  4. [Problem] Dream btw. Enigma2 Adapter
739 Beiträge 82 Kommentatoren 287.9k Aufrufe 15 Beobachtet
    Stefan-G
    #295
    habe mal eine Funktion zur Anzeige aller Bouquets und Kanäle und zum Umschalten implementiert:
    ! var parseString = require('xml2js').parseString;
    ! var request = require('request');
    ! var urlVUplus = 'http://192.168.1.101:82';
    ! var instanz = 'javascript.0'; instanz = instanz + '.';
    ! var pfad = 'XMLParsing'; pfad = pfad + '.'; // Pfad innerhalb der Instanz
    ! var debug = true;
    ! // VU+ Power-Status
    ! createState(pfad + 'VUplus.BouquetNames', 'init', {type: "string", name: "Names of Enigma bouquets", write:true, read:true});
    ! createState(pfad + 'VUplus.BouquetNumbers', 'init', {type: "string", name: "References of Enigma bouquets", write:true, read:true});
    ! createState(pfad + 'VUplus.NumberOfBouquets', 0, {type: "number", name: "How many bouquets are defined in Enigma", write:false, read:true});
    ! createState(pfad + 'VUplus.BouquetNumberCurrent', 0, {type: "number", name: "Number of selected Enigma bouquet", write:true, read:true});
    ! createState(pfad + 'VUplus.BouquetCurrentlySelected.BouquetName', 'init',{type: "string", name: "Name of currently selected Enigma bouquet", write:true, read:true});
    ! createState(pfad + 'VUplus.BouquetCurrentlySelected.BouquetReference', 'init',{type: "string", name: "Reference of currently selected Enigma bouquet", write:true, read:true});
    ! createState(pfad + 'VUplus.BouquetCurrentlySelected.ChannelNames', 'init',{type: "string", name: "Channel names of currently selected Enigma bouquet", write:true, read:true});
    ! createState(pfad + 'VUplus.BouquetCurrentlySelected.ChannelReferences', 'init',{type: "string", name: "Channel references of currently selected Enigma bouquet", write:true, read:true});
    ! createState(pfad + 'VUplus.ChannelReferenceCurrent', 'init', {type: "string", name: "Reference of selected channel", write:true, read:true});
    ! //example HHTP requests to obtain bouquet and channel list:
    ! //http://192.168.1.101:82/web/getservices
    ! //Favourites (TV):
    ! //http://192.168.1.101:82/web/getservices … %20bouquet
    ! //German Free SD
    ! //http://192.168.1.101:82/web/getservices ... %20bouquet
    ! //German Free HD
    ! //German HD+
    ! // This function collects all channel names (TV stations) and the respective
    ! // channel references and writes them into the respective states created before
    ! // (in calling function GetVUplusChannels()
    ! function GetVUplusBouquetChannels(strBouquetReference, iBouquetNumber) {
    ! var strAllChannelNames = '';
    ! var strAllChannelReferences = '';
    ! request(urlVUplus + '/web/getservices?sRef=' + strBouquetReference, function (error, response, body) {
    ! if (!error && response.statusCode == 200) {
    ! //if(debug){log("Body: " + body);}
    ! parseString(body, {
    ! explicitArray: false,
    ! mergeAttrs: true
    ! function (err, result) {
    ! if (err) {
    ! log("Fehler: " + err);
    ! } else {
    ! for (var j = 0; j < result.e2servicelist.e2service.length; j++) {
    ! var strSender = result.e2servicelist.e2service[j].e2servicename;
    ! var strService = result.e2servicelist.e2service[j].e2servicereference;
    ! if(debug){ log("Sender Nr. " + j + ": " + strSender + ", Service: " + strService);}
    ! strAllChannelNames = strAllChannelNames + strSender + ';';
    ! strAllChannelReferences = strAllChannelReferences + strService + ';';
    ! strAllChannelNames = strAllChannelNames.slice(0,strAllChannelNames.length-1); // cut away last ";"
    ! strAllChannelReferences = strAllChannelReferences.slice(0,strAllChannelReferences.length-1); // cut away last ";"
    ! if(debug){ log('All channels for Bouquet ' + iBouquetNumber +': ' + strAllChannelNames);}
    ! if(debug){ log('All channel references for Bouquet ' + iBouquetNumber + ': ' + strAllChannelReferences);}
    ! setState(instanz + pfad + 'VUplus.Bouquet' + iBouquetNumber + '.ChannelNames', strAllChannelNames);
