  4. [Problem] Dream btw. Enigma2 Adapter
739 Beiträge 82 Kommentatoren 287.6k Aufrufe 15 Beobachtet
    schnipsel71
    #292
    Das habe ich auch. Jedenfalls komme ich ins Openwebif ohne Kennworteingabe.
    Die Einstellungen des vuplus-Adapters sehen also so aus:
    …klappt aber nicht.
    • wendy2702W Online
      wendy2702W Online
      #293
      Trage mal nur die Ip ein ohne````
      http://
        schnipsel71
        #294
        Oh Mann, Danke!
          Stefan-G
          #295
          habe mal eine Funktion zur Anzeige aller Bouquets und Kanäle und zum Umschalten implementiert:
          ! var parseString = require('xml2js').parseString;
          ! var request = require('request');
          ! var urlVUplus = 'http://192.168.1.101:82';
          ! var instanz = 'javascript.0'; instanz = instanz + '.';
          ! var pfad = 'XMLParsing'; pfad = pfad + '.'; // Pfad innerhalb der Instanz
          ! var debug = true;
          ! // VU+ Power-Status
          ! createState(pfad + 'VUplus.BouquetNames', 'init', {type: "string", name: "Names of Enigma bouquets", write:true, read:true});
          ! createState(pfad + 'VUplus.BouquetNumbers', 'init', {type: "string", name: "References of Enigma bouquets", write:true, read:true});
          ! createState(pfad + 'VUplus.NumberOfBouquets', 0, {type: "number", name: "How many bouquets are defined in Enigma", write:false, read:true});
          ! createState(pfad + 'VUplus.BouquetNumberCurrent', 0, {type: "number", name: "Number of selected Enigma bouquet", write:true, read:true});
          ! createState(pfad + 'VUplus.BouquetCurrentlySelected.BouquetName', 'init',{type: "string", name: "Name of currently selected Enigma bouquet", write:true, read:true});
          ! createState(pfad + 'VUplus.BouquetCurrentlySelected.BouquetReference', 'init',{type: "string", name: "Reference of currently selected Enigma bouquet", write:true, read:true});
          ! createState(pfad + 'VUplus.BouquetCurrentlySelected.ChannelNames', 'init',{type: "string", name: "Channel names of currently selected Enigma bouquet", write:true, read:true});
          ! createState(pfad + 'VUplus.BouquetCurrentlySelected.ChannelReferences', 'init',{type: "string", name: "Channel references of currently selected Enigma bouquet", write:true, read:true});
          ! createState(pfad + 'VUplus.ChannelReferenceCurrent', 'init', {type: "string", name: "Reference of selected channel", write:true, read:true});
          ! //example HHTP requests to obtain bouquet and channel list:
          ! //http://192.168.1.101:82/web/getservices
          ! //Favourites (TV):
          ! //http://192.168.1.101:82/web/getservices … %20bouquet
          ! //German Free SD
          ! //http://192.168.1.101:82/web/getservices ... %20bouquet
          ! //German Free HD
          ! //German HD+
          ! // This function collects all channel names (TV stations) and the respective
          ! // channel references and writes them into the respective states created before
          ! // (in calling function GetVUplusChannels()
          ! function GetVUplusBouquetChannels(strBouquetReference, iBouquetNumber) {
          ! var strAllChannelNames = '';
          ! var strAllChannelReferences = '';
          ! request(urlVUplus + '/web/getservices?sRef=' + strBouquetReference, function (error, response, body) {
          ! if (!error && response.statusCode == 200) {
          ! //if(debug){log("Body: " + body);}
          ! parseString(body, {
          ! explicitArray: false,
          ! mergeAttrs: true
          ! function (err, result) {
          ! if (err) {
          ! log("Fehler: " + err);
          ! } else {
          ! for (var j = 0; j < result.e2servicelist.e2service.length; j++) {
          ! var strSender = result.e2servicelist.e2service[j].e2servicename;
          ! var strService = result.e2servicelist.e2service[j].e2servicereference;
          ! if(debug){ log("Sender Nr. " + j + ": " + strSender + ", Service: " + strService);}
          ! strAllChannelNames = strAllChannelNames + strSender + ';';
          ! strAllChannelReferences = strAllChannelReferences + strService + ';';
          ! strAllChannelNames = strAllChannelNames.slice(0,strAllChannelNames.length-1); // cut away last ";"
          ! strAllChannelReferences = strAllChannelReferences.slice(0,strAllChannelReferences.length-1); // cut away last ";"
