files.pythonhosted.org/packages/c7/90/415728875c230fafd13d118512bde3184d810d7bf798a631abc05fac09d0/urwid-2.0.1.tar.gz (604kB)
                                  100% |████████████████████████████████| 614kB 11.3MB/s
                              Collecting construct==2.9.41 (from xbox-smartglass-core)
                                Downloading https://files.pythonhosted.org/packages/e6/f5/064be5013506d54212b396e8fc3e9890e60ed6a27df6d52529f0b8361cd5/construct-2.9.41.tar.gz (54kB)
                                  100% |████████████████████████████████| 61kB 13.0MB/s
                              Collecting gevent==1.2.2 (from xbox-smartglass-core)
                                Downloading https://files.pythonhosted.org/packages/13/a9/81166b3ad2d344882ab42eb222e7723f93838fdf641b17b319b3a84821a7/gevent-1.2.2-cp35-cp35m-manylinux1_x86_64.whl (1.7MB)
                                  100% |████████████████████████████████| 1.7MB 9.2MB/s
                              Collecting xbox-webapi>=1.1.2 (from xbox-smartglass-core)
                                Downloading https://files.pythonhosted.org/packages/04/9c/bd60a0093db35f32263306987cb6776ac12e0d9a8911a4be1c5856ff6d0b/xbox_webapi-1.1.5-py2.py3-none-any.whl (44kB)
                                  100% |████████████████████████████████| 51kB 10.1MB/s
                              Collecting appdirs==1.4.3 (from xbox-smartglass-core)
                                Downloading https://files.pythonhosted.org/packages/56/eb/810e700ed1349edde4cbdc1b2a21e28cdf115f9faf263f6bbf8447c1abf3/appdirs-1.4.3-py2.py3-none-any.whl
                              Collecting dpkt==1.9.1 (from xbox-smartglass-core)
                                Downloading https://files.pythonhosted.org/packages/bf/a4/8e4622fac4841b5e4a347fa9da4c057a7974258df247031280008d6ac0d0/dpkt-1.9.1.tar.gz (115kB)
                                  100% |████████████████████████████████| 122kB 15.1MB/s
                              Collecting aenum==2.1.2; python_version <= "3.5" (from xbox-smartglass-core)
                                Downloading https://files.pythonhosted.org/packages/0d/46/5b6a6c13fee40f9dfaba84de1394bfe082c0c7d95952ba0ffbd56ce3a3f7/aenum-2.1.2-py3-none-any.whl
                              Collecting cryptography==2.2.2 (from xbox-smartglass-core)
                                Downloading https://files.pythonhosted.org/packages/fa/f4/3cde3604972dfa2b0fea85b9711948bb4fb70ab64095322aef35071bd254/cryptography-2.2.2-cp34-abi3-manylinux1_x86_64.whl (2.2MB)
                                  100% |████████████████████████████████| 2.2MB 11.6MB/s
                              Collecting Werkzeug>=0.14 (from Flask->xbox-smartglass-rest)
                                Downloading https://files.pythonhosted.org/packages/20/c4/12e3e56473e52375aa29c4764e70d1b8f3efa6682bef8d0aae04fe335243/Werkzeug-0.14.1-py2.py3-none-any.whl (322kB)
                                  100% |████████████████████████████████| 327kB 16.5MB/s
                              Collecting Jinja2>=2.10 (from Flask->xbox-smartglass-rest)
                                Downloading https://files.pythonhosted.org/packages/7f/ff/ae64bacdfc95f27a016a7bed8e8686763ba4d277a78ca76f32659220a731/Jinja2-2.10-py2.py3-none-any.whl (126kB)
                                  100% |████████████████████████████████| 133kB 10.3MB/s
                              Collecting click>=5.1 (from Flask->xbox-smartglass-rest)
                                Downloading https://files.pythonhosted.org/packages/34/c1/8806f99713ddb993c5366c362b2f908f18269f8d792aff1abfd700775a77/click-6.7-py2.py3-none-any.whl (71kB)
                                  100% |████████████████████████████████| 71kB 9.7MB/s
                              Collecting itsdangerous>=0.24 (from Flask->xbox-smartglass-rest)
                                Downloading https://files.pythonhosted.org/packages/dc/b4/a60bcdba945c00f6d608d8975131ab3f25b22f2bcfe1dab221165194b2d4/itsdangerous-0.24.tar.gz (46kB)
                                  100% |████████████████████████████████| 51kB 8.5MB/s
                              Collecting marshmallow-objects (from xbox-smartglass-stump>=0.9.4->xbox-smartglass-rest)
                                Downloading https://files.pythonhosted.org/packages/2a/46/710e3383d1216f1f066ee16da24d144c04c2d3180bdd962f08194f123849/marshmallow_objects-1.0.14-py2.py3-none-any.whl
                              Collecting greenlet>=0.4.10 (from gevent==1.2.2->xbox-smartglass-core)
                                Downloading https://files.pythonhosted.org/packages/2e/65/27f35497cc0102a792390d056e793e064da95fc9eae45d75ae0ba49c0a0d/greenlet-0.4.15-cp35-cp35m-manylinux1_x86_64.whl (41kB)
                                  100% |████████████████████████████████| 51kB 9.3MB/s
                              Collecting demjson (from xbox-webapi>=1.1.2->xbox-smartglass-core)
                                Downloading https://files.pythonhosted.org/packages/96/67/6db789e2533158963d4af689f961b644ddd9200615b8ce92d6cad695c65a/demjson-2.2.4.tar.gz (131kB)
                                  100% |████████████████████████████████| 133kB 14.6MB/s
                              Requirement already satisfied: requests in /usr/lib/python3/dist-packages (from xbox-webapi>=1.1.2->xbox-smartglass-core) (2.9.1)