    ! setState(instanz + pfad + 'VUplus.Bouquet' + iBouquetNumber + '.ChannelReferences', strAllChannelReferences);
    ! } else {
    ! if(debug){log(error);}
    ! // This function creates states for all bouquets with all info about the bouquet
    ! // e.g. channels (TV station) names and respective service references
    ! function CreateBouquetStates(NrOfBouquets) {
    ! for (var i = 0; i < NrOfBouquets; i++) {
    ! createState(pfad + 'VUplus.Bouquet' + i + '.BouquetName', 'init',{type: "string", name: "Name of Enigma bouquets number "+ i, write:true, read:true});
    ! createState(pfad + 'VUplus.Bouquet' + i + '.BouquetReference', 'init',{type: "string", name: "Reference of Enigma bouquets number "+ i, write:true, read:true});
    ! createState(pfad + 'VUplus.Bouquet' + i + '.ChannelNames', 'init',{type: "string", name: "Channel names of Enigma bouquets number "+ i, write:true, read:true});
    ! createState(pfad + 'VUplus.Bouquet' + i + '.ChannelReferences', 'init',{type: "string", name: "Channel references of Enigma bouquets number "+ i, write:true, read:true});
    ! // TODO: here code could be added which deletes states if more bouquet states have already been created befor than bouquets exit presently, e.g. this can happen if an bouquet has been deleted on the ENIGMA system
    ! // This function all available bouquets (TV station lists) for an ENIGMA system
    ! // and creates states for all bouquets filled with channel (TV station) and
    ! // respective service references for bouquets and channels
    ! function GetVUplusChannels() {
    ! request(urlVUplus + '/web/getservices', function (error, response, body) {
    ! mergeAttrs: true
    ! if (err) {
    ! } else {
    ! if(debug){ log("Anzahl Bouquets: " + result.e2servicelist.e2service.length);}
    ! var strBouquetName = '';
    ! var strBouquetReference = '';
    ! var strAllBouquetNames = '';
    ! var strAllBouquetNumbers = '';
    ! // create as many states as bouquets exist
    ! setState(instanz + pfad + 'VUplus.NumberOfBouquets', result.e2servicelist.e2service.length);
    ! CreateBouquetStates(result.e2servicelist.e2service.length);
    ! for (i = 0; i < result.e2servicelist.e2service.length; i++) {
    ! strBouquetName = result.e2servicelist.e2service__.e2servicename;
    ! strBouquetReference = result.e2servicelist.e2service__.e2servicereference.replace(/ /g, "%20").replace(/"/g, "%22");
    ! strAllBouquetNames = strAllBouquetNames + strBouquetName + ';';
    ! strAllBouquetNumbers = strAllBouquetNumbers + i + ';';
    ! if(debug){ log("Bouquet Nr. " + i + ": " + strBouquetName + ", Bouquet References: " + strBouquetReference);}
    ! setState(instanz + pfad + 'VUplus.Bouquet' + i + '.BouquetName', strBouquetName);
    ! setState(instanz + pfad + 'VUplus.Bouquet' + i + '.BouquetReference', strBouquetReference);
    ! GetVUplusBouquetChannels(strBouquetReference, i);
    ! strAllBouquetNames = strAllBouquetNames.slice(0,strAllBouquetNames.length-1); // cut away last ";"
    ! strAllBouquetNumbers = strAllBouquetNumbers.slice(0,strAllBouquetNumbers.length-1); // cut away last ";"
    ! if(debug){ log("All Bouquets: " + strAllBouquetNames);}
    ! if(debug){ log("All Bouquet numbers: " + strAllBouquetNumbers);}
    ! setState(instanz + pfad + 'VUplus.BouquetNames', strAllBouquetNames);
    ! setState(instanz + pfad + 'VUplus.BouquetNumbers', strAllBouquetNumbers);
    ! } else {
    ! on(instanz + pfad + 'VUplus.BouquetNumberCurrent', function(obj) {
    ! var ChannelNamesOfNewCurrentBouquet = getState(instanz + pfad + 'VUplus.Bouquet' + obj.newState.val + '.ChannelNames').val;
    ! var ChannelReferencesOfNewCurrentBouquet = getState(instanz + pfad + 'VUplus.Bouquet' + obj.newState.val + '.ChannelReferences').val;
    ! var FirstChannelReferenceOFNewBouquet = ChannelReferencesOfNewCurrentBouquet.slice(0, ChannelReferencesOfNewCurrentBouquet.indexOf(';'));
    ! if(debug){ log('Current bouquet number changed to: ' + obj.newState.val );}