          ! if(debug){ log('All channels for Bouquet ' + iBouquetNumber +': ' + strAllChannelNames);}
          ! if(debug){ log('All channel references for Bouquet ' + iBouquetNumber + ': ' + strAllChannelReferences);}
          ! setState(instanz + pfad + 'VUplus.Bouquet' + iBouquetNumber + '.ChannelNames', strAllChannelNames);
          ! setState(instanz + pfad + 'VUplus.Bouquet' + iBouquetNumber + '.ChannelReferences', strAllChannelReferences);
          ! } else {
          ! if(debug){log(error);}
          ! // This function creates states for all bouquets with all info about the bouquet
          ! // e.g. channels (TV station) names and respective service references
          ! function CreateBouquetStates(NrOfBouquets) {
          ! for (var i = 0; i < NrOfBouquets; i++) {
          ! createState(pfad + 'VUplus.Bouquet' + i + '.BouquetName', 'init',{type: "string", name: "Name of Enigma bouquets number "+ i, write:true, read:true});
          ! createState(pfad + 'VUplus.Bouquet' + i + '.BouquetReference', 'init',{type: "string", name: "Reference of Enigma bouquets number "+ i, write:true, read:true});
          ! createState(pfad + 'VUplus.Bouquet' + i + '.ChannelNames', 'init',{type: "string", name: "Channel names of Enigma bouquets number "+ i, write:true, read:true});
          ! createState(pfad + 'VUplus.Bouquet' + i + '.ChannelReferences', 'init',{type: "string", name: "Channel references of Enigma bouquets number "+ i, write:true, read:true});
          ! // TODO: here code could be added which deletes states if more bouquet states have already been created befor than bouquets exit presently, e.g. this can happen if an bouquet has been deleted on the ENIGMA system
          ! // This function all available bouquets (TV station lists) for an ENIGMA system
          ! // and creates states for all bouquets filled with channel (TV station) and
          ! // respective service references for bouquets and channels
          ! function GetVUplusChannels() {
          ! request(urlVUplus + '/web/getservices', function (error, response, body) {
          ! mergeAttrs: true
          ! if (err) {
          ! } else {
          ! if(debug){ log("Anzahl Bouquets: " + result.e2servicelist.e2service.length);}
          ! var strBouquetName = '';
          ! var strBouquetReference = '';
          ! var strAllBouquetNames = '';
          ! var strAllBouquetNumbers = '';
          ! // create as many states as bouquets exist
          ! setState(instanz + pfad + 'VUplus.NumberOfBouquets', result.e2servicelist.e2service.length);
          ! CreateBouquetStates(result.e2servicelist.e2service.length);
          ! for (i = 0; i < result.e2servicelist.e2service.length; i++) {
          ! strBouquetName = result.e2servicelist.e2service__.e2servicename;
          ! strBouquetReference = result.e2servicelist.e2service__.e2servicereference.replace(/ /g, "%20").replace(/"/g, "%22");
          ! strAllBouquetNames = strAllBouquetNames + strBouquetName + ';';
          ! strAllBouquetNumbers = strAllBouquetNumbers + i + ';';
          ! if(debug){ log("Bouquet Nr. " + i + ": " + strBouquetName + ", Bouquet References: " + strBouquetReference);}
          ! setState(instanz + pfad + 'VUplus.Bouquet' + i + '.BouquetName', strBouquetName);
          ! setState(instanz + pfad + 'VUplus.Bouquet' + i + '.BouquetReference', strBouquetReference);
          ! GetVUplusBouquetChannels(strBouquetReference, i);
          ! strAllBouquetNames = strAllBouquetNames.slice(0,strAllBouquetNames.length-1); // cut away last ";"
          ! strAllBouquetNumbers = strAllBouquetNumbers.slice(0,strAllBouquetNumbers.length-1); // cut away last ";"
          ! if(debug){ log("All Bouquets: " + strAllBouquetNames);}
          ! if(debug){ log("All Bouquet numbers: " + strAllBouquetNumbers);}
          ! setState(instanz + pfad + 'VUplus.BouquetNames', strAllBouquetNames);
          ! setState(instanz + pfad + 'VUplus.BouquetNumbers', strAllBouquetNumbers);
          ! } else {
          ! on(instanz + pfad + 'VUplus.BouquetNumberCurrent', function(obj) {
          ! var ChannelNamesOfNewCurrentBouquet = getState(instanz + pfad + 'VUplus.Bouquet' + obj.newState.val + '.ChannelNames').val;
          ! var ChannelReferencesOfNewCurrentBouquet = getState(instanz + pfad + 'VUplus.Bouquet' + obj.newState.val + '.ChannelReferences').val;