                              Collecting idna>=2.1 (from cryptography==2.2.2->xbox-smartglass-core)
                                Downloading https://files.pythonhosted.org/packages/4b/2a/0276479a4b3caeb8a8c1af2f8e4355746a97fab05a372e4a2c6a6b876165/idna-2.7-py2.py3-none-any.whl (58kB)
                                  100% |████████████████████████████████| 61kB 14.3MB/s
                              Collecting cffi>=1.7; platform_python_implementation != "PyPy" (from cryptography==2.2.2->xbox-smartglass-core)
                                Downloading https://files.pythonhosted.org/packages/59/cc/0e1635b4951021ef35f5c92b32c865ae605fac2a19d724fb6ff99d745c81/cffi-1.11.5-cp35-cp35m-manylinux1_x86_64.whl (420kB)
                                  100% |████████████████████████████████| 430kB 11.0MB/s
                              Requirement already satisfied: six>=1.4.1 in /usr/lib/python3/dist-packages (from cryptography==2.2.2->xbox-smartglass-core) (1.10.0)
                              Collecting asn1crypto>=0.21.0 (from cryptography==2.2.2->xbox-smartglass-core)
                                Downloading https://files.pythonhosted.org/packages/ea/cd/35485615f45f30a510576f1a56d1e0a7ad7bd8ab5ed7cdc600ef7cd06222/asn1crypto-0.24.0-py2.py3-none-any.whl (101kB)
                                  100% |████████████████████████████████| 102kB 13.7MB/s
                              Collecting MarkupSafe>=0.23 (from Jinja2>=2.10->Flask->xbox-smartglass-rest)
                                Downloading https://files.pythonhosted.org/packages/4d/de/32d741db316d8fdb7680822dd37001ef7a448255de9699ab4bfcbdf4172b/MarkupSafe-1.0.tar.gz
                              Collecting marshmallow (from marshmallow-objects->xbox-smartglass-stump>=0.9.4->xbox-smartglass-rest)
                                Downloading https://files.pythonhosted.org/packages/3f/4d/cb555dfc2e2f926179884665fa1e6ae6b8f8102e4f8228b73e2a30eb0ee0/marshmallow-2.15.6-py2.py3-none-any.whl (44kB)
                                  100% |████████████████████████████████| 51kB 14.6MB/s
                              Collecting pycparser (from cffi>=1.7; platform_python_implementation != "PyPy"->cryptography==2.2.2->xbox-smartglass-core)
                                Downloading https://files.pythonhosted.org/packages/68/9e/49196946aee219aead1290e00d1e7fdeab8567783e83e1b9ab5585e6206a/pycparser-2.19.tar.gz (158kB)
                                  100% |████████████████████████████████| 163kB 12.8MB/s
                              Installing collected packages: Werkzeug, MarkupSafe, Jinja2, click, itsdangerous, Flask, urwid, construct, greenlet, gevent, appdirs, demjson, xbox-webapi, dpkt, aenum, idna, pycparser, cffi, asn1crypto, cryptography, xbox-smartglass-core, marshmallow, marshmallow-objects, xbox-smartglass-stump, xbox-smartglass-rest
                                Running setup.py install for MarkupSafe ... done
                                Running setup.py install for itsdangerous ... done
                                Running setup.py install for urwid ... done
                                Running setup.py install for construct ... done
                                Running setup.py install for demjson ... done
                                Running setup.py install for dpkt ... done
                                Running setup.py install for pycparser ... done
                              Successfully installed Flask-1.0.2 Jinja2-2.10 MarkupSafe-1.0 Werkzeug-0.14.1 aenum-2.1.2 appdirs-1.4.3 asn1crypto-0.24.0 cffi-1.11.5 click-6.7 construct-2.9.41 cryptography-2.2.2 demjson-2.2.4 dpkt-1.9.1 gevent-1.2.2 greenlet-0.4.15 idna-2.7 itsdangerous-0.24 marshmallow-2.15.6 marshmallow-objects-1.0.14 pycparser-2.19 urwid-2.0.1 xbox-smartglass-core-1.0.10 xbox-smartglass-rest-0.9.5 xbox-smartglass-stump-0.9.4 xbox-webapi-1.1.5
                              iobroker.core@1.0.0 /opt/iobroker
                              └─┬ iobroker.xbox@0.0.6
                                ├── nopy@0.2.6
                                ├── ping@0.2.2
                                └─┬ request@2.88.0
                                  ├── aws4@1.8.0
                                  ├── combined-stream@1.0.7
                                  ├── extend@3.0.2
                                  ├─┬ form-data@2.3.2
                                  │ └── combined-stream@1.0.6
                                  ├─┬ har-validator@5.1.0
                                  │ └─┬ ajv@5.5.2
                                  │   └── fast-json-stable-stringify@2.0.0
                                  ├─┬ mime-types@2.1.20
                                  │ └── mime-db@1.36.0
                                  ├── oauth-sign@0.9.0
                                  ├── qs@6.5.2
                                  ├── safe-buffer@5.1.2
                                  ├─┬ tough-cookie@2.4.3
                                  │ └── psl@1.1.29
                                  └── uuid@3.3.2
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/noble/node_modules/xpc-connection):
                              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                              xxx@xxx:/opt/iobroker$ sudo iobroker add xbox