    ! if(debug){ log('First channel in urrent bouquet: ' + ChannelNamesOfNewCurrentBouquet.slice(0, ChannelNamesOfNewCurrentBouquet.indexOf(';')) );}
    ! if(debug){ log('First channel reference in urrent bouquet: ' + FirstChannelReferenceOFNewBouquet);}
    ! // serch if the currently selected TC channel exists in the new selected bouquet
    ! if(ChannelReferencesOfNewCurrentBouquet.indexOf(getState(instanz + pfad + 'VUplus.ChannelReferenceCurrent').val) == -1) {
    ! if(debug){ log('Currently selected TC channel not found in previous bouquet, switching channel.');}
    ! setState(instanz + pfad + 'VUplus.ChannelReferenceCurrent', FirstChannelReferenceOFNewBouquet);
    ! // set new values for selected bouquet
    ! setState(instanz + pfad + 'VUplus.BouquetCurrentlySelected.BouquetName', getState(instanz + pfad + 'VUplus.Bouquet' + obj.newState.val + '.BouquetName').val);
    ! setState(instanz + pfad + 'VUplus.BouquetCurrentlySelected.BouquetReference', getState(instanz + pfad + 'VUplus.Bouquet' + obj.newState.val + '.BouquetReference').val);
    ! setState(instanz + pfad + 'VUplus.BouquetCurrentlySelected.ChannelNames', ChannelNamesOfNewCurrentBouquet);
    ! setState(instanz + pfad + 'VUplus.BouquetCurrentlySelected.ChannelReferences', ChannelReferencesOfNewCurrentBouquet);
    ! on(instanz + pfad + 'VUplus.ChannelReferenceCurrent', function(obj) {
    ! if(debug){ log('Chosen current channel reference: ' + obj.newState.val );}
    ! request(urlVUplus + '/api/zap?sRef=' + obj.newState.val, function (error, response, body) {
    ! //log("Body: " + body);
    ! mergeAttrs: true
    ! if (err) {
    ! } else {
    ! if(debug){ log(result);}
    ! } else {
    ! log(error);
    ! // create and fill all states for bouquets and station names
    ! GetVUplusChannels();____ __Code mag natürlich noch optimierbar sein. Ich fände es cool, wenn es diese Funktion gleich im Adapter gäbe, oder gibt es einen Grund, das dort nicht zu implementieren? Kann dann so aussehen (roter Kasten):
    Die Widgets dafür sind dann wie folgt:
    ! [{"tpl":"tplJquiSelectList","data":{"oid":"javascript.0.XMLParsing.VUplus.BouquetNumberCurrent","values":"{javascript.0.XMLParsing.VUplus.BouquetNumbers}","texts":"{javascript.0.XMLParsing.VUplus.BouquetNames}","height":"170","open":false,"gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"g_visibility":false,"g_fixed":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"370px","top":"213px","width":"214px","height":"29px"},"widgetSet":"jqui"},{"tpl":"tplValueString","data":{"oid":"","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"Bouquet:","html_append":"","test_html":"","visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"376px","top":"184px","color":"#ffffff","width":"186px","height":"20px","text-shadow":"rgba(0, 0, 0, 0.9) 3px 3px 4px","font-family":"Tahoma, Geneva, sans-serif"},"widgetSet":"basic"},{"tpl":"tplJquiSelectList","data":{"oid":"javascript.0.XMLParsing.VUplus.ChannelReferenceCurrent","values":"{javascript.0.XMLParsing.VUplus.BouquetCurrentlySelected.ChannelReferences}","texts":"{javascript.0.XMLParsing.VUplus.BouquetCurrentlySelected.ChannelNames}","height":"170","open":false,"gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"g_visibility":false,"g_fixed":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"605px","top":"212px","width":"217px","height":"29px"},"widgetSet":"jqui"},{"tpl":"tplValueString","data":{"oid":"","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"Sender:","html_append":"","test_html":"","visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","values":"{javascript.0.XMLParsing.VUplus.Bouquet3.ChannelReferences}","texts":"{javascript.0.XMLParsing.VUplus.Bouquet3.ChannelNames}"},"style":{"left":"607px","top":"181px","color":"#ffffff","width":"186px","height":"20px","text-shadow":"rgba(0, 0, 0, 0.9) 3px 3px 4px","font-family":"Tahoma, Geneva, sans-serif"},"widgetSet":"basic"}]
    Vielleicht mag das ja jemand einbauen (meine Git-/Adapter- Kenntnisse sind leider nicht gut genug).