          ! var FirstChannelReferenceOFNewBouquet = ChannelReferencesOfNewCurrentBouquet.slice(0, ChannelReferencesOfNewCurrentBouquet.indexOf(';'));
          ! if(debug){ log('Current bouquet number changed to: ' + obj.newState.val );}
          ! if(debug){ log('First channel in urrent bouquet: ' + ChannelNamesOfNewCurrentBouquet.slice(0, ChannelNamesOfNewCurrentBouquet.indexOf(';')) );}
          ! if(debug){ log('First channel reference in urrent bouquet: ' + FirstChannelReferenceOFNewBouquet);}
          ! // serch if the currently selected TC channel exists in the new selected bouquet
          ! if(ChannelReferencesOfNewCurrentBouquet.indexOf(getState(instanz + pfad + 'VUplus.ChannelReferenceCurrent').val) == -1) {
          ! if(debug){ log('Currently selected TC channel not found in previous bouquet, switching channel.');}
          ! setState(instanz + pfad + 'VUplus.ChannelReferenceCurrent', FirstChannelReferenceOFNewBouquet);
          ! // set new values for selected bouquet
          ! setState(instanz + pfad + 'VUplus.BouquetCurrentlySelected.BouquetName', getState(instanz + pfad + 'VUplus.Bouquet' + obj.newState.val + '.BouquetName').val);
          ! setState(instanz + pfad + 'VUplus.BouquetCurrentlySelected.BouquetReference', getState(instanz + pfad + 'VUplus.Bouquet' + obj.newState.val + '.BouquetReference').val);
          ! setState(instanz + pfad + 'VUplus.BouquetCurrentlySelected.ChannelNames', ChannelNamesOfNewCurrentBouquet);
          ! setState(instanz + pfad + 'VUplus.BouquetCurrentlySelected.ChannelReferences', ChannelReferencesOfNewCurrentBouquet);
          ! on(instanz + pfad + 'VUplus.ChannelReferenceCurrent', function(obj) {
          ! if(debug){ log('Chosen current channel reference: ' + obj.newState.val );}
          ! request(urlVUplus + '/api/zap?sRef=' + obj.newState.val, function (error, response, body) {
          ! //log("Body: " + body);
          ! mergeAttrs: true
          ! if (err) {
          ! } else {
          ! if(debug){ log(result);}
          ! } else {
          ! log(error);
          ! // create and fill all states for bouquets and station names
          ! GetVUplusChannels();____ __Code mag natürlich noch optimierbar sein. Ich fände es cool, wenn es diese Funktion gleich im Adapter gäbe, oder gibt es einen Grund, das dort nicht zu implementieren? Kann dann so aussehen (roter Kasten):
          Die Widgets dafür sind dann wie folgt:
          ! [{"tpl":"tplJquiSelectList","data":{"oid":"javascript.0.XMLParsing.VUplus.BouquetNumberCurrent","values":"{javascript.0.XMLParsing.VUplus.BouquetNumbers}","texts":"{javascript.0.XMLParsing.VUplus.BouquetNames}","height":"170","open":false,"gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"g_visibility":false,"g_fixed":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"370px","top":"213px","width":"214px","height":"29px"},"widgetSet":"jqui"},{"tpl":"tplValueString","data":{"oid":"","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"Bouquet:","html_append":"","test_html":"","visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"376px","top":"184px","color":"#ffffff","width":"186px","height":"20px","text-shadow":"rgba(0, 0, 0, 0.9) 3px 3px 4px","font-family":"Tahoma, Geneva, sans-serif"},"widgetSet":"basic"},{"tpl":"tplJquiSelectList","data":{"oid":"javascript.0.XMLParsing.VUplus.ChannelReferenceCurrent","values":"{javascript.0.XMLParsing.VUplus.BouquetCurrentlySelected.ChannelReferences}","texts":"{javascript.0.XMLParsing.VUplus.BouquetCurrentlySelected.ChannelNames}","height":"170","open":false,"gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"g_visibility":false,"g_fixed":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"605px","top":"212px","width":"217px","height":"29px"},"widgetSet":"jqui"},{"tpl":"tplValueString","data":{"oid":"","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"Sender:","html_append":"","test_html":"","visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","values":"{javascript.0.XMLParsing.VUplus.Bouquet3.ChannelReferences}","texts":"{javascript.0.XMLParsing.VUplus.Bouquet3.ChannelNames}"},"style":{"left":"607px","top":"181px","color":"#ffffff","width":"186px","height":"20px","text-shadow":"rgba(0, 0, 0, 0.9) 3px 3px 4px","font-family":"Tahoma, Geneva, sans-serif"},"widgetSet":"basic"}]
          Vielleicht mag das ja jemand einbauen (meine Git-/Adapter- Kenntnisse sind leider nicht gut genug).