                              host.HomeControl install adapter xbox
                              got /opt/iobroker/node_modules/iobroker.xbox/admin
                              upload [2] xbox.admin /opt/iobroker/node_modules/iobroker.xbox/admin/xbox.png xbox.png image/png
                              upload [1] xbox.admin /opt/iobroker/node_modules/iobroker.xbox/admin/words.js words.js application/javascript
                              upload [0] xbox.admin /opt/iobroker/node_modules/iobroker.xbox/admin/index_m.html index_m.html text/html
                              host.HomeControl object system.adapter.xbox created
                              host.HomeControl create instance xbox
                              host.HomeControl object xbox.0.media.stop created
                              host.HomeControl object xbox.0.media.fastForward created
                              host.HomeControl object xbox.0.media.view created
                              host.HomeControl object xbox.0.media.rewind created
                              host.HomeControl object xbox.0.media.back created
                              host.HomeControl object xbox.0.media.menu created
                              host.HomeControl object xbox.0.media.channelDown created
                              host.HomeControl object xbox.0.media.nextTrack created
                              host.HomeControl object xbox.0.media.channelUp created
                              host.HomeControl object xbox.0.media.seek created
                              host.HomeControl object xbox.0.media.playPause created
                              host.HomeControl object xbox.0.media.previousTrack created
                              host.HomeControl object xbox.0.media.record created
                              host.HomeControl object xbox.0.media.pause created
                              host.HomeControl object xbox.0.media.play created
                              host.HomeControl object xbox.0.gamepad.dpadDown created
                              host.HomeControl object xbox.0.gamepad.dpadLeft created
                              host.HomeControl object xbox.0.gamepad.dpadRight created
                              host.HomeControl object xbox.0.gamepad.clear created
                              host.HomeControl object xbox.0.gamepad.dpadUp created
                              host.HomeControl object xbox.0.gamepad.y created
                              host.HomeControl object xbox.0.gamepad.x created
                              host.HomeControl object xbox.0.gamepad.b created
                              host.HomeControl object xbox.0.gamepad.a created
                              host.HomeControl object xbox.0.gamepad.nexus created
                              host.HomeControl object xbox.0.gamepad.menu created
                              host.HomeControl object xbox.0.gamepad.view created
                              host.HomeControl object xbox.0.gamepad.enroll created
                              host.HomeControl object xbox.0.gamepad.rightThumbstick created
                              host.HomeControl object xbox.0.gamepad.leftThumbstick created
                              host.HomeControl object xbox.0.gamepad.leftShoulder created
                              host.HomeControl object xbox.0.gamepad.rightShoulder created
                              host.HomeControl object xbox.0.settings.power created
                              host.HomeControl object xbox.0.settings created
                              host.HomeControl object xbox.0.gamepad created
                              host.HomeControl object xbox.0.media created
                              host.HomeControl object xbox.0.info.connection created
                              host.HomeControl object xbox.0.info created
                              host.HomeControl object system.adapter.xbox.0.outputCount created
                              host.HomeControl object system.adapter.xbox.0.inputCount created
                              host.HomeControl object system.adapter.xbox.0.uptime created
                              host.HomeControl object system.adapter.xbox.0.memRss created
                              host.HomeControl object system.adapter.xbox.0.memHeapTotal created
                              host.HomeControl object system.adapter.xbox.0.memHeapUsed created
                              host.HomeControl object system.adapter.xbox.0.connected created
                              host.HomeControl object system.adapter.xbox.0.alive created
                              host.HomeControl object system.adapter.xbox.0 created
                                foxriver76F Offline
                                foxriver76
                                @Dutchman:
                                @foxriver76:
                                Hier das ergebnis :
                                Okay, darüber findet er auch net wriklich raus wo seine Module liegen. Jedenfalls kann es laut npm sein, dass wenn ein npm Package (iobroker.xbox in diesem Fall) in dem Projekt eines anderen npm Packages liegt (iobroker), dass er es dann in die node_modules des übergeordneten Packages installiert. Zumindest habe ich es so verstanden, nur wovon das abhängt weiß ich nicht.