    Ne Timer-Liste wäre auch cool. Vielleicht schafft das ja auch jemand schneller als ich… ;)__
    • hg6806H Offline
      hg6806H Offline
      hg6806
      #296
      leider funktioniert bei meiner Dreambox DM7020HD die Pasue/Play Funktion über den VUPlus Adapter nicht
      vuplus.0.VuPlus.RC.PLAY_PAUSE
      …erkennt die Box nicht wirklich.
      Bei den Codes für die Fernbedienung ist diese Funktion auch nicht drauf.
      Wie kann ich das schalten?
        aleks-83
        #297
        ich habe den Enigma2 Adapter bei mir installiert und für meine VU+ Duo 2 konfiguriert.
        Die Datenobjekte sind aber immer noch leer.
        Muss ich das iwie anstoßen?
        Aleks
        = Dell Optiplex Micro - 10GB RAM - 200GB SSD - Debian VM =
        = Node.js v20.19.6 = NPM 22.22.2 = JS Controller 7.2.2 =
        Ubiquiti UAP-AC-LR - UAP-AC-Lite - Synology DS716+II - Fritz!Box 7490
        Glasfaser 400
        • Matten MattenM Offline
          Matten Matten
          #298
          IP Adresse und Port richtig eingegeben?
          ioBroker auf Beelink mit WIN10 home|CCU3 (Raspberrymatic)|Neato BotVac D3|HYPERION Ambilight auf RPI3 und RPI ZeroW|HA-Bridge|Milight LED|Nodered&Redmatic|VU Duo2 & Solo se V2
            aleks-83
            #299
            Ja habe ich.
            Allerdings nutze ich https, ist das ein Problem?
            ich habe die IP mit https://192.xxxx angegeben oder auch mal als 192.xxxx
            Glasfaser 400
              Matten Matten
              #300
              Funktioniert nur mit http
                #301
                Habe jetzt endlich meine Dreambox 920 am Netz.
                Adapter installiert und Konfiguriert:
                enigma2.0 2018-08-04 18:05:42.432 error at Object.write (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:1314:29)
                enigma2.0 2018-08-04 18:05:42.432 error at closeTag (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:874:5)
                enigma2.0 2018-08-04 18:05:42.432 error at emitNode (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:630:3)
                enigma2.0 2018-08-04 18:05:42.432 error at emit (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:625:33)
                enigma2.0 2018-08-04 18:05:42.432 error at Object.onclosetag (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/lib/xml2js.js:423:26)
                enigma2.0 2018-08-04 18:05:42.432 error at Parser.emit (events.js:188:7)
                enigma2.0 2018-08-04 18:05:42.432 error at emitOne (events.js:96:13)
                enigma2.0 2018-08-04 18:05:42.432 error at Parser. <anonymous>(/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/lib/xml2js.js:462:18)
                enigma2.0 2018-08-04 18:05:42.432 error at /opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:62:21
                enigma2.0 2018-08-04 18:05:42.432 error at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:162:60)
                enigma2.0 2018-08-04 18:05:42.432 error TypeError: Cannot read property 'e2webifversion' of undefined
                enigma2.0 2018-08-04 18:05:42.431 error uncaught exception: Cannot read property 'e2webifversion' of undefined
                enigma2.0 2018-08-04 18:05:42.429 error at Object.write (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:1314:29)
                enigma2.0 2018-08-04 18:05:42.429 error at closeTag (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:874:5)
                enigma2.0 2018-08-04 18:05:42.429 error at emitNode (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:630:3)
                enigma2.0 2018-08-04 18:05:42.429 error at emit (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:625:33)
                enigma2.0 2018-08-04 18:05:42.429 error at Object.onclosetag (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/lib/xml2js.js:423:26)
                enigma2.0 2018-08-04 18:05:42.429 error at Parser.emit (events.js:188:7)
                enigma2.0 2018-08-04 18:05:42.429 error at emitOne (events.js:96:13)
                enigma2.0 2018-08-04 18:05:42.429 error at Parser. <anonymous>(/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/lib/xml2js.js:462:18)
                enigma2.0 2018-08-04 18:05:42.429 error at /opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:62:21
                enigma2.0 2018-08-04 18:05:42.429 error at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:132:94)
                enigma2.0 2018-08-04 18:05:42.429 error TypeError: Cannot read property 'e2eventlist' of undefined
                enigma2.0 2018-08-04 18:05:42.428 error uncaught exception: Cannot read property 'e2eventlist' of undefined
                enigma2.0 2018-08-04 18:05:42.425 error at Object.write (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:1314:29)
                enigma2.0 2018-08-04 18:05:42.425 error at closeTag (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:874:5)
                enigma2.0 2018-08-04 18:05:42.425 error at emitNode (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:630:3)
                enigma2.0 2018-08-04 18:05:42.425 error at emit (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:625:33)
                enigma2.0 2018-08-04 18:05:42.425 error at Object.onclosetag (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/lib/xml2js.js:423:26)
                enigma2.0 2018-08-04 18:05:42.425 error at Parser.emit (events.js:188:7)
                enigma2.0 2018-08-04 18:05:42.425 error at emitOne (events.js:96:13)
                enigma2.0 2018-08-04 18:05:42.425 error at Parser. <anonymous>(/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/lib/xml2js.js:462:18)
                enigma2.0 2018-08-04 18:05:42.425 error at /opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:62:21</anonymous></anonymous></anonymous>
                Bei den Tests die hier im Thread stehen, kommt immer:
                Precondition failed!