          Ne Timer-Liste wäre auch cool. Vielleicht schafft das ja auch jemand schneller als ich… ;)__
          • hg6806H Offline
            hg6806H Offline
            hg6806
            #296
            leider funktioniert bei meiner Dreambox DM7020HD die Pasue/Play Funktion über den VUPlus Adapter nicht
            vuplus.0.VuPlus.RC.PLAY_PAUSE
            …erkennt die Box nicht wirklich.
            Bei den Codes für die Fernbedienung ist diese Funktion auch nicht drauf.
            Wie kann ich das schalten?
              aleks-83
              #297
              ich habe den Enigma2 Adapter bei mir installiert und für meine VU+ Duo 2 konfiguriert.
              Die Datenobjekte sind aber immer noch leer.
              Muss ich das iwie anstoßen?
              Aleks
              = Dell Optiplex Micro - 10GB RAM - 200GB SSD - Debian VM =
              = Node.js v20.19.6 = NPM 22.22.2 = JS Controller 7.2.2 =
              Ubiquiti UAP-AC-LR - UAP-AC-Lite - Synology DS716+II - Fritz!Box 7490
              Glasfaser 400
              • Matten MattenM Offline
                Matten Matten
                #298
                IP Adresse und Port richtig eingegeben?
                ioBroker auf Beelink mit WIN10 home|CCU3 (Raspberrymatic)|Neato BotVac D3|HYPERION Ambilight auf RPI3 und RPI ZeroW|HA-Bridge|Milight LED|Nodered&Redmatic|VU Duo2 & Solo se V2
                  aleks-83
                  #299
                  Ja habe ich.
                  Allerdings nutze ich https, ist das ein Problem?
                  ich habe die IP mit https://192.xxxx angegeben oder auch mal als 192.xxxx
                  Glasfaser 400
                    Matten Matten
                    #300
                    Funktioniert nur mit http
                      #301
                      Habe jetzt endlich meine Dreambox 920 am Netz.
                      Adapter installiert und Konfiguriert:
                      enigma2.0 2018-08-04 18:05:42.432 error at Object.write (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:1314:29)
                      enigma2.0 2018-08-04 18:05:42.432 error at closeTag (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:874:5)
                      enigma2.0 2018-08-04 18:05:42.432 error at emitNode (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:630:3)
                      enigma2.0 2018-08-04 18:05:42.432 error at emit (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:625:33)
                      enigma2.0 2018-08-04 18:05:42.432 error at Object.onclosetag (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/lib/xml2js.js:423:26)
                      enigma2.0 2018-08-04 18:05:42.432 error at Parser.emit (events.js:188:7)
                      enigma2.0 2018-08-04 18:05:42.432 error at emitOne (events.js:96:13)
                      enigma2.0 2018-08-04 18:05:42.432 error at Parser. <anonymous>(/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/lib/xml2js.js:462:18)
                      enigma2.0 2018-08-04 18:05:42.432 error at /opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:62:21
                      enigma2.0 2018-08-04 18:05:42.432 error at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:162:60)
                      enigma2.0 2018-08-04 18:05:42.432 error TypeError: Cannot read property 'e2webifversion' of undefined
                      enigma2.0 2018-08-04 18:05:42.431 error uncaught exception: Cannot read property 'e2webifversion' of undefined
                      enigma2.0 2018-08-04 18:05:42.429 error at Object.write (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:1314:29)
                      enigma2.0 2018-08-04 18:05:42.429 error at closeTag (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:874:5)
                      enigma2.0 2018-08-04 18:05:42.429 error at emitNode (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:630:3)
                      enigma2.0 2018-08-04 18:05:42.429 error at emit (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:625:33)
                      enigma2.0 2018-08-04 18:05:42.429 error at Object.onclosetag (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/lib/xml2js.js:423:26)
                      enigma2.0 2018-08-04 18:05:42.429 error at Parser.emit (events.js:188:7)
                      enigma2.0 2018-08-04 18:05:42.429 error at emitOne (events.js:96:13)
