Adapter: iobroker.backitup (stable Release)
Mein Fehler!
Die Angabe für CIFS oder FTP hat gefehlt :````
sudo bash backitup.sh "minimal|||deine nas ip|dein Verzeichnis|Dein_NAS_User|Dein_NAS_PW||||CIFS|false|false|||| | | |dein_IoBroker_Dir" -
Das sieht schon interessanter aus:
minimal|||192.168.138.71|public/backups|Mein_usr|Mein_pw||||CIFS|false|false|||| | | |/opt/iobroker --- Mount Backup-Path on CIFS --- mount: wrong fs type, bad option, bad superblock on //192.168.138.71/public/backups, missing codepage or helper program, or other error (for several filesystems (e.g. nfs, cifs) you might need a /sbin/mount. <type>helper program) In some cases useful info is found in syslog - try dmesg | tail or so. mount: wrong fs type, bad option, bad superblock on //192.168.138.71/public/backups, missing codepage or helper program, or other error (for several filesystems (e.g. nfs, cifs) you might need a /sbin/mount. <type>helper program) In some cases useful info is found in syslog - try dmesg | tail or so. error --- Backup-Pfad wurde nicht auf CIFS-Server verbunden --- --- Es wurde ein Normales Backup gestartet --- Backup created: /opt/iobroker/backups/2018_07_17-23_16_00_backupiobroker.tar.gz success --- Ein normales Backup wurde erstellt --- find: invalid argument `+ ' to `-mtime' --- Es werden keine alten Backups geloescht ---</type></type> -
Hab noch was:
[ 7126.470039] No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the less secure SMB1 dialect to access old ser vers which do not support SMB3 (or SMB2.1) specify vers=1.0 on mount.HTH
Gute Nacht in …
Nach dem neuen Update erscheint folgende Meldung im Log:
backitup.0 2018-07-17 23:31:29.984 warn Please translate ind words.js: CIFS-Mount: JA backitup.0 2018-07-17 23:31:29.983 warn Please translate ind words.js: Typ backitup.0 2018-07-17 23:31:29.981 warn Please translate ind words.js: Noch keine Backups erstellt backitup.0 2018-07-17 23:31:29.957 info [ccu] oneClick backup startedWeitere Einträge gibt es nicht obwohl das Backup erstellt und auf die NAS geschrieben wurde.
Das erweitert zwar die Ausgabe, aber nach der "warn" Meldung ist Schluss und die Erfolgsmeldungen werden nicht ausgegeben.
Vor dem Update sah es im Log so aus:
backitup.0 2018-07-17 22:37:09.255 info success --- Umount CIFS Server --- backitup.0 2018-07-17 22:37:09.255 info success --- Ueberpruefung auf alte Dateien und loeschen erfolgreich --- backitup.0 2018-07-17 22:37:09.255 info --- Alte Backups entfernen --- backitup.0 2018-07-17 22:37:09.255 info success --- Ein Homematic-CCU Backup wurde erstellt --- backitup.0 2018-07-17 22:37:09.255 info success --- Login Homematic-CCU erfolgreich --- backitup.0 2018-07-17 22:37:09.255 info --- Es wurde ein Homematic CCU Backup gestartet --- backitup.0 2018-07-17 22:37:09.255 info success --- CIFS-Server verbunden --- backitup.0 2018-07-17 22:37:09.255 info --- Backup-Pfad auf CIFS mounten --- backitup.0 2018-07-17 22:37:09.255 info exec: ccu||30|192.168.178.215|Sicherungen/RaspberyMatic|Riemann|xxxxx|192.168.178.217|Admin||CIFS||||||5|localhost|3307 backitup.0 2018-07-17 22:36:39.158 info OneClick CCU Backup gestartetJetzt ist es so:
backitup.0 2018-07-17 23:46:46.851 warn Please translate ind words.js: CIFS-Mount: JA backitup.0 2018-07-17 23:46:46.850 warn Please translate ind words.js: Typ backitup.0 2018-07-17 23:46:46.849 warn Please translate ind words.js: Noch keine Backups erstellt backitup.0 2018-07-17 23:46:46.807 info [ccu] bash /opt/iobroker/node_modules/iobroker.backitup/backitup.sh "ccu||30|192.168.178.215|Sicherungen/RaspberyMatic|Riemann|xxx|192.168.178.217|Admin||CIFS|||||||||/opt/iobroker" backitup.0 2018-07-17 23:46:46.802 info [ccu] oneClick backup startedNach dem Update waren auch alle Einstellungen verschwunden und alle Objekte waren doppelt vorhanden.
