  4. [Problem] Dream btw. Enigma2 Adapter
    5.8k
739 Beiträge 82 Kommentatoren 270.9k Aufrufe 15 Beobachtet
  • Matten MattenM Offline
    Matten Matten
    #300
    Funktioniert nur mit http
    ioBroker auf Beelink mit WIN10 home|CCU3 (Raspberrymatic)|Neato BotVac D3|HYPERION Ambilight auf RPI3 und RPI ZeroW|HA-Bridge|Milight LED|Nodered&Redmatic|VU Duo2 & Solo se V2
      #301
      Habe jetzt endlich meine Dreambox 920 am Netz.
      Adapter installiert und Konfiguriert:
      enigma2.0 2018-08-04 18:05:42.432 error at Object.write (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:1314:29)
      enigma2.0 2018-08-04 18:05:42.432 error at closeTag (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:874:5)
      enigma2.0 2018-08-04 18:05:42.432 error at emitNode (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:630:3)
      enigma2.0 2018-08-04 18:05:42.432 error at emit (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:625:33)
      enigma2.0 2018-08-04 18:05:42.432 error at Object.onclosetag (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/lib/xml2js.js:423:26)
      enigma2.0 2018-08-04 18:05:42.432 error at Parser.emit (events.js:188:7)
      enigma2.0 2018-08-04 18:05:42.432 error at emitOne (events.js:96:13)
      enigma2.0 2018-08-04 18:05:42.432 error at Parser. <anonymous>(/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/lib/xml2js.js:462:18)
      enigma2.0 2018-08-04 18:05:42.432 error at /opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:62:21
      enigma2.0 2018-08-04 18:05:42.432 error at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:162:60)
      enigma2.0 2018-08-04 18:05:42.432 error TypeError: Cannot read property 'e2webifversion' of undefined
      enigma2.0 2018-08-04 18:05:42.431 error uncaught exception: Cannot read property 'e2webifversion' of undefined
      enigma2.0 2018-08-04 18:05:42.429 error at Object.write (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:1314:29)
      enigma2.0 2018-08-04 18:05:42.429 error at closeTag (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:874:5)
      enigma2.0 2018-08-04 18:05:42.429 error at emitNode (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:630:3)
      enigma2.0 2018-08-04 18:05:42.429 error at emit (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:625:33)
      enigma2.0 2018-08-04 18:05:42.429 error at Object.onclosetag (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/lib/xml2js.js:423:26)
      enigma2.0 2018-08-04 18:05:42.429 error at Parser.emit (events.js:188:7)
      enigma2.0 2018-08-04 18:05:42.429 error at emitOne (events.js:96:13)
      enigma2.0 2018-08-04 18:05:42.429 error at Parser. <anonymous>(/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/lib/xml2js.js:462:18)
      enigma2.0 2018-08-04 18:05:42.429 error at /opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:62:21
      enigma2.0 2018-08-04 18:05:42.429 error at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:132:94)
      enigma2.0 2018-08-04 18:05:42.429 error TypeError: Cannot read property 'e2eventlist' of undefined
      enigma2.0 2018-08-04 18:05:42.428 error uncaught exception: Cannot read property 'e2eventlist' of undefined
      enigma2.0 2018-08-04 18:05:42.425 error at Object.write (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:1314:29)
      enigma2.0 2018-08-04 18:05:42.425 error at closeTag (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:874:5)
      enigma2.0 2018-08-04 18:05:42.425 error at emitNode (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:630:3)
      enigma2.0 2018-08-04 18:05:42.425 error at emit (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:625:33)
      enigma2.0 2018-08-04 18:05:42.425 error at Object.onclosetag (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/lib/xml2js.js:423:26)
      enigma2.0 2018-08-04 18:05:42.425 error at Parser.emit (events.js:188:7)
      enigma2.0 2018-08-04 18:05:42.425 error at emitOne (events.js:96:13)
      enigma2.0 2018-08-04 18:05:42.425 error at Parser. <anonymous>(/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/lib/xml2js.js:462:18)
      enigma2.0 2018-08-04 18:05:42.425 error at /opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:62:21</anonymous></anonymous></anonymous>
      Bei den Tests die hier im Thread stehen, kommt immer:
      Precondition failed!
      sessionid is missing, invalid or expired!
      Was habe ich vergessen zu konfigurieren?
      • ? Offline
        #302
        Bin nicht ganz sicher.
        Geh mal auf der Dream:
        Einstellungen
        Netzwerk
        Webinterface
        Ganz nach unten scrollen und die letzten 3 Einstellungen auf aus.
          #303
          Danke.
          Ich habe jetzt zumindest etwas, und keine Fehler im log
            aleks-83
            #304
            @Matten Matten:
            Funktioniert nur mit http `
            OK, habe intern ausm LAN jetzt http aktiviert.
            Das läuft.
            Ebenso dein Skript um die Box zu steuern!