                                Jedenfalls probiert er jetzt erst mal nopy in iobroker.xbox zu finden und sonst schaut er noch in iobroker selbst.
                                Und wenn Packages fehlen muss unter Linux mit sudo (sonst kann er apt install nicht ausführen) installiert werden, oder man installiert sie eben händisch. Super, dass es auf den Linux-basierten Systemen zumindest schon mal klappt. :)
                                Vielen Dank fürs testen soweit.
                                • X Offline
                                  X Offline
                                  Xyolyp
                                  Den Adapter hatte ich zufälligerweise schon vor einigen Wochen gefunden und ausprobiert, aber nicht zum Laufen bekommen. Werde heute Abend direkt den nächsten Versuch starten.
                                    foxriver76F Offline
                                    foxriver76
                                    @Xyolyp:
                                    Den Adapter hatte ich zufälligerweise schon vor einigen Wochen gefunden und ausprobiert, aber nicht zum Laufen bekommen. Werde heute Abend direkt den nächsten Versuch starten. `
                                    Da gab es ihn noch nicht :)
                                    Es gibt einen auf Github von Idittmar oder so, wahrscheinlich war es der.
                                    beste Grüße
                                    • X Offline
                                      X Offline
                                      Xyolyp
                                      @foxriver76:
                                      Es gibt einen auf Github von Idittmar oder so, wahrscheinlich war es der. `
                                      Jetzt wo du es sagst…
                                      Deiner funktioniert nachdem ich bei der Installation erst Probleme hatte. Ich habe im home Ordner von meinem SSH Benutzer (Linux Raspbian) sudo npm i iobroker.xbox --unsafe-perm ausgeführt, nachdem die Installation via Admin nicht funktioniert hat.
                                      Der Adapter war aber auch nach einem Reboot nicht in der Liste. Also einmal wieder entfernt, cd /opt/iobroker und nochmal sudo npm i iobroker.xbox --unsafe-perm und tadaa, der Adapter ist da und funktioniert.
                                      Einziges Problemchen, das ich bisher noch feststellen konnte war, dass das DPad nicht immer funktioniert. Da im Log nichts dazu steht kann ich mir aber auch vorstellen, dass es ein Problem meiner XBox ist (sie hat so einige...)
                                        foxriver76F Offline
                                        foxriver76
                                        @Xyolyp:
                                        @foxriver76:
                                        Einziges Problemchen, das ich bisher noch feststellen konnte war, dass das DPad nicht immer funktioniert. Da im Log nichts dazu steht kann ich mir aber auch vorstellen, dass es ein Problem meiner XBox ist (sie hat so einige...) `
                                        Dpad funktioniert nicht und der Rest schon?
                                        Also Logging sollte es soweit geben, wenn was nicht passt.
                                        Zur Installation: Grundsätzlich sollte man ioBroker Adapter isntallieren, während man sich im Ordner /opt/iobroker/ befindet oder man geht auf nummer sicher mittels dem –prefix flag, dann ist es egal wo man sich aktuell befindet.
                                        sudo npm i iobroker.xbox --unsafe-perm --prefix /opt/iobroker/
                                        beste Grüße und schon mal Danke fürs testen
                                          foxriver76F Offline
                                          foxriver76
                                          Aktuell gibt es 0.0.8 als Version, es wurde lediglich das Logging etwas zurückgeschraubt im Falle, dass die Xbox online ist und mehrmals hintereinander keine Verbindung zustande kommt, werden die wiederholten Meldungen nur auf Debug geloggt. Ansonsten hatte ich am Anfang ein paar Attribute in der io-package erstellt, die nicht benötigt werden –> habe sie entfernt.
                                          Ich plane den Adapter in 1 - 2 Wochen ins offizielle Repo aufzunehmen (vorerst nur latest), falls ihr Feedback jeglicher Art habt, schreibt es bitte.
                                          beste Grüße
                                          fox