                      enigma2.0 2018-08-04 18:05:42.429 error at Parser. <anonymous>(/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/lib/xml2js.js:462:18)
                      enigma2.0 2018-08-04 18:05:42.429 error at /opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:62:21
                      enigma2.0 2018-08-04 18:05:42.429 error at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:132:94)
                      enigma2.0 2018-08-04 18:05:42.429 error TypeError: Cannot read property 'e2eventlist' of undefined
                      enigma2.0 2018-08-04 18:05:42.428 error uncaught exception: Cannot read property 'e2eventlist' of undefined
                      enigma2.0 2018-08-04 18:05:42.425 error at Object.write (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:1314:29)
                      enigma2.0 2018-08-04 18:05:42.425 error at closeTag (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:874:5)
                      enigma2.0 2018-08-04 18:05:42.425 error at emitNode (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:630:3)
                      enigma2.0 2018-08-04 18:05:42.425 error at emit (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/node_modules/sax/lib/sax.js:625:33)
                      enigma2.0 2018-08-04 18:05:42.425 error at Object.onclosetag (/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/lib/xml2js.js:423:26)
                      enigma2.0 2018-08-04 18:05:42.425 error at Parser.emit (events.js:188:7)
                      enigma2.0 2018-08-04 18:05:42.425 error at emitOne (events.js:96:13)
                      enigma2.0 2018-08-04 18:05:42.425 error at Parser. <anonymous>(/opt/iobroker/node_modules/iobroker.enigma2/lib/xml2js/lib/xml2js.js:462:18)
                      enigma2.0 2018-08-04 18:05:42.425 error at /opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:62:21</anonymous></anonymous></anonymous>
                      Bei den Tests die hier im Thread stehen, kommt immer:
                      Precondition failed!
                      sessionid is missing, invalid or expired!
                      Was habe ich vergessen zu konfigurieren?
                      • ? Offline
                        #302
                        Bin nicht ganz sicher.
                        Geh mal auf der Dream:
                        Einstellungen
                        Netzwerk
                        Webinterface
                        Ganz nach unten scrollen und die letzten 3 Einstellungen auf aus.
                          #303
                          Danke.
                          Ich habe jetzt zumindest etwas, und keine Fehler im log
                            aleks-83
                            #304
                            @Matten Matten:
                            Funktioniert nur mit http `
                            OK, habe intern ausm LAN jetzt http aktiviert.
                            Das läuft.
                            Ebenso dein Skript um die Box zu steuern!
                            Super, vielen Dank für deine Arbeit und die Unterstützung :!:
                            Glasfaser 400
                              Matten Matten
                              #305
                              @Pocky:
                              Einstellungen
                              Netzwerk
                              Webinterface
                              Ganz nach unten scrollen und die letzten 3 Einstellungen auf aus. `
                              Ist das möglich hier ein Screenshot zu posten oder die Einstellungen zu beschreiben die dort deaktiviert werden müssen? Damit dann auch andere Forum User wissen was sie ausschalten sollen. Hab leider gerade keine dream am laufen sonst hätte ich es selbst gepostet.
                              Vielen Dank im voraus :)
                              Matten Matten
                                #306
                                Muss ich mal mit dem Handy machen ;-)
                                per Webinterface kommt man da nicht daruf.
                                • ? Offline
                                  #307
                                  Screenshots vom OSD lassen sich vom Webinterface machen.
                                  Dafür muss natürlich vorher über die Dream das entsprechende Menü aufgerufen werden.