            Super, vielen Dank für deine Arbeit und die Unterstützung :!:
            = Dell Optiplex Micro - 10GB RAM - 200GB SSD - Debian VM =
            = Node.js v20.19.6 = NPM 10.8.2 = JS Controller 7.0.7 =
            Ubiquiti UAP-AC-LR - UAP-AC-Lite - Synology DS716+II - Fritz!Box 7490
            Glasfaser 400
              Matten Matten
              #305
              @Pocky:
              Einstellungen
              Netzwerk
              Webinterface
              Ganz nach unten scrollen und die letzten 3 Einstellungen auf aus. `
              Ist das möglich hier ein Screenshot zu posten oder die Einstellungen zu beschreiben die dort deaktiviert werden müssen? Damit dann auch andere Forum User wissen was sie ausschalten sollen. Hab leider gerade keine dream am laufen sonst hätte ich es selbst gepostet.
              Vielen Dank im voraus :)
              Matten Matten
                #306
                Muss ich mal mit dem Handy machen ;-)
                per Webinterface kommt man da nicht daruf.
                • ? Offline
                  #307
                  Screenshots vom OSD lassen sich vom Webinterface machen.
                  Dafür muss natürlich vorher über die Dream das entsprechende Menü aufgerufen werden.
                  Bei mir unter Original DMM OE 2.5 befindet sich die Config des Webinterface hier:
                  (Bei anderen Enigma2 Versionen kann das auch woanders sein)
                  Einstellungen
                  Netzwerk
                  Webinterface
                  Dann ganz nach unten Scrollen und die letzten 3 Einträge auf aus stellen.
                    Matten Matten
                    #308
                    Super danke!
                    Matten Matten
                      #309
                      @Pocky:
                      Screenshots vom OSD lassen sich vom Webinterface machen. `
                      :vorDenKopfKlatsch:
                      Klar doch
                        Matten Matten
                        #310
                        @Matten Matten:
                        Blockly Umlaute & Sonderzeichen Dekodierung?
                        Hallo Leute,
                        gibt es eine Möglichkeit mit Blockly Umlaute und Sonderzeichen zu dekorieren?
                        Aus folgenden Hintergrund:
                        Ich möchte die Enigma2 Programm Info in eine CCU2 Systemvariable als Zeichenkette schreiben, sobald ein äöü im Text enthalten sind, wird der Text nicht in die Systemvariable übertragen.
                        Wenn ich bspw ein
                        ä
                        Anstatt ein````
                        ä
                        Eintrage wird das auch in die Systemvariable übernommen. (HTML encode)
                        [https://encoder.mattiasgeniar.be/index.php](https://encoder.mattiasgeniar.be/index.php)
                        Hat einer eine Idee oder eine Lösung wie ich das umsetzen kann? Vielleicht ein Java Skript im Blockly Skript oder so? `
                        Da niemand auf meine Frage antwortet, vermute ich das es niemand weiß, bzw keiner eine Idee hat.
                        Falls es doch jemand interessiert oder auch so eine Decodierung benötigt:
                        createState('Decoded.enigma2.Programm_Info', '');
                        on({id: 'enigma2.0.enigma2.PROGRAMM_INFO'}, function (obj) {
                        	var s=getState('enigma2.0.enigma2.PROGRAMM_INFO').val;
                        	s=replaceAll(s,'ä','ä');
                        	s=replaceAll(s,'ö','ö');
                        	s=replaceAll(s,'ü','ü');
                        	s=replaceAll(s,'Ä','Ä');
                        	s=replaceAll(s,'Ö','Ö');
                        	s=replaceAll(s,'Ü','Ü');
                        	s=replaceAll(s,'Â|À|Å|Ã','A');
                            s=replaceAll(s,'â|à|å|ã','a');
                            s=replaceAll(s,'Ç','C');
                            s=replaceAll(s,'ç','c');
                            s=replaceAll(s,'É|Ê|È|Ë','E');
                            s=replaceAll(s,'é|ê|è|ë','e');
                            s=replaceAll(s,'Ó|Ô|Ò|Õ|Ø','O');
                            s=replaceAll(s,'ó|ô|ò|õ','o');
                            s=replaceAll(s,'Š','S');
                            s=replaceAll(s,'š','s');
                            s=replaceAll(s,'Ú|Û|Ù','U');
                            s=replaceAll(s,'ú|û|ù','u');
                            s=replaceAll(s,'Ý|Ÿ','Y');
                            s=replaceAll(s,'ý|ÿ','y');
                            s=replaceAll(s,'Ž','Z');
                            s=replaceAll(s,'ž','z');
                            s=replaceAll(s,':',' ');
                            s=replaceAll(s,'Š',' ');
                            s=replaceAll(s,'ß','ss');
                            s=replaceAll(s,'?',' ');
                        	setState('Decoded.enigma2.Programm_Info',s);
                        function replaceAll(string, token, newtoken) {
                            if(token!=newtoken)
                            while(string.indexOf(token) > -1) {
                                string = string.replace(token, newtoken);
                            return string;
                        dann wird das bei Objekte unter
                        javascript.0.Decoded.enigma2.Programm_Info
                        decodiert, und man kann diesen text dann in die HomeMatic CCU2 senden/portieren.
