  4. IoBroker und Nodejs 10
    6.6k
137 Beiträge 30 Kommentatoren 96.0k Aufrufe 8 Beobachtet
  • apollon77A Offline
    Bitte keine Threads mixen!! Hier geht es um nodejs 10!!
    Aber werden für nodejs 8 noch 10 sind Probleme mit Modus bekannt.
    Bitte Logs und so dazu in einem neuen Thread Posten.
      meisterlemon
      bei mir geht nichts mehr, iobroker kann nicht mehr gestartet werden:
      Starting iobroker controller daemon...
      /opt/iobroker/node_modules/daemonize2/lib/daemonize.js:136
                  throw new Error(msg.error);
      Error: TypeError: common.log is not a function
          at module.exports.DailyRotateFile.log (/opt/iobroker/node_modules/winston-daily-rotate-file/index.js:215:23)
          at transportLog (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/winston/lib/winston/logger.js:234:15)
          at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/async/lib/async.js:157:13
          at _each (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/async/lib/async.js:57:9)
          at Object.async.each (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/async/lib/async.js:156:9)
          at exports.Logger.Logger.log (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/winston/lib/winston/logger.js:246:9)
          at exports.Logger.target.(anonymous function) [as info] (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/winston/lib/winston/common.js:54:18)
          at init (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:2401:12)
          at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/controller.js:2513:1)
          at Module._compile (internal/modules/cjs/loader.js:702:30)
          at ChildProcess. <anonymous>(/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:136:19)
          at ChildProcess.emit (events.js:182:13)
          at emit (internal/child_process.js:811:12)
          at process._tickCallback (internal/process/next_tick.js:63:19)
      root@debian:/opt/iobroker#</anonymous></anonymous>
      Sonos Komponente, Intel i5 NUC mit SSD, Z-Wave, Xiaomi Mihome, Fibaro Shutter, iPad 17 in der Wand,s50 Roborock,
      VCDS vorhanden
        <ironie-ein>Warte mal … meine Glaskugel sagt ... Mist muss die erst putzen ... <ironie-aus>Hast Du bitte mal ein paar mehr Infos?
        Was hast Du vorher getan?
        node -v?
        npm -v?
        ...</ironie-aus></ironie-ein>
          meisterlemon
          node ist v 10.5
          npm ist 4.6.1
          Habe es updaten müssen und seit dem geht nichts mehr, sollte node aktualisieren und hatte eine Anleitung hier aus dem netz gemacht und seit dem geht es nicht mehr
          VCDS vorhanden
            Was hattest Du vorher für eine Node.js Version? bei versionssprüngen muss man die Teile die nativ bei der installation gebaut werden neu bauen.
            Geh mal in das ioBroker Verzeichnis und ruf
            sudo npm rebuild
            auf. geht es dann?
            Solche Fälle findest Du aber zur Genüge im Forum mit Lösungen und so.
              meisterlemon
              Das kam nach dem aufruf:
              ursaNative.target.mk:97: die Regel für Ziel „Release/obj.target/ursaNative/src/ursaNative.o“ scheiterte
              make: *** [Release/obj.target/ursaNative/src/ursaNative.o] Fehler 1
              make: Verzeichnis „/opt/iobroker/node_modules/ursa/build“ wird verlassen
              gyp ERR! build error
              gyp ERR! stack Error: `make` failed with exit code: 2
              gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:285:23)
              gyp ERR! stack     at ChildProcess.emit (events.js:182:13)
              gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:237:12)
              gyp ERR! System Linux 4.9.0-4-amd64
              gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
              gyp ERR! cwd /opt/iobroker/node_modules/ursa
              gyp ERR! node -v v10.5.0
              gyp ERR! node-gyp -v v3.6.0
              gyp ERR! not ok
              npm ERR! code ELIFECYCLE
              npm ERR! errno 1
              npm ERR! ursa@0.9.4 install: `node-gyp rebuild`
              npm ERR! Exit status 1
              npm ERR!
              npm ERR! Failed at the ursa@0.9.4 install script.
              npm ERR!     /root/.npm/_logs/2018-06-26T16_03_50_493Z-debug.log
              Ich weiß nicht welche Version drauf war um ehrlich zu sein, wie baue ich das denn neu auf????