Geändert: passwort entfernt; Homoran (Admin)
Heute gab es von bluefox große Änderungen, damit der Adapter es vielleicht in die Iobroker Repro schafft.
Leider haben sich dabei einige Fehler eingeschlichen, an denen peoples und ich aber dran sind.
hier mal mein Kurzfeedback:
Adapterversion 0.2.0, Fritzbox mit HDD dran
FTP –> funktioniert (gleich auf Anhieb)
CIFS --> funktioniert (hier hatte ich eine Weile gebraucht habe bis die Einstellungen (Fritzbox und Pfad im Adapter) korrekt waren.
Grüße, Lenny `
Hallon Lenny.
Hier würde ich gerne mal eingrätschen. Meine Config ist ähnlich an der Fritzbox ist eine Platte angeschlossen.
Den FTP zugriff habe ich auch gut hinbekommen.
An CIFS bin ich gescheitert.
Ich habe sowohl
Fritz.nas/backupordner/
Als auch 192.168.178.254/backupordner probiert.
Leider bis jetzt ohne Erfolg
Was hast du denn eingetrageb bzw. Bei der Fritzbox aktiviert?
Stefan
Stefan `
Hallo Stefan,
hier mal meine Einstellungen mit ein paar Anmerkungen…
Nutzer in der Fritzbox anlegen --> System/FRITZ!Box-Benutzer/Benutzer aufrufen und Benutzer hinzufügen --> Hacken bei "Zugang zu NAS-Inhalten" setzen --> Verzeichnis hinzufügen --> Verzeichnis auswählen ("Alle an der FRITZ!Box verfügbaren Speicher" hat bei mir nicht funktioniert, daher Freigabe zweier einzelner Ordner) --> Beispiel: /WD-MyPassport25E2-01/FRITZ/backup_iobroker/minimal --> "OK" klickenHeimnetzfreigabe erstellen --> Heimnetz/Speicher (NAS) aufrufen --> Hacken bei "Zugriff über ein Netzlaufwerk (SMB) aktiv" setzen --> Beispiel: "Name" fritzbox, "Arbeitsgruppe" fritzbox (was unter "Name" eingetragen ist, brauchen wir noch im Adapter) --> "Übernehmen" klickenAdaptereinstellungen --> "Verbindungstyp" CIFS --> "Host" IP der Fritzbox (habe hier nur mit der IP getestet, nicht mit dem Namen) --> "Benutzername" der, der in der Fritzbox unter "Benutzer" angelegt wurde --> "Passwort" das, was in der Fritzbox unter "Benutzer" angelegt wurde --> "NAS-Pfad für Standard-Backup" Freigabe und Pfad zum freigegebenen Ordner OHNE dem ersten "/" --> Beispiel: fritzbox/WD-MyPassport25E2-01/FRITZ/backup_iobroker/minimal --> "NAS-Pfad für Komplett-Backup" hier noch für das Komplett-Backup falls getrennte Ordner --> "Speichern"Dann sollte das schon alles funktionieren. Testen kann man das, indem man in den backitup-Objekten den betreffenden "OneClick" kurz auf "true" toggelt.
Getestet habe ich mit Version 0.2.0
Grüße, Lenny
Hab noch was:
Gute Nacht in …
Rainer `
Hi Rainer,
hast die cifs zum laufen bekommen?
Hast du mal im bash geschaut.
Eventuell musst du die Versionsnummer anpassen.
Da gibt es im backitup.sh zwei mount Befehle.
Falls es mit einer anderen Version gehen sollte, dann muss ich da ne for Schleife einbauen.
Im shell ist aktuell vers=1.0
Da gibt es im backitup.sh zwei mount Befehle. `
Ist ja lieb gemeint - aber das kann ich leider nicht.Ich hatte es immer mit deinem Befehl gemacht.
sudo bash backitup.sh "minimal|||deine nas ip|dein Verzeichnis|Dein_NAS_User|Dein_NAS_PW||||CIFS|false|false|||| | | |dein_IoBroker_Dir"das backitup.sh habe ich mir noch nicht angesehen, da würde ich zu viel kaputt machen ;-)