                        gruß
                        Matten Matten
                          Matten Matten
                          #311
                          Moin, falls es jemand interessiert, ich habe eben eine neue enigma2 Version (V0.3.0) in github gestellt
                          https://github.com/Matten-Matten/ioBroker.enigma2.git
                          Matten Matten
                            Turbo
                            #312
                            Installiert und läuft!
                            Ich musste allerdings die alte Version deinstallieren und dann nochmal neu installieren, da in den Adapter-Einstellungen die Webinterface-Einstellung fehlte.
                            Vielen Dank für die tolle Arbeit.
                              aleks-83
                              #313
                              @Matten Matten:
                              Moin, falls es jemand interessiert, ich habe eben eine neue enigma2 Version (V0.3.0) in github gestellt `
                              Super, Danke!
                              Hat sich an der Installationsweise was verändert?
                              Wenn ich "sudo iobroker add enigma2" ausführe (so hatte ich es bisher installiert meine ich), kommt:
                              host.ioBroker-RasPi Unknown packetName enigma2
                              Und wenn ich "sudo npm install enigma2" ausführe, kommt:
                              npm ERR! code E404
                              npm ERR! 404 Not found : enigma2
                              npm ERR! 404
                              npm ERR! 404  'enigma2' is not in the npm registry.
                              npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
                              npm ERR! 404
                              npm ERR! 404 Note that you can also install from a
                              npm ERR! 404 tarball, folder, http url, or git url.
                              npm ERR!     /root/.npm/_logs/2018-09-19T14_18_33_855Z-debug.log
                              Glasfaser 400
                                Matten Matten
                                #314
                                Über github installieren!
                                Am besten über die Admin Maske
                                oder im Ordner iobroker:
                                sudo iobroker url "https://github.com/Matten-Matten/ioBroker.enigma2.git"
                                oder:
                                sudo npm install https://github.com/Matten-Matten/ioBroker.enigma2/tarball/master
                                am ende ein Adapter Upload machen und die bestehende Instanz neu starten
                                Matten Matten
                                • metaxaM Offline
                                  metaxaM Offline
                                  metaxa
                                  #315
                                  Hallo Matten Matten!
                                  Tolle Arbeit, danke!
                                  Erstmals installiert, dann Script gefunden und …. "astrein" TOP!
                                  Ist irgendwann eine Message vorgesehen?
                                  z.B.: http://192.168.0.53/web/message?text=BEWEGUNG:….....
                                  LG, mxa
                                  DM800/OW
                                    Matten Matten
                                    #316
                                    @metaxa:
                                    LG, mxa
                                    DM800/OW `
                                    Das sollte man dann auch über das Script hin bekommen. Kann mich da noch Mal dran hängen.
                                    Dann vielleicht sogar mit Auswahl was das für eine Nachricht sein soll (Info, Frage mit ja nein , …).
                                    Matten Matten
                                    • metaxaM Offline
                                      metaxaM Offline
                                      metaxa
                                      #317
                                      @Matten Matten:
                                      Dann vielleicht sogar mit Auswahl was das für eine Nachricht sein soll (Info, Frage mit ja nein , …). `
                                      Ich verwende diesen Befehl noch aktuell gesteuert über HM. Problem ist(war?) immer die Formatierung (Leerzeichen, Tab, Zeilenschaltung, etc…)
                                      Eventuell muss man dann das neu vorgesehene Feld in dieser Form befüllen:
                                      EG%20Haus:%09" # tmpA # "
                                      WC:%09" # tmpB # "
                                      Bad:%09" # tmpC # "
                                      Schlafzimmer:%09" # tmpD # "
                                      Kellerabgang:%09" # tmpG # "
                                      Büro L:%09" # tmpE # "
                                      Büro R:%09" # tmpF # "
                                      EG%20Terrasse:%09" # tmpH # "
                                      Wohnzimmer:%09" # tmpI # "
                                      Küche L:%09" # tmpJ # "
                                      Küche R:%09" # tmpK # "
                                      ! Keller WM:%09" # tmpL # "
                                      Keller Werkst.:%09" # tmpM # "
                                      Keller Sauna:%09" # tmpN # "
                                      ! Garage:%09" # tmpO # "
                                      &type=2&timeout=10'");
                                      Ist halt nicht sehr userfreundlich und für dich sicher ein Haufen Arbeit.
                                      LG, mxa
                                        Matten Matten
                                        #318
                                        Der enigma2 Adapter V0.3.1 + ENIGMA 2 BUTTON SCRIPT V2.1 ->ENIGMA 2 BUTTON SCRIPT V2.2
                                        ist raus. jetzt mit Message send
                                        (in Verbindung mit "ENIGMA 2 BUTTON SCRIPT V2.1" ->ENIGMA 2 BUTTON SCRIPT V2.2)
                                        Matten Matten
                                          Matten Matten
                                          #319
                                          ENIGMA 2 BUTTON SCRIPT V2.2 ist raus.
                                          kleinen Fehler korrigiert. :roll:
                                          Matten Matten