              VCDS vorhanden
                Dann installier ggf mal js-Controller neu drüber
                Gesendet vom Handy …
                  meisterlemon
                  Hab ich damit gemacht ;
                  sudo npm install iobroker.js-controller@0.5.15
                  nun startet der iobroker zwar im terminal aber auf den browser per ip geht es nicht, ist nicht aufrufbar
                  VCDS vorhanden
                    0.5.15?! Wir sind bei 1.2.3 im stable …
                    Gesendet vom Handy ...
                      meisterlemon
                      installiere ich die 1.2.3 dann kommt die fehlermeldung wieder…..
                      update:
                      Ich habe es nun soweit hinbekommen das es bei node die version 10.4.1 keine fehlermeldung mehr kommt wenn ich den befehl iobroker start oder restart eingebe. Aber ich komme einfach nicht über die IP auf die Oberfläche
                      root@debian:/opt/iobroker# npm -v
                      6.1.0
                      root@debian:/opt/iobroker# node -v
                      v10.4.1
                      VCDS vorhanden
                        Der Admin Adapter läuft als Prozess? Ggf den Port neu setzen oder zweite neue Instanz?
                          meisterlemon
                          Ja:
                          root@debian:/opt/iobroker# iobroker list instances
                          system.adapter.admin.0                 : admin       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          aber die oberfläche vis oder admin geht trotzdem nicht, wie kriegen wir das nun zum Starten?
                          VCDS vorhanden
                          • V Offline
                            V Offline
                            valbuz
                            Hallo
                            Brauche da auch mal einen Rat.
                            Habe soeben alle Updates der Adapter incl. Admin 3.4.7 gemacht.
                            Folgende Versionen sind bei mir noch aktuell drauf:
                            NPM: 3.10.10
                            Node: 6.12.0
                            NodeJS: 6.12.0
                            Soll/Muss ein Update hier gemacht werden? Wenn ja, auf welche Version würdet Ihr mir raten? 😢
                            Pat
                            2xProxmox auf NUC
                            E3DC 13kWh Speicher via RCSP an ioBroker
                            • AlCalzoneA Offline
                              AlCalzoneA Offline
                              AlCalzone
                              Aktuell kannst bei den Versionen bleiben. Wenns unbedingt ein Update sein muss (warum auch immer), dann auf NodeJS 8.
                              Aber ganz wichtig: NPM-Version überprüfen und wenn nötig eine unterstützte Version (4 oder ab 5.7.1) installieren.
                              • V Offline
                                V Offline
                                valbuz
                                Danke!
                                Ist mir auch lieber so…. ;)
                                2xProxmox auf NUC
                                  K-L-S
                                  Hallo, ich habe Node.js 10.14.1 und NPM 6.4.1 im Einsatz.
                                  Beim löschen des Protokolls kommt es bei mir zu folgendem Fehler:
                                  siehe Anhang
                                  Danach erfolgt ein iobroker _restart
                                  ioBroker läfut auf Windows 10 1809
                                  Was kann ich tun?
                                    Bite die vollständige Fehlermeldung aus dem Log auf der Platte (siehe meine Signatur) rausholen und senden als Github issueim js-controller Projekt. Ist leider abgeschnitten. Danke
                                      K-L-S
                                      Danke,
                                      Issue ist eingestellt.
                                        Kylo Ren
                                        Kann man zwischenzeitlich auf Nodejs 10 updaten? Bin momentan noch bei 8 und ich nutze auch den ZWave-Adapter.
                                        ioBroker auf Debian 12 (ESXi) • Echo dot • Steckdosen mit Tasmota • Broadlink RM pro • rund 20 Shellys • FritzBox 6490 + 7490 • 12 x Fritz!Dect 301
                                          Ist nicht empfohlen.
                                          Du bräuchtest js.controller 1.5.x vom GitHub und aktuell machen noch Bluetooth-Adapter Probleme weil es da erst seit ein paar Tagen node10 support für eine Bluetooth Library gibt …