                                  Bei mir unter Original DMM OE 2.5 befindet sich die Config des Webinterface hier:
                                  (Bei anderen Enigma2 Versionen kann das auch woanders sein)
                                  Einstellungen
                                  Netzwerk
                                  Webinterface
                                  Dann ganz nach unten Scrollen und die letzten 3 Einträge auf aus stellen.
                                    Matten Matten
                                    #308
                                    Super danke!
                                    Matten Matten
                                      #309
                                      @Pocky:
                                      Screenshots vom OSD lassen sich vom Webinterface machen. `
                                      :vorDenKopfKlatsch:
                                      Klar doch
                                        Matten Matten
                                        #310
                                        @Matten Matten:
                                        Blockly Umlaute & Sonderzeichen Dekodierung?
                                        Hallo Leute,
                                        gibt es eine Möglichkeit mit Blockly Umlaute und Sonderzeichen zu dekorieren?
                                        Aus folgenden Hintergrund:
                                        Ich möchte die Enigma2 Programm Info in eine CCU2 Systemvariable als Zeichenkette schreiben, sobald ein äöü im Text enthalten sind, wird der Text nicht in die Systemvariable übertragen.
                                        Wenn ich bspw ein
                                        ä
                                        Anstatt ein````
                                        ä
                                        Eintrage wird das auch in die Systemvariable übernommen. (HTML encode)
                                        [https://encoder.mattiasgeniar.be/index.php](https://encoder.mattiasgeniar.be/index.php)
                                        Hat einer eine Idee oder eine Lösung wie ich das umsetzen kann? Vielleicht ein Java Skript im Blockly Skript oder so? `
                                        Da niemand auf meine Frage antwortet, vermute ich das es niemand weiß, bzw keiner eine Idee hat.
                                        Falls es doch jemand interessiert oder auch so eine Decodierung benötigt:
                                        createState('Decoded.enigma2.Programm_Info', '');
                                        on({id: 'enigma2.0.enigma2.PROGRAMM_INFO'}, function (obj) {
                                        	var s=getState('enigma2.0.enigma2.PROGRAMM_INFO').val;
                                        	s=replaceAll(s,'ä','ä');
                                        	s=replaceAll(s,'ö','ö');
                                        	s=replaceAll(s,'ü','ü');
                                        	s=replaceAll(s,'Ä','Ä');
                                        	s=replaceAll(s,'Ö','Ö');
                                        	s=replaceAll(s,'Ü','Ü');
                                        	s=replaceAll(s,'Â|À|Å|Ã','A');
                                            s=replaceAll(s,'â|à|å|ã','a');
                                            s=replaceAll(s,'Ç','C');
                                            s=replaceAll(s,'ç','c');
                                            s=replaceAll(s,'É|Ê|È|Ë','E');
                                            s=replaceAll(s,'é|ê|è|ë','e');
                                            s=replaceAll(s,'Ó|Ô|Ò|Õ|Ø','O');
                                            s=replaceAll(s,'ó|ô|ò|õ','o');
                                            s=replaceAll(s,'Š','S');
                                            s=replaceAll(s,'š','s');
                                            s=replaceAll(s,'Ú|Û|Ù','U');
                                            s=replaceAll(s,'ú|û|ù','u');
                                            s=replaceAll(s,'Ý|Ÿ','Y');
                                            s=replaceAll(s,'ý|ÿ','y');
                                            s=replaceAll(s,'Ž','Z');
                                            s=replaceAll(s,'ž','z');
                                            s=replaceAll(s,':',' ');
                                            s=replaceAll(s,'Š',' ');
                                            s=replaceAll(s,'ß','ss');
                                            s=replaceAll(s,'?',' ');
                                        	setState('Decoded.enigma2.Programm_Info',s);
                                        function replaceAll(string, token, newtoken) {
                                            if(token!=newtoken)
                                            while(string.indexOf(token) > -1) {
                                                string = string.replace(token, newtoken);
                                            return string;
                                        dann wird das bei Objekte unter
                                        javascript.0.Decoded.enigma2.Programm_Info
                                        decodiert, und man kann diesen text dann in die HomeMatic CCU2 senden/portieren.
                                        gruß
                                        Matten Matten
                                          Matten Matten
                                          #311
                                          Moin, falls es jemand interessiert, ich habe eben eine neue enigma2 Version (V0.3.0) in github gestellt
                                          https://github.com/Matten-Matten/ioBroker.enigma2.git
                                          Matten Matten