                sessionid is missing, invalid or expired!
                Was habe ich vergessen zu konfigurieren?
                • ? Offline
                  #302
                  Bin nicht ganz sicher.
                  Geh mal auf der Dream:
                  Einstellungen
                  Netzwerk
                  Webinterface
                  Ganz nach unten scrollen und die letzten 3 Einstellungen auf aus.
                    #303
                    Danke.
                    Ich habe jetzt zumindest etwas, und keine Fehler im log
                      aleks-83
                      #304
                      @Matten Matten:
                      Funktioniert nur mit http `
                      OK, habe intern ausm LAN jetzt http aktiviert.
                      Das läuft.
                      Ebenso dein Skript um die Box zu steuern!
                      Super, vielen Dank für deine Arbeit und die Unterstützung :!:
                      Glasfaser 400
                        Matten Matten
                        #305
                        @Pocky:
                        Einstellungen
                        Netzwerk
                        Webinterface
                        Ganz nach unten scrollen und die letzten 3 Einstellungen auf aus. `
                        Ist das möglich hier ein Screenshot zu posten oder die Einstellungen zu beschreiben die dort deaktiviert werden müssen? Damit dann auch andere Forum User wissen was sie ausschalten sollen. Hab leider gerade keine dream am laufen sonst hätte ich es selbst gepostet.
                        Vielen Dank im voraus :)
                        Matten Matten
                          #306
                          Muss ich mal mit dem Handy machen ;-)
                          per Webinterface kommt man da nicht daruf.
                          • ? Offline
                            #307
                            Screenshots vom OSD lassen sich vom Webinterface machen.
                            Dafür muss natürlich vorher über die Dream das entsprechende Menü aufgerufen werden.
                            Bei mir unter Original DMM OE 2.5 befindet sich die Config des Webinterface hier:
                            (Bei anderen Enigma2 Versionen kann das auch woanders sein)
                            Einstellungen
                            Netzwerk
                            Webinterface
                            Dann ganz nach unten Scrollen und die letzten 3 Einträge auf aus stellen.
                              Matten Matten
                              #308
                              Super danke!
                              Matten Matten
                                #309
                                @Pocky:
                                Screenshots vom OSD lassen sich vom Webinterface machen. `
                                :vorDenKopfKlatsch:
                                Klar doch
                                  Matten Matten
                                  #310
                                  @Matten Matten:
                                  Blockly Umlaute & Sonderzeichen Dekodierung?
                                  Hallo Leute,
                                  gibt es eine Möglichkeit mit Blockly Umlaute und Sonderzeichen zu dekorieren?
                                  Aus folgenden Hintergrund:
                                  Ich möchte die Enigma2 Programm Info in eine CCU2 Systemvariable als Zeichenkette schreiben, sobald ein äöü im Text enthalten sind, wird der Text nicht in die Systemvariable übertragen.
                                  Wenn ich bspw ein
                                  ä
                                  Anstatt ein````
                                  ä
                                  Eintrage wird das auch in die Systemvariable übernommen. (HTML encode)
                                  [https://encoder.mattiasgeniar.be/index.php](https://encoder.mattiasgeniar.be/index.php)
                                  Hat einer eine Idee oder eine Lösung wie ich das umsetzen kann? Vielleicht ein Java Skript im Blockly Skript oder so? `
                                  Da niemand auf meine Frage antwortet, vermute ich das es niemand weiß, bzw keiner eine Idee hat.
                                  Falls es doch jemand interessiert oder auch so eine Decodierung benötigt:
                                  createState('Decoded.enigma2.Programm_Info', '');
                                  on({id: 'enigma2.0.enigma2.PROGRAMM_INFO'}, function (obj) {
                                  	var s=getState('enigma2.0.enigma2.PROGRAMM_INFO').val;
                                  	s=replaceAll(s,'ä','ä');
                                  	s=replaceAll(s,'ö','ö');
                                  	s=replaceAll(s,'ü','ü');
                                  	s=replaceAll(s,'Ä','Ä');
                                  	s=replaceAll(s,'Ö','Ö');
                                  	s=replaceAll(s,'Ü','Ü');
                                  	s=replaceAll(s,'Â|À|Å|Ã','A');
                                      s=replaceAll(s,'â|à|å|ã','a');
                                      s=replaceAll(s,'Ç','C');
                                      s=replaceAll(s,'ç','c');
                                      s=replaceAll(s,'É|Ê|È|Ë','E');
                                      s=replaceAll(s,'é|ê|è|ë','e');
                                      s=replaceAll(s,'Ó|Ô|Ò|Õ|Ø','O');
                                      s=replaceAll(s,'ó|ô|ò|õ','o');
                                      s=replaceAll(s,'Š','S');
                                      s=replaceAll(s,'š','s');
                                      s=replaceAll(s,'Ú|Û|Ù','U');
                                      s=replaceAll(s,'ú|û|ù','u');
                                      s=replaceAll(s,'Ý|Ÿ','Y');
                                      s=replaceAll(s,'ý|ÿ','y');
                                      s=replaceAll(s,'Ž','Z');
                                      s=replaceAll(s,'ž','z');
                                      s=replaceAll(s,':',' ');
                                      s=replaceAll(s,'Š',' ');
                                      s=replaceAll(s,'ß','ss');
                                      s=replaceAll(s,'?',' ');
                                  	setState('Decoded.enigma2.Programm_Info',s);
                                  function replaceAll(string, token, newtoken) {
                                      if(token!=newtoken)
                                      while(string.indexOf(token) > -1) {
                                          string = string.replace(token, newtoken);
                                      return string;
                                  dann wird das bei Objekte unter
                                  javascript.0.Decoded.enigma2.Programm_Info
                                  decodiert, und man kann diesen text dann in die HomeMatic CCU2 senden/portieren.
                                  gruß
                                  Matten Matten
                                    Matten Matten
                                    #311
                                    Moin, falls es jemand interessiert, ich habe eben eine neue enigma2 Version (V0.3.0) in github gestellt
                                    https://github.com/Matten-Matten/ioBroker.enigma2.git
                                    Matten Matten
                                      Turbo
                                      #312
                                      Installiert und läuft!
                                      Ich musste allerdings die alte Version deinstallieren und dann nochmal neu installieren, da in den Adapter-Einstellungen die Webinterface-Einstellung fehlte.
                                      Vielen Dank für die tolle Arbeit.
                                        aleks-83
                                        #313
                                        @Matten Matten:
                                        Moin, falls es jemand interessiert, ich habe eben eine neue enigma2 Version (V0.3.0) in github gestellt `
                                        Super, Danke!
                                        Hat sich an der Installationsweise was verändert?
                                        Wenn ich "sudo iobroker add enigma2" ausführe (so hatte ich es bisher installiert meine ich), kommt:
                                        host.ioBroker-RasPi Unknown packetName enigma2
                                        Und wenn ich "sudo npm install enigma2" ausführe, kommt:
                                        npm ERR! code E404
                                        npm ERR! 404 Not found : enigma2
                                        npm ERR! 404
                                        npm ERR! 404  'enigma2' is not in the npm registry.
                                        npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
                                        npm ERR! 404
                                        npm ERR! 404 Note that you can also install from a
                                        npm ERR! 404 tarball, folder, http url, or git url.
                                        npm ERR!     /root/.npm/_logs/2018-09-19T14_18_33_855Z-debug.log
                                        Glasfaser 400
                                          Matten Matten
                                          #314
                                          Über github installieren!
                                          Am besten über die Admin Maske
                                          oder im Ordner iobroker:
                                          sudo iobroker url "https://github.com/Matten-Matten/ioBroker.enigma2.git"
                                          oder:
                                          sudo npm install https://github.com/Matten-Matten/ioBroker.enigma2/tarball/master
                                          am ende ein Adapter Upload machen und die bestehende Instanz neu starten
                                          Matten Matten
